    4. iob diag - Skript
    iob diag - Skript
    • Feuersturm
      Feuersturm @Thomas Braun last edited by Feuersturm
      @thomas-braun Na dann wollen wir mal 🙂
      iob fix vorab auf meinem Testsystem ausgeführt
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : lxc
      Distributor ID: Ubuntu
      Description:    Ubuntu 22.04.3 LTS
      Release:        22.04
      Codename:       jammy
      PRETTY_NAME="Ubuntu 22.04.3 LTS"
      NAME="Ubuntu"
      VERSION_ID="22.04"
      VERSION="22.04.3 LTS (Jammy Jellyfish)"
      VERSION_CODENAME=jammy
      ID=ubuntu
      ID_LIKE=debian
      HOME_URL="https://www.ubuntu.com/"
      SUPPORT_URL="https://help.ubuntu.com/"
      BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
      PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
      UBUNTU_CODENAME=jammy
      Systemuptime and Load:
       20:04:08 up 16:51,  2 users,  load average: 18.21, 15.76, 15.08
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Mon 2023-08-14 20:04:10 CEST
                 Universal time: Mon 2023-08-14 18:04:10 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      proxmox
      /home/proxmox
      proxmox sudo iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.1G        2.1G        959M        0.0K        1.0G        2.0G
      Swap:           512M        0.0K        511M
      Total:          4.6G        2.1G        1.5G
               4096 M total memory
               2127 M used memory
                475 M active memory
               2344 M inactive memory
                958 M free memory
                  0 M buffer memory
               1010 M swap cache
                512 M total swap
                  0 M used swap
                511 M free swap
      *** FILESYSTEM ***
      Filesystem                          Type   Size  Used Avail Use% Mounted on
      /dev/mapper/data2-vm--3108--disk--1 ext4    20G   13G  6.3G  67% /
      none                                tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                               tmpfs  7.7G     0  7.7G   0% /dev/shm
      tmpfs                               tmpfs  3.1G  156K  3.1G   1% /run
      tmpfs                               tmpfs  5.0M     0  5.0M   0% /run/lock
      tmpfs                               tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
      tmpfs                               tmpfs  1.6G     0  1.6G   0% /run/user/1001
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems (real ones only):
      TARGET SOURCE                              FSTYPE OPTIONS
      /      /dev/mapper/data2-vm--3108--disk--1 ext4   rw,relatime,stripe=16
      /var:
      914M    /var/
      469M    /var/lib
      293M    /var/cache
      287M    /var/cache/apt
      201M    /var/cache/apt/archives
      Archived and active journals take up 16.0M in the file system.
      /opt/iobroker/backups:
      93M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      731M    /opt/iobroker/iobroker-data/
      506M    /opt/iobroker/iobroker-data/files
      162M    /opt/iobroker/iobroker-data/backup-objects
      126M    /opt/iobroker/iobroker-data/files/vis
      118M    /opt/iobroker/iobroker-data/files/vis/widgets
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c4efe404.js.map
      20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.7f5fc837.js.map
      19M     /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.df70fdfc.js.map
      17M     /opt/iobroker/iobroker-data/objects.jsonl
      14M     /opt/iobroker/iobroker-data/objects.json.migrated
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  5.0.11
      admin:          6.8.0
      javascript:     7.1.4
      Adapters from github:   5
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBrokerTestsystem                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : ioBrokerTestsystem                       -  enabled
        system.adapter.benchmark.0              : benchmark             : ioBrokerTestsystem                       - disabled
        system.adapter.daswetter.0              : daswetter             : ioBrokerTestsystem                       -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : ioBrokerTestsystem                       -  enabled
        system.adapter.devices.0                : devices               : ioBrokerTestsystem                       - disabled
        system.adapter.discovery.0              : discovery             : ioBrokerNew                              - disabled
        system.adapter.dwd.0                    : dwd                   : ioBrokerTestsystem                       -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : ioBrokerTestsystem                       -  enabled
        system.adapter.fully-tablet-control.0   : fully-tablet-control  : ioBrokerTestsystem                       - disabled
        system.adapter.history.1                : history               : ioBrokerNew                              - disabled
      + system.adapter.hm-rega.0                : hm-rega               : ioBrokerTestsystem                       -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       -  enabled, port: 0
        system.adapter.hue.0                    : hue                   : ioBrokerTestsystem                       - disabled, port: 443
        system.adapter.ical.0                   : ical                  : ioBrokerTestsystem                       - disabled
        system.adapter.ical.1                   : ical                  : ioBrokerTestsystem                       - disabled
        system.adapter.ical.2                   : ical                  : ioBrokerTestsystem                       - disabled
        system.adapter.ical.3                   : ical                  : ioBrokerTestsystem                       - disabled
        system.adapter.ical.4                   : ical                  : ioBrokerTestsystem                       - disabled
        system.adapter.ical.5                   : ical                  : ioBrokerTestsystem                       -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : ioBrokerTestsystem                       - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerTestsystem                       - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBrokerTestsystem                       - disabled
        system.adapter.influxdb.0               : influxdb              : ioBrokerTestsystem                       - disabled, port: 8086
      + system.adapter.info.0                   : info                  : ioBrokerTestsystem                       -  enabled
      + system.adapter.javascript.0             : javascript            : ioBrokerTestsystem                       -  enabled
        system.adapter.mqtt.0                   : mqtt                  : ioBrokerTestsystem                       - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.nina.0                   : nina                  : ioBrokerTestsystem                       -  enabled
        system.adapter.openweathermap.0         : openweathermap        : ioBrokerTestsystem                       -  enabled
      + system.adapter.proxmox.0                : proxmox               : ioBrokerTestsystem                       -  enabled, port: 8006
        system.adapter.rainbird.0               : rainbird              : ioBrokerTestsystem                       - disabled
      + system.adapter.samsung-community.0      : samsung-community     : ioBrokerTestsystem                       -  enabled
        system.adapter.sayit.0                  : sayit                 : ioBrokerTestsystem                       - disabled, port: 0
      + system.adapter.scenes.0                 : scenes                : ioBrokerTestsystem                       -  enabled
      + system.adapter.scheduler.0              : scheduler             : ioBrokerTestsystem                       -  enabled
      + system.adapter.simple-api.0             : simple-api            : ioBrokerTestsystem                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.socketio.0               : socketio              : ioBrokerTestsystem                       - disabled, port: 8084, bind: 192.168.178.77, run as: admin
        system.adapter.spotify-premium.0        : spotify-premium       : ioBrokerTestsystem                       - disabled
        system.adapter.sql.0                    : sql                   : ioBrokerNew                              - disabled, port: 3306
      + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBrokerTestsystem                       -  enabled
        system.adapter.telegram.0               : telegram              : ioBrokerTestsystem                       - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : ioBrokerTestsystem                       -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : ioBrokerTestsystem                       -  enabled
      + system.adapter.unifi.0                  : unifi                 : ioBrokerTestsystem                       -  enabled
      + system.adapter.valloxmv.0               : valloxmv              : ioBrokerTestsystem                       -  enabled, port: 80
      + system.adapter.vis-2-beta.0             : vis-2-beta            : ioBrokerTestsystem                       -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBrokerTestsystem                       -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBrokerTestsystem                       -  enabled
        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBrokerTestsystem                       -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBrokerTestsystem                       -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBrokerTestsystem                       - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBrokerTestsystem                       -  enabled
        system.adapter.vis-history.0            : vis-history           : ioBrokerTestsystem                       - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBrokerTestsystem                       -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerTestsystem                       - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : ioBrokerTestsystem                       - disabled
        system.adapter.vis-map.0                : vis-map               : ioBrokerTestsystem                       - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBrokerTestsystem                       - disabled
        system.adapter.vis-metro.0              : vis-metro             : ioBrokerTestsystem                       -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerTestsystem                       - disabled
        system.adapter.vis.0                    : vis                   : ioBrokerTestsystem                       -  enabled
      + system.adapter.web.0                    : web                   : ioBrokerTestsystem                       -  enabled, port: 8082, bind: 192.168.178.77, run as: admin
        system.adapter.worx.0                   : worx                  : ioBrokerTestsystem                       - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.8.0    , installed 6.8.0
      Adapter    "backitup"     : 2.7.0    , installed 2.6.23 [Updatable]
      Adapter    "benchmark"    : 1.1.4    , installed 1.1.4
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "device-watcher": 2.9.3   , installed 2.9.3
      Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
      Adapter    "fullcalendar" : 2.2.6    , installed 2.2.2  [Updatable]
      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "hue"          : 3.9.5    , installed 3.9.5
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "openweathermap": 0.4.2   , installed 0.4.2
      Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
      Adapter    "rainbird"     : 0.2.2    , installed 0.2.3
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "socketio"     : 6.5.2    , installed 6.4.0  [Updatable]
      Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "unifi"        : 0.6.6    , installed 0.6.6
      Adapter    "valloxmv"     : 1.2.0    , installed 1.2.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-2-widgets-energy": 0.2.3, installed 0.2.3
      Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
      Adapter    "vis-2-widgets-jaeger-design": 1.0.0, installed 1.0.0
      Adapter    "vis-2-widgets-material": 0.8.5, installed 0.8.5
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "web"          : 6.1.0    , installed 6.0.3  [Updatable]
      Adapter    "worx"         : 2.3.2    , installed 2.3.2
      Adapter    "ws"           : 2.5.3    , installed 2.4.0  [Updatable]
      Objects and States
      Objects:        13145
      States:         11802
      Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
      Hit:4 https://deb.nodesource.com/node_18.x jammy InRelease
      Reading package lists...
      Pending Updates: 3
      *** Listening Ports ***
      tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       316603498  35631/io.web.0
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        311048807  91/systemd-resolved
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       316587698  35266/iobroker.js-c
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       316585912  35266/iobroker.js-c
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          311049284  1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          311047903  141/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          311048905  305/master
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       316592190  35284/io.admin.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       316596098  35542/io.simple-api
      tcp6       0      0 :::111                  :::*                    LISTEN      0          311049286  1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          311047905  141/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      108        311049073  110/grafana-server
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          311048906  305/master
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        311048806  91/systemd-resolved
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          311049285  1/init
      udp6       0      0 :::111                  :::*                                0          311049287  1/init
      Log manuell entfernt
      Manipulation System
      proxmox@ioBrokerTestsystem:~$ sudo touch /usr/local/bin/nodejs
      proxmox@ioBrokerTestsystem:~$ sudo chmod +x /usr/local/bin/nodejs
      proxmox@ioBrokerTestsystem:~$ curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_diag > iob_diag
        % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                       Dload  Upload   Total   Spent    Left  Speed
      100 19718  100 19718    0     0  28309      0 --:--:-- --:--:-- --:--:-- 28453
      proxmox@ioBrokerTestsystem:~$ ls
      github  iob_diag  package-lock.json
      proxmox@ioBrokerTestsystem:~$ chmod 744 iob_diag
      iob diag von github ausgeführt
      Skript v.2023-08-12
      *** BASE SYSTEM ***
       Static hostname: ioBrokerTestsystem
             Icon name: computer-container
               Chassis: container
            Machine ID: db91a8d9813048b3b0d9627361bf92a2
               Boot ID: 32a84dd282b744a48a6aa21ecc09b231
        Virtualization: lxc
      Operating System: Ubuntu 22.04.3 LTS
                Kernel: Linux 6.2.16-3-pve
          Architecture: x86-64
      model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
       20:15:09 up 17:02,  1 user,  load average: 15.12, 14.87, 15.12
      CPU threads: 4
                     Local time: Mon 2023-08-14 20:15:09 CEST
                 Universal time: Mon 2023-08-14 18:15:09 UTC
                       RTC time: n/a
                RTC in local TZ: no
      proxmox
      /home/proxmox
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.1G        1.9G        1.2G        0.0K        1.1G        2.2G
      Total:          4.6G        1.9G        1.7G
               4096 M total memory
               1854 M used memory
                588 M active memory
               2045 M inactive memory
               1154 M free memory
                  0 M buffer memory
               1087 M swap cache
                512 M total swap
                  0 M used swap
                511 M free swap
      *** FAILED SERVICES ***
        UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount   loaded failed failed RPC Pipe File System
      * sys-kernel-debug.mount loaded failed failed Kernel Debug File System
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** FILESYSTEM ***
      tmpfs                               tmpfs  3.1G  160K  3.1G   1% /run
      /var:
      914M    /var/
      469M    /var/lib
      293M    /var/cache
      287M    /var/cache/apt
      734M    /opt/iobroker/iobroker-data/
      18M     /opt/iobroker/iobroker-data/objects.jsonl
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      /usr/bin/corepack       0.18.0
      *** nodejs is NOT correctly installed ***
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.8.0
      javascript:     7.1.4
      Adapter State
      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       -  enabled, port: 0
      + instance is alive
      Objects and States
      Objects:        13145
      States:         11802
      Reading package lists... Done
      Pending Updates: 3
      In diesem Abschnitt kommt jetzt in Rot *** nodejs is NOT correctly installed ***
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      Errors in npm tree:
      Etwas irritierend ist diese Ausgabe das dort erst steht No problems detected und dann Errors in npm tree: aber keine weitere Ausgabe
      Errors in npm tree:
        Thomas Braun Most Active @Feuersturm last edited by
        @feuersturm sagte in iob diag - Skript:
        Ja, da gebe ich dir recht, das ist verwirrend. Muss ich mir vielleicht was anderes ausdenken.
        No problems detected bezieht sich hier wirklich auf dieses npm8-Problem mit den kryptischen temp. Verzeichnissen und die andere Meldung auf richtige Fehler im npm tree.
        Keine Meldung hier = Keine Fehler im tree.
        Hat dich das Skript denn am Ende (nach der Summary) dazu aufgefordert die Fehler zu fixen?
        • Feuersturm
          @thomas-braun Da war ich wohl etwas zu schnell 🙂 So geht es mit der Summary weiter:
                               v.2023-08-12
                   Chassis: container
            Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               amd64
          Timezone:               Europe/Berlin (CEST, +0200)
          User-ID:                1001
          X-Server:               false
          Boot Target:            graphical.target
          Pending OS-Updates:     3
          Pending iob updates:    5
          Nodejs-Installation:    /usr/local/bin/nodejs
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
          Recommended versions are nodejs 18.17.1 and npm 9.6.7
          MEMORY:
          Mem:            4.1G        1.9G        1.1G        0.0K        1.1G        2.2G
          Total:          4.6G        1.9G        1.6G
          Active iob-Instances:   23
          ioBroker Core:          js-controller           5.0.11
                                  admin                   6.8.0
          Objects type: jsonl
          States  type: jsonl
          Objects:                13145
          States:                 11796
          Size of iob-Database:
          14M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
          2.3M    /opt/iobroker/iobroker-data/objects_BACKUP_153020.json
          1.2M    /opt/iobroker/iobroker-data/objects_REMOTE_153020.json
          11M     /opt/iobroker/iobroker-data/states.jsonl
          5.3M    /opt/iobroker/iobroker-data/states.json.migrated
          5.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
          0       /opt/iobroker/iobroker-data/states.json.broken
          === Mark text until here for copying ===
          Your nodejs-Installation seems to be broken. Shall we try to fix it?
          DO NOT RUN FIX ON NON-LINUX-SYSTEMS!
          Press <y> to continue or any other key to quit
          Fixing your nodejs setup
          *** Deleting /usr/local/bin/nodejs ***
          Wrong paths have been fixed. Run \'iob diag\' again to check if your installation is fine now
          Danach erneut iob diag ausgeführt (github Variante)
          Skript v.2023-08-12
          *** BASE SYSTEM ***
                   Chassis: container
            Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
           21:10:04 up 17:57,  1 user,  load average: 14.54, 14.78, 14.78
          CPU threads: 4
                         Local time: Mon 2023-08-14 21:10:05 CEST
                     Universal time: Mon 2023-08-14 19:10:05 UTC
                           RTC time: n/a
                    RTC in local TZ: no
          proxmox
          /home/proxmox
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
                   4096 M total memory
                   1885 M used memory
                    544 M active memory
                   2117 M inactive memory
                   1125 M free memory
                      0 M buffer memory
                   1084 M swap cache
                    512 M total swap
                      0 M used swap
                    511 M free swap
          *** FILESYSTEM ***
          /var:
          914M    /var/
          469M    /var/lib
          293M    /var/cache
          287M    /var/cache/apt
          741M    /opt/iobroker/iobroker-data/
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.8.0
          javascript:     7.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        13145
          States:         11796
          Hit:3 https://deb.nodesource.com/node_18.x jammy InRelease
          Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
          Pending Updates: 3
          2023-08-14 21:10:40.535  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
          2023-08-14 21:11:10.916  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 41336
          2023-08-14 21:11:18.165  - info: hm-rpc.0 (41336) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.17.1, js-controller: 5.0.11
          2023-08-14 21:11:19.544  - info: hm-rpc.0 (41336) xmlrpc server is trying to listen on 192.168.178.77:2010
          2023-08-14 21:11:19.547  - info: hm-rpc.0 (41336) xmlrpc client is trying to connect to 192.168.178.84:2010/ with ["http://192.168.178.77:2010","ioBrokerTestsystem:hm-rpc.0:929dc2370363482799117e5946401b05"]
          2023-08-14 21:11:19.621  - error: hm-rpc.0 (41336) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
          2023-08-14 21:11:49.617  - error: hm-rpc.0 (41336) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
          2023-08-14 21:11:49.627  - info: hm-rpc.0 (41336) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
          2023-08-14 21:11:49.656  - error: hm-rpc.0 (41336) Cannot call init: [http://192.168.178.77:2010, ""] Unknown XML-RPC tag 'TITLE'
          2023-08-14 21:11:49.684  - info: hm-rpc.0 (41336) terminating
          2023-08-14 21:11:49.693  - info: hm-rpc.0 (41336) Terminated (NO_ERROR): Without reason
          2023-08-14 21:11:50.667  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
          2023-08-14 21:11:50.669  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
          2023-08-14 21:12:21.244  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 41411
          2023-08-14 21:12:28.488  - info: hm-rpc.0 (41411) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.17.1, js-controller: 5.0.11
          2023-08-14 21:12:29.389  - info: hm-rpc.0 (41411) xmlrpc server is trying to listen on 192.168.178.77:2010
          2023-08-14 21:12:29.403  - info: hm-rpc.0 (41411) xmlrpc client is trying to connect to 192.168.178.84:2010/ with ["http://192.168.178.77:2010","ioBrokerTestsystem:hm-rpc.0:37c6a758693e440730b66c6e2688cd46"]
          2023-08-14 21:12:29.581  - error: hm-rpc.0 (41411) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
          2023-08-14 21:12:59.538  - error: hm-rpc.0 (41411) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
          2023-08-14 21:12:59.595  - info: hm-rpc.0 (41411) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
          2023-08-14 21:12:59.633  - error: hm-rpc.0 (41411) Cannot call init: [http://192.168.178.77:2010, ""] Unknown XML-RPC tag 'TITLE'
          2023-08-14 21:12:59.661  - info: hm-rpc.0 (41411) terminating
          2023-08-14 21:12:59.665  - info: hm-rpc.0 (41411) Terminated (NO_ERROR): Without reason
          2023-08-14 21:13:00.498  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
          2023-08-14 21:13:00.500  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
          und die summary
                               v.2023-08-12
                   Chassis: container
            Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               amd64
          User-ID:                1001
          X-Server:               false
          Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
          MEMORY:
          Active iob-Instances:   22
                                  admin                   6.8.0
          Objects type: jsonl
          States  type: jsonl
          Objects:                13145
          States:                 11796
          13M     /opt/iobroker/iobroker-data/states.jsonl
            Juhu! Tut! 🙂
            • Feuersturm
              @thomas-braun Was genau soll das Skript bzw. eine Variante denn alles fixen?
                @feuersturm
                Zwei Stufen: Bei den üblichen falschen Pfaden der nodejs-bins werden die Pfade gelöscht, meist ist es dann damit ja auch schon getan.
                Die zweite Stufe wird gezündet, wenn ein nodejs <> der aktuellen Empfehlung gefunden wird, dann wird angeboten diese zu installieren.
                • Feuersturm
                  @thomas-braun Wenn die zweite Stufe implementiert ist kann ich dies auch gerne einmal testen. Kann ja ein Downgrade auf z.B. nodejs 16 machen
                  Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                    Ist schon drin. Wird nur angeboten, wenn eine abweichende Version läuft.
                    Achtung, dein iobroker wird da gestoppt und du musst den Container dann neustarten. Gibt aber Hinweise im Text.
                    Für einen geskripteten Restart eines Containers hab ich zu wenig Plan davon. Bei nativen Installationen wird der ioBroker auch wieder vom Skript gestartet.
                    • Glasfaser
                      Glasfaser @Feuersturm last edited by Glasfaser
                      Was mir gerade einfällt :
                      mit einem Buanet ioBroker Image kann man den Container mit
                      maint restart -y
                      neustarten.
                        Thomas Braun Most Active @Glasfaser last edited by
                        @glasfaser
                        Docker? Hab ich im Code ausgeschlossen.
                        • Glasfaser
                          Glasfaser @Thomas Braun last edited by
                          Ja Docker ,
                          Sorry habe ich nicht dazu geschrieben 🙂
                            @glasfaser
                            Docker-Dosen kann ich rein gar nicht testen. Und ist mir auch 'zu anders' im Vergleich zu einem LXC oder einer nativen Installation.
                            Aber man topft das ganze doch ohnehin immer in einen neuen Übertopf um, oder nicht?
                            • Feuersturm
                              Kurzfassung: Funktioniert 🙂
                              Langfassung:
                              Downgrade nodejs von 18 auf 16
                              proxmox@ioBrokerTestsystem:/home$ apt policy nodejs
                              nodejs:
                                Version table:
                               *** 18.17.1-deb-1nodesource1 100
                                   16.20.2-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
                              proxmox@ioBrokerTestsystem:/home$ sudo apt install nodejs=16.20.2-deb-1nodesource1
                              Building dependency tree... Done
                              The following packages were automatically installed and are no longer required:
                                libllvm13 libvulkan1 libwayland-client0 mesa-vulkan-drivers
                              Use 'sudo apt autoremove' to remove them.
                              The following packages will be DOWNGRADED:
                                nodejs
                              0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 3 not upgraded.
                              Need to get 27.2 MB of archives.
                              After this operation, 60.4 MB disk space will be freed.
                              Do you want to continue? [Y/n] y
                              Get:1 https://deb.nodesource.com/node_16.x jammy/main amd64 nodejs amd64 16.20.2-deb-1nodesource1 [27.2 MB]
                              Fetched 27.2 MB in 4s (6498 kB/s)
                              dpkg: warning: downgrading nodejs from 18.17.1-deb-1nodesource1 to 16.20.2-deb-1nodesource1
                              (Reading database ... 46660 files and directories currently installed.)
                              Preparing to unpack .../nodejs_16.20.2-deb-1nodesource1_amd64.deb ...
                              Unpacking nodejs (16.20.2-deb-1nodesource1) over (18.17.1-deb-1nodesource1) ...
                              Setting up nodejs (16.20.2-deb-1nodesource1) ...
                              Processing triggers for man-db (2.10.2-1) ...
                              proxmox@ioBrokerTestsystem:/home$ nodejs -v && npm -v
                              v16.20.2
                              8.19.4
                              danach noch ein iob fix und dann ein iob start ausgeführt.
                              iob diag (github version)
                              Skript v.2023-08-12
                              *** BASE SYSTEM ***
                                       Chassis: container
                                Virtualization: lxc
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                               22:12:14 up 18:59,  1 user,  load average: 12.95, 13.98, 14.17
                              CPU threads: 4
                                             Local time: Mon 2023-08-14 22:12:14 CEST
                                         Universal time: Mon 2023-08-14 20:12:14 UTC
                                               RTC time: n/a
                                        RTC in local TZ: no
                              proxmox
                              /home/proxmox
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            4.1G        1.8G        1.1G        0.0K        1.1G        2.3G
                              Total:          4.6G        1.8G        1.7G
                                       4096 M total memory
                                       1801 M used memory
                                        619 M active memory
                                       2020 M inactive memory
                                       1146 M free memory
                                          0 M buffer memory
                                       1147 M swap cache
                                        512 M total swap
                                          0 M used swap
                                        511 M free swap
                              *** FILESYSTEM ***
                              /var:
                              914M    /var/
                              469M    /var/lib
                              293M    /var/cache
                              287M    /var/cache/apt
                              733M    /opt/iobroker/iobroker-data/
                              /usr/bin/nodejs         v16.20.2
                              /usr/bin/node           v16.20.2
                              /usr/bin/npm            8.19.4
                              /usr/bin/npx            8.19.4
                              /usr/bin/corepack       0.17.0
                              nodejs:
                                Installed: 16.20.2-deb-1nodesource1
                                Candidate: 16.20.2-deb-1nodesource1
                                Version table:
                               *** 16.20.2-deb-1nodesource1 500
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.8.0
                              javascript:     7.1.4
                              Adapter State
                                system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       - disabled, port: 0
                              + instance is alive
                              Objects and States
                              Objects:        13145
                              States:         11802
                              Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
                              Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                              Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                              Pending Updates: 3
                              tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       317245085  45156/io.web.0
                              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       317230619  44801/iobroker.js-c
                              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       317232637  44801/iobroker.js-c
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       317233130  44829/io.admin.0
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1000       317245613  45066/io.simple-api
                              2023-08-14 22:09:24.761  - info: hm-rpc.0 (45672) terminating
                              2023-08-14 22:09:24.767  - info: hm-rpc.0 (45672) Terminated (NO_ERROR): Without reason
                              2023-08-14 22:09:24.807  - info: hm-rpc.0 (45672) terminating
                              2023-08-14 22:09:25.104  - info: hm-rpc.0 (45672) terminating with timeout
                              2023-08-14 22:09:26.022  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                              2023-08-14 22:09:26.027  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
                              2023-08-14 22:09:56.356  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 45692
                              2023-08-14 22:10:02.445  - info: hm-rpc.0 (45692) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.20.2, js-controller: 5.0.11
                              2023-08-14 22:10:03.210  - info: hm-rpc.0 (45692) xmlrpc server is trying to listen on 192.168.178.77:2010
                              2023-08-14 22:10:03.214  - info: hm-rpc.0 (45692) xmlrpc client is trying to connect to 192.168.178.84:2010/ with ["http://192.168.178.77:2010","ioBrokerTestsystem:hm-rpc.0:d96698d96618b7431e6c2903595df786"]
                              2023-08-14 22:10:03.286  - error: hm-rpc.0 (45692) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                              2023-08-14 22:10:33.320  - info: hm-rpc.0 (45692) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
                              2023-08-14 22:10:33.429  - error: hm-rpc.0 (45692) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                              2023-08-14 22:10:33.452  - error: hm-rpc.0 (45692) Cannot call init: [http://192.168.178.77:2010, ""] Unknown XML-RPC tag 'TITLE'
                              2023-08-14 22:10:33.486  - info: hm-rpc.0 (45692) terminating
                              2023-08-14 22:10:33.490  - info: hm-rpc.0 (45692) Terminated (NO_ERROR): Without reason
                              2023-08-14 22:10:34.338  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                              2023-08-14 22:10:34.341  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
                              2023-08-14 22:11:04.698  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 46399
                              2023-08-14 22:11:06.352  - info: host.ioBrokerTestsystem "system.adapter.hm-rpc.0" disabled
                              2023-08-14 22:11:06.364  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 (force=false, process=true)
                              2023-08-14 22:11:07.036  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 send kill signal
                              2023-08-14 22:11:08.043  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 killing pid 46399
                              2023-08-14 22:11:08.292  - warn: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated due to SIGTERM
                              2023-08-14 22:11:08.295  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code null ()
                              Summary
                                                   v.2023-08-12
                                       Chassis: container
                                Virtualization: lxc
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               amd64
                              User-ID:                1001
                              X-Server:               false
                              Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                                                      /usr/bin/npm            8.19.4
                                                      /usr/bin/npx            8.19.4
                              MEMORY:
                              Mem:            4.1G        1.7G        1.2G        0.0K        1.1G        2.3G
                                                      admin                   6.8.0
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                13145
                              States:                 11802
                              4.4M    /opt/iobroker/iobroker-data/states.jsonl
                              You are running nodejs v.16.20.2. Do you want to install recommended nodejs v.18.17.1?
                              *** DO NOT TRY THIS FIX ON NON-LINUX-SYSTEMS! ***
                              lxc
                              Waiting for ioBroker to shut down - Give me a minute...
                              ## Installing the NodeSource Node.js 18.x repo...
                              ## Populating apt-get cache...
                              + apt-get update
                              ## Confirming "jammy" is supported...
                              + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/jammy/Release'
                              ## Adding the NodeSource signing key to your keyring...
                              + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                              ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
                              + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' > /etc/apt/sources.list.d/nodesource.list
                              + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' >> /etc/apt/sources.list.d/nodesource.list
                              ## Running `apt-get update` for you...
                              + apt-get update
                              Get:4 https://deb.nodesource.com/node_18.x jammy InRelease [4563 B]
                              Get:5 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages [776 B]
                              Fetched 5339 B in 13s (404 B/s)
                              ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
                              ## You may also need development tools to build native addons:
                                   sudo apt-get install gcc g++ make
                              ## To install the Yarn package manager, run:
                                   curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                                   echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                   sudo apt-get update && sudo apt-get install yarn
                              The following packages will be upgraded:
                                nodejs
                              1 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
                              Need to get 28.9 MB of archives.
                              After this operation, 60.4 MB of additional disk space will be used.
                              Get:1 https://deb.nodesource.com/node_18.x jammy/main amd64 nodejs amd64 18.17.1-deb-1nodesource1 [28.9 MB]
                              Fetched 28.9 MB in 7s (4254 kB/s)
                              (Reading database ... 44173 files and directories currently installed.)
                              Preparing to unpack .../nodejs_18.17.1-deb-1nodesource1_amd64.deb ...
                              Unpacking nodejs (18.17.1-deb-1nodesource1) over (16.20.2-deb-1nodesource1) ...
                              Setting up nodejs (18.17.1-deb-1nodesource1) ...
                              Please restart your container
                              We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                              Die Meldung Please restart your container im Textfluss geht unter, wenn man nicht ganz genau hinsieht. Kannst du diesen Hinweis etwas prominenter darstellen?
                              Danach erneut iob diag ausführen
                              Skript v.2023-08-12
                              *** BASE SYSTEM ***
                                       Chassis: container
                                       Boot ID: 3a75cdd6c2ce4a53a75e3c91157c7622
                                Virtualization: lxc
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                               22:28:42 up 3 min,  1 user,  load average: 19.30, 17.42, 16.00
                              CPU threads: 4
                                             Local time: Mon 2023-08-14 22:28:42 CEST
                                         Universal time: Mon 2023-08-14 20:28:42 UTC
                                               RTC time: n/a
                                        RTC in local TZ: no
                              proxmox
                              /home/proxmox
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            4.1G        1.7G        1.8G        0.0K        582M        2.4G
                              Swap:           512M          0B        512M
                              Total:          4.6G        1.7G        2.3G
                                       4096 M total memory
                                       1695 M used memory
                                        188 M active memory
                                       1972 M inactive memory
                                       1818 M free memory
                                          0 M buffer memory
                                        582 M swap cache
                                        512 M total swap
                                          0 M used swap
                                        512 M free swap
                              *** FILESYSTEM ***
                              tmpfs                               tmpfs  3.1G  148K  3.1G   1% /run
                              [sudo] password for proxmox:
                              /var:
                              914M    /var/
                              469M    /var/lib
                              293M    /var/cache
                              287M    /var/cache/apt
                              737M    /opt/iobroker/iobroker-data/
                              19M     /opt/iobroker/iobroker-data/objects.jsonl
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.8.0
                              javascript:     7.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        13145
                              States:         11802
                              Pending Updates: 3
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          317360475  312/master
                              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       317358721  118/iobroker.js-con
                              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       317358714  118/iobroker.js-con
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          317355939  1/init
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          317358193  133/sshd: /usr/sbin
                              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        317359166  91/systemd-resolved
                              tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       317371974  679/io.web.0
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          317360476  312/master
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       317357878  372/io.admin.0
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1000       317370670  608/io.simple-api.0
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          317355941  1/init
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          317358204  133/sshd: /usr/sbin
                              tcp6       0      0 :::3000                 :::*                    LISTEN      108        317358632  117/grafana-server
                              udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        317359165  91/systemd-resolved
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          317355940  1/init
                              udp6       0      0 :::111                  :::*                                0          317355942  1/init
                              2023-08-14 22:28:59.392  - info: hm-rega.0 (481) added/updated 6 programs
                              2023-08-14 22:28:59.400  - info: hm-rega.0 (481) deleted 0 programs
                              2023-08-14 22:28:59.533  - info: hm-rega.0 (481) update rooms to enum.rooms
                              2023-08-14 22:28:59.622  - info: info.0 (572) cpu Temp res = {"main":66,"cores":[68,66,64,64],"max":68,"socket":[],"chipset":null}
                              2023-08-14 22:29:00.413  - info: hm-rega.0 (481) update functions to enum.functions
                              2023-08-14 22:29:00.587  - info: hm-rega.0 (481) update favorites to enum.favorites
                              2023-08-14 22:29:03.929  - error: daswetter.0 (530) force terminate
                              2023-08-14 22:29:03.964  - warn: daswetter.0 (530) Terminated (UNKNOWN_ERROR): Without reason
                              2023-08-14 22:29:04.493  - error: daswetter.0 (530) exception in await insertIntoList [Error: DB closed]
                              2023-08-14 22:29:04.620  - error: daswetter.0 (530) exception in await insertIntoList [Error: DB closed]
                              2023-08-14 22:29:04.641  - error: daswetter.0 (530) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2": Connection is closed.
                              2023-08-14 22:29:04.661  - error: daswetter.0 (530) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2": Connection is closed.]
                              2023-08-14 22:29:05.271  - error: host.ioBrokerTestsystem instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                              2023-08-14 22:29:25.224  - info: tankerkoenig.0 (615) Start first request
                              2023-08-14 22:29:38.220  - info: openweathermap.0 (500) Terminated (NO_ERROR): Without reason
                              2023-08-14 22:29:39.128  - info: host.ioBrokerTestsystem instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                              2023-08-14 22:30:00.188  - info: host.ioBrokerTestsystem instance system.adapter.dwd.0 started with pid 1358
                              2023-08-14 22:30:04.578  - info: host.ioBrokerTestsystem instance system.adapter.ical.5 started with pid 1365
                              2023-08-14 22:30:16.625  - info: dwd.0 (1358) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.11
                              2023-08-14 22:30:17.904  - info: ical.5 (1365) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.11
                              2023-08-14 22:30:19.239  - info: dwd.0 (1358) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2023-08-14 22:30:19.909  - info: host.ioBrokerTestsystem instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2023-08-14 22:30:22.333  - info: ical.5 (1365) processing URL: ioBrokerTesting https://calendar.google.com/calendar/ical/0g7gpl8tcsjsbacjrkunfg8l0c%40group.calendar.google.com/private-ee9dd402778b56aafd5eea5e6f591bd6/basic.ics
                              2023-08-14 22:30:27.616  - info: ical.5 (1365) Terminated (NO_ERROR): Without reason
                              2023-08-14 22:30:28.275  - info: host.ioBrokerTestsystem instance system.adapter.ical.5 terminated with code 0 (NO_ERROR)
                                                   v.2023-08-12
                                       Chassis: container
                                Virtualization: lxc
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               amd64
                              User-ID:                1001
                              X-Server:               false
                                                      /usr/bin/npm            9.6.7
                                                      /usr/bin/npx            9.6.7
                              MEMORY:
                              Mem:            4.1G        1.6G        1.6G        0.0K        899M        2.5G
                              Total:          4.6G        1.6G        2.1G
                                                      admin                   6.8.0
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                13145
                              States:                 11802
                              20M     /opt/iobroker/iobroker-data/objects.jsonl
                              7.0M    /opt/iobroker/iobroker-data/states.jsonl
                              Feuersturm Thomas Braun 2 Replies Last reply Reply Quote 0
                              • Feuersturm
                                Feuersturm @Feuersturm last edited by
                                @Thomas-Braun Kleiner Nachtrag zu
                                                        /usr/bin/npm            8.19.4
                                                        /usr/bin/npx            8.19.4
                                Anstatt Your nodejs installation is correct könnte man hier ausgeben Your nodejs installation is correct and supported but it is not the recommended version
                                  @feuersturm
                                  Jaaaaa, so hatte ich mir das vorgestellt.
                                  Text so besser?
                                  *** You need to manually restart your container now! ***
                                  • Feuersturm
                                    @thomas-braun Ja, das fällt besser auf.
                                      @feuersturm
                                      Habs gerade auf github hochgeschubst.
                                      • andre
                                        andre Developer last edited by
                                        Bin ich der Einzige der es irgendwie bedenklich findet wenn ein Diagnose-Script auch gefundene Probleme korrigiert statt nur darüber zu informieren? Meines Erachtens sollte ein Diagnosescript 100% safe sein. Also ausschließlich Informationen auslesen.
                                        Wo wäre dann sonst der Unterschied zum Fixer-Script? Dann können wir die Diag-Ausgabe doch eigentlich auch direkt in den Fixer einbauen, oder sehe ich das falsch?
                                        @apollon77 @foxriver76 @AlCalzone @Bluefox
                                        Habt ihr eine Meinung dazu? Sollte das Thema vielleicht auf die Dev-Meeting-Liste? Ich denke das ist in jedem Fall zumindest diskussionswürdig.
                                        MfG,
                                        André
                                        Thomas Braun Homoran mcm1957 3 Replies Last reply Reply Quote 4
                                          Thomas Braun Most Active @andre last edited by Thomas Braun
                                          @andre sagte in iob diag - Skript:
                                          Da bin ich dabei.
                                          Ist ja auch eine Beta-Version zum herumspielen. Den Code kann man easy da wieder rausnehmen und in den Fixer (oder ein eigenes Skript integrieren).
                                          War nur für den Moment einfacher das an 'iob diag' anzuhängen.
                                          Den Fix musst du aber auch bestätigen und damit wollen, der wird ja nicht hinterrücks plötzlich ausgeführt.
                                          • andre
                                            andre Developer @Thomas Braun last edited by
                                            Ok, wollte nur darauf hinweisen, bevor aus dem Diag-Script die "eierlegende Wollmilchsau" wird. So wie das m. E. leider mit dem Backitup-Adapter passiert ist. 🙂
                                            @thomas-braun sagte in iob diag - Skript:
                                            Ja, das ist richtig. Aber du kennst ja auch die unerfahrenen User... Da erzählt ein Script was von node Version und schon ist ein ioBroker Einsteiger und Linux Neuling gnadenlos überfordert...
                                            MfG,
                                            André
                                            738
                                            154740
