    3. Off Topic
    4. Fehler /usr/lib/node_modules/npm/lib/cli.js:35 info-Adapter
    • Smizi
      Smizi @Thomas Braun last edited by
      @thomas-braun sagte in Fehler /usr/lib/node_modules/npm/lib/cli.js:35 info-Adapter:
      iob diag
      Ohh, cool, du bist noch da.
      jaein, ich versuche es ja, aber bin schaffs nicht, weil zu kein Linux Erfahrung (Mist!)
      anbei zumindest die Long-Version
      Smizi 1 Reply Last reply Reply Quote 0
      • Smizi
        Smizi @Smizi last edited by
        @smizi sagte in Fehler /usr/lib/node_modules/npm/lib/cli.js:35 info-Adapter:
        iob diag
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model		: Raspberry Pi 4 Model B Rev 1.4
        Architecture    : aarch64
        Docker          : false
        Virtualization  : none
        Distributor ID:	Debian
        Description:	Debian GNU/Linux 11 (bullseye)
        Release:	11
        Codename:	bullseye
        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
        NAME="Debian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        Systemuptime and Load:
         15:04:55 up  2:44,  1 user,  load average: 3.70, 3.98, 3.92
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=64.7'C
        volt=0.9160V
        *** Time and Time Zones ***
                       Local time: Mon 2023-08-14 15:04:56 CEST
                   Universal time: Mon 2023-08-14 13:04:56 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        Boot Target: 	multi-user.target
        *** MEMORY ***
        Mem:            7.8G        2.6G        2.9G        4.0M        2.4G        5.1G
        Swap:            99M          0B         99M
        Total:          7.9G        2.6G        3.0G
                 7811 M total memory
                 2582 M used memory
                 4259 M active memory
                  515 M inactive memory
                 2863 M free memory
                  101 M buffer memory
                 2263 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        Filesystem                     Type      Size  Used Avail Use% Mounted on
        /dev/root                      ext4      459G   31G  410G   7% /
        devtmpfs                       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs                          tmpfs     3.9G  736K  3.9G   1% /dev/shm
        tmpfs                          tmpfs     1.6G  1.2M  1.6G   1% /run
        tmpfs                          tmpfs     5.0M  4.0K  5.0M   1% /run/lock
        /dev/sdb1                      exfat      29G   32M   29G   1% /mnt/usb0
        /dev/sda1                      vfat      255M   32M  224M  13% /boot
        //192.168.1.46/Backup/ioBroker cifs      3.5T  1.9T  1.6T  55% /opt/iobroker/backups
        tmpfs                          tmpfs     782M     0  782M   0% /run/user/1000
        [Mon Aug 14 12:20:39 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:BF:9F:66 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=6d6cae10-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Mon Aug 14 12:20:41 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Aug 14 12:20:41 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Mon Aug 14 12:20:43 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET                  SOURCE                         FSTYPE OPTIONS
        /                       /dev/sda2                      ext4   rw,noatime
        |-/mnt/usb0             /dev/sdb1                      exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
        |-/boot                 /dev/sda1                      vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        `-/opt/iobroker/backups //192.168.1.46/Backup/ioBroker cifs   rw,relatime,vers=1.0,cache=strict,username=Backup,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.1.46,soft,unix,posixpaths,serverino,mapposix,acl,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
        /var:
        25G	/var/
        20G	/var/lib/influxdb/engine/data/82a2a7778d484ffc/autogen
        Archived and active journals take up 4.0G in the file system.
        /opt/iobroker/backups:
        2.0G	/opt/iobroker/backups/
        0	/opt/iobroker/backups/yahka_1.hapdata
        /opt/iobroker/iobroker-data:
        592M	/opt/iobroker/iobroker-data/
        418M	/opt/iobroker/iobroker-data/files
        129M	/opt/iobroker/iobroker-data/backup-objects
        88M	/opt/iobroker/iobroker-data/files/echarts.admin
        72M	/opt/iobroker/iobroker-data/files/telegram.admin
        35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        30M	/opt/iobroker/iobroker-data/objects.jsonl
        23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
        23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
        23M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.17.1
        /usr/bin/node 		v18.17.1
            throw err
        TypeError: Class extends value undefined is not a constructor or null
            at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/fs-minipass/lib/index.js:136:4)
            at Module._compile (node:internal/modules/cjs/loader:1256:14)
            at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
            at Module.load (node:internal/modules/cjs/loader:1119:32)
            at Module._load (node:internal/modules/cjs/loader:960:12)
            at Module.require (node:internal/modules/cjs/loader:1143:19)
            at require (node:internal/modules/cjs/helpers:121:18)
            at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/cacache/lib/content/read.js:4:13)
        Node.js v18.17.1
        /usr/bin/npm
            throw err
        Node.js v18.17.1
        /usr/bin/npx
            throw err
        Node.js v18.17.1
            throw err
        Node.js v18.17.1
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        MULTIHOSTSERVICE/enabled: false
        Core adapters versions
        js-controller: 	4.0.24
        admin: 		6.3.5
        javascript: 	7.0.3
            throw err
        Node.js v18.17.1
        Adapters from github: 	0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
        + system.adapter.bmw.0                    : bmw                   : raspberrypi                              -  enabled
        + system.adapter.bshb.0                   : bshb                  : raspberrypi                              -  enabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
        + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
          system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          system.adapter.doorbird.0               : doorbird              : raspberrypi                              -  enabled
        + system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
        + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
          system.adapter.envertech-pv.0           : envertech-pv          : raspberrypi                              -  enabled
          system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
        + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
          system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
        + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
        + system.adapter.mihome.0                 : mihome                : raspberrypi                              -  enabled, port: 9898, bind: 0.0.0.0
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
        + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
        + system.adapter.nuki.0                   : nuki                  : raspberrypi                              -  enabled
          system.adapter.oilfox.1                 : oilfox                : raspberrypi                              -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
        + system.adapter.pvoutputorg.0            : pvoutputorg           : raspberrypi                              -  enabled
        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, bind: 0.0.0.0
          system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled
        + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
        + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
        + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.withings.0               : withings              : raspberrypi                              -  enabled
        + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
        + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        default       : http://download.iobroker.net/sources-dist.json
        repro         : http://iobroker.live/repo/sources-dist.json
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.3.5    , installed 6.3.5
        Adapter    "alarm"        : 3.3.12   , installed 3.3.12
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "ble"          : 0.13.4   , installed 0.13.4
        Adapter    "bmw"          : 2.5.7    , installed 2.5.7
        Adapter    "bshb"         : 0.2.4    , installed 0.2.4
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.8  [Updatable]
        Adapter    "denon"        : 1.15.3   , installed 1.15.2 [Updatable]
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "doorbird"     : 1.0.5    , installed 1.0.5
        Adapter    "echarts"      : 1.5.1    , installed 1.5.1
        Adapter    "envertech-pv" : 1.0.2    , installed 0.1.0-alpha.0 [Updatable]
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
        Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "info"         : 1.9.26   , installed 1.9.26
        Adapter    "iot"          : 1.14.5   , installed 1.14.5
        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "nuki"         : 1.6.0    , installed 1.6.0
        Adapter    "oilfox"       : 4.1.2    , installed 4.1.2
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
        Adapter    "pvoutputorg"  : 1.8.9    , installed 1.8.8  [Updatable]
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
        Adapter    "sonos"        : 2.3.1    , installed 2.3.1
        Adapter    "synology"     : 2.1.13   , installed 2.1.13
        Adapter    "tado"         : 0.4.8    , installed 0.4.8
        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "withings"     : 0.0.13   , installed 0.0.13
        Adapter    "wled"         : 0.6.7    , installed 0.6.7
        Adapter    "yahka"        : 0.17.0   , installed 0.17.0
        Objects and States
        Objects: 	16124
        States: 	14042
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://repository.picockpit.com/raspbian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 778C2E78CFB9A731
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Failed to fetch http://repository.picockpit.com/raspbian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 778C2E78CFB9A731
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/picockpit.list:1 and /etc/apt/sources.list.d/picockpit.list:2
        W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/picockpit.list:1 and /etc/apt/sources.list.d/picockpit.list:2
        W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/picockpit.list:1 and /etc/apt/sources.list.d/picockpit.list:2
        W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/picockpit.list:1 and /etc/apt/sources.list.d/picockpit.list:2
        Hit:1 http://repository.picockpit.com/raspbian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:6 https://apt.grafana.com stable InRelease
        Get:7 https://repos.influxdata.com/debian bullseye InRelease [7040 B]
        Hit:8 https://deb.nodesource.com/node_18.x bullseye InRelease
        Err:1 http://repository.picockpit.com/raspbian bullseye InRelease
        Err:7 https://repos.influxdata.com/debian bullseye InRelease
        Fetched 7040 B in 3s (2296 B/s)
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:1883          0.0.0.0:*               LISTEN      111        12465      540/mosquitto
        tcp        0      0 0.0.0.0:33695           0.0.0.0:*               LISTEN      1001       28854      1732/io.yahka.0
        tcp        0      0 192.168.1.129:42001     0.0.0.0:*               LISTEN      1001       14000      1011/io.hm-rpc.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15329      776/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13746      776/iobroker.js-con
        tcp        0      0 0.0.0.0:41185           0.0.0.0:*               LISTEN      1001       28852      1732/io.yahka.0
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          15669      694/lighttpd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12482      543/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      998        15647      637/pihole-FTL
        tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      998        15653      637/pihole-FTL
        tcp        0      0 127.0.0.1:39059         0.0.0.0:*               LISTEN      1001       30083      1732/io.yahka.0
        tcp        0      0 127.0.0.1:43917         0.0.0.0:*               LISTEN      1001       30078      1732/io.yahka.0
        tcp6       0      0 :::80                   :::*                    LISTEN      0          15670      694/lighttpd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12484      543/sshd: /usr/sbin
        tcp6       0      0 :::53                   :::*                    LISTEN      998        15649      637/pihole-FTL
        tcp6       0      0 ::1:4711                :::*                    LISTEN      998        15654      637/pihole-FTL
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        12590      619/influxd
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27758      1672/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15784      833/io.admin.0
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16682      1134/io.sonos.0
        tcp6       0      0 ::1:1883                :::*                    LISTEN      111        12466      540/mosquitto
        tcp6       0      0 :::3000                 :::*                    LISTEN      110        15703      614/grafana-server
        udp        0      0 0.0.0.0:53              0.0.0.0:*                           998        15646      637/pihole-FTL
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15485      613/dhcpcd
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       14052      1049/io.mihome-vacu
        udp        0  13824 0.0.0.0:54058           0.0.0.0:*                           1001       2015355    1119/io.shelly.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       26484      1716/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12437      396/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       12847      1119/io.shelly.0
        udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       2391631    1072/io.mihome.0
        udp        0      0 0.0.0.0:55521           0.0.0.0:*                           108        12439      396/avahi-daemon: r
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16723      1164/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16724      1164/io.tuya.0
        udp6       0      0 :::53                   :::*                                998        15648      637/pihole-FTL
        udp6       0      0 :::45488                :::*                                108        12440      396/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        12438      396/avahi-daemon: r
        2023-08-14 15:06:54.622  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:121:18)
        2023-08-14 15:06:54.623  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/cacache/lib/content/read.js:4:13)
        2023-08-14 15:06:54.623  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
        2023-08-14 15:06:54.623  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        2023-08-14 15:06:54.623  - error: host.raspberrypi Caught by controller[0]: Node.js v18.17.1
        2023-08-14 15:06:54.628  - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/iobroker.info/main.js:89
        2023-08-14 15:06:54.628  - error: host.raspberrypi Caught by controller[0]: 		adapter.log.error("Could not check npm version: " + e);
        2023-08-14 15:06:54.628  - error: host.raspberrypi Caught by controller[0]: 		        ^
        2023-08-14 15:06:54.628  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'log')
        2023-08-14 15:06:54.629  - error: host.raspberrypi Caught by controller[0]:     at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
        2023-08-14 15:06:54.629  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
        2023-08-14 15:06:54.629  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
        2023-08-14 15:06:54.629  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        2023-08-14 15:06:54.629  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
        2023-08-14 15:06:54.629  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
        2023-08-14 15:06:54.630  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        2023-08-14 15:06:54.630  - error: host.raspberrypi Caught by controller[0]:     at node:internal/main/run_main_module:23:47
        2023-08-14 15:06:54.630  - error: host.raspberrypi Caught by controller[0]: Node.js v18.17.1
        2023-08-14 15:06:54.630  - error: host.raspberrypi instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2023-08-14 15:06:54.630  - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
        2023-08-14 15:07:00.974  - info: bshb.0 (1270) Check if client with identifier: ioBroker.bshb_f8e1effa-de6e-4e9f-9f4e-8447b26c0efd is already paired.
        2023-08-14 15:07:00.993  - info: bshb.0 (1270) Client with identifier: ioBroker.bshb_f8e1effa-de6e-4e9f-9f4e-8447b26c0efd was not paired yet.
        2023-08-14 15:07:00.994  - info: bshb.0 (1270) Start pairing. Activate pairing on Bosch Smart Home Controller by pressing button until flashing.
        2023-08-14 15:07:01.012  - warn: bshb.0 (1270) Could not pair client. Did you press the paring button? Error details: BshbError: [ERROR] error during call to BSHC:
        2023-08-14 15:07:01.013  - warn: bshb.0 (1270) Could not pair client. Did you press the paring button on Bosch Smart Home Controller? Error details: BshbError: [ERROR] error during call to BSHC:
          Thomas Braun Most Active @Smizi last edited by
          @smizi
          Spricht dein gemountetes NAS wirklich nur CIFS v1.0?
          Das ist späte Kreidezeit und sollte tunlichst vermieden werden.
          Stell das auf das höchstmögliche Protokoll ein.
          sudo apt install --reinstall nodejs
          sagt?
          • Smizi
            OK, danke für den Tip mit CIFS!
            Nodejs sagt:
            eading package lists... Done
            Building dependency tree... Done
            0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 1 not upgraded.
            Need to get 28.1 MB of archives.
            After this operation, 0 B of additional disk space will be used.
            Get:1 https://deb.nodesource.com/node_18.x bullseye/main arm64 nodejs arm64 18.17.1-deb-1nodesource1 [28.1 MB]
            Fetched 28.1 MB in 3s (10.3 MB/s)
            (Reading database ... 59608 files and directories currently installed.)
            Preparing to unpack .../nodejs_18.17.1-deb-1nodesource1_arm64.deb ...
            Unpacking nodejs (18.17.1-deb-1nodesource1) over (18.17.1-deb-1nodesource1) ...
            Setting up nodejs (18.17.1-deb-1nodesource1) ...
            Processing triggers for man-db (2.9.4-2) ...
              @smizi
              Bitte VOLLSTÄNDIG.
              Inkl. erstem LogIn Prompt und der Eingabe sowie dem abschließenden LogIn Prompt, damit man sieht wo du da wie unterwegs bist.
              • Smizi
                @thomas-braun ähm ja, aber da ist doch nicht mehr...```
                pi@raspberrypi:~ $ sudo apt install --reinstall nodejs
                Reading package lists... Done
                Fetched 28.1 MB in 3s (10.1 MB/s)
                  Thomas Braun Most Active @Smizi last edited by Thomas Braun
                  Danach geht es doch noch weiter. 100%ig. Und wenn es nur die neue Eingabezeile ist. Die möchte ich aber sehen, damit ich weiß bis wo das mit welchen Meldungen gelaufen ist.
                  • Smizi
                    @thomas-braun leider nein, das ist alles...sorry```
                    pi@raspberrypi:~ $
                      1 not upgraded.
                      Welches Paket ist das?
                      sudo apt update
                      sudo apt full-upgrade
                      • Smizi
                        Sorry, ich verstehe nicht ganz:
                        pi@raspberrypi:~ $ sudo apt update
                        Hit:1 http://deb.debian.org/debian bullseye InRelease
                        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                        Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,040 B]
                        Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
                        Hit:7 https://apt.grafana.com stable InRelease
                        Err:5 https://repos.influxdata.com/debian bullseye InRelease
                        Fetched 7,040 B in 2s (4,558 B/s)
                        1 package can be upgraded. Run 'apt list --upgradable' to see it.
                        pi@raspberrypi:~ $ sudo apt full-upgrade
                        Calculating upgrade... Done
                        The following packages will be upgraded:
                        grafana
                        1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        Need to get 80.4 MB of archives.
                        After this operation, 10.1 MB of additional disk space will be used.
                        Do you want to continue? [Y/n] Y
                        Get:1 https://apt.grafana.com stable/main arm64 grafana arm64 10.0.3 [80.4 MB]
                        Fetched 80.4 MB in 10s (7,797 kB/s)
                        Reading changelogs... Done
                        Preparing to unpack .../grafana_10.0.3_arm64.deb ...
                        Unpacking grafana (10.0.3) over (9.3.2) ...
                        Setting up grafana (10.0.3) ...
                        Installing new version of config file /etc/init.d/grafana-server ...
                        Installing new version of config file /usr/lib/systemd/system/grafana-server.service ...
                        Restarting grafana-server service... OK
                        pi@raspberrypi:~ $
                        DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
                        • DJMarc75
                          DJMarc75 @Smizi last edited by
                          @smizi bitte alles immer in Codetags posten
                            @smizi
                            Okay, war grafana.
                            Dann fällt mir aber auch nix mehr dazu ein.
                            • Smizi
                              Smizi @DJMarc75 last edited by
                              @djmarc75 sagte in Fehler /usr/lib/node_modules/npm/lib/cli.js:35 info-Adapter:
                              Sorry, mein Fehler 😕
                              • Smizi
                                kann ich noch irgendwas tuen, oder was wäre deine Empfehlung?
                                Gibt es einen bezahlbaren Service via IOB-Projkt, wo ggfs. nochwas geht?
                                  @smizi
                                  Installier es flugs neu und lass diesmal unnötigen Kram von der Kiste.
                                  Backup des ioBrokers hast du ja.
                                  • Smizi
                                    @thomas-braun hm, ok und Danke!
                                    3429
