    4. Neuer Adapter für Roborock-Staubsauger
      SpacerX @SpacerX last edited by
      Ich habe nun mal Chrome installiert. Das ändert leider Garnichts.
      Noch mal eine Ausgabe dazu.
      [11:01:04.438][10.0.0.1:54441] server connect 142.250.184.206:443
      [11:01:04.485][10.0.0.1:54441] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for clients3.google.com, this may indicate that the client does not trust the proxy's certificate.
      [11:01:04.485][10.0.0.1:54441] client disconnect
      [11:01:04.485][10.0.0.1:54441] server disconnect 142.250.184.206:443
      [11:01:04.500][10.0.0.1:49611] client connect
      [11:01:04.610][10.0.0.1:54442] client connect
      [11:01:04.625][10.0.0.1:54442] server connect 142.250.184.206:443
      [11:01:04.672][10.0.0.1:54442] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for clients3.google.com, this may indicate that the client does not trust the proxy's certificate.
      [11:01:04.672][10.0.0.1:54442] client disconnect
      [11:01:04.672][10.0.0.1:54442] server disconnect 142.250.184.206:443
      [11:01:07.218][10.0.0.1:54381] client connect
      [11:01:07.250][10.0.0.1:54381] server connect 52.29.91.104:8883
      [11:01:07.359][10.0.0.1:54381] client disconnect
      [11:01:07.359][10.0.0.1:54381] server disconnect 52.29.91.104:8883
      [11:01:09.109][10.0.0.1:54443] client connect
      [11:01:09.124][10.0.0.1:54444] client connect
      [11:01:09.140][10.0.0.1:54443] server connect 18.195.207.39:443
      [11:01:09.155][10.0.0.1:54444] server connect 52.29.136.229:443
      [11:01:09.218][10.0.0.1:54443] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for api-eu.roborock.com, this may indicate that the client does not trust the proxy's certificate.
      [11:01:09.218][10.0.0.1:54443] client disconnect
      [11:01:09.218][10.0.0.1:54443] server disconnect 18.195.207.39:443
      [11:01:09.218][10.0.0.1:54444] Client TLS handshake failed. The client disconnected during the handshake. If this happens consistently for awsde0.fds.api.xiaomi.com, this may indicate that the client does not trust the proxy's certificate.
      Die Verbindung zum iPhone mit WireGuard scheint zu Funktionieren nur vom Proxy zu Roborock usw. klappt anscheinend nicht weil was mit dem Zertifikat nicht hin haut.
      Ehrlich gesagt ist so langsam meine Frustschwelle erreicht.
      <frust = on>
      Wer sich den ganzen Müll mit den Zertifikaten ausgedacht hat gehört geteert und gefedert.
      <frust = off>
      Vielleicht war mein Vorgehen bei der ganzen Installation auch falsch.
      • Python installiert
      • pip installiert [python -m pip install --user pipx]
      • Dann die Installationen zu mitmproxy
        • py -m pipx install mitmproxy --force
        • py -m pipx inject mitmproxy websocket
        • py -m pipx inject mitmproxy websocket-client
      Noch jemand eine Idee wie man das Prob gelöst bekommt?
      @copystring
      Geht der Installationskram auch anders. In der Wiki ist von Python als Voraussetzung nicht die Rede. Ich nehme mal an durch die Programmiererei hast du den Kram eh auf dem Rechner. Deshalb klappts bei dir ohne Prob. Ich hab's nur nicht so mit den Zertifikaten und hab immer versucht dem aus dem Weg zu gehen.
      copystring 1 Reply Last reply Reply Quote 0
      • jahnbes
        jahnbes @SpacerX last edited by
        @spacerx
        Hallo, ich habe das Wiki ergänzt, vielen Dank.
        Und Dein kleines Skript ist Klasse, ich habe bisher in der langen Liste immer geschaut, ob sich ein Datenpunkt ändert und wenn ja, wie.
        Viele Grüße, Bert.
          SpacerX @jahnbes last edited by
          @jahnbes sagte in Neuer Adapter für Roborock-Staubsauger:
          Das war mein Ansinnen. Weil man die Objekte ja nicht mit einmal auf den Bildschirm bekommt ist es unmöglich das vernünftig nach zu vollziehen.
          • copystring
            copystring @SpacerX last edited by
            @spacerx said in Neuer Adapter für Roborock-Staubsauger:
            Nein. mitmproxy braucht zwingend Python.
            Hast du das Zertifikat von mitmproxy denn auf dem iPhone als root Zertifikat hinzugefügt?
              SpacerX @copystring last edited by
              @copystring ja habe ich.
              • copystring
                copystring @SpacerX last edited by copystring
                @spacerx mit iPhone kenne ich mich nur wenig aus. Sicher, dass es als root Zertifikat hinzugefügt ist? Alle anderen Zertifikatstypen wären falsch.
                  @copystring das war das Stichwort. Es reichte nicht das Profil zu Installieren. Da muss man beim iPhone doch tiefer in die Abgründe der Einstellungen.
                  Jedenfalls zappelt jetzt was.
                    @spacerx
                    Ab und an tauchen folgende Meldungen auf.
                    C:\Users\SpacerX\.local\pipx\venvs\mitmproxy\Scripts\python.exe
                    [21:15:18.262] Packet type CONNACK is not supported yet!
                    [21:15:18.262] Addon error: unpack requires a buffer of 2 bytes
                    Traceback (most recent call last):
                      File "C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py", line 286, in tcp_message
                        mqtt_packet = MQTTControlPacket(message.content)
                      File "C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py", line 83, in __init__
                        self._parse_publish_variable_headers()
                      File "C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py", line 136, in _parse_publish_variable_headers
                        field_length, field_content_bytes = self._parse_length_prefixed_bytes(offset)
                      File "C:\ioBroker\node_modules\iobroker.roborock\lib\sniffing\mitmproxy_roborock.py", line 127, in _parse_length_prefixed_bytes
                        field_length = struct.unpack("!H", field_length_bytes)[0]
                    struct.error: unpack requires a buffer of 2 bytes
                    [21:15:18.309] [PUBLISH]
                    Die Sniffing Message taucht bei mir leider auch nicht im Log auf.
                    Jetzt weis ich noch nicht genau nach was ich schauen soll.
                    • copystring
                      @spacerx okay. Kann ich mir aktuell nicht angucken. Bin im Urlaub. Du müsstest dich gedulden oder selber mal schauen was das sein kann.
                        @copystring Alles gut!
                        Nachdem ich 24h Lebenszeit in das Unternehmen Sniffing verschwendet habe, habe ich der PC-Kiste erst mal den Strom abgedreht. Zur Frustbewältigung ein Eis gegessen und 3 Kippen verschlungen.
                        Nu hat es mir dann doch keine Ruhe gelassen. Also PC wieder an. ioBroker-Dienst + mitmproxy gestartet, Wireguard auf iPone angeschalten und Roborock App gestartet.
                        Jetzt passt auf was kommt!
                        Es Läuft. Decoded sniffing in der Log-Ausgabe.
                        Hier schon mal rausgepickt was ich herausfinden will.
                        2023-08-05 22:12:19.101  - roborock.0 (8400) Decoded sniffing message: {"dps":{"101":"{"id":277019,"method":"get_wash_towel_mode","params":{}}"},"t":1691266339}
                        2023-08-05 22:12:19.181  - roborock.0 (8400) dps debug: {"id":277019,"result":{"wash_mode":1}}
                        2023-08-05 22:12:19.204  - roborock.0 (8400) Decoded sniffing message: {"dps":{"101":"{"id":277020,"method":"get_smart_wash_params","params":{}}"},"t":1691266339}
                        2023-08-05 22:12:19.296  - roborock.0 (8400) dps debug: {"id":277020,"result":{"smart_wash":0,"wash_interval":1200}}
                        Das sind Teile von den Einstellungen der Dockingstation.
                        Ich bin erst mal Happy.
                        Falls jemand für das Sniffing mit Roborock App auf iPhone Unterstützung braucht kann ich gern mit meinen Notizen von diesem Amoklauf behilflich sein.
                        Gut Nächtle.
                          @jahnbes Bevor ich es vergessen!
                          In der Doku zu den Objekten vom Robi Hast du eingetragen:
                          wash_ready wird nach meiner Beobachtung und den Logs von oben immer dann auf TRUE wenn der Robi zum Mopp Waschen richtig herum an der Station angedockt hat. Unter dem Wasserbefüllstutzen am Roboter ist ein Mikroschalter der durch eine kleine Nase unter dem Wasserstutzen der Station betätigt wird.
                          wash_ready wird FALSE wenn der Robi nach dem Mopp Waschen wieder abdockt und der Robi dreht rum um in Ladeposition wieder anzudocken.
                          jahnbes 1 Reply Last reply Reply Quote 0
                            tritanium @jahnbes last edited by
                            @matt77che
                            Danke, so habe ich es jetzt auch im Wiki eingetragen.
                            Wenn ihr schon mal dabei seid, das Wiki zu vervollständigen 😄 wir haben einen Q7 Max+
                            Mehrfache Tests haben ergeben:
                            clean_type:
                            1 = Gesamt Reinigung (alle Räume)
                            2 = Zonenreinigung (ausgewählt über die App z.b.)
                            3 = Raumreinigung
                            start_type:
                            1 = manuell (Knopfdruck am Roboter)
                            2 = via App (aus der App gestartet oder per ioBroker.Adapter)
                            3 = Planstart (durch Zeitplanung in der App)
                            complete Type
                            1 = normal beendet
                            <> 1 = abgebrochen
                            Andere Werte habe ich auch noch, die schicke ich nachher noch nach 🙂
                            Gruß Micha
                            • jahnbes
                              @spacerx Danke, ist geändert!
                              • jahnbes
                                jahnbes @tritanium last edited by
                                @tritanium
                                Danke, MIcha, ich habe das Wiki ergänzt. Und warte auf Weiteres!
                                Ein schönes Wochenende noch, Gruß Bert.
                                  SpacerX @jahnbes last edited by SpacerX
                                  @jahnbes Sorry das ich nerve.
                                  Es ist genau umgekehrt!
                                  0 = Nicht bereit zum Mopp Waschen
                                  1 = Bereit zum Mopp Waschen und ggf. Wasser nachtanken
                                  Sagt aus das der Saugroboter richtig herum in der Station steht und bereit ist um den Mopp zu Waschen oder Wasser nachzutanken.
                                  Wenn der Robi beim Andocken zum Waschen den Befüllstutzen nicht treffen würde bleibt wash_ready auf 0 (FALSE)
                                  • jahnbes
                                    jahnbes @SpacerX last edited by jahnbes
                                    @spacerx
                                    Oh je, ich habe 0 und 1 und die Zuordnung von true und false dazu verwechselt. Mea culpa.
                                    Gruß Bert.
                                      tritanium @jahnbes last edited by tritanium
                                      @jahnbes
                                      So, diesmal habe ich mich mit dem Aufbau der JSON befasst.
                                      Datenpunkt ...CleaningInfo.JSON:
                                      begin + end:-------> Im TS Format
                                      duration:-----------> in Sekunden
                                      area:----------------> Gereingte Fläche (durch 1000000, für m²)
                                      error:---------------> 0 = ohne Fehler beendet
                                      complete:----------> 0 = abgebrochene Reinigung, 1 = Reingung beendet
                                      start_type:---------> siehe Wiki
                                      clean_type:--------> siehe Wiki
                                      dust_collection_Status: -----> 0 = Staub eingesammelt (nur), 1 = gesaugt + gewischt
                                      map_flag:-----------> Karten ID (bei mir immer 0, da nur eine Karte verwendet wird)
                                      Den DP "finish_reason" gibt es übrigens mit folgenden Ergebnissen:
                                      21
                                      24
                                      52
                                      54
                                      56
                                      Die bin ich aber noch am "testen" 🙂
                                      Habe die JSON bei mir in der VIS drin und dementspreechend formatiert:
                                      Melde mich wieder wenn ich mehr habe, bis dahin lg MIcha
                                      • jahnbes
                                        @tritanium
                                        Danke!
                                        • jahnbes
                                          Im Wiki ist die Unterteilung in "Roboter" und "Dock" aufgelöst. Sie war nicht mehr durchzuhalten. Jetzt ist alles wie im ioBroker angeordnet, also alphabetisch anhand des Objektnamens
                                          Wenn ein Objekt nur für eine Station relevant ist, wird das gleich nach seinem Namen durch das Wort "Dock" angezeigt.
                                          • Daniel Syberg
                                            Daniel Syberg last edited by
                                            ich habe gerade den Adapter installiert, die Instanz lässt sich auch öffnen.
                                            Allerdings bekomme ich keine Verbindung, es kommen immer wieder Fehlermeldungen und es erfolgt alle paar Sekunden ein Neutstart.
                                            Anbei die Meldungen im Log:
                                            Kann mir vielleicht jemand helfen?
                                            81.1k
                                            916
                                            311259
