    4. Test Adapter Plex v0.8.x
    • Du-Bass
      Du-Bass @Zefau last edited by
      @Zefau
      Good day!
      I installed this adapter. Filled in ip and tried to get PIN, but couldn't get it... What did i do wrong?
      Du-Bass 1 Reply Last reply Reply Quote 0
      • Du-Bass
        Du-Bass @Du-Bass last edited by
        @Du-Bass said in Test Adapter Plex v0.8.x:
        @Zefau
        Good day!
        Solved this question.
        I have to change instance to debug, and at log check th PIN. I think it will great to add to readme for this adapter
        • Negalein
          @Zefau
          hab heute deinen Adapter installiert.
          Mir füllt es das Log extrem an.
          Hab den Adapter schon auf warn gestellt. Wird aber nicht unterdrückt.
          plex.0 2022-01-05 23:15:03.914	warn	Object of state "plex.0.libraries.4-horror" is missing the required property "common.type"
          plex.0 2022-01-05 23:15:03.914	warn	Object of state "plex.0.libraries.10-filme" is missing the required property "common.type"
          plex.0 2022-01-05 23:15:03.914	warn	Object of state "plex.0.libraries" is missing the required property "common.type"
          plex.0 2022-01-05 23:15:03.913	warn	Object of state "plex.0.settings.other" is missing the required property "common.type"
          • Negalein
            Negalein Global Moderator @sigi234 last edited by
            @sigi234 sagte in Test Adapter Plex v0.8.x:
            Arbeite schon an einer Vis:
            Servus Sigi!
            Verwendest du noch Plex und gibt es deinen View noch?
              ticaki last edited by
              wow ist das Problem schon alt.
              ich hab die common.type Warnung gefixt bitte testen
              https://github.com/ticaki/ioBroker.plex
              Dann mache ich eine PR draus.
                liv-in-sky @ticaki last edited by
                @ticaki
                die common.type sind nicht gekommen - aber evtl möchtest du das noch ansehen - beim starten eines videos
                plex.0
                2023-08-12 15:24:50.482	info	State value to set for "plex.0._playing._recent-player.playing" has to be type "string" but received type "boolean"
                plex.0
                2023-08-12 15:24:50.479	info	State value to set for "plex.0._playing._recent-player.Metadata.parentRatingKey" has to be type "number" but received type "string"
                plex.0
                2023-08-12 15:24:50.479	info	State value to set for "plex.0._playing._recent-player.Metadata.grandparentRatingKey" has to be type "number" but received type "string"
                  @ticaki und nochmals danke - wäre schade um den adapter
                    ticaki @liv-in-sky last edited by ticaki
                    @liv-in-sky
                    kannst du dieses Addon(Tautulli) testen? Das ist seit 2021 archiviert und ich wollte sowas altes nicht installieren. Oder gibts da was gepflegtes für?
                    Ich gucke auch mal nach diesen typen
                      liv-in-sky @ticaki last edited by liv-in-sky
                      @ticaki sagte in Test Adapter Plex v0.8.x:
                      habe ich angesehen (tautulli) - es wurde sofort das laufende video übertragen und in tautulli sichtbar - hat mir erstmal gereicht - brauchst du ws besonderes
                        @liv-in-sky
                        Nein danke, muß nur den Code besser verstehen. Also ist das Tautulli noch ok? Kann ich das ohne furcht installieren? 😂
                          @ticaki bei mir läuft es noch - habe aber nicht die neuste plex version - hatte mal ein problem , das ich meine mediathek daten nicht mehr über die apps aktualisieren konnte - daher blieb ich bei der älteren version
                          1.25.3.5409
                            @liv-in-sky
                            Ich kann alles überall aktualisieren das nur nebenher:
                            https://github.com/ticaki/ioBroker.plex/tree/testing
                            das wirft bei mir keine Warnungen oder unnötigen Infos mehr raus. Da haben in der alten Version über 10 Datenpunkte gefehlt und 2 scheinen sich geändert zu haben.
                            Den plex.0 Objektdatenbaum zu löschen scheint auch kein Problem zu sein, der wird bei jedem Start neu erstellt nur unter _playing werden die Geräte erst bei Benutzung eingetragen.
                            Wegen der geänderten Datenpunkte ist entweder löschen oder per Hand ändern angeraten 🙂
                            "playing.metadata.ratingkey": {"description": "The unique identifier for the movie, episode, or track.", "role": "value", "type": "string"},
                            "playing.metadata.year": {"description": "The release year for the item", "role": "text", "type": "number"},
                            ach und wenn no clue irgendwo steht bedeutet das genau das - bin für erleuchtung dankbar 🙂
                              habe das jetzt installiert - dann:
                                @liv-in-sky
                                Das ist von dem Addon und mein vorheriger hack(den ich entfernt habe) hat das abgefangen tja mal sehen
                                  @ticaki soll ich waarten oder wieder andere version installieren ?
                                    seh ich nirgends - habe aber auch nicht danach gesucht
                                      @liv-in-sky
                                      moment ... das ist echt lachhaft ich hab die '' überall entfernt bis auf ststistics.user
                                      nochmal testen bitte gleicher link
                                      "libraries.directory": {"description": "no clue", "role": "indicator", "type": "boolean"},
                                      "libraries.hidden": {"description": "no clue", "role": "value", "type":"number"},
                                        @ticaki habe nochmal installiert und mal die dp unter einem chrome player gelöscht - sollen ja wieder angelegt werden
                                        dann kommt das.
                                        plex.0
                                        2023-08-12 17:14:18.957	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.summary" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.957	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.originallyAvailableAt" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.957	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.key" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.957	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.Director" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.957	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.title" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.957	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.lastViewedAt" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.957	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.lastViewedAtDate" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.957	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.duration" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.956	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.ratingKey" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.956	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.stream.remaining_time" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.955	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.stream.stream_bandwidth" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.955	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.stream.stream_video.stream_video_ref_frames" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.955	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.stream.stream_video.stream_video_height" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.955	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.stream.stream_video.stream_video_codec_level" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.955	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.stream.stream_video.stream_video_bitrate" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.955	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.stream.stream_video.stream_video_width" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.955	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.stream.stream_video._data" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.955	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.stream.remaining_duration" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.954	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.stream.stream_bitrate" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.954	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.stream._data" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.954	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.file.size" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.954	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.file.name" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.954	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.file.path" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.954	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.file._data" has no existing object, this might lead to an error in future versions
                                        plex.0
                                        2023-08-12 17:14:18.954	warn	State "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.event" has no existing object, this might lead to an error in future versions
                                          @ticaki
                                          habe mal alles restartet - die dp werden wieder angelegt aber leider so:
                                          plex.0
                                          2023-08-12 17:18:35.697	info	State value to set for "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.duration" has to be type "number" but received type "string"
                                          plex.0
                                          2023-08-12 17:18:35.696	info	State value to set for "plex.0._playing._recent-player.Metadata.duration" has to be type "number" but received type "string"
                                          plex.0
                                          2023-08-12 17:18:35.696	info	State value to set for "plex.0._playing._recent-player.Metadata.ratingKey" has to be type "number" but received type "string"
                                          plex.0
                                          2023-08-12 17:18:09.156	info	State value to set for "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.parentRatingKey" has to be type "number" but received type "string"
                                          plex.0
                                          2023-08-12 17:18:09.156	info	State value to set for "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.grandparentRatingKey" has to be type "number" but received type "string"
                                          plex.0
                                          2023-08-12 17:18:09.149	info	State value to set for "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.lastViewedAt" has to be type "number" but received type "string"
                                          plex.0
                                          2023-08-12 17:18:09.149	info	State value to set for "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.duration" has to be type "number" but received type "string"
                                          plex.0
                                          2023-08-12 17:18:09.148	info	State value to set for "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.year" has to be type "number" but received type "string"
                                          plex.0
                                          2023-08-12 17:18:09.138	info	State value to set for "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Metadata.librarySectionID" has to be type "number" but received type "string"
                                          plex.0
                                          2023-08-12 17:18:09.138	info	State value to set for "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Player.local" has to be type "boolean" but received type "string"
                                          plex.0
                                          2023-08-12 17:18:09.137	info	State value to set for "plex.0._playing.chrome-4ays2x70z22bh3izrda15gqv.Account.userId" has to be type "number" but received type "string"
                                            @liv-in-sky sagte in Test Adapter Plex v0.8.x:
                                            Hast du plex nach dem löschen neu gestartet?
                                            ach und zu tautulli, hatte da die falsche github seite, wird ja doch noch gepflegt und gibt sogar für proxmox ein installer script
                                            https://tteck.github.io/Proxmox/
                                            plex
                                            14
                                            312
                                            45759
