    4. Bambulab 3d-Drucker adapter
    • Dutchman
      Dutchman Developer Most Active Administrators @DarkDevil last edited by
      @darkdevil sagte in Bambulab 3d-Drucker adapter:
      Ich hoffe, dass das der richtige Eintrag ist
      jep 🙂
      ok ich hatte erwartet das dan gar kein Datenpunkt AMS kommt, AMS ist aber da nur halt lehr dadurch knallt der code
      Fixed in jetziger git versions, bitte mal neu ziehen und probieren 🙂
        Leider nicht, es bleibt beim Fehler
        Dutchman 2 Replies Last reply Reply Quote 0
        • Dutchman
          der Fehler ist noch 1:1 der selbe ?
          • Dutchman
            bitte nochmal von git probieren, ich habe da noch was gefunden und ergänzt
              DarkDevil @Dutchman last edited by
              @dutchman
              auch nach dem letzten Update bekomme ich die Fehler. Die Print Message lautet immer noch:
              	Printer Message {"print":{"upload":{"status":"idle","progress":0,"message":""},"nozzle_temper":21.125,"nozzle_target_temper":0,"bed_temper":19.5,"bed_target_temper":0,"chamber_temper":5,"mc_print_stage":"1","heatbreak_fan_speed":"0","cooling_fan_speed":"0","big_fan1_speed":"0","big_fan2_speed":"0","mc_percent":0,"mc_remaining_time":0,"ams_status":0,"ams_rfid_status":6,"hw_switch_state":1,"spd_mag":100,"spd_lvl":2,"print_error":83935249,"lifecycle":"product","wifi_signal":"-52dBm","gcode_state":"IDLE","gcode_file_prepare_percent":"0","queue_number":0,"project_id":"0","profile_id":"0","task_id":"0","subtask_id":"0","subtask_name":"","gcode_file":"","stg":[],"stg_cur":0,"print_type":"idle","home_flag":16904,"mc_print_line_number":"0","mc_print_sub_stage":0,"sdcard":true,"force_upgrade":false,"mess_production_state":"active","layer_num":0,"total_layer_num":0,"hms":[],"online":{"ahb":false,"rfid":false,"version":87449353},"ams":{"ams":[],"ams_exist_bits":"0","tray_exist_bits":"0","tray_is_bbl_bits":"0","tray_tar":"255","tray_now":"254","tray_pre":"254","tray_read_done_bits":"0","tray_reading_bits":"0","version":1,"insert_flag":true,"power_on_flag":false},"ipcam":{"ipcam_dev":"1","ipcam_record":"enable","timelapse":"disable","mode_bits":3},"vt_tray":{"id":"254","tag_uid":"0000000000000000","tray_id_name":"","tray_info_idx":"","tray_type":"","tray_sub_brands":"","tray_color":"00000000","tray_weight":"0","tray_diameter":"0.00","tray_temp":"0","tray_time":"0","bed_temp_type":"0","bed_temp":"0","nozzle_temp_max":"0","nozzle_temp_min":"0","xcam_info":"000000000000000000000000","tray_uuid":"00000000000000000000000000000000","remain":0,"k":0.019999999552965164,"n":1.399999976158142},"lights_report":[{"node":"chamber_light","mode":"off"}],"upgrade_state":{"sequence_id":0,"progress":"","status":"","consistency_request":false,"dis_state":0,"err_code":0,"force_upgrade":false,"message":"","module":"","new_version_state":2,"new_ver_list":[]},"command":"push_status","msg":0,"sequence_id":"19"}}
              Dutchman 1 Reply Last reply Reply Quote 1
              • Dutchman
                Hmm sehr merkwürdig, ich habe mir deine MQTT Nachricht in de adapter kopiert und erhalte selbe diese Fehler nicht 😕
                Habe aber auch noch eine kleine optimalisierung gemacht im code, ziehe mal bitte nochmal neu von git und beachte das Jetzt auch die version 1.5 installiert wird ich erhoffe mir das es damit erledigt ist 🙂
                  @dutchman ich habe den adapter vorhin einmal komplett gelöscht und von github die version 1.5. geladen.
                  der Fehler hat sich verändert 😕
                  	[messageHandler] TypeError: Cannot read properties of undefined (reading 'ams_exist_bits') | TypeError: Cannot read properties of undefined (reading 'ams_exist_bits') at Bambulab.messageHandler (/opt/iobroker/node_modules/iobroker.bambulab/main.js:199:57) at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.bambulab/main.js:107:11) at MqttClient.emit (node:events:513:28) at MqttClient._handlePublish (/opt/iobroker/node_modules/mqtt/lib/client.js:1547:12) at MqttClient._handlePacket (/opt/iobroker/node_modules/mqtt/lib/client.js:535:12) at work (/opt/iobroker/node_modules/mqtt/lib/client.js:438:12) at Writable.writable._write (/opt/iobroker/node_modules/mqtt/lib/client.js:452:5) at doWrite (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139) at writeOrBuffer (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5) at Writable.write (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11)
                  • Dutchman
                    Dutchman Developer Most Active Administrators @DarkDevil last edited by Dutchman
                    Bitte noch einmal neu von git ziehen habe da noch eine Stelle geändert
                    Edit: Per chat bestaetigt das es hiermit geloest ist 🙂
                    BjoernF 1 Reply Last reply Reply Quote 0
                    • BjoernF
                      BjoernF @Dutchman last edited by BjoernF
                      @dutchman Genial dass du hier an einem Adapter arbeitest. Ich behelfe mir aktuell noch mit einer Connection über Home Assistant die ich mir dann in IOB rüber ziehe.
                      Nebst den Funktionen die du schon auf der Liste hast, wären noch folgende Statusabfragen interessant, die man sich ggf. in die VIS einbauen könnte.
                      • Pinterstatus (Printing, idle, error usw.)
                      • PrintProgress
                      • remaining time
                      • print time
                      • Bed temperature
                      • Nozzle Temperature
                      • AMS infos (tray details)
                      • Current layer
                      • und und und 🙂 in HA sind echt viele Status Daten drin, die er sich aus dem Drucker per MQTT zieht, wäre super wenn man die auch in den IOB Adapter zur Verfügung hätte, dann könnte die Brücke über HA wieder raus 😉
                      EDIT: Erinnerung an mich selbst, erst checken dann labern LOL sehe nun dass ja alles oben genannte bereits drin ist im Adapter!
                      GEILE ARBEIT!
                      VG BJörn
                      • Dutchman
                        Dutchman Developer Most Active Administrators @BjoernF last edited by
                        @bjoernf sagte in Bambulab 3d-Drucker adapter:
                        GEILE ARBEIT!
                        danke fuer die blumen 🙂 ja glaube von deiner liste habe ich alles drin 😉
                        BjoernF 1 Reply Last reply Reply Quote 1
                        • BjoernF
                          @dutchman wobei print end time konnte ich jetzt noch nicht finden in den DPs
                          • Dutchman
                            Dutchman Developer Most Active Administrators @BjoernF last edited by Dutchman
                            Hmm end Zeit nicht, remaining time wohl.
                            Da der Wert nicht vom Drucker kommt könnte man aber ne Berechnung einbauen
                            Wen gewünscht bitte kleine issue auf git mit der info erstellen dan arbeite ich die issues ab und Beier es bei einer nächsten Version ein
                              SoerenKaiser99 @Dutchman last edited by
                              @dutchman ich habe seit eben einen P1S. Kann ich helfen beim Testen?
                              • Webranger
                                Webranger last edited by
                                Seit Donnerstg steht nun ein x1C bei mir im Keller.
                                Hab den Adapter ohne Probleme installieren können.
                                Ich seh allerding glaube ich nicht alle Datenpunkte.
                                z.B. sind bei mir nicht zu finden:
                                Pinterstatus (Printing, idle, error usw.), PrintProgress, remaining time, print time, Bed temperature, Nozzle Temperature, AMS infos (tray details), Current layer
                                Bei mir sieht es so aus:
                                Hab ich irgendwas vergessen?
                                Gruss Danyel
                                A Dutchman 2 Replies Last reply Reply Quote 1
                                  spoeh-man last edited by
                                  bei mir wirft der adapter ständig Fehler
                                  	[messageHandler] TypeError: Cannot read properties of undefined (reading 'ams') | TypeError: Cannot read properties of undefined (reading 'ams') at Bambulab.messageHandler (/opt/iobroker/node_modules/iobroker.bambulab/main.js:199:57) at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.bambulab/main.js:107:11) at MqttClient.emit (node:events:514:28) at MqttClient._handlePublish (/opt/iobroker/node_modules/mqtt/lib/client.js:1547:12) at MqttClient._handlePacket (/opt/iobroker/node_modules/mqtt/lib/client.js:535:12) at work (/opt/iobroker/node_modules/mqtt/lib/client.js:438:12) at writable._write (/opt/iobroker/node_modules/mqtt/lib/client.js:452:5) at doWrite (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139) at writeOrBuffer (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5) at Writable.write (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11)
                                    Apropo @Webranger last edited by
                                    @webranger Sieht bei mir leider genauso aus. Hast du inzwischen raus gefunden woran es liegt?
                                    Und wie ist das mit der Seriennummer? Muss man die nur beim P1P angeben? Ich finde die bei meinem X1CC in den Netzwerkeinstellungen nicht.
                                    Webranger tugsi 2 Replies Last reply Reply Quote 0
                                    • Webranger
                                      Webranger @Apropo last edited by
                                      @apropo nein der Fehler ist immer noch aber der Entwickler ist dran. Zu der Seriennummer, die musste ich bei mir auch erst suchen aber steht irgendwo kann dir aber auch wirklich gerade nicht sagen wo.
                                      • tugsi
                                        tugsi @Apropo last edited by
                                        @apropo Seriennummer findest Du in der Handy-App unter Einstellungen - Firmware-Version
                                        Die Fehlermeldungen hab ich auch.
                                        Matzebhv 1 Reply Last reply Reply Quote 0
                                        • Matzebhv
                                          Matzebhv @tugsi last edited by
                                          Ich habe den Adapter erstmal wegen des Fehlers deaktiviert, sobald der Drucker läuft wird das Log komplett geflutet.
                                          Matze
                                          BTW, was ein geiler Drucker ( X1 )
                                            djalexz last edited by
                                            Sehr sehr GEIL
                                            1000 Dank @Dutchman für den Adapter.
                                            Richtig nice. Bin echt begeistert 😄
                                            Ich werde in den nächsten Tagen mal alles durchtesten und entsprchend kommentieren.
                                            Wenn wir es jetzt noch hinbekommen diese dämliche Kamera vom Bambu im ioBroker anzeigen zu lassen, sind keine Wünsche mehr offen und der Drucker ist vollumfänglich im Smarthome integriert.
                                            PS. Die ganzen Anregungen im Bambulab GIT von wegen RTSPS, HomeAssistant und Co. funktionieren beim ioBroker nicht.
                                            Wie dem auch sei. Nochmals vielen vielen Dank für die Arbeit und ich freue mich zu Testen.
                                            LG Alex
                                            273
                                            86812
