    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Sayit-Adapter seit gestern stumm
      crunchip Forum Testing Most Active @Meister Mopper last edited by crunchip
      @meister-mopper so, läuft wieder, hab den net-tool neugestartet, jetzt spricht er wieder
      aber die Meldung bleibt
      sayit.0
      2023-08-13 19:22:47.862	error	Cannot play file: Timeout by checking of announcement finished playing
      sayit.0
      2023-08-13 19:22:47.858	error	Error while checking if chromecast.0.20dfb9c72a61.player.announcement finished playing announcement: {"url":"http://10.1.1.10:8082/sayit.0/tts.mp3?ts=1691947357341","volume":50}: TIMEOUT
      javascript.0
      2023-08-13 19:22:12.136	info	script.js.Ansagen.Wetter-Push5-test: info: DWD2 Warnung gefunden oder entfernt.RID: 1853.6084017200394
      javascript.0
      2023-08-13 19:22:12.134	info	script.js.Ansagen.Wetter-Push5-test: info: Add UWZ/DWD/ZAMG warning to database. id: 0_userdata.0.wetterwarnung.data.dwd.809471172.warning.object headline: Amtliche WARNUNG vor HITZE
      • Meister Mopper
        Meister Mopper @crunchip last edited by
        @crunchip
        Jetzt wird es spooky, habe mal ein Backup vom 30.07.2023 gestartet. Es läuft gar kein text to speak mehr.
        Irgendwie können die devices gar nicht mehr angesprochen werden.
        sayit.4	2023-08-13 19:20:51.011	error	Error while checking if chromecast.0.d4f54704fa54.player.announcement finished playing announcement: {"url":"http://192.168.178.10:8082/sayit.4/tts.mp3?ts=1691947240501","volume":40}: TIMEOUT
        sayit.4	2023-08-13 19:20:51.013	error	Cannot play file: Timeout by checking of announcement finished playing
        sayit.4	2023-08-13 19:21:02.974	error	Error: The module '/opt/iobroker/node_modules/mdns/build/Release/dns_sd_bindings.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 83. This version of Node.js requiresNODE_MODULE_VERSION 108. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
        sayit.4	2023-08-13 19:21:19.396	error	Error while checking if chromecast.0.d4f54704fa54.player.announcement finished playing announcement: {"url":"http://192.168.178.10:8082/sayit.4/tts.mp3?ts=1691947268882","volume":40}: TIMEOUT
        sayit.4	2023-08-13 19:21:19.397	error	Cannot play file: Timeout by checking of announcement finished playing
        sayit.4	2023-08-13 19:22:14.061	error	Error while checking if chromecast.0.d4f54704fa54.player.announcement finished playing announcement: {"url":"http://192.168.178.10:8082/sayit.4/tts.mp3?ts=1691947323551","volume":40}: TIMEOUT
        sayit.4	2023-08-13 19:22:14.061	error	Cannot play file: Timeout by checking of announcement finished playing
        • Meister Mopper
          @crunchip sagte in Sayit-Adapter seit gestern stumm:
          Was ist da in Franken los? 😀
            @meister-mopper muss ne alte Meldung ausn cache sein😂 heut wars gar net so warm
              @meister-mopper sagte in Sayit-Adapter seit gestern stumm:
              bei mir is der cache aus und der test Button funktioniert auch, sprachausgabe erfolgt
              edit aber wenn ich den test button in der instanz betätige erschein im log
              sayit.0
              2023-08-13 19:33:23.210	error	Error on MDNS discovery: Error: getaddrinfo -3008
              • Meister Mopper
                @crunchip
                So, bin jetzt wieder zurück auf dem aktuellen ioBroker und es funktionieren keine Sprachnachrichten.
                Stoppe ich den chromecast.0, lösche alle chromecast Objekte und starte den Adapter neu, labert meine Tante, aber nicht mit Skript.
                Es ist zum Haareraufen.
                  @meister-mopper irgendwas am Netztwerk geändert? Probleme mit unifi?
                  Meister Mopper 2 Replies Last reply Reply Quote 0
                  • Meister Mopper
                    Meister Mopper @crunchip last edited by Meister Mopper
                    @crunchip
                    Nö, wurde auch schon wegen der dns-Meldung aufmerksam, hier wird aber fleißig richtig aufgelöst (zudem 2xpihole und unbound).
                      ticaki Developer @Meister Mopper last edited by
                      @meister-mopper
                      Verstehe ich das richtig. Wenn du den Datenpunkt per Hand beschreibst geht es, aber per Blockly nicht?
                      • Meister Mopper
                        Meister Mopper @ticaki last edited by
                        @ticaki sagte in Sayit-Adapter seit gestern stumm:
                        Genau so!
                          @meister-mopper
                          Zeig mir mal den Javascript code vom Blockly
                          • Meister Mopper
                            Meister Mopper @ticaki last edited by Meister Mopper
                            @ticaki
                            sendTo("sayit.4", "say", { text: 'Testdurchsage' });
                            console.warn("Executed sayit.4: : " + 'Testdurchsage');
                            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
                              @meister-mopper
                              Da drauf klicken und den Text in codetags posten
                              https://github.com/ioBroker/ioBroker.sayit/issues/269
                                @meister-mopper
                                Dann würde ich dir empfehlen bis es wieder geht den Datenpunkt per "steuere Objekt" zu beschreiben.
                                • Meister Mopper
                                  @ticaki
                                  Ich Danke dir,
                                  das ist eine Lösung, aber auch zeitaufwändig.
                                  • Meister Mopper
                                    @crunchip
                                    So, wissen wir jetzt bescheid.
                                    Danke @ticaki
                                    FragMike 1 Reply Last reply Reply Quote 1
                                    • FragMike
                                      FragMike @Meister Mopper last edited by
                                      ich habe das beschriebene Problem seit dem 7.12.23
                                      Löschen von Datenpunkten hilft aber bei mir nicht.
                                      • Meister Mopper
                                        Meister Mopper @FragMike last edited by
                                        @fragmike sagte in Sayit-Adapter seit gestern stumm:
                                        7.12.23
                                        Hä? Was meinst du?
                                        Und was soll dies bedeuten?
                                        FragMike 1 Reply Last reply Reply Quote 0
                                        • FragMike
                                          @meister-mopper
                                          das Problem ist bei mir seit dem 23.12.23 vorhanden, dass mein Google mini stumm bleibt und dass das löschen von Datenpunkten / Objekten im Chromecast Verzeichnisse auch keine Besserung herbeiführt.
                                          Sprachausgabe funktioniert übrigens immer noch nicht 😞
                                          crunchip mcm1957 2 Replies Last reply Reply Quote 0
                                            crunchip Forum Testing Most Active @FragMike last edited by
                                            @fragmike hattest ein update gemacht auf die v3.x?
                                            sayit problem ausgabe text to speech
                                            2297
