    4. Alexa2 Version 3.23.1+
    • DJMarc75
      DJMarc75 @Sushibomba last edited by
      @sushibomba
       <variables>
         <variable id="ArF@RQP@E4dRrEB6V=Y+">musik läuft</variable>
         <variable id="5@{OBB!pgabI9xXk2O~n">volume</variable>
       </variables>
       <block type="variables_set" id="0;:0an@a~eRFJD%hr4{F" x="-1063" y="-362">
         <field name="VAR" id="ArF@RQP@E4dRrEB6V=Y+">musik läuft</field>
           <block type="logic_boolean" id="p3]$pTV8:f*m^x;Z`epp">
           <block type="comment" id="`5e(f:ij|C6*J7T!K5Qx">
             <field name="COMMENT">Occupancy</field>
               <block type="on_ext" id="zH#-a*P*Yt-bpm=yh+@_">
                 <value name="OID0">
                   <shadow type="field_oid" id="Ab?XV5Mhj$;)QHjK41({">
                   <block type="controls_if" id=":BQEb0vK5@7e1e)JBEN.">
                       <block type="logic_operation" id="#/hG+M`;}F7-`(Bq@9X." inline="false">
                         <field name="OP">AND</field>
                           <block type="logic_operation" id="tK;w2ROHQ@TeacmLPPWE" inline="false">
                             <field name="OP">OR</field>
                               <block type="time_compare_ex" id="mMB`8=m4$FAAY]2_DB~F">
                                 <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                                 <value name="START_TIME">
                                   <shadow type="text" id="Muh,^j/YK}wa2|0T.%`}">
                                     <field name="TEXT">06:00</field>
                                 <value name="END_TIME">
                                   <shadow type="text" id="LD,)).dfu3ruMzFJ])-#">
                                     <field name="TEXT">08:00</field>
                               <block type="time_compare_ex" id="3@]-:2Fc!|y;(FZG_(%x">
                                   <shadow type="text" id="P?i$3!$(]qN/4Jo=JiAL">
                                     <field name="TEXT">21:01</field>
                                   <shadow type="text" id="W:xT/a=a6P61!K.(V=qs">
                                     <field name="TEXT">23:59</field>
                           <block type="logic_negate" id="d2EuU2lwhSF6*dCsGft~">
                             <value name="BOOL">
                               <block type="variables_get" id=";Bj:)jO|K,d74WP{H?pZ">
                       <block type="variables_set" id="(Zq6^`Se:.xJ^JI_U+#a">
                         <field name="VAR" id="5@{OBB!pgabI9xXk2O~n">volume</field>
                           <block type="math_number" id="9@wiCfjO`yr?jIC]eWHn">
                             <field name="NUM">5</field>
                           <block type="procedures_callnoreturn" id="YhJ*2E?YF$jUKbAm)g0Y">
                             <mutation name="DefJay"></mutation>
                     <value name="IF1">
                       <block type="logic_operation" id="9aNc[0i*s0xdz}A^8iqY" inline="false">
                           <block type="time_compare_ex" id="Rc;r9*CJiDA?8zt/bphU">
                               <shadow type="text" id=".~@W0~Zf0Ke@{MYPj/9S">
                                 <field name="TEXT">08:01</field>
                               <shadow type="text" id="b,duG4R.9q:~(%f[;Ouh">
                                 <field name="TEXT">21:00</field>
                           <block type="logic_negate" id="/[1u?*m%,Ycl3y{3t#){">
                             <value name="BOOL">
                               <block type="variables_get" id="YKpA/{)+}~lzx~o~8)x-">
                     <statement name="DO1">
                       <block type="variables_set" id="W#DR0c`S,7}%[r1$M(d-">
                           <block type="math_number" id="c0)Y}1g4/,?]w;.)C!.W">
                             <field name="NUM">10</field>
                           <block type="procedures_callnoreturn" id="V+xM^*k(oqxyfy;6*bQs">
                   <block type="comment" id="6kydn`A2gUSRTfa^vSd[">
                     <field name="COMMENT">no_motion</field>
                       <block type="on_ext" id="{.Kj$;C/:K1H^lyy+J)9">
                         <value name="OID0">
                           <shadow type="field_oid" id="U4-8o[lw^~Orol+.L#`:">
                           <block type="controls_if" id="d9x~hFxMp!_xFZ:g*=Cw">
                               <block type="logic_operation" id="7.|i#$S!faKc=^WxBB^+" inline="false">
                                   <block type="logic_compare" id=":7b8jw.z.]+L`TuvB3J~">
                                     <field name="OP">GT</field>
                                       <block type="on_source" id="P1i@B=TP7GxOFbW`CMCP">
                                       <block type="math_number" id="R-Cm%4ZnC0@LLrn3b]#|">
                                         <field name="NUM">180</field>
                                   <block type="variables_get" id="{(h[vL*/c~~m*ay6B$VR">
                               <block type="control" id="c~e/euSo`@i[UMx,?851">
                                 <field name="OID">alexa2.0.Echo-Devices.G090LF1182060W0C.Player.controlPause</field>
                                   <block type="logic_boolean" id="Zs0$,fjDIn)A5KUKw_fL">
                                   <block type="variables_set" id="r!:Y(V2q3$RCKjn$Q}5i">
                                       <block type="logic_boolean" id="B_~_)n_55j{2H]uc+x5.">
       <block type="procedures_defnoreturn" id="ljDBOm=%?(V;N,ASL]Rl" x="-487" y="38">
         <field name="NAME">DefJay</field>
         <statement name="STACK">
           <block type="variables_set" id="KxiKB:6=W|P}LIG];G`S">
               <block type="logic_boolean" id="=JxpC%[aEPrYa..$bmpb">
               <block type="control" id="@xBP7V4pMW%4.kQHV|w?">
                 <field name="OID">alexa2.0.Echo-Devices.G090LF1182060W0C.Player.volume</field>
                   <block type="variables_get" id="7s-V}P-US!-0^5SoWqLV">
                   <block type="control" id="n+$M_3}28k(g|^K!CakT">
                     <field name="OID">alexa2.0.Echo-Devices.G090LF1182060W0C.Player.TuneIn-Station</field>
                       <block type="text" id="!vcCP~qfN1+9N-E5/.|:">
                         <field name="TEXT">s54430</field>
        apollon77 last edited by
        Version 3.24.0 mit dem Fix wegen den Push-Notification geht gerade raus ... GitHub schon aktuell. Latest im laufe der Nacht
        Fabio apollon77 2 Replies Last reply Reply Quote 8
        • Fabio
          Fabio @apollon77 last edited by
          @apollon77 vielen Dank für deine Mühen. 👍👌😉
            apollon77 @apollon77 last edited by
            @apollon77 sagte in Alexa2 Version 3.23.1+:
            Die 3.24.1 is the way to go 🙂
            Fabio Siragus Negalein 3 Replies Last reply Reply Quote 5
            • Fabio
              @apollon77 läuft super gerade getestet. Danke.👍
                apollon77 @Fabio last edited by
                @fa-bio ebenso Danke 🙂
                • Oreider
                  Oreider last edited by
                  jetzt hab ich bei mir noch den Fehler dass im Punkt "Player" unter anderem der currentState nicht aktualisiert wird.
                  Auch unter Version 3.24.1
                  Hab ich ein individuelles Problem in meinem Setup oder kann das jemand bestätigen?
                  @apollon77: Von mir auch ein Danke für deine super Arbeit!
                  Tom
                  DJMarc75 Ro75 2 Replies Last reply Reply Quote 0
                  • DJMarc75
                    DJMarc75 @Oreider last edited by DJMarc75
                    @oreider sagte in Alexa2 Version 3.23.1+:
                    "Unter Anderem" ist nicht ziehlführend
                    Bitte alle Datenpunte hier aufführen.
                    Oreider 1 Reply Last reply Reply Quote 0
                    • Ro75
                      Ro75 @Oreider last edited by
                      @oreider also ich kann folgende Aussage treffen:
                      1. Alexa spiele ... Radio
                      2. Radio beginnt zu spielen und der gennnte DP ("currentState") wird auf true gesetzt
                      3. Sage ich jetzt Alexa stopp oder betätige den DP "controlPause" wird der Stream beendet, allerdings läuft noch immer "mediaProgress" und "mediaProgressStr" weiter.
                      4. Erst 180 Sekunden später wird der genannte DP ("currentState") auf false gesetzt und die DP unter Punkt 3 halten an mit dem Zeitpunkt wo stopp gesagt wurde.
                      Ro75.
                      Ro75 1 Reply Last reply Reply Quote 0
                      • Oreider
                        Oreider @DJMarc75 last edited by
                        @djmarc75
                        verstehe....
                        Es wird keiner der Datenpunkte im Player aktualisiert.
                        Die Steuerungselemente unter Player wie Pause, Play usw. funktionieren hingegen noch wunderbar.
                        Tom
                        • Siragus
                          Siragus @apollon77 last edited by Siragus
                          @apollon77
                          Hallo apollon77, läuft wieder wunderbar.
                          Vielen Dank für Deine top Arbeit. 👍
                            kingmyst last edited by
                            Ist schon bekannt das die History nicht mehr funktioniert? Siehe auch Bewertungen des Adapters..
                              Thomas Braun Most Active @kingmyst last edited by
                              @kingmyst
                              Guten Morgen.
                              Version 3.24.1 installieren...
                              • Ro75
                                Ro75 last edited by
                                Eine Frage zum Adapter. Aus der Hilfe bin ich nicht schlau geworden.
                                Frage: Welche Werte sind hier zulässig, sprich min ist 0, aber was ist MAX? Und wo sind die Auswirkungen? Nur Sprache, Musik oder alles?
                                Ro75.
                                • DJMarc75
                                  DJMarc75 @Ro75 last edited by DJMarc75
                                  @ro75 sagte in Alexa2 Version 3.23.1+:
                                  Steht in den Objektdate 😉
                                    "common": {
                                      "name": "Equalizer Bass",
                                      "type": "number",
                                      "role": "level.bass",
                                      "min": -6,
                                      "max": 6,
                                  nur Musik
                                  Ro75 1 Reply Last reply Reply Quote 1
                                  • Ro75
                                    Ro75 @DJMarc75 last edited by
                                    @djmarc75 sagte in Alexa2 Version 3.23.1+:
                                    Danke für den Tipp. Da habe ich nicht nachgesehen. Aber gut zu wissen.
                                    Ro75.
                                    • Negalein
                                      Negalein Global Moderator @apollon77 last edited by
                                      Amazon funkt wieder rein.
                                      DP wieder leer 😞
                                      • Ro75
                                        Ro75 last edited by
                                        Also bei mir funktioniert alles weiterhin, gerade getestet.
                                        • Diginix
                                          Diginix @Negalein last edited by
                                          @negalein Bei mir läuft auch heute alles problemlos und alle states werden per Push aktualisiert.
                                          • Negalein
                                            Negalein Global Moderator @Diginix last edited by Negalein
                                            @diginix sagte in Alexa2 Version 3.23.1+:
                                            gerade getestet.
                                            beim direkt angesprochenem Dot:
                                            Alexa, spiele Lieder von .... --> Funktioniert und die DP springen auch an.
                                            dann, "Alexa stopp" --> Alexa hört auf, aber DP laufen weiter, solange bis der Song aus ist (bei 0:00 angekommen).
                                            bei Befehl auf anderen Dot
                                            bei "Alexa, spiele .... auf Küche (2. Dot) --> fängt Küche ganz normal zu spielen an, aber alle DP bleiben auf false. Erst nach fast 60 Sek. springen sie um.
                                            bei "Alexa stopp auf Küche" --> selbes spiel wie oben.
                                            255
                                            33695
