    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    • Jackl1st
      Jackl1st @Jackl1st last edited by
      @jackl1st sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
      @arteck
      2023-08-11 10:35:40.136 - debug: bluelink.0 (8027) Set new full status for U5YH7F15GPL143495
      2023-08-11 10:35:40.137 - debug: bluelink.0 (8027) RAW {"vehicleStatus":{"airCtrlOn":false,"engine":false,"doorLock":true,"doorOpen":{"frontLeft":0,"frontRight":0,"backLeft":0,"backRight":0},"trunkOpen":false,"airTemp":{"value":"00H","unit":0,"hvacTempType":1},"defrost":false,"lowFuelLight":false,"acc":false,"hoodOpen":false,"transCond":true,"steerWheelHeat":0,"sideBackWindowHeat":0,"dte":{"value":605,"unit":1},"tirePressureLamp":{"tirePressureLampAll":0,"tirePressureLampFL":0,"tirePressureLampFR":0,"tirePressureLampRL":0,"tirePressureLampRR":0},"seatHeaterVentState":{"frSeatHeatState":2,"flSeatHeatState":2,"rlSeatHeatState":2,"rrSeatHeatState":2},"battery":{"batSoc":81,"batState":0},"lampWireStatus":{"stopLamp":{"stopLampStatus":false,"leftLamp":false,"rightLamp":false},"headLamp":{"headLampStatus":false,"leftLowLamp":false,"rightLowLamp":false,"leftHighLamp":false,"rightHighLamp":false,"leftBifuncLamp":false,"rightBifuncLamp":false},"turnSignalLamp":{"turnSignalLampStatus":false,"leftFrontLamp":false,"rightFrontLamp":false,"leftRearLamp":false,"rightRearLamp":false}},"windowOpen":{"frontLeft":0,"frontRight":0,"backLeft":0,"backRight":0},"smartKeyBatteryWarning":false,"fuelLevel":85,"washerFluidStatus":false,"breakOilStatus":false,"engineOilStatus":false,"sleepModeCheck":false,"time":"20230811063536","remoteWaitingTimeAlert":{"remoteControlAvailable":1,"remoteControlWaitingTime":168,"elapsedTime":"00:54:56"},"systemCutOffAlert":0,"tailLampStatus":0,"hazardStatus":0},"odometer":{"value":146.5,"unit":1}}
      2023-08-11 10:35:40.235 - debug: roomba.0 (6658) DEBUG MISSION DATA: {"cleanMissionStatus":{"cycle":"none","phase":"charge","expireM":0,"expireTm":0,"rechrgM":0,"error":0,"notReady":0,"mssnM":0,"mssnStrtTm":0,"sqft":0,"initiator":"","nMssn":1847},"bin":{"present":true,"full":false}}
      2023-08-11 10:35:40.602 - debug: bluelink.0 (8027) Set 81 battery state for U5YH7F15GPL143495
      2023-08-11 10:35:40.611 - info: bluelink.0 (8027) Update for U5YH7F15GPL143495 successfull
      Jetzt habe ich das endlich gerafft...
        arteck Developer Most Active @Jackl1st last edited by
        ne leider seh ich die Daten da nicht.. scheint das die nicht geliefert werden
        Jackl1st 2 Replies Last reply Reply Quote 0
        • Jackl1st
          Jackl1st @arteck last edited by
          @arteck , sehe ich auch so. Bei meinem Vorgänger , dem PHEV funktionierte das noch. Da hatte ich auch den Standort. Na was solls. Danke.
            Jui last edited by Jui
            Hallo Zusammen,
            Kia / PHEV
            ich habe folgendes Problem mit dem Adapter auch mit der vorherigen und der neuen Version 2.3.6 :
            Wenn der Adapter neu gestartet ist, funktioniert der Datenabgleich fehlerfrei, Daten werden nach Plan oder per refresh eingelesen.
            Sende ich über control einen Befehl, zb. charge läuft der auch fehlerfrei durch und wird am Fahrzeug ausgeführt.
            Danach geht der Adapter quasi nicht mehr!
            Alle gesendeten Anforderungen werden mit Fehlermeldungen quittiert, die alle in etwa gleich lauten s.u.
            Wenn ich die Instanz neu starte geht der refresh wieder und bis zum ersten control Befehl auch alles, dann wieder Schluss.
            Habt Ihr eine Idee?
            Danke.
            bluelink.0
            2023-08-12 18:12:26.167	error	Error onStateChange ManagedBluelinkyError: @EuropeVehicle.startCharge: [400] Bad Request on [POST] https://prd.eu-ccapi.kia.com:8080/api/v2/spa/vehicles/XXX/control/charge - {"retCode":"F","resCode":"4002","resMsg":"Invalid request body - Invalid deviceId. ","msgId":"XXX"}
            nik82 1 Reply Last reply Reply Quote 0
            • nik82
              nik82 Most Active @Jui last edited by
              @jui
              https://forum.iobroker.net/post/1023967
                Jui @nik82 last edited by
                @nik82
                Danke, den Beitrag hatte ich nicht gefunden.
                • Jackl1st
                  @arteck , fragt sich trotzdem warum nicht. Fahrzeug ist im Adapter richtig eingestellt. Hat ja mit meinem PEHV auch funktioniert.
                    A Former User @Jackl1st last edited by
                    Frag Hyundai/Kia... die sollten es wissen.. 🙂
                    Jackl1st 1 Reply Last reply Reply Quote 0
                    • Jackl1st
                      Jackl1st @Guest last edited by Jackl1st
                      @ilovegym , gute Antwort. Ich dachte echt, kannst mal den Entwickler des Adapters fragen. Wenn man immer solch tolle Antworten bekommt, kann man auch auf gewisse Dinge verzichten.
                      nik82 ? arteck 3 Replies Last reply Reply Quote 0
                      • nik82
                        nik82 Most Active @Jackl1st last edited by
                        @jackl1st
                        Der Entwickler kann leider nur das Verarbeiten was vom Hersteller bzw. der Api kommt.
                        Wenn da nicht mehr vom Hersteller/Api kommt, dann kann der Entwickler keine Daten herbeizaubern, dann müsste man wirklich Hyundai/Kia fragen 🙂
                        Was natürlich nichts bewirken wird.
                        Aber somit war die Antwort von @ilovegym nicht falsch...
                          ja sorry aber das ist halt mal so, wenn du das genau wissen willst, dann musst du den Entwickler der Software fragen, die die Daten uebertraegt, und das ist halt mal Hyundai und nicht der Entwickler vom iobroker-Adapter.. er kann nur das, was er bekommt, umsetzen, und das wird ja einwandfrei gemacht.
                          Wenn dir meine Antworten nicht gefallen, kann ich auch nix zu.. 🙂 ich haett auch gern manches anders.. 🙂
                            @jackl1st da muss ich den 2 recht geben .. zaubern kann ich nicht
                            • Jackl1st
                              @arteck , also das hat ja auch keiner verlangt. Aber deine Aussage, das die erforderlichen Daten nicht abgerufen werden, kann ich auch aus dem log heraus lesen. Ich dachte nur, du als Entwickler, hast da ein wenig mehr Einblick, und das hast du ja auch, ist unumstritten. Deshalb berblüfft mich deine Aussage ein wenig. Und scheinbar bin ich hier der Einzigste bei dem die Koordinaten nicht übertragen werden. Sonst wären da ja vielleicht noch ein paar Meinungen dazu gekommen.
                              Aber ich schlage mal vor, das Thema hiermit zu beenden. Ich werde den Adapter nun doch deinstallieren und benutze halt die Handy App. Ende.
                                auch DE stehen ??
                                • Jackl1st
                                  @ilovegym , da ich schon mehrfach erwänt habe das das schon mein 2. Kia Xceed ist, und beim 1., einen PHEV das übertragen der GPS Daten problemlos funktioniert hat, dachte ich das jemand eine Lösung weiß. Man kann ja nie wissen. Das der Hersteller der Software dafür verantwortlich ist weiß ich auch. Braucht man eben niemanden hier im Forum unter die Nase zu reiben. Das erscheint mir wie eine Aussage wenn man eben nicht weiter weiß. Und genau so wird es sein.
                                  Lasst es gut sein, das Thema ist für mich beendet.
                                  Meister Mopper arteck 2 Replies Last reply Reply Quote -1
                                  • Meister Mopper
                                    Meister Mopper @Jackl1st last edited by
                                    @jackl1st
                                    Ändert aber nix, wenn die Server nicht das tun, was sie sollen.
                                    Kürzlich geschehen:
                                    bluelink.0	2023-08-14 19:58:18.828	error	Error on API-Request Status, ErrorCount:1
                                    Ich habe für mich längst die Fehlerquelle lokalisiert, es ist Hyundai und es sind nicht die Entwickler.
                                    Da hier alles open source ist und weitgehend profitlos abläuft ist es mir ein Bedürfnis, dich um eine gebotene gewaltlose Kommunikation zu bitten.
                                    Wer sollte denn sonst die Adapter am Leben halten? Möchtest du?
                                      @jackl1st ich hab nochmal in den Source code geschaut..deshlab meine Frage.. ob das jetzt dein erster oder 5-ter Kia ist ist mir persönlich egal. und acuh wenn du es schon zig mal geschrieben hast.. MERK ICH MIR SOWAS NICHT..SRY..
                                      paar Sachen könnten wir noch schaun .. aber so wie du dich hier verhält.. Sache ist für mich erledigt..
                                      Jackl1st 1 Reply Last reply Reply Quote 1
                                      • Jackl1st
                                        @arteck , ja so vertritt jeder seine Meinung. Falls ich mich im Ton vergriffen haben sollte, bitte ich um Entschuldigung. Aber ich hatte ja auch schon geschrieben das das Thema , inclusive Adapter, für mich erledigt ist.
                                        • Z
                                          zeron850 @Jackl1st last edited by
                                          Hallo Zusammen,
                                          ich habe die neueste Version des Bluelink Adapters von Github installiert und bei mir kommt seit heute folgende Fehlermeldung:
                                          @EuropeVehicle.status: [503] Service Unavailable on [GET] https://prd.eu-ccapi.kia.com:8080/api/v2/spa/vehicles/202da26d-xxxx/status - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"xxx"}
                                          Abrufe sind auf 3 pro Tag eingestellt. Kann mir hier jemand weiterhelfen?
                                          DANKE
                                            A Former User @zeron850 last edited by
                                            @zeron850
                                            Service unavailable- die Server haben Hitzefrei..
                                            81.1k
                                            2288
                                            853842
