    4. Node-Red
    5. Huawei Wechselrichter und Wallbox abfrage über Modus?
    • mickym
      mickym Most Active @mickym last edited by
      @mickym Ja das sind ja die gleichen Zahlen die ich auch habe - kannst Du mal Deine Set Node exportieren und hier in Code-tags einstellen? oder welcher Code gehört zu Deinen Set Nodes?
      HomeWolf 1 Reply Last reply Reply Quote 0
      • HomeWolf
        HomeWolf @mickym last edited by HomeWolf
        @mickym
                "id": "f9e28c9cf87b10de",
                "type": "tab",
                "label": "Carlo Gavazzi EM24 Emulator",
                "disabled": false,
                "info": "# Emulador de Carlo Gavazzi EM24</h1>\n## [www.alferez.es](https://www.alferez.es/)\n\n## Configuración\n### IP De Shelly EM\nPara configurar todo, primero hay que\nespecificar la IP del Shelly.\n\nLo primero es Editar el Http Request y\nespecificar la IP de nuestro Shelly\npara que obtenga los datos correctamente.\n\n",
                "env": []
                "id": "d85ca744fbfe6e5e",
                "type": "modbus-server",
                "z": "f9e28c9cf87b10de",
                "name": "Zähler Wallbox 502",
                "logEnabled": true,
                "hostname": "192.168.170.101",
                "serverPort": "502",
                "responseDelay": 100,
                "delayUnit": "ms",
                "coilsBufferSize": "50000",
                "holdingBufferSize": "50000",
                "inputBufferSize": "50000",
                "discreteBufferSize": "50000",
                "showErrors": true,
                "x": 510,
                "y": 660,
                "wires": [
                "id": "2b4b6dd6aa10fa59",
                "type": "comment",
                "name": "Servidor Modbus Local",
                "info": "",
                "x": 120,
                "y": 120,
                "wires": []
                "id": "ef3777476848e255",
                "type": "comment",
                "name": "Escribimos datos",
                "info": "Escribimos datos en el Servidor Node Red Local",
                "x": 740,
                "y": 720,
                "wires": []
                "id": "90bb79e977b6ca06",
                "type": "comment",
                "name": "CONFIGURACIÓN",
                "x": 110,
                "y": 40,
                "wires": []
                "id": "5144969614df4fcb",
                "type": "inject",
                "name": "Cada 5seg",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "5",
                "crontab": "",
                "once": true,
                "onceDelay": "5",
                "topic": "",
                "payload": "",
                "payloadType": "date",
                "x": 110,
                "y": 860,
                "wires": [
                        "da12bd71a288bef5",
                        "d3b9633eb916db2e",
                        "d5ee6a83d356ca80",
                        "f7c2b725c50da8ea",
                        "f006808b128050d4",
                        "38e8bbcade1c7b52",
                        "e67a5777118a7f48",
                        "e2737b712da619e9",
                        "8a1f7a09e682ebbb"
                "id": "f2a00ecdc7885bae",
                "type": "comment",
                "name": "Tomamos datos de Shelly cada 5 seg",
                "info": "",
                "x": 170,
                "y": 760,
                "wires": []
                "id": "357253f85a0b1480",
                "type": "modbus-write",
                "name": "V L1",
                "showStatusActivities": true,
                "showErrors": false,
                "showWarnings": true,
                "unitid": "1",
                "dataType": "MHoldingRegisters",
                "adr": "0",
                "quantity": "2",
                "server": "866daf61d2f53247",
                "emptyMsgOnFail": false,
                "keepMsgProperties": false,
                "delayOnStart": false,
                "startDelayTime": "",
                "x": 1150,
                "y": 1200,
                "wires": [
                "id": "f1ba4bacd50b0d30",
                "name": "A L1",
                "unitid": "1",
                "adr": "0x000C",
                "quantity": "2",
                "x": 1150,
                "y": 1420,
                "wires": [
                "id": "726cd7160ac15a5b",
                "name": "W L1",
                "unitid": "1",
                "adr": "18",
                "quantity": "2",
                "x": 1370,
                "y": 740,
                "wires": [
                "id": "45ba44771f3b7960",
                "type": "function",
                "name": "Set",
                "func": "// Para usarlo en el calculo de los Amps\nflow.set('volts1',msg.payload);\n\nvar volts=new Int32Array(2);\nvolts[0] = (msg.payload * 10).toFixed(1);\nmsg={};\nmsg.payload=volts;\nreturn msg;",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 810,
                "y": 1200,
                "wires": [
                        "357253f85a0b1480"
                "id": "e39f83c0a9afb2d9",
                "type": "function",
                "name": "Set",
                "func": "// Para usarlo en el calculo del sumatorio\nflow.set('watts1',msg.payload);\n\nvar watts=new Int32Array(2);\nwatts[0]=msg.payload.toFixed(0) * 10;\nif (watts[0] < 0 ) {\n    watts[0] = 65535 + watts[0];\n    watts[1] = 65535;\n}\nmsg={};\nmsg.payload=watts;\nreturn msg;",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 1110,
                "y": 740,
                "wires": [
                        "726cd7160ac15a5b"
                "id": "0bb77d9dcb3e2c18",
                "name": "V L2",
                "unitid": "1",
                "adr": "0x0002",
                "quantity": "2",
                "x": 1150,
                "y": 1260,
                "wires": [
                "id": "f732f84cf8c95e80",
                "name": "A L2",
                "unitid": "1",
                "adr": "0x000E",
                "quantity": "2",
                "x": 1150,
                "y": 1480,
                "wires": [
                "id": "c871b67cd93a4dae",
                "name": "W L2",
                "unitid": "1",
                "adr": "0x0014",
                "quantity": "2",
                "x": 1150,
                "y": 940,
                "wires": [
                "id": "a6d1ff1ddb1ff686",
                "type": "function",
                "name": "Set",
                "func": "// Para usarlo en el calculo de los Amps\nflow.set('volts2',msg.payload);\n\nvar volts=new Int32Array(2);\nvolts[0] = (msg.payload * 10).toFixed(1);\nmsg={};\nmsg.payload=volts;\nreturn msg;",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 810,
                "y": 1260,
                "wires": [
                        "0bb77d9dcb3e2c18"
                "id": "77bf9e0a52e514da",
                "type": "function",
                "name": "Set",
                "func": "// Para usarlo en el calculo de los Amps\nflow.set('amps2', msg.payload);\n\nvar amps = new Int32Array(2);\namps[0] = (msg.payload * 1000).toFixed(1);\nmsg = {};\nmsg.payload = amps;\nreturn msg;",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 810,
                "y": 1480,
                "wires": [
                        "f732f84cf8c95e80"
                "id": "d7f09fa1e5fb4b47",
                "type": "function",
                "name": "Set",
                "func": "// Para usarlo en el calculo del sumatorio\nflow.set('watts2',msg.payload);\n\nvar watts=new Int32Array(2);\nwatts[0]=msg.payload.toFixed(0) * 10;\nif (watts[0] < 0 ) {\n    watts[0] = 65535 + watts[0];\n    watts[1] = 65535;\n}\nmsg={};\nmsg.payload=watts;\nreturn msg;",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 990,
                "y": 940,
                "wires": [
                        "c871b67cd93a4dae"
                "id": "9469e19eb6011e9f",
                "name": "V L3",
                "unitid": "1",
                "adr": "0x0004",
                "quantity": "2",
                "x": 1150,
                "y": 1320,
                "wires": [
                "id": "b01d0ff5d7fdb1bb",
                "name": "A L3",
                "unitid": "1",
                "adr": "0x0010",
                "quantity": "2",
                "x": 1150,
                "y": 1540,
                "wires": [
                "id": "989321cef997cfbf",
                "name": "W L3",
                "unitid": "1",
                "adr": "0x0016",
                "quantity": "2",
                "x": 1150,
                "y": 1060,
                "wires": [
                        "e36f090eabbf2753"
                "id": "8de4fd13347b532c",
                "type": "function",
                "name": "Set",
                "func": "// Para usarlo en el calculo de los Amps\nflow.set('volts3',msg.payload);\n\nvar volts=new Int32Array(2);\nvolts[0] = (msg.payload * 10).toFixed(1);\nmsg={};\nmsg.payload=volts;\nreturn msg;",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 810,
                "y": 1320,
                "wires": [
                        "9469e19eb6011e9f"
                "id": "dbaf70c0429a6671",
                "type": "function",
                "name": "Set",
                "func": "// Para usarlo en el calculo del sumatorio\nflow.set('watts3',msg.payload);\n\nvar watts=new Int32Array(2);\nwatts[0]=msg.payload.toFixed(0) * 10;\nif (watts[0] < 0 ) {\n    watts[0] = 65535 + watts[0];\n    watts[1] = 65535;\n}\nmsg={};\nmsg.payload=watts;\nreturn msg;",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 990,
                "y": 1060,
                "wires": [
                        "989321cef997cfbf"
                "id": "e36f090eabbf2753",
                "type": "function",
                "name": "Sum",
                "func": "var watts1=flow.get('watts1');\nvar watts2=flow.get('watts2');\nvar watts3=flow.get('watts3');\nvar watts = new Int32Array(2);\n\nwatts[0]=(watts1.toFixed(0) * 10 ) + (watts2.toFixed(0) * 10) + (watts3.toFixed(0) * 10);\nif (watts[0] < 0 ) {\n    watts[0] = 65535 + watts[0];\n    watts[1] = 65535;\n}\nmsg = {payload: watts};\n\nreturn msg;",
                "outputs": 2,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 1370,
                "y": 1060,
                "wires": [
                        "6ae219f0a7358252"
                "id": "6ae219f0a7358252",
                "name": "Sum Watts",
                "unitid": "1",
                "adr": "40",
                "quantity": "2",
                "x": 1590,
                "y": 1060,
                "wires": [
                "id": "2fb89b6c5276c576",
                "type": "function",
                "name": "Set",
                "func": "// Para usarlo en el calculo del sumatorio\n//flow.set('twatts1',msg.payload);\n\nvar twatts=new Int32Array(2);\nvar valor = (parseInt(msg.payload / 100)).toString(2).padStart(32, '0');\n\nvar twatts = new Int32Array(2);\ntwatts[0] = parseInt(valor.substring(16, 32), 2);\ntwatts[1] = parseInt(valor.substring(0, 16), 2);\n\nmsg = { payload: twatts};\nreturn msg;",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 1110,
                "y": 780,
                "wires": [
                        "f0e7d6179e37722c"
                "id": "f0e7d6179e37722c",
                "name": "Total W Energia L1",
                "unitid": "1",
                "adr": "64",
                "quantity": "2",
                "x": 1410,
                "y": 780,
                "wires": [
                "id": "f6d5913e5b967ed5",
                "type": "function",
                "name": "Set",
                "func": "// Para usarlo en el calculo del sumatorio\nflow.set('twatts2',msg.payload);\n\nvar twatts=new Int32Array(2);\ntwatts[0] = (msg.payload * 10).toFixed(0);\ntwatts[1] = 0;\nmsg={};\nmsg.payload=twatts;\nreturn msg;",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 990,
                "y": 1000,
                "wires": [
                        "d95420a974d4a870"
                "id": "d95420a974d4a870",
                "name": "Total W L2",
                "unitid": "1",
                "adr": "0x0042",
                "quantity": "2",
                "x": 1170,
                "y": 1000,
                "wires": [
                "id": "ed4935e8dd804b32",
                "type": "function",
                "name": "Set",
                "func": "// Para usarlo en el calculo del sumatorio\nflow.set('twatts3',msg.payload);\n\nvar twatts=new Int32Array(2);\ntwatts[0] = (msg.payload * 10).toFixed(0);\ntwatts[1] = 0;\nmsg={};\nmsg.payload=twatts;\nreturn msg;",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 990,
                "y": 1120,
                "wires": [
                        "cec58ed8e2357f6c"
                "id": "cec58ed8e2357f6c",
                "name": "Total W L3",
                "unitid": "1",
                "adr": "0x0044",
                "quantity": "2",
                "x": 1170,
                "y": 1120,
                "wires": [
                "id": "da12bd71a288bef5",
                "type": "ioBroker get",
                "name": "Hausanschluss_L1_Leistung",
                "topic": "hm-rega.0.28633",
                "attrname": "payload",
                "payloadType": "value",
                "errOnInvalidState": "nothing",
                "x": 480,
                "y": 820,
                "wires": [
                        "48e7ed7b6861dcd8",
                        "b06d7b007aaab749",
                        "1ce212f0c79db925",
                        "ab1234a45e0a8774"
                "id": "d3b9633eb916db2e",
                "name": "Hausanschluss_L2_Leistung",
                "topic": "hm-rega.0.28634",
                "x": 480,
                "y": 940,
                "wires": [
                        "be40508b6446758d",
                        "e825cf7e813c968f"
                "id": "d5ee6a83d356ca80",
                "name": "Hausanschluss_L3_Leistung",
                "topic": "hm-rega.0.28635",
                "x": 480,
                "y": 1060,
                "wires": [
                        "22cce512d3b2647d",
                        "336a68b856c72ad5"
                "id": "f7c2b725c50da8ea",
                "name": "Hausanschluss_L1_Spannung",
                "topic": "hm-rega.0.27680",
                "x": 490,
                "y": 1200,
                "wires": [
                        "45ba44771f3b7960"
                "id": "f006808b128050d4",
                "name": "Hausanschluss_L2_Spannung",
                "topic": "hm-rega.0.27681",
                "x": 490,
                "y": 1260,
                "wires": [
                        "a6d1ff1ddb1ff686"
                "id": "38e8bbcade1c7b52",
                "name": "Hausanschluss_L3_Spannung",
                "topic": "hm-rega.0.27682",
                "x": 490,
                "y": 1320,
                "wires": [
                        "8de4fd13347b532c"
                "id": "e67a5777118a7f48",
                "name": "Hausanschluss_L1_Strom",
                "topic": "hm-rega.0.28488",
                "x": 470,
                "y": 1420,
                "wires": [
                        "7d5ed3eec5a6f49b"
                "id": "e2737b712da619e9",
                "name": "Hausanschluss_L2_Strom",
                "topic": "hm-rega.0.28489",
                "x": 470,
                "y": 1480,
                "wires": [
                        "77bf9e0a52e514da"
                "id": "8a1f7a09e682ebbb",
                "name": "Hausanschluss_L3_Strom",
                "topic": "hm-rega.0.28490",
                "x": 470,
                "y": 1540,
                "wires": [
                        "a1d8e8a15e2c8b36"
                "id": "7d5ed3eec5a6f49b",
                "type": "function",
                "name": "Set",
                "func": "// Para usarlo en el calculo de los Amps\nflow.set('amps1',msg.payload);\n\nvar amps=new Int32Array(2);\namps[0] = (msg.payload * 1000).toFixed(1);\nmsg={};\nmsg.payload=amps;\nreturn msg;",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 810,
                "y": 1420,
                "wires": [
                        "f1ba4bacd50b0d30"
                "id": "a1d8e8a15e2c8b36",
                "type": "function",
                "name": "Set",
                "func": "// Para usarlo en el calculo de los Amps\nflow.set('amps3', msg.payload);\n\nvar amps = new Int32Array(2);\namps[0] = (msg.payload * 1000).toFixed(1);\nmsg = {};\nmsg.payload = amps;\nreturn msg;",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 810,
                "y": 1540,
                "wires": [
                        "b01d0ff5d7fdb1bb"
                "id": "7d11db7b00d54855",
                "type": "comment",
                "name": "Inicializamos al arrancar",
                "info": "",
                "x": 130,
                "y": 220,
                "wires": []
                "id": "f232b0e3864ad187",
                "type": "inject",
                "name": "Inicializar",
                "props": [
                        "p": "payload"
                "repeat": "",
                "crontab": "",
                "once": true,
                "onceDelay": "10",
                "topic": "",
                "x": 320,
                "y": 260,
                "wires": [
                        "eb42043ba8794be0"
                "id": "ad19ee6e1b2b9c99",
                "name": "Modelo",
                "showErrors": true,
                "unitid": "1",
                "dataType": "HoldingRegister",
                "adr": "11",
                "quantity": "1",
                "x": 700,
                "y": 160,
                "wires": [
                "id": "ce5f9aa72c6c4d0e",
                "name": "HW Version",
                "showErrors": true,
                "unitid": "1",
                "adr": "777",
                "quantity": "1",
                "x": 710,
                "y": 200,
                "wires": [
                "id": "78815d56e051e3cc",
                "name": "FW Version",
                "showErrors": true,
                "unitid": "1",
                "adr": "772",
                "quantity": "1",
                "x": 710,
                "y": 240,
                "wires": [
                "id": "198a6465eb033dbe",
                "name": "PH Config",
                "showErrors": true,
                "unitid": "1",
                "adr": "4098",
                "quantity": "1",
                "x": 710,
                "y": 280,
                "wires": [
                "id": "caf897d25cd3dcc5",
                "name": "Serial",
                "showErrors": true,
                "unitid": "1",
                "adr": "20480",
                "quantity": "7",
                "x": 690,
                "y": 320,
                "wires": [
                "id": "e3b112ed6ea41956",
                "name": "ShitchPos",
                "showErrors": true,
                "unitid": "1",
                "adr": "41216",
                "quantity": "1",
                "x": 700,
                "y": 360,
                "wires": [
                "id": "eb42043ba8794be0",
                "type": "function",
                "name": "Definiciones",
                "func": "var data1 = { payload: 1648 };\nvar data2 = { payload: 0x101E };\nvar data3 = { payload: 3 };\nvar data4 = { payload: [22359,22320,16716,17989,21061,23088,17747]};\nvar data5 = { payload: 0x1 };\nvar data6 = { paload: 7 }\nreturn [data1, data2, data3, data4, data5, data6];",
                "outputs": 6,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 470,
                "y": 260,
                "wires": [
                        "ad19ee6e1b2b9c99"
                        "ce5f9aa72c6c4d0e",
                        "78815d56e051e3cc"
                        "198a6465eb033dbe"
                        "caf897d25cd3dcc5"
                        "e3b112ed6ea41956"
                        "0f20e509b80dc879"
                "id": "0f20e509b80dc879",
                "name": "Aplication",
                "showErrors": true,
                "unitid": "1",
                "dataType": "MCoils",
                "adr": "40960",
                "quantity": "1",
                "x": 700,
                "y": 400,
                "wires": [
                "id": "48e7ed7b6861dcd8",
                "type": "change",
                "name": "Watt => Kilowatt",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "payload / 1000",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 890,
                "y": 780,
                "wires": [
                        "2fb89b6c5276c576"
                "id": "ef90c94a09aa51df",
                "type": "buffer-maker",
                "name": "",
                "specification": "spec",
                "specificationType": "ui",
                "items": [
                        "name": "item1",
                        "type": "floatbe",
                        "length": 1,
                        "dataType": "msg",
                        "data": "payload"
                "swap1": "",
                "swap2": "",
                "swap3": "",
                "swap1Type": "swap",
                "swap2Type": "swap",
                "swap3Type": "swap",
                "msgProperty": "payload",
                "msgPropertyType": "str",
                "x": 1010,
                "y": 820,
                "wires": [
                        "64099d52a0a6f579",
                        "364501a42aeddf1a"
                "id": "64099d52a0a6f579",
                "type": "buffer-parser",
                "name": "",
                "data": "payload",
                "dataType": "msg",
                "items": [
                        "type": "uint16be",
                        "name": "item1",
                        "offset": 0,
                        "length": 1,
                        "offsetbit": 0,
                        "scale": "1",
                        "mask": ""
                        "type": "uint16be",
                        "name": "item2",
                        "offset": 2,
                        "length": 1,
                        "offsetbit": 0,
                        "scale": "1",
                        "mask": ""
                "swap1": "",
                "swap2": "",
                "swap3": "",
                "resultType": "value",
                "resultTypeType": "return",
                "multipleResult": false,
                "fanOutMultipleResult": false,
                "setTopic": true,
                "outputs": 1,
                "x": 1190,
                "y": 820,
                "wires": [
                        "6936fa4769127b7a"
                "id": "b06d7b007aaab749",
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 890,
                "y": 740,
                "wires": [
                        "e39f83c0a9afb2d9"
                "id": "be40508b6446758d",
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 810,
                "y": 940,
                "wires": [
                        "d7f09fa1e5fb4b47"
                "id": "e825cf7e813c968f",
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 810,
                "y": 1000,
                "wires": [
                        "f6d5913e5b967ed5"
                "id": "22cce512d3b2647d",
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 810,
                "y": 1060,
                "wires": [
                        "dbaf70c0429a6671"
                "id": "336a68b856c72ad5",
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 810,
                "y": 1120,
                "wires": [
                        "ed4935e8dd804b32"
                "id": "6936fa4769127b7a",
                "type": "debug",
                "name": "debug 1",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "complete": "false",
                "statusVal": "",
                "statusType": "auto",
                "x": 1420,
                "y": 880,
                "wires": []
                "id": "1ce212f0c79db925",
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 810,
                "y": 820,
                "wires": [
                        "ef90c94a09aa51df",
                        "c0435f080e3937a1"
                "id": "364501a42aeddf1a",
                "type": "debug",
                "name": "debug 2",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 1200,
                "y": 880,
                "wires": []
                "id": "c0435f080e3937a1",
                "type": "debug",
                "name": "debug 3",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 1000,
                "y": 880,
                "wires": []
                "id": "ab1234a45e0a8774",
                "type": "debug",
                "name": "debug 4",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 780,
                "y": 880,
                "wires": []
                "id": "866daf61d2f53247",
                "type": "modbus-client",
                "name": "Wallbox",
                "clienttype": "tcp",
                "bufferCommands": true,
                "stateLogEnabled": true,
                "queueLogEnabled": true,
                "failureLogEnabled": false,
                "tcpHost": "192.168.170.101",
                "tcpPort": "502",
                "tcpType": "DEFAULT",
                "serialPort": "/dev/ttyUSB",
                "serialType": "RTU-BUFFERD",
                "serialBaudrate": "9600",
                "serialDatabits": "8",
                "serialStopbits": "1",
                "serialParity": "none",
                "serialConnectionDelay": "100",
                "serialAsciiResponseStartDelimiter": "0x3A",
                "unit_id": "1",
                "commandDelay": "1",
                "clientTimeout": "1000",
                "reconnectOnTimeout": true,
                "reconnectTimeout": "2000",
                "parallelUnitIdsAllowed": true
        [/s]
        • mickym
          mickym Most Active last edited by mickym
          OK - so gehts
          Nee so wie vorher wars besser - aber ich habs schon.
          Sehr gut 🙂
          HomeWolf mickym 2 Replies Last reply Reply Quote 0
          • HomeWolf
            @mickym 😄 Deine für deine Geduld... hat ein bisschen gedauert 😄
            • mickym
              @mickym Also wie gesagt - ich kanns im Moment nicht so richtig nachvollziehen - aber die Set Nodes haben unterschiedlichen Code - das ist eigentlich ein NoGo - zumindest um das nachzuvollziehen.
              Oben ist Debug 100 und unten Debug 101 - welcher funktioniert nun?
              • mickym
                Falls diese komische Array - als String intern konvertiert wird prüfe doch mal ob Du mit einer Inject Node mit einem richtigen Array ebenfalls funktioniert.
                Also
                Probiere mal direkt mit einer Inject Node in die Modbus Node zu schreiben, ob das gleiche Ergebnis rauskommt.
                        "id": "8befce9809d19c32",
                        "type": "inject",
                        "name": "",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "Array",
                        "payload": "[10,0]",
                        "payloadType": "json",
                        "x": 1510,
                        "y": 660,
                        "wires": [
                                "726cd7160ac15a5b"
                • HomeWolf
                  HomeWolf last edited by
                  @mickym
                  Also ich habe es jetzt mal auf den Anfang zurück gebaut. Über geben wird an W L1 1499,0 und an Total W Engere L1 14,0. Das Ergebnis an der Wallbox ist 149,90 KW. Somit würde ich sagen ist W L1 der ausschlag gebende
                  • HomeWolf
                    @mickym
                    wenn ich [1000,0] eingebe, kommt 100,00 kw raus...
                    • mickym
                      mickym Most Active @HomeWolf last edited by
                      @homewolf In die Inject -Node?
                      • HomeWolf
                        @mickym
                        jap, also da wo du die 10 eingetragen hattest..
                        • mickym
                          @homewolf Ok - dann passt das zumindest dass das Intern wieder als nummerisches Array behandelt wird. Das Komma in dem String halt also nichts mit einem Dezimalkomma zu tun - sondern separiert die beiden Array Werte. In Modbus schreibst Du in regel 2 unsigned Integer.
                          • HomeWolf
                            @mickym
                            wenn wir vorne das Change weg machen, bekommen wir den Wert nicht hinter der Funktion durch 1000 gesetzt, so das das kommen bleibt?
                            • mickym
                              mickym Most Active @HomeWolf last edited by mickym
                              @homewolf Das Problem ist, dass die Register nur mit Integerwerten arbeitet und nicht mit Floats. Solange Du also 1499 eingibst hast Du kein Problem. Aber 1,499 ist eben nicht darstellbar sondern wird als Integer behandelt.
                              Was diese Zeile macht
                              ist folgendes. Wenn Du 1.499 eingibst - wird das ganze gerundet ohne Dezimalstellen (toFixed(0)). Also auf 1 und dann mit 10 mulitpliziert.
                              Bei 1499 gibts keine Kommastellen und es wird einfach mit 10 multipiziert. also 14990. Deshalb kommt da 149,90 kW raus.
                              Wenn wir also 1,49kw haben wollen bzw. 1,5 kW also 1,499 auf 2 Kommastellen gerundet dann müssen wir 150 eingeben. Trotzdem werden wir ggf. Probleme bekommen. Aber ich versuchs mal mit 150 - Also 1499/1000 auf 2 Kommastellen gerundet und dann *100 - Allerdings komme ich mit dem Array noch nicht klar.
                              • mickym
                                So ich weiß zwar nicht warum bei Dir das Integer nun le und nicht be ist aber so müsste die Umrechnung funktionieren:
                                       "id": "495d7f363e304f9d",
                                       "name": "",
                                       "data": "payload",
                                       "dataType": "msg",
                                       "items": [
                                               "type": "uint16le",
                                               "name": "item1",
                                               "offset": 0,
                                               "length": 1,
                                               "offsetbit": 0,
                                               "scale": "1",
                                               "mask": ""
                                               "type": "uint16le",
                                               "name": "item2",
                                               "offset": 2,
                                               "length": 1,
                                               "offsetbit": 0,
                                               "scale": "1",
                                               "mask": ""
                                       "swap1": "",
                                       "swap2": "",
                                       "swap3": "",
                                       "setTopic": true,
                                       "outputs": 1,
                                       "x": 1350,
                                       "y": 980,
                                       "wires": [
                                               "009c970f692bf59f"
                                       "id": "c326ce521b2cc006",
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "$round(payload / 1000,2)*100",
                                               "tot": "jsonata"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 960,
                                       "y": 980,
                                       "wires": [
                                               "9fc019d1c2bc52cc"
                                       "id": "9fc019d1c2bc52cc",
                                       "name": "",
                                       "items": [
                                               "name": "item1",
                                               "type": "int32le",
                                               "length": 1,
                                               "dataType": "msg",
                                               "data": "payload"
                                       "swap1": "",
                                       "swap2": "",
                                       "swap3": "",
                                       "x": 1170,
                                       "y": 980,
                                       "wires": [
                                               "495d7f363e304f9d"
                                Die 3 Nodes zwischen die iobroker Node und die Modbus Node klemmen. Warum das eine le und das andere be ist - keine Ahnung vielleicht ist das Hardwareabhängig.
                                Sprich die Nachkommastellen werden automatisch von der Hardware auf 2 Nachkommastellen fix interpretiert.
                                Die Summierungsfunktion ist für mich Schwachsinn. Da musst Du meines Erachtens mal schauen, ob das überhaupt Sinn macht.
                                • HomeWolf
                                  @mickym
                                  klappt super... danke dir... musste nur change aus der 100 eine 10 machen, da er sonst bei 1230 W 123,0 übergeben hat, also 12,3 kW - Übergeben muss er aber ja 12,0 also 1,2 kw. Eine Frage hätte ich noch, haben wir auch die Möglichkeit, dass er 12,3 übergibt? Also das der Zähler 1,23 kw übergeben bekommt und nicht 1,20 kw ... die 30 W hat zwar keinerlei ausgefragt, bei der Regelung, ging mehr mir um die Optik 😄 und das Verständnis.
                                  Ja die Summieren ist für die aktuelle Leistung zu übergeben, damit die Wallbox entscheiden kann, was Sie nun macht.
                                  Also es kann ja sein, dass W 1 -3,00 KW ist, aber W 2 1,5 KW und W 3 1,5KW ist, da die Wallbox bei -1,4 kW anfängt zu laden, würde Sie jetzt Laden, da wenn keine gesamt W vorhanden ist, Sie immer nur W 1 betrachtet. aber W gesamt wäre ja 0 kw. gibt es denn noch eine andere Version die Werte zu addieren? Ich mein ich kann das auch in meiner Homematic direkt addieren lassen und den Wert übergeben, aber mir geht es ja auch darum möglichst viel in Node Red zu verstehen.
                                  • mickym
                                    @homewolf So mal langsam wie berechnest Du was? ich dachte das Teil macht aus 123 eine 1,23 kW. Wie schaut denn jetzt Deine Formel aus in der Change Node?
                                    Nochmal Modbus verarbeitet nur ganze Zahlen und keine Floats. Wenn er aus 123 nicht 1,23 macht, was ich eigentlich dachte - dann verstehe ich das ganze Ding nicht mehr.
                                    Wenn Du aus meiner Formel hinten nur *10 machst, dann steht da nicht mehr 123 sondern 12,3 und das GEHT nicht - da KEINE Ganzzahl.
                                    Deine ursprüngliche Funktion:
                                    watts[0]=msg.payload.toFixed(0) * 10; hat auch nichts anderes gemacht. Dieser Teil
                                    erzeugt nur GANZZahlen also 0 Dezimalkommastellen.
                                    Somit würde das Teil nur EINE Dezimalkommastelle verstehen. Dann würde ich die Formel in der Change Node aber anders umbauen, dass sie noch verständlich ist.
                                    $round(payload / 1000,1)*10
                                    so wird die errechnete kW auf 1 Nachkommastelle gerundet und dann mal 10 genommen. Wenn Du einfach nur mal 10 anstelle mal 100 nimmst, dann wird alles hinten einfach abgeschnitten aber nicht mehr ordnungsgemäß gerundet.
                                    • mickym
                                      @homewolf sagte in Huawei Wechselrichter und Wallbox abfrage über Modus?:
                                      So erst mal aus Deinem ursprünglichen Flow - diese beiden Set Nodes machen exakt das gleiche - weshalb sie unsinnig sind.
                                      Der einzige Unterschied ist, dass die ursprüngliche payload in die Flowvariable twatts anstelle von watts geschrieben wird. Und die Summe wurde dann aus twatts in der 1 verwendet. Das Teil hat also im 1. Teil überhaupt nichts aufsummiert, sondern nur den Ursprungswert in eine Flowvariable geschrieben. Diese wurde aber später nie verwendet - ich sehe sie nicht?
                                      Ich verstehe dass nun zwar und finde es mit den function Nodes nicht besonders elegant - aber dann ist es am wirklich am Einfachsten, was wir bereits hatten. Du rechnest die Watt in kW um, musst aber mit den Ungenauigkeiten leben.
                                      Dann war das doch gar nicht so schlecht:
                                      Genauer wirst Du es kaum hinbekommen. Weil nur 1 Kommastelle akzeptiert wird.
                                      Wie gesagt man kann das auch alles ohne function Nodes lösen, aber dadurch wird es ja nicht genauer.
                                      Also einfach wieder nur durch 1000 rechnen. Die Change Nodes kannst Du dann entweder mit payload/1000 belassen oder Du änderst halt deine function Nodes, wo du alle eingehenden payloads teilen musst. Dann ist aber die Lösung mit der Change Node sicher einfacher. Die aktuellen Werte siehst Du übrigens immer im Kontextfenster:
                                      • HomeWolf
                                        @mickym ook, dann muss ich mit der Differenz einfach leben.
                                        er macht aus 1234 W ->12,0 und das wird an Modbus übergeben und im gerate sind das dann 1,2 kw.
                                        Ich verzweifele noch an dieser Wallbox. Alle Daten werden laut Huawei Portal an die Wallbox übertragen. Heute Mittag, als dann genug sonne da war, hat die Wallbox sich auch wie erhofft eingeschaltet, aber leider immer nur für 20 Sekunden und dann geht sie wieder aus. und wieder an usw. Also Sie die Daten immer nur kurz bekommen würde und danach wieder Leistungen von 0 KW
                                        • mickym
                                          @homewolf hänge einfach Debug nodes hinter die Funktion Nodes und lass die Ausgabe ins iobroker Log schreiben. Dann siehst Du was in due Modbus Nodes geschrieben wird.
                                          • HomeWolf
                                            @mickym
                                            da kommt immer das gleich, von der Seite aus sieht es gut aus..
                                            14.8.2023, 19:30:27node: debug 3
                                            hm-rega.0.32538 : msg.payload : array[2]
                                            [ 65485, 65535 ]
                                            Gibt es eine Möglichkeit, bei Modbus mit zu hören? Also Überlegung war, die Wallbox wie eigentlich vorgesehen an den Wechselrichter zu hängen und dann zu schauen, welche register die Wallbox abfragt, nicht das irgend ein Register der Wallbox fehlt. oder kann ich sogar schon so sehen, wann die Wallbox bei Node Red an Registern anfragt?
                                            5713
