    4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
      arteck Developer Most Active @Bongo last edited by
      @bongo sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
      Oder kann man das aus den Json Listen raus holen?
      du kannst aus dem JSON immer was rausholen
        Malz1902 last edited by
        Bei mir will der Adapter irgendwie nicht mwhe starten:
        host.iobroker
        	2023-07-31 09:55:41.061	error	instance system.adapter.device-watcher.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.iobroker
        	2023-07-31 09:55:41.061	error	Caught by controller[0]: }
        host.iobroker
        	2023-07-31 09:55:41.061	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.device-watcher/main.js' ]
        host.iobroker
        	2023-07-31 09:55:41.061	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.iobroker
        	2023-07-31 09:55:41.061	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
        host.iobroker
        	2023-07-31 09:55:41.061	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
        host.iobroker
        	2023-07-31 09:55:41.061	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
        host.iobroker
        	2023-07-31 09:55:41.061	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
        host.iobroker
        	2023-07-31 09:55:41.061	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
        host.iobroker
        	2023-07-31 09:55:41.061	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.device-watcher/main.js:7:20)
        host.iobroker
        	2023-07-31 09:55:41.061	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
        host.iobroker
        	2023-07-31 09:55:41.061	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
        host.iobroker
        	2023-07-31 09:55:41.060	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:841:27)
        host.iobroker
        	2023-07-31 09:55:41.060	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
        host.iobroker
        	2023-07-31 09:55:41.060	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.device-watcher/main.js
        host.iobroker
        	2023-07-31 09:55:41.060	error	Caught by controller[0]: Require stack:
        host.iobroker
        	2023-07-31 09:55:41.060	error	Caught by controller[0]: Error: Cannot find module 'cron-parser'
        host.iobroker
        	2023-07-31 09:55:41.060	error	Caught by controller[0]: ^
        host.iobroker
        	2023-07-31 09:55:41.060	error	Caught by controller[0]: throw err;
        host.iobroker
        	2023-07-31 09:55:41.059	error	Caught by controller[0]: node:internal/modules/cjs/loader:998
          A Former User @Malz1902 last edited by
          @malz1902 er findet, warum auch immer, das module cron parser nicht. Hast du schon versucht den adapter neu zu installieren?
            Malz1902 @Guest last edited by
            @ciddi89 ja schon mehrfach, leider keine Besserung
              @malz1902 said in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
              host.iobroker
              	2023-08-01 08:53:36.334	warn	adapter "device-watcher" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
              Node.js
              v16.20.1
              soll ich auf 18 gehen?
                Malz1902 @Malz1902 last edited by
                host.iobroker
                Node.js
                v16.20.1
                hmm okay mit nodejs geht es auch nicht
                  @malz1902 sollte auch egal sein angegeben ist das es bei 16, 18 und 20 gehen soll. Nur 14 wurde entfernt. Besteht der Fehler weiterhin wenn du auf Version 2.9.2 gehst?
                    @ciddi89 bin runter bis Version 2.8.2. immer der gleiche Fehler:
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	instance system.adapter.device-watcher.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: Node.js v18.17.0
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: }
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.device-watcher/main.js' ]
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.device-watcher/main.js:11:20)
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.device-watcher/main.js
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: Require stack:
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: Error: Cannot find module 'cron-parser'
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: ^
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: throw err;
                    host.iobroker
                    	2023-08-01 09:24:22.173	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
                      Habe in der Javascript Instanz jetzt cron-parser als npm Modul angegeben, dann geht es
                        @malz1902 hmm okay... Evtl wurde das Modul von einem anderen Adapter gelöscht oder so? Ist nur komisch, normalerweise sollte er das neu laden wenn der Adapter neu installiert wird.
                        • FredF
                          FredF Most Active Forum Testing last edited by
                          @ciddi89 Ich habe nichts gefunden darüber... vielleicht auch falsch gesucht...
                          Der ble Adapter hat den Datenpunkt ble.0.info.driverState, überwacht dein Adapter den auch?
                          Bei Updates geht der gerne vom Status poweredOn auf unauthorized und empfängt dann keine Daten mehr.
                           "_id": "ble.0.info.driverState",
                           "type": "state",
                           "common": {
                             "role": "indicator.state",
                             "name": "bluetooth driver state",
                             "desc": "The current state of the bluetooth driver",
                             "type": "string",
                             "read": true,
                             "write": false,
                             "def": "poweredOff"
                           "native": {},
                           "from": "system.adapter.ble.0",
                           "ts": 1691677391808,
                           "acl": {
                             "object": 1636,
                             "state": 1636,
                             "owner": "system.user.admin",
                           "user": "system.user.admin"
                            A Former User @FredF last edited by
                            @fredf ne den überwacht der Adapter nicht. Sollte dann aber nicht besser der Ble Adapter auf ‚Nicht verbunden mit Gerät oder Dienst‘ gehen? Nutze selber Ble nicht mehr in Verbindung mit iobroker daher weiß ich nicht mehr ob der das dann so macht. Ich glaube nicht, wäre aber meiner Meinung sinnvoller.
                            • FredF
                              FredF Most Active Forum Testing @Guest last edited by
                              @ciddi89 ok muss ich mal beobachten. Mache dann ein issue beim ble Adapter auf
                                jerzimeik last edited by
                                ich habe den Adapter über Github installiert und bekomme nach dem Starten des Adapters folgende Fehlermeldung:
                                Im Javascript-Adapter habe ich den Eintrag gesetzt:
                                Wo könnte noch der Fehler liegen?
                                da_Woody Merlin123 crunchip 3 Replies Last reply Reply Quote 0
                                • da_Woody
                                  da_Woody @jerzimeik last edited by
                                  @jerzimeik keine Screenshots von logs.
                                  Die gehören kopiert und in codetags eingefügt.
                                  • Merlin123
                                    Merlin123 @jerzimeik last edited by
                                    @jerzimeik Die neu 2er Version läuft nur mit js-controller > 5.0. Welchen js-controller hast Du im Einsatz?
                                      crunchip Forum Testing Most Active @jerzimeik last edited by
                                      @jerzimeik sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                                      ist normalerweise gar nicht nötig
                                      nodejs 18.11 ist mittlerweile auch nicht mehr der neuste Stand, da du aus deinem anderen Thread auch Probleme hast, shelly im iot hinzu zu fügen, zeig mal die Ausgabe von iob diag
                                        jerzimeik last edited by jerzimeik
                                        iob upgrade self
                                        bringt komischerweise auch nichts Neues.
                                        Die Ausgabe von iob diag :
                                                             v.2023-04-16
                                        Operatingsystem:        Ubuntu 21.04
                                        Kernel:                 5.11.22-4-pve
                                        Installation:           lxc
                                        Timezone:               Europe/Berlin (CEST, +0200)
                                        User-ID:                0
                                        X-Server:               false
                                        Boot Target:            graphical.target
                                        Pending OS-Updates:     0
                                        Pending iob updates:    0
                                        Nodejs-Installation:    /usr/bin/nodejs         v18.11.0
        /usr/bin/node           v18.11.0
        /usr/bin/npm            8.19.2
        /usr/bin/npx            8.19.2
                                        Recommended versions are nodejs 18.x.y and npm 9.x.y
                                        MEMORY:
                                        Mem:           7.7G        156M        6.4G          0B        1.2G        7.6G
                                        Swap:          7.2G        2.0M        7.2G
                                        Total:          14G        159M         13G
                                        Active iob-Instances:   2
                                        Active repo(s): stable
                                        ioBroker Core:          js-controller           4.0.24
        admin                   6.8.0
                                        ioBroker Status:        iobroker is not running on this host.
                                        Objects type: jsonl
                                        States  type: jsonl
                                          system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
                                          system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
                                          system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        Objects:                57729
                                        States:                 43526
                                        Size of iob-Database:
                                        65M     /opt/iobroker/iobroker-data/objects.jsonl
                                        35M     /opt/iobroker/iobroker-data/objects.json.migrated
                                        35M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                        90M     /opt/iobroker/iobroker-data/states.jsonl
                                        5.7M    /opt/iobroker/iobroker-data/states.json.migrated
                                        5.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                        • DJMarc75
                                          DJMarc75 @jerzimeik last edited by
                                          Ubuntu 21.04
                                          Hat seit Januar 2022 das EOL erreicht.
                                          v18.11.0
                                          18.17.1 ist aktuell.
                                          Da würde ich als erstes mal ansetzen.
                                            Nach
                                            sudo apt purge --autoremove nodejs* npm node-*
                                            und
                                            curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash
                                            sudo apt install nodejs
                                            sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                            bleibt aber die Version
                                            /usr/bin/nodejs
                                            /usr/bin/node
                                            /usr/bin/npm
                                            /usr/bin/npx
                                            v18.11.0
                                            v18.11.0
                                            8.19.2
                                            8.19.2
                                            Vorher habe ich natürlich apt update und apt upgrade gemacht.
                                            JLeg DJMarc75 2 Replies Last reply Reply Quote 0
                                            1461
                                            491633
