    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      wm20320 @arteck last edited by
      @arteck Sieht extrem gut aus! Klasse!!👏
      023-08-03 13:21:47.725 - debug: bluelink.0 (42536) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-08-03 13:21:47.764 - debug: bluelink.0 (42536) Objects client ready ... initialize now
      2023-08-03 13:21:47.765 - debug: bluelink.0 (42536) Objects create System PubSub Client
      2023-08-03 13:21:47.766 - debug: bluelink.0 (42536) Objects create User PubSub Client
      2023-08-03 13:21:47.816 - debug: bluelink.0 (42536) Objects client initialize lua scripts
      2023-08-03 13:21:47.821 - debug: bluelink.0 (42536) Objects connected to redis: 127.0.0.1:9001
      2023-08-03 13:21:47.858 - debug: bluelink.0 (42536) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-08-03 13:21:47.875 - debug: bluelink.0 (42536) States create System PubSub Client
      2023-08-03 13:21:47.876 - debug: bluelink.0 (42536) States create User PubSub Client
      2023-08-03 13:21:47.906 - debug: bluelink.0 (42536) States connected to redis: 127.0.0.1:9000
      2023-08-03 13:21:48.137 - info: bluelink.0 (42536) starting. Version 2.3.5 (non-npm: Newan/ioBroker.bluelink#master) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.17.0, js-controller: 5.0.11
      2023-08-03 13:21:48.161 - info: bluelink.0 (42536) Login to api
      2023-08-03 13:21:51.159 - info: bluelink.0 (42536) 1 Vehicles found
      2023-08-03 13:21:51.161 - debug: bluelink.0 (42536) [{"vehicleConfig":{"nickname":"i10","name":"i10","regDate":"2021-02-19 15:21:34.280","brandIndicator":"H","id":"64bd2074-1675-48a1-b845-40567dfaabdd","vin":"NLHDRXXXX","generation":"2021"},"controller":{"userConfig":{"username":"XXXX@XXXX.de","password":"XXXX","region":"EU","brand":"hyundai","autoLogin":true,"pin":"XXXX","vin":"","language":"de"},"session":{"accessToken":"Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJwaWQiOiI1YmIyYzcyMDlhOTk0MzA0MTk0MzZlYzQiLCJ1aWQiOiIxMTZjMjljZi04MTkzLTQyY2YtYWYxMi0zY2EzODYxOTZmNTciLCJzaWQiOiI2ZDQ3N2MzOC0zY2E0LTRjZjMtOTU1Ny0yYTE5MjlhOTQ2NTQiLCJleHAiOjE2OTExNDgxMTAsImlhdCI6MTY5MTA2MTcxMCwiaXNzIjoiYmx1ZWxpbmsifQ.f5kYjKGfkeXfPqfXUqHXI6c0VahnAGvKZDoa7_VthtVzaHhDvClNc39F5-WocAlzaDDS6LjWze_enrkzADjyKl_p8dNUci5dYouBXz4sLvKo_FdFUx7WDK0noE2vKKHz8Je1dgH8K8_n_CAbrVCqeNgW93Ta8hBILYlpes0fr8RiiEGaN2Hs5iIa-c4EwrJLkMAGiLcUFMLJAf_elua7hM0tuhOqYwmp0sZLn5vDgOfnWCRQO5ZBUdoBNZFutdjgh5hryGbIt8dCiUCp9wa0PYkNcKDWShNYIIz9x54cHiOKZM1pfLcM8oaPKJQVWBtYA0QbVWmnABAUBaHfq8CFPw","refreshToken":"SBCBKBVDUS6MFWNDJ9HCPW","deviceId":"c3990e26-80e2-4a1f-8c75-e8c071cd363d","tokenExpiresAt":1691148110,"controlTokenExpiresAt":0},"_environment":{"brand":"hyundai","host":"prd.eu-ccapi.hyundai.com:8080","baseUrl":"https://prd.eu-ccapi.hyundai.com:8080","clientId":"6d477c38-3ca4-4cf3-9557-2a1929a94654","appId":"1eba27d2-9a5b-4eba-8ec7-97eb6c62fb51","endpoints":{"session":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/authorize?response_type=code&state=test&client_id=6d477c38-3ca4-4cf3-9557-2a1929a94654&redirect_uri=https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/redirect","login":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin","language":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/language","redirectUri":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/redirect","token":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/token","integration":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/integrationinfo","silentSignIn":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/silentsignin"},"basicToken":"Basic NmQ0NzdjMzgtM2NhNC00Y2YzLTk1NTctMmExOTI5YTk0NjU0OktVeTQ5WHhQekxwTHVvSzB4aEJDNzdXNlZYaG10UVI5aVFobUlGampvWTRJcHhzVg==","GCMSenderID":"414998006775"},"authStrategies":{"main":{"language":"de"},"fallback":{"language":"de"}}},"_fullStatus":null,"_status":null,"_location":null,"_odometer":null,"region":"EU","serverRates":{"max":-1,"current":-1}}]
      2023-08-03 13:21:51.299 - debug: bluelink.0 (42536) Read new status from api for NLHDRXXXX
      2023-08-03 13:21:51.303 - info: bluelink.0 (42536) Read new update for NLHDRXXXX directly from the car
      2023-08-03 13:22:09.287 - debug: bluelink.0 (42536) Set new full status for NLHDRXXXX
      2023-08-03 13:22:09.288 - debug: bluelink.0 (42536) RAW {"vehicleStatus":{"airCtrlOn":false,"engine":false,"doorLock":true,"doorOpen":{"frontLeft":0,"frontRight":0,"backLeft":0,"backRight":0},"trunkOpen":false,"airTemp":{"value":"00H","unit":0,"hvacTempType":1},"defrost":false,"lowFuelLight":false,"acc":false,"hoodOpen":false,"transCond":false,"steerWheelHeat":0,"sideBackWindowHeat":0,"dte":{"value":328,"unit":1},"tirePressureLamp":{"tirePressureLampAll":0},"battery":{"batSoc":88,"batState":0},"sleepModeCheck":false,"time":"20230803092205","remoteWaitingTimeAlert":{"remoteControlAvailable":1,"remoteControlWaitingTime":168,"elapsedTime":"14:42:23"},"systemCutOffAlert":0,"tailLampStatus":0,"hazardStatus":0},"odometer":{"value":23293,"unit":1}}
      2023-08-03 13:22:09.714 - debug: bluelink.0 (42536) Set 88 battery state for NLHDRXXXX
      2023-08-03 13:22:09.719 - info: bluelink.0 (42536) Update for NLHDRXXXX successfull
        arteck Developer Most Active @wm20320 last edited by
        @wm20320 dann machmal den debug aus..und beobachte mal
          wm20320 @arteck last edited by wm20320
          @arteck Läuft bisher ohne errors - allerdings seit dem Start vor ca. 1 h keine Aktualisierung trotz (testweise) eingestellter 300 Anfragen pro Tag.
          Ergänzung: weiterhin keine Aktualisierung (3 h) - hab neu gestartet, aber Adapter ruft nur einmal ab - durchgängig aber keoine Errors (Lebenszeichen, Verbindung Host, Verbindung Gerät/Dienst: grüner Haken)
            arteck Developer Most Active @wm20320 last edited by arteck
            @wm20320
            warte bis 23 uhr dann hast du die infos.. die werden nur einmal am Tag geholt..
              @arteck Gestern um 23 Uhr ist nix passiert. Adapter läuft seit gestern 14:01 - seitdem kein log-Eintrag mehr. Timestamp in den Objekten nach wie vor auch 14:01 - ich beobachte mal weiter.
                @wm20320 dan lass mal schauen
                installier nochmal von GIT
                und such morgen im LOG nach
                DriveHistory Update for
                sollte um 23 uhr erscheinen
                ich seh gerade
                if (this.config.evHistory && this.config.motor != 'GAS') {
                für Benziner ist es nicht drin....
                kannst du ein trip verlauf in der App sehen ??
                W 2 Replies Last reply Reply Quote 0
                  @arteck 👍
                  Du meinst in der offizielen Bluelink-App? Ja, da kann ich sowohl die Trips abrufen, als auch den Fahrzeug-Standort. -- Beim Adapter werden keine Trip-Datenpunkte angelegt und der Datenpunkt vehicleLocation liest bei lat und lon fälschlicherweise "0°" aus. (positionURL und speed bleiben leer)
                  Update: "DriveHistory" find ich im LOG nicht, Datenpunkt lastInfoUpdate bleibt auch auf altem Wert, die anderen Werte sind aber trotzdem aktualisiert, scheint also zu passen 😊
                  • nik82
                    nik82 Most Active last edited by
                    @arteck
                    Kleinigkeit ist mir gerade aufgefallen, nicht schlimm, aber vielleicht ist es ja nur eine Kleinigkeit zum "fixen".
                    Wenn ich einen "Refresh from Server" mache, dann stellt es mir das Ladelimit immer auf 0 im Objekt:
                    Mach ich danach einen "Refresh from Car" dann ist es wieder richtig 🙂
                      @arteck Hi! Ist der Fix in der 2.3.6 schon mit drin? Oder war mein Problem so speziell, dass ich bei der /tarball/master bleiben sollte?
                      Jedenfalls nochmal Danke für den Fix!
                        @wm20320 welcher Fix ?
                          arteck Developer Most Active @nik82 last edited by
                          @nik82 ich lass es erstaml so.. kann sein dass der Server mal wieder spinnt.. beobachte das mal aber, bitte
                            @arteck Bootloop Benziner (Hyundai i10)
                              @wm20320 axo ja ist drin
                                daNick @arteck last edited by
                                Neues Subthema / Auswertung der Adapter Daten
                                Ich würde gerne Daten meines Hyundai Ioniq 5 über ioBroker an influxdb geben und dann über grafana auswerten
                                (Entwicklung Batterieladung, Durchschnitsverbrauch, Laufleistung, etc, was auch immer geht 🙂 )
                                Leider bin ich typischer Sekundär-Frickler ("Gib mir eine Vorlage, ich versuche dann was daraus zu bauen/es anzupassen").
                                Meine Frage:
                                Hat jemand schon etwas in der Richtung gebaut und kann "erste Hilfestellung zum späteren selber Weiterfliegen" geben?
                                Danke!
                                daNick
                                Meister Mopper Jackl1st 2 Replies Last reply Reply Quote 0
                                  Shadow79 @Newan last edited by Shadow79
                                  @newan Hallo, habe seit 3 Tagen auch einen Hyundai. Nutze auch IOBROKER. Bin aber ein NOOB. Ich habe den Adapter installiert und die Nutzerdate eingegeben. Eine Verbindung besteht auch. Aber mir werden unter Objekte keine Datein angezeigt. ? Bei meinen anderen Adapter bekomme ich ich daten angezeigt. WIe bei den Shellys usw. was mache ich falsch?
                                  Danke im Voraus
                                  Newan 1 Reply Last reply Reply Quote 0
                                  • Meister Mopper
                                    Meister Mopper @daNick last edited by
                                    @danick sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                    Das habe ich auch vor, ein Hexenwerk ist das nicht. Allerdings würde es bei den derzeit unzuverlässigen Servern von Hyundai/Kia zu großen Schwankungen bei den Daten kommen.
                                    Deshalb habe ich es zunächst hintangestellt.
                                    • Newan
                                      Newan @Shadow79 last edited by
                                      @shadow79 Das ist wie Glaskugel lesen.
                                      Ggf wird dein Auto nicht unterstützt? Welches ist es den und stell den Adapter mal auf debug, ggf steht dann da was im log
                                      • Jackl1st
                                        Jackl1st @daNick last edited by
                                        @danick , habe ich schon. Leider sind die Daten bei mir sehr unzuverlässig. Der Adapter läuft, aber ich bekomme zB. keine GPS Daten rein. Alles andere auch nur unzuverlässig.
                                        • Jackl1st
                                          Jackl1st @Jackl1st last edited by
                                          • Jackl1st
                                            Jackl1st @Jackl1st last edited by Jackl1st
                                            Vielleicht weiß jemand warum bei meinem Xceed keine GPS Daten ankommen?
                                            81.1k
                                            2281
                                            852711
