    4. ioBroker funktioniert nicht mehr
      rsw2004 @Thomas Braun last edited by
      [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
      [    0.000000] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023
      [    0.000000] random: crng init done
      [    0.000000] Detected PIPT I-cache on CPU0
      [    0.000000] CPU features: detected: Spectre-v2
      [    0.000000] CPU features: detected: Spectre-v3a
      [    0.000000] CPU features: detected: Spectre-v4
      [    0.000000] CPU features: detected: Spectre-BHB
      [    0.000000] CPU features: kernel page table isolation forced ON by KASLR
      [    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
      [    0.000000] CPU features: detected: ARM erratum 1742098
      [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
      [    0.000000] alternatives: applying boot alternatives
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 996912
      [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
      [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
      [    0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
      [    0.000000] efi: UEFI not found.
      [    0.000000] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
      [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      [    0.000000] Zone ranges:
      [    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
      [    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000fbffffff]
      [    0.000000]   Normal   empty
      [    0.000000] Movable zone start for each node
      [    0.000000] Early memory node ranges
      [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
      [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
      [    0.000000] On node 0, zone DMA32: 19456 pages in unavailable ranges
      [    0.000000] On node 0, zone DMA32: 16384 pages in unavailable ranges
      [    0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
      [    0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
      [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
      [    0.000000] software IO TLB: area num 4.
      [    0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
      [    0.000000] Memory: 3356948K/4050944K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 169708K reserved, 524288K cma-reserved)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] ftrace: allocating 39744 entries in 156 pages
      [    0.000000] ftrace: allocated 156 pages with 4 groups
      [    0.000000] trace event string verifier disabled[    0.000000] rcu: Preemptible hierarchical RCU implementation.
      [    0.000000] rcu:     RCU event tracing is enabled.
      [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
      [    0.000000]  Trampoline variant of Tasks RCU enabled.
      [    0.000000]  Rude variant of Tasks RCU enabled.
      [    0.000000]  Tracing variant of Tasks RCU enabled.
      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
      [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
      [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
      [    0.000000] Root IRQ handler: gic_handle_irq
      [    0.000000] GIC: Using split EOI/Deactivate mode[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
      [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
      [    0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
      [    0.000320] Console: colour dummy device 80x25
      [    0.000923] printk: console [tty1] enabled
      [    0.000993] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
      [    0.001034] pid_max: default: 32768 minimum: 301[    0.001177] LSM: Security Framework initializing[    0.001412] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.001500] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.002842] cgroup: Disabling memory control group subsystem
      [    0.005174] cblist_init_generic: Setting adjustable number of callback queues.
      [    0.005209] cblist_init_generic: Setting shift to 2 and lim to 1.
      [    0.005410] cblist_init_generic: Setting shift to 2 and lim to 1.
      [    0.005605] cblist_init_generic: Setting shift to 2 and lim to 1.
      [    0.006081] rcu: Hierarchical SRCU implementation.
      [    0.006106] rcu:     Max phase no-delay instances is 1000.
      [    0.007475] EFI services will not be available.
      [    0.008119] smp: Bringing up secondary CPUs ...
      [    0.009238] Detected PIPT I-cache on CPU1
      [    0.009396] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
      [    0.010584] Detected PIPT I-cache on CPU2
      [    0.010705] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
      [    0.011862] Detected PIPT I-cache on CPU3
      [    0.011990] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
      [    0.012140] smp: Brought up 1 node, 4 CPUs
      [    0.012231] SMP: Total of 4 processors activated.
      [    0.012253] CPU features: detected: 32-bit EL0 Support
      [    0.012272] CPU features: detected: 32-bit EL1 Support
      [    0.012294] CPU features: detected: CRC32 instructions
      [    0.012441] CPU: All CPU(s) started at EL2
      [    0.012477] alternatives: applying system-wide alternatives
      [    0.014365] devtmpfs: initialized
      [    0.026516] Enabled cp15_barrier support
      [    0.026583] Enabled setend support
      [    0.026817] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
      [    0.026870] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [    0.040956] pinctrl core: initialized pinctrl subsystem
      [    0.041868] DMI not present or invalid.
      [    0.042584] NET: Registered PF_NETLINK/PF_ROUTE protocol family
      [    0.046262] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
      [    0.046585] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
      [    0.047571] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
      [    0.047683] audit: initializing netlink subsys (disabled)
      [    0.047983] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
      [    0.048646] thermal_sys: Registered thermal governor 'step_wise'
      [    0.048741] cpuidle: using governor menu
      [    0.049164] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
      [    0.049383] ASID allocator initialised with 32768 entries
      [    0.049565] Serial: AMBA PL011 UART driver
      [    0.063137] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      [    0.084311] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
      [    0.088327] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
      [    0.104676] KASLR enabled
      [    0.140261] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
      [    0.146221] SCSI subsystem initialized
      [    0.146507] usbcore: registered new interface driver usbfs
      [    0.146580] usbcore: registered new interface driver hub
      [    0.146662] usbcore: registered new device driver usb
      [    0.147073] usb_phy_generic phy: supply vcc not found, using dummy regulator
      [    0.147309] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
      [    0.147691] pps_core: LinuxPPS API ver. 1 registered
      [    0.147716] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
      [    0.147757] PTP clock support registered
      [    0.148896] vgaarb: loaded
      [    0.149710] clocksource: Switched to clocksource arch_sys_counter
      [    0.150281] VFS: Disk quotas dquot_6.6.0
      [    0.150377] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
      [    0.150578] FS-Cache: Loaded
      [    0.150752] CacheFiles: Loaded
      [    0.160200] NET: Registered PF_INET protocol family
      [    0.160964] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
      [    0.165755] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
      [    0.165933] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [    0.165980] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
      [    0.166244] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
      [    0.167292] TCP: Hash tables configured (established 32768 bind 32768)
      [    0.167581] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
      [    0.167697] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
      [    0.168044] NET: Registered PF_UNIX/PF_LOCAL protocol family
      [    0.168924] RPC: Registered named UNIX socket transport module.
      [    0.168960] RPC: Registered udp transport module.
      [    0.168980] RPC: Registered tcp transport module.
      [    0.168999] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.169035] PCI: CLS 0 bytes, default 64
      [    0.171722] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
      [    0.172153] kvm [1]: IPA Size Limit: 44 bits
      [    0.173502] kvm [1]: vgic interrupt IRQ9
      [    0.173797] kvm [1]: Hyp mode initialized successfully
      [    1.334410] Initialise system trusted keyrings
      [    1.334915] workingset: timestamp_bits=46 max_order=20 bucket_order=0
      [    1.342628] zbud: loaded
      [    1.345546] NFS: Registering the id_resolver key type
      [    1.345613] Key type id_resolver registered
      [    1.345634] Key type id_legacy registered
      [    1.345814] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    1.345845] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
      [    1.347312] Key type asymmetric registered
      [    1.347345] Asymmetric key parser 'x509' registered
      [    1.347439] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
      [    1.347734] io scheduler mq-deadline registered
      [    1.347762] io scheduler kyber registered
      [    1.349781] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)[    1.358754] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
      [    1.358821] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff][    1.358930] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
      [    1.359032] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00ffffffff -> 0x0400000000
      [    1.360100] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
      [    1.360134] pci_bus 0000:00: root bus resource [bus 00-ff]
      [    1.360163] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
      [    1.360254] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
      [    1.360534] pci 0000:00:00.0: PME# supported from D0 D3hot
      [    1.364740] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
      [    1.364941] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
      [    1.365083] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
      [    1.431804] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
      [    1.431989] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
      [    1.432131] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
      [    1.432629] pci 0000:01:00.0: PME# supported from D0 D3hot
      [    1.433436] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
      [    1.433477] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
      [    1.433535] pci 0000:00:00.0: PCI bridge to [bus 01]
      [    1.433567] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
      [    1.447270] iproc-rng200 fe104000.rng: hwrng registered
      [    1.447901] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
      [    1.449533] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
      [    1.463027] brd: module loaded
      [    1.472079] loop: module loaded
      [    1.472972] Loading iSCSI transport class v2.0-870.
      [    1.478582] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
      [    1.537878] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
      [    1.539089] usbcore: registered new interface driver r8152
      [    1.539178] usbcore: registered new interface driver lan78xx
      [    1.539273] usbcore: registered new interface driver smsc95xx
      [    1.586796] pci 0000:00:00.0: enabling device (0000 -> 0002)
      [    1.586993] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.587037] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
      [    1.587824] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
      [    1.588893] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.588928] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
      [    1.588965] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
      [    1.589391] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
      [    1.589428] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    1.589456] usb usb1: Product: xHCI Host Controller
      [    1.589478] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
      [    1.589500] usb usb1: SerialNumber: 0000:01:00.0[    1.590334] hub 1-0:1.0: USB hub found
      [    1.590421] hub 1-0:1.0: 1 port detected
      [    1.591402] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
      [    1.591439] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    1.591466] usb usb2: Product: xHCI Host Controller
      [    1.591489] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
      [    1.591511] usb usb2: SerialNumber: 0000:01:00.0[    1.592216] hub 2-0:1.0: USB hub found
      [    1.592340] hub 2-0:1.0: 4 ports detected
      [    1.594223] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [    1.594604] dwc_otg: FIQ enabled
      [    1.594616] dwc_otg: NAK holdoff enabled
      [    1.594627] dwc_otg: FIQ split-transaction FSM enabled
      [    1.594644] Module dwc_common_port init
      [    1.595244] usbcore: registered new interface driver uas
      [    1.595367] usbcore: registered new interface driver usb-storage
      [    1.595625] mousedev: PS/2 mouse device common for all mice
      [    1.602490] sdhci: Secure Digital Host Controller Interface driver
      [    1.602530] sdhci: Copyright(c) Pierre Ossman
      [    1.603257] sdhci-pltfm: SDHCI platform and OF driver helper
      [    1.607001] ledtrig-cpu: registered to indicate activity on CPUs
      [    1.607381] hid: raw HID events driver (C) Jiri Kosina
      [    1.607617] usbcore: registered new interface driver usbhid
      [    1.607644] usbhid: USB HID core driver
      [    1.616816] NET: Registered PF_PACKET protocol family
      [    1.616991] Key type dns_resolver registered
      [    1.618462] registered taskstats version 1
      [    1.618561] Loading compiled-in X.509 certificates
      [    1.619507] Key type .fscrypt registered
      [    1.619535] Key type fscrypt-provisioning registered
      [    1.635627] uart-pl011 fe201000.serial: there is not valid maps for state default
      [    1.636409] uart-pl011 fe201000.serial: cts_event_workaround enabled
      [    1.636599] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
      [    1.646078] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      [    1.646583] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
      [    1.647952] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [    1.647985] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      [    1.679960] of_cfs_init
      [    1.680106] of_cfs_init: OK
      [    1.712931] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
      [    1.713531] Waiting for root device PARTUUID=105e3ec4-02...
      [    1.767144] mmc1: new high speed SDIO card at address 0001
      [    1.815348] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
      [    1.816450] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
      [    1.821077]  mmcblk0: p1 p2
      [    1.821735] mmcblk0: mmc0:aaaa SL16G 14.8 GiB (quirks 0x00004000)
      [    1.845752] usb 1-1: new high-speed USB device number 2 using xhci_hcd
      [    1.850330] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [    1.850439] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [    1.855942] devtmpfs: mounted
      [    1.864826] Freeing unused kernel memory: 4160K
      [    1.865049] Run /sbin/init as init process
      [    1.865071]   with arguments:
      [    1.865081]     /sbin/init
      [    1.865091]   with environment:
      [    1.865100]     HOME=/
      [    1.865110]     TERM=linux
      [    1.996424] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
      [    1.996485] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
      [    1.996514] usb 1-1: Product: USB2.0 Hub
      [    1.998823] hub 1-1:1.0: USB hub found
      [    1.999163] hub 1-1:1.0: 4 ports detected
      [    2.248990] systemd[1]: System time before build time, advancing clock.
      [    2.429091] NET: Registered PF_INET6 protocol family
      [    2.431100] Segment Routing with IPv6
      [    2.431161] In-situ OAM (IOAM) with IPv6
      [    2.508178] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
      [    2.509274] systemd[1]: Detected architecture arm64.
      [    2.520793] systemd[1]: Set hostname to <raspberrypi4>.
      [    3.289012] systemd[1]: Queued start job for default target Multi-User System.
      [    3.311430] systemd[1]: Created slice system-getty.slice.
      [    3.313274] systemd[1]: Created slice system-modprobe.slice.
      [    3.314709] systemd[1]: Created slice system-systemd\x2dfsck.slice.
      [    3.315891] systemd[1]: Created slice User and Session Slice.
      [    3.316725] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
      [    3.317483] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
      [    3.318996] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
      [    3.319540] systemd[1]: Reached target Local Encrypted Volumes.
      [    3.320038] systemd[1]: Reached target Paths.
      [    3.320465] systemd[1]: Reached target Slices.
      [    3.320866] systemd[1]: Reached target Swap.
      [    3.326933] systemd[1]: Listening on Syslog Socket.
      [    3.328075] systemd[1]: Listening on fsck to fsckd communication Socket.
      [    3.328784] systemd[1]: Listening on initctl Compatibility Named Pipe.
      [    3.330439] systemd[1]: Listening on Journal Audit Socket.
      [    3.331557] systemd[1]: Listening on Journal Socket (/dev/log).
      [    3.332842] systemd[1]: Listening on Journal Socket.
      [    3.335075] systemd[1]: Listening on udev Control Socket.
      [    3.336215] systemd[1]: Listening on udev Kernel Socket.
      [    3.337489] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
      [    3.358240] systemd[1]: Mounting POSIX Message Queue File System...
      [    3.363375] systemd[1]: Mounting RPC Pipe File System...
      [    3.369344] systemd[1]: Mounting Kernel Debug File System...
      [    3.375373] systemd[1]: Mounting Kernel Trace File System...
      [    3.376420] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
      [    3.383453] systemd[1]: Starting Restore / save the current clock...
      [    3.390057] systemd[1]: Starting Set the console keyboard layout...
      [    3.396146] systemd[1]: Starting Create list of static device nodes for the current kernel...
      [    3.402500] systemd[1]: Starting Load Kernel Module configfs...
      [    3.409132] systemd[1]: Starting Load Kernel Module drm...
      [    3.415968] systemd[1]: Starting Load Kernel Module fuse...
      [    3.419780] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.[    3.428792] systemd[1]: Starting File System Check on Root Device...
      [    3.439346] systemd[1]: Starting Journal Service...
      [    3.467401] systemd[1]: Starting Load Kernel Modules...
      [    3.473558] systemd[1]: Starting Coldplug All udev Devices...
      [    3.483740] fuse: init (API version 7.37)
      [    3.494242] systemd[1]: Mounted POSIX Message Queue File System.
      [    3.495657] systemd[1]: Mounted RPC Pipe File System.
      [    3.499033] systemd[1]: Mounted Kernel Debug File System.
      [    3.500545] systemd[1]: Mounted Kernel Trace File System.
      [    3.503366] systemd[1]: Finished Restore / save the current clock.
      [    3.510380] systemd[1]: Finished Create list of static device nodes for the current kernel.
      [    3.513188] systemd[1]: modprobe@configfs.service: Succeeded.
      [    3.516525] systemd[1]: Finished Load Kernel Module configfs.
      [    3.519251] systemd[1]: modprobe@fuse.service: Succeeded.
      [    3.520982] systemd[1]: Finished Load Kernel Module fuse.
      [    3.555682] systemd[1]: Mounting FUSE Control File System...
      [    3.569009] systemd[1]: Mounting Kernel Configuration File System...
      [    3.576662] systemd[1]: Started File System Check Daemon to report status.
      [    3.594430] systemd[1]: Finished Load Kernel Modules.
      [    3.595784] systemd[1]: Mounted FUSE Control File System.
      [    3.596760] systemd[1]: Mounted Kernel Configuration File System.
      [    3.603099] systemd[1]: Starting Apply Kernel Variables...
      [    3.625556] systemd[1]: modprobe@drm.service: Succeeded.
      [    3.627838] systemd[1]: Finished Load Kernel Module drm.
      [    3.663414] systemd[1]: Finished File System Check on Root Device.
      [    3.666385] systemd[1]: Finished Apply Kernel Variables.
      [    3.694871] systemd[1]: Starting Remount Root and Kernel File Systems...
      [    3.844759] systemd[1]: Started Journal Service.[    3.847279] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      [    3.962764] systemd-journald[142]: Received client request to flush runtime journal.
      [    3.975388] systemd-journald[142]: File /var/log/journal/d3a8466ddfb64ce6bef13e128446c843/system.journal corrupted or uncleanly shut down, renaming and replacing.
      [    4.905676] mc: Linux media interface: v0.10
      [    4.914953] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.917029] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      [    4.917069] [vc_sm_connected_init]: start
      [    4.926201] [vc_sm_connected_init]: installed successfully
      [    5.018774] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
      [    5.046480] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
      [    5.169627] videodev: Linux video capture interface: v2.00
      [    5.173973] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.254392] bcm2835_audio bcm2835_audio: card created with 8 channels
      [    5.448834] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.493359] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.507510] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.523435] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.588822] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.593790] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.627287] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.648568] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      [    5.648649] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [    5.655271] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      [    5.655333] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [    5.675489] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      [    5.675550] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [    5.676946] rpivid feb10000.codec: Device registered as /dev/video19
      [    5.707838] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
      [    5.715130] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
      [    5.715224] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
      [    5.722136] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
      [    5.722197] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
      [    5.726668] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
      [    5.733318] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
      [    5.739418] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
      [    5.740081] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
      [    5.740123] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
      [    5.740145] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
      [    5.740171] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
      [    5.740200] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
      [    5.811652] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
      [    5.911546] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
      [    5.922153] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
      [    5.978814] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
      [    5.978863] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
      [    5.978887] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
      [    5.978922] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
      [    5.978946] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
      [    5.979378] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
      [    6.001857] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    6.060334] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    6.083789] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
      [    6.401215] brcmfmac: F1 signature read @0x18000000=0x15264345
      [    6.416568] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    6.417891] usbcore: registered new interface driver brcmfmac
      [    6.687279] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
      [    6.797633] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
      [    6.817046] Registered IR keymap rc-cec
      [    6.818226] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
      [    6.819325] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
      [    6.853345] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
      [    6.878085] Registered IR keymap rc-cec
      [    6.878363] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
      [    6.878602] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
      [    6.935958] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
      [    6.946363] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
      [    6.970239] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
      [    6.973814] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
      [    6.974407] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
      [    6.974740] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
      [    6.975200] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
      [    7.078286] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
      [    7.084554] vc4-drm gpu: [drm] Cannot find any crtc or sizes
      [    7.167676] uart-pl011 fe201000.serial: no DMA platform data
      [    7.190981] 8021q: 802.1Q VLAN Support v1.8
      [    7.316217] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
      [    8.039347] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
      [    8.048847] bcmgenet fd580000.ethernet eth0: Link is Down
      [   12.125872] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
      [   12.125916] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [   13.888659] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
      [   15.390312] Bluetooth: Core ver 2.22
      [   15.390400] NET: Registered PF_BLUETOOTH protocol family
      [   15.390405] Bluetooth: HCI device and connection manager initialized
      [   15.390421] Bluetooth: HCI socket layer initialized
      [   15.390429] Bluetooth: L2CAP socket layer initialized
      [   15.390442] Bluetooth: SCO socket layer initialized
      [   15.398400] Bluetooth: HCI UART driver ver 2.3
      [   15.398423] Bluetooth: HCI UART protocol H4 registered
      [   15.398847] Bluetooth: HCI UART protocol Three-wire (H5) registered
      [   15.400455] Bluetooth: HCI UART protocol Broadcom registered
      [   15.760872] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [   15.760892] Bluetooth: BNEP filters: protocol multicast
      [   15.760908] Bluetooth: BNEP socket layer initialized
      [   15.765360] Bluetooth: MGMT ver 1.22
      [   15.774030] NET: Registered PF_ALG protocol family
      robin@raspberrypi4:/ $
        Thomas Braun Most Active @rsw2004 last edited by
        @rsw2004
        Keine Ahnung was da schief ist.
        Aber hast du auch
        dmesg -T
        eingegeben? Eigentlich sollten dann auch Zeitstempel in der Ausgabe erscheinen.
          Neuer Versuch
          [Tue Aug  8 22:54:46 2023] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
          [Tue Aug  8 22:54:46 2023] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023
          [Tue Aug  8 22:54:46 2023] random: crng init done
          [Tue Aug  8 22:54:46 2023] Machine model: Raspberry Pi 4 Model B Rev 1.4
          [Tue Aug  8 22:54:46 2023] efi: UEFI not found.
          [Tue Aug  8 22:54:46 2023] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
          [Tue Aug  8 22:54:46 2023] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool[Tue Aug  8 22:54:46 2023] Zone ranges:
          [Tue Aug  8 22:54:46 2023]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
          [Tue Aug  8 22:54:46 2023]   DMA32    [mem 0x0000000040000000-0x00000000fbffffff]
          [Tue Aug  8 22:54:46 2023]   Normal   empty
          [Tue Aug  8 22:54:46 2023] Movable zone start for each node
          [Tue Aug  8 22:54:46 2023] Early memory node ranges[Tue Aug  8 22:54:46 2023]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
          [Tue Aug  8 22:54:46 2023]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
          [Tue Aug  8 22:54:46 2023] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
          [Tue Aug  8 22:54:46 2023] On node 0, zone DMA32: 19456 pages in unavailable ranges
          [Tue Aug  8 22:54:46 2023] On node 0, zone DMA32: 16384 pages in unavailable ranges
          [Tue Aug  8 22:54:46 2023] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
          [Tue Aug  8 22:54:46 2023] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
          [Tue Aug  8 22:54:46 2023] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
          [Tue Aug  8 22:54:46 2023] Detected PIPT I-cache on CPU0
          [Tue Aug  8 22:54:46 2023] CPU features: detected: Spectre-v2
          [Tue Aug  8 22:54:46 2023] CPU features: detected: Spectre-v3a
          [Tue Aug  8 22:54:46 2023] CPU features: detected: Spectre-v4
          [Tue Aug  8 22:54:46 2023] CPU features: detected: Spectre-BHB
          [Tue Aug  8 22:54:46 2023] CPU features: kernel page table isolation forced ON by KASLR
          [Tue Aug  8 22:54:46 2023] CPU features: detected: Kernel page table isolation (KPTI)
          [Tue Aug  8 22:54:46 2023] CPU features: detected: ARM erratum 1742098
          [Tue Aug  8 22:54:46 2023] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
          [Tue Aug  8 22:54:46 2023] alternatives: applying boot alternatives
          [Tue Aug  8 22:54:46 2023] Built 1 zonelists, mobility grouping on.  Total pages: 996912
          [Tue Aug  8 22:54:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=105e3ec4-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Tue Aug  8 22:54:46 2023] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
          [Tue Aug  8 22:54:46 2023] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
          [Tue Aug  8 22:54:46 2023] mem auto-init: stack:off, heap alloc:off, heap free:off
          [Tue Aug  8 22:54:46 2023] software IO TLB: area num 4.
          [Tue Aug  8 22:54:46 2023] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
          [Tue Aug  8 22:54:46 2023] Memory: 3356948K/4050944K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 169708K reserved, 524288K cma-reserved)
          [Tue Aug  8 22:54:46 2023] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
          [Tue Aug  8 22:54:46 2023] ftrace: allocating 39744 entries in 156 pages
          [Tue Aug  8 22:54:46 2023] ftrace: allocated 156 pages with 4 groups
          [Tue Aug  8 22:54:46 2023] trace event string verifier disabled
          [Tue Aug  8 22:54:46 2023] rcu: Preemptible hierarchical RCU implementation.
          [Tue Aug  8 22:54:46 2023] rcu:         RCU event tracing is enabled.
          [Tue Aug  8 22:54:46 2023] rcu:         RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
          [Tue Aug  8 22:54:46 2023]      Trampoline variant of Tasks RCU enabled.
          [Tue Aug  8 22:54:46 2023]      Rude variant of Tasks RCU enabled.
          [Tue Aug  8 22:54:46 2023]      Tracing variant of Tasks RCU enabled.
          [Tue Aug  8 22:54:46 2023] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
          [Tue Aug  8 22:54:46 2023] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
          [Tue Aug  8 22:54:46 2023] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
          [Tue Aug  8 22:54:46 2023] Root IRQ handler: gic_handle_irq
          [Tue Aug  8 22:54:46 2023] GIC: Using split EOI/Deactivate mode
          [Tue Aug  8 22:54:46 2023] rcu: srcu_init: Setting srcu_struct sizes based on contention.
          [Tue Aug  8 22:54:46 2023] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
          [Tue Aug  8 22:54:46 2023] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
          [Tue Aug  8 22:54:46 2023] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns[Tue Aug  8 22:54:46 2023] Console: colour dummy device 80x25
          [Tue Aug  8 22:54:46 2023] printk: console [tty1] enabled
          [Tue Aug  8 22:54:46 2023] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
          [Tue Aug  8 22:54:46 2023] pid_max: default: 32768 minimum: 301
          [Tue Aug  8 22:54:46 2023] LSM: Security Framework initializing
          [Tue Aug  8 22:54:46 2023] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
          [Tue Aug  8 22:54:46 2023] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
          [Tue Aug  8 22:54:46 2023] cgroup: Disabling memory control group subsystem
          [Tue Aug  8 22:54:46 2023] cblist_init_generic: Setting adjustable number of callback queues.
          [Tue Aug  8 22:54:46 2023] cblist_init_generic: Setting shift to 2 and lim to 1.
          [Tue Aug  8 22:54:46 2023] rcu: Hierarchical SRCU implementation.
          [Tue Aug  8 22:54:46 2023] rcu:         Max phase no-delay instances is 1000.
          [Tue Aug  8 22:54:46 2023] EFI services will not be available.
          [Tue Aug  8 22:54:46 2023] smp: Bringing up secondary CPUs ...
          [Tue Aug  8 22:54:46 2023] Detected PIPT I-cache on CPU1
          [Tue Aug  8 22:54:46 2023] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
          [Tue Aug  8 22:54:46 2023] Detected PIPT I-cache on CPU2
          [Tue Aug  8 22:54:46 2023] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
          [Tue Aug  8 22:54:46 2023] Detected PIPT I-cache on CPU3
          [Tue Aug  8 22:54:46 2023] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
          [Tue Aug  8 22:54:46 2023] smp: Brought up 1 node, 4 CPUs
          [Tue Aug  8 22:54:46 2023] SMP: Total of 4 processors activated.
          [Tue Aug  8 22:54:46 2023] CPU features: detected: 32-bit EL0 Support
          [Tue Aug  8 22:54:46 2023] CPU features: detected: 32-bit EL1 Support
          [Tue Aug  8 22:54:46 2023] CPU features: detected: CRC32 instructions
          [Tue Aug  8 22:54:46 2023] CPU: All CPU(s) started at EL2
          [Tue Aug  8 22:54:46 2023] alternatives: applying system-wide alternatives
          [Tue Aug  8 22:54:46 2023] devtmpfs: initialized
          [Tue Aug  8 22:54:46 2023] Enabled cp15_barrier support
          [Tue Aug  8 22:54:46 2023] Enabled setend support
          [Tue Aug  8 22:54:46 2023] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
          [Tue Aug  8 22:54:46 2023] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
          [Tue Aug  8 22:54:46 2023] pinctrl core: initialized pinctrl subsystem
          [Tue Aug  8 22:54:46 2023] DMI not present or invalid.
          [Tue Aug  8 22:54:46 2023] NET: Registered PF_NETLINK/PF_ROUTE protocol family
          [Tue Aug  8 22:54:46 2023] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
          [Tue Aug  8 22:54:46 2023] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
          [Tue Aug  8 22:54:46 2023] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations[Tue Aug  8 22:54:46 2023] audit: initializing netlink subsys (disabled)
          [Tue Aug  8 22:54:46 2023] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
          [Tue Aug  8 22:54:46 2023] thermal_sys: Registered thermal governor 'step_wise'
          [Tue Aug  8 22:54:46 2023] cpuidle: using governor menu
          [Tue Aug  8 22:54:46 2023] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
          [Tue Aug  8 22:54:46 2023] ASID allocator initialised with 32768 entries
          [Tue Aug  8 22:54:46 2023] Serial: AMBA PL011 UART driver
          [Tue Aug  8 22:54:46 2023] bcm2835-mbox fe00b880.mailbox: mailbox enabled
          [Tue Aug  8 22:54:46 2023] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
          [Tue Aug  8 22:54:46 2023] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
          [Tue Aug  8 22:54:46 2023] KASLR enabled
          [Tue Aug  8 22:54:46 2023] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
          [Tue Aug  8 22:54:46 2023] SCSI subsystem initialized
          [Tue Aug  8 22:54:46 2023] usbcore: registered new interface driver usbfs
          [Tue Aug  8 22:54:46 2023] usbcore: registered new interface driver hub
          [Tue Aug  8 22:54:46 2023] usbcore: registered new device driver usb
          [Tue Aug  8 22:54:46 2023] usb_phy_generic phy: supply vcc not found, using dummy regulator
          [Tue Aug  8 22:54:46 2023] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
          [Tue Aug  8 22:54:46 2023] pps_core: LinuxPPS API ver. 1 registered
          [Tue Aug  8 22:54:46 2023] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
          [Tue Aug  8 22:54:46 2023] PTP clock support registered
          [Tue Aug  8 22:54:46 2023] vgaarb: loaded
          [Tue Aug  8 22:54:46 2023] clocksource: Switched to clocksource arch_sys_counter
          [Tue Aug  8 22:54:46 2023] VFS: Disk quotas dquot_6.6.0
          [Tue Aug  8 22:54:46 2023] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
          [Tue Aug  8 22:54:46 2023] FS-Cache: Loaded
          [Tue Aug  8 22:54:46 2023] CacheFiles: Loaded
          [Tue Aug  8 22:54:46 2023] NET: Registered PF_INET protocol family
          [Tue Aug  8 22:54:46 2023] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
          [Tue Aug  8 22:54:46 2023] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
          [Tue Aug  8 22:54:46 2023] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
          [Tue Aug  8 22:54:46 2023] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
          [Tue Aug  8 22:54:46 2023] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
          [Tue Aug  8 22:54:46 2023] TCP: Hash tables configured (established 32768 bind 32768)
          [Tue Aug  8 22:54:46 2023] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
          [Tue Aug  8 22:54:46 2023] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
          [Tue Aug  8 22:54:46 2023] NET: Registered PF_UNIX/PF_LOCAL protocol family
          [Tue Aug  8 22:54:46 2023] RPC: Registered named UNIX socket transport module.
          [Tue Aug  8 22:54:46 2023] RPC: Registered udp transport module.
          [Tue Aug  8 22:54:46 2023] RPC: Registered tcp transport module.
          [Tue Aug  8 22:54:46 2023] RPC: Registered tcp NFSv4.1 backchannel transport module.
          [Tue Aug  8 22:54:46 2023] PCI: CLS 0 bytes, default 64
          [Tue Aug  8 22:54:46 2023] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
          [Tue Aug  8 22:54:46 2023] kvm [1]: IPA Size Limit: 44 bits
          [Tue Aug  8 22:54:46 2023] kvm [1]: vgic interrupt IRQ9
          [Tue Aug  8 22:54:46 2023] kvm [1]: Hyp mode initialized successfully
          [Tue Aug  8 22:54:47 2023] Initialise system trusted keyrings
          [Tue Aug  8 22:54:47 2023] workingset: timestamp_bits=46 max_order=20 bucket_order=0
          [Tue Aug  8 22:54:47 2023] zbud: loaded
          [Tue Aug  8 22:54:47 2023] NFS: Registering the id_resolver key type
          [Tue Aug  8 22:54:47 2023] Key type id_resolver registered
          [Tue Aug  8 22:54:47 2023] Key type id_legacy registered
          [Tue Aug  8 22:54:47 2023] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
          [Tue Aug  8 22:54:47 2023] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
          [Tue Aug  8 22:54:47 2023] Key type asymmetric registered
          [Tue Aug  8 22:54:47 2023] Asymmetric key parser 'x509' registered
          [Tue Aug  8 22:54:47 2023] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
          [Tue Aug  8 22:54:47 2023] io scheduler mq-deadline registered
          [Tue Aug  8 22:54:47 2023] io scheduler kyber registered
          [Tue Aug  8 22:54:47 2023] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
          [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
          [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
          [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
          [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00ffffffff -> 0x0400000000
          [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
          [Tue Aug  8 22:54:47 2023] pci_bus 0000:00: root bus resource [bus 00-ff]
          [Tue Aug  8 22:54:47 2023] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
          [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
          [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: PME# supported from D0 D3hot
          [Tue Aug  8 22:54:47 2023] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
          [Tue Aug  8 22:54:47 2023] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
          [Tue Aug  8 22:54:47 2023] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
          [Tue Aug  8 22:54:47 2023] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
          [Tue Aug  8 22:54:47 2023] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
          [Tue Aug  8 22:54:47 2023] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
          [Tue Aug  8 22:54:47 2023] pci 0000:01:00.0: PME# supported from D0 D3hot
          [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
          [Tue Aug  8 22:54:47 2023] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
          [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: PCI bridge to [bus 01]
          [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
          [Tue Aug  8 22:54:47 2023] iproc-rng200 fe104000.rng: hwrng registered
          [Tue Aug  8 22:54:47 2023] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
          [Tue Aug  8 22:54:47 2023] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
          [Tue Aug  8 22:54:47 2023] brd: module loaded
          [Tue Aug  8 22:54:47 2023] loop: module loaded
          [Tue Aug  8 22:54:47 2023] Loading iSCSI transport class v2.0-870.
          [Tue Aug  8 22:54:47 2023] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
          [Tue Aug  8 22:54:47 2023] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
          [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver r8152
          [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver lan78xx
          [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver smsc95xx
          [Tue Aug  8 22:54:47 2023] pci 0000:00:00.0: enabling device (0000 -> 0002)
          [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: xHCI Host Controller
          [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
          [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
          [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
          [Tue Aug  8 22:54:47 2023] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
          [Tue Aug  8 22:54:47 2023] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
          [Tue Aug  8 22:54:47 2023] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [Tue Aug  8 22:54:47 2023] usb usb1: Product: xHCI Host Controller
          [Tue Aug  8 22:54:47 2023] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
          [Tue Aug  8 22:54:47 2023] usb usb1: SerialNumber: 0000:01:00.0
          [Tue Aug  8 22:54:47 2023] hub 1-0:1.0: USB hub found
          [Tue Aug  8 22:54:47 2023] hub 1-0:1.0: 1 port detected
          [Tue Aug  8 22:54:47 2023] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
          [Tue Aug  8 22:54:47 2023] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [Tue Aug  8 22:54:47 2023] usb usb2: Product: xHCI Host Controller
          [Tue Aug  8 22:54:47 2023] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
          [Tue Aug  8 22:54:47 2023] usb usb2: SerialNumber: 0000:01:00.0
          [Tue Aug  8 22:54:47 2023] hub 2-0:1.0: USB hub found
          [Tue Aug  8 22:54:47 2023] hub 2-0:1.0: 4 ports detected
          [Tue Aug  8 22:54:47 2023] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
          [Tue Aug  8 22:54:47 2023] dwc_otg: FIQ enabled
          [Tue Aug  8 22:54:47 2023] dwc_otg: NAK holdoff enabled
          [Tue Aug  8 22:54:47 2023] dwc_otg: FIQ split-transaction FSM enabled
          [Tue Aug  8 22:54:47 2023] Module dwc_common_port init
          [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver uas
          [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver usb-storage
          [Tue Aug  8 22:54:47 2023] mousedev: PS/2 mouse device common for all mice
          [Tue Aug  8 22:54:47 2023] sdhci: Secure Digital Host Controller Interface driver
          [Tue Aug  8 22:54:47 2023] sdhci: Copyright(c) Pierre Ossman
          [Tue Aug  8 22:54:47 2023] sdhci-pltfm: SDHCI platform and OF driver helper
          [Tue Aug  8 22:54:47 2023] ledtrig-cpu: registered to indicate activity on CPUs
          [Tue Aug  8 22:54:47 2023] hid: raw HID events driver (C) Jiri Kosina
          [Tue Aug  8 22:54:47 2023] usbcore: registered new interface driver usbhid
          [Tue Aug  8 22:54:47 2023] usbhid: USB HID core driver
          [Tue Aug  8 22:54:47 2023] NET: Registered PF_PACKET protocol family
          [Tue Aug  8 22:54:47 2023] Key type dns_resolver registered
          [Tue Aug  8 22:54:47 2023] registered taskstats version 1
          [Tue Aug  8 22:54:47 2023] Loading compiled-in X.509 certificates
          [Tue Aug  8 22:54:47 2023] Key type .fscrypt registered
          [Tue Aug  8 22:54:47 2023] Key type fscrypt-provisioning registered
          [Tue Aug  8 22:54:47 2023] uart-pl011 fe201000.serial: there is not valid maps for state default
          [Tue Aug  8 22:54:47 2023] uart-pl011 fe201000.serial: cts_event_workaround enabled
          [Tue Aug  8 22:54:47 2023] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
          [Tue Aug  8 22:54:47 2023] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
          [Tue Aug  8 22:54:47 2023] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
          [Tue Aug  8 22:54:47 2023] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
          [Tue Aug  8 22:54:47 2023] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
          [Tue Aug  8 22:54:47 2023] of_cfs_init
          [Tue Aug  8 22:54:47 2023] of_cfs_init: OK
          [Tue Aug  8 22:54:47 2023] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
          [Tue Aug  8 22:54:47 2023] Waiting for root device PARTUUID=105e3ec4-02...
          [Tue Aug  8 22:54:47 2023] mmc1: new high speed SDIO card at address 0001
          [Tue Aug  8 22:54:47 2023] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
          [Tue Aug  8 22:54:47 2023] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
          [Tue Aug  8 22:54:47 2023]  mmcblk0: p1 p2
          [Tue Aug  8 22:54:47 2023] mmcblk0: mmc0:aaaa SL16G 14.8 GiB (quirks 0x00004000)
          [Tue Aug  8 22:54:47 2023] usb 1-1: new high-speed USB device number 2 using xhci_hcd
          [Tue Aug  8 22:54:47 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Tue Aug  8 22:54:47 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Tue Aug  8 22:54:47 2023] devtmpfs: mounted
          [Tue Aug  8 22:54:47 2023] Freeing unused kernel memory: 4160K
          [Tue Aug  8 22:54:47 2023] Run /sbin/init as init process
          [Tue Aug  8 22:54:47 2023]   with arguments:
          [Tue Aug  8 22:54:47 2023]     /sbin/init
          [Tue Aug  8 22:54:47 2023]   with environment:
          [Tue Aug  8 22:54:47 2023]     HOME=/
          [Tue Aug  8 22:54:47 2023]     TERM=linux
          [Tue Aug  8 22:54:47 2023] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
          [Tue Aug  8 22:54:47 2023] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
          [Tue Aug  8 22:54:47 2023] usb 1-1: Product: USB2.0 Hub
          [Tue Aug  8 22:54:47 2023] hub 1-1:1.0: USB hub found
          [Tue Aug  8 22:54:47 2023] hub 1-1:1.0: 4 ports detected
          [Tue Aug  8 22:54:48 2023] systemd[1]: System time before build time, advancing clock.
          [Tue Aug  8 22:54:48 2023] NET: Registered PF_INET6 protocol family
          [Tue Aug  8 22:54:48 2023] Segment Routing with IPv6
          [Tue Aug  8 22:54:48 2023] In-situ OAM (IOAM) with IPv6
          [Tue Aug  8 22:54:48 2023] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
          [Tue Aug  8 22:54:48 2023] systemd[1]: Detected architecture arm64.
          [Tue Aug  8 22:54:48 2023] systemd[1]: Set hostname to <raspberrypi4>.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Queued start job for default target Multi-User System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Created slice system-getty.slice.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Created slice system-modprobe.slice.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Created slice system-systemd\x2dfsck.slice.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Created slice User and Session Slice.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Reached target Local Encrypted Volumes.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Reached target Paths.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Reached target Slices.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Reached target Swap.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on Syslog Socket.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on fsck to fsckd communication Socket.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on initctl Compatibility Named Pipe.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on Journal Audit Socket.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on Journal Socket (/dev/log).
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on Journal Socket.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on udev Control Socket.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Listening on udev Kernel Socket.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting POSIX Message Queue File System...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting RPC Pipe File System...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting Kernel Debug File System...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting Kernel Trace File System...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Restore / save the current clock...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Set the console keyboard layout...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Create list of static device nodes for the current kernel...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Load Kernel Module configfs...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Load Kernel Module drm...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Load Kernel Module fuse...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting File System Check on Root Device...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Journal Service...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Load Kernel Modules...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Coldplug All udev Devices...
          [Tue Aug  8 22:54:49 2023] fuse: init (API version 7.37)
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted POSIX Message Queue File System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted RPC Pipe File System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted Kernel Debug File System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted Kernel Trace File System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Restore / save the current clock.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Create list of static device nodes for the current kernel.
          [Tue Aug  8 22:54:49 2023] systemd[1]: modprobe@configfs.service: Succeeded.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Load Kernel Module configfs.
          [Tue Aug  8 22:54:49 2023] systemd[1]: modprobe@fuse.service: Succeeded.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Load Kernel Module fuse.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting FUSE Control File System...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounting Kernel Configuration File System...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Started File System Check Daemon to report status.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Load Kernel Modules.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted FUSE Control File System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Mounted Kernel Configuration File System.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Apply Kernel Variables...
          [Tue Aug  8 22:54:49 2023] systemd[1]: modprobe@drm.service: Succeeded.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Load Kernel Module drm.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished File System Check on Root Device.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Finished Apply Kernel Variables.
          [Tue Aug  8 22:54:49 2023] systemd[1]: Starting Remount Root and Kernel File Systems...
          [Tue Aug  8 22:54:49 2023] systemd[1]: Started Journal Service.
          [Tue Aug  8 22:54:49 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          [Tue Aug  8 22:54:49 2023] systemd-journald[142]: Received client request to flush runtime journal.
          [Tue Aug  8 22:54:49 2023] systemd-journald[142]: File /var/log/journal/d3a8466ddfb64ce6bef13e128446c843/system.journal corrupted or uncleanly shut down, renaming and replacing.
          [Tue Aug  8 22:54:50 2023] mc: Linux media interface: v0.10
          [Tue Aug  8 22:54:50 2023] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:50 2023] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
          [Tue Aug  8 22:54:50 2023] [vc_sm_connected_init]: start
          [Tue Aug  8 22:54:50 2023] [vc_sm_connected_init]: installed successfully
          [Tue Aug  8 22:54:51 2023] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
          [Tue Aug  8 22:54:51 2023] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
          [Tue Aug  8 22:54:51 2023] videodev: Linux video capture interface: v2.00
          [Tue Aug  8 22:54:51 2023] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:51 2023] bcm2835_audio bcm2835_audio: card created with 8 channels
          [Tue Aug  8 22:54:51 2023] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:51 2023] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:51 2023] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:51 2023] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:51 2023] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
          [Tue Aug  8 22:54:51 2023] rpivid feb10000.codec: Device registered as /dev/video19
          [Tue Aug  8 22:54:51 2023] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
          [Tue Aug  8 22:54:51 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
          [Tue Aug  8 22:54:51 2023] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
          [Tue Aug  8 22:54:52 2023] cfg80211: Loading compiled-in X.509 certificates for regulatory database
          [Tue Aug  8 22:54:52 2023] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
          [Tue Aug  8 22:54:52 2023] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid[Tue Aug  8 22:54:52 2023] brcmfmac: F1 signature read @0x18000000=0x15264345
          [Tue Aug  8 22:54:52 2023] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
          [Tue Aug  8 22:54:52 2023] usbcore: registered new interface driver brcmfmac
          [Tue Aug  8 22:54:52 2023] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
          [Tue Aug  8 22:54:52 2023] Registered IR keymap rc-cec
          [Tue Aug  8 22:54:52 2023] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
          [Tue Aug  8 22:54:52 2023] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
          [Tue Aug  8 22:54:52 2023] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
          [Tue Aug  8 22:54:52 2023] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Tue Aug  8 22:54:52 2023] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Tue Aug  8 22:54:53 2023] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
          [Tue Aug  8 22:54:53 2023] vc4-drm gpu: [drm] Cannot find any crtc or sizes
          [Tue Aug  8 22:54:53 2023] uart-pl011 fe201000.serial: no DMA platform data
          [Tue Aug  8 22:54:53 2023] 8021q: 802.1Q VLAN Support v1.8
          [Tue Aug  8 22:54:53 2023] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
          [Tue Aug  8 22:54:54 2023] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
          [Tue Aug  8 22:54:54 2023] bcmgenet fd580000.ethernet eth0: Link is Down
          [Tue Aug  8 22:54:58 2023] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
          [Tue Aug  8 22:54:58 2023] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
          [Tue Aug  8 22:54:59 2023] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
          [Tue Aug  8 22:55:01 2023] Bluetooth: Core ver 2.22[Tue Aug  8 22:55:01 2023] NET: Registered PF_BLUETOOTH protocol family
          [Tue Aug  8 22:55:01 2023] Bluetooth: HCI device and connection manager initialized
          [Tue Aug  8 22:55:01 2023] Bluetooth: HCI socket layer initialized
          [Tue Aug  8 22:55:01 2023] Bluetooth: L2CAP socket layer initialized
          [Tue Aug  8 22:55:01 2023] Bluetooth: SCO socket layer initialized
          [Tue Aug  8 22:55:01 2023] Bluetooth: HCI UART driver ver 2.3
          [Tue Aug  8 22:55:01 2023] Bluetooth: HCI UART protocol H4 registered
          [Tue Aug  8 22:55:01 2023] Bluetooth: HCI UART protocol Three-wire (H5) registered
          [Tue Aug  8 22:55:01 2023] Bluetooth: HCI UART protocol Broadcom registered
          [Tue Aug  8 22:55:01 2023] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
          [Tue Aug  8 22:55:01 2023] Bluetooth: BNEP filters: protocol multicast
          [Tue Aug  8 22:55:01 2023] Bluetooth: BNEP socket layer initialized
          [Tue Aug  8 22:55:01 2023] Bluetooth: MGMT ver 1.22[Tue Aug  8 22:55:01 2023] NET: Registered PF_ALG protocol family
            rsw2004 @rsw2004 last edited by
            @Thomas-Braun
            Was wäre denn in dem Fall wahrscheinlicher? Defekte Speicherkarte oder gar ein defekt am Raspberry?
            Thomas Braun Ro75 2 Replies Last reply Reply Quote 0
              @rsw2004
              Keine Ahnung.
              • Ro75
                Ro75 @rsw2004 last edited by
                @rsw2004 sagte in ioBroker funktioniert nicht mehr:
                Ich habe hier einige Raspberry's am Laufen. SD-Karten sind mir schon einige abgeflogen. Die "preiswerteste" Variante wäre wohl testweise es mal mit einer frischen zu versuchen - so würde ich herangehen.
                Ro75.
                mcm1957 R 2 Replies Last reply Reply Quote 0
                • mcm1957
                  mcm1957 @Ro75 last edited by
                  Wenn du nicht nur was zum Spielen brauchst solltest du eine SSD an den Raspi anschließen.
                  SD ist immer problematisch
                  Ro75 R 2 Replies Last reply Reply Quote 0
                  • Ro75
                    Ro75 @mcm1957 last edited by
                    @mcm57 sagte in ioBroker funktioniert nicht mehr:
                    Da stimme ich dir zu 100% zu. Nur hier ging es ja um
                      rsw2004 @mcm1957 last edited by
                      @mcm57
                      Ich denke das wäre für meine Zwecke etwas dick aufgetragen. Im Endeffekt kopple ich mit ioBroker lediglich eine handvoll Funktionen aus meinem KNX-System mit HomeKit und nutze Geofencing um die Heizung runterzuregeln, wenn Bereich verlassen wird.
                      Also tatsächlich Spielerei.
                        rsw2004 @Ro75 last edited by
                        @ro75
                        Irgendwelche Empfehlung was Hersteller und Typ betrifft?
                        Dann werde ich mir demnächst mal eine Neue besorgen.
                          Thomas Braun Most Active @rsw2004 last edited by Thomas Braun
                          @rsw2004
                          Ich hatte zu meiner SD-Karten-Zeit ausschließlich Samsung im Einsatz.
                          Bis auf einmal, als ich auf eine billige Intenso aus dem Supermarkt notgedrungen ausgewichen bin. Die hat dann auch nur wenige Wochen gehalten. Lesson learned...
                          • mcm1957
                            @rsw2004
                            Bei ca 20,-- EUR für 240GB ?
                            Da kommt ja die SD schon fast teurer...
                            Abgesehen davon dass du natürlich ein USB Gehäuse brauchst. (Argon One M2 oder ein anderes)
                            https://geizhals.at/?cat=hdssd&xf=1035_Western+Digital
                            (Keine direkte Empfehlung, soll nur zeigen dass die ssd Preise für kleine ssds im Keller sind)
                              Homoran Global Moderator Administrators @mcm1957 last edited by
                              nicht nur für kleine!
                              M2 NVMe 1TB für unter 50 Euro https://www.alternate.de/listing.xhtml?q=nvme+1tb&s=price_asc
                              1595
