    4. Huawei Sun2000 & ioBroker via JS script funktioniert
      R4 @leonundjulie last edited by
      @leonundjulie
      Für Versionsinfos auch hier schauen, man muss nur bisschen suchen...
      Beim SDongle sind V100R001C00SPC133 bzw. V200R022C10SPC107 derzeit aktuell.
        hussi last edited by hussi
        Guten Tag zusammen,
        ich bräuchte mal ein kleines bisschen Unterstützung. Ich möchte das Skript von @Chris_B etwas abspecken. Ich brauche das Zusammenrechnen der Verbrauche zum Beispiel nicht.
        Dies ist mein Ausgangscode:
        // From iobroker Forum: "Huawei Sun2000 & ioBroker via JS script funktioniert"
        // https://forum.iobroker.net/topic/53005/huawei-sun2000-iobroker-via-js-script-funktioniert
        createState("javascript.0.Solarpower.Derived.BatteryOverview", "",  {read: true, write: true, name: "Battery Overview SOC"});
        createState("javascript.0.Solarpower.Derived.HouseConsumption", "",  {read: true, write: true, name: "Consumption of House", unit: "W"});
        createState("javascript.0.Solarpower.Derived.YieldToday", "",  {read: true, write: true, name: "Yield Today", unit: "kW"});
        createState("javascript.0.Solarpower.Derived.IsBatteryLoading", 0,  {read: true, write: true, name: "Luna 2000 Battery is loading", type: "number"});
        createState("javascript.0.Solarpower.Derived.IsGridExporting", 0,  {read: true, write: true, name: "Exporting Power to Grid", type: "number"});
        createState("javascript.0.Solarpower.Derived.PeakPanelPower", 0,  {read: true, write: true, name: "Peak panel power today"});
        createState("javascript.0.Solarpower.Derived.GridExportSum", 0,  {read: true, write: true, name: "Total export to grid", unit: "kWh"});
        createState("javascript.0.Solarpower.Derived.GridImportSum", 0,  {read: true, write: true, name: "Total import from grid", unit: "kWh"});
        createState("javascript.0.Solarpower.Derived.GridExportToday", 0,  {read: true, write: true, name: "Export to grid today", unit: "kWh"});
        createState("javascript.0.Solarpower.Derived.GridImportToday", 0,  {read: true, write: true, name: "Import from grid today", unit: "kWh"});
        createState("javascript.0.Solarpower.Derived.ConsumptionToday", 0,  {read: true, write: true, name: "Consumption today", unit: "kWh"});
        createState("javascript.0.Solarpower.Derived.ConsumptionSum", 0,  {read: true, write: true, name: "Consumption total sum", unit: "kWh"});
        createState("javascript.0.Solarpower.Derived.ConsumptionStart", 0,  {read: true, write: true, name: "Consumption total sum at start of day", unit: "kWh"});
        var ModbusRTU = require("modbus-serial");
        var fs = require('fs');
        var client = new ModbusRTU();
        var testCreateState = 0;
        var currentinverter = 1;
        var modbusErrorMessages =
        [   "Unknown error",
            "Illegal function (device does not support this read/write function)",
            "Illegal data address (register not supported by device)",
            "Illegal data value (value cannot be written to this register)",
            "Slave device failure (device reports internal error)",
            "Acknowledge (requested data will be available later)",
            "Slave device busy (retry request again later)"
        // open connection to a tcp line
        client.setTimeout(10000);
        // Enter your inverter modbus IP and port here:
        client.connectTCP("192.168.1.108", { port: 502 });
        // Enter the Modbus-IDs of your Sun2000 inverters here (example for two inverters): const ModBusIDs = [16, 1];
        const ModBusIDs = [1];
        // On which Modbus-ID can we reach the power meter? (via Sun2000!)
        const PowerMeterID = 0;
        // Enter your battery stack setup. 2 dimensional array, e.g. [[3, 2], [3, 0]] means:
        // First inverter has two battery stacks with 3 + 2 battery modules
        // while second inverter has only one battery stack with 3 battery modules
        const BatteryUnits = [[1, 0]];
        // These register spaces need to be read
        const RegToRead =
        [ [32000, 116],   // inverter status -                            read fast
          [37000, 68],    // battery information -                        read fast
          [37100, 114],   // meter info -                                 read fast
          [37700, 100],   // battery information -                        read fast
          [38200, 100],   // additional battery information -             read fast
          [30000, 81],    // model info, SN, max Power (static info) -    read slow
          [37800, 100],   // additional battery information -             read slow
          [38300, 100],   // additional battery information -             read slow
          [38400, 100]    // additional battery information -             read slow
        //[35300, 40]     // inverter power adjustments -                 do not read
        const RegFast = 5;      // number of register spaces to read fast (must be < RegToRead.length)
        const RegFastMod = 10;  // read slow registers every n'th time (mod operator)
        var RegReadCnt = 0;     // Loop counter
        var RegToReadPtr = 0;   // pointer to register spaces
        var GlobalDataBuffer = new Array(2);
        for ( var i=0; i < ModBusIDs.length; i++)
            GlobalDataBuffer[i] = new Array(50000); // not optimized....
        // Some helper functions
        function readUnsignedInt16(array)
        {   return array[0];
        function readUnsignedInt32(array)
        {   return array[0] * 256 * 256 + array[1];
        function readSignedInt16(array)
        {   var value = 0;
            if (array[0] > 32767)   value = array[0] - 65535;
                else                value = array[0];
            return value;
        function readSignedInt32(array)
        {   var value = 0;
            for (var i = 0; i < 2; i++) { value = (value << 16) | array[i]; }
            return value;
        function getU16(dataarray, index)
        {   return readUnsignedInt16(dataarray.slice(index, index+1));
        function getU32(dataarray, index)
        {   return readUnsignedInt32(dataarray.slice(index, index+2));
        function getI16(dataarray, index)
        {   return readSignedInt16(dataarray.slice(index, index+1));
        function getI32(dataarray, index)
        {   return readSignedInt32(dataarray.slice(index, index+2));
        function getString(dataarray, index, length)
        {   var shortarray = dataarray.slice(index, index+length);
            var bytearray = [];
            for (var i = 0; i < length; i++)
            {   bytearray.push(dataarray[index+i] >> 8);
                bytearray.push(dataarray[index+i] & 0xff);
            var value =  String.fromCharCode.apply(null, bytearray);
            return value;
        function getZeroTerminatedString(dataarray, index, length)
            var bytearray = [];
            for(var i = 0; i < length; i++)
            var value2 = new String(value).trim();
            return value2;
        function forcesetState(objectname, value, options)
        // perform createState() only if variable does not yet exist, and perform the check via existsState() only once for each processing round
        {   if (testCreateState == 0)
            {   if (!existsState("javascript.0." + objectname)) { createState(objectname, value, options); }
                else                                            { setState(objectname, value); }
            } else
        // Functions to map registers into ioBreaker objects
        function ProcessOptimizers(id)
            forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerTotalNumber",     getU16(GlobalDataBuffer[id-1], 37200), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerOnlineNumber",    getU16(GlobalDataBuffer[id-1], 37201), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerFeatureData",     getU16(GlobalDataBuffer[id-1], 37202), {name: "", unit: ""});
        function ProcessInverterPowerAdjustments(id)
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementMode",     getU16(GlobalDataBuffer[id-1], 35300), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementValue",    getU32(GlobalDataBuffer[id-1], 35301), {name: "", unit: ""}); // Note: This might be an error in the manual. It says register 35302 with quantity 2, but on 35303 is already the next value.
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementCommand",  getU16(GlobalDataBuffer[id-1], 35303), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementMode",   getU16(GlobalDataBuffer[id-1], 35304), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementValue",  getU32(GlobalDataBuffer[id-1], 35305), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementCommand",getU16(GlobalDataBuffer[id-1], 35307), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.PowerMeterActivePower",     getI32(GlobalDataBuffer[id-1], 35313), {name: "", unit: ""});
        function ProcessBattery(id)
            // Battery registers 1-15 (Stack 1 related)
            if ( BatteryUnits[id-1][0] > 0)
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RunningStatus",               getU16(GlobalDataBuffer[id-1], 37000), {name: "", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.ChargeAndDischargePower",     getI32(GlobalDataBuffer[id-1], 37001), {name: "Charge and Discharge Power", unit: "W"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BusVoltage",                  getU16(GlobalDataBuffer[id-1], 37003) / 10, {name: "Busvoltage", unit: "V"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BatterySOC",                  getU16(GlobalDataBuffer[id-1], 37004) / 10, {name: "Battery SOC", unit: "%"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.WorkingMode",                 getU16(GlobalDataBuffer[id-1], 37006), {name: "Working Mode", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RatedChargePower",            getU32(GlobalDataBuffer[id-1], 37007), {name: "", unit: "W"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RatedDischargePower",         getU32(GlobalDataBuffer[id-1], 37009), {name: "", unit: "W"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.FaultID",                     getU16(GlobalDataBuffer[id-1], 37014), {name: "", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37015) * 10, {name: "", unit: "Wh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37017) * 10, {name: "", unit: "Wh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BusCurrent",                  getI16(GlobalDataBuffer[id-1], 37021) / 10, {name: "Buscurrent", unit: "A"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BatteryTemperature",          getI16(GlobalDataBuffer[id-1], 37022) / 10, {name: "Battery Temperatue", unit: "°C"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RemainingChargeDischargeTime",getU16(GlobalDataBuffer[id-1], 37025), {name: "", unit: "mins"});
                //forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.DCDCversion",                 getZeroTerminatedString(GlobalDataBuffer[id-1], 37026, 10), {name: "", unit: ""});
                //forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BMSversion",                  getZeroTerminatedString(GlobalDataBuffer[id-1], 37036, 10), {name: "", unit: ""});
            // Battery registers 16+17 (Storage-related)
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.MaximumChargePower",                     getU32(GlobalDataBuffer[id-1], 37046), {name: "", unit: "W"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.MaximumDischargePower",                  getU32(GlobalDataBuffer[id-1], 37048), {name: "", unit: "W"});
            // Battery register 18-20 (Stack 1 related)
            if (BatteryUnits[id-1][0] > 0)
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.SN",         getZeroTerminatedString(GlobalDataBuffer[id-1], 37052, 10), {name: "Serialnumber", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.TotalCharge",                 getU32(GlobalDataBuffer[id-1], 37066) * 10, {name: "", unit: "Wh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.TotalDischarge",              getU32(GlobalDataBuffer[id-1], 37068) * 10, {name: "", unit: "Wh"});
            // Battery register 21-31 (Stack 2 related)
            if ( BatteryUnits[id-1][1] > 0)
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.SN",         getZeroTerminatedString(GlobalDataBuffer[id-1], 37700, 10), {name: "Serialnumber", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BatterySOC",                  getU16(GlobalDataBuffer[id-1], 37738) / 10, {name: "", unit: "%"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.RunningStatus",               getU16(GlobalDataBuffer[id-1], 37741), {name: "", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.ChargeAndDischargePower",     getI32(GlobalDataBuffer[id-1], 37743), {name: "", unit: "W"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37746) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37748) / 100, {name: "", unit: "kWh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BusVoltage",                  getU16(GlobalDataBuffer[id-1], 37750) / 10, {name: "", unit: "V"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BusCurrent",                  getI16(GlobalDataBuffer[id-1], 37751) / 10, {name: "", unit: "A"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BatteryTemperature",          getI16(GlobalDataBuffer[id-1], 37752) / 10, {name: "", unit: "°C"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.TotalCharge",                 getU32(GlobalDataBuffer[id-1], 37753) * 10, {name: "", unit: "Wh"});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.TotalDischarge",              getU32(GlobalDataBuffer[id-1], 37755) * 10, {name: "", unit: "Wh"});
            // Battery register 32-41 (Storage related)
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.RatedCapacity",                          getU32(GlobalDataBuffer[id-1], 37758) / 1, {name: "", unit: "Wh"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.SOC",                                    getU16(GlobalDataBuffer[id-1], 37760) / 10, {name: "", unit: "%"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.RunningStatus",                          getU16(GlobalDataBuffer[id-1], 37762) / 1, {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.BusVoltage",                             getU16(GlobalDataBuffer[id-1], 37763) / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.BusCurrent",                             getI16(GlobalDataBuffer[id-1], 37764) / 10, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.ChargeAndDischargePower",                getI32(GlobalDataBuffer[id-1], 37765) / 1, {name: "", unit: "W"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.TotalCharge",                            getU32(GlobalDataBuffer[id-1], 37780) * 10, {name: "", unit: "Wh"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.TotalDischarge",                         getU32(GlobalDataBuffer[id-1], 37782) * 10, {name: "", unit: "Wh"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.CurrentDayChargeCapacity",               getU32(GlobalDataBuffer[id-1], 37784) * 10, {name: "", unit: "Wh"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.CurrentDayDischargeCapacity",            getU32(GlobalDataBuffer[id-1], 37786) * 10, {name: "Current DayDiscarge ", unit: "Wh"});
            // Battery registers 42+43 (Battery stack related)
            if (BatteryUnits[id-1][1] > 0)
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.SoftwareVersion", getZeroTerminatedString(GlobalDataBuffer[id-1], 37814, 8), {name: "Softwareversion", unit: ""});
                forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.SoftwareVersion", getZeroTerminatedString(GlobalDataBuffer[id-1], 37799, 8), {name: "Softwareversion", unit: ""});
            // Registers 44 to 98: (Battery pack related)
            for(var i = 1; i <= 2; i++)
                if(BatteryUnits[id-1][i-1] >= 0)
                    for(var j = 1; j <= BatteryUnits[id-1][i-1]; j++)
                        //[[38200, 38242, 38284] [38326, 38368, 38410]]; (+42 for each battery pack, +126 for each stack)
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".SN",              getZeroTerminatedString(GlobalDataBuffer[id-1], 38200+(i-1)*126+(j-1)*42, 6), {name: "", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".FirmwareVersion", getZeroTerminatedString(GlobalDataBuffer[id-1], 38210+(i-1)*126+(j-1)*42, 8), {name: "", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".WorkingStatus",                    getU16(GlobalDataBuffer[id-1], 38228+(i-1)*126+(j-1)*42), {name: "", unit: ""});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".BatterySOC",                       getU16(GlobalDataBuffer[id-1], 38229+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "%"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".ChargeAndDischargePower",          getI32(GlobalDataBuffer[id-1], 38233+(i-1)*126+(j-1)*42) / 1000, {name: "", unit: "kW"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Voltage",                          getU16(GlobalDataBuffer[id-1], 38235+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "V"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Current",                          getI16(GlobalDataBuffer[id-1], 38236+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "A"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalCharge",                      getU32(GlobalDataBuffer[id-1], 38238+(i-1)*126+(j-1)*42) * 10, {name: "", unit: "Wh"});
                        forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalDischarge",                   getU32(GlobalDataBuffer[id-1], 38240+(i-1)*126+(j-1)*42) * 10, {name: "", unit: "Wh"});
                        // [[38452, 38454, 38456][38458, 38460, 38462]] ( +2 for each pack, +6 for each stack)
                        createState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MaxTemperature", getI16(GlobalDataBuffer[id-1], 38452+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                        createState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MinTemperature", getI16(GlobalDataBuffer[id-1], 38453+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
            // Battery registers 110-141 are not supported by this script yet!
        function ProcessPowerMeterStatus()
            forcesetState("Solarpower.Huawei.Meter.Status",                   getU16(GlobalDataBuffer[PowerMeterID], 37100), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Meter.VoltageL1",                getI32(GlobalDataBuffer[PowerMeterID], 37101)  / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Meter.VoltageL2",                getI32(GlobalDataBuffer[PowerMeterID], 37103)  / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Meter.VoltageL3",                getI32(GlobalDataBuffer[PowerMeterID], 37105)  / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Meter.CurrentL1",                getI32(GlobalDataBuffer[PowerMeterID], 37107)  / 100, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Meter.CurrentL2",                getI32(GlobalDataBuffer[PowerMeterID], 37109)  / 100, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Meter.CurrentL3",                getI32(GlobalDataBuffer[PowerMeterID], 37111) / 100, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Meter.ActivePower",              getI32(GlobalDataBuffer[PowerMeterID], 37113) / 1, {name: "", unit: "W"});
            forcesetState("Solarpower.Huawei.Meter.ReactivePower",            getI32(GlobalDataBuffer[PowerMeterID], 37115) / 1, {name: "", unit: "Var"});
            forcesetState("Solarpower.Huawei.Meter.PowerFactor",              getI16(GlobalDataBuffer[PowerMeterID], 37117) / 1000, {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Meter.GridFrequency",            getI16(GlobalDataBuffer[PowerMeterID], 37118) / 100, {name: "", unit: "Hz"});
            forcesetState("Solarpower.Huawei.Meter.PositiveActiveEnergy",     getI32(GlobalDataBuffer[PowerMeterID], 37119) * 10, {name: "", unit: "Wh"});
            forcesetState("Solarpower.Huawei.Meter.ReverseActiveEnergy",      getI32(GlobalDataBuffer[PowerMeterID], 37121) * 10, {name: "", unit: "Wh"});
            forcesetState("Solarpower.Huawei.Meter.AccumulatedReactivePower", getI32(GlobalDataBuffer[PowerMeterID], 37123) / 100, {name: "", unit: "kVarh"});
            //forcesetState("Solarpower.Huawei.Meter.MeterType",                getU16(GlobalDataBuffer[PowerMeterID], 37125), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Meter.VoltageL1-L2",             getI32(GlobalDataBuffer[PowerMeterID], 37126) / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Meter.VoltageL2-L3",             getI32(GlobalDataBuffer[PowerMeterID], 37128) / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Meter.VoltageL3-L1",             getI32(GlobalDataBuffer[PowerMeterID], 37130) / 10, {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Meter.ActivePowerL1",            getI32(GlobalDataBuffer[PowerMeterID], 37132) / 1, {name: "", unit: "W"});
            forcesetState("Solarpower.Huawei.Meter.ActivePowerL2",            getI32(GlobalDataBuffer[PowerMeterID], 37134) / 1, {name: "", unit: "W"});
            forcesetState("Solarpower.Huawei.Meter.ActivePowerL3",            getI32(GlobalDataBuffer[PowerMeterID], 37136) / 1, {name: "", unit: "W"});
            //forcesetState("Solarpower.Huawei.Meter.MeterModel",               getU16(GlobalDataBuffer[PowerMeterID], 37138), {name: "", unit: ""});
        function ProcessInverterStatus(id)
            forcesetState("Solarpower.Huawei.Inverter." + id + ".State1",                 getU16(GlobalDataBuffer[id-1], 32000), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".State2",                 getU16(GlobalDataBuffer[id-1], 32001), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".State3",                 getU16(GlobalDataBuffer[id-1], 32002), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm1",                 getU16(GlobalDataBuffer[id-1], 32008), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm2",                 getU16(GlobalDataBuffer[id-1], 32009), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm3",                 getU16(GlobalDataBuffer[id-1], 32010), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".String.1_Voltage",       getI16(GlobalDataBuffer[id-1], 32016) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".String.1_Current",       getI16(GlobalDataBuffer[id-1], 32017) / 100 , {name: "", unit: "A"});
            //forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Voltage",     getI16(GlobalDataBuffer[id-1], 32018) / 10  , {name: "", unit: "V"});
            //forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Current",     getI16(GlobalDataBuffer[id-1], 32019) / 100 , {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".InputPower",             getI32(GlobalDataBuffer[id-1], 32064) / 1000, {name: "", unit: "kW"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage",     getU16(GlobalDataBuffer[id-1], 32066) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage",     getU16(GlobalDataBuffer[id-1], 32067) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage",     getU16(GlobalDataBuffer[id-1], 32068) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Voltage",        getU16(GlobalDataBuffer[id-1], 32069) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Voltage",        getU16(GlobalDataBuffer[id-1], 32070) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Voltage",        getU16(GlobalDataBuffer[id-1], 32071) / 10  , {name: "", unit: "V"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Current",        getI32(GlobalDataBuffer[id-1], 32072) / 1000, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Current",        getI32(GlobalDataBuffer[id-1], 32074) / 1000, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Current",        getI32(GlobalDataBuffer[id-1], 32076) / 1000, {name: "", unit: "A"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".PeakActivePowerDay",     getI32(GlobalDataBuffer[id-1], 32078) / 1000, {name: "", unit: "kW"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ActivePower",            getI32(GlobalDataBuffer[id-1], 32080) / 1000, {name: "", unit: "kW"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ReactivePower",          getI32(GlobalDataBuffer[id-1], 32082) / 1000, {name: "", unit: "kVar"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".PowerFactor",            getI16(GlobalDataBuffer[id-1], 32084) / 1000, {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".GridFrequency",          getU16(GlobalDataBuffer[id-1], 32085) / 100 , {name: "", unit: "Hz"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Efficiency",             getU16(GlobalDataBuffer[id-1], 32086) / 100 , {name: "", unit: "%"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".InternalTemperature",    getI16(GlobalDataBuffer[id-1], 32087) / 10  , {name: "", unit: "°C"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".InsulationResistance",   getU16(GlobalDataBuffer[id-1], 32088) / 1000, {name: "", unit: "MOhm"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".DeviceStatus",           getU16(GlobalDataBuffer[id-1], 32089), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".FaultCode",              getU16(GlobalDataBuffer[id-1], 32090), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".StartupTime",            getU16(GlobalDataBuffer[id-1], 32091), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ShutdownTime",           getU16(GlobalDataBuffer[id-1], 32093), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".AccumulatedEnergyYield", getU32(GlobalDataBuffer[id-1], 32106) * 10, {name: "", unit: "Wh"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".DailyEnergyYield",       getU32(GlobalDataBuffer[id-1], 32114) * 10, {name: "", unit: "Wh"});
        function ProcessDeviceInfo(id)
            // Note: Manual says its quantitiy is 15, but that is the number (+1) of 8bit characters
            forcesetState("Solarpower.Huawei.Inverter." + id + ".Model",  getZeroTerminatedString(GlobalDataBuffer[id-1], 30000, 8), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".SN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30015, 6), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".PN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30025, 6), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".ModelID",                 getU16(GlobalDataBuffer[id-1], 30070), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".PVStrings",               getU16(GlobalDataBuffer[id-1], 30071), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".MPPTrackers",             getU16(GlobalDataBuffer[id-1], 30072), {name: "", unit: ""});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxRatedPower",           getU32(GlobalDataBuffer[id-1], 30073) / 1000, {name: "", unit: "kW"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxActivePower",          getU32(GlobalDataBuffer[id-1], 30075) / 1000, {name: "", unit: "kW"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxApparentPower",        getU32(GlobalDataBuffer[id-1], 30077) / 1000, {name: "", unit: "kVA"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxReactivePowerToGrid",  getI32(GlobalDataBuffer[id-1], 30079) / 1000, {name: "", unit: "kVAr"});
            forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxReactivePowerFromGrid",getI32(GlobalDataBuffer[id-1], 30081) / 1000, {name: "", unit: "kVAr"});
        function readRegisterSpace(id, address, length)
            client.setID(ModBusIDs[id-1]);
            client.readHoldingRegisters(address, length, function(err, data)
                if (err)
                {   console.warn("Error received reading address " + address + " from id: " + ModBusIDs[id-1] + " with error: " + modbusErrorMessages[err.modbusCode]);
                else
                    //console.debug("Read data from id/address " + ModBusIDs[id-1] + "/" + address + "\nData is: " + data.data);
                    for (var i = 0; i < length; i++) GlobalDataBuffer[id-1][address+i] = data.data[i];
        function ProcessData()
            //console.debug("Processing new data...");
            for ( var i = 1; i <= ModBusIDs.length; i++)
                ProcessDeviceInfo(i);
                ProcessInverterStatus(i);
                ProcessBattery(i);
                //ProcessInverterPowerAdjustments(i);
                ProcessOptimizers(i);
            ProcessPowerMeterStatus();
            // get SOC of first battery stack and combine to one string
            var BatOverview = "";
            for(var j = 1; j <= BatteryUnits[0][0]; j++)
                if (j > 1) BatOverview += ", ";
                BatOverview += getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery" + j + ".BatterySOC").val + "%";
            setState("javascript.0.Solarpower.Derived.BatteryOverview", BatOverview);
            // determine peak panel power
            var PanelPower = getState("javascript.0.Solarpower.Huawei.Inverter.1.InputPower").val;
            var PanelMax = getState("javascript.0.Solarpower.Derived.PeakPanelPower").val;
            if (PanelPower > PanelMax) setState("javascript.0.Solarpower.Derived.PeakPanelPower", PanelPower);
            // determine power used by house
            setState("javascript.0.Solarpower.Derived.HouseConsumption", getState("javascript.0.Solarpower.Huawei.Inverter.1.ActivePower").val * 1000 -
                getState("javascript.0.Solarpower.Huawei.Meter.ActivePower").val);
            // determine yield today
            setState("javascript.0.Solarpower.Derived.YieldToday", getState("javascript.0.Solarpower.Huawei.Inverter.1.DailyEnergyYield").val +
                getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayChargeCapacity").val -
                getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayDischargeCapacity").val)
            // determine if battery is loading
            setState("javascript.0.Solarpower.Derived.IsBatteryLoading", getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.ChargeAndDischargePower").val > 0 ? 0 : 1);
            // determine if power is imported or exported
            setState("javascript.0.Solarpower.Derived.IsGridExporting", getState("javascript.0.Solarpower.Huawei.Meter.ActivePower").val > 0 ? 1 : 0);
            // compute export and import today
            setState("javascript.0.Solarpower.Derived.GridExportToday", getState("javascript.0.Solarpower.Huawei.Meter.PositiveActiveEnergy").val - getState("javascript.0.Solarpower.Derived.GridExportSum").val);
            setState("javascript.0.Solarpower.Derived.GridImportToday", getState("javascript.0.Solarpower.Huawei.Meter.ReverseActiveEnergy").val - getState("javascript.0.Solarpower.Derived.GridImportSum").val);
            // compute consumption today
            setState("javascript.0.Solarpower.Derived.ConsumptionSum",
                getState("javascript.0.Solarpower.Huawei.Inverter.1.AccumulatedEnergyYield").val +
                getState("javascript.0.Solarpower.Huawei.Meter.PositiveActiveEnergy").val);
            setState("javascript.0.Solarpower.Derived.ConsumptionToday",
                getState("javascript.0.Solarpower.Derived.ConsumptionSum").val -
                getState("javascript.0.Solarpower.Derived.ConsumptionStart").val);
            testCreateState = 1;                // do not check on createState any more
        setInterval(function()
        // This is the main function triggering a  read via modbus-tcp every 5000 ms (see end of SetInterval)
        // Processing of data is triggered as soon as one complete set of registers is copied
        // with 5 seconds, new values are displyed every 50 seconds
            //console.debug("Triggering read of inverter " + currentinverter + " at address " + RegToRead[RegToReadPtr][0] + " with length " +  RegToRead[RegToReadPtr][1]);
            readRegisterSpace(currentinverter, RegToRead[RegToReadPtr][0], RegToRead[RegToReadPtr][1]);
            // determine if all or only fast registers should be read
            var CurLength = RegFast;
            if ((RegReadCnt % RegFastMod) == 0) CurLength = RegToRead.length
            RegToReadPtr++;
            if (RegToReadPtr >= CurLength)
                RegToReadPtr = 0;
                // go through all inverters, if there are several
                currentinverter++
                if (currentinverter > ModBusIDs.length)
                    ProcessData();
                    //if (CurLength == RegFast) log("Processing done (FAST)!", "info"); else log("Processing done (SLOW)!", "info");
                    RegReadCnt++;
        }, 5000);
        // one minute before midnight - perform housekeeping actions
        schedule("59 23 * * *", function ()
            // reset peak power for next day
            setState("javascript.0.Solarpower.Derived.PeakPanelPower", 0);
            // copy current export/import kWh - used to compute daily import/export in kWh
            setState("javascript.0.Solarpower.Derived.GridExportSum", getState("javascript.0.Solarpower.Huawei.Meter.PositiveActiveEnergy").val);
            setState("javascript.0.Solarpower.Derived.GridImportSum", getState("javascript.0.Solarpower.Huawei.Meter.ReverseActiveEnergy").val);
            // copy consumption Sum to Start for the next day
            setState("javascript.0.Solarpower.Derived.ConsumptionStart", getState("javascript.0.Solarpower.Derived.ConsumptionSum").val);
            // log important iformation to file
            SolarPowerLogging();
        function SolarPowerLogging()
        // write values of today in file
            // get
            var log1 = getState("javascript.0.Solarpower.Derived.YieldToday").val;
            var log2 = getState("javascript.0.Solarpower.Derived.GridExportToday").val;
            var log3 = getState("javascript.0.Solarpower.Derived.GridImportToday").val;
            var log4 = getState("javascript.0.Solarpower.Derived.ConsumptionToday").val;
            // Zerlege Datum und Zeit in Variable
            var now =    new Date();
            var year =   now.getFullYear();
            var month =  addZero(now.getMonth() + 1);
            var day =    addZero(now.getDate());
            var currDate = day + '.' + month + '.' + year;
            var string = " ";
            // create string that is appended to the file
            string = currDate + ";" + log1.toFixed(3) + ";" + log2.toFixed(3) + ";" + log3.toFixed(3) + ";" + log4.toFixed(3) + "\n";
            fs.appendFileSync("/opt/iobroker/iobroker-data/SolarpowerLog.csv", string);
            // erzeuge Log-Eintrag
            log("Solerpower log:" + string, "info");
        function addZero(Num)
        // if number <10 add zero values at the beginning of numbers
            if (Num < 10) Num = "0" + Num;
            return Num;
        Wenn ich nun folgende, für mich unwichtige Teile, entferne
            // get
            var string = " ";
            return Num;
                ProcessBattery(i);
        Arbeitet das Skript nicht mehr. Ich bekomme aber kein Protokoll und auch keine Daten in den Objekten. Aber was genau fehlt mir, damit ich nun die Daten bekomme?
        Viele Grüße
        Martin
          leonundjulie @R4 last edited by leonundjulie
          @r4 said in Huawei Sun2000 & ioBroker via JS script funktioniert:
          @leonundjulie
          Was soll ich sagen - es läuft. Warum? Zunächst habe ich mir die aktuellen Software Paketen für den WR und den Dongle aus dem Netz gezogen.
          WR: alles aktuell 😀
          sDongle: um sich einloggen zu können -> SDongle heraus, nach 2 Minuten wieder rein, eingeloggt …. Software ist aktuell🤔
          Zurück zum IOBROKER, Skript gestartet …. 😀😀😀😀, alle 5 Sekunden kommen Werte.
          Jetzt hoffe ich nur, dass das auch so anhält.
          Dank gebührt allen, die geholfen haben - Merci. Natürlich bleibe ich dabei, warte aufs nächste Update des Skriptes und teste gerne weiter mit
          Nachtrag vom heutigen Sonntag: da ich erst heute Zeit finde, kann ich erst jetzt als Nachbrenner einbringen, das ich oben vergessen habe zu erwähnen, dass ich in meinem EnPAL-Konstrukt während des ganzen Testens die LAN-Verbindung zwischen dem Huawei S2000 und der EnPAL Box herausgezogen hatte. Kaum war der LAN-Stecker wieder in der Buchse, hat das Skript keine Werte mehr ausgeworfen. Dies führt zur Annahme, dass der SDongle - wenn WLAN und LAN gleichzeitig eingesteckt sind - (oder vielleicht der Wechselrichter selber) einer LAN-Verbindung Priorität gibt bzw. WLAN keine weiteren Zugriffe erlaubt.
          Auch der in anderen Foren beschriebene Zugriff via WLAN funktioniert via dem WLAN des WR (Netz mit geringer Reichweite und nicht via WLAN des Dongles), wenn die LAN-Schnittstelle des SDongles verwendet wird.
          Also werde ich jetzt mal versuchen meinen PI an das LAN der EnPAL-Box anzuschließen, ein Port ist noch frei :-), und mich wieder melden wenn ich das IP-Routing im Griff habe. Gemäß meiner obigen These müsste dann endlich gehen.
            R4 @hussi last edited by R4
            @hussi
            Du entfernst Funktionen wie SolarPowerLogging() und vor allem ProcessData() und wunderst dich, dass es kein Loggingprotokoll mehr gibt und die SW nicht mehr tut?
            Bitte lass das Zeug drin, wenn du nicht weißt, was es tut.
            So viel CPU Zeit benötigt das jetzt auch nicht...
            (ok,
            schedule("59 23 * * *", function () {...}
            kannst du rauslöschen, wenn du keine Logdatei willst.)
              hussi @R4 last edited by
              @r4 Nee ich wundere mich nicht. Ich weiß ja nicht was ich tue. Brauche aber die Berechnungen nicht und habe daher gedacht ich kann sie so rausnehmen.
              Frei nach dem Gedanken: Je schmaler, je besser.
                Chris_B @hussi last edited by
                @hussi Ich würde echt nicht raten, solche Dinge rauszunehmen. Nicht weil es (teilweise) Dinge sind, die ichgeschrieben habe, aber einfach Dinge löschen bringt wenig, auch wenn Du gewisses nicht brauchst. Diese Berechnungen brauchen ja keine relevante Rechenleistung und dadurch wird das Skript nicht wirklich 'besser', in einer Form, die Du bemerken würdest... Gruss
                L H 2 Replies Last reply Reply Quote 0
                  leonundjulie @Chris_B last edited by leonundjulie
                  @chris_b und @R. Guten Morgen Euch Beiden. Ich habe eine Verständnisfrage zum Konzept des Skripte. Die Frage kam auf im Rahmen der Analyse der bei mir Installierten EnPAL-Topologie und der Tatsache, dass man ganz am Anfang des Skriptes die ID des SmartMeters angibt, die dann beim Ablauf des Skriptes, also beim Abfragen der verschiedenen Werte, bei der Abfrage des SmartMeters verwendet wird.
                  Warum wird die Abfrage an das SmartMeter und nicht an den WR gerichtet? Die verwendeten Register-Adressen gehören doch zum Wechselrichter und nicht zum SmartMeter 🤷‍♂️
                  R C 2 Replies Last reply Reply Quote 0
                    hussi @Chris_B last edited by hussi
                    @chris_b Hab ich verstanden. Dann lasse ich alles so. Wie gesagt: Dachte je schmaler, je besser.
                    Danke für Deine Tolle Arbeit!
                    Edit:
                    Wenn ich nur eine Batterie habe, mache ich das dann so:
                      @leonundjulie sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
                      Auch hier: ?
                      Das Script liest nur die ModBus-Daten des WR ein.
                      Der WR selbst stellt die Smartmeter-Daten bereit (liest die von dort selbst ein).
                      Und mit
                      stellst du auch nicht die ID des PowerMeters ein (der hat gar keine), sondern
                      hier also wird der erste Eintrag im Array
                      verwendet, was die Modbus-ID des WR ist, an dem der PowerMeter angeschlossen ist.
                        Auch hier: ?
                        Und mit
                        Ja, auch hier … da die Node-Red-Variante bei mir nicht laufen will - aber jetzt kann ich es ja vielleicht erklären (s.o.).
                        Danke für die Antwort. Auch den Anteil habe ich jetzt verstanden. Und ich dachte schon die Antwort dafür zu haben, warum in der Zeit - als ich die LAN-Strecke zwischen SUN2000 und EnPAL-Box unterbrochen hatte - im SUN2000 keine Meter-Werte mehr auftauchten. Irgendein Geheimnis steckten in dieser EnPAL-Topologie immer noch 😉
                          Chris_B @leonundjulie last edited by
                          @leonundjulie Der Antwort von @R4 habe ich nichts hinzuzufügen - genau so ist es 🙂 Ich würde auch das im Skript nicht verändern, deckt den Fall von 2 WR ab. Ich weiss nicht, wie häufig das ist, aber es ist allgemeiner...
                            @chris_b said in Huawei Sun2000 & ioBroker via JS script funktioniert:
                            Hallo zusammen.
                            Ich habe heute meinen PI mal direkt ins EnPAL-Netzwerk gehängt und folgende IP zugeteilt bekommen.
                            31b2a593-94ef-4915-975b-cd500191de29-image.jpeg.
                            Über den EnPAL Switch komme ich dann auf die IP …..159 des WR.
                            Ich habe das Skript in der Version 3 verwendet und nur die IP und die Batterie [0,0] eingestellt.
                            Das Ergebnis ist wie beim Zugriff via WLAN: ich bekomme Werte für einen Zyklus und dann bleiben die Werte unverändert 😞
                            Ich werde Morgen WLAN im SDongle deaktivieren und dann direkt auf die LAN-Schnittstelle des SDongles gehen …. zumindest dann muss es ja wie bei Euch laufen.
                              juggi1962 last edited by juggi1962
                              Hallo @R4 und @Chris-B
                              Kann mir von euch Beiden jemand erklären wie ich auf diese beiden Register
                                  forcesetState(SHI + id + ".BatteryRW.MaximumChargingPower",                 getU32(Buffer[id-1], 47075), {name: "", unit: "W"});
                                  forcesetState(SHI + id + ".BatteryRW.MaximumDischargingPower",              getU32(Buffer[id-1], 47077), {name: "", unit: "W"});
                              Schreiben kann damit ich die 5000 W Original Einstellungen ändern kann.
                              Ich möchte gern, wenn ich meine Wallbox auf Überschussladen habe die beiden Parameter auf 0 stellen, damit der PV Speicher nichts mehr liefern und laden kann. Ich hab das ganze per Blockly versucht auf die Datenpunkte die ich mit dem Skript auslese zu schreiben, aber es ändert sich nichts.
                              Ich hoffe das war halbwegs verständlich.
                              Danke im Voraus, Gruß Jürgen
                              Atifan R 2 Replies Last reply Reply Quote 0
                              • Atifan
                                Atifan @juggi1962 last edited by
                                Hi Leute, gibt ja die Möglichkeit den Wechselrichter über das Script hier aus dem Thread auszulesen oder über NodeRed. Was ist besser? Gibts Unterschiede?
                                  R4 @juggi1962 last edited by R4
                                  @juggi1962 sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
                                  47075
                                  Das Schreiben ins Register 47075 hab ich weiter zurück schon mal beschrieben.
                                  (Hinweis:
                                  Der Akku lädt trotz Eintrag "0" im Register 47075 mit ~200W.
                                  Huawei schreibt mir dazu:
                                  [Problem Description] :While MaximumChargingPower is 0 BusCurrent (ModBus register 37021) is not 0 and, considering BusVoltage, it seems there are always about 200W on the way to the battery?
                                  [Problem Analysis]:
                                  The battery charge and discharge sampling has fixed errors, so it cannot be controlled to 0 W without charging or charging.
                                  If the customer does not want to charge the battery, set the battery charge-off SOC and current SOC to the same value.
                                  For example, if the battery SOC reaches 16% and does not want to be charged, set the charging end SOC to 16%.
                                  In this way, the SOC of the battery is maintained to 16%.
                                  [Root Cause]: The battery charge and discharge sampling has fixed errors.
                                  [Solution]:
                                    leonundjulie @leonundjulie last edited by leonundjulie
                                    @leonundjulie said in Huawei Sun2000 & ioBroker via JS script funktioniert:
                                    Hallo zusammen.
                                    Wie gestern angekündigt, habe ich den WR SUN2000 jetzt direkt mit meiner FB verbunden (dafür also die LAN-Strecke zur EnPAL-Box getrennt 😉 ). Das Ergebnis:
                                    • die EnPAL-Box funktioniert, in der EnPAL-App werden weiterhin korrekte Werte angezeigt (die Kiste ist ja selber im FB-Netzwerk und holt sich Ihre Werte dann wohl über die WLAN-Strecke zur SUN2000 ... -> das EnPAL-Thema kläre ich an anderer Stelle, hier geht es ja um das Skript 😉 )
                                    • das Skrift läuft 🙂 🙂
                                    • Fazit: alle zuvor beschribenen Probleme ergeben sich auf Grund der von EnPAL gewollten Netzwerk-Topologie
                                    Eine Thematik bleibt dennoch offen - weil ich keine Batterien habe, bekomme ich viele (überflüssige) Meldungen.
                                    Dieses Muster wiederholt sich stätig. Was muss in dem Skript (siehe Anlage) noch auskommentiert werden? V3_was_muss_raus.txt
                                    In dem Zusammenhang: wird es kurzfristig eine Version 4 des Skriptes geben? Oder muss ich mich gedulden und auf den Adapter warten?
                                    bahnuhr C 2 Replies Last reply Reply Quote 0
                                    • bahnuhr
                                      bahnuhr Forum Testing Most Active @leonundjulie last edited by
                                      @leonundjulie
                                      Der Link
                                      klappt nicht.
                                        leonundjulie @bahnuhr last edited by
                                        @bahnuhr said in Huawei Sun2000 & ioBroker via JS script funktioniert:
                                        @leonundjulie
                                        Der Link
                                        klappt nicht.
                                        Auf ein Neues: V3_was_muss_raus.txt
                                          juggi1962 @R4 last edited by
                                          @r4 Danke für deine Antwort und Mitteilung von Huawei.
                                          Leider kenn ich mich mit JS überhaupt nicht aus, anders sieht es mit Blockly aus, aber wenn ich dort auf die Datenpunkte von 47075 und 47077 schreibe sieht man dass es sich ändert, aber zurück kommt dann immer wieder was schon da stand. Leider kann ich mich nicht besser ausdrücken.
                                          Geht das überhaupt so, wie gesagt ich kann das nur so halbwegs mit Blockly.
                                          Vielleicht kannst mir da ja weiterhelfen. Ich verstehe das was du weiter oben beschrieben hast nicht wirklich.
                                            @juggi1962
                                            Du verwendest das Script und mit den dort erzeugten Datenpunkten versorgst du dann Blockly? (Hab mich noch nie damit beschäftigt, habe deshalb keine Ahnung davon...)
                                            Dann geht das mit dem Schreiben nicht. Du könntest in ioBroker unter "Objekte" die Datenpunkte auch direkt ändern, selbst das würde nichts bewirken. Das Script liest nur Daten aus und hat keinen "Rückkanal". Dazu müsstest du Änderungen im Script selbst vornehmen.
                                            477
                                            90900
