    • Negalein
      Negalein Global Moderator @Michael Roling last edited by
      @michael-roling sagte in Test Adapter telegram-menu v.0.3.x:
      Mmmh das ist komisch, ich habe das Problem nicht, ich bastel gerade selbst an meinem Menu und bei mir taucht das Problem nicht auf
      ich hab hier mal das Log vom Start.
      Eventuell siehst du was.
      2023-07-31 10:18:50.581  - info: host.ioBroker instance system.adapter.telegram-menu.0 started with pid 394412
      2023-07-31 10:18:51.002  - debug: telegram-menu.0 (394412) Redis Objects: Use Redis connection: 0.0.0.0:9001
      2023-07-31 10:18:51.101  - debug: telegram-menu.0 (394412) Objects client ready ... initialize now
      2023-07-31 10:18:51.102  - debug: telegram-menu.0 (394412) Objects create System PubSub Client
      2023-07-31 10:18:51.102  - debug: telegram-menu.0 (394412) Objects create User PubSub Client
      2023-07-31 10:18:51.252  - debug: telegram-menu.0 (394412) Objects client initialize lua scripts
      2023-07-31 10:18:51.265  - debug: telegram-menu.0 (394412) Objects connected to redis: 0.0.0.0:9001
      2023-07-31 10:18:51.325  - debug: telegram-menu.0 (394412) Redis States: Use Redis connection: 0.0.0.0:9000
      2023-07-31 10:18:51.373  - debug: telegram-menu.0 (394412) States create System PubSub Client
      2023-07-31 10:18:51.373  - debug: telegram-menu.0 (394412) States create User PubSub Client
      2023-07-31 10:18:51.467  - debug: telegram-menu.0 (394412) States connected to redis: 0.0.0.0:9000
      2023-07-31 10:18:51.934  - info: telegram-menu.0 (394412) starting. Version 0.4.2 in /opt/iobroker/node_modules/iobroker.telegram-menu, node: v16.20.1, js-controller: 4.0.24
      2023-07-31 10:18:51.972  - debug: telegram-menu.0 (394412) Instance "telegram.0"
      2023-07-31 10:18:51.972  - debug: telegram-menu.0 (394412) Datapoint "telegram.0.info.connection"
      2023-07-31 10:18:52.517  - info: telegram-menu.0 (394412) Telegram was found
      2023-07-31 10:18:52.519  - debug: telegram-menu.0 (394412) Navigation {"Global":[{"call":"Home","value":"Licht && Strom && Wetter","text":"Wählen Sie eine Aktion"},{"call":"Licht","value":"Home && Wohnzimmer Licht, Wintergarten Licht, Wintergarten Strip","text":"Wähle eine Aktion"},{"call":"Strom","value":"Home && Pelletsofen, 3D Drucker","text":"Wähle eine Aktion"},{"call":"Wetter","value":"Home && Aussentemperatur, Windstärke, Regen","text":"Wähle eine Aktion"}],"Christian":[{"call":"Startseite","value":"Licht, Steckdose && Iobroker, Heizung","text":"Wähle eine Aktion"}]}
      2023-07-31 10:18:52.519  - debug: telegram-menu.0 (394412) Action {"Global":{"get":[{"trigger":["Aussentemperatur"],"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"text":["Aussentemperatur && °C"],"newline_checkbox":["true"]},{"trigger":["Windstärke"],"IDs":["0_userdata.0.Wetterstation.Wind"],"text":["Windstärke && km/h"],"newline_checkbox":["true"]},{"trigger":["Regen"],"IDs":["0_userdata.0.Wetterstation.Regen_Tag"],"text":["Regen heute && mm"],"newline_checkbox":["true"]}],"set":[{"trigger":["Wintergarten Strip"],"IDs":["hue.0.Wintergarten_Strip.on"],"values":["-"],"returnText":["Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Pelletsofen"],"IDs":["hs100.0.10_0_1_76.state"],"values":["-"],"returnText":["Pelletsofen ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Wohnzimmer Licht"],"IDs":["hue.0.Wohnzimmer.on"],"values":["-"],"returnText":["Wohnzimmer Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Wintergarten Licht"],"IDs":["hue.0.Wintergarten.on"],"values":["-"],"returnText":["Wintergarten Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["3D Drucker"],"IDs":["alias.0.EG.Strom.3D-Drucker"],"values":["-"],"returnText":["3D-Drucker ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}],"pic":[]},"Christian":{"get":[],"set":[],"pic":[]}}
      2023-07-31 10:18:52.520  - debug: telegram-menu.0 (394412) Array [["Licht "],[" Strom "],[" Wetter"]]
      2023-07-31 10:18:52.520  - debug: telegram-menu.0 (394412) Array [["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]]
      2023-07-31 10:18:52.521  - debug: telegram-menu.0 (394412) Array [["Home "],[" Pelletsofen"," 3D Drucker"]]
      2023-07-31 10:18:52.521  - debug: telegram-menu.0 (394412) Array [["Home "],[" Aussentemperatur"," Windstärke"," Regen"]]
      2023-07-31 10:18:52.522  - debug: telegram-menu.0 (394412) elementVal [["Licht "],[" Strom "],[" Wetter"]]
      2023-07-31 10:18:52.522  - debug: telegram-menu.0 (394412) elementVal [["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]]
      2023-07-31 10:18:52.523  - debug: telegram-menu.0 (394412) elementVal [["Home "],[" Pelletsofen"," 3D Drucker"]]
      2023-07-31 10:18:52.523  - debug: telegram-menu.0 (394412) elementVal [["Home "],[" Aussentemperatur"," Windstärke"," Regen"]]
      2023-07-31 10:18:52.523  - debug: telegram-menu.0 (394412) New Structure: {"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"}}
      2023-07-31 10:18:52.524  - debug: telegram-menu.0 (394412) action set: [{"trigger":["Wintergarten Strip"],"IDs":["hue.0.Wintergarten_Strip.on"],"values":["-"],"returnText":["Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Pelletsofen"],"IDs":["hs100.0.10_0_1_76.state"],"values":["-"],"returnText":["Pelletsofen ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Wohnzimmer Licht"],"IDs":["hue.0.Wohnzimmer.on"],"values":["-"],"returnText":["Wohnzimmer Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Wintergarten Licht"],"IDs":["hue.0.Wintergarten.on"],"values":["-"],"returnText":["Wintergarten Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["3D Drucker"],"IDs":["alias.0.EG.Strom.3D-Drucker"],"values":["-"],"returnText":["3D-Drucker ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}]
      2023-07-31 10:18:52.524  - debug: telegram-menu.0 (394412) action get: [{"trigger":["Aussentemperatur"],"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"text":["Aussentemperatur && °C"],"newline_checkbox":["true"]},{"trigger":["Windstärke"],"IDs":["0_userdata.0.Wetterstation.Wind"],"text":["Windstärke && km/h"],"newline_checkbox":["true"]},{"trigger":["Regen"],"IDs":["0_userdata.0.Wetterstation.Regen_Tag"],"text":["Regen heute && mm"],"newline_checkbox":["true"]}]
      2023-07-31 10:18:52.524  - debug: telegram-menu.0 (394412) action pic: []
      2023-07-31 10:18:52.524  - debug: telegram-menu.0 (394412) action : {"get":[{"trigger":["Aussentemperatur"],"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"text":["Aussentemperatur && °C"],"newline_checkbox":["true"]},{"trigger":["Windstärke"],"IDs":["0_userdata.0.Wetterstation.Wind"],"text":["Windstärke && km/h"],"newline_checkbox":["true"]},{"trigger":["Regen"],"IDs":["0_userdata.0.Wetterstation.Regen_Tag"],"text":["Regen heute && mm"],"newline_checkbox":["true"]}],"set":[{"trigger":["Wintergarten Strip"],"IDs":["hue.0.Wintergarten_Strip.on"],"values":["-"],"returnText":["Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Pelletsofen"],"IDs":["hs100.0.10_0_1_76.state"],"values":["-"],"returnText":["Pelletsofen ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Wohnzimmer Licht"],"IDs":["hue.0.Wohnzimmer.on"],"values":["-"],"returnText":["Wohnzimmer Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Wintergarten Licht"],"IDs":["hue.0.Wintergarten.on"],"values":["-"],"returnText":["Wintergarten Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["3D Drucker"],"IDs":["alias.0.EG.Strom.3D-Drucker"],"values":["-"],"returnText":["3D-Drucker ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}],"pic":[]}
      2023-07-31 10:18:52.525  - debug: telegram-menu.0 (394412) Element set: {"trigger":["Wintergarten Strip"],"IDs":["hue.0.Wintergarten_Strip.on"],"values":["-"],"returnText":["Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}
      2023-07-31 10:18:52.526  - debug: telegram-menu.0 (394412) Trigger: ["Wintergarten Strip"]
      2023-07-31 10:18:52.526  - debug: telegram-menu.0 (394412) Element set: {"trigger":["Pelletsofen"],"IDs":["hs100.0.10_0_1_76.state"],"values":["-"],"returnText":["Pelletsofen ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}
      2023-07-31 10:18:52.526  - debug: telegram-menu.0 (394412) Trigger: ["Pelletsofen"]
      2023-07-31 10:18:52.526  - debug: telegram-menu.0 (394412) Element set: {"trigger":["Wohnzimmer Licht"],"IDs":["hue.0.Wohnzimmer.on"],"values":["-"],"returnText":["Wohnzimmer Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}
      2023-07-31 10:18:52.526  - debug: telegram-menu.0 (394412) Trigger: ["Wohnzimmer Licht"]
      2023-07-31 10:18:52.526  - debug: telegram-menu.0 (394412) Element set: {"trigger":["Wintergarten Licht"],"IDs":["hue.0.Wintergarten.on"],"values":["-"],"returnText":["Wintergarten Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}
      2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Trigger: ["Wintergarten Licht"]
      2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Element set: {"trigger":["3D Drucker"],"IDs":["alias.0.EG.Strom.3D-Drucker"],"values":["-"],"returnText":["3D-Drucker ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}
      2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Trigger: ["3D Drucker"]
      2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Obj set: {"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"-","toggle":true,"confirm":"true","returnText":"Pelletsofen ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"true","returnText":"Wohnzimmer Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"3D Drucker":{"switch":[{"id":"alias.0.EG.Strom.3D-Drucker","value":"-","toggle":true,"confirm":"true","returnText":"3D-Drucker ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]}}
      2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Element get: {"trigger":["Aussentemperatur"],"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"text":["Aussentemperatur && °C"],"newline_checkbox":["true"]}
      2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Trigger: ["Aussentemperatur"]
      2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Element get: {"trigger":["Windstärke"],"IDs":["0_userdata.0.Wetterstation.Wind"],"text":["Windstärke && km/h"],"newline_checkbox":["true"]}
      2023-07-31 10:18:52.528  - debug: telegram-menu.0 (394412) Trigger: ["Windstärke"]
      2023-07-31 10:18:52.528  - debug: telegram-menu.0 (394412) Element get: {"trigger":["Regen"],"IDs":["0_userdata.0.Wetterstation.Regen_Tag"],"text":["Regen heute && mm"],"newline_checkbox":["true"]}
      2023-07-31 10:18:52.528  - debug: telegram-menu.0 (394412) Trigger: ["Regen"]
      2023-07-31 10:18:52.528  - debug: telegram-menu.0 (394412) Subscribe "hue.0.Wintergarten_Strip.on"
      2023-07-31 10:18:52.528  - debug: telegram-menu.0 (394412) Subscribe "hs100.0.10_0_1_76.state"
      2023-07-31 10:18:52.529  - debug: telegram-menu.0 (394412) Subscribe "hue.0.Wohnzimmer.on"
      2023-07-31 10:18:52.529  - debug: telegram-menu.0 (394412) Subscribe "hue.0.Wintergarten.on"
      2023-07-31 10:18:52.529  - debug: telegram-menu.0 (394412) Subscribe "alias.0.EG.Strom.3D-Drucker"
      2023-07-31 10:18:52.529  - debug: telegram-menu.0 (394412) SetForeignStates: ["hue.0.Wintergarten_Strip.on","hs100.0.10_0_1_76.state","hue.0.Wohnzimmer.on","hue.0.Wintergarten.on","alias.0.EG.Strom.3D-Drucker"]
      2023-07-31 10:18:52.529  - debug: telegram-menu.0 (394412) Name "Global"
      2023-07-31 10:18:52.529  - debug: telegram-menu.0 (394412) Array Buttons: [{"call":"Home","value":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},{"call":"Licht","value":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},{"call":"Strom","value":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},{"call":"Wetter","value":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"}]
      2023-07-31 10:18:52.535  - debug: telegram-menu.0 (394412) Gen. Actions: {"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"-","toggle":true,"confirm":"true","returnText":"Pelletsofen ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"true","returnText":"Wohnzimmer Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"3D Drucker":{"switch":[{"id":"alias.0.EG.Strom.3D-Drucker","value":"-","toggle":true,"confirm":"true","returnText":"3D-Drucker ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]},"Windstärke":{"getData":[{"id":"0_userdata.0.Wetterstation.Wind","text":"Windstärke && km/h","newline":"true"}]},"Regen":{"getData":[{"id":"0_userdata.0.Wetterstation.Regen_Tag","text":"Regen heute && mm","newline":"true"}]}}
      2023-07-31 10:18:52.535  - debug: telegram-menu.0 (394412) Array [["Licht"," Steckdose "],[" Iobroker"," Heizung"]]
      2023-07-31 10:18:52.535  - debug: telegram-menu.0 (394412) elementVal [["Licht"," Steckdose "],[" Iobroker"," Heizung"]]
      2023-07-31 10:18:52.535  - debug: telegram-menu.0 (394412) New Structure: {"Startseite":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}
      2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) action set: []
      2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) action get: []
      2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) action pic: []
      2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) action : {"get":[],"set":[],"pic":[]}
      2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) Obj set: {"Startseite":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}
      2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) SetForeignStates: []
      2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) Name "Christian"
      2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) Array Buttons: [{"call":"Startseite","value":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}]
      2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) Gen. Actions: {"Startseite":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}
      2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) Checkbox {"checkboxNoValueFound":true,"resKey":true,"oneTiKey":false}
      2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) GroupList ["Global","Christian"]
      2023-07-31 10:18:52.537  - debug: telegram-menu.0 (394412) Group "Global"
      2023-07-31 10:18:52.537  - debug: telegram-menu.0 (394412) Send this Value : "Wählen Sie eine Aktion"
      2023-07-31 10:18:52.537  - debug: telegram-menu.0 (394412) Send this to : "Christian"
      2023-07-31 10:18:52.537  - debug: telegram-menu.0 (394412) Group "Christian"
      2023-07-31 10:18:52.538  - debug: telegram-menu.0 (394412) Send this Value : "Wähle eine Aktion"
      2023-07-31 10:18:52.538  - debug: telegram-menu.0 (394412) Send this to : ""
      2023-07-31 10:19:02.772  - debug: telegram-menu.0 (394412) else "hs100.0.10_0_1_76.state"
      2023-07-31 10:19:02.772  - debug: telegram-menu.0 (394412) else undefined
      2023-07-31 10:19:03.056  - debug: telegram-menu.0 (394412) else "alias.0.EG.Strom.3D-Drucker"
      2023-07-31 10:19:03.057  - debug: telegram-menu.0 (394412) else undefined
      • Michael Roling
        Michael Roling Developer @Negalein last edited by
        @negalein Leider kann ich so nichts finden! Da scheint auch einiges noch zu fehlen
          fritzke316 @Michael Roling last edited by fritzke316
          @michael-roling
          habe nochmal die neueste Version von github geladen, jetzt werden mir die Werte von den Submenus nicht mehr gesetzt und im Log bekomme ich Fehlermeldungen dieser Art beim Betätigen der Navi Buttons:
          backMenu{"Friedrich":{"list":["Startseite","Heizung","Startseite"],"last":"Licht"}}
          backMenu{"Friedrich":{"list":[],"last":"Startseite"}}
          backMenu{"Friedrich":{"list":["Startseite"],"last":"Heizung"}}
          • Michael Roling
            Michael Roling Developer @fritzke316 last edited by
            @fritzke316 installiere dann die latest 0.4.2 direkt im iobroker.
              @michael-roling
              Wie muss ich da vorgehen? Den Adapter löschen und nochmal installieren?
              • flkontakt
                flkontakt @Michael Roling last edited by
                @michael-roling Hallo, auch auf die Gefahr hin, dass ich mich blamiere:
                Bisher habe ich per Script und Telegram gesteuert, möchte gerne deinen Adapter testen. Siehe Bilder, meine ersten Einstellungen. Ich scheitere aber schon am Navigationsmenu, ich kann dies im Adapter anpassen, beim betätigen der Button erfolgt aber keine weitere Navigation.
                Was mache ich hier falsch?
                  fritzke316 @flkontakt last edited by fritzke316
                  @flkontakt
                  ich denke du musst noch ganz oben einen Benutzer für die Gruppe eintragen!
                  Ansonsten sieht es doch gut aus 🙂
                  flkontakt 1 Reply Last reply Reply Quote 1
                  • flkontakt
                    flkontakt @fritzke316 last edited by
                    @fritzke316 das also zum Thema blamieren............. Das war es natürlich, hätte man drauf kommen können 😉
                    Jetzt kann ich testen, werde hier sicherlich nochmal mit Fragen aufschlagen.
                    Vielen Dank für die Unterstützung!!!
                    Michael Roling 1 Reply Last reply Reply Quote 1
                    • Michael Roling
                      Michael Roling Developer @flkontakt last edited by
                      @flkontakt Perfekt! Oben der Button ist nur die Gruppe, unten muss der Name rein, wie schon geschehen. Du kannst den Button auch zum Beispiel Gruppe 1 nennen.
                      • Michael Roling
                        @fritzke316
                        Du stellst erstmal auf latest repo um und dann kannst du unter adapter au dem rechten plus kästchen die version auswählen. evtl. muss du erst eine version zurück gehen und dann wieder auf die 0.4.2!
                        • Michael Roling
                          @fritzke316 die beiden errors sind garkeine errors, ich hatte die vergessen aus dem code zu nehmen🙈🙈🙈
                            @michael-roling
                            Wenn ich auf das plus Kästchen drücke kommt bei mir keine Versionsauswahl, nur das:
                            • Michael Roling
                              @fritzke316 du hast aber umgestellt auf latest?
                                @michael-roling
                                ja den Hacken bei latest Repository habe ich gesetzt.
                                Habe dann nochmal den Pfeil für "Adapter auf Updates überprüfen" angecklickt, dann hats geklappt.
                                Auch die Werte aus den Submeüs werden jetzt gesetz.
                                Danke für die Hilfe!!
                                • Michael Roling
                                  @fritzke316 ok. Das liegt dann aber an deinem System. Das kann ich nicht beeinflussen.
                                  Welches Menu lässt sich denn nicht mehr anzeigen?
                                    @michael-roling
                                    Sorry habe meinen post von vorher nochmal editiert, da ich die Lösung gefunden habe, war nur etwas zu langsam :))
                                    • Michael Roling
                                      @fritzke316 also geht wieder alles?
                                        @michael-roling
                                        Ja soweit alles Super 👍
                                        Danke nochmal für die Hilfe
                                        • Michael Roling
                                          @fritzke316 Nutz du denn noch das menu:back?
                                            @michael-roling
                                            Nein habe ich noch nicht in Verwendung wollte ich aber noch testen
                                            1795
                                            787022
