    5. Problem mit einen vorher funktionierenden Script
      kurt_88 @paul53 last edited by kurt_88
      @paul53 Anbei das Script zum ansteuern des Heizstabes der Brauchwasser Wärmepumpe.
      Der Heizstab verbraucht so 1,6 KWh.
      Und der Java Teil.
      var delayOn, delayOff;
      on({id: [].concat(['0_userdata.0.Stromzaehler.Aktuell']), change: "ne"}, async function (obj) {
        var value = obj.state.val;
        if ((obj.state ? obj.state.val : "") >= -1300) {
          (function () {if (delayOn) {clearTimeout(delayOn); delayOn = null;}})();
        } else if ((obj.oldState ? obj.oldState.val : "") >= -1300) {
          delayOn = setTimeout(async function () {
            setState("zigbee.0.a4c1380d59c4e599.state"/*On/off state of the switch*/, true);
          }, 150000);
        if ((obj.state ? obj.state.val : "") <= 400) {
          (function () {if (delayOff) {clearTimeout(delayOff); delayOff = null;}})();
        } else if ((obj.oldState ? obj.oldState.val : "") <= 400) {
          delayOff = setTimeout(async function () {
            setState("zigbee.0.a4c1380d59c4e599.state"/*On/off state of the switch*/, false);
          }, 90000);
      sendTo("telegram", "send", {
          text: 'Heizstab bwbp ist an'
          text: 'Heizstab bwwp ist aus'
      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
      T paul53 2 Replies Last reply Reply Quote 0
        ticaki Developer @kurt_88 last edited by ticaki
        @kurt_88
        Der Javateil ist nur wichtig wenn du ein Problem hast und man findet es nicht im Skript (und für mich manchmal)
        hast du das - bei den 400 vergessen?
          kurt_88 @ticaki last edited by kurt_88
          @ticaki Wie meinst Du das mit bei den 400 vergessen?
            @kurt_88 du hast überall minus werte stehen ausser bei den 400
              @ticaki Das hängt mit dem auslesen des Stromzählers zusammen, bei negativen Werten speise ich über die Solarpannels den Strom ein und bei positiven Werten beziehe ich den Strom vom Versorger. Ich möchte dann nur bei größer werdenden Bezug von 400 Watt, dass sich der Heizstab wieder ausschaltet.
                paul53 @kurt_88 last edited by paul53
                @kurt_88 sagte: Script zum ansteuern des Heizstabes der Brauchwasser Wärmepumpe.
                Mache es besser mit nur einem Trigger (ein Skript).
                Vorschlag: Anstelle der verzögerten Abschaltung bei -855 W schalte den 1,6 kW Heizstab bei -1000 W ein und gleichzeitig die 400 W Heizung aus.
                  @paul53 Danke, dass sieht erheblich übersichtlicher aus, eine Bitte, könntest Du mir das Script noch im xml format posten? Dann kann ich das einfacher bei mir übernehmen.
                    @kurt_88 sagte: Script noch im xml format posten?
                     <variables>
                       <variable type="timeout" id="BadOn">BadOn</variable>
                       <variable type="timeout" id="WPOn">WPOn</variable>
                       <variable type="timeout" id="BadOff">BadOff</variable>
                       <variable type="timeout" id="WPOff">WPOff</variable>
                     </variables>
                     <block type="on_ext" id="Vk!`Ru5(z=}lka56G|sS" x="-1262" y="-1212">
                       <value name="OID0">
                         <shadow type="field_oid" id="_H{a+UiEMQa/Hvz{+]m,">
                           <field name="oid">0_userdata.0.Stromzaehler.Aktuell</field>
                         <block type="controls_if" id=";-c|_OeqD9AJHA3yS.]O">
                             <block type="logic_compare" id="g9EByzdjgOW=N6bdMFuN">
                               <field name="OP">GTE</field>
                                 <block type="on_source" id="aOe%6d2ijN}EAW6n6M!G">
                                 <block type="math_number" id=",6I/H7C!Rzb9nlk=)+~G">
                                   <field name="NUM">-500</field>
                             <block type="timeouts_cleartimeout" id="zoSm;acfB*sAm`_1Q9bm">
                               <field name="NAME">BadOn</field>
                           <value name="IF1">
                             <block type="logic_compare" id="hhAJOM.@{n)?p,I7nNp=">
                                 <block type="on_source" id="i[w%(9n|G0;=zRw_?Lap">
                                   <field name="ATTR">oldState.val</field>
                                 <block type="math_number" id="|=syCv%87$-nf}mYqNi3">
                           <statement name="DO1">
                             <block type="timeouts_settimeout" id="*PuamP#)z)Y,@rWv]OCg">
                               <field name="DELAY">150</field>
                                 <block type="control" id=".PM3||_$}I(@D~55m7Bk">
                                   <field name="OID">zigbee.0.a4c138c5b266a383.state</field>
                                     <block type="logic_boolean" id="`UZopM?377{Qt2jn:QBH">
                             <block type="controls_if" id="}0#xg;X*.!)n27!ZE!S7">
                                 <block type="logic_compare" id="#E:et(au|V?@~N^FAlAB">
                                     <block type="on_source" id="DhcUTan,=uaK~7Iwjz.j">
                                     <block type="math_number" id="PMh-=2@@H=Z!o%L+:5,H">
                                       <field name="NUM">-1000</field>
                                 <block type="timeouts_cleartimeout" id=",kBP5wN-pd{YWr6uNc[n">
                                   <field name="NAME">WPOn</field>
                               <value name="IF1">
                                 <block type="logic_compare" id=")+u8[OWw{_R`*E,KZzi#">
                                     <block type="on_source" id="Z2hY9iEce{NW-hbz603j">
                                     <block type="math_number" id="L,TSJ}TL|wQ8-E(iP6u8">
                                 <block type="timeouts_settimeout" id="1_H;fY4@IROl%B?Gdm/I">
                                     <block type="control" id=",~#4%+H))7LJu{w27H52">
                                         <block type="logic_boolean" id="6D,;)go=#[Z2B7:le,z7">
                                         <block type="control" id="giOOVGxxZQcwV:tsBKRJ">
                                           <field name="OID">0_userdata.0.Blockly.Switch</field>
                                             <block type="logic_boolean" id="cQ6CM7F9zQw89D=]{yO2">
                                 <block type="controls_if" id="_ichMh#kZF3kZan@2w}O">
                                     <block type="logic_compare" id="[DsB+yY)TZwx[6^5MV}D">
                                       <field name="OP">LTE</field>
                                         <block type="on_source" id="/#xd(wiy=pV.=L6)U2y_">
                                         <block type="math_number" id=")!4?b`XZ2NCj=mtuUGx3">
                                           <field name="NUM">-20</field>
                                     <block type="timeouts_cleartimeout" id="q-s4]kEZHvys$9$(~w1*">
                                       <field name="NAME">BadOff</field>
                                   <value name="IF1">
                                     <block type="logic_compare" id="TF6x8%zv;jBVW:3Z[]jc">
                                         <block type="on_source" id="@_G;s)Ws{V,1{0hAXXta">
                                         <block type="math_number" id="y2l{,^~g`3@l4EiYzg!S">
                                     <block type="timeouts_settimeout" id="Os=E:51nQq#-Y(T!sT?X">
                                       <field name="DELAY">120</field>
                                         <block type="control" id="Y(LyJ^@ZkO_G(_NL`Q:+">
                                             <block type="logic_boolean" id="JXhIApHzB]RuIapvt0*f">
                                     <block type="controls_if" id="K^Y1A!$K,l3LKxdd3CW!">
                                         <block type="logic_compare" id="U=et!uU$?WtNBLFd*9n|">
                                             <block type="on_source" id="!)DUMg?[vFBHWH3L4N=.">
                                             <block type="math_number" id="tgLzrg=Wl9W_$aeN%li=">
                                               <field name="NUM">400</field>
                                         <block type="timeouts_cleartimeout" id="5F.#I0U_/Fv-:fX{CZ?,">
                                           <field name="NAME">WPOff</field>
                                       <value name="IF1">
                                         <block type="logic_compare" id="c=Tg;VU;um,eqg85^Egn">
                                             <block type="on_source" id="B%N8/c(+IX?DuEDf$uZY">
                                             <block type="math_number" id=".!T6PgD4}9N!wz{Qj3z4">
                                         <block type="timeouts_settimeout" id="SJ-swm78U@Z[PPFv}Oo*">
                                           <field name="DELAY">90</field>
                                             <block type="control" id="zu:NS;t`@gCzP1hEN5$+">
                                                 <block type="logic_boolean" id="%6givn4N1E/Gfq)]gBu8">
                     <block type="on_ext" id="@4`.~ED)M=MdrIu7^a=e" x="-562" y="-1212">
                       <value name="OID0">
                         <shadow type="field_oid" id="l5jBM,Dnty}GLYo[8y%K">
                         <block type="text" id="cnL_juyDIvH5Pyg)ad-/">
                           <field name="TEXT">zigbee.0.a4c138c5b266a383.state</field>
                         <block type="telegram" id="D]_RwFq7u3/*W~~d!E2{">
                           <field name="LOG"></field>
                           <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                           <value name="MESSAGE">
                             <shadow type="text" id="^HO7u[,7m*ZH(cgXlq_r">
                               <field name="TEXT">Heizung Bad2 ist aus</field>
                             <block type="text_join" id="llif0$``7rg,!9s+H0JQ">
                               <value name="ADD0">
                                 <block type="text" id="(%s?wKRYR?$!c=!UN8lc">
                                   <field name="TEXT">Heizung Bad2 ist </field>
                               <value name="ADD1">
                                 <block type="logic_ternary" id="U@s976kEk#A{@9$Dw~w3">
                                   <value name="IF">
                                     <block type="on_source" id="N-p`pim$!xOa`a-fpv1|">
                                   <value name="THEN">
                                     <block type="text" id=".~/u?:Tjgd7Q^4F_Jc/y">
                                       <field name="TEXT">an</field>
                                   <value name="ELSE">
                                     <block type="text" id="IaAtw3_Of?-/;~zmjSA0">
                                       <field name="TEXT">aus</field>
                         <block type="on_ext" id="7XAl,I4rWK70,QpHn:lu">
                           <value name="OID0">
                             <shadow type="field_oid" id="QeaK^hfm}pHgOD+?bx2o">
                               <field name="oid">0_userdata.0.Blockly.Switch</field>
                             <block type="telegram" id="K.4F{_SjV2~ZgHA]TwVT">
                                 <shadow type="text">
                                 <block type="text_join" id="El)d!2nwS-[M!{~6irsS">
                                   <value name="ADD0">
                                     <block type="text" id="0p=ur+VH,.4ha)kqlw+|">
                                       <field name="TEXT">Heizstab bwbp ist </field>
                                   <value name="ADD1">
                                     <block type="logic_ternary" id="rGwzB!JofwDWV)xk?d7K">
                                       <value name="IF">
                                         <block type="on_source" id="%dxdS.MEsY+f|/Qk?|ob">
                                       <value name="THEN">
                                         <block type="text" id="fyKg@gT*NW#Ad%0-/q4{">
                                       <value name="ELSE">
                                         <block type="text" id="u6./+x-Nlhy`HA8M|s9I">
                      @paul53 Danke, übersehe ich jetzt was? Bei dem Script wird aber nicht der Heizstab der Wärmepumpe zugeschaltet, oder? Da müsste dann der Block mit zigbee.0.a4c1380d59c4e599 noch rein?
                        @kurt_88 sagte: Bei dem Script wird aber nicht der Heizstab der Wärmepumpe zugeschaltet
                        Der Datenpunkt "Switch" muss durch den DP für den Heizstab ersetzt werden. Ich hatte ihn nicht zur Verfügung.
                          @paul53 Ok, ich habe mal wieder den Wald vor lauter Bäumen nicht gesehen, nochmals vielen Dank. Ich werde mal gleich testen, es scheint auch gerade die Sonne. 🙂
                          Mikewolf 1 Reply Last reply Reply Quote 0
                          • Mikewolf
                            Mikewolf @kurt_88 last edited by
                            @kurt_88 will den thread nicht kapern, hatte aber immer Probleme wenn wert ein - Vorzeichen hat,
                            das Ding hat auch bei -500 geschalten obwohl ich als BEdingung hatte grösser /gleich 0 , als ich dann vorher den wert *-1 gerechnet habe und dann auf diesen gerechneten wert getrigert habe ,funktionierte alles (vorher ca 2,5 Jahren hat es damals funktioniert , nur dann irgend ein Update und seitdem nicht mehr) kann aber nicht genau sagen wann es war , waren 3Schlaganfälle dazwischen sorry
                              kurt_88 @Mikewolf last edited by
                              @mikewolf Danke kein Problem, wie meinst Du das mit *-? Du stellst bei -500 einfach ein Stern davor, dann müsst es *-500 heißen?
                              1628
