    3. Off Topic
    4. InfluxDB
    5. InfluxDB im Query unter _measurement keine Datenpunkte mehr
      Geesthachter @Guest last edited by
      @dp20eic sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
      so sieht es bei mir aus, ja BackitUp nutze ich.
      influxd --help
      code_pi@raspberrypi:~ $  influxd --help
              Start up the daemon configured with flags/env vars/config file.
              The order of precedence for config options are as follows (1 highest, 3 lowest):
                      1. flags
                      2. env vars
                      3. config file
              A config file can be provided via the INFLUXD_CONFIG_PATH env var. If a file is
              not provided via an env var, influxd will look in the current directory for a
              config.{json|toml|yaml|yml} file. If one does not exist, then it will continue unchanged.
      Usage:
        influxd [flags]
        influxd [command]
      Available Commands:
        downgrade    Downgrade metadata schema used by influxd to match the expectations of an older release
        help         Help about any command
        inspect      Commands for inspecting on-disk database data
        recovery     Commands used to recover / regenerate operator access to the DB
        run          Start the influxd server
        upgrade      Upgrade a 1.x version of InfluxDB
        version      Print the influxd server version
      Flags:
            --assets-path string                                              override default assets by serving from a specific directory (developer mode)
            --bolt-path string                                                path to boltdb database (default "/home/pi/.influxdbv2/influxd.bolt")
            --e2e-testing                                                     add /debug/flush endpoint to clear stores; used for end-to-end tests
            --engine-path string                                              path to persistent engine files (default "/home/pi/.influxdbv2/engine")
            --feature-flags stringToString                                    feature flag overrides (default [])
            --flux-log-enabled                                                enables detailed logging for flux queries
            --hardening-enabled                                               enable hardening options (disallow private IPs within flux and templates HTTP requests)
        -h, --help                                                            help for influxd
            --http-bind-address string                                        bind address for the REST HTTP API (default ":8086")
            --http-idle-timeout duration                                      max duration the server should keep established connections alive while waiting for new requests. Set to 0 for no timeout (default 3m0s)
            --http-read-header-timeout duration                               max duration the server should spend trying to read HTTP headers for new requests. Set to 0 for no timeout (default 10s)
            --http-read-timeout duration                                      max duration the server should spend trying to read the entirety of new requests. Set to 0 for no timeout
            --http-write-timeout duration                                     max duration the server should spend on processing+responding to requests. Set to 0 for no timeout
            --influxql-max-select-buckets int                                 The maximum number of group by time bucket a SELECT can create. A value of zero will max the maximum number of buckets unlimited.
            --influxql-max-select-point int                                   The maximum number of points a SELECT can process. A value of 0 will make the maximum point count unlimited. This will only be checked every second so queries will not be aborted immediately when hitting the limit.
            --influxql-max-select-series int                                  The maximum number of series a SELECT can run. A value of 0 will make the maximum series count unlimited.
            --instance-id string                                              add an instance id for replications to prevent collisions and allow querying by edge node
            --log-level Log-Level                                             supported log levels are debug, info, and error (default info)
            --metrics-disabled                                                Don't expose metrics over HTTP at /metrics
            --no-tasks                                                        disables the task scheduler
            --pprof-disabled                                                  Don't expose debugging information over HTTP at /debug/pprof
            --query-concurrency int32                                         the number of queries that are allowed to execute concurrently. Set to 0 to allow an unlimited number of concurrent queries (default 1024)
            --query-initial-memory-bytes int                                  the initial number of bytes allocated for a query when it is started. If this is unset, then query-memory-bytes will be used
            --query-max-memory-bytes int                                      the maximum amount of memory used for queries. Can only be set when query-concurrency is limited. If this is unset, then this number is query-concurrency * query-memory-bytes
            --query-memory-bytes int                                          maximum number of bytes a query is allowed to use at any given time. This must be greater or equal to query-initial-memory-bytes
            --query-queue-size int32                                          the number of queries that are allowed to be awaiting execution before new queries are rejected. Must be > 0 if query-concurrency is not unlimited (default 1024)
            --reporting-disabled                                              disable sending telemetry data to https://telemetry.influxdata.com every 8 hours
            --secret-store string                                             data store for secrets (bolt or vault) (default "bolt")
            --session-length int                                              ttl in minutes for newly created sessions (default 60)
            --session-renew-disabled                                          disables automatically extending session ttl on request
            --sqlite-path string                                              path to sqlite database. if not set, sqlite database will be stored in the bolt-path directory as "influxd.sqlite".
            --storage-cache-max-memory-size Size                              The maximum size a shard's cache can reach before it starts rejecting writes. (default 1.0 GiB)
            --storage-cache-snapshot-memory-size Size                         The size at which the engine will snapshot the cache and write it to a TSM file, freeing up memory. (default 25 MiB)
            --storage-cache-snapshot-write-cold-duration Duration             The length of time at which the engine will snapshot the cache and write it to a new TSM file if the shard hasn't received writes or deletes. (default 10m0s)
            --storage-compact-full-write-cold-duration Duration               The duration at which the engine will compact all TSM files in a shard if it hasn't received a write or delete. (default 4h0m0s)
            --storage-compact-throughput-burst Size                           The rate limit in bytes per second that we will allow TSM compactions to write to disk. (default 48 MiB)
            --storage-max-concurrent-compactions int                          The maximum number of concurrent full and level compactions that can run at one time.  A value of 0 results in 50% of runtime.GOMAXPROCS(0) used at runtime.  Any number greater than 0 limits compactions to that value.  This setting does not apply to cache snapshotting.
            --storage-max-index-log-file-size Size                            The threshold, in bytes, when an index write-ahead log file will compact into an index file. Lower sizes will cause log files to be compacted more quickly and result in lower heap usage at the expense of write throughput. (default 1.0 MiB)
            --storage-no-validate-field-size                                  Skip field-size validation on incoming writes.
            --storage-retention-check-interval Duration                       The interval of time when retention policy enforcement checks run. (default 30m0s)
            --storage-series-file-max-concurrent-snapshot-compactions int     The maximum number of concurrent snapshot compactions that can be running at one time across all series partitions in a database.
            --storage-series-id-set-cache-size int                            The size of the internal cache used in the TSI index to store previously calculated series results.
            --storage-shard-precreator-advance-period Duration                The default period ahead of the endtime of a shard group that its successor group is created. (default 30m0s)
            --storage-shard-precreator-check-interval Duration                The interval of time when the check to pre-create new shards runs. (default 10m0s)
            --storage-tsm-use-madv-willneed                                   Controls whether we hint to the kernel that we intend to page in mmap'd sections of TSM files.
            --storage-validate-keys                                           Validates incoming writes to ensure keys only have valid unicode characters.
            --storage-wal-fsync-delay Duration                                The amount of time that a write will wait before fsyncing. A duration greater than 0 can be used to batch up multiple fsync calls. This is useful for slower disks or when WAL write contention is seen. (default 0s)
            --storage-wal-max-concurrent-writes int                           The max number of writes that will attempt to write to the WAL at a time. (default <nprocs> * 2)
            --storage-wal-max-write-delay storage-wal-max-concurrent-writes   The max amount of time a write will wait when the WAL already has storage-wal-max-concurrent-writes active writes. Set to 0 to disable the timeout. (default 10m0s)
            --storage-write-timeout duration                                  The max amount of time the engine will spend completing a write request before cancelling with a timeout. (default 10s)
            --store string                                                    backing store for REST resources (disk or memory) (default "disk")
            --testing-always-allow-setup                                      ensures the /api/v2/setup endpoint always returns true to allow onboarding
            --tls-cert string                                                 TLS certificate for HTTPs
            --tls-key string                                                  TLS key for HTTPs
            --tls-min-version string                                          Minimum accepted TLS version (default "1.2")
            --tls-strict-ciphers                                              Restrict accept ciphers to: ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, ECDHE_RSA_WITH_AES_128_GCM_SHA256, ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, ECDHE_RSA_WITH_AES_256_GCM_SHA384, ECDHE_ECDSA_WITH_CHACHA20_POLY1305, ECDHE_RSA_WITH_CHACHA20_POLY1305
            --tracing-type string                                             supported tracing types are log, jaeger
            --ui-disabled                                                     Disable the InfluxDB UI
            --vault-addr string                                               address of the Vault server expressed as a URL and port, for example: https://127.0.0.1:8200/.
            --vault-cacert string                                             path to a PEM-encoded CA certificate file on the local disk. This file is used to verify the Vault server's SSL certificate. This environment variable takes precedence over VAULT_CAPATH.
            --vault-capath string                                             path to a directory of PEM-encoded CA certificate files on the local disk. These certificates are used to verify the Vault server's SSL certificate.
            --vault-client-cert string                                        path to a PEM-encoded client certificate on the local disk. This file is used for TLS communication with the Vault server.
            --vault-client-key string                                         path to an unencrypted, PEM-encoded private key on disk which corresponds to the matching client certificate.
            --vault-client-timeout duration                                   timeout variable. The default value is 60s.
            --vault-max-retries int                                           maximum number of retries when a 5xx error code is encountered. The default is 2, for three total attempts. Set this to 0 or less to disable retrying.
            --vault-skip-verify                                               do not verify Vault's presented certificate before communicating with it. Setting this variable is not recommended and voids Vault's security model.
            --vault-tls-server-name string                                    name to use as the SNI host when connecting via TLS.
            --vault-token string                                              vault authentication token
      Use "influxd [command] --help" for more information about a command.
        Geesthachter last edited by
        ehrlich gesagt weiß ich dennoch nicht was ich jetzt machen soll
          A Former User @Geesthachter last edited by
          @geesthachter sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
          Moin,
          das ist doch ganz einfach, geh mit putty oder wie auch immer per ssh auf Dein RasPI, dann suchst Du Dir in der WEB-GUI die measurements raus, die Du löschen willst und rufst dann den Befehl mit dem zu löschenden measurement auf
          influx delete --bucket "hier Dein Name des Buckets" --start '1970-01-01T00:00:00.000Z' --stop 'now' --predicate '_measurement="hier das zu löschende measurement"'
          Das musst Du dann für alle measurements die Du löschen willst, wiederholen.
          Oder Du installierst Dir auf einem Win Rechner InfluxDBStudio und löscht damit https://github.com/CymaticLabs/InfluxDBStudio
          VG
          Bernd
            crunchip Forum Testing Most Active @Guest last edited by
            funktioniert doch nur mit influxdb1.x, aber nicht mit v2.x
              A Former User @crunchip last edited by
              @crunchip sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
              Moin,
              hab ich dann wohl beim Überfliegen übersehen, also doch am besten auf der Kommandozeile.
              VG
              Bernd
                Moin,
                VG
                Bernd
                Danke für deine Hilfe, mein Bucket heißt Iobroker
                das habe ich hier mal eingetragen aber was meinst du mit dem zu löschenden masurement?
                code_influx delete --bucket Iobroker --start '1970-01-01T00:00:00.000Z' --stop 'now' --predicate '_measurement="hier das zu löschende measurement"'
                  crunchip Forum Testing Most Active @Geesthachter last edited by
                  in deinem unteren screen stehn doch die measurement(Datenpunkte) diesen musst du in die Zeile einfügen
                  und das für jeden einzelnen, den du löschen möchtest
                    Geesthachter @crunchip last edited by
                    code_pi@raspberrypi:~ $ influx delete --bucket Iobroker --start '1970-01-01T00:00:00.000Z' --stop 'now' --predicate '_measurement="boltdb_reads_total"'
                    Error: must specify org ID or org name
                    Was mache ich falsch?
                    Ich bekomme eine Fehlermeldung
                    crunchip ? 2 Replies Last reply Reply Quote 0
                      @geesthachter die "" weglassen
                        Moin,
                        mein Fehler, ich möchte eigentlich keine vorgefertigten Befehle hier posten, da jede Umgebung ein klein wenig anders aussieht und sich verhält.
                        Denn wenn man nur Kopiert, dann lernt man nichts 😉
                        Also, in der offiziellen Dokumentation zu influxDB https://docs.influxdata.com/influxdb/v2.7/write-data/delete-data/ siehst Du bei den Beispielen wie es korrekt ist.
                        In Deiner Delete Anweisung fehlt die Organisation, das ist ein Merkmal, das Du beim Anlegen und Einrichten von influxDB angegeben hast, in der WEB-GUI von influxDB findest Du die passende Information
                        Auch auf der Kommandozeile kannst Du die Information abgreifen
                        influx org list
                        VG
                        Bernd
                          @dp20eic
                          Danke für den Hinweis
                          Org ist dann bei mir auch Iobroker. Habe ich das dort jetzt an der richtigen Stelle richtig eingetragen?
                          Jetzt stimmt aber irgendwas mit "start, stop" noch nicht.
                          code_pi@raspberrypi:~ $ influx delete --org Iobroker -- bucket Iobroker --start '1970        -01-01T00:00:00.000Z' --stop 'now' --predicate '_measurement=boltdb_reads_total'
                          NAME:
                              delete - Delete points from InfluxDB
                          USAGE:
                              delete [command options] [arguments...]
                          DESCRIPTION:
                             Delete points from InfluxDB, by specify start, end time and a sql like predic        ate string
                          COMMON OPTIONS:
                             --host value                     HTTP address of InfluxDB [$INFLUX_HOST]
                             --skip-verify                    Skip TLS certificate chain and host name ver        ification [$INFLUX_SKIP_VERIFY]
                             --configs-path value             Path to the influx CLI configurations [$INFL        UX_CONFIGS_PATH]
                             --active-config value, -c value  Config name to use for command [$INFLUX_ACTI        VE_CONFIG]
                             --http-debug
                             --token value, -t value          Token to authenticate request [$INFLUX_TOKEN        ]
                          OPTIONS:
                             --org-id value               The ID of the organization that owns the bucket        [$INFLUX_ORG_ID]
                             --org value, -o value        The name of the organization that owns the bucke        t [$INFLUX_ORG]
                             --bucket-id value            The ID of the bucket to delete from [$INFLUX_BUC        KET_ID]
                             --bucket value, -b value     The name of the bucket to delete from [$INFLUX_B        UCKET_NAME]
                             --start value                The start time in RFC3339Nano format (ex: '2009-        01-02T23:00:00Z')
                             --stop value                 The stop time in RFC3339Nano format (ex: '2009-0        1-02T23:00:00Z')
                             --predicate value, -p value  sql like predicate string (ex: 'tag1="v1" and (t        ag2=123)')
                          Error: Required flags "start, stop" not set
                          Homoran ? 3 Replies Last reply Reply Quote 0
                            Homoran Global Moderator Administrators @Geesthachter last edited by
                            sieht nicht so aus
                              Moin,
                              Du musst genau hinschauen, was Du da eintippst 🙂
                              Du:
                              Ich:
                              influx delete --org Iobroker --bucket Iobroker
                              Hier noch einmal die Dokumentation zu allen Flags https://docs.influxdata.com/influxdb/v2.7/reference/cli/influx/delete/
                              Korrekt sollte es so sein
                              influx delete --bucket Iobroker --org Iobroker --start 1970-01-01T00:00:00Z --stop now --predicate '_measurement="example-measurement"'
                              VG
                              Bernd
                                @dp20eic Hallo Bernd
                                Entschuldige das ich es nicht verstehe ich. was habe ich jetzt wieder falsch gemacht?
                                pi@raspberrypi:~ $ influx delete --bucket Iobroker --org Iobroker --start 1970-01-01T00:00:00Z --stop now --predicate '_measurement= boltdb_reads_total'
                                Error: stop time "now" cannot be parsed as RFC3339Nano: parsing time "now" as "2006-01-02T15:04:05.999999999Z07:00": cannot parse "now" as "2006"
                                  Moin,
                                  ist ja nicht schwer, now entspricht nicht der Notation
                                  influx delete --bucket Iobroker --org Iobroker --start 1970-01-01T00:00:00Z --stop $(date +"%Y-%m-%dT%H:%M:%SZ") --predicate '_measurement="example-measurement"'
                                  Hiermit $(date +"%Y-%m-%dT%H:%M:%SZ") wird das Datum von heute gesetzt.
                                  Jetzt verstehst Du, warum ich es nicht mag, fertige Kommandos zu posten, es wird nur kopiert, ohne sich die Dokumentationen anzuschauen 🙂
                                  Du kannst das mit dem Datum auch kontollieren
                                  # echo $(date +"%Y-%m-%dT%H:%M:%SZ")
                                  2023-08-17T12:56:38Z
                                  VG
                                  Bernd
                                    ich hatte es auch schon versuch das ich statt des now das heutige Datum eingegeben hatte
                                    aber damit bekam ich die selbe Fehlermeldung wie mit deinem Vorschlag.
                                     influx delete --org Iobroker --bucket Iobroker --start '1970-01-01T00:00:00.000Z' --stop '2023-08-17T00:00:00Z' --predicate '_measurement=boltdb_reads_total'
                                    Error: failed to delete data: 401 Unauthorized: unauthorized access
                                     influx delete --bucket Iobroker --org Iobroker --start 1970-01-01T00:00:00Z --stop $(date +"%Y-%m-%dT%H:%M:%SZ") --predicate '_measurement=boltdb_reads_total'
                                    Was muss ich jetzt bei dieser Fehlermeldung machen?
                                      ist das inzwischen korrigiert?
                                        A Former User @Geesthachter last edited by A Former User
                                        Moin,
                                        dann weiter im Lesen
                                        Authentication credentials
                                        The examples below assume your InfluxDB host, organization, and token are provided by either the active influx CLI configuration
                                        or by environment variables (INFLUX_HOST, INFLUX_ORG, and INFLUX_TOKEN). If you do not have a CLI configuration
                                        set up or the environment variables set, include these required credentials for each command with the following flags:
                                            --host: InfluxDB host
                                            -o, --org or --org-id: InfluxDB organization name or ID
                                            -t, --token: InfluxDB API token
                                        Du musst Dich auch authentifizieren, damit Du etwas mit der Datenbank/Bucket machen darfst.
                                        Die passenden Informationen findest Du
                                        influx auth list
                                        influx delete --bucket Iobroker --org Iobroker -t "dein Token" --start 1970-01-01T00:00:00Z --stop $(date +"%Y-%m-%dT%H:%M:%SZ") --predicate '_measurement=boltdb_reads_total'
                                        Den Token dann aber ohne " am Anfang und am Ende
                                        VG
                                        Bernd
                                          Danke, jetzt kommt keine Fehlermeldung mehr. wenn ich aber danach in Influx nachschaue, ist dort "boltdb_reads_total" weiterhin vorhanden
                                          ? Marc Berg 2 Replies Last reply Reply Quote 0
                                            Moin,
                                            ich kann Dir nicht sagen, was da nicht stimmt.
                                            Wenn keine Log-Meldungen kommen, dann kann das nur daran liegen, dass er das measurement nicht gefunden hat, denn eigentlich sollte, wenn man die Dokumentation liest, das so aussehen
                                            Jetzt mal ehrlich, liest Du die Dokumentation von influxDB
                                            VG
                                            Bernd
                                            1.2k
                                            16791
