    3. Entwicklung
    4. Adapter: Worx Landroid v2.x.x
      Thomas Braun Most Active @CaesarII last edited by Thomas Braun
      @caesarii
      Auch bei dir geheime Meldungen?
      iob add worx --debug
      sagt?
      C O 2 Replies Last reply Reply Quote 0
        @caesarii
        Grundsätzlich ist der Adapter nämlich installierbar:
        echad@chet:~ $ iob add worx --debug
        NPM version: 9.8.0
        Installing iobroker.worx@2.3.2... (System call)
        added 113 packages in 19s
        107 packages are looking for funding
          run `npm fund` for details
        host.chet install adapter worx
        upload [13] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [12] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [11] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [10] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [9] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [8] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [7] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [6] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [5] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [4] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [3] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [2] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/index_m.html index_m.html text/html
        upload [1] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/jsonConfig.json jsonConfig.json application/json
        upload [0] worx.admin /opt/iobroker/node_modules/iobroker.worx/admin/worx.png worx.png image/png
        host.chet object system.adapter.worx created/updated
        host.chet create instance worx
        host.chet object system.adapter.worx.0.alive created
        host.chet object system.adapter.worx.0.connected created
        host.chet object system.adapter.worx.0.compactMode created
        host.chet object system.adapter.worx.0.cpu created
        host.chet object system.adapter.worx.0.cputime created
        host.chet object system.adapter.worx.0.memHeapUsed created
        host.chet object system.adapter.worx.0.memHeapTotal created
        host.chet object system.adapter.worx.0.memRss created
        host.chet object system.adapter.worx.0.uptime created
        host.chet object system.adapter.worx.0.inputCount created
        host.chet object system.adapter.worx.0.outputCount created
        host.chet object system.adapter.worx.0.eventLoopLag created
        host.chet object system.adapter.worx.0.sigKill created
        host.chet object system.adapter.worx.0.logLevel created
        host.chet object worx.0.info created
        host.chet object worx.0.info.connection created
        host.chet Set default value of worx.0.info.connection: false
        host.chet object system.adapter.worx.0 created
        echad@chet:~ $
        • O
          optus28 @Thomas Braun last edited by
          @thomas-braun Hast Du mir einen Tipp wie ich die Ergebnisliste kopieren kann. Sind mehrere Seiten.
          Es ist für mich geheim 😉 weil ich nicht verstehe was da passiert!!
            CaesarII @Thomas Braun last edited by
            @thomas-braun Dass der Adapter installierbar ist bezweifle ich auch nicht. Nur mir fehlt komplett das Knoff-Hoff was bei einer Installation im Hintergrund abläuft. Hier das gewünschte Ergebnis:
            host.raspberrypi create instance worx
            host.raspberrypi object system.adapter.worx.1.alive created
            host.raspberrypi object system.adapter.worx.1.connected created
            host.raspberrypi object system.adapter.worx.1.compactMode created
            host.raspberrypi object system.adapter.worx.1.cpu created
            host.raspberrypi object system.adapter.worx.1.cputime created
            host.raspberrypi object system.adapter.worx.1.memHeapUsed created
            host.raspberrypi object system.adapter.worx.1.memHeapTotal created
            host.raspberrypi object system.adapter.worx.1.memRss created
            host.raspberrypi object system.adapter.worx.1.uptime created
            host.raspberrypi object system.adapter.worx.1.inputCount created
            host.raspberrypi object system.adapter.worx.1.outputCount created
            host.raspberrypi object system.adapter.worx.1.eventLoopLag created
            host.raspberrypi object system.adapter.worx.1.sigKill created
            host.raspberrypi object system.adapter.worx.1.logLevel created
            host.raspberrypi object worx.1.info created
            host.raspberrypi object worx.1.info.connection created
            host.raspberrypi Set default value of worx.1.info.connection: false
            host.raspberrypi object system.adapter.worx.1 created
            • O
              optus28 @optus28 last edited by optus28
              Habe ich gelöscht
              • O
                @thomas-braun $ iobroker add worx auto --host klaus-PC(SmartHomeKlaus230620) --debug
                npm WARN cleanup [ npm WARN cleanup 'F:\ioBroker2020\SmartHomeKlaus230620\node_modules\iobroker.worx', npm WARN cleanup [Error: EPERM: operation not permitted, rmdir 'F:\ioBroker2020\SmartHomeKlaus230620\node_modules\iobroker.worx\node_modules'] { npm WARN cleanup errno: -4048, npm WARN cleanup code: 'EPERM', npm WARN cleanup syscall: 'rmdir', npm WARN cleanup path: 'F:\ioBroker2020\SmartHomeKlaus230620\node_modules\iobroker.worx\node_modules' npm WARN cleanup } npm WARN cleanup ] npm WARN cleanup ]
                npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node ./scripts/install.js
                npm ERR! _secureEstablished: true,
                npm ERR! error: [Function: socketErrorListener], npm ERR! data: [Function: socketOnData], npm ERR! drain: [Function: ondrain] npm ERR! }, npm ERR! _eventsCount: 11,
                npm ERR! errorEmitted: false, npm ERR! emitClose: false,
                npm ERR! destroyed: false,
                npm ERR! pendingcb: 0,
                npm ERR! _parent: TCP { npm ERR! reading: [Getter/Setter], npm ERR! onconnection: null, npm ERR! [Symbol(owner_symbol)]: [Circular *1]
                npm ERR! constructed: true,
                npm ERR! emitClose: true, npm ERR! autoDestroy: true, npm ERR! destroyed: false, npm ERR! errored: null, npm ERR! closed: false, npm ERR! closeEmitted: false, npm ERR! defaultEncoding: 'utf8', npm ERR! awaitDrainWriters: null, npm ERR! multiAwaitDrain: false, npm ERR! readingMore: true,
                npm ERR! 'Connection',
                npm ERR! 'FRA53-C1',
                npm ERR! [Symbol(kTrailersCount)]: 0
                npm ERR! [Symbol(async_id_symbol)]: 8, npm ERR! [Symbol(kHandle)]: TLSWrap {
                npm ERR! maxBodyLength: 10485760, npm ERR! protocol: 'https:', npm ERR! path: null, npm ERR! method: 'GET',
                npm ERR! OutgoingMessage: [Function: OutgoingMessage],
                npm ERR! free: [Function (anonymous)], npm ERR! newListener: [Function: maybeEnableKeylog] npm ERR! }, npm ERR! _eventsCount: 2,
                npm ERR! _maxListeners: undefined, npm ERR! defaultPort: 443,
                npm ERR! }
                npm ERR! _keepAliveTimeout: 0, npm ERR! _onPendingData: [Function: nop], npm ERR! agent: Agent {
                npm ERR! _securePending: false, npm ERR! _newSessionPending: false,
                npm ERR! [Symbol(kBufferGen)]: null, npm ERR! [Symbol(kCapture)]: false,
                npm ERR! },
                npm ERR! tail: { data: [Buffer [Uint8Array]], next: null }, npm ERR! length: 1 npm ERR! },
                npm ERR! sync: true, npm ERR! needReadable: false, npm ERR! emittedReadable: false, npm ERR! readableListening: false, npm ERR! resumeScheduled: false, npm ERR! errorEmitted: false,
                npm ERR! decoder: null, npm ERR! encoding: null, npm ERR! [Symbol(kPaused)]: null
                npm ERR! secureConnecting: false,
                npm ERR! servername: 'd332vdhbectycy.cloudfront.net',
                npm ERR! _hadError: false, npm ERR! _parent: null, npm ERR! _host: 'd332vdhbectycy.cloudfront.net', npm ERR! _closeAfterHandlingError: false, npm ERR! _readableState: ReadableState { npm ERR! objectMode: false, npm ERR! highWaterMark: 16384, npm ERR! buffer: BufferList { head: null, tail: null, length: 0 }, npm ERR! length: 0,
                npm ERR! sync: false,
                npm ERR! reading: true,
                npm ERR! }
                npm ERR! }, npm ERR! [Symbol(verified)]: true, npm ERR! [Symbol(pendingSession)]: null, npm ERR! [Symbol(async_id_symbol)]: 8, npm ERR! [Symbol(kHandle)]: TLSWrap { npm ERR! _parent: TCP {
                npm ERR! [Symbol(kBufferCb)]: null,
                npm ERR! Accept: 'application/json, text/plain, /', npm ERR! 'User-Agent': 'axios/0.24.0' npm ERR! }, npm ERR! agent: undefined,
                npm ERR! maxCachedSessions: 100, npm ERR! _sessionCache: [Object], npm ERR! [Symbol(kCapture)]: false npm ERR! }, npm ERR! host: 'd332vdhbectycy.cloudfront.net',
                npm ERR! 'Server', npm ERR! 'AmazonS3',
                npm ERR! method: null, npm ERR! statusCode: 403, npm ERR! statusMessage: 'Forbidden',
                npm ERR! session: undefined, npm ERR! ALPNProtocols: undefined, npm ERR! requestOCSP: undefined,
                npm ERR! },
                npm ERR! readingMore: false,
                npm ERR! errored: null, npm ERR! closed: false, npm ERR! closeEmitted: false, npm ERR! [Symbol(kOnFinished)]: [] npm ERR! },
                npm ERR! onhandshakestart: {},
                npm ERR! reading: true, npm ERR! onkeylog: [Function: onkeylog], npm ERR! onhandshakestart: {},
                npm ERR! }, npm ERR! _consuming: false, npm ERR! _dumped: false, npm ERR! req: [Circular *2],
                npm ERR! timeoutCb: null, npm ERR! upgradeOrConnect: false,
                npm ERR! pskCallback: undefined, npm ERR! highWaterMark: undefined, npm ERR! onread: undefined, npm ERR! signal: undefined
                npm ERR! needDrain: false,
                npm ERR! _parentWrap: undefined, npm ERR! _secureContext: SecureContext { context: SecureContext {} }, npm ERR! reading: true, npm ERR! onkeylog: [Function: onkeylog],
                npm ERR! onerror: [Function: onerror], npm ERR! [Symbol(owner_symbol)]: [Circular *1] npm ERR! },
                npm ERR! connecting: false,
                npm ERR! pendingcb: 0, npm ERR! constructed: true,
                npm ERR! [Symbol(res)]: TLSWrap {
                npm ERR! maxRedirects: 21, npm ERR! maxBodyLength: 10485760,
                npm ERR! noDelay: true, npm ERR! servername: 'd332vdhbectycy.cloudfront.net', npm ERR! _agentKey: 'd332vdhbectycy.cloudfront.net:443:::::::::::::::::::::',
                npm ERR! complete: false,
                npm ERR! 'AmazonS3', npm ERR! 'X-Cache',
                npm ERR! pipe: false, npm ERR! secureContext: [SecureContext], npm ERR! isServer: false,
                npm ERR! onwrite: [Function: bound onwrite], npm ERR! writecb: null,
                npm ERR! afterWriteTickInfo: null, npm ERR! buffered: [], npm ERR! bufferedIndex: 0, npm ERR! allBuffers: true, npm ERR! allNoop: true, npm ERR! pendingcb: 0, npm ERR! constructed: true,
                npm ERR! _pendingEncoding: '', npm ERR! server: undefined, npm ERR! _server: null,
                npm ERR! [Symbol(connect-options)]: {
                npm ERR! headers: [Object],
                npm ERR! auth: undefined, npm ERR! hostname: 'd332vdhbectycy.cloudfront.net',
                npm ERR! [Symbol(kHeaders)]: { npm ERR! 'content-type': 'application/xml', npm ERR! 'transfer-encoding': 'chunked',
                npm ERR! 'x-amz-cf-pop': 'FRA53-C1',
                npm ERR! req: [Circular *2] npm ERR! } npm ERR! }, npm ERR! maxHeadersCount: null, npm ERR! reusedSocket: false,
                npm ERR! ending: false, npm ERR! ended: false, npm ERR! finished: false,
                npm ERR! STATUS_CODES: [Object], npm ERR! Agent: [Function], npm ERR! ClientRequest: [Function: ClientRequest],
                npm ERR! validateHeaderValue: [Function: _node_internal], npm ERR! get: [Function: get],
                npm ERR! },
                npm ERR! _redirectCount: 0, npm ERR! _redirects: [], npm ERR! _requestBodyLength: 0,
                npm ERR! }, npm ERR! response: {
                npm ERR! connection: 'close', npm ERR! date: 'Mon, 31 Jul 2023 15:12:52 GMT', npm ERR! server: 'AmazonS3', npm ERR! 'x-cache': 'Error from cloudfront',
                npm ERR! 'x-amz-cf-id': 'eyCnE7Hu2dATVaM4hD2J5DQQJBoMLKrqHyAG-u_X4uTlBQt9arqb7g==' npm ERR! }, npm ERR! config: {
                npm ERR! forcedJSONParsing: true,
                npm ERR! transformResponse: [ [Function: transformResponse] ], npm ERR! timeout: 0, npm ERR! xsrfCookieName: 'XSRF-TOKEN', npm ERR! xsrfHeaderName: 'X-XSRF-TOKEN',
                npm ERR! abort: [Function (anonymous)], npm ERR! aborted: [Function (anonymous)], npm ERR! connect: [Function (anonymous)],
                npm ERR! error: [Function (anonymous)], npm ERR! socket: [Function (anonymous)], npm ERR! timeout: [Function (anonymous)],
                npm ERR! _last: true, npm ERR! chunkedEncoding: false,
                npm ERR! _defaultKeepAlive: true,
                npm ERR! secureConnecting: false, npm ERR! _SNICallback: null, npm ERR! servername: 'd332vdhbectycy.cloudfront.net',
                npm ERR! [Function: onClose], npm ERR! [Function: socketCloseListener] npm ERR! ],
                npm ERR! reading: true, npm ERR! constructed: true,
                npm ERR! decoder: null, npm ERR! encoding: null, npm ERR! [Symbol(kPaused)]: false
                npm ERR! writecb: null, npm ERR! writelen: 0,
                npm ERR! socket: [Circular *1], npm ERR! incoming: <ref *3> IncomingMessage { npm ERR! _readableState: [ReadableState], npm ERR! _events: [Object: null prototype],
                npm ERR! upgrade: false, npm ERR! url: '', npm ERR! method: null,
                npm ERR! }, npm ERR! outgoing: [Circular *2], npm ERR! maxHeaderPairs: 2000, npm ERR! _consumed: false, npm ERR! onIncoming: [Function: parserOnIncomingClient],
                npm ERR! _defaultAgent: Agent {
                npm ERR! _eventsCount: 2, npm ERR! _maxListeners: undefined, npm ERR! defaultPort: 443, npm ERR! protocol: 'https:', npm ERR! options: [Object: null prototype],
                npm ERR! sockets: [Object: null prototype] { npm ERR! 'd332vdhbectycy.cloudfront.net:443:::::::::::::::::::::': [ [TLSSocket] ]
                npm ERR! _eventsCount: 1, npm ERR! _maxListeners: undefined, npm ERR! socket: <ref *1> TLSSocket { npm ERR! _tlsOptions: { npm ERR! allowHalfOpen: undefined,
                npm ERR! onhandshakedone: [Function (anonymous)],
                npm ERR! onocspresponse: [Function: onocspresponse], npm ERR! onnewsession: [Function: onnewsessionclient], npm ERR! onerror: [Function: onerror], npm ERR! [Symbol(owner_symbol)]: [Circular *1] npm ERR! },
                npm ERR! decodeStrings: false,
                npm ERR! pathname: '/aws-crt-1.17.0-source.tgz', npm ERR! _defaultAgent: [Agent], npm ERR! host: 'd332vdhbectycy.cloudfront.net', npm ERR! noDelay: true, npm ERR! servername: 'd332vdhbectycy.cloudfront.net', npm ERR! _agentKey: 'd332vdhbectycy.cloudfront.net:443:::::::::::::::::::::',
                npm ERR! encrypted: true, npm ERR! _events: [Object: null prototype] { npm ERR! close: [Array], npm ERR! end: [Array], npm ERR! newListener: [Function: keylogNewListener],
                npm ERR! allowHalfOpen: false,
                npm ERR! dataEmitted: false,
                npm ERR! 'Content-Type', npm ERR! 'application/xml',
                npm ERR! secureContext: SecureContext { context: SecureContext {} },
                npm ERR! emitClose: false, npm ERR! autoDestroy: true,
                npm ERR! _removedContLen: false, npm ERR! _removedTE: false, npm ERR! strictContentLength: false,
                npm ERR! '\r\n',
                npm ERR! joinDuplicateHeaders: undefined,
                npm ERR! [Symbol(kBytesWritten)]: 0, npm ERR! [Symbol(kNeedDrain)]: false, npm ERR! [Symbol(corked)]: 0,
                npm ERR! _closed: false, npm ERR! socket: [Circular *1],
                npm ERR! _removedTE: false, npm ERR! strictContentLength: false, npm ERR! _contentLength: 0,
                npm ERR! '2': [Function: parserOnHeadersComplete], npm ERR! '3': [Function: parserOnBody], npm ERR! '4': [Function: parserOnMessageComplete],
                npm ERR! _last: true, npm ERR! chunkedEncoding: false, npm ERR! shouldKeepAlive: false,
                npm ERR! _redirectCount: 0, npm ERR! _redirects: [], npm ERR! _requestBodyLength: 0, npm ERR! _requestBodyBuffers: [],
                npm ERR! }, npm ERR! [Symbol(kHeadersCount)]: 18,
                npm ERR! A complete log of this run can be found in: npm ERR! C:\WINDOWS\ServiceProfiles\iobroker(SmartHomeKlaus230620)\AppData\Local\npm-cache_logs\2023-07-31T15_11_23_568Z-debug-0.log
                host.klaus-PC(SmartHomeKlaus230620) Cannot install iobroker.worx@2.3.2: 1
                ERROR: Process exited with code 25
                Schließen wenn fertig
                  @caesarii sagte in Adapter: Worx Landroid v2.x.x:
                  Da wurde offenbar ohne Fehlermeldung eine Instanz worx.1 angelegt.
                    Thomas Braun Most Active @optus28 last edited by
                    @optus28 sagte in Adapter: Worx Landroid v2.x.x:
                    Hab ich aber keine Ahnung von. Vielleicht ein Windooze-User.
                    • O
                      @thomas-braun Dennoch Danke!
                        Lucky_ESA Developer Most Active last edited by
                        Steht doch in der Fehlermeldung! EPERM - Du hast ein permission Problem.
                        Ich würde alle Worx Instanzen und den Adapter deinstallieren. Funktioniert das nicht per Adminoberfläche, dann halt manuell und Windows restart.
                        Gruß//Lucky
                        • O
                          optus28 @Lucky_ESA last edited by
                          @lucky_esa Danke für die Antwort. Habe ich gemacht. Es gibt keine Instanzen und keinen Adapter mehr.
                          PC wurde neu gestartet. Ergebnis bei versuchter Installation wie von mir beschrieben.
                          Wie gesagt, das erste mal dass ein Worx update nicht funktioniert.
                          VG
                          L Gargano 2 Replies Last reply Reply Quote 0
                            Lucky_ESA Developer Most Active @optus28 last edited by
                            VG
                            Wie bereits gesagt hast du ein permission Problem. Wenn du alles löscht dann mal schauen, ob alle Ordner (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\iobroker.worx\node_modules) wirklich gelöscht wurden.
                            Gruß//Lucky
                            Thomas Braun O 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @Lucky_ESA last edited by
                              @lucky_esa sagte in Adapter: Worx Landroid v2.x.x:
                              Wieso?
                              Hab das gleiche Problem mit dem Adapter
                              War vielleicht doch nicht das gleiche Problem... 😄
                              Also besser nicht an Threads hängen, die allenfalls ähnliche Fehlerbilder haben.
                                Lucky_ESA Developer Most Active @Thomas Braun last edited by
                                @thomas-braun sagte in Adapter: Worx Landroid v2.x.x:
                                Wieso?
                                Darum: EPERM: operation not permitted
                                Gruß//Lucky
                                • Gargano
                                  Gargano @optus28 last edited by
                                  @optus28 'iob fix' gemacht ?
                                  Falls dies unter Windows gibt.
                                  • O
                                    @lucky_esa Habe alles gemacht. von Worx war nichts mehr zu finden.
                                    Immerhin wurde die Fehlermeldung deutlich kürzer.
                                    npm ERR! code 1
                                    npm ERR! path F:\ioBroker2020\SmartHomeKlaus230620\node_modules\aws-crt npm ERR! command failed npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node ./scripts/install.js npm ERR! ERR! OMG CMake is not installed. Install CMake. npm ERR! ERR! OMG CMake is not installed. Install CMake. npm ERR! F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\cMake.js:106 npm ERR! throw new Error("CMake is not installed. Install CMake."); npm ERR! ^ npm ERR! npm ERR! Error: CMake is not installed. Install CMake. npm ERR! at CMake.getGenerators (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\cMake.js:106:15) npm ERR! at Toolset._getTopSupportedVisualStudioGenerator (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\toolset.js:217:28) npm ERR! at async Toolset.initializeWin (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\toolset.js:159:17) npm ERR! at async Toolset.initialize (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\toolset.js:32:13) npm ERR! at async BuildSystem._ensureInstalled (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\buildSystem.js:40:9) npm ERR! at async BuildSystem._invokeCMake (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\buildSystem.js:69:9) npm ERR! at async buildLocally (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\aws-crt\scripts\build.js:154:5) npm ERR! at async buildFromRemoteSource (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\aws-crt\scripts\build.js:176:5) npm ERR! npm ERR! Node.js v18.16.0 npm ERR! A complete log of this run can be found in: npm ERR! C:\WINDOWS\ServiceProfiles\iobroker(SmartHomeKlaus230620)\AppData\Local\npm-cache_logs\2023-07-31T21_43_20_887Z-debug-0.log
                                    Schade, dass ich es nicht hinbekomme. Nutze seit den ersten Worx Adaptern in 2017 , 2018 bis zur letzten Version vor 2.3.xx den Adapter und hatte bisher keine Probleme.
                                    Viele Grüße
                                    Klaus
                                      @optus28
                                      Installier das nach. Wenn es cmake für Windows gibt.
                                      • O
                                        optus28 @Thomas Braun last edited by optus28
                                        @thomas-braun Nach Installation von CMAKE im System Path.
                                        Wieder ein Stück kürzer aber leider noch nicht erfolgreich.
                                        npm ERR! info RUN '--no-warn-unused-cli', npm ERR! info RUN '-G',
                                        npm ERR! A complete log of this run can be found in: npm ERR! C:\WINDOWS\ServiceProfiles\iobroker(SmartHomeKlaus230620)\AppData\Local\npm-cache_logs\2023-07-31T23_14_49_746Z-debug-0.log
                                        Wüsste gerne ob es jemand geschafft hat Worx 2.3.xx unter Win zum Laufen gebracht zu haben.
                                        Vielen Dank für die bisherige Geduld und Unterstützung.
                                        O L 2 Replies Last reply Reply Quote 0
                                        • O
                                          @optus28 Ich bekomme es nicht hin und gebe auf. Dann eben iobroker ohne worx.
                                          Vielleicht könnte sich der Entwickler / Programmiere ja mal anschauen was er programmiert hat.
                                          Vielen Dank für die Hilfen.
                                            Das passt ja. Dein Betrübssystem spielt da nicht mit. Musst du richtig konfigurieren.
                                            1.0k
                                            1194
                                            455157
