    4. Test Adapter time-switch v2.0.x GitHub/Latest
    • Iccube
      Iccube last edited by
      hätte da auch große Intresse an die integration an Lovelance
      • Vumer
        Vumer last edited by
        bekomme sporadisch diese Fehler:
        host.iobroker 2022-12-06 02:00:00.902	error	instance system.adapter.time-switch.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        time-switch.0 2022-12-06 02:00:00.020	error	Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=8, minute=18, weekdays=[0]} is not registered.
        time-switch.0 2022-12-06 02:00:00.020	error	Error: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=8, minute=18, weekdays=[0]} is not registered. at TimeTriggerScheduler.unregister (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:34:19) at /opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:73 at Array.forEach (<anonymous>) at Object.execute (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:32) at Job.job (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:22:33) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10) at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:552:11 at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:510:7) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
        time-switch.0 2022-12-06 02:00:00.019	error	uncaught exception: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=8, minute=18, weekdays=[0]} is not registered.
        time-switch.0 2022-12-06 02:00:00.018	error	Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=8, minute=15, weekdays=[0]} is not registered.
        time-switch.0 2022-12-06 02:00:00.017	error	Error: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=8, minute=15, weekdays=[0]} is not registered. at TimeTriggerScheduler.unregister (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:34:19) at /opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:73 at Array.forEach (<anonymous>) at Object.execute (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:32) at Job.job (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:22:33) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10) at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:552:11 at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:510:7) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
        time-switch.0 2022-12-06 02:00:00.017	error	uncaught exception: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=8, minute=15, weekdays=[0]} is not registered.
        time-switch.0 2022-12-06 02:00:00.015	error	Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=8, minute=19, weekdays=[0]} is not registered.
        time-switch.0 2022-12-06 02:00:00.015	error	Error: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=8, minute=19, weekdays=[0]} is not registered. at TimeTriggerScheduler.unregister (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:34:19) at /opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:73 at Array.forEach (<anonymous>) at Object.execute (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:32) at Job.job (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:22:33) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10) at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:552:11 at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:510:7) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
        time-switch.0 2022-12-06 02:00:00.015	error	uncaught exception: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=8, minute=19, weekdays=[0]} is not registered.
        time-switch.0 2022-12-06 02:00:00.011	error	Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=8, minute=16, weekdays=[0]} is not registered.
        time-switch.0 2022-12-06 02:00:00.011	error	Error: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=8, minute=16, weekdays=[0]} is not registered. at TimeTriggerScheduler.unregister (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:34:19) at /opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:73 at Array.forEach (<anonymous>) at Object.execute (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:32) at Job.job (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:22:33) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10) at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:552:11 at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:510:7) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
        time-switch.0 2022-12-06 02:00:00.007	error	uncaught exception: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=8, minute=16, weekdays=[0]} is not registered.
        was habe ich wieder falsch gemacht?
          LittleNo @Axel Koeneke last edited by
          @axel-koeneke said in Test Adapter time-switch v2.0.x GitHub/Latest:
          @theloh sagte in Test Adapter time-switch v2.0.x GitHub/Latest:
          Hallo Zusammen,
          ich habe eben die aktuelle Version auf meinem PI4 aus dem github Link installiert und wo
          normal das Widget erscheint fehlt das Bild. Es sieht also nicht so aus wie unten gezeigt.
          Ziehe ich das Widgeht dann in die Vis, ist kein Widget zusehen. Ea ist jedoch da, weil ich es mit STR+A
          selektieren kann.
          Kenn jemand eine Lösung, dass es wie unten aussieht?
          Ich habe den Adapter bereits einmal deinstalliert und neu installiert.
          Ich habe genau das gleiche Problem, jedoch nur wenn ich per Remote (Pro) damit arbeiten will.
          Local oder Vis auf Android funktioniert einwandfrei.
          Basiert das Widget evtl. auf Material-CSS? Damit hatte ich bis jetzt immer Probleme und nutze es deshalb nicht mehr.
          VG
          Axel
          Ich habe das Problem ebenfalls, bei mir funktioniert es auf PC und Android, aber auf iOS (iPad und iPhone) wird mir das Widget nicht angezeigt (egal ob lokal oder über die Pro-Cloud)
            Dete @walli545 last edited by
            @walli545
            Hi, erst mal danke für Deine Mühe und die gute Umsetzung.
            Ich hätte eine Frage, bzw. Änderungswunsch.
            Kann ich den Status ob der Timer auf Auto oder Manuell steht abfragen?
            Wenn nicht fände ich ein Bit für jeden Timer sinnvoll an dem ich den Status abfragen kann.
            Anwendungsfall : Wenn der Timer auf Auto steht, lasse ich keinen manuellen Eingriff zu.
            Gruß und danke
              Medea @Dete last edited by
              @dete
              Findest du doch bei den Objekten, für jeden Timer gibts einen Knoten und einen Datenpunkt enabled. Der Rest der Daten ist im Datenpunkt data als JSON gespeichert.
                elektrickser.de @holymoly last edited by
                @holymoly Schon eine Lösung gefunden, für eine Zeitschaltuhr in IQontrol?
                  holymoly @elektrickser.de last edited by
                  @elektrickser-de Hi, leider nicht. Hab einfach zur meiner eigentlichen Visu ne "Vis" nur mit Schaltuhren erstellt. Gr hm
                    @holymoly Ja, so hab ichs jetzt auch gelöst
                    • Christian Kohlöffel
                      Christian Kohlöffel last edited by
                      gibt es einen Plan den Adapter vis-2 fähig zu machen. Ich habe die vis-2 Oberfläche gerade parallel im beta am laufen und leider ist dieser Adapter wohl nicht vis-2 kompatible, oder mache ich da nur was falsch?
                      Christian
                      • BananaJoe
                        BananaJoe Most Active @Christian Kohlöffel last edited by
                        @christian-kohlöffel mhh, @walli545 war seit Januar nicht mehr hier online ...
                        Im April hat er mal auf einen GitHub Issue geantwortet.
                        Ich schlage vor das du auf GitHub einen Issue dafür eröffnest.
                          diwoma @BananaJoe last edited by
                          @bananajoe sagte in Test Adapter time-switch v2.0.x GitHub/Latest:
                          Seit Januar 2022
                            Eggi last edited by
                            Hallo
                            Ich habe den Adapter installiert und entsprechend auch konfiguriert
                            Den gesetzten Datenpunkt (boolean) kann ich auch mit dem Schalter "Aktueller Wert" schalten.
                            Nur das zeitgesteuerte Schalten funktioniert nicht.
                            Hat jemand eine Idee, woran das liegen könnte?!
                            sigi234 JHx 2 Replies Last reply Reply Quote 0
                              sigi234 Forum Testing Most Active @Eggi last edited by
                              @eggi
                              Gib mal bei Wert false bzw. true ein
                                Eggi @sigi234 last edited by Eggi
                                @sigi234 Servus
                                laut Anleitung währen die Werte für "Wahrheitswert" nicht erforderlich - hab's aber nun trotzdem versucht und auch die Instanz neu gestartet.
                                Leider das gleiche Ergebnis.... per Zeitsteuerung keine Funktion - mit dem Schieberegler funktioniert es hingegen.
                                Im Protokoll ist auch kein Fehler oder Warnung zu finden
                                Im Log ist zu finden:
                                starting. Version 2.2.2 (non-npm: walli545/ioBroker.time-switch#45b5addb484d270dcac6d1bfdb1a9f86b444d80e) in /opt/iobroker/node_modules/iobroker.time-switch, node: v18.17.1, js-controller: 4.0.24
                                  @eggi sagte in Test Adapter time-switch v2.0.x GitHub/Latest:
                                  @sigi234 Servus
                                  Ok, muss ich mal bei mir testen. Ich installiere den Adapter mal.
                                  E 2 Replies Last reply Reply Quote 0
                                    @sigi234 Danke für Deine Hilfe
                                    ich habe anstelle von boolean mal auf string umgestellt - gleiches Ergebnis
                                    Mit der Zeitzone kann ja wohl nichts zu tun haben, oder?
                                    Die Uhrzeit wird richtig angezeigt
                                      @sigi234 Ich glaube, ich kann den Fehler eingrenzen.
                                      Offensichtlich hat es wirklich etwas mit der Zeitzone zu tun - hab' mal zu testzwecken bei den Stunden 2 abgezogen (also aktuelle Uhrzeit 08:50 --> Schaltzeit 06:50 gesetzt) ==> dann hat es funktioniert.
                                        Ja, bei mir gerade getestet , funktioniert einwandfrei.
                                          @sigi234 Ja, geht auch bei mir, jedoch mit "verschobener" Zeiteinstellung - keine Ahnung warum nicht die akutelle Zeit verwendet wird...
                                            Welches System hast du?
                                            adapter switch test time vis zeitschaltuhr
                                            75
                                            481
                                            114680
