      smarthome2020 @MCU last edited by
      @mcu
      ja, nutze Spotify auch als Adapter.
      Skriptneustart:
      javascript.0
      2023-07-26 22:15:19.753	info	script.js.Peripherie.Jarvis.Spotify_PlayList_v1_0_5: registered 6 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      javascript.0
      2023-07-26 22:15:19.753	info	script.js.Peripherie.Jarvis.Spotify_PlayList_v1_0_5: Script playListSpotify 1.0.5 gestartet!
      javascript.0
      2023-07-26 22:15:19.750	info	Start javascript script.js.Peripherie.Jarvis.Spotify_PlayList_v1_0_5
      javascript.0
      2023-07-26 22:15:19.465	info	script.js.Peripherie.Jarvis.TrackListHTML_v1_0_6: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      javascript.0
      2023-07-26 22:15:19.458	info	Start javascript script.js.Peripherie.Jarvis.TrackListHTML_v1_0_6
      javascript.0
      2023-07-26 22:15:17.864	info	Stop script script.js.Peripherie.Jarvis.TrackListHTML_v1_0_6
      javascript.0
      2023-07-26 22:15:17.384	info	Stop script script.js.Peripherie.Jarvis.Spotify_PlayList_v1_0_5
      Playlist holen:
      javascript.0
      2023-07-26 22:16:16.817	info	script.js.Peripherie.Jarvis.Spotify_PlayList_v1_0_5: Jarvis-Devices von Instanz 0 im angegebenen Device geändert!
      javascript.0
      2023-07-26 22:16:16.816	info	script.js.Peripherie.Jarvis.Spotify_PlayList_v1_0_5: ElementValue: {"":"Keine Auswahl","Pop Brandneu":"Pop Brandneu","Testosteron":"Testosteron"}
      javascript.0
      2023-07-26 22:16:16.815	info	script.js.Peripherie.Jarvis.Spotify_PlayList_v1_0_5: JarviSel - SpotifyInstanz: 0
      javascript.0
      2023-07-26 22:16:16.815	info	script.js.Peripherie.Jarvis.Spotify_PlayList_v1_0_5: Anzahl Playlist in Spotify: 2 - {"":"Keine Auswahl","Pop Brandneu":"Pop Brandneu","Testosteron":"Testosteron"}
        MCU @smarthome2020 last edited by
        @smarthome2020
        Welche IP hat der Server auf dem simpleApi installiert ist?
        Ist die IP-Adresse im Script hinterlegt?
          smarthome2020 @MCU last edited by smarthome2020
          @mcu
          IP ist die des ioBrokers und ist in den Skripten hinterlegt.
          Unter PlayListSelect zeigt sich im Datenpunkt folgende Auswahl:
            MCU last edited by
            @smarthome2020 Wechsel auf den anderen thread.
            https://forum.iobroker.net/topic/52228/howto-zusatz-programme-fuer-jarvis-v3/282
            • I
              ioBroker-lover last edited by
              Während früher alle paar Tage Updates kamen, liegt die Entwicklung auf Git nun scheinbar bereits zwei Monate.
              Jeder verdient eine Pause, aber da es früher sehr regelmäßig Infos zum Entwicklungsstand gab, frage ich mich doch, ob beim Entwickler alles gut ist.
              Gibt es offizielle Infos, hab ich was verpasst?
                MCU @ioBroker-lover last edited by
                @iobroker-lover Der Entwickler ist gerade umgezogen, er versucht so schnell wie möglich wieder weiter die Issues zu bearbeiten.
                  MCU last edited by MCU
                  @andreas-bosch
                  Bitte ab Aufgaben ein Objekt-Export.
                  Brauche Daten zum Testen.
                  Man kann sich schon mal einlesen:
                  https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/scripts-3.1.x-pro/sonstige-skripte/kombinationsskripte/jsonworks
                    memme last edited by
                    ich binde meine Hivision Kameras per DisplayImage ein. Das funktioniert auch gut. Ein Bild pro Sekunde reicht als Übersicht (10 Kameras).
                    Nun würde ich gerne ein Bild temporär (für eine Minute) als Vollbild anzeigen lassen. Wie mache ich das?
                    Es gibt einen Hikvision adapter, der ein DP bei detektierter Bewegung auf true schaltet und dann würde ich die Kamera gerne im Vollbild anzeigen.
                    Danke & Grüße
                      MCU @memme last edited by
                      @memme Fullscreen erlauben
                        hotspot_2 last edited by
                        ich bekomme in unregelmäßigen Abständen diese Meldung hier:
                        Meine Lizenz habe ich aber erst verlängert.
                        Muss ich da was unternehmen?
                          MCU @hotspot_2 last edited by
                          @hotspot_2 Hast du bei der Verlängerung auch wieder eine txt-Datei mit der Lizenz erhalten?
                          Wenn ja, dann diese wieder in jarvis.0.info.pro einfügen
                            hotspot_2 @MCU last edited by
                            @mcu Danke. Das habe ich nicht gemacht, jetzt aber. Dann sollte es jetzt passen.
                              @mcu und wie trigger ich das? Sodass bei dp Änderung 1 Minute full screen der jeweiligen Kamera kommt?Danke
                                @memme Doppelklick auf die Widgetzeile?
                                Oder wie meinst du es?
                                  memme @MCU last edited by
                                  @mcu
                                  Wenn eine Kamera eine Bewegung detektiert wird ein Datenpunkt auf true gesetzt und dann soll das entsprechende Kamerabild für eine Minute fullscreen angezeigt werden.
                                  Also ohne manuelle interaktion
                                    @memme Dann kann man mit Notification arbeiten.
                                    https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/notifications-pro/synology-bild
                                      @mcu kannst du das genauer erklären?
                                        MCU @memme last edited by MCU
                                        @memme Lies dir bitte den Bereich Notification durch, kann leider nicht so intensiv helfen, wie sonst. Habe hier auch nicht das schnelle Equipment.
                                        Dann beschreiben bitte was du noch an Hilfe benötigst.
                                        Dazu bitte die Link-Adresse einstellen, die für die Anzeige vom Bild genutzt wird, wenn der Schalter true ist.
                                          memme @MCU last edited by memme
                                          @mcu
                                          @mcu Hab es nun mal ausprobiert. Leider bekomme ich es nur mit einem standbild zum laufen.
                                          Standbild URL:
                                          let httpAdr = "http://user:pw@IP/ISAPI/Streaming/channels/102/picture";
                                          Das funktioniert. Aber ein Standbild ist eher semi optimal. Gibt es ne möglichkeit den Iframe alle 1s zu reloaden? dann wäre das auch ok.
                                          Mjpeg Stream:
                                          let httpAdr = "http://user:pw@IP/ISAPI/Streaming/channels/102/httppreview";
                                          Leider haut Firefox da eine Fehlermeldung raus und öffnet den stream nicht:
                                          Firefox darf diese eingebettete Seite nicht öffnen
                                          Rtsp Stream:
                                          let httpAdr = "rtsp://user:pw@IP/ISAPI/Streaming/channels/102/";
                                          Da kommt leider gar kein bild obwohl der stream im VLC geht.
                                          Ich habe es auch mal versucht den Stream in Jarvis per State HTMl wiederzugeben. Da kommt nur ein Play button:
                                          String DP angelegt und dann im State Html hinterlegt:
                                          <html>
                                          <head>
                                          <meta charset=utf-8 />
                                          <title>Your title</title>
                                            <link href="https://unpkg.com/video.js/dist/video-js.css" rel="stylesheet">
                                            <script src="https://unpkg.com/video.js/dist/video.js"></script>
                                            <script src="https://unpkg.com/@videojs/http-streaming/dist/videojs-http-streaming.js"></script>
                                          </head>
                                          <body>
                                            <video height="500" id="Stellplatz" class="video-js vjs-fluid vjs-default-skin" controls preload="auto"
                                            data-setup='{}'>
                                              <source src="http://user:pw@IP/ISAPI/Streaming/channels/102/httppreview" type="application/x-mpegURL">
                                            </video>
                                          <script>
                                          var player = videojs('Stellplatz', {autoplay: 'any'});
                                          player.play();
                                          </script>
                                          </body>
                                          </html>
                                          M I 2 Replies Last reply Reply Quote 0
                                            @memme Gibt es bei der Kamera kein Video Stream als Link?
                                            M M 2 Replies Last reply Reply Quote 0
                                            254
                                            4489
                                            2668934
