    4. ioBroker funktioniert nicht mehr
      Thomas Braun Most Active @rsw2004 last edited by
      @rsw2004 sagte in ioBroker funktioniert nicht mehr:
      Hat jemand eine Idee?
      iob diag
      sagt? Und bitte keine Bildchen aus Konsolistan, kann keiner was gescheites mit anfangen.
        rsw2004 @Thomas Braun last edited by
                             v.2023-04-16
        Operatingsystem:        Debian GNU/Linux 11 (bullseye)
        Kernel:                 6.1.21-v8+
        Installation:           Native
        Timezone:               Europe/Berlin (CEST, +0200)User-ID:                1000
        X-Server:               false
        Boot Target:            multi-user.target
        Pending OS-Updates:     20
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                                /usr/bin/node           v18.16.1
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            3.8G        232M        3.1G        1.0M        507M        3.5G
        Swap:            99M          0B         99M
        Total:          3.9G        232M        3.2G
        Active iob-Instances:   1
        Active repo(s): stable
        ioBroker Core:          js-controller           4.0.24
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                118
        States:                 79
        Size of iob-Database:
        7.7M    /opt/iobroker/iobroker-data/objects.jsonl
        5.2M    /opt/iobroker/iobroker-data/states.jsonl
          Aktuell halten.
          Und gib bitte die Langfassung bekannt.
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Model           : Raspberry Pi 4 Model B Rev 1.4
            Architecture    : aarch64
            Docker          : false
            Virtualization  : none
            Distributor ID: Debian
            Description:    Debian GNU/Linux 11 (bullseye)
            Release:        11
            Codename:       bullseye
            PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
            NAME="Debian GNU/Linux"
            VERSION_ID="11"
            VERSION="11 (bullseye)"
            VERSION_CODENAME=bullseye
            ID=debian
            HOME_URL="https://www.debian.org/"
            SUPPORT_URL="https://www.debian.org/support"
            BUG_REPORT_URL="https://bugs.debian.org/"
            Systemuptime and Load:
             20:05:33 up  2:13,  0 users,  load average: 0.00, 0.03, 0.04
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            Other values than 0x0 hint to temperature/voltage problems
            temp=52.5'C
            volt=0.9160V
            *** Time and Time Zones ***
                           Local time: Tue 2023-08-08 20:05:33 CEST
                       Universal time: Tue 2023-08-08 18:05:33 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            robin
            /home/robin
            robin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            3.8G        230M        3.1G        1.0M        509M        3.5G
            Swap:            99M          0B         99M
            Total:          3.9G        230M        3.2G
                     3794 M total memory
                      230 M used memory
                      296 M active memory
                      334 M inactive memory
                     3054 M free memory
                       45 M buffer memory
                      463 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /dev/root      ext4       15G  3.2G   11G  24% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /devtmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     759M  1.1M  758M   1% /runtmpfs          tmpfs     5.0M  4.0K  5.0M   1% /run/lock
            /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
            tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
            [Tue Aug  8 17:52:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Tue Aug  8 17:52:03 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Tue Aug  8 17:52:03 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Tue Aug  8 17:52:05 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            Show mounted filesystems (real ones only):
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600`-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            541M    /var/
            180M    /var/cache
            174M    /var/cache/apt
            147M    /var/lib
            123M    /var/lib/apt/lists
            Archived and active journals take up 112.0M in the file system.
            /opt/iobroker/backups:
            11M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            167M    /opt/iobroker/iobroker-data/
            122M    /opt/iobroker/iobroker-data/files
            52M     /opt/iobroker/iobroker-data/files/javascript.admin
            34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
            33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
            8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
            6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            sort: write failed: 'standard output': Broken pipe
            sort: write error
            *** NodeJS-Installation ***
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Installed: 18.16.1-deb-1nodesource1
              Candidate: 18.17.0-deb-1nodesource1
              Version table:
                 18.17.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
             *** 18.16.1-deb-1nodesource1 100
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                 12.22.12~dfsg-1~deb11u3 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
            No problems detected
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            MULTIHOSTSERVICE/enabled: false
            Core adapters versions
            js-controller:  4.0.24
            admin:          6.3.5
            javascript:     7.0.3
            Adapters from github:   0
            Adapter State
            + instance is alive
            ioBroker-Repositories
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.3.5    , installed 6.3.5
            Adapter    "backitup"     : 2.6.23   , installed 2.6.23
            Adapter    "bluelink"     : 2.3.2    , installed 2.3.2
            Adapter    "geofency"     : 1.2.4    , installed 1.2.4
            Adapter    "info"         : 1.9.26   , installed 1.9.26
            Adapter    "iot"          : 1.14.5   , installed 1.14.5
            Adapter    "javascript"   : 7.0.3    , installed 7.0.3
            Controller "js-controller": 4.0.24   , installed 4.0.24
            Adapter    "openknx"      : 0.5.3    , installed 0.5.3
            Adapter    "solax"        : 0.7.5    , installed 0.7.5
            Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
            Adapter    "synology"     : 2.1.13   , installed 2.1.13
            Adapter    "yahka"        : 0.17.0   , installed 0.17.0
            Objects and States
            Objects:        118
            States:         79
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
            Reading package lists...
            Pending Updates: 20
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12735      494/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1477       494/iobroker.js-con
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13683      534/sshd: /usr/sbin
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13685      534/sshd: /usr/sbin
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1490       651/dhcpcd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1442       391/avahi-daemon: r
            udp        0      0 0.0.0.0:42577           0.0.0.0:*                           108        1444       391/avahi-daemon: r
            udp6       0      0 :::45999                :::*                                108        1445       391/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        1443       391/avahi-daemon: r
            2023-08-08 17:39:02.271  - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.nodeNewestNext"
            2023-08-08 17:39:02.282  - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmCurrent"
            2023-08-08 17:39:02.299  - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmNewest"
            2023-08-08 17:39:02.311  - info: host.raspberrypi4 Delete state "system.host.raspberrypi4.versions.npmNewestNext"
            2023-08-08 17:39:02.321  - info: host.raspberrypi4 Some obsolete host states deleted.
            2023-08-08 17:39:23.178  - info: host.raspberrypi4 received SIGTERM
            2023-08-08 17:39:23.255  - info: host.raspberrypi4 terminated
            2023-08-08 17:40:02.223  - info: host.raspberrypi4 iobroker.js-controller version 4.0.24 js-controller starting
            2023-08-08 17:40:02.230  - info: host.raspberrypi4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2023-08-08 17:40:02.231  - info: host.raspberrypi4 hostname: raspberrypi4, node: v18.16.1
            2023-08-08 17:40:02.231  - info: host.raspberrypi4 ip addresses: 192.168.178.55 fd20:384a:b205:4332:15e1:cf9a:3fe7:8394 fe80::54cc:fb68:5387:7415
            2023-08-08 17:40:03.091  - info: host.raspberrypi4 connected to Objects and States
            2023-08-08 17:40:03.117  - info: host.raspberrypi4 added notifications configuration of host
            2023-08-08 17:40:03.530  - info: host.raspberrypi4  no instances found
            2023-08-08 17:51:52.065  - info: host.raspberrypi4 received SIGTERM
            2023-08-08 17:51:52.143  - info: host.raspberrypi4 terminated
            2023-08-08 17:52:00.983  - info: host.raspberrypi4 iobroker.js-controller version 4.0.24 js-controller starting
            2023-08-08 17:52:00.989  - info: host.raspberrypi4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2023-08-08 17:52:00.991  - info: host.raspberrypi4 hostname: raspberrypi4, node: v18.16.1
            2023-08-08 17:52:00.991  - info: host.raspberrypi4 ip addresses:
            2023-08-08 17:52:01.984  - info: host.raspberrypi4 connected to Objects and States
            2023-08-08 17:52:02.018  - info: host.raspberrypi4 added notifications configuration of host
            2023-08-08 17:52:02.665  - info: host.raspberrypi4  no instances found
            2023-08-08 17:52:02.666  - info: host.raspberrypi4 no instances found
              @rsw2004
              iob stop
              sudo apt update
              sudo apt full-upgrade
              sudo reboot
              Vor dem reboot bitte die Ausgaben von apt posten.
                Reading package lists... Done
                Building dependency tree... Done
                Calculating upgrade... Done
                The following packages will be upgraded:
                  firmware-atheros firmware-brcm80211
                  firmware-libertas firmware-misc-nonfree
                  firmware-realtek libcamera-apps-lite libcamera0
                  libpam-systemd libssl1.1 libsystemd0
                  libudev-dev libudev1 nodejs openssl
                  python3-libcamera python3-picamera2 systemd
                  systemd-sysv systemd-timesyncd udev
                20 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                Need to get 107 MB of archives.
                After this operation, 5,668 kB of additional disk space will be used.
                Do you want to continue? [Y/n] y
                Get:1 http://deb.debian.org/debian bullseye-updates/main arm64 libudev-dev arm64 247.3-7+deb11u4 [124 kB]
                Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 libssl1.1 arm64 1.1.1n-0+deb11u5+rpt1 [1,393 kB]
                Get:3 http://deb.debian.org/debian bullseye-updates/main arm64 libsystemd0 arm64 247.3-7+deb11u4 [355 kB]
                Get:4 https://deb.nodesource.com/node_18.x bullseye/main arm64 nodejs arm64 18.17.0-deb-1nodesource1 [28.1 MB]
                Get:5 http://archive.raspberrypi.org/debian bullseye/main arm64 firmware-atheros all 1:20230210-5~bpo11+1+rpt1 [16.8 MB]
                Get:6 http://deb.debian.org/debian bullseye-updates/main arm64 systemd-timesyncd arm64 247.3-7+deb11u4 [130 kB]
                Get:7 http://deb.debian.org/debian bullseye-updates/main arm64 libpam-systemd arm64 247.3-7+deb11u4 [275 kB]
                Get:8 http://deb.debian.org/debian bullseye-updates/main arm64 systemd arm64 247.3-7+deb11u4 [4,155 kB]
                Get:9 http://deb.debian.org/debian bullseye-updates/main arm64 udev arm64 247.3-7+deb11u4 [1,423 kB]
                Get:10 http://deb.debian.org/debian bullseye-updates/main arm64 libudev1 arm64 247.3-7+deb11u4 [163 kB]
                Get:11 http://deb.debian.org/debian bullseye-updates/main arm64 systemd-sysv arm64 247.3-7+deb11u4 [114 kB]
                Get:12 http://archive.raspberrypi.org/debian bullseye/main arm64 firmware-brcm80211 all 1:20230210-5~bpo11+1+rpt1 [5,868 kB]
                Get:13 http://archive.raspberrypi.org/debian bullseye/main arm64 firmware-libertas all 1:20230210-5~bpo11+1+rpt1 [31.2 MB]
                Get:14 http://archive.raspberrypi.org/debian bullseye/main arm64 firmware-misc-nonfree all 1:20230210-5~bpo11+1+rpt1 [13.0 MB]
                Get:15 http://archive.raspberrypi.org/debian bullseye/main arm64 firmware-realtek all 1:20230210-5~bpo11+1+rpt1 [1,511 kB]
                Get:16 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera0 arm64 0~git20230720+bde9b04f-1 [826 kB]
                Get:17 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera-apps-lite arm64 1.2.1-1 [281 kB]
                Get:18 http://archive.raspberrypi.org/debian bullseye/main arm64 openssl arm64 1.1.1n-0+deb11u5+rpt1 [832 kB]
                Get:19 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-libcamera arm64 0~git20230720+bde9b04f-1 [190 kB]
                Get:20 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-picamera2 all 0.3.12-2 [50.4 kB]
                Fetched 107 MB in 10s (10.5 MB/s)
                Reading changelogs... Done
                Preconfiguring packages ...
                (Reading database ... 50437 files and directories currently installed.)
                Preparing to unpack .../libudev-dev_247.3-7+deb11u4_arm64.deb ...
                Unpacking libudev-dev:arm64 (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
                Preparing to unpack .../libsystemd0_247.3-7+deb11u4_arm64.deb ...
                Unpacking libsystemd0:arm64 (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
                Setting up libsystemd0:arm64 (247.3-7+deb11u4) ...
                Preparing to unpack .../systemd-timesyncd_247.3-7+deb11u4_arm64.deb ...
                Unpacking systemd-timesyncd (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
                Preparing to unpack .../libpam-systemd_247.3-7+deb11u4_arm64.deb ...
                Unpacking libpam-systemd:arm64 (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
                Preparing to unpack .../systemd_247.3-7+deb11u4_arm64.deb ...
                Unpacking systemd (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
                Preparing to unpack .../udev_247.3-7+deb11u4_arm64.deb ...
                Unpacking udev (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
                Preparing to unpack .../libudev1_247.3-7+deb11u4_arm64.deb ...
                Unpacking libudev1:arm64 (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
                Setting up libudev1:arm64 (247.3-7+deb11u4) ...
                Setting up systemd (247.3-7+deb11u4) ...
                Preparing to unpack .../systemd-sysv_247.3-7+deb11u4_arm64.deb ...
                Unpacking systemd-sysv (247.3-7+deb11u4) over (247.3-7+deb11u2) ...
                Preparing to unpack .../libssl1.1_1.1.1n-0+deb11u5+rpt1_arm64.deb ...
                Unpacking libssl1.1:arm64 (1.1.1n-0+deb11u5+rpt1) over (1.1.1n-0+deb11u5) ...
                Setting up libssl1.1:arm64 (1.1.1n-0+deb11u5+rpt1) ...
                Preparing to unpack .../00-firmware-atheros_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
                Unpacking firmware-atheros (1:20230210-5~bpo11+1+rpt1) over (1:20221012-1~bpo11+1+rpt1) ...
                Preparing to unpack .../01-firmware-brcm80211_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
                Unpacking firmware-brcm80211 (1:20230210-5~bpo11+1+rpt1) over (1:20221012-1~bpo11+1+rpt1) ...
                Preparing to unpack .../02-firmware-libertas_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
                Unpacking firmware-libertas (1:20230210-5~bpo11+1+rpt1) over (1:20221012-1~bpo11+1+rpt1) ...
                Preparing to unpack .../03-firmware-misc-nonfree_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
                Unpacking firmware-misc-nonfree (1:20230210-5~bpo11+1+rpt1) over (1:20221012-1~bpo11+1+rpt1) ...
                Preparing to unpack .../04-firmware-realtek_1%3a20230210-5~bpo11+1+rpt1_all.deb ...
                Unpacking firmware-realtek (1:20230210-5~bpo11+1+rpt1) over (1:20221012-1~bpo11+1+rpt1) ...
                Preparing to unpack .../05-libcamera0_0~git20230720+bde9b04f-1_arm64.deb ...
                Unpacking libcamera0:arm64 (0~git20230720+bde9b04f-1) over (0~git20230302+923f5d70-1) ...
                Preparing to unpack .../06-libcamera-apps-lite_1.2.1-1_arm64.deb ...
                Unpacking libcamera-apps-lite (1.2.1-1) over (0~git20230301+54a781d-1) ...
                Preparing to unpack .../07-nodejs_18.17.0-deb-1nodesource1_arm64.deb ...
                Unpacking nodejs (18.17.0-deb-1nodesource1) over (18.16.1-deb-1nodesource1) ...
                Preparing to unpack .../08-openssl_1.1.1n-0+deb11u5+rpt1_arm64.deb ...
                Unpacking openssl (1.1.1n-0+deb11u5+rpt1) over (1.1.1n-0+deb11u5) ...
                Preparing to unpack .../09-python3-libcamera_0~git20230720+bde9b04f-1_arm64.deb ...
                Unpacking python3-libcamera (0~git20230720+bde9b04f-1) over (0~git20230302+923f5d70-1) ...
                Preparing to unpack .../10-python3-picamera2_0.3.12-2_all.deb ...
                Unpacking python3-picamera2 (0.3.12-2) over (0.3.9-1) ...
                Setting up systemd-sysv (247.3-7+deb11u4) ...
                Setting up firmware-atheros (1:20230210-5~bpo11+1+rpt1) ...
                Setting up firmware-misc-nonfree (1:20230210-5~bpo11+1+rpt1) ...
                Setting up nodejs (18.17.0-deb-1nodesource1) ...
                Setting up firmware-brcm80211 (1:20230210-5~bpo11+1+rpt1) ...
                Setting up firmware-realtek (1:20230210-5~bpo11+1+rpt1) ...
                Setting up systemd-timesyncd (247.3-7+deb11u4) ...
                Setting up udev (247.3-7+deb11u4) ...
                Setting up libudev-dev:arm64 (247.3-7+deb11u4) ...
                Setting up firmware-libertas (1:20230210-5~bpo11+1+rpt1) ...
                Setting up libpam-systemd:arm64 (247.3-7+deb11u4) ...
                Setting up libcamera0:arm64 (0~git20230720+bde9b04f-1) ...
                Setting up openssl (1.1.1n-0+deb11u5+rpt1) ...
                Setting up python3-libcamera (0~git20230720+bde9b04f-1) ...
                Setting up libcamera-apps-lite (1.2.1-1) ...
                Setting up python3-picamera2 (0.3.12-2) ...
                Processing triggers for initramfs-tools (0.140) ...Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
                Processing triggers for man-db (2.9.4-2) ...
                Processing triggers for dbus (1.12.24-0+deb11u1) ...
                  @rsw2004
                  Das ist nicht alles.
                  Oder es fehlt der Login Prompt, woran man das erkennen könnte.
                    Der code ist natürlich nach dem reboot weg. Dachte es wäre alles…
                    Hier nochmal ein neuer iob diag, falls das hilft
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        11
                    Codename:       bullseye
                    VERSION_ID="11"
                    ID=debian
                     20:49:52 up 1 min,  0 users,  load average: 0.47, 0.35, 0.14
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    temp=52.1'C
                    volt=0.9160V
                                   Local time: Tue 2023-08-08 20:49:52 CEST
                               Universal time: Tue 2023-08-08 18:49:52 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    robin
                    /home/robin
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            3.8G        178M        3.4G        1.0M        190M        3.5G
                    Swap:            99M          0B         99M
                    Total:          3.9G        178M        3.5G
                             3794 M total memory
                              178 M used memory
                              231 M active memory
                               57 M inactive memory
                             3424 M free memory
                               19 M buffer memory
                              171 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /dev/root      ext4       15G  3.3G   11G  24% /
                    [Tue Aug  8 20:48:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Tue Aug  8 20:48:05 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Tue Aug  8 20:48:05 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Tue Aug  8 20:48:07 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    /var:
                    550M    /var/
                    180M    /var/cache
                    174M    /var/cache/apt
                    147M    /var/lib
                    Archived and active journals take up 120.0M in the file system.
                    sort: write error
                    /usr/bin/nodejs         v18.17.0
                    /usr/bin/node           v18.17.0
                    /usr/bin/npm            9.6.7
                    /usr/bin/npx            9.6.7
                    nodejs:
                      Installed: 18.17.0-deb-1nodesource1
                      Version table:
                     *** 18.17.0-deb-1nodesource1 500
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.3.5
                    javascript:     7.0.3
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        118
                    States:         79
                    Pending Updates: 0
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11853      467/iobroker.js-con
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14162      467/iobroker.js-con
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12899      522/sshd: /usr/sbin
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          12901      522/sshd: /usr/sbin
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12940      664/dhcpcd
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12739      353/avahi-daemon: r
                    udp        0      0 0.0.0.0:58693           0.0.0.0:*                           108        12741      353/avahi-daemon: r
                    udp6       0      0 :::53751                :::*                                108        12742      353/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                108        12740      353/avahi-daemon: r
                    2023-08-08 20:32:59.069  - info: host.raspberrypi4 received SIGTERM
                    2023-08-08 20:32:59.115  - info: host.raspberrypi4 terminated
                    2023-08-08 20:48:02.032  - info: host.raspberrypi4 iobroker.js-controller version 4.0.24 js-controller starting
                    2023-08-08 20:48:02.040  - info: host.raspberrypi4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2023-08-08 20:48:02.042  - info: host.raspberrypi4 hostname: raspberrypi4, node: v18.17.0
                    2023-08-08 20:48:02.043  - info: host.raspberrypi4 ip addresses:
                    2023-08-08 20:48:03.279  - info: host.raspberrypi4 connected to Objects and States
                    2023-08-08 20:48:03.312  - info: host.raspberrypi4 added notifications configuration of host
                    2023-08-08 20:48:03.324  - info: host.raspberrypi4 Node.js version has changed from 18.16.1 to 18.17.02023-08-08 20:48:03.969  - info: host.raspberrypi4 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node2023-08-08 20:48:04.004  - info: host.raspberrypi4  no instances found
                    2023-08-08 20:48:04.005  - info: host.raspberrypi4 no instances found
                      Der irritiert mich. Das sollte nicht passieren.
                      iob start admin
                      iob start web
                        robin@raspberrypi4:/ $ iob start admin
                        Cannot find any instances of "admin"!
                        robin@raspberrypi4:/ $ iob start web
                        Cannot find any instances of "web"!
                        Muss ich vorher das Verzeichnis wechseln?
                        cd /opt/iobroker
                          Nein. Aber dann add mal.
                          iob add admin
                          iob add web
                          iob restart admin
                          iob restart web
                            Das hat jetzt zumindest mal insofern funktioniert, dass ich wieder auf die Weboberfläche komme.
                            Und obwohl laut Diag alle Instanzen vorhanden sein sollten, werden mir nur die gerade hinzugefügten web und und admin Instanzen angezeigt.
                            Der Rest ist einfach weg.
                            Bei Objekten sind auch noch entsprechende Überreste vorhanden, also leere Ordner Namen der Instanzen.
                            Wie kann sich ioBroker denn so vergessen?
                            R Thomas Braun 2 Replies Last reply Reply Quote 0
                              rsw2004 @rsw2004 last edited by
                              @Thomas-Braun
                              ioBroker Backup habe ich geladen. Hat auch soweit erstmal ohne Probleme geklappt.
                              Allerdings zeigts mir im Protokoll 3 neue Meldungen an.
                                Die musst du jetzt hinzufügen.
                                Keine Ahnung. Irgendein File wohl korrupt. Dein sort reagiert ja auch merkwürdig. Ich würde mal den Datenträger mistrauisch beäugen.
                                  @rsw2004
                                  Bitte keine Bilder von Text. Kann ich nicht kopieren und zitieren.
                                    Ok, läuft bis jetzt. Mal abwarten wie lange.
                                    Vielen Dank für deine Hilfe
                                      Hat nicht lange gehalten 😕
                                      Dieses mal wurden wohl die Instanzen nur deaktiviert/gestoppt.
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:        11
                                      Codename:       bullseye
                                      VERSION_ID="11"
                                      ID=debian
                                       18:17:48 up 19:23,  0 users,  load average: 0.00, 0.00, 0.00
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=52.5'C
                                      volt=0.9160V
                                                     Local time: Wed 2023-08-09 18:17:48 CEST
                                                 Universal time: Wed 2023-08-09 16:17:48 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      robin
                                      /home/robin
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            3.8G        255M        3.1G        1.0M        419M        3.5G
                                      Swap:            99M          0B         99M
                                      Total:          3.9G        255M        3.2G
                                               3794 M total memory
                                                255 M used memory
                                                382 M active memory
                                                192 M inactive memory
                                               3118 M free memory
                                                 40 M buffer memory
                                                379 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      [Tue Aug  8 22:54:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
                                      [Tue Aug  8 22:54:47 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Tue Aug  8 22:54:47 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                      [Tue Aug  8 22:54:49 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                      /var:
                                      558M    /var/
                                      180M    /var/cache
                                      174M    /var/cache/apt
                                      147M    /var/lib
                                      131M    /var/log
                                      Archived and active journals take up 128.0M in the file system.
                                      8.0M    /opt/iobroker/backups/
                                      181M    /opt/iobroker/iobroker-data/
                                      sort: 20M       /opt/iobroker/iobroker-data/objects.jsonl
                                      7.7M    /opt/iobroker/iobroker-data/states.jsonl
                                      sort: write error
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.3.5
                                      javascript:     7.0.3
                                      Adapter State
                                        system.adapter.admin.0                  : admin                 : raspberrypi4                             - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        system.adapter.backitup.0               : backitup              : raspberrypi4                             - disabled
                                        system.adapter.geofency.0               : geofency              : raspberrypi4                             - disabled, port: 7999, bind: 0.0.0.0
                                        system.adapter.info.0                   : info                  : raspberrypi4                             - disabled
                                        system.adapter.iot.0                    : iot                   : raspberrypi4                             - disabled
                                        system.adapter.javascript.0             : javascript            : raspberrypi4                             - disabled
                                        system.adapter.openknx.0                : openknx               : raspberrypi4                             - disabled
                                        system.adapter.solax.0                  : solax                 : raspberrypi4                             - disabled
                                        system.adapter.web.0                    : web                   : raspberrypi4                             - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        system.adapter.yahka.0                  : yahka                 : raspberrypi4                             - disabled
                                      + instance is alive
                                      Objects and States
                                      Objects:        905
                                      States:         702
                                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                                      Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                                      Pending Updates: 0
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12989      504/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12959      504/iobroker.js-con
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14039      539/sshd: /usr/sbin
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          14444      539/sshd: /usr/sbin
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12955      678/dhcpcd
                                      udp        0      0 0.0.0.0:37781           0.0.0.0:*                           108        13939      372/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13937      372/avahi-daemon: r
                                      udp6       0      0 :::55672                :::*                                108        13940      372/avahi-daemon: r
                                      udp6       0      0 :::5353                 :::*                                108        13938      372/avahi-daemon: r
                                      2023-08-09 09:07:38.505  - info: host.raspberrypi4 stopInstance system.adapter.web.0 send kill signal
                                      2023-08-09 09:07:38.473  - info: web.0 (1341) Got terminate signal TERMINATE_YOURSELF
                                      2023-08-09 09:07:38.588  - info: web.0 (1341) terminated http server on port 8082
                                      2023-08-09 09:07:38.589  - info: web.0 (1341) terminating
                                      2023-08-09 09:07:38.591  - info: web.0 (1341) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2023-08-09 09:07:38.768  - info: host.raspberrypi4 "system.adapter.yahka.0" disabled
                                      2023-08-09 09:07:38.769  - info: host.raspberrypi4 stopInstance system.adapter.yahka.0 (force=false, process=true)
                                      2023-08-09 09:07:38.768  - info: yahka.0 (1358) Adapter is disabled => stop
                                      2023-08-09 09:07:38.779  - info: yahka.0 (1358) cleaning up ...
                                      2023-08-09 09:07:38.780  - info: yahka.0 (1358) cleaned up ...
                                      2023-08-09 09:07:38.786  - info: yahka.0 (1358) Got terminate signal TERMINATE_YOURSELF
                                      2023-08-09 09:07:38.816  - info: host.raspberrypi4 stopInstance system.adapter.yahka.0 send kill signal
                                      2023-08-09 09:07:38.832  - info: yahka.0 (1358) terminating
                                      2023-08-09 09:07:38.833  - info: yahka.0 (1358) Terminated (NO_ERROR): Without reason
                                      2023-08-09 09:07:39.140  - info: host.raspberrypi4 instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2023-08-09 09:07:39.381  - info: host.raspberrypi4 instance system.adapter.yahka.0 terminated with code 0 (NO_ERROR)
                                      2023-08-09 09:07:42.922  - info: admin.0 (574) Adapter is disabled => stop
                                      2023-08-09 09:07:42.923  - info: host.raspberrypi4 "system.adapter.admin.0" disabled
                                      2023-08-09 09:07:42.923  - info: host.raspberrypi4 stopInstance system.adapter.admin.0 (force=false, process=true)
                                      2023-08-09 09:07:42.924  - info: admin.0 (574) terminating http server on port 8081
                                      2023-08-09 09:07:42.935  - info: admin.0 (574) Got terminate signal TERMINATE_YOURSELF
                                      2023-08-09 09:07:42.942  - info: admin.0 (574) terminating
                                      2023-08-09 09:07:42.943  - info: admin.0 (574) Terminated (NO_ERROR): Without reason
                                      2023-08-09 09:07:42.968  - info: host.raspberrypi4 stopInstance system.adapter.admin.0 send kill signal
                                      2023-08-09 09:07:43.503  - info: host.raspberrypi4 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                                      Thomas Braun DJMarc75 2 Replies Last reply Reply Quote 0
                                        Wie 0 users?
                                        Irgendwas stimmt da ganz und gar nicht mit dem System, würde ich sagen.
                                        dmesg -T
                                        sagt? Achtung, kann viel sein...
                                        • DJMarc75
                                          DJMarc75 @rsw2004 last edited by
                                          kann eigentlich auch so nicht stimmen 🤔
                                            [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
                                            [    0.000000] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023
                                            [    0.000000] random: crng init done
                                            [    0.000000] Detected PIPT I-cache on CPU0
                                            [    0.000000] CPU features: detected: Spectre-v2
                                            [    0.000000] CPU features: detected: Spectre-v3a
                                            [    0.000000] CPU features: detected: Spectre-v4
                                            [    0.000000] CPU features: detected: Spectre-BHB
                                            [    0.000000] CPU features: kernel page table isolation forced ON by KASLR
                                            [    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
                                            [    0.000000] CPU features: detected: ARM erratum 1742098
                                            [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
                                            [    0.000000] alternatives: applying boot alternatives
                                            [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 996912
                                            [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
                                            [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
                                            [    0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
                                            [    0.000000] efi: UEFI not found.
                                            [    0.000000] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
                                            [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                                            [    0.000000] Zone ranges:
                                            [    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
                                            [    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000fbffffff]
                                            [    0.000000]   Normal   empty
                                            [    0.000000] Movable zone start for each node
                                            [    0.000000] Early memory node ranges
                                            [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
                                            [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                                            [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
                                            [    0.000000] On node 0, zone DMA32: 19456 pages in unavailable ranges
                                            [    0.000000] On node 0, zone DMA32: 16384 pages in unavailable ranges
                                            [    0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
                                            [    0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
                                            [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
                                            [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
                                            [    0.000000] software IO TLB: area num 4.
                                            [    0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
                                            [    0.000000] Memory: 3356948K/4050944K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 169708K reserved, 524288K cma-reserved)
                                            [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                                            [    0.000000] ftrace: allocating 39744 entries in 156 pages
                                            [    0.000000] ftrace: allocated 156 pages with 4 groups
                                            [    0.000000] trace event string verifier disabled[    0.000000] rcu: Preemptible hierarchical RCU implementation.
                                            [    0.000000] rcu:     RCU event tracing is enabled.
                                            [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
                                            [    0.000000]  Trampoline variant of Tasks RCU enabled.
                                            [    0.000000]  Rude variant of Tasks RCU enabled.
                                            [    0.000000]  Tracing variant of Tasks RCU enabled.
                                            [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
                                            [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
                                            [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
                                            [    0.000000] Root IRQ handler: gic_handle_irq
                                            [    0.000000] GIC: Using split EOI/Deactivate mode[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
                                            [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                                            [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                                            [    0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                                            [    0.000320] Console: colour dummy device 80x25
                                            [    0.000923] printk: console [tty1] enabled
                                            [    0.000993] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
                                            [    0.001034] pid_max: default: 32768 minimum: 301[    0.001177] LSM: Security Framework initializing[    0.001412] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
                                            [    0.001500] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
                                            [    0.002842] cgroup: Disabling memory control group subsystem
                                            [    0.005174] cblist_init_generic: Setting adjustable number of callback queues.
                                            [    0.005209] cblist_init_generic: Setting shift to 2 and lim to 1.
                                            [    0.005410] cblist_init_generic: Setting shift to 2 and lim to 1.
                                            [    0.005605] cblist_init_generic: Setting shift to 2 and lim to 1.
                                            [    0.006081] rcu: Hierarchical SRCU implementation.
                                            [    0.006106] rcu:     Max phase no-delay instances is 1000.
                                            [    0.007475] EFI services will not be available.
                                            [    0.008119] smp: Bringing up secondary CPUs ...
                                            [    0.009238] Detected PIPT I-cache on CPU1
                                            [    0.009396] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
                                            [    0.010584] Detected PIPT I-cache on CPU2
                                            [    0.010705] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
                                            [    0.011862] Detected PIPT I-cache on CPU3
                                            [    0.011990] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
                                            [    0.012140] smp: Brought up 1 node, 4 CPUs
                                            [    0.012231] SMP: Total of 4 processors activated.
                                            [    0.012253] CPU features: detected: 32-bit EL0 Support
                                            [    0.012272] CPU features: detected: 32-bit EL1 Support
                                            [    0.012294] CPU features: detected: CRC32 instructions
                                            [    0.012441] CPU: All CPU(s) started at EL2
                                            [    0.012477] alternatives: applying system-wide alternatives
                                            [    0.014365] devtmpfs: initialized
                                            [    0.026516] Enabled cp15_barrier support
                                            [    0.026583] Enabled setend support
                                            [    0.026817] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
                                            [    0.026870] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                                            [    0.040956] pinctrl core: initialized pinctrl subsystem
                                            [    0.041868] DMI not present or invalid.
                                            [    0.042584] NET: Registered PF_NETLINK/PF_ROUTE protocol family
                                            [    0.046262] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
                                            [    0.046585] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
                                            [    0.047571] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
                                            [    0.047683] audit: initializing netlink subsys (disabled)
                                            [    0.047983] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
                                            [    0.048646] thermal_sys: Registered thermal governor 'step_wise'
                                            [    0.048741] cpuidle: using governor menu
                                            [    0.049164] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
                                            [    0.049383] ASID allocator initialised with 32768 entries
                                            [    0.049565] Serial: AMBA PL011 UART driver
                                            [    0.063137] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                                            [    0.084311] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
                                            [    0.088327] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
                                            [    0.104676] KASLR enabled
                                            [    0.140261] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                                            [    0.146221] SCSI subsystem initialized
                                            [    0.146507] usbcore: registered new interface driver usbfs
                                            [    0.146580] usbcore: registered new interface driver hub
                                            [    0.146662] usbcore: registered new device driver usb
                                            [    0.147073] usb_phy_generic phy: supply vcc not found, using dummy regulator
                                            [    0.147309] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
                                            [    0.147691] pps_core: LinuxPPS API ver. 1 registered
                                            [    0.147716] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
                                            [    0.147757] PTP clock support registered
                                            [    0.148896] vgaarb: loaded
                                            [    0.149710] clocksource: Switched to clocksource arch_sys_counter
                                            [    0.150281] VFS: Disk quotas dquot_6.6.0
                                            [    0.150377] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
                                            [    0.150578] FS-Cache: Loaded
                                            [    0.150752] CacheFiles: Loaded
                                            [    0.160200] NET: Registered PF_INET protocol family
                                            [    0.160964] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
                                            [    0.165755] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
                                            [    0.165933] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
                                            [    0.165980] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
                                            [    0.166244] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
                                            [    0.167292] TCP: Hash tables configured (established 32768 bind 32768)
                                            [    0.167581] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
                                            [    0.167697] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
                                            [    0.168044] NET: Registered PF_UNIX/PF_LOCAL protocol family
                                            [    0.168924] RPC: Registered named UNIX socket transport module.
                                            [    0.168960] RPC: Registered udp transport module.
                                            [    0.168980] RPC: Registered tcp transport module.
                                            [    0.168999] RPC: Registered tcp NFSv4.1 backchannel transport module.
                                            [    0.169035] PCI: CLS 0 bytes, default 64
                                            [    0.171722] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
                                            [    0.172153] kvm [1]: IPA Size Limit: 44 bits
                                            [    0.173502] kvm [1]: vgic interrupt IRQ9
                                            [    0.173797] kvm [1]: Hyp mode initialized successfully
                                            [    1.334410] Initialise system trusted keyrings
                                            [    1.334915] workingset: timestamp_bits=46 max_order=20 bucket_order=0
                                            [    1.342628] zbud: loaded
                                            [    1.345546] NFS: Registering the id_resolver key type
                                            [    1.345613] Key type id_resolver registered
                                            [    1.345634] Key type id_legacy registered
                                            [    1.345814] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                                            [    1.345845] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                                            [    1.347312] Key type asymmetric registered
                                            [    1.347345] Asymmetric key parser 'x509' registered
                                            [    1.347439] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
                                            [    1.347734] io scheduler mq-deadline registered
                                            [    1.347762] io scheduler kyber registered
                                            [    1.349781] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)[    1.358754] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                                            [    1.358821] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff][    1.358930] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                                            [    1.359032] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00ffffffff -> 0x0400000000
                                            [    1.360100] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                                            [    1.360134] pci_bus 0000:00: root bus resource [bus 00-ff]
                                            [    1.360163] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                                            [    1.360254] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                                            [    1.360534] pci 0000:00:00.0: PME# supported from D0 D3hot
                                            [    1.364740] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
                                            [    1.364941] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
                                            [    1.365083] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
                                            [    1.431804] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                                            [    1.431989] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                                            [    1.432131] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                                            [    1.432629] pci 0000:01:00.0: PME# supported from D0 D3hot
                                            [    1.433436] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                                            [    1.433477] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                                            [    1.433535] pci 0000:00:00.0: PCI bridge to [bus 01]
                                            [    1.433567] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                                            [    1.447270] iproc-rng200 fe104000.rng: hwrng registered
                                            [    1.447901] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                                            [    1.449533] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                                            [    1.463027] brd: module loaded
                                            [    1.472079] loop: module loaded
                                            [    1.472972] Loading iSCSI transport class v2.0-870.
                                            [    1.478582] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                                            [    1.537878] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                                            [    1.539089] usbcore: registered new interface driver r8152
                                            [    1.539178] usbcore: registered new interface driver lan78xx
                                            [    1.539273] usbcore: registered new interface driver smsc95xx
                                            [    1.586796] pci 0000:00:00.0: enabling device (0000 -> 0002)
                                            [    1.586993] xhci_hcd 0000:01:00.0: xHCI Host Controller
                                            [    1.587037] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                                            [    1.587824] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
                                            [    1.588893] xhci_hcd 0000:01:00.0: xHCI Host Controller
                                            [    1.588928] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                                            [    1.588965] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                                            [    1.589391] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
                                            [    1.589428] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                            [    1.589456] usb usb1: Product: xHCI Host Controller
                                            [    1.589478] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
                                            [    1.589500] usb usb1: SerialNumber: 0000:01:00.0[    1.590334] hub 1-0:1.0: USB hub found
                                            [    1.590421] hub 1-0:1.0: 1 port detected
                                            [    1.591402] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
                                            [    1.591439] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                            [    1.591466] usb usb2: Product: xHCI Host Controller
                                            [    1.591489] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
                                            [    1.591511] usb usb2: SerialNumber: 0000:01:00.0[    1.592216] hub 2-0:1.0: USB hub found
                                            [    1.592340] hub 2-0:1.0: 4 ports detected
                                            [    1.594223] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                                            [    1.594604] dwc_otg: FIQ enabled
                                            [    1.594616] dwc_otg: NAK holdoff enabled
                                            [    1.594627] dwc_otg: FIQ split-transaction FSM enabled
                                            [    1.594644] Module dwc_common_port init
                                            [    1.595244] usbcore: registered new interface driver uas
                                            [    1.595367] usbcore: registered new interface driver usb-storage
                                            [    1.595625] mousedev: PS/2 mouse device common for all mice
                                            [    1.602490] sdhci: Secure Digital Host Controller Interface driver
                                            [    1.602530] sdhci: Copyright(c) Pierre Ossman
                                            [    1.603257] sdhci-pltfm: SDHCI platform and OF driver helper
                                            [    1.607001] ledtrig-cpu: registered to indicate activity on CPUs
                                            [    1.607381] hid: raw HID events driver (C) Jiri Kosina
                                            [    1.607617] usbcore: registered new interface driver usbhid
                                            [    1.607644] usbhid: USB HID core driver
                                            [    1.616816] NET: Registered PF_PACKET protocol family
                                            [    1.616991] Key type dns_resolver registered
                                            [    1.618462] registered taskstats version 1
                                            [    1.618561] Loading compiled-in X.509 certificates
                                            [    1.619507] Key type .fscrypt registered
                                            [    1.619535] Key type fscrypt-provisioning registered
                                            [    1.635627] uart-pl011 fe201000.serial: there is not valid maps for state default
                                            [    1.636409] uart-pl011 fe201000.serial: cts_event_workaround enabled
                                            [    1.636599] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                                            [    1.646078] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                                            [    1.646583] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                                            [    1.647952] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                                            [    1.647985] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                                            [    1.679960] of_cfs_init
                                            [    1.680106] of_cfs_init: OK
                                            [    1.712931] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
                                            [    1.713531] Waiting for root device PARTUUID=105e3ec4-02...
                                            [    1.767144] mmc1: new high speed SDIO card at address 0001
                                            [    1.815348] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
                                            [    1.816450] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
                                            [    1.821077]  mmcblk0: p1 p2
                                            [    1.821735] mmcblk0: mmc0:aaaa SL16G 14.8 GiB (quirks 0x00004000)
                                            [    1.845752] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                                            [    1.850330] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                            [    1.850439] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                            [    1.855942] devtmpfs: mounted
                                            [    1.864826] Freeing unused kernel memory: 4160K
                                            [    1.865049] Run /sbin/init as init process
                                            [    1.865071]   with arguments:
                                            [    1.865081]     /sbin/init
                                            [    1.865091]   with environment:
                                            [    1.865100]     HOME=/
                                            [    1.865110]     TERM=linux
                                            [    1.996424] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                                            [    1.996485] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                                            [    1.996514] usb 1-1: Product: USB2.0 Hub
                                            [    1.998823] hub 1-1:1.0: USB hub found
                                            [    1.999163] hub 1-1:1.0: 4 ports detected
                                            [    2.248990] systemd[1]: System time before build time, advancing clock.
                                            [    2.429091] NET: Registered PF_INET6 protocol family
                                            [    2.431100] Segment Routing with IPv6
                                            [    2.431161] In-situ OAM (IOAM) with IPv6
                                            [    2.508178] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
                                            [    2.509274] systemd[1]: Detected architecture arm64.
                                            [    2.520793] systemd[1]: Set hostname to <raspberrypi4>.
                                            [    3.289012] systemd[1]: Queued start job for default target Multi-User System.
                                            [    3.311430] systemd[1]: Created slice system-getty.slice.
                                            [    3.313274] systemd[1]: Created slice system-modprobe.slice.
                                            [    3.314709] systemd[1]: Created slice system-systemd\x2dfsck.slice.
                                            [    3.315891] systemd[1]: Created slice User and Session Slice.
                                            [    3.316725] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
                                            [    3.317483] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
                                            [    3.318996] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
                                            [    3.319540] systemd[1]: Reached target Local Encrypted Volumes.
                                            [    3.320038] systemd[1]: Reached target Paths.
                                            [    3.320465] systemd[1]: Reached target Slices.
                                            [    3.320866] systemd[1]: Reached target Swap.
                                            [    3.326933] systemd[1]: Listening on Syslog Socket.
                                            [    3.328075] systemd[1]: Listening on fsck to fsckd communication Socket.
                                            [    3.328784] systemd[1]: Listening on initctl Compatibility Named Pipe.
                                            [    3.330439] systemd[1]: Listening on Journal Audit Socket.
                                            [    3.331557] systemd[1]: Listening on Journal Socket (/dev/log).
                                            [    3.332842] systemd[1]: Listening on Journal Socket.
                                            [    3.335075] systemd[1]: Listening on udev Control Socket.
                                            [    3.336215] systemd[1]: Listening on udev Kernel Socket.
                                            [    3.337489] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
                                            [    3.358240] systemd[1]: Mounting POSIX Message Queue File System...
                                            [    3.363375] systemd[1]: Mounting RPC Pipe File System...
                                            [    3.369344] systemd[1]: Mounting Kernel Debug File System...
                                            [    3.375373] systemd[1]: Mounting Kernel Trace File System...
                                            [    3.376420] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
                                            [    3.383453] systemd[1]: Starting Restore / save the current clock...
                                            [    3.390057] systemd[1]: Starting Set the console keyboard layout...
                                            [    3.396146] systemd[1]: Starting Create list of static device nodes for the current kernel...
                                            [    3.402500] systemd[1]: Starting Load Kernel Module configfs...
                                            [    3.409132] systemd[1]: Starting Load Kernel Module drm...
                                            [    3.415968] systemd[1]: Starting Load Kernel Module fuse...
                                            [    3.419780] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.[    3.428792] systemd[1]: Starting File System Check on Root Device...
                                            [    3.439346] systemd[1]: Starting Journal Service...
                                            [    3.467401] systemd[1]: Starting Load Kernel Modules...
                                            [    3.473558] systemd[1]: Starting Coldplug All udev Devices...
                                            [    3.483740] fuse: init (API version 7.37)
                                            [    3.494242] systemd[1]: Mounted POSIX Message Queue File System.
                                            [    3.495657] systemd[1]: Mounted RPC Pipe File System.
                                            [    3.499033] systemd[1]: Mounted Kernel Debug File System.
                                            [    3.500545] systemd[1]: Mounted Kernel Trace File System.
                                            [    3.503366] systemd[1]: Finished Restore / save the current clock.
                                            [    3.510380] systemd[1]: Finished Create list of static device nodes for the current kernel.
                                            [    3.513188] systemd[1]: modprobe@configfs.service: Succeeded.
                                            [    3.516525] systemd[1]: Finished Load Kernel Module configfs.
                                            [    3.519251] systemd[1]: modprobe@fuse.service: Succeeded.
                                            [    3.520982] systemd[1]: Finished Load Kernel Module fuse.
                                            [    3.555682] systemd[1]: Mounting FUSE Control File System...
                                            [    3.569009] systemd[1]: Mounting Kernel Configuration File System...
                                            [    3.576662] systemd[1]: Started File System Check Daemon to report status.
                                            [    3.594430] systemd[1]: Finished Load Kernel Modules.
                                            [    3.595784] systemd[1]: Mounted FUSE Control File System.
                                            [    3.596760] systemd[1]: Mounted Kernel Configuration File System.
                                            [    3.603099] systemd[1]: Starting Apply Kernel Variables...
                                            [    3.625556] systemd[1]: modprobe@drm.service: Succeeded.
                                            [    3.627838] systemd[1]: Finished Load Kernel Module drm.
                                            [    3.663414] systemd[1]: Finished File System Check on Root Device.
                                            [    3.666385] systemd[1]: Finished Apply Kernel Variables.
                                            [    3.694871] systemd[1]: Starting Remount Root and Kernel File Systems...
                                            [    3.844759] systemd[1]: Started Journal Service.[    3.847279] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                            [    3.962764] systemd-journald[142]: Received client request to flush runtime journal.
                                            [    3.975388] systemd-journald[142]: File /var/log/journal/d3a8466ddfb64ce6bef13e128446c843/system.journal corrupted or uncleanly shut down, renaming and replacing.
                                            [    4.905676] mc: Linux media interface: v0.10
                                            [    4.914953] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                                            [    4.917029] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                                            [    4.917069] [vc_sm_connected_init]: start
                                            [    4.926201] [vc_sm_connected_init]: installed successfully
                                            [    5.018774] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
                                            [    5.046480] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
                                            [    5.169627] videodev: Linux video capture interface: v2.00
                                            [    5.173973] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                                            [    5.254392] bcm2835_audio bcm2835_audio: card created with 8 channels
                                            [    5.448834] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                            [    5.493359] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                            [    5.507510] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                            [    5.523435] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
                                            [    5.588822] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                                            [    5.593790] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                                            [    5.627287] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                                            [    5.648568] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                                            [    5.648649] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                                            [    5.655271] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                                            [    5.655333] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                                            [    5.675489] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                                            [    5.675550] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                                            [    5.676946] rpivid feb10000.codec: Device registered as /dev/video19
                                            [    5.707838] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                                            [    5.715130] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
                                            [    5.715224] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
                                            [    5.722136] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
                                            [    5.722197] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
                                            [    5.726668] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                                            [    5.733318] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                                            [    5.739418] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                                            [    5.740081] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                                            [    5.740123] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                                            [    5.740145] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                                            [    5.740171] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                                            [    5.740200] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                                            [    5.811652] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
                                            [    5.911546] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
                                            [    5.922153] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
                                            [    5.978814] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
                                            [    5.978863] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                                            [    5.978887] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                                            [    5.978922] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                                            [    5.978946] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                                            [    5.979378] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                                            [    6.001857] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                            [    6.060334] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                            [    6.083789] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
                                            [    6.401215] brcmfmac: F1 signature read @0x18000000=0x15264345
                                            [    6.416568] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                            [    6.417891] usbcore: registered new interface driver brcmfmac
                                            [    6.687279] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
                                            [    6.797633] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
                                            [    6.817046] Registered IR keymap rc-cec
                                            [    6.818226] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
                                            [    6.819325] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
                                            [    6.853345] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
                                            [    6.878085] Registered IR keymap rc-cec
                                            [    6.878363] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
                                            [    6.878602] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
                                            [    6.935958] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
                                            [    6.946363] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
                                            [    6.970239] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
                                            [    6.973814] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
                                            [    6.974407] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
                                            [    6.974740] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
                                            [    6.975200] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
                                            [    7.078286] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                                            [    7.084554] vc4-drm gpu: [drm] Cannot find any crtc or sizes
                                            [    7.167676] uart-pl011 fe201000.serial: no DMA platform data
                                            [    7.190981] 8021q: 802.1Q VLAN Support v1.8
                                            [    7.316217] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                                            [    8.039347] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                                            [    8.048847] bcmgenet fd580000.ethernet eth0: Link is Down
                                            [   12.125872] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                                            [   12.125916] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                                            [   13.888659] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                                            [   15.390312] Bluetooth: Core ver 2.22
                                            [   15.390400] NET: Registered PF_BLUETOOTH protocol family
                                            [   15.390405] Bluetooth: HCI device and connection manager initialized
                                            [   15.390421] Bluetooth: HCI socket layer initialized
                                            [   15.390429] Bluetooth: L2CAP socket layer initialized
                                            [   15.390442] Bluetooth: SCO socket layer initialized
                                            [   15.398400] Bluetooth: HCI UART driver ver 2.3
                                            [   15.398423] Bluetooth: HCI UART protocol H4 registered
                                            [   15.398847] Bluetooth: HCI UART protocol Three-wire (H5) registered
                                            [   15.400455] Bluetooth: HCI UART protocol Broadcom registered
                                            [   15.760872] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                            [   15.760892] Bluetooth: BNEP filters: protocol multicast
                                            [   15.760908] Bluetooth: BNEP socket layer initialized
                                            [   15.765360] Bluetooth: MGMT ver 1.22
                                            [   15.774030] NET: Registered PF_ALG protocol family
                                            1595
