    4. iob diag - Skript
    iob diag - Skript
    • Feuersturm
      Feuersturm @Thomas Braun last edited by
      @thomas-braun Da war ich wohl etwas zu schnell 🙂 So geht es mit der Summary weiter:
                           v.2023-08-12
       Static hostname: ioBrokerTestsystem
             Icon name: computer-container
               Chassis: container
            Machine ID: db91a8d9813048b3b0d9627361bf92a2
               Boot ID: 32a84dd282b744a48a6aa21ecc09b231
        Virtualization: lxc
      Operating System: Ubuntu 22.04.3 LTS
                Kernel: Linux 6.2.16-3-pve
          Architecture: x86-64
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1001
      X-Server:               false
      Boot Target:            graphical.target
      Pending OS-Updates:     3
      Pending iob updates:    5
      Nodejs-Installation:    /usr/local/bin/nodejs
                              /usr/bin/node           v18.17.1
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
                              /usr/bin/corepack       0.18.0
      Recommended versions are nodejs 18.17.1 and npm 9.6.7
      *** nodejs is NOT correctly installed ***
      MEMORY:
      Mem:            4.1G        1.9G        1.1G        0.0K        1.1G        2.2G
      Swap:           512M        0.0K        511M
      Total:          4.6G        1.9G        1.6G
      Active iob-Instances:   23
      Active repo(s): beta
      ioBroker Core:          js-controller           5.0.11
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : ioBrokerTestsystem                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : ioBrokerTestsystem                       -  enabled, port: 8082, bind: 192.168.178.77, run as: admin
      Objects:                13145
      States:                 11796
      Size of iob-Database:
      18M     /opt/iobroker/iobroker-data/objects.jsonl
      14M     /opt/iobroker/iobroker-data/objects.json.migrated
      14M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      2.3M    /opt/iobroker/iobroker-data/objects_BACKUP_153020.json
      1.2M    /opt/iobroker/iobroker-data/objects_REMOTE_153020.json
      11M     /opt/iobroker/iobroker-data/states.jsonl
      5.3M    /opt/iobroker/iobroker-data/states.json.migrated
      5.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      === Mark text until here for copying ===
      Your nodejs-Installation seems to be broken. Shall we try to fix it?
      DO NOT RUN FIX ON NON-LINUX-SYSTEMS!
      Press <y> to continue or any other key to quit
      Fixing your nodejs setup
      *** Deleting /usr/local/bin/nodejs ***
      Wrong paths have been fixed. Run \'iob diag\' again to check if your installation is fine now
      Danach erneut iob diag ausgeführt (github Variante)
      Skript v.2023-08-12
      *** BASE SYSTEM ***
               Chassis: container
        Virtualization: lxc
      model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       21:10:04 up 17:57,  1 user,  load average: 14.54, 14.78, 14.78
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Mon 2023-08-14 21:10:05 CEST
                 Universal time: Mon 2023-08-14 19:10:05 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      proxmox
      /home/proxmox
      proxmox sudo iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               4096 M total memory
               1885 M used memory
                544 M active memory
               2117 M inactive memory
               1125 M free memory
                  0 M buffer memory
               1084 M swap cache
                512 M total swap
                  0 M used swap
                511 M free swap
      *** FAILED SERVICES ***
        UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount   loaded failed failed RPC Pipe File System
      * sys-kernel-debug.mount loaded failed failed Kernel Debug File System
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                          Type   Size  Used Avail Use% Mounted on
      /dev/mapper/data2-vm--3108--disk--1 ext4    20G   13G  6.3G  67% /
      none                                tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                               tmpfs  7.7G     0  7.7G   0% /dev/shm
      tmpfs                               tmpfs  3.1G  160K  3.1G   1% /run
      tmpfs                               tmpfs  5.0M     0  5.0M   0% /run/lock
      tmpfs                               tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
      tmpfs                               tmpfs  1.6G     0  1.6G   0% /run/user/1001
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET SOURCE                              FSTYPE OPTIONS
      /      /dev/mapper/data2-vm--3108--disk--1 ext4   rw,relatime,stripe=16
      /var:
      914M    /var/
      469M    /var/lib
      293M    /var/cache
      287M    /var/cache/apt
      201M    /var/cache/apt/archives
      Archived and active journals take up 16.0M in the file system.
      /opt/iobroker/backups:
      93M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      741M    /opt/iobroker/iobroker-data/
      506M    /opt/iobroker/iobroker-data/files
      162M    /opt/iobroker/iobroker-data/backup-objects
      126M    /opt/iobroker/iobroker-data/files/vis
      118M    /opt/iobroker/iobroker-data/files/vis/widgets
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c4efe404.js.map
      20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.7f5fc837.js.map
      19M     /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.df70fdfc.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.11
      admin:          6.8.0
      javascript:     7.1.4
      Adapters from github:   5
      Adapter State
      + system.adapter.backitup.0               : backitup              : ioBrokerTestsystem                       -  enabled
        system.adapter.benchmark.0              : benchmark             : ioBrokerTestsystem                       - disabled
        system.adapter.daswetter.0              : daswetter             : ioBrokerTestsystem                       -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : ioBrokerTestsystem                       -  enabled
        system.adapter.devices.0                : devices               : ioBrokerTestsystem                       - disabled
        system.adapter.discovery.0              : discovery             : ioBrokerNew                              - disabled
        system.adapter.dwd.0                    : dwd                   : ioBrokerTestsystem                       -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : ioBrokerTestsystem                       -  enabled
        system.adapter.fully-tablet-control.0   : fully-tablet-control  : ioBrokerTestsystem                       - disabled
        system.adapter.history.1                : history               : ioBrokerNew                              - disabled
      + system.adapter.hm-rega.0                : hm-rega               : ioBrokerTestsystem                       -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       -  enabled, port: 0
        system.adapter.hue.0                    : hue                   : ioBrokerTestsystem                       - disabled, port: 443
        system.adapter.ical.0                   : ical                  : ioBrokerTestsystem                       - disabled
        system.adapter.ical.1                   : ical                  : ioBrokerTestsystem                       - disabled
        system.adapter.ical.2                   : ical                  : ioBrokerTestsystem                       - disabled
        system.adapter.ical.3                   : ical                  : ioBrokerTestsystem                       - disabled
        system.adapter.ical.4                   : ical                  : ioBrokerTestsystem                       - disabled
        system.adapter.ical.5                   : ical                  : ioBrokerTestsystem                       -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : ioBrokerTestsystem                       - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerTestsystem                       - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBrokerTestsystem                       - disabled
        system.adapter.influxdb.0               : influxdb              : ioBrokerTestsystem                       - disabled, port: 8086
      + system.adapter.info.0                   : info                  : ioBrokerTestsystem                       -  enabled
      + system.adapter.javascript.0             : javascript            : ioBrokerTestsystem                       -  enabled
        system.adapter.mqtt.0                   : mqtt                  : ioBrokerTestsystem                       - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.nina.0                   : nina                  : ioBrokerTestsystem                       -  enabled
        system.adapter.openweathermap.0         : openweathermap        : ioBrokerTestsystem                       -  enabled
      + system.adapter.proxmox.0                : proxmox               : ioBrokerTestsystem                       -  enabled, port: 8006
        system.adapter.rainbird.0               : rainbird              : ioBrokerTestsystem                       - disabled
      + system.adapter.samsung-community.0      : samsung-community     : ioBrokerTestsystem                       -  enabled
        system.adapter.sayit.0                  : sayit                 : ioBrokerTestsystem                       - disabled, port: 0
      + system.adapter.scenes.0                 : scenes                : ioBrokerTestsystem                       -  enabled
      + system.adapter.scheduler.0              : scheduler             : ioBrokerTestsystem                       -  enabled
      + system.adapter.simple-api.0             : simple-api            : ioBrokerTestsystem                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.socketio.0               : socketio              : ioBrokerTestsystem                       - disabled, port: 8084, bind: 192.168.178.77, run as: admin
        system.adapter.spotify-premium.0        : spotify-premium       : ioBrokerTestsystem                       - disabled
        system.adapter.sql.0                    : sql                   : ioBrokerNew                              - disabled, port: 3306
      + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBrokerTestsystem                       -  enabled
        system.adapter.telegram.0               : telegram              : ioBrokerTestsystem                       - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : ioBrokerTestsystem                       -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : ioBrokerTestsystem                       -  enabled
      + system.adapter.unifi.0                  : unifi                 : ioBrokerTestsystem                       -  enabled
      + system.adapter.valloxmv.0               : valloxmv              : ioBrokerTestsystem                       -  enabled, port: 80
      + system.adapter.vis-2-beta.0             : vis-2-beta            : ioBrokerTestsystem                       -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBrokerTestsystem                       -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBrokerTestsystem                       -  enabled
        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBrokerTestsystem                       -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBrokerTestsystem                       -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBrokerTestsystem                       - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBrokerTestsystem                       -  enabled
        system.adapter.vis-history.0            : vis-history           : ioBrokerTestsystem                       - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBrokerTestsystem                       -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerTestsystem                       - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : ioBrokerTestsystem                       - disabled
        system.adapter.vis-map.0                : vis-map               : ioBrokerTestsystem                       - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBrokerTestsystem                       - disabled
        system.adapter.vis-metro.0              : vis-metro             : ioBrokerTestsystem                       -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerTestsystem                       - disabled
        system.adapter.vis.0                    : vis                   : ioBrokerTestsystem                       -  enabled
        system.adapter.worx.0                   : worx                  : ioBrokerTestsystem                       - disabled
      + instance is alive
      ioBroker-Repositories
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.8.0    , installed 6.8.0
      Adapter    "backitup"     : 2.7.0    , installed 2.6.23 [Updatable]
      Adapter    "benchmark"    : 1.1.4    , installed 1.1.4
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "device-watcher": 2.9.3   , installed 2.9.3
      Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
      Adapter    "fullcalendar" : 2.2.6    , installed 2.2.2  [Updatable]
      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "hue"          : 3.9.5    , installed 3.9.5
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "openweathermap": 0.4.2   , installed 0.4.2
      Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
      Adapter    "rainbird"     : 0.2.2    , installed 0.2.3
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "socketio"     : 6.5.2    , installed 6.4.0  [Updatable]
      Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "unifi"        : 0.6.6    , installed 0.6.6
      Adapter    "valloxmv"     : 1.2.0    , installed 1.2.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-2-widgets-energy": 0.2.3, installed 0.2.3
      Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
      Adapter    "vis-2-widgets-jaeger-design": 1.0.0, installed 1.0.0
      Adapter    "vis-2-widgets-material": 0.8.5, installed 0.8.5
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "web"          : 6.1.0    , installed 6.0.3  [Updatable]
      Adapter    "worx"         : 2.3.2    , installed 2.3.2
      Adapter    "ws"           : 2.5.3    , installed 2.4.0  [Updatable]
      Objects and States
      Objects:        13145
      States:         11796
      Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 https://deb.nodesource.com/node_18.x jammy InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
      Reading package lists... Done
      Pending Updates: 3
      *** Listening Ports ***
      tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       316603498  35631/io.web.0
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        311048807  91/systemd-resolved
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       316587698  35266/iobroker.js-c
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       316585912  35266/iobroker.js-c
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          311049284  1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          311047903  141/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          311048905  305/master
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       316592190  35284/io.admin.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       316596098  35542/io.simple-api
      tcp6       0      0 :::111                  :::*                    LISTEN      0          311049286  1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          311047905  141/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      108        311049073  110/grafana-server
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          311048906  305/master
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        311048806  91/systemd-resolved
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          311049285  1/init
      udp6       0      0 :::111                  :::*                                0          311049287  1/init
      2023-08-14 21:10:40.535  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
      2023-08-14 21:11:10.916  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 41336
      2023-08-14 21:11:18.165  - info: hm-rpc.0 (41336) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.17.1, js-controller: 5.0.11
      2023-08-14 21:11:19.544  - info: hm-rpc.0 (41336) xmlrpc server is trying to listen on 192.168.178.77:2010
      2023-08-14 21:11:19.547  - info: hm-rpc.0 (41336) xmlrpc client is trying to connect to 192.168.178.84:2010/ with ["http://192.168.178.77:2010","ioBrokerTestsystem:hm-rpc.0:929dc2370363482799117e5946401b05"]
      2023-08-14 21:11:19.621  - error: hm-rpc.0 (41336) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
      2023-08-14 21:11:49.617  - error: hm-rpc.0 (41336) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
      2023-08-14 21:11:49.627  - info: hm-rpc.0 (41336) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
      2023-08-14 21:11:49.656  - error: hm-rpc.0 (41336) Cannot call init: [http://192.168.178.77:2010, ""] Unknown XML-RPC tag 'TITLE'
      2023-08-14 21:11:49.684  - info: hm-rpc.0 (41336) terminating
      2023-08-14 21:11:49.693  - info: hm-rpc.0 (41336) Terminated (NO_ERROR): Without reason
      2023-08-14 21:11:50.667  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
      2023-08-14 21:11:50.669  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
      2023-08-14 21:12:21.244  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 41411
      2023-08-14 21:12:28.488  - info: hm-rpc.0 (41411) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.17.1, js-controller: 5.0.11
      2023-08-14 21:12:29.389  - info: hm-rpc.0 (41411) xmlrpc server is trying to listen on 192.168.178.77:2010
      2023-08-14 21:12:29.403  - info: hm-rpc.0 (41411) xmlrpc client is trying to connect to 192.168.178.84:2010/ with ["http://192.168.178.77:2010","ioBrokerTestsystem:hm-rpc.0:37c6a758693e440730b66c6e2688cd46"]
      2023-08-14 21:12:29.581  - error: hm-rpc.0 (41411) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
      2023-08-14 21:12:59.538  - error: hm-rpc.0 (41411) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
      2023-08-14 21:12:59.595  - info: hm-rpc.0 (41411) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
      2023-08-14 21:12:59.633  - error: hm-rpc.0 (41411) Cannot call init: [http://192.168.178.77:2010, ""] Unknown XML-RPC tag 'TITLE'
      2023-08-14 21:12:59.661  - info: hm-rpc.0 (41411) terminating
      2023-08-14 21:12:59.665  - info: hm-rpc.0 (41411) Terminated (NO_ERROR): Without reason
      2023-08-14 21:13:00.498  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
      2023-08-14 21:13:00.500  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
      und die summary
                           v.2023-08-12
               Chassis: container
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1001
      X-Server:               false
      Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      MEMORY:
      Mem:            4.1G        1.9G        1.2G        0.0K        1.1G        2.2G
      Total:          4.6G        1.9G        1.7G
      Active iob-Instances:   22
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                13145
      States:                 11796
      13M     /opt/iobroker/iobroker-data/states.jsonl
        Thomas Braun Most Active @Feuersturm last edited by
        @feuersturm sagte in iob diag - Skript:
        Juhu! Tut! 🙂
        • Feuersturm
          @thomas-braun Was genau soll das Skript bzw. eine Variante denn alles fixen?
            @feuersturm
            Zwei Stufen: Bei den üblichen falschen Pfaden der nodejs-bins werden die Pfade gelöscht, meist ist es dann damit ja auch schon getan.
            Die zweite Stufe wird gezündet, wenn ein nodejs <> der aktuellen Empfehlung gefunden wird, dann wird angeboten diese zu installieren.
            • Feuersturm
              @thomas-braun Wenn die zweite Stufe implementiert ist kann ich dies auch gerne einmal testen. Kann ja ein Downgrade auf z.B. nodejs 16 machen
              Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                Ist schon drin. Wird nur angeboten, wenn eine abweichende Version läuft.
                Achtung, dein iobroker wird da gestoppt und du musst den Container dann neustarten. Gibt aber Hinweise im Text.
                Für einen geskripteten Restart eines Containers hab ich zu wenig Plan davon. Bei nativen Installationen wird der ioBroker auch wieder vom Skript gestartet.
                • Glasfaser
                  Glasfaser @Feuersturm last edited by Glasfaser
                  Was mir gerade einfällt :
                  mit einem Buanet ioBroker Image kann man den Container mit
                  maint restart -y
                  neustarten.
                    Thomas Braun Most Active @Glasfaser last edited by
                    @glasfaser
                    Docker? Hab ich im Code ausgeschlossen.
                    • Glasfaser
                      Glasfaser @Thomas Braun last edited by
                      Ja Docker ,
                      Sorry habe ich nicht dazu geschrieben 🙂
                        @glasfaser
                        Docker-Dosen kann ich rein gar nicht testen. Und ist mir auch 'zu anders' im Vergleich zu einem LXC oder einer nativen Installation.
                        Aber man topft das ganze doch ohnehin immer in einen neuen Übertopf um, oder nicht?
                        • Feuersturm
                          Kurzfassung: Funktioniert 🙂
                          Langfassung:
                          Downgrade nodejs von 18 auf 16
                          proxmox@ioBrokerTestsystem:/home$ apt policy nodejs
                          nodejs:
                            Version table:
                           *** 18.17.1-deb-1nodesource1 100
                               16.20.2-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
                          proxmox@ioBrokerTestsystem:/home$ sudo apt install nodejs=16.20.2-deb-1nodesource1
                          Building dependency tree... Done
                          The following packages were automatically installed and are no longer required:
                            libllvm13 libvulkan1 libwayland-client0 mesa-vulkan-drivers
                          Use 'sudo apt autoremove' to remove them.
                          The following packages will be DOWNGRADED:
                            nodejs
                          0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 3 not upgraded.
                          Need to get 27.2 MB of archives.
                          After this operation, 60.4 MB disk space will be freed.
                          Do you want to continue? [Y/n] y
                          Get:1 https://deb.nodesource.com/node_16.x jammy/main amd64 nodejs amd64 16.20.2-deb-1nodesource1 [27.2 MB]
                          Fetched 27.2 MB in 4s (6498 kB/s)
                          dpkg: warning: downgrading nodejs from 18.17.1-deb-1nodesource1 to 16.20.2-deb-1nodesource1
                          (Reading database ... 46660 files and directories currently installed.)
                          Preparing to unpack .../nodejs_16.20.2-deb-1nodesource1_amd64.deb ...
                          Unpacking nodejs (16.20.2-deb-1nodesource1) over (18.17.1-deb-1nodesource1) ...
                          Setting up nodejs (16.20.2-deb-1nodesource1) ...
                          Processing triggers for man-db (2.10.2-1) ...
                          proxmox@ioBrokerTestsystem:/home$ nodejs -v && npm -v
                          v16.20.2
                          8.19.4
                          danach noch ein iob fix und dann ein iob start ausgeführt.
                          iob diag (github version)
                          Skript v.2023-08-12
                          *** BASE SYSTEM ***
                                   Chassis: container
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                           22:12:14 up 18:59,  1 user,  load average: 12.95, 13.98, 14.17
                          CPU threads: 4
                                         Local time: Mon 2023-08-14 22:12:14 CEST
                                     Universal time: Mon 2023-08-14 20:12:14 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          proxmox
                          /home/proxmox
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            4.1G        1.8G        1.1G        0.0K        1.1G        2.3G
                          Total:          4.6G        1.8G        1.7G
                                   4096 M total memory
                                   1801 M used memory
                                    619 M active memory
                                   2020 M inactive memory
                                   1146 M free memory
                                      0 M buffer memory
                                   1147 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    511 M free swap
                          *** FILESYSTEM ***
                          /var:
                          914M    /var/
                          469M    /var/lib
                          293M    /var/cache
                          287M    /var/cache/apt
                          733M    /opt/iobroker/iobroker-data/
                          /usr/bin/nodejs         v16.20.2
                          /usr/bin/node           v16.20.2
                          /usr/bin/npm            8.19.4
                          /usr/bin/npx            8.19.4
                          /usr/bin/corepack       0.17.0
                          nodejs:
                            Installed: 16.20.2-deb-1nodesource1
                            Candidate: 16.20.2-deb-1nodesource1
                            Version table:
                           *** 16.20.2-deb-1nodesource1 500
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.8.0
                          javascript:     7.1.4
                          Adapter State
                            system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       - disabled, port: 0
                          + instance is alive
                          Objects and States
                          Objects:        13145
                          States:         11802
                          Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
                          Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                          Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                          Pending Updates: 3
                          tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       317245085  45156/io.web.0
                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       317230619  44801/iobroker.js-c
                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       317232637  44801/iobroker.js-c
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       317233130  44829/io.admin.0
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       317245613  45066/io.simple-api
                          2023-08-14 22:09:24.761  - info: hm-rpc.0 (45672) terminating
                          2023-08-14 22:09:24.767  - info: hm-rpc.0 (45672) Terminated (NO_ERROR): Without reason
                          2023-08-14 22:09:24.807  - info: hm-rpc.0 (45672) terminating
                          2023-08-14 22:09:25.104  - info: hm-rpc.0 (45672) terminating with timeout
                          2023-08-14 22:09:26.022  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                          2023-08-14 22:09:26.027  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
                          2023-08-14 22:09:56.356  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 45692
                          2023-08-14 22:10:02.445  - info: hm-rpc.0 (45692) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v16.20.2, js-controller: 5.0.11
                          2023-08-14 22:10:03.210  - info: hm-rpc.0 (45692) xmlrpc server is trying to listen on 192.168.178.77:2010
                          2023-08-14 22:10:03.214  - info: hm-rpc.0 (45692) xmlrpc client is trying to connect to 192.168.178.84:2010/ with ["http://192.168.178.77:2010","ioBrokerTestsystem:hm-rpc.0:d96698d96618b7431e6c2903595df786"]
                          2023-08-14 22:10:03.286  - error: hm-rpc.0 (45692) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                          2023-08-14 22:10:33.320  - info: hm-rpc.0 (45692) xmlrpc -> 192.168.178.84:2010/ init ["http://192.168.178.77:2010",""]
                          2023-08-14 22:10:33.429  - error: hm-rpc.0 (45692) Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                          2023-08-14 22:10:33.452  - error: hm-rpc.0 (45692) Cannot call init: [http://192.168.178.77:2010, ""] Unknown XML-RPC tag 'TITLE'
                          2023-08-14 22:10:33.486  - info: hm-rpc.0 (45692) terminating
                          2023-08-14 22:10:33.490  - info: hm-rpc.0 (45692) Terminated (NO_ERROR): Without reason
                          2023-08-14 22:10:34.338  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                          2023-08-14 22:10:34.341  - info: host.ioBrokerTestsystem Restart adapter system.adapter.hm-rpc.0 because enabled
                          2023-08-14 22:11:04.698  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 started with pid 46399
                          2023-08-14 22:11:06.352  - info: host.ioBrokerTestsystem "system.adapter.hm-rpc.0" disabled
                          2023-08-14 22:11:06.364  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 (force=false, process=true)
                          2023-08-14 22:11:07.036  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 send kill signal
                          2023-08-14 22:11:08.043  - info: host.ioBrokerTestsystem stopInstance system.adapter.hm-rpc.0 killing pid 46399
                          2023-08-14 22:11:08.292  - warn: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated due to SIGTERM
                          2023-08-14 22:11:08.295  - info: host.ioBrokerTestsystem instance system.adapter.hm-rpc.0 terminated with code null ()
                          Summary
                                               v.2023-08-12
                                   Chassis: container
                            Virtualization: lxc
                          Installation:           lxc
                          Kernel:                 x86_64
                          Userland:               amd64
                          User-ID:                1001
                          X-Server:               false
                          Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                                                  /usr/bin/npm            8.19.4
                                                  /usr/bin/npx            8.19.4
                          MEMORY:
                          Mem:            4.1G        1.7G        1.2G        0.0K        1.1G        2.3G
                                                  admin                   6.8.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                13145
                          States:                 11802
                          4.4M    /opt/iobroker/iobroker-data/states.jsonl
                          You are running nodejs v.16.20.2. Do you want to install recommended nodejs v.18.17.1?
                          *** DO NOT TRY THIS FIX ON NON-LINUX-SYSTEMS! ***
                          lxc
                          Waiting for ioBroker to shut down - Give me a minute...
                          ## Installing the NodeSource Node.js 18.x repo...
                          ## Populating apt-get cache...
                          + apt-get update
                          Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                          ## Confirming "jammy" is supported...
                          + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/jammy/Release'
                          ## Adding the NodeSource signing key to your keyring...
                          + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                          ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
                          + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' > /etc/apt/sources.list.d/nodesource.list
                          + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' >> /etc/apt/sources.list.d/nodesource.list
                          ## Running `apt-get update` for you...
                          + apt-get update
                          Get:4 https://deb.nodesource.com/node_18.x jammy InRelease [4563 B]
                          Get:5 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages [776 B]
                          Fetched 5339 B in 13s (404 B/s)
                          ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
                          ## You may also need development tools to build native addons:
                               sudo apt-get install gcc g++ make
                          ## To install the Yarn package manager, run:
                               curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                               echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                               sudo apt-get update && sudo apt-get install yarn
                          The following packages will be upgraded:
                            nodejs
                          1 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
                          Need to get 28.9 MB of archives.
                          After this operation, 60.4 MB of additional disk space will be used.
                          Get:1 https://deb.nodesource.com/node_18.x jammy/main amd64 nodejs amd64 18.17.1-deb-1nodesource1 [28.9 MB]
                          Fetched 28.9 MB in 7s (4254 kB/s)
                          (Reading database ... 44173 files and directories currently installed.)
                          Preparing to unpack .../nodejs_18.17.1-deb-1nodesource1_amd64.deb ...
                          Unpacking nodejs (18.17.1-deb-1nodesource1) over (16.20.2-deb-1nodesource1) ...
                          Setting up nodejs (18.17.1-deb-1nodesource1) ...
                          Please restart your container
                          We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                          Die Meldung Please restart your container im Textfluss geht unter, wenn man nicht ganz genau hinsieht. Kannst du diesen Hinweis etwas prominenter darstellen?
                          Danach erneut iob diag ausführen
                          Skript v.2023-08-12
                          *** BASE SYSTEM ***
                                   Chassis: container
                                   Boot ID: 3a75cdd6c2ce4a53a75e3c91157c7622
                            Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                           22:28:42 up 3 min,  1 user,  load average: 19.30, 17.42, 16.00
                          CPU threads: 4
                                         Local time: Mon 2023-08-14 22:28:42 CEST
                                     Universal time: Mon 2023-08-14 20:28:42 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          proxmox
                          /home/proxmox
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            4.1G        1.7G        1.8G        0.0K        582M        2.4G
                          Swap:           512M          0B        512M
                          Total:          4.6G        1.7G        2.3G
                                   4096 M total memory
                                   1695 M used memory
                                    188 M active memory
                                   1972 M inactive memory
                                   1818 M free memory
                                      0 M buffer memory
                                    582 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    512 M free swap
                          *** FILESYSTEM ***
                          tmpfs                               tmpfs  3.1G  148K  3.1G   1% /run
                          [sudo] password for proxmox:
                          /var:
                          914M    /var/
                          469M    /var/lib
                          293M    /var/cache
                          287M    /var/cache/apt
                          737M    /opt/iobroker/iobroker-data/
                          19M     /opt/iobroker/iobroker-data/objects.jsonl
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.8.0
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        13145
                          States:         11802
                          Pending Updates: 3
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          317360475  312/master
                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       317358721  118/iobroker.js-con
                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       317358714  118/iobroker.js-con
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          317355939  1/init
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          317358193  133/sshd: /usr/sbin
                          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        317359166  91/systemd-resolved
                          tcp        0      0 192.168.178.77:8082     0.0.0.0:*               LISTEN      1000       317371974  679/io.web.0
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          317360476  312/master
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       317357878  372/io.admin.0
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       317370670  608/io.simple-api.0
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          317355941  1/init
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          317358204  133/sshd: /usr/sbin
                          tcp6       0      0 :::3000                 :::*                    LISTEN      108        317358632  117/grafana-server
                          udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        317359165  91/systemd-resolved
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          317355940  1/init
                          udp6       0      0 :::111                  :::*                                0          317355942  1/init
                          2023-08-14 22:28:59.392  - info: hm-rega.0 (481) added/updated 6 programs
                          2023-08-14 22:28:59.400  - info: hm-rega.0 (481) deleted 0 programs
                          2023-08-14 22:28:59.533  - info: hm-rega.0 (481) update rooms to enum.rooms
                          2023-08-14 22:28:59.622  - info: info.0 (572) cpu Temp res = {"main":66,"cores":[68,66,64,64],"max":68,"socket":[],"chipset":null}
                          2023-08-14 22:29:00.413  - info: hm-rega.0 (481) update functions to enum.functions
                          2023-08-14 22:29:00.587  - info: hm-rega.0 (481) update favorites to enum.favorites
                          2023-08-14 22:29:03.929  - error: daswetter.0 (530) force terminate
                          2023-08-14 22:29:03.964  - warn: daswetter.0 (530) Terminated (UNKNOWN_ERROR): Without reason
                          2023-08-14 22:29:04.493  - error: daswetter.0 (530) exception in await insertIntoList [Error: DB closed]
                          2023-08-14 22:29:04.620  - error: daswetter.0 (530) exception in await insertIntoList [Error: DB closed]
                          2023-08-14 22:29:04.641  - error: daswetter.0 (530) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2": Connection is closed.
                          2023-08-14 22:29:04.661  - error: daswetter.0 (530) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_9.symbol_value2": Connection is closed.]
                          2023-08-14 22:29:05.271  - error: host.ioBrokerTestsystem instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                          2023-08-14 22:29:25.224  - info: tankerkoenig.0 (615) Start first request
                          2023-08-14 22:29:38.220  - info: openweathermap.0 (500) Terminated (NO_ERROR): Without reason
                          2023-08-14 22:29:39.128  - info: host.ioBrokerTestsystem instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                          2023-08-14 22:30:00.188  - info: host.ioBrokerTestsystem instance system.adapter.dwd.0 started with pid 1358
                          2023-08-14 22:30:04.578  - info: host.ioBrokerTestsystem instance system.adapter.ical.5 started with pid 1365
                          2023-08-14 22:30:16.625  - info: dwd.0 (1358) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.11
                          2023-08-14 22:30:17.904  - info: ical.5 (1365) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.11
                          2023-08-14 22:30:19.239  - info: dwd.0 (1358) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2023-08-14 22:30:19.909  - info: host.ioBrokerTestsystem instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2023-08-14 22:30:22.333  - info: ical.5 (1365) processing URL: ioBrokerTesting https://calendar.google.com/calendar/ical/0g7gpl8tcsjsbacjrkunfg8l0c%40group.calendar.google.com/private-ee9dd402778b56aafd5eea5e6f591bd6/basic.ics
                          2023-08-14 22:30:27.616  - info: ical.5 (1365) Terminated (NO_ERROR): Without reason
                          2023-08-14 22:30:28.275  - info: host.ioBrokerTestsystem instance system.adapter.ical.5 terminated with code 0 (NO_ERROR)
                                               v.2023-08-12
                                   Chassis: container
                            Virtualization: lxc
                          Installation:           lxc
                          Kernel:                 x86_64
                          Userland:               amd64
                          User-ID:                1001
                          X-Server:               false
                                                  /usr/bin/npm            9.6.7
                                                  /usr/bin/npx            9.6.7
                          MEMORY:
                          Mem:            4.1G        1.6G        1.6G        0.0K        899M        2.5G
                          Total:          4.6G        1.6G        2.1G
                                                  admin                   6.8.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                13145
                          States:                 11802
                          20M     /opt/iobroker/iobroker-data/objects.jsonl
                          7.0M    /opt/iobroker/iobroker-data/states.jsonl
                          Feuersturm Thomas Braun 2 Replies Last reply Reply Quote 0
                          • Feuersturm
                            Feuersturm @Feuersturm last edited by
                            @Thomas-Braun Kleiner Nachtrag zu
                                                    /usr/bin/npm            8.19.4
                                                    /usr/bin/npx            8.19.4
                            Anstatt Your nodejs installation is correct könnte man hier ausgeben Your nodejs installation is correct and supported but it is not the recommended version
                              @feuersturm
                              Jaaaaa, so hatte ich mir das vorgestellt.
                              Text so besser?
                              *** You need to manually restart your container now! ***
                              • Feuersturm
                                @thomas-braun Ja, das fällt besser auf.
                                  @feuersturm
                                  Habs gerade auf github hochgeschubst.
                                  • andre
                                    andre Developer last edited by
                                    Bin ich der Einzige der es irgendwie bedenklich findet wenn ein Diagnose-Script auch gefundene Probleme korrigiert statt nur darüber zu informieren? Meines Erachtens sollte ein Diagnosescript 100% safe sein. Also ausschließlich Informationen auslesen.
                                    Wo wäre dann sonst der Unterschied zum Fixer-Script? Dann können wir die Diag-Ausgabe doch eigentlich auch direkt in den Fixer einbauen, oder sehe ich das falsch?
                                    @apollon77 @foxriver76 @AlCalzone @Bluefox
                                    Habt ihr eine Meinung dazu? Sollte das Thema vielleicht auf die Dev-Meeting-Liste? Ich denke das ist in jedem Fall zumindest diskussionswürdig.
                                    MfG,
                                    André
                                    Thomas Braun Homoran mcm1957 3 Replies Last reply Reply Quote 4
                                      Thomas Braun Most Active @andre last edited by Thomas Braun
                                      @andre sagte in iob diag - Skript:
                                      Da bin ich dabei.
                                      Ist ja auch eine Beta-Version zum herumspielen. Den Code kann man easy da wieder rausnehmen und in den Fixer (oder ein eigenes Skript integrieren).
                                      War nur für den Moment einfacher das an 'iob diag' anzuhängen.
                                      Den Fix musst du aber auch bestätigen und damit wollen, der wird ja nicht hinterrücks plötzlich ausgeführt.
                                      • andre
                                        andre Developer @Thomas Braun last edited by
                                        Ok, wollte nur darauf hinweisen, bevor aus dem Diag-Script die "eierlegende Wollmilchsau" wird. So wie das m. E. leider mit dem Backitup-Adapter passiert ist. 🙂
                                        @thomas-braun sagte in iob diag - Skript:
                                        Ja, das ist richtig. Aber du kennst ja auch die unerfahrenen User... Da erzählt ein Script was von node Version und schon ist ein ioBroker Einsteiger und Linux Neuling gnadenlos überfordert...
                                        MfG,
                                        André
                                          Die Resultate der bisherigen Überforderung soll das Ding ja gerade wieder ausbügeln... Bislang schaut das auch ganz gut aus. Tut was es soll.
                                          Komplett zerballerte Dreifach-Installationen von nodejs bekommst du auch mit dem Skript nicht gebändigt. Jedenfalls nicht im ersten Anlauf.
                                            Thomas Braun Most Active @Thomas Braun last edited by Thomas Braun
                                            Hab jetzt noch einen Hinweis auf den Beta Code drin:
                                            !!! THIS CODE IS IN BETA STAGE. TRY IT AT YOUR OWN RISK !!!
                                            You are running nodejs v.$NODEUSED. Do you want to install recommended nodejs v.$NODERECOM?
                                            Press <y> to continue or any other key to quit"
                                            738
                                            154740
