    4. JavaScript
    5. (gelöst) Datenpunkte per RESTful API senden
    • JoJo58
      JoJo58 @paul53 last edited by
      @paul53 Das funktioniert auch. Kommt folgendes zurück:
      19:17:41.238	info	javascript.0 (27410) Start javascript script.js.API_Daten_senden.Test_API
      19:17:41.244	info	javascript.0 (27410) script.js.API_Daten_senden.Test_API: string
      19:17:41.244	info	javascript.0 (27410) script.js.API_Daten_senden.Test_API: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      19:18:21.901	info	javascript.0 (27410) Stop script script.js.API_Daten_senden.Test_API
      19:18:21.909	info	javascript.0 (27410) Start javascript script.js.API_Daten_senden.Test_API
      19:18:21.941	info	javascript.0 (27410) script.js.API_Daten_senden.Test_API: [ { "date": "12.08.2023", "severity": "warn", "from": "hm-rega.0", "message": "[2 Einträge] Script \"!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems\" ignored, b", "ts": 1691799750581 }, { "date": "12.08.2023", "severity": "warn", "from": "influxdb.0", "message": "Error on writePoint(\"{\"value\":12,\"time\":\"2023-08-12T00:21:39.143Z\",\"from\":\"system.adapter.hm-rpc.1\",", "ts": 1691799724657 }, { "date": "12.08.2023", "severity": "warn", "from": "influxdb.0", "message": "Error on writePoint(\"{\"value\":31,\"time\":\"2023-08-12T00:21:28.764Z\",\"from\":\"system.adapter.hm-rpc.1\",", "ts": 1691799721275 }, { "date": "12.08.2023", "severity": "warn", "from": "influxdb.0", "message": "Error on writePoint(\"{\"value\":33,\"time\":\"2023-08-12T00:20:21.862Z\",\"from\":\"system.adapter.hm-rpc.1\",", "ts": 1691799721275 }, { "date": "12.08.2023", "severity": "warn", "from": "influxdb.0", "message": "Error on writePoint(\"{\"value\":3.2,\"time\":\"2023-08-12T00:21:28.763Z\",\"from\":\"system.adapter.hm-rpc.1\"", "ts": 1691799721274 }, { "date": "12.08.2023", "severity": "warn", "from": "influxdb.0", "message": "Error on writePoint(\"{\"value\":0.26,\"time\":\"2023-08-12T00:21:28.523Z\",\"from\":\"system.adapter.hm-rpc.0", "ts": 1691799721265 } ]
      19:18:21.941	info	javascript.0 (27410) script.js.API_Daten_senden.Test_API: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        paul53 @JoJo58 last edited by
        @jojo58 sagte: Das funktioniert auch.
        Dann muss es auch mit der Variablen funktionieren. Irgendwo vertippt?
        JoJo58 1 Reply Last reply Reply Quote 0
        • JoJo58
          JoJo58 @paul53 last edited by JoJo58
          @paul53 Es gibt keinerlei Fehlermeldungen und hier das komplette Script nochmal. Ich sehe auch keinen Fehler:
          var request = require ('request');
          // WarnAndError
          let jsonWar = getState("logparser.0.filters.WarnAndError.json").val.replace(/<[^>]+>/g, '');
          //let jsonWar = getState("logparser.0.filters.WarnAndError.json").val;
          // WarnAndError
          // request('http://192.168.1.14:8087/set/0_userdata.0.LogParser_Raspi4.WarnAndError.json?value=' +jsonWar);
          // WarnAndError
          request('http://192.168.1.14:8087/set/0_userdata.0.LogParser_Raspi4.WarnAndError.json?value=' +jsonWar, function (error, response, result) {
              if (error) {
                 log(error, 'warn');
              } else {
                 log(result);
          Die alten Zeilen sind zwar noch drin, aber wie du siehst auskommentiert.
            @jojo58 sagte: Ich sehe auch keinen Fehler:
            Ich auch nicht. Versuche mal
            log(jsonWar);
            jsonWar = jsonWar.replace(/<[^>]+>/g, '');
            log(jsonWar);
            JoJo58 2 Replies Last reply Reply Quote 0
            • JoJo58
              @paul53 im Ersten log stehen jetzt ALLE Daten (wie bei dir) und im zweiten Log nichts mehr, das ist leer. Soll ich dir das posten?
              • JoJo58
                @paul53 Jetzt tauchen zwischendurch Fehler auf:
                19:44:20.059	warn	javascript.0 (27410) script.js.API_Daten_senden.LP_jsonWarn_senden: {'errno':-104,'code':'ECONNRESET','syscall':'read'}
                  @jojo58 sagte: im zweiten Log nichts mehr, das ist leer.
                  Dann bin ich mit meinem Latein am Ende.
                  • DJMarc75
                    DJMarc75 @JoJo58 last edited by
                    @jojo58 wäre es nicht auch eine Idee diese Datenpunkte per MQTT zu schicken ?
                    Nur mal so gefragt 😉
                    • JoJo58
                      @paul53 Und was ist wenn man den String erst bereinigt und lokal in einen Datenpunkt schreibt? Also z.B. von "logparser.0.filters.WarnAndError.json" bereinigen und nach "0_userdata.0.LP_JSON.Warn_JSON" kopieren und ich dann die Daten übertrage? Wie müsste das Script aussehen?
                      • JoJo58
                        JoJo58 @DJMarc75 last edited by
                        @djmarc75 sagte in Datenpunkte per RESTful API senden:
                        Tja, wenn es sonst nicht gehen sollte, muss ich mir das wohl ansehen. Dazu müsste ich mir aber erst nochmal den Kurs von Matthias Kleine reinziehen. Habe bis jetzt nichts mit MQTT zu tun gehabt. Hab zwar 2 Shelly 3EM, aber die sind über den Adapter angebunden.
                          paul53 @JoJo58 last edited by paul53
                          @jojo58 sagte: Und was ist wenn man den String erst bereinigt und lokal in einen Datenpunkt schreibt?
                          Was soll ein zusätzlicher Datenpunkt bringen, wenn das "Bereinigen" bei Dir nicht funktioniert?
                          @jojo58 sagte in Datenpunkte per RESTful API senden:
                          Wieso wie bei mir? Es muss HTML-Code enthalten.
                          • DJMarc75
                            ? Das hat ja mit Shellys erstmal nix zu tun.
                            Ich habe bei mir einen RPI3 als MQTT - Broker am laufen und auf all meinen ioBroker-Installationen den MQTT-Client Adapter installiert.
                            Das ist kinderleicht einfach Daten hin und her zu schieben 😉
                            Wäre halt eine Idee - aber in Deinem Beitrag halt auch OffTopic
                            Ihr findet schon eine Lösung 👍
                            • JoJo58
                              @paul53 Nee, kein HTML Code zu sehen. Ist ne Menge an Log, aber hier sind die Daten dann doch:
                              20:04:00.005	info	javascript.0 (27410) script.js.API_Daten_senden.LP_jsonWarn_senden: [{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[292 Einträge] Request error: Error: read ECONNRESET","ts":1691862860015},{"date":"12.08.2023","severity":"warn","from":"javascript.0","message":"[25 Einträge] LP_jsonWarn_senden: {'errno':-104,'code':'ECONNRESET','syscall':'read'}","ts":1691862860014},{"date":"12.08.2023","severity":"warn","from":"admin.0","message":"[4 Einträge] cannot subscribe on alias \"alias.0.LP_Senden.WarnAndError\": Alias alias.0.LP_Senden.WarnAndError has","ts":1691862708537},{"date":"12.08.2023","severity":"warn","from":"admin.0","message":"[6 Einträge] Alias alias.0.LP_Senden.WarnAndError has no target 12","ts":1691862708536},{"date":"12.08.2023","severity":"warn","from":"admin.0","message":"cannot subscribe on alias \"alias.0.LP_Senden.Info\": Alias alias.0.LP_Senden.Info has no target 12","ts":1691862708536},{"date":"12.08.2023","severity":"warn","from":"admin.0","message":"[2 Einträge] Alias alias.0.LP_Senden.Info has no target 12","ts":1691862708532},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[15 Einträge] at processImmediate (node:internal/timers:478:21)","ts":1691861229151},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[15 Einträge] at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1628:17)","ts":1691861229151},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[15 Einträge] at /opt/iobroker/node_modules/iobroker.javascript/main.js:2153:17","ts":1691861229151},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[15 Einträge] at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2055:37)","ts":1691861229151},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[15 Einträge] at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1802:21)","ts":1691861229151},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[15 Einträge] at new Script (node:vm:100:7)","ts":1691861229151},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[7 Einträge] SyntaxError: missing ) after argument list","ts":1691861229150},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] ^","ts":1691861229150},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[3 Einträge] LP_jsonWarn_senden:6","ts":1691861229148},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[17 Einträge] at processTimers (node:internal/timers:512:7)","ts":1691861220006},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[17 Einträge] at listOnTimeout (node:internal/timers:569:17)","ts":1691861220006},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[17 Einträge] at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib","ts":1691861220006},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[17 Einträge] at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:2","ts":1691861220006},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[17 Einträge] at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:","ts":1691861220006},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[17 Einträge] at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1606:34)","ts":1691861220005},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] LP_jsonWarn_senden:26:9)","ts":1691861220005},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] LP_jsonWarn_senden: TypeError: Cannot read properties of undefined (reading 'replace')","ts":1691861220004},{"date":"12.08.2023","severity":"warn","from":"javascript.0","message":"Test_API:3:3","ts":1691860628260},{"date":"12.08.2023","severity":"warn","from":"javascript.0","message":"[2 Einträge] Test_API:1:12","ts":1691860628260},{"date":"12.08.2023","severity":"warn","from":"javascript.0","message":"[2 Einträge] getState \"logparser.0.filters.WarAndError.json\" not found (3)","ts":1691860628259},{"date":"12.08.2023","severity":"warn","from":"javascript.0","message":"Test_API:2:3","ts":1691860571410},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"at Script.runInContext (node:vm:141:12)","ts":1691856265304},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"Test_API:10:3","ts":1691856265303},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"Test_API:2:96","ts":1691856265303},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"Test_API: ReferenceError: jsonWar is not defined","ts":1691856265303},{"date":"12.08.2023","severity":"warn","from":"javascript.0","message":"[5 Einträge] LP_jsonInfo_senden: wled unten nicht erreichbar!ReferenceError: json is not defined","ts":1691852250006},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] SyntaxError: Identifier 'json' has already been declared","ts":1691851613182},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] ^","ts":1691851613182},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[7 Einträge] LP_jsonInfo_senden:19","ts":1691851613181},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] ^","ts":1691851551115},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[5 Einträge] LP_jsonInfo_senden:37:9)","ts":1691851550005},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[5 Einträge] LP_jsonInfo_senden:14:5)","ts":1691851550005},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[5 Einträge] replace is not a function","ts":1691851550004},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] SyntaxError: Cannot use import statement outside a module","ts":1691846703724},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] ^^^^^^","ts":1691846703724},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] import axios from \"axios\";","ts":1691846703723},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[6 Einträge] LP_jsonInfo_senden:3","ts":1691846703723},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] LP_jsonInfo_senden:16:44)","ts":1691845140012},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[4 Einträge] LP_jsonInfo_senden: ReferenceError: value is not defined","ts":1691845140012},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] LP_jsonInfo_senden:13:5)","ts":1691845140007},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] LP_jsonInfo_senden:19:68)","ts":1691845140006},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[3 Einträge] SyntaxError: Identifier 'encodedData' has already been declared","ts":1691845057530},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[10 Einträge] ^","ts":1691845057530},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"async function encodedData(ip, dp, encodedData) {","ts":1691845057530},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[3 Einträge] LP_jsonInfo_senden:18","ts":1691845057529},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] async function encodedData(ip, dp, value) {","ts":1691845030381},{"date":"12.08.2023","severity":"warn","from":"admin.0","message":"[2 Einträge] Alias alias.0.LP_Senden.Info has no target 12","ts":1691843720523},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[4 Einträge] postJson(192.168.1.14:8087, 0_userdata.0.LogParser_Raspi4.HomeMatic.json, logparser.0.filters.Homema","ts":1691842834490},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[9 Einträge] LP_jsonInfo_senden:13","ts":1691842834490},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[6 Einträge] LP_jsonInfo_senden:36:9)","ts":1691842090005},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[6 Einträge] LP_jsonInfo_senden:17:53)","ts":1691842090005},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[6 Einträge] at JSON.parse ()","ts":1691842090005},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[6 Einträge] LP_jsonInfo_senden: SyntaxError: Unexpected token l in JSON at position 0","ts":1691842090004},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] LP_jsonInfo_senden:13","ts":1691841992150},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"postJson(192.168.1.14, 0_userdata.0.LogParser_Raspi4.HomeMatic.json, logparser.0.filters.Homematic.j","ts":1691841949930},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"SyntaxError: Unexpected number","ts":1691841668371},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"async function postJson(192.168.1.14:8087, logparser.0.filters.Homematic.json, value) {","ts":1691841668370},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"LP_jsonInfo_senden:16","ts":1691841668369},{"date":"12.08.2023","severity":"warn","from":"admin.0","message":"[3 Einträge] Alias alias.0.LP_Senden.Info has no target 12","ts":1691841573977},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"resolve(\"Beispiel\"\");","ts":1691840295831},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"LP_jsonInfo_senden_neu:39","ts":1691840295830},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[3 Einträge] LP_jsonInfo_senden_neu: Fehler beim Übertragen der Daten an das Zielsystem:","ts":1691840290009},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the no","ts":1691839799660},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] npm","ts":1691839799658},{"date":"12.08.2023","severity":"warn","from":"admin.0","message":"[2 Einträge] Alias alias.0.LP_Senden.WarnAndError has no target 9","ts":1691838260105},{"date":"12.08.2023","severity":"warn","from":"javascript.0","message":"[2 Einträge] Alias alias.0.LP_Senden.WarnAndError has no target 12","ts":1691838260089},{"date":"12.08.2023","severity":"warn","from":"influxdb.0","message":"Alias alias.0.LP_Senden.WarnAndError has no target 12","ts":1691838260086},{"date":"12.08.2023","severity":"warn","from":"admin.0","message":"[2 Einträge] Alias alias.0.LP_Senden.Info has no target 12","ts":1691838247232},{"date":"12.08.2023","severity":"warn","from":"javascript.0","message":"[2 Einträge] Alias alias.0.LP_Senden.Info has no target 9","ts":1691838246574},{"date":"12.08.2023","severity":"warn","from":"javascript.0","message":"[2 Einträge] Alias alias.0.LP_Senden.Info has no target 12","ts":1691838246556},{"date":"12.08.2023","severity":"warn","from":"influxdb.0","message":"Alias alias.0.LP_Senden.Info has no target 12","ts":1691838246554},{"date":"12.08.2023","severity":"warn","from":"admin.0","message":"cannot subscribe on alias \"alias.0.LP_Senden.HomeMatic\": Alias alias.0.LP_Senden.HomeMatic has no ta","ts":1691838225030},{"date":"12.08.2023","severity":"warn","from":"admin.0","message":"[2 Einträge] Alias alias.0.LP_Senden.HomeMatic has no target 12","ts":1691838225027},{"date":"12.08.2023","severity":"warn","from":"javascript.0","message":"[2 Einträge] Alias alias.0.LP_Senden.HomeMatic has no target 9","ts":1691838221586},{"date":"12.08.2023","severity":"warn","from":"influxdb.0","message":"[2 Einträge] Alias alias.0.LP_Senden.HomeMatic has no target 12","ts":1691838221569},{"date":"12.08.2023","severity":"warn","from":"javascript.0","message":"Alias alias.0.LP_Senden.HomeMatic has no target 12","ts":1691838221571},{"date":"12.08.2023","severity":"warn","from":"luftdaten.0","message":"[9 Einträge] [fillSensorData] received error 500 response from remote sensor 8139 with content: \"\"","ts":1691832628557},{"date":"12.08.2023","severity":"warn","from":"luftdaten.0","message":"[17 Einträge] [fillSensorData] received error 500 response from remote sensor 35026 with content: \"\"","ts":1691830847337},{"date":"12.08.2023","severity":"warn","from":"luftdaten.0","message":"[18 Einträge] [fillSensorData] received error 500 response from remote sensor 5630 with content: \"\"","ts":1691830845454},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"npm notice npm notice New minor version of npm available! 9.5.1 -> 9.8.1 ","ts":1691824451308},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issue","ts":1691824432838},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[2 Einträge] WARN","ts":1691824432835},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"[3 Einträge] ","ts":1691824432830},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() i","ts":1691824432658},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"npm ","ts":1691824432528},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"WARN deprecated har-validator@5.1.5: this library is no longer supported ","ts":1691824432214},{"date":"12.08.2023","severity":"error","from":"javascript.0","message":"npm","ts":1691824432210},{"date":"12.08.2023","severity":"warn","from":"hm-rega.0","message":"[2 Einträge] Script \"!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems\" ignored, b","ts":1691799750581},{"date":"12.08.2023","severity":"warn","from":"influxdb.0","message":"Error: error authorizing query: user_iobroker not authorized to execute statement 'ALTER RETENTION P","ts":1691799749396},{"date":"12.08.2023","severity":"warn","from":"influxdb.0","message":"Error on writePoint(\"{\"value\":12,\"time\":\"2023-08-12T00:21:39.143Z\",\"from\":\"system.adapter.hm-rpc.1\",","ts":1691799724657},{"date":"12.08.2023","severity":"warn","from":"influxdb.0","message":"Error on writePoint(\"{\"value\":31,\"time\":\"2023-08-12T00:21:28.764Z\",\"from\":\"system.adapter.hm-rpc.1\",","ts":1691799721275},{"date":"12.08.2023","severity":"warn","from":"influxdb.0","message":"Error on writePoint(\"{\"value\":33,\"time\":\"2023-08-12T00:20:21.862Z\",\"from\":\"system.adapter.hm-rpc.1\",","ts":1691799721275},{"date":"12.08.2023","severity":"warn","from":"influxdb.0","message":"Error on writePoint(\"{\"value\":3.2,\"time\":\"2023-08-12T00:21:28.763Z\",\"from\":\"system.adapter.hm-rpc.1\"","ts":1691799721274},{"date":"12.08.2023","severity":"warn","from":"influxdb.0","message":"Error on writePoint(\"{\"value\":2733089.2,\"time\":\"2023-08-12T00:21:28.556Z\",\"from\":\"system.adapter.rpi","ts":1691799721274}]
                              20:04:00.024	info	javascript.0 (27410) script.js.API_Daten_senden.LP_jsonWarn_senden
                                @jojo58 sagte: kein HTML Code zu sehen.
                                Dann muss auch nichts bereinigt werden und es kann so gesendet werden.
                                Weshalb ist jetzt kein HTML-Code mehr enthalten?
                                JoJo58 3 Replies Last reply Reply Quote 0
                                • JoJo58
                                  @paul53 Ich habe jetzt das Log drin gelassen, aber das Replace rausgenommen. Jetzt ist wieder HTML Code drin.
                                  20:21:30.004	info	javascript.0 (2067) script.js.API_Daten_senden.LP_jsonWarn_senden: [{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"javascript.0","message":"[7 Einträge] Alias alias.0.LP_Senden.WarnAndError has no target 12","ts":1691864284068},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"javascript.0","message":"[2 Einträge] Alias alias.0.LP_Senden.Info has no target 12","ts":1691864284067},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[292 Einträge] Request error: Error: read ECONNRESET","ts":1691862860015},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"javascript.0","message":"[25 Einträge] LP_jsonWarn_senden: {'errno':-104,'code':'ECONNRESET','syscall':'read'}","ts":1691862860014},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"admin.0","message":"[4 Einträge] cannot subscribe on alias \"alias.0.LP_Senden.WarnAndError\": Alias alias.0.LP_Senden.WarnAndError has","ts":1691862708537},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"admin.0","message":"[2 Einträge] Alias alias.0.LP_Senden.Info has no target 12","ts":1691862708532},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[15 Einträge] at processImmediate (node:internal/timers:478:21)","ts":1691861229151},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[15 Einträge] at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1628:17)","ts":1691861229151},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[15 Einträge] at /opt/iobroker/node_modules/iobroker.javascript/main.js:2153:17","ts":1691861229151},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[15 Einträge] at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2055:37)","ts":1691861229151},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[15 Einträge] at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1802:21)","ts":1691861229151},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[15 Einträge] at new Script (node:vm:100:7)","ts":1691861229151},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[7 Einträge] SyntaxError: missing ) after argument list","ts":1691861229150},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] ^","ts":1691861229150},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[3 Einträge] LP_jsonWarn_senden:6","ts":1691861229148},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[17 Einträge] at processTimers (node:internal/timers:512:7)","ts":1691861220006},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[17 Einträge] at listOnTimeout (node:internal/timers:569:17)","ts":1691861220006},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[17 Einträge] at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib","ts":1691861220006},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[17 Einträge] at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:2","ts":1691861220006},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[17 Einträge] at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:","ts":1691861220006},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[17 Einträge] at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1606:34)","ts":1691861220005},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] LP_jsonWarn_senden:26:9)","ts":1691861220005},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] LP_jsonWarn_senden: TypeError: Cannot read properties of undefined (reading 'replace')","ts":1691861220004},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"javascript.0","message":"Test_API:3:3","ts":1691860628260},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"javascript.0","message":"[2 Einträge] Test_API:1:12","ts":1691860628260},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"javascript.0","message":"[2 Einträge] getState \"logparser.0.filters.WarAndError.json\" not found (3)","ts":1691860628259},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"javascript.0","message":"Test_API:2:3","ts":1691860571410},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"at Script.runInContext (node:vm:141:12)","ts":1691856265304},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"Test_API:10:3","ts":1691856265303},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"Test_API:2:96","ts":1691856265303},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"Test_API: ReferenceError: jsonWar is not defined","ts":1691856265303},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"javascript.0","message":"[5 Einträge] LP_jsonInfo_senden: wled unten nicht erreichbar!ReferenceError: json is not defined","ts":1691852250006},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] SyntaxError: Identifier 'json' has already been declared","ts":1691851613182},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] ^","ts":1691851613182},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[7 Einträge] LP_jsonInfo_senden:19","ts":1691851613181},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] ^","ts":1691851551115},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[5 Einträge] LP_jsonInfo_senden:37:9)","ts":1691851550005},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[5 Einträge] LP_jsonInfo_senden:14:5)","ts":1691851550005},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[5 Einträge] replace is not a function","ts":1691851550004},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] SyntaxError: Cannot use import statement outside a module","ts":1691846703724},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] ^^^^^^","ts":1691846703724},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] import axios from \"axios\";","ts":1691846703723},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[6 Einträge] LP_jsonInfo_senden:3","ts":1691846703723},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] LP_jsonInfo_senden:16:44)","ts":1691845140012},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[4 Einträge] LP_jsonInfo_senden: ReferenceError: value is not defined","ts":1691845140012},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] LP_jsonInfo_senden:13:5)","ts":1691845140007},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] LP_jsonInfo_senden:19:68)","ts":1691845140006},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[3 Einträge] SyntaxError: Identifier 'encodedData' has already been declared","ts":1691845057530},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[10 Einträge] ^","ts":1691845057530},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"async function encodedData(ip, dp, encodedData) {","ts":1691845057530},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[3 Einträge] LP_jsonInfo_senden:18","ts":1691845057529},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] async function encodedData(ip, dp, value) {","ts":1691845030381},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"admin.0","message":"[2 Einträge] Alias alias.0.LP_Senden.Info has no target 12","ts":1691843720523},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[4 Einträge] postJson(192.168.1.14:8087, 0_userdata.0.LogParser_Raspi4.HomeMatic.json, logparser.0.filters.Homema","ts":1691842834490},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[9 Einträge] LP_jsonInfo_senden:13","ts":1691842834490},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[6 Einträge] LP_jsonInfo_senden:36:9)","ts":1691842090005},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[6 Einträge] LP_jsonInfo_senden:17:53)","ts":1691842090005},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[6 Einträge] at JSON.parse (<anonymous>)","ts":1691842090005},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[6 Einträge] LP_jsonInfo_senden: SyntaxError: Unexpected token l in JSON at position 0","ts":1691842090004},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] LP_jsonInfo_senden:13","ts":1691841992150},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"postJson(192.168.1.14, 0_userdata.0.LogParser_Raspi4.HomeMatic.json, logparser.0.filters.Homematic.j","ts":1691841949930},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"SyntaxError: Unexpected number","ts":1691841668371},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"async function postJson(192.168.1.14:8087, logparser.0.filters.Homematic.json, value) {","ts":1691841668370},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"LP_jsonInfo_senden:16","ts":1691841668369},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"admin.0","message":"[3 Einträge] Alias alias.0.LP_Senden.Info has no target 12","ts":1691841573977},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"resolve(\"Beispiel\"\");","ts":1691840295831},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"LP_jsonInfo_senden_neu:39","ts":1691840295830},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[3 Einträge] LP_jsonInfo_senden_neu: Fehler beim Übertragen der Daten an das Zielsystem:","ts":1691840290009},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the no","ts":1691839799660},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] npm","ts":1691839799658},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"admin.0","message":"[2 Einträge] Alias alias.0.LP_Senden.WarnAndError has no target 9","ts":1691838260105},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"javascript.0","message":"[2 Einträge] Alias alias.0.LP_Senden.WarnAndError has no target 12","ts":1691838260089},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"influxdb.0","message":"Alias alias.0.LP_Senden.WarnAndError has no target 12","ts":1691838260086},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"admin.0","message":"[2 Einträge] Alias alias.0.LP_Senden.Info has no target 12","ts":1691838247232},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"javascript.0","message":"[2 Einträge] Alias alias.0.LP_Senden.Info has no target 9","ts":1691838246574},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"javascript.0","message":"[2 Einträge] Alias alias.0.LP_Senden.Info has no target 12","ts":1691838246556},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"influxdb.0","message":"Alias alias.0.LP_Senden.Info has no target 12","ts":1691838246554},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"admin.0","message":"cannot subscribe on alias \"alias.0.LP_Senden.HomeMatic\": Alias alias.0.LP_Senden.HomeMatic has no ta","ts":1691838225030},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"admin.0","message":"[2 Einträge] Alias alias.0.LP_Senden.HomeMatic has no target 12","ts":1691838225027},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"javascript.0","message":"[2 Einträge] Alias alias.0.LP_Senden.HomeMatic has no target 9","ts":1691838221586},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"influxdb.0","message":"[2 Einträge] Alias alias.0.LP_Senden.HomeMatic has no target 12","ts":1691838221569},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"javascript.0","message":"Alias alias.0.LP_Senden.HomeMatic has no target 12","ts":1691838221571},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"luftdaten.0","message":"[9 Einträge] [fillSensorData] received error 500 response from remote sensor 8139 with content: \"\"","ts":1691832628557},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"luftdaten.0","message":"[17 Einträge] [fillSensorData] received error 500 response from remote sensor 35026 with content: \"\"","ts":1691830847337},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"luftdaten.0","message":"[18 Einträge] [fillSensorData] received error 500 response from remote sensor 5630 with content: \"\"","ts":1691830845454},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"npm notice npm notice New minor version of npm available! 9.5.1 -> 9.8.1 ","ts":1691824451308},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issue","ts":1691824432838},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[2 Einträge] WARN","ts":1691824432835},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"[3 Einträge] ","ts":1691824432830},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() i","ts":1691824432658},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"npm ","ts":1691824432528},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"WARN deprecated har-validator@5.1.5: this library is no longer supported ","ts":1691824432214},{"date":"12.08.2023","severity":"<span class='logError logSeverity'>error</span>","from":"javascript.0","message":"npm","ts":1691824432210},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"hm-rega.0","message":"[2 Einträge] Script \"!# system.fn 0.1 !# !# Dieses Script gibt die FW-Versionsnummer und mehr systems\" ignored, b","ts":1691799750581},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"influxdb.0","message":"Error: error authorizing query: user_iobroker not authorized to execute statement 'ALTER RETENTION P","ts":1691799749396},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"influxdb.0","message":"Error on writePoint(\"{\"value\":12,\"time\":\"2023-08-12T00:21:39.143Z\",\"from\":\"system.adapter.hm-rpc.1\",","ts":1691799724657},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"influxdb.0","message":"Error on writePoint(\"{\"value\":31,\"time\":\"2023-08-12T00:21:28.764Z\",\"from\":\"system.adapter.hm-rpc.1\",","ts":1691799721275},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"influxdb.0","message":"Error on writePoint(\"{\"value\":33,\"time\":\"2023-08-12T00:20:21.862Z\",\"from\":\"system.adapter.hm-rpc.1\",","ts":1691799721275},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"influxdb.0","message":"Error on writePoint(\"{\"value\":3.2,\"time\":\"2023-08-12T00:21:28.763Z\",\"from\":\"system.adapter.hm-rpc.1\"","ts":1691799721274},{"date":"12.08.2023","severity":"<span class='logWarn logSeverity'>warn</span>","from":"influxdb.0","message":"Error on writePoint(\"{\"value\":2733089.2,\"time\":\"2023-08-12T00:21:28.556Z\",\"from\":\"system.adapter.rpi","ts":1691799721274}]
                                  20:21:30.027	warn	javascript.0 (2067) script.js.API_Daten_senden.LP_jsonWarn_senden: {'errno':-104,'code':'ECONNRESET','syscall':'read'}
                                  20:21:31.051	info	javascript.0 (2067) Stop script script.js.API_Daten_senden.LP_jsonWarn_senden
                                  • JoJo58
                                    @paul53 Ich hab für heute genug Misserfolge gehabt, kümmere mich morgen nochmal um das Problem. Vielen Dank für deine Hilfe und einen schönen Abend noch.
                                    Gruß JoJo
                                    • JoJo58
                                      @paul53 Guten Morgen, das hat mir keine Ruhe gelassen und ich habe es jetzt nochmal anders versucht. Zuerst bereinige ich die Daten mit replace und schreibe sie in einen neuen Datenpunkt.
                                      // WarnAndError
                                      //log(jsonWar);
                                      //log(jsonWar);
                                      setState('0_userdata.0.LP_JSON.Warn_JSON', jsonWar);
                                      Das klappt und im neuen Datenpunkt habe ich dann diesen String stehen:
                                         "date": "13.08.2023",
                                         "severity": "warn",
                                         "from": "javascript.0",
                                         "message": "[21 Einträge] at processTimers (node:internal/timers:512:7)",
                                         "ts": 1691909930020
                                         "severity": "warn",
                                         "message": "[21 Einträge] at listOnTimeout (node:internal/timers:569:17)",
                                         "ts": 1691909930019
                                         "severity": "warn",
                                         "message": "[21 Einträge] at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib",
                                         "ts": 1691909930019
                                         "severity": "warn",
                                         "message": "[21 Einträge] at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:2",
                                         "ts": 1691909930019
                                         "severity": "warn",
                                         "message": "[21 Einträge] at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:",
                                         "ts": 1691909930018
                                         "severity": "warn",
                                         "message": "[21 Einträge] at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1606:34)",
                                         "ts": 1691909930018
                                         "severity": "warn",
                                         "message": "[2 Einträge] LP_Warn_kopieren:26:9)",
                                         "ts": 1691909930017
                                         "severity": "warn",
                                         "message": "[2 Einträge] LP_Warn_kopieren:13:5)",
                                         "ts": 1691909930017
                                         "severity": "warn",
                                         "message": "[2 Einträge] at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)",
                                         "ts": 1691909930017
                                         "severity": "warn",
                                         "message": "[2 Einträge] State \"0_userdata.0.LP_JSON.Warn_JSON?value=\" not found",
                                         "ts": 1691909930015
                                         "severity": "error",
                                         "message": "[2 Einträge] LP_Warn_kopieren:25:9)",
                                         "ts": 1691909680009
                                         "message": "[2 Einträge] LP_Warn_kopieren:13:47)",
                                         "ts": 1691909680009
                                         "message": "[2 Einträge] LP_Warn_kopieren: TypeError: Cannot read properties of undefined (reading 'jsonWar')",
                                         "ts": 1691909680008
                                         "message": "[16 Einträge] at processImmediate (node:internal/timers:478:21)",
                                         "ts": 1691909628303
                                         "message": "[16 Einträge] at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1628:17)",
                                         "ts": 1691909628303
                                         "message": "[16 Einträge] at /opt/iobroker/node_modules/iobroker.javascript/main.js:2153:17",
                                         "ts": 1691909628302
                                         "message": "[16 Einträge] at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2055:37)",
                                         "ts": 1691909628302
                                         "message": "[16 Einträge] at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1802:21)",
                                         "ts": 1691909628302
                                         "message": "[16 Einträge] at new Script (node:vm:100:7)",
                                         "ts": 1691909628301
                                         "message": "SyntaxError: Unexpected token ')'",
                                         "ts": 1691909628301
                                         "message": "[3 Einträge] ^",
                                         "ts": 1691909628299
                                         "message": "});",
                                         "ts": 1691909628297
                                         "message": "LP_Warn_kopieren:19",
                                         "ts": 1691909628295
                                         "severity": "warn",
                                         "from": "admin.0",
                                         "message": "[6 Einträge] cannot subscribe on alias \"alias.0.LP_Senden.WarnAndError\": Alias alias.0.LP_Senden.WarnAndError has",
                                         "ts": 1691909246969
                                         "severity": "warn",
                                         "from": "admin.0",
                                         "message": "[9 Einträge] Alias alias.0.LP_Senden.WarnAndError has no target 12",
                                         "ts": 1691909246969
                                         "severity": "warn",
                                         "from": "admin.0",
                                         "message": "cannot subscribe on alias \"alias.0.LP_Senden.Info\": Alias alias.0.LP_Senden.Info has no target 12",
                                         "ts": 1691909246968
                                         "severity": "warn",
                                         "from": "admin.0",
                                         "message": "[2 Einträge] Alias alias.0.LP_Senden.Info has no target 12",
                                         "ts": 1691909246965
                                         "severity": "warn",
                                         "from": "drops-weather.0",
                                         "message": "AxiosError: timeout of 15000ms exceeded",
                                         "ts": 1691886909572
                                         "from": "telegram.0",
                                         "message": "getMe (reconnect #20) Error:Error: EFATAL: Error: connect ECONNREFUSED 149.154.167.220:443",
                                         "ts": 1691877596283
                                         "from": "pushover.0",
                                         "message": "Cannot send notification: {\"errno\":-111,\"code\":\"ECONNREFUSED\",\"syscall\":\"connect\",\"address\":\"104.20.",
                                         "ts": 1691877596127
                                         "severity": "warn",
                                         "message": "Error: connect ECONNREFUSED 104.26.13.67:443",
                                         "ts": 1691877594578
                                         "message": "getMe (reconnect #10) Error:Error: EFATAL: Error: connect ECONNREFUSED 149.154.167.220:443",
                                         "ts": 1691877586178
                                         "message": "getMe (reconnect #0) Error:Error: EFATAL: Error: connect ECONNREFUSED 149.154.167.220:443",
                                         "ts": 1691877576053
                                         "severity": "warn",
                                         "message": "polling_error: EFATAL, EFATAL: Error: read ECONNRESET",
                                         "ts": 1691877576024
                                         "severity": "warn",
                                         "from": "admin.0",
                                         "message": "[3 Einträge] Alias alias.0.LP_Senden.Info has no target 12",
                                         "ts": 1691865596912
                                         "from": "host.raspi4gb",
                                         "message": "Invalid request getRepository. \"callback\" or \"from\" is null",
                                         "ts": 1691865034664
                                         "message": "[7 Einträge] Request error: Error: connect ECONNREFUSED 192.168.1.14:8087",
                                         "ts": 1691864888570
                                         "message": "[293 Einträge] Request error: Error: read ECONNRESET",
                                         "ts": 1691864490028
                                         "severity": "warn",
                                         "message": "[26 Einträge] LP_jsonWarn_senden: {'errno':-104,'code':'ECONNRESET','syscall':'read'}",
                                         "ts": 1691864490027
                                         "severity": "warn",
                                         "from": "admin.0",
                                         "ts": 1691862708532
                                         "message": "[7 Einträge] SyntaxError: missing ) after argument list",
                                         "ts": 1691861229150
                                         "message": "[3 Einträge] LP_jsonWarn_senden:6",
                                         "ts": 1691861229148
                                         "message": "[2 Einträge] LP_jsonWarn_senden:26:9)",
                                         "ts": 1691861220005
                                         "message": "[2 Einträge] LP_jsonWarn_senden: TypeError: Cannot read properties of undefined (reading 'replace')",
                                         "ts": 1691861220004
                                         "severity": "warn",
                                         "message": "Test_API:3:3",
                                         "ts": 1691860628260
                                         "severity": "warn",
                                         "message": "[2 Einträge] Test_API:1:12",
                                         "ts": 1691860628260
                                         "severity": "warn",
                                         "message": "[2 Einträge] getState \"logparser.0.filters.WarAndError.json\" not found (3)",
                                         "ts": 1691860628259
                                         "severity": "warn",
                                         "message": "Test_API:2:3",
                                         "ts": 1691860571410
                                         "message": "at Script.runInContext (node:vm:141:12)",
                                         "ts": 1691856265304
                                         "message": "Test_API:10:3",
                                         "ts": 1691856265303
                                         "message": "Test_API:2:96",
                                         "ts": 1691856265303
                                         "message": "Test_API: ReferenceError: jsonWar is not defined",
                                         "ts": 1691856265303
                                         "severity": "warn",
                                         "message": "[5 Einträge] LP_jsonInfo_senden: wled unten nicht erreichbar!ReferenceError: json is not defined",
                                         "ts": 1691852250006
                                         "message": "[2 Einträge] SyntaxError: Identifier 'json' has already been declared",
                                         "ts": 1691851613182
                                         "message": "[2 Einträge] ^",
                                         "ts": 1691851613182
                                         "message": "[7 Einträge] LP_jsonInfo_senden:19",
                                         "ts": 1691851613181
                                         "ts": 1691851551115
                                         "message": "[5 Einträge] LP_jsonInfo_senden:37:9)",
                                         "ts": 1691851550005
                                         "message": "[5 Einträge] LP_jsonInfo_senden:14:5)",
                                         "ts": 1691851550005
                                         "message": "[5 Einträge] replace is not a function",
                                         "ts": 1691851550004
                                         "message": "[2 Einträge] SyntaxError: Cannot use import statement outside a module",
                                         "ts": 1691846703724
                                         "message": "[2 Einträge] ^^^^^^",
                                         "ts": 1691846703724
                                         "message": "[2 Einträge] import axios from \"axios\";",
                                         "ts": 1691846703723
                                         "message": "[6 Einträge] LP_jsonInfo_senden:3",
                                         "ts": 1691846703723
                                         "message": "[2 Einträge] LP_jsonInfo_senden:16:44)",
                                         "ts": 1691845140012
                                         "message": "[4 Einträge] LP_jsonInfo_senden: ReferenceError: value is not defined",
                                         "ts": 1691845140012
                                         "message": "[2 Einträge] LP_jsonInfo_senden:13:5)",
                                         "ts": 1691845140007
                                         "message": "[2 Einträge] LP_jsonInfo_senden:19:68)",
                                         "ts": 1691845140006
                                         "message": "[3 Einträge] SyntaxError: Identifier 'encodedData' has already been declared",
                                         "ts": 1691845057530
                                         "message": "[10 Einträge] ^",
                                         "ts": 1691845057530
                                         "message": "async function encodedData(ip, dp, encodedData) {",
                                         "ts": 1691845057530
                                         "message": "[3 Einträge] LP_jsonInfo_senden:18",
                                         "ts": 1691845057529
                                         "message": "[2 Einträge] async function encodedData(ip, dp, value) {",
                                         "ts": 1691845030381
                                         "severity": "warn",
                                         "from": "admin.0",
                                         "ts": 1691843720523
                                         "message": "[4 Einträge] postJson(192.168.1.14:8087, 0_userdata.0.LogParser_Raspi4.HomeMatic.json, logparser.0.filters.Homema",
                                         "ts": 1691842834490
                                         "message": "[9 Einträge] LP_jsonInfo_senden:13",
                                         "ts": 1691842834490
                                         "message": "[6 Einträge] LP_jsonInfo_senden:36:9)",
                                         "ts": 1691842090005
                                         "message": "[6 Einträge] LP_jsonInfo_senden:17:53)",
                                         "ts": 1691842090005
                                         "message": "[6 Einträge] at JSON.parse ()",
                                         "ts": 1691842090005
                                         "message": "[6 Einträge] LP_jsonInfo_senden: SyntaxError: Unexpected token l in JSON at position 0",
                                         "ts": 1691842090004
                                         "message": "[2 Einträge] LP_jsonInfo_senden:13",
                                         "ts": 1691841992150
                                         "message": "postJson(192.168.1.14, 0_userdata.0.LogParser_Raspi4.HomeMatic.json, logparser.0.filters.Homematic.j",
                                         "ts": 1691841949930
                                         "message": "SyntaxError: Unexpected number",
                                         "ts": 1691841668371
                                         "message": "async function postJson(192.168.1.14:8087, logparser.0.filters.Homematic.json, value) {",
                                         "ts": 1691841668370
                                         "message": "LP_jsonInfo_senden:16",
                                         "ts": 1691841668369
                                         "severity": "warn",
                                         "from": "admin.0",
                                         "ts": 1691841573977
                                         "message": "resolve(\"Beispiel\"\");",
                                         "ts": 1691840295831
                                         "message": "LP_jsonInfo_senden_neu:39",
                                         "ts": 1691840295830
                                         "message": "[3 Einträge] LP_jsonInfo_senden_neu: Fehler beim Übertragen der Daten an das Zielsystem:",
                                         "ts": 1691840290009
                                         "message": "WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the no",
                                         "ts": 1691839799660
                                         "message": "[2 Einträge] npm",
                                         "ts": 1691839799658
                                         "severity": "warn",
                                         "from": "admin.0",
                                         "message": "[2 Einträge] Alias alias.0.LP_Senden.WarnAndError has no target 9",
                                         "ts": 1691838260105
                                         "severity": "warn",
                                         "message": "[2 Einträge] Alias alias.0.LP_Senden.WarnAndError has no target 12",
                                         "ts": 1691838260089
                                         "severity": "warn",
                                         "message": "Alias alias.0.LP_Senden.WarnAndError has no target 12",
                                         "ts": 1691838260086
                                         "severity": "warn",
                                         "from": "admin.0",
                                         "ts": 1691838247232
                                         "severity": "warn",
                                         "message": "[2 Einträge] Alias alias.0.LP_Senden.Info has no target 9",
                                         "ts": 1691838246574
                                         "severity": "warn",
                                         "ts": 1691838246556
                                         "severity": "warn",
                                         "message": "Alias alias.0.LP_Senden.Info has no target 12",
                                         "ts": 1691838246554
                                         "severity": "warn",
                                         "from": "admin.0",
                                         "message": "cannot subscribe on alias \"alias.0.LP_Senden.HomeMatic\": Alias alias.0.LP_Senden.HomeMatic has no ta",
                                         "ts": 1691838225030
                                         "severity": "warn",
                                         "from": "admin.0",
                                         "message": "[2 Einträge] Alias alias.0.LP_Senden.HomeMatic has no target 12",
                                         "ts": 1691838225027
                                      Das sieht schon mal sehr gut aus. Dann habe ich mit diesem Script die Daten übertragen:
                                      // WarnAndError
                                      let jsonWar = getState("0_userdata.0.LP_JSON.Warn_JSON").val;
                                      // WarnAndError
                                      Was dann ankommt, ist nur ein Teil der Daten und die sind wieder irgendwie kaputt:
                                      [{"date":"13.08.2023","severity":"warn","from":"javascript.0","message":"[21 Einträge] at processTimers (node:internal/timers:512:7)","ts":1691909930020},{"date":"13.08.2023","severity":"warn","from":"javascript.0","message":"[21 Einträge] at listOnTimeout (node:internal/timers:569:17)","ts":1691909930019},{"date":"13.08.2023","severity":"warn","from":"javascript.0","message":"[21 Einträge] at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib","ts":1691909930019},{"date":"13.08.2023","severity":"warn","from":"javascript.0","message":"[21 Einträge] at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:2","ts":1691909930019},{"date":"13.08.2023","severity":"warn","from":"javascript.0","message":"[21 Einträge] at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:","ts":1691909930018},{"date":"13.08.2023","severity":"warn","from":"javascript.0","message":"[21 Einträge] at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1606:34)","ts":1691909930018},{"date":"13.08.2023","severity":"warn","from":"javascript.0","message":"[2 Einträge] LP_Warn_kopieren:26:9)","ts":1691909930017},{"date":"13.08.2023","severity":"warn","from":"javascript.0","message":"[2 Einträge] LP_Warn_kopieren:13:5)","ts":1691909930017},{"date":"13.08.2023","severity":"warn","from":"javascript.0","message":"[2 Einträge] at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)","ts":1691909930017},{"date":"13.08.2023","severity":"warn","from":"javascript.0","message":"[2 Einträge] State \"0_userdata.0.LP_JSON.Warn_JSON?value
                                      [EDIT]
                                      Hab die Lösung gefunden. Mache es nach dem Bereinigen wie von @ticaki beschrieben mit axios und dann klappt die Übertragung und ich kann die Daten in VIS anzeigen.
                                      // das hier muß einmal im Skript stehen
                                      const axios = require("axios")
                                      // hiermit sendest du die Daten: sollte selbst erklärend sein
                                      postJson("192.168.1.14:8087", "0_userdata.0.LogParser_Raspi4.WarnAndError.json", getState("0_userdata.0.LP_JSON.Warn_JSON").val)
                                      //Das hier irgendwo unten wo es nicht stört
                                      async function postJson(ip, dp, value) {
                                      // WarnAndError
                                          try {
                                              const {data} = await axios.post('http://'+ip+'/setValueFromBody/'+dp, jsonWar, {
                                                      headers: {
                                                          "Content-Type": 'application/json'
                                          } catch(error) {
                                              console.warn('Daten nicht übertragen!' + error)
                                      Also erst mit replace bereinigen und in einen lokalen DP kopieren, dann von dort aus mit axios übertragen. Ist axios eigentlich eine Funktion, oder wie nennt man das?
                                      Gruß Johannes
                                        @jojo58 sagte: Ist axios eigentlich eine Funktion, oder wie nennt man das?
                                        Das ist ein NPM-Modul: Node-Modul, das mittels NPM installiert wird.
                                          @jojo58 sagte: in einen lokalen DP kopieren, dann von dort aus
                                          Hast Du es mal ohne den zusätzlichen DP mit Axios nach dem Bereinigen versucht?
                                          • JoJo58
                                            @paul53 Ja, gestern schon und das hat nicht funktioniert.
                                            1.2k
                                            2162
