    4. (gelöst) Beim öffnen der GUI vermehrt Timeouts.
    • ESP8266
      ESP8266 @Thomas Braun last edited by ESP8266
      @thomas-braun , icxh arbeite mit schon immer mit Putty. Dort kann man kopieren oder in ein Log schreiben.
        Thomas Braun Most Active @ESP8266 last edited by
        @esp8266
        Hier in CodeTags eingebettet reinkopieren.
        • ESP8266
          ESP8266 @Thomas Braun last edited by Homoran
          @thomas-braun ,als doch ohne.
          *** ioBroker Diagnosis ***
          Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
          The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
          https://forum.iobroker.net
          Just copy and paste the Summary Page, including the ``` characters at start and end.
          It helps us to help you!
          Press any key to continue
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Model		: Raspberry Pi 4 Model B Rev 1.2
          Architecture    : aarch64
          Docker          : false
          Virtualization  : none
          Distributor ID:	Raspbian
          Description:	Raspbian GNU/Linux 11 (bullseye)
          Release:	11
          Codename:	bullseye
          PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
          NAME="Raspbian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=raspbian
          ID_LIKE=debian
          HOME_URL="http://www.raspbian.org/"
          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
          Systemuptime and Load:
           13:03:30 up  1:35,  3 users,  load average: 3.08, 3.09, 2.72
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          Other values than 0x0 hint to temperature/voltage problems
          temp=43.8'C
          volt=0.8438V
          *** Time and Time Zones ***
                         Local time: Mon 2023-07-31 13:03:30 CEST
                     Universal time: Mon 2023-07-31 11:03:30 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server: 	true
          Desktop:
          Terminal: 	tty
          Boot Target: 	graphical.target
          *** MEMORY ***
          Mem:            3.7G        2.2G        269M         35M        1.3G        1.4G
          Swap:            99M          0B         99M
          Total:          3.8G        2.2G        369M
                   3743 M total memory
                   2189 M used memory
                   2407 M active memory
                    644 M inactive memory
                    269 M free memory
                    139 M buffer memory
                   1145 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4      110G  6.0G  101G   6% /
          devtmpfs       devtmpfs  1.6G     0  1.6G   0% /dev
          tmpfs          tmpfs     1.9G   24K  1.9G   1% /dev/shm
          tmpfs          tmpfs     749M  1.3M  748M   1% /run
          /dev/sda1      vfat      255M   51M  205M  20% /boot
          tmpfs          tmpfs     375M   20K  375M   1% /run/user/1000
          [Mon Jul 31 11:27:49 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:8B:67:E3 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=7df941dc-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Mon Jul 31 11:27:52 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Mon Jul 31 11:27:52 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Mon Jul 31 11:27:54 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
          [Mon Jul 31 11:27:59 2023] EXT4-fs (sda2): resizing filesystem from 1420632 to 29240320 blocks
          [Mon Jul 31 11:28:02 2023] EXT4-fs (sda2): resized filesystem to 29240320
          Show mounted filesystems (real ones only):
          TARGET  SOURCE    FSTYPE OPTIONS
          /       /dev/sda2 ext4   rw,noatime
          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          524M	/var/
          182M	/var/log
          177M	/var/log/journal/7c7da7cd88a44588896e76ac0de90413
          125M	/var/lib
          Archived and active journals take up 176.0M in the file system.
          /opt/iobroker/backups:
          4.0K	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          493M	/opt/iobroker/iobroker-data/
          452M	/opt/iobroker/iobroker-data/files
          88M	/opt/iobroker/iobroker-data/files/echarts.admin
          57M	/opt/iobroker/iobroker-data/files/echarts
          51M	/opt/iobroker/iobroker-data/files/javascript.admin
          33M	/opt/iobroker/iobroker-data/objects.jsonl
          33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
          23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
          23M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v18.17.0
          /usr/bin/node 		v18.17.0
          /usr/bin/npm 		9.6.7
          /usr/bin/npx 		9.6.7
          nodejs:
            Installed: 18.17.0-deb-1nodesource1
            Candidate: 18.17.0-deb-1nodesource1
            Version table:
           *** 18.17.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u4 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          MULTIHOSTSERVICE/enabled: false
          Core adapters versions
          js-controller: 	5.0.11
          admin: 		6.6.4
          javascript: 	7.1.1
          Adapters from github: 	5
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled, compact disabled
          + system.adapter.apsystems-ecu.0          : apsystems-ecu         : iobroker                                 -  enabled, compact disabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
          + system.adapter.backitup.1               : backitup              : iobroker                                 -  enabled, compact disabled
          + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled, compact disabled
          + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled, compact disabled
            system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled, compact disabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled, compact disabled
            system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled, compact disabled
          + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
          + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
          + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled, compact disabled
            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled, compact enabled (group 1)
          + system.adapter.g-homa.0                 : g-homa                : iobroker                                 -  enabled, compact disabled
          + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled, compact disabled
          + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled, compact disabled
          + system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled, compact disabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
          + system.adapter.kodi.0                   : kodi                  : iobroker                                 -  enabled, compact enabled (group 1), port: 9090
          + system.adapter.maxcul.0                 : maxcul                : iobroker                                 -  enabled, compact disabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 192.168.62.15
          + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1888, bind: 0.0.0.0
          + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled, compact disabled
          + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled, compact disabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 192.168.62.15
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 192.168.62.15
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled, compact disabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled, compact disabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled, compact disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled, compact disabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.withings.0               : withings              : iobroker                                 -  enabled, compact disabled
            system.adapter.wled.0                   : wled                  : iobroker                                 - disabled, compact disabled
          + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled, compact disabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, compact disabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): beta
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 6.6.4    , installed 6.6.4
          Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
          Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
          Adapter    "denon"        : 1.15.3   , installed 1.15.3
          Adapter    "device-reminder": 1.2.9  , installed 1.2.9
          Adapter    "discovery"    : 3.2.0    , installed 3.2.0
          Adapter    "echarts"      : 1.5.1    , installed 1.5.1
          Adapter    "enigma2"      : 1.5.0    , installed 1.5.0
          Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
          Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
          Adapter    "g-homa"       : 0.5.3    , installed 0.5.3
          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
          Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
          Adapter    "history"      : 2.2.4    , installed 2.2.4
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "info"         : 1.9.26   , installed 1.9.26
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "javascript"   : 7.1.1    , installed 7.1.1
          Controller "js-controller": 5.0.11   , installed 5.0.11
          Adapter    "kodi"         : 2.0.9    , installed 2.0.9
          Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "octoprint"    : 5.0.1    , installed 5.0.1
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "socketio"     : 6.4.0    , installed 6.4.0
          Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
          Adapter    "telegram"     : 1.16.0   , installed 1.16.0
          Adapter    "text2command" : 3.0.2    , installed 3.0.2
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "web"          : 6.0.3    , installed 6.0.3
          Adapter    "withings"     : 0.0.13   , installed 0.0.13
          Adapter    "wled"         : 0.7.0    , installed 0.7.0
          Adapter    "ws"           : 2.4.0    , installed 2.4.0
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee"       : 1.8.18   , installed 1.8.18
          Objects and States
          Objects: 	14839
          States: 	12289
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 https://deb.nodesource.com/node_18.x bullseye InRelease
          Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          845        629/ebusd
          tcp        0      0 0.0.0.0:37509           0.0.0.0:*               LISTEN      1001       94812      18232/io.yahka.0
          tcp        0      0 192.168.62.15:1885      0.0.0.0:*               LISTEN      1001       83890      16433/io.mqtt.0
          tcp        0      0 192.168.62.15:1884      0.0.0.0:*               LISTEN      1001       83889      16433/io.mqtt.0
          tcp        0      0 192.168.62.15:1883      0.0.0.0:*               LISTEN      1001       85303      16566/io.sonoff.0
          tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      116        106820     19527/python3
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15826      651/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          51895      1/init
          tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      116        106799     19542/motion
          tcp        0      0 192.168.62.15:9095      0.0.0.0:*               LISTEN      1001       83597      16159/io.fakeroku.0
          tcp        0      0 192.168.62.15:9094      0.0.0.0:*               LISTEN      1001       83596      16159/io.fakeroku.0
          tcp        0      0 192.168.62.15:9093      0.0.0.0:*               LISTEN      1001       83595      16159/io.fakeroku.0
          tcp        0      0 0.0.0.0:54805           0.0.0.0:*               LISTEN      106        53321      9137/rpc.statd
          tcp        0      0 0.0.0.0:8011            0.0.0.0:*               LISTEN      116        106798     19542/motion
          tcp        0      0 0.0.0.0:8010            0.0.0.0:*               LISTEN      116        106797     19542/motion
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17282      1294/cupsd
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53241      9687/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       55128      9687/iobroker.js-co
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       83659      16231/io.harmony.0
          tcp6       0      0 :::54263                :::*                    LISTEN      106        53325      9137/rpc.statd
          tcp6       0      0 :::50000                :::*                    LISTEN      1001       81744      16217/io.g-homa.0
          tcp6       0      0 :::21                   :::*                    LISTEN      0          15721      615/vsftpd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15828      651/sshd: /usr/sbin
          tcp6       0      0 :::111                  :::*                    LISTEN      0          51901      1/init
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17281      1294/cupsd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       99362      18529/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       86980      17138/io.web.0
          udp        0      0 0.0.0.0:53148           0.0.0.0:*                           1001       84378      16042/io.broadlink2
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15104      531/dhcpcd
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          51897      1/init
          udp        0      0 0.0.0.0:57555           0.0.0.0:*                           1001       81474      16042/io.broadlink2
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       85726      16792/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       85727      16792/io.tuya.0
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       83660      16231/io.harmony.0
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18802      1295/cups-browsed
          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       84373      16042/io.broadlink2
          udp        0      0 127.0.0.1:833           0.0.0.0:*                           0          53314      9137/rpc.statd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       94817      18232/io.yahka.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       94816      18232/io.yahka.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15657      447/avahi-daemon: r
          udp        0      0 0.0.0.0:46393           0.0.0.0:*                           106        53319      9137/rpc.statd
          udp        0      0 0.0.0.0:58847           0.0.0.0:*                           108        15659      447/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       85301      16530/io.shelly.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       83598      16159/io.fakeroku.0
          udp6       0      0 :::111                  :::*                                0          51905      1/init
          udp6       0      0 :::44227                :::*                                108        15660      447/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        15658      447/avahi-daemon: r
          udp6       0      0 :::38260                :::*                                106        53323      9137/rpc.statd
          iob diag has finished.
          Press any key for a summary
          Copy text starting here:
          		     v.2023-04-16
          Operatingsystem: 	Raspbian GNU/Linux 11 (bullseye)
          Kernel: 		6.1.21-v8+
          Installation: 		Native
          Timezone: 		Europe/Berlin (CEST, +0200)
          User-ID: 		1000
          X-Server: 		true
          Pending OS-Updates: 	0
          Pending iob updates: 	0
          Nodejs-Installation: 	/usr/bin/nodejs 	v18.17.0
          			/usr/bin/npm 		9.6.7
          			/usr/bin/npx 		9.6.7
          Recommended versions are nodejs 18.x.y and npm 9.x.y
          MEMORY:
          Mem:            3.7G        2.3G        156M         35M        1.3G        1.3G
          Swap:            99M          0B         99M
          Total:          3.8G        2.3G        256M
          Active iob-Instances: 	37
          ioBroker Core: 		js-controller 		5.0.11
          			admin 			6.6.4
          ioBroker Status: 	iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          Objects: 		14839
          States: 		12289
          Size of iob-Database:
          7.8M	/opt/iobroker/iobroker-data/states.jsonl
            @esp8266
            Da läuft einfach zu viel unnötiges Zeuch. Ein voller X-Server mit allem Zipp und Zapp z. B.
            Abschalten, über Terminal bedienen.
            Schalt den Compact Mode aus.
            shelly.0 und mqtt.0 lauschen auf dem gleichen Port.
            • ESP8266
              @thomas-braun, unnötiges Zeug? Für mich ist das alles Relevant. Ich arbeite hier schon allein mit nur einer Fernbedienung. Damit steuere ich 9 Geräte. Dazu brauch ich fakeroku und den Harmony Adaper. 2 Instanzen für Mqtt. Die 2. Instanz allein ist schon für die Wetterstation.
              Unnütziges sehe ich nicht.
              Gut die gleichen Ports werde ich überprüfen.
              Wo lässt sich der Compact Mode ausschalten?
              btw. Im Shelly Adapter lässt sich kein Port ändern. Läuft übrigens nicht mit MQTT sondern Coap.
              • ESP8266
                ESP8266 @ESP8266 last edited by ESP8266
                @esp8266 sagte in Beim öffnen der GUI vermehrt Timeouts.:
                @thomas-braun,
                Erledigt.
                Ich setzte es auf gelöst. Erstmal....weiter beobachten.
                  Thomas Braun Most Active last edited by
                  Der mqtt.0 läuft aber auf dem gleichen Port.
                  Und ein X-Server (und alles was da dranhängt, cupsd z.B.), ist immer unnütz auf einem iobroker-Server.
                  • ESP8266
                    @thomas-braun , Lösung?
                    Bin ich jetzt Blind. Wo kann ich die Themenüberschrift ändern?
                    Finde keine Option.
                    Bitte ein Mod die Überschrift auf (gelöst) abändern.
                    • bahnuhr
                      bahnuhr Forum Testing Most Active @ESP8266 last edited by
                      in #1
                      (hast doch aber auch schon 600 Beiträge; noch nie gemacht ?)
                      • ESP8266
                        ESP8266 @bahnuhr last edited by ESP8266
                        @bahnuhr , ich habe auch schon Themen abgeändert. Jahre her....so oft brauchte ich keine Hilfe um welche zu erstellen.
                        Nur finde ich auf der Seite nichts mehr....wenn ich nicht fragen würde, hätte ich die Option schon gefunden....
                        Es gibt hier nur die Option seine Beiträge zu bearbeiten. Das sollte sich mal ein Web-Masteranschauen.
                        Nichts....
                        • BBTown
                          BBTown @ESP8266 last edited by
                          @esp8266 Du kannst (als der Ersteller dieses Threads) den ersten Beitrag editieren
                          Somit kannst Du im ersten Beitrag die Überschrift ändern (diese ist relevant für den Titel des Threads)
                          ESP8266 1 Reply Last reply Reply Quote 1
                          • ESP8266
                            ESP8266 @BBTown last edited by
                            @bbtown , nun ist der Groschen gefallen. Ich mach nicht wegen irgenwas gleich Themen auf.....wenn nur in seltenen Fällen.
                            Nochmals 👍
                              e-i-k-e last edited by e-i-k-e
                              Ich habe auch ab und zu Timeouts.
                              Fällt euch bei meinem "iob diag" etwas auf?
                              Skript v.2023-04-16
                              *** BASE SYSTEM ***
                              Architecture    : x86_64
                              Docker          : false
                              Virtualization  : kvm
                              Distributor ID: Ubuntu
                              Description:    Ubuntu 22.04.2 LTS
                              Release:        22.04
                              Codename:       jammy
                              PRETTY_NAME="Ubuntu 22.04.2 LTS"
                              NAME="Ubuntu"
                              VERSION_ID="22.04"
                              VERSION="22.04.2 LTS (Jammy Jellyfish)"
                              VERSION_CODENAME=jammy
                              ID=ubuntu
                              ID_LIKE=debian
                              HOME_URL="https://www.ubuntu.com/"
                              SUPPORT_URL="https://help.ubuntu.com/"
                              BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
                              PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-poli        cy"
                              UBUNTU_CODENAME=jammy
                               21:52:32 up 3 days,  5:12,  2 users,  load average: 1.10, 1.74, 1.59
                              CPU threads: 8
                                             Local time: Mon 2023-07-31 21:52:32 CEST
                                         Universal time: Mon 2023-07-31 19:52:32 UTC
                                               RTC time: Mon 2023-07-31 19:52:32
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              pi adm cdrom sudo dip plugdev lxd iobroker
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            5.9G        4.1G        534M        1.0M        1.3G        1.6G
                              Swap:           2.9G        0.0K        2.9G
                              Total:          8.9G        4.1G        3.5G
                                       5925 M total memory
                                       4073 M used memory
                                        605 M active memory
                                       4360 M inactive memory
                                        534 M free memory
                                        127 M buffer memory
                                       1188 M swap cache
                                       2947 M total swap
                                          0 M used swap
                                       2947 M free swap
                              *** FILESYSTEM ***
                              Filesystem                        Type   Size  Used Avail Use% Mounted on
                              tmpfs                             tmpfs  593M  1.2M  592M   1% /run
                              /dev/mapper/ubuntu--vg-ubuntu--lv ext4    15G   13G 1000M  93% /
                              tmpfs                             tmpfs  2.9G     0  2.9G   0% /dev/shm
                              tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                              /dev/sda2                         ext4   2.0G  254M  1.6G  14% /boot
                              /dev/sda1                         vfat   1.1G  6.1M  1.1G   1% /boot/efi
                              tmpfs                             tmpfs  593M  4.0K  593M   1% /run/user/1000
                              [Fri Jul 28 16:40:25 2023] EXT4-fs (dm-0): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
                              [Fri Jul 28 16:40:27 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode:        none.
                              [Fri Jul 28 16:40:29 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
                              /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
                              |-/snap/core20/1950 /dev/loop0                        squashfs ro,nodev,relatime        ,errors=continue
                              |-/snap/core20/1974 /dev/loop1                        squashfs ro,nodev,relatime        ,errors=continue
                              |-/snap/lxd/24322   /dev/loop2                        squashfs ro,nodev,relatime        ,errors=continue
                              |-/snap/snapd/19457 /dev/loop4                        squashfs ro,nodev,relatime        ,errors=continue
                              |-/snap/snapd/19361 /dev/loop3                        squashfs ro,nodev,relatime        ,errors=continue
                              `-/boot             /dev/sda2                         ext4     rw,relatime
                                `-/boot/efi       /dev/sda1                         vfat     rw,relatime,fmask        =0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount        -ro
                              /var:
                              1.8G    /var/
                              962M    /var/log
                              953M    /var/log/journal/65cc3a3537eb488f8788ce0a60cda8d3
                              665M    /var/lib
                              Archived and active journals take up 952.1M in the file system.
                              607M    /opt/iobroker/backups/
                              125M    /opt/iobroker/iobroker-data/
                              44M     /opt/iobroker/iobroker-data/files
                              40M     /opt/iobroker/iobroker-data/eusec.0/T8010P2322140527/last_live
                              34M     /opt/iobroker/iobroker-data/objects.jsonl
                              7.5M    /opt/iobroker/iobroker-data/states.jsonl
                              7.3M    /opt/iobroker/iobroker-data/files/vis.0/Icons/Mond/Monde.psd
                              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
                              5.1M    /opt/iobroker/iobroker-data/files/vis.0/Beispiel_neu/vis-views.json
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
                              nodejs:
                                Version table:
                                      500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
                                   12.22.9~dfsg-1ubuntu3 500
                                      500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                              ioBroker Status
                              At least one iobroker host is running.
                              Objects type: redis
                              States  type: redis
                              js-controller:  5.0.9
                              admin:          6.6.4
                              javascript:     7.1.1
                              Adapters from github:   1
                              Adapter State
                              + system.adapter.admin.2                  : admin                 : ioBroker-Rock                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                              + system.adapter.admin.3                  : admin                 : ioBroker-Rock                            -  enabled, port: 8900, bind: 0.0.0.0, run as: admin
                              + system.adapter.alarm.0                  : alarm                 : ioBroker-Rock                            -  enabled
                              + system.adapter.alexa2.0                 : alexa2                : ioBroker-Rock                            -  enabled
                              + system.adapter.backitup.0               : backitup              : ioBroker-Rock                            -  enabled
                                system.adapter.boscheasycontrol.0       : boscheasycontrol      : ioBroker-Rock                            - disabled
                              + system.adapter.cloud.0                  : cloud                 : ioBroker-Rock                            -  enabled
                                system.adapter.daswetter.0              : daswetter             : ioBroker-Rock                            -  enabled
                              + system.adapter.device-reminder.0        : device-reminder       : ioBroker-Rock                            -  enabled
                              + system.adapter.device-watcher.0         : device-watcher        : ioBroker-Rock                            -  enabled
                              + system.adapter.discovergy.0             : discovergy            : ioBroker-Rock                            -  enabled
                                system.adapter.discovery.0              : discovery             : ioBroker-Rock                            - disabled
                                system.adapter.dwd.0                    : dwd                   : ioBroker-Rock                            -  enabled
                              + system.adapter.echarts.0                : echarts               : ioBroker-Rock                            -  enabled
                                system.adapter.eusec.0                  : eusec                 : ioBroker-Rock                            - disabled
                                system.adapter.feiertage.0              : feiertage             : ioBroker-Rock                            -  enabled
                                system.adapter.flot.0                   : flot                  : ioBroker-Rock                            -  enabled
                              + system.adapter.heatingcontrol.1         : heatingcontrol        : ioBroker-Rock                            -  enabled
                              + system.adapter.hm-rega.0                : hm-rega               : ioBroker-Rock                            -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                              + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                              + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                              + system.adapter.hoover.0                 : hoover                : ioBroker-Rock                            -  enabled
                                system.adapter.ical.0                   : ical                  : ioBroker-Rock                            -  enabled
                                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-Rock                            -  enabled
                                system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-Rock                            -  enabled
                                system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-Rock                            -  enabled
                                system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-Rock                            -  enabled
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-Rock                            -  enabled
                                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-Rock                            -  enabled
                              + system.adapter.influxdb.0               : influxdb              : ioBroker-Rock                            -  enabled, port: 8086
                                system.adapter.iqontrol.0               : iqontrol              : ioBroker-Rock                            - disabled
                              + system.adapter.javascript.0             : javascript            : ioBroker-Rock                            -  enabled
                              + system.adapter.javascript.2             : javascript            : raspberrypi-display1                     -  enabled
                              + system.adapter.javascript.3             : javascript            : raspberrypi-display4                     -  enabled
                              + system.adapter.javascript.4             : javascript            : raspberrypi-display2                     -  enabled
                              + system.adapter.javascript.5             : javascript            : raspberrypi-display5                     -  enabled
                              + system.adapter.midea.0                  : midea                 : ioBroker-Rock                            -  enabled
                                system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-Rock                            - disabled, port: 54321, bind: 0.0.0.0
                                system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker-Rock                            - disabled, port: 54321, bind: 0.0.0.0
                              + system.adapter.mihome.0                 : mihome                : ioBroker-Rock                            -  enabled, port: 9898, bind: 192.168.3.100
                              + system.adapter.milight-smart-light.0    : milight-smart-light   : ioBroker-Rock                            -  enabled
                              + system.adapter.modbus.0                 : modbus                : ioBroker-Rock                            -  enabled
                              + system.adapter.mqtt.0                   : mqtt                  : ioBroker-Rock                            -  enabled, port: 1886, bind: 0.0.0.0
                              + system.adapter.musiccast.0              : musiccast             : ioBroker-Rock                            -  enabled
                              + system.adapter.nut.0                    : nut                   : ioBroker-Rock                            -  enabled
                              + system.adapter.proxmox.0                : proxmox               : ioBroker-Rock                            -  enabled, port: 8006
                              + system.adapter.rpi2.1                   : rpi2                  : raspberrypi-display1                     -  enabled
                              + system.adapter.rpi2.2                   : rpi2                  : raspberrypi-display2                     -  enabled
                              + system.adapter.rpi2.3                   : rpi2                  : raspberrypi-display3                     -  enabled
                              + system.adapter.rpi2.4                   : rpi2                  : raspberrypi-display4                     -  enabled
                              + system.adapter.rpi2.5                   : rpi2                  : raspberrypi-display5                     -  enabled
                              + system.adapter.sainlogic.0              : sainlogic             : ioBroker-Rock                            -  enabled, port: 45000, bind: 192.168.3.100
                              + system.adapter.scenes.0                 : scenes                : ioBroker-Rock                            -  enabled
                              + system.adapter.shelly.0                 : shelly                : ioBroker-Rock                            -  enabled, port: 1890, bind: 0.0.0.0
                              + system.adapter.shelly.1                 : shelly                : ioBroker-Rock                            -  enabled, port: 1899, bind: 0.0.0.0
                              + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker-Rock                            -  enabled
                                system.adapter.simple-api.0             : simple-api            : ioBroker-Rock                            - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                              + system.adapter.smartcontrol.0           : smartcontrol          : ioBroker-Rock                            -  enabled
                              + system.adapter.smartmeter.0             : smartmeter            : ioBroker-Rock                            -  enabled
                              + system.adapter.sonoff.0                 : sonoff                : ioBroker-Rock                            -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker-Rock                            -  enabled
                              + system.adapter.sprinklecontrol.0        : sprinklecontrol       : ioBroker-Rock                            -  enabled
                              + system.adapter.statistics.0             : statistics            : ioBroker-Rock                            -  enabled
                                system.adapter.synology.0               : synology              : ioBroker-Rock                            - disabled, port: 5001
                              + system.adapter.telegram.0               : telegram              : ioBroker-Rock                            -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.text2command.0           : text2command          : ioBroker-Rock                            -  enabled
                                system.adapter.unifi.0                  : unifi                 : ioBroker-Rock                            - disabled
                                system.adapter.vis-bars.0               : vis-bars              : ioBroker-Rock                            -  enabled
                                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-Rock                            -  enabled
                                system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-Rock                            -  enabled
                                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-Rock                            -  enabled
                                system.adapter.vis-history.0            : vis-history           : ioBroker-Rock                            -  enabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-Rock                            -  enabled
                                system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker-Rock                            -  enabled
                              + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-Rock                            -  enabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-Rock                            -  enabled
                                system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-Rock                            -  enabled
                                system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-Rock                            -  enabled
                                system.adapter.vis-material.0           : vis-material          : ioBroker-Rock                            -  enabled
                                system.adapter.vis-metro.0              : vis-metro             : ioBroker-Rock                            -  enabled
                                system.adapter.vis-players.0            : vis-players           : ioBroker-Rock                            -  enabled
                                system.adapter.vis-plumb.0              : vis-plumb             : ioBroker-Rock                            -  enabled
                                system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-Rock                            -  enabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-Rock                            -  enabled
                                system.adapter.vis-weather.0            : vis-weather           : ioBroker-Rock                            -  enabled
                                system.adapter.vis.0                    : vis                   : ioBroker-Rock                            -  enabled
                                system.adapter.web-speedy.0             : web-speedy            : ioBroker-Rock                            - disabled
                              + system.adapter.web.0                    : web                   : ioBroker-Rock                            -  enabled, port: 8082, bind: 192.168.3.100 (SSL), run as: admin
                              + system.adapter.web.1                    : web                   : ioBroker-Rock                            -  enabled, port: 8083, bind: 192.168.3.100, run as: admin
                              + system.adapter.wolf-smartset.0          : wolf-smartset         : ioBroker-Rock                            -  enabled
                              + system.adapter.worx.0                   : worx                  : ioBroker-Rock                            -  enabled
                              + system.adapter.yamaha.0                 : yamaha                : ioBroker-Rock                            -  enabled
                                system.adapter.yeelight-2.0             : yeelight-2            : ioBroker-Rock                            -  enabled
                                system.adapter.yr.0                     : yr                    : ioBroker-Rock                            -  enabled
                              + system.adapter.zigbee.0                 : zigbee                : ioBroker-Rock                            -  enabled, port: /dev/ttyACM0
                              + instance is alive
                              Adapter    "alarm"        : 3.3.12   , installed 3.3.12
                              Adapter    "device-watcher": 2.9.3   , installed 2.9.3
                              Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
                              Adapter    "eusec"        : 1.0.0    , installed 1.0.0
                              Adapter    "haier"        : 1.0.4    , installed 1.0.4
                              Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                              Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                              Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
                              Adapter    "hoover"       : 0.1.0    , installed 0.1.0
                              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                              Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                              Controller "js-controller": 5.0.11   , installed 5.0.9  [Updatable]
                              Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                              Adapter    "midea"        : 0.0.7    , installed 0.0.7
                              Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                              Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
                              Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
                              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                              Adapter    "musiccast"    : 1.1.0    , installed 1.1.0
                              Adapter    "nut"          : 1.6.0    , installed 1.6.0
                              Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                              Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
                              Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
                              Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
                              Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                              Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                              Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                              Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                              Adapter    "synology"     : 2.1.13   , installed 2.1.13
                              Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                              Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                              Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                              Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
                              Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
                              Adapter    "worx"         : 2.3.2    , installed 2.3.2
                              Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
                              Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                              Adapter    "yr"           : 5.3.0    , installed 5.3.0
                              Adapter    "zigbee"       : 1.8.19   , installed 1.8.19
                              Objects and States
                              Objects:        34001
                              States:         31411
                              Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                              Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                              Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                              Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
                              Hit:5 https://deb.nodesource.com/node_18.x jammy InRelease
                              Pending Updates: 32
                              tcp        0      0 192.168.3.100:8082      0.0.0.0:*               LISTEN      1001       25731      1364/io.web.0
                              tcp        0      0 192.168.3.100:8083      0.0.0.0:*               LISTEN      1001       26065      1665/io.web.1
                              tcp        0      0 192.168.3.100:45000     0.0.0.0:*               LISTEN      1001       25891      1540/io.sainlogic.0
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20970      729/sshd: /usr/sbin
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          20517      1/init
                              tcp        0      0 192.168.3.100:8701      0.0.0.0:*               LISTEN      1001       23097      1117/io.hm-rpc.1
                              tcp        0      0 192.168.3.100:2010      0.0.0.0:*               LISTEN      1001       23879      1102/io.hm-rpc.2
                              tcp        0      0 192.168.3.100:2001      0.0.0.0:*               LISTEN      1001       25012      1265/io.hm-rpc.0
                              tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       24757      1085/io.mqtt.0
                              tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       24758      1085/io.mqtt.0
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21394      1203/io.sonoff.0
                              tcp        0      0 0.0.0.0:1899            0.0.0.0:*               LISTEN      1001       21227      1070/io.shelly.1
                              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        22613      675/systemd-resolve
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22994      842/io.admin.2
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          20981      729/sshd: /usr/sbin
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          16685      1/init
                              tcp6       0      0 :::8900                 :::*                    LISTEN      1001       23807      969/io.admin.3
                              udp        0      0 0.0.0.0:52119           0.0.0.0:*                           1001       25471      1650/io.milight-sma
                              udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        22612      675/systemd-resolve
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          20518      1/init
                              udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       27662      1680/io.musiccast.0
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25117      1325/io.shelly.0
                              udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       106986     1299/io.mihome.0
                              udp6       0      0 :::111                  :::*                                0          20519      1/init
                              2023-07-31 21:48:59.895  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                              2023-07-31 21:49:02.149  - info: mqtt.0 (1085) Client [] connected with secret 1690832942136_993
                              2023-07-31 21:49:27.904  - info: sonoff.0 (1203) Client [Durchflusszähler_2] connected with secret 1690832967899_7008
                              2023-07-31 21:50:00.108  - info: host.ioBroker-Rock instance system.adapter.dwd.0 started with pid 31383
                              2023-07-31 21:50:01.463  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                              2023-07-31 21:50:01.678  - info: mqtt.0 (1085) Client [] connected with secret 1690833001676_8269
                              2023-07-31 21:50:04.642  - info: dwd.0 (31383) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.0, js-controller: 5.0.9
                              2023-07-31 21:50:05.880  - info: dwd.0 (31383) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2023-07-31 21:50:06.418  - info: host.ioBroker-Rock instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2023-07-31 21:50:18.164  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                              2023-07-31 21:51:00.962  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                              2023-07-31 21:51:01.240  - info: mqtt.0 (1085) Client [] connected with secret 1690833061240_2410
                              2023-07-31 21:52:00.147  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                              2023-07-31 21:52:00.385  - info: mqtt.0 (1085) Client [] connected with secret 1690833120385_7205
                              2023-07-31 21:52:03.771  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                              2023-07-31 21:52:32.329  - info: influxdb.0 (1009) Store 501 buffered influxDB history points
                              2023-07-31 21:52:33.760  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                              2023-07-31 21:52:37.762  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                              2023-07-31 21:52:58.670  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                              2023-07-31 21:53:00.917  - info: mqtt.0 (1085) Client [] connected with secret 1690833180916_4500
                              2023-07-31 21:53:11.760  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                              2023-07-31 21:53:33.766  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                              2023-07-31 21:54:00.204  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                              2023-07-31 21:54:00.466  - info: mqtt.0 (1085) Client [] connected with secret 1690833240465_8793
                              2023-07-31 21:54:11.769  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                                Thomas Braun Most Active @e-i-k-e last edited by
                                @e-i-k-e sagte in (gelöst) Beim öffnen der GUI vermehrt Timeouts.:
                                Pending Updates: 32
                                Klopp die rein.
                                Ansonsten seh ich keine dicken Hunde.
                                  e-i-k-e @Thomas Braun last edited by
                                  Erledigt.
                                  Wie ist dies zu verstehen?
                                  Ich betreibe ein Master/Slave System.
                                    Die Abfrage hat sich in das Skript verirrt, funktioniert nicht wie gedacht.
                                    Ignorieren.
                                      Alles klar. 😉
                                      2570
