    4. Instanzen installieren
      jarule2005 last edited by
      das Image mache ich mit dem Win32DiskImager drauf!
      LG
        Guten Morgen,
        habe es jetzt so gemacht wie Rainer geschrieben hatte.
        Folgendes kam über die Konsole zurück als ich Harmony installieren wollte.
        ! root@ioBroker-Pi1:/opt/iobroker# sudo iobroker add harmony
        ! npm install iobroker.harmony –production --prefix "/opt/iobroker" (System call)npm WARN addRemoteGit Error: not found: git
        ! npm WARN addRemoteGit at getNotFoundError (/usr/local/lib/node_modules/npm/node_modules/which/which.js:14:12)
        ! npm WARN addRemoteGit at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:69:19)
        ! npm WARN addRemoteGit at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:81:29)
        ! npm WARN addRemoteGit at /usr/local/lib/node_modules/npm/node_modules/which/which.js:90:16
        ! npm WARN addRemoteGit at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
        ! npm WARN addRemoteGit at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
        ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15)
        ! npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cd ... ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: git
        ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
        ! npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefined
        ! npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https://www.npmjs.com/package/@xmpp/xml>
        ! npm ERR! Linux 4.9.35+
        ! npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
        ! npm ERR! node v6.10.0
        ! npm ERR! npm v3.10.10
        ! npm ERR! code ENOGIT
        ! npm ERR! not found: git
        ! npm ERR!
        ! npm ERR! Failed using git.
        ! npm ERR! This is most likely not a problem with npm itself.
        ! npm ERR! Please check if you have git installed and in your PATH.
        ! npm ERR! Please include the following file with any support request:
        ! npm ERR! /opt/iobroker/npm-debug.log
        ! host.ioBroker-Pi1 Cannot install iobroker.harmony: 1
          Mach bitte über die Konsole
          sudo apt-get install git
          Dann nochmal installieren wie zuletzt.
          Rainer
            Hallo und guten Morgen,
            allem Anschein nach bin ich echt zu doof um ioBroker zu installieren.
            Habe mir jetzt den Pi3 bestellt und dann das Raspbian drauf und versucht ioBroker gemäß Anleitung http://www.iobroker.net/docu/?page_id=5106&lang=de . Das läuft auch alles soweit bis auf die INstallation von ioBroker. Hier gibt es Fehlermeldungen bei irgendeiner Serialport Datei. Er installiert iobroker.discovery nicht etc etc.
            Also eine fertige INstallation von hier genommen http://www.iobroker.net/docu/?page_id=2563&lang=de
            Image geschrieben und die Einstellungen geändert, SSH frei gegeben etc.
            Dann auf die ioBroker Seite zugegriffen. Es erscheint der Lizenzvertrag. Diesen bestätigt und …......... nichts. Der Lizenvertrag steht ewig da. Dann kommt irgendwann automatisch die EInstellungen für Land etc. und ioBroker durchsucht das Netzwerk nach Geräten. Er findet auch bei mir zumindest 24 Stück (laut Anzeige) aber dann steht da was von suche Dienste und es dauert ewig und es passiert nichts. Geht man dann auf fertig/schliessen oder was da steht, sind fast alle Adapter im Webinterface weg!
            Hier mal das Log
            ! discovery.0 2017-10-25 07:47:45.790 info starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.11.2
            ! discovery.0 2017-10-25 07:47:45.646 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:47:42.491 info instance system.adapter.discovery.0 started with pid 1760
            ! host.raspi3 2017-10-25 07:47:12.454 info Restart adapter system.adapter.discovery.0 because enabled
            ! host.raspi3 2017-10-25 07:47:12.452 error instance system.adapter.discovery.0 terminated with code 0 (OK)
            ! discovery.0 2017-10-25 07:47:12.409 info terminating
            ! discovery.0 2017-10-25 07:47:11.899 error at TypeError (native)
            ! discovery.0 2017-10-25 07:47:11.899 error TypeError: There's no write queue for that file descriptor (after write)!
            ! discovery.0 2017-10-25 07:47:11.897 error uncaught exception: There's no write queue for that file descriptor (after write)!
            ! discovery.0 2017-10-25 07:47:10.215 info Found 25 addresses
            ! discovery.0 2017-10-25 07:47:10.174 info Done discovering ping devices. 11 packages received
            ! discovery.0 2017-10-25 07:47:10.127 info Done discovering upnp devices. 13 packages received
            ! discovery.0 2017-10-25 07:47:09.287 info Done discovering mdns devices. 0 packages received
            ! discovery.0 2017-10-25 07:47:04.197 info Done discovering wifi-mi-light devices. 0 packages received
            ! discovery.0 2017-10-25 07:46:55.219 info Done discovering tr064 devices. 0 packages received
            ! discovery.0 2017-10-25 07:46:55.217 warn tr-064.0 not installed
            ! discovery.0 2017-10-25 07:46:55.133 info Discovering wifi-mi-light devices…
            ! discovery.0 2017-10-25 07:46:55.120 info Discovering UPnP devices...
            ! discovery.0 2017-10-25 07:46:54.387 info Done discovering serial devices. 1 packages received
            ! discovery.0 2017-10-25 07:46:54.298 info Discovering ping devices...
            ! discovery.0 2017-10-25 07:46:54.266 info Discovering mDNS devices...
            ! host.raspi3 2017-10-25 07:46:30.776 warn Requested repository "undefined" does not exist in config.
            ! admin.0 2017-10-25 07:45:57.046 info system.adapter.admin.0: logging true
            ! socketio.0 2017-10-25 07:45:57.062 info system.adapter.admin.0: logging true
            ! web.0 2017-10-25 07:45:57.046 info system.adapter.admin.0: logging true
            ! history.0 2017-10-25 07:45:57.052 info system.adapter.admin.0: logging true
            ! discovery.0 2017-10-25 07:45:57.046 info system.adapter.admin.0: logging true
            ! admin.0 2017-10-25 07:45:57.044 info system.adapter.admin.0: logging true
            ! rpi2.0 2017-10-25 07:45:57.043 info system.adapter.admin.0: logging true
            ! admin.0 2017-10-25 07:45:57.030 info Change log subscriber state: true
            ! admin.0 2017-10-25 07:45:54.180 info Repository received successfully.
            ! host.raspi3 2017-10-25 07:45:54.171 warn Requested repository "undefined" does not exist in config.
            ! admin.0 2017-10-25 07:45:53.866 info Request actual repository...
            ! web.0 2017-10-25 07:45:53.801 info http server listening on port 8082
            ! web.0 2017-10-25 07:45:53.791 info socket.io server listening on port 8082
            ! admin.0 2017-10-25 07:45:53.437 info Use link "http://localhost:8081" to configure.
            ! admin.0 2017-10-25 07:45:53.436 info http server listening on port 8081
            ! admin.0 2017-10-25 07:45:53.339 warn No repository source configured
            ! admin.0 2017-10-25 07:45:53.328 info received all objects
            ! web.0 2017-10-25 07:45:52.561 info starting. Version 2.1.3 in /opt/iobroker/node_modules/iobroker.web, node: v6.11.2
            ! web.0 2017-10-25 07:45:52.353 info States connected to redis: 0.0.0.0:6379
            ! admin.0 2017-10-25 07:45:51.865 info received all states
            ! admin.0 2017-10-25 07:45:50.160 info requesting all objects
            ! admin.0 2017-10-25 07:45:50.154 info requesting all states
            ! admin.0 2017-10-25 07:45:50.067 info starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.admin, node: v6.11.2
            ! admin.0 2017-10-25 07:45:49.899 info States connected to redis: 0.0.0.0:6379
            ! discovery.0 2017-10-25 07:45:49.098 info starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.11.2
            ! discovery.0 2017-10-25 07:45:48.936 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:45:48.236 info instance system.adapter.web.0 started with pid 1398
            ! host.raspi3 2017-10-25 07:45:45.358 info instance system.adapter.discovery.0 started with pid 1392
            ! host.raspi3 2017-10-25 07:45:43.836 info instance system.adapter.admin.0 started with pid 1386
            ! rpi2.0 2017-10-25 07:45:34.488 info starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v6.11.2
            ! rpi2.0 2017-10-25 07:45:34.345 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:45:31.882 info instance system.adapter.rpi2.0 started with pid 1331
            ! socketio.0 2017-10-25 07:45:30.402 info socket.io server listening on port 8084
            ! socketio.0 2017-10-25 07:45:30.177 info starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v6.11.2
            ! socketio.0 2017-10-25 07:45:30.048 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:45:27.875 info instance system.adapter.socketio.0 started with pid 1321
            ! history.0 2017-10-25 07:45:26.675 info starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.history, node: v6.11.2
            ! history.0 2017-10-25 07:45:26.593 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:45:24.093 info instance system.adapter.vis.0 terminated while should be started once
            ! host.raspi3 2017-10-25 07:45:23.883 info instance system.adapter.history.0 started with pid 1311
            ! vis.0 2017-10-25 07:45:22.835 error No license found for vis. Please get one on https://iobroker.net !
            ! vis.0 2017-10-25 07:45:22.815 info starting. Version 0.15.5 in /opt/iobroker/node_modules/iobroker.vis, node: v6.11.2
            ! vis.0 2017-10-25 07:45:22.640 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:45:18.212 info Restart adapter system.adapter.web.0 because enabled
            ! host.raspi3 2017-10-25 07:45:18.209 error instance system.adapter.web.0 terminated with code 7 (Adapter already running)
            ! host.raspi3 2017-10-25 07:45:15.876 info instance system.adapter.web.0 started with pid 1290
            ! host.raspi3 2017-10-25 07:45:15.346 info Restart adapter system.adapter.discovery.0 because enabled
            ! host.raspi3 2017-10-25 07:45:15.345 error instance system.adapter.discovery.0 terminated with code 7 (Adapter already running)
            ! host.raspi3 2017-10-25 07:45:13.812 info Restart adapter system.adapter.admin.0 because enabled
            ! host.raspi3 2017-10-25 07:45:13.810 error instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
            ! host.raspi3 2017-10-25 07:45:11.881 info instance system.adapter.discovery.0 started with pid 1276
            ! host.raspi3 2017-10-25 07:45:07.937 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:45:07.907 info instance system.adapter.admin.0 started with pid 1270
            ! host.raspi3 2017-10-25 07:45:07.862 info starting 7 instances
            ! host.raspi3 2017-10-25 07:45:07.839 info 12 instances found
            ! host.raspi3 2017-10-25 07:45:07.817 info InMemoryDB connected
            ! host.raspi3 2017-10-25 07:45:07.784 info inMem-objects listening on port 9001
            ! host.raspi3 2017-10-25 07:45:07.447 info ip addresses: 192.168.10.59 fe80::bede:f140:bdf2:4c09
            ! host.raspi3 2017-10-25 07:45:07.445 info hostname: raspi3, node: v6.11.2
            ! host.raspi3 2017-10-25 07:45:07.443 info Copyright (c) 2014-2017 bluefox, hobbyquaker
            ! host.raspi3 2017-10-25 07:45:07.428 info iobroker.js-controller version 1.1.3 js-controller starting
            ! Adapter 2017-10-25 07:45:02.508 info rpi2 still running
            ! Adapter 2017-10-25 07:45:02.503 info socketio still running
            ! Adapter 2017-10-25 07:45:02.503 info history still running
            ! Adapter 2017-10-25 07:45:02.502 info web still running
            ! Adapter 2017-10-25 07:45:02.501 info discovery still running
            ! Adapter 2017-10-25 07:45:02.501 info admin still running
            ! host.raspi3 2017-10-25 07:45:02.500 info force terminating
            ! host.raspi3 2017-10-25 07:44:59.839 info received SIGTERM
            ! host.raspi3 2017-10-25 07:44:54.827 info received SIGTERM
            ! iobroker 2017-10-25 07:44:53.932 info exit 0
            ! iobroker 2017-10-25 07:44:53.907 info Starting node restart.js
            ! admin.0 2017-10-25 07:44:52.391 info system.adapter.admin.0: logging true
            ! iobroker 2017-10-25 07:44:52.433 info _restart
            ! SyntaxError: 2017-10-25 07:44:52.428 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2677:31)
            ! SyntaxError: 2017-10-25 07:44:52.428 error at ObjectsInMemServer.extendObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2463:13)
            ! SyntaxError: 2017-10-25 07:44:52.428 error at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1670:18)
            ! SyntaxError: 2017-10-25 07:44:52.428 error at ObjectsInMemServer.getUserGroup (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:374:29)
            ! SyntaxError: 2017-10-25 07:44:52.428 error at ObjectsInMemServer. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1674:17)
            ! SyntaxError: 2017-10-25 07:44:52.428 error at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1737:16)
            ! SyntaxError: 2017-10-25 07:44:52.428 error at ObjectsInMemServer. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2467:33)
            ! SyntaxError: 2017-10-25 07:44:52.428 error at ObjectsInMemServer.extendObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2475:20)
            ! SyntaxError: 2017-10-25 07:44:52.428 error at setDefaultAcl (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:350:30)
            ! SyntaxError: 2017-10-25 07:44:52.428 error at Object.parse (native)
            ! SyntaxError: 2017-10-25 07:44:52.428 error Unexpected token u in JSON at position 0
            ! web.0 2017-10-25 07:44:52.393 info system.adapter.admin.0: logging true
            ! uncaught 2017-10-25 07:44:52.393 error exception: Unexpected token u in JSON at position 0
            ! admin.0 2017-10-25 07:44:52.388 info system.adapter.admin.0: logging true
            ! history.0 2017-10-25 07:44:52.377 info system.adapter.admin.0: logging true
            ! socketio.0 2017-10-25 07:44:52.377 info system.adapter.admin.0: logging true
            ! rpi2.0 2017-10-25 07:44:52.355 info system.adapter.admin.0: logging true
            ! discovery.0 2017-10-25 07:44:52.351 info system.adapter.admin.0: logging true
            ! admin.0 2017-10-25 07:44:52.321 info Change log subscriber state: true
            ! admin.0 2017-10-25 07:44:50.166 info Repository received successfully.
            ! web.0 2017-10-25 07:44:48.354 info http server listening on port 8082
            ! web.0 2017-10-25 07:44:48.343 info socket.io server listening on port 8082
            ! host.raspi3 2017-10-25 07:44:48.309 info Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
            ! admin.0 2017-10-25 07:44:48.002 info Request actual repository...
            ! admin.0 2017-10-25 07:44:47.578 info Use link "http://localhost:8081" to configure.
            ! admin.0 2017-10-25 07:44:47.576 info http server listening on port 8081
            ! admin.0 2017-10-25 07:44:47.364 info received all objects
            ! web.0 2017-10-25 07:44:47.143 info starting. Version 2.1.3 in /opt/iobroker/node_modules/iobroker.web, node: v6.11.2
            ! web.0 2017-10-25 07:44:47.000 info States connected to redis: 0.0.0.0:6379
            ! admin.0 2017-10-25 07:44:45.852 info received all states
            ! admin.0 2017-10-25 07:44:44.125 info requesting all objects
            ! admin.0 2017-10-25 07:44:44.119 info requesting all states
            ! admin.0 2017-10-25 07:44:44.033 info starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.admin, node: v6.11.2
            ! admin.0 2017-10-25 07:44:43.867 info States connected to redis: 0.0.0.0:6379
            ! discovery.0 2017-10-25 07:44:43.776 info starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.11.2
            ! discovery.0 2017-10-25 07:44:43.619 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:44:42.792 info instance system.adapter.web.0 started with pid 1177
            ! host.raspi3 2017-10-25 07:44:40.061 info instance system.adapter.discovery.0 started with pid 1171
            ! host.raspi3 2017-10-25 07:44:38.513 info instance system.adapter.admin.0 started with pid 1165
            ! rpi2.0 2017-10-25 07:44:28.427 info starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v6.11.2
            ! rpi2.0 2017-10-25 07:44:28.348 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:44:26.559 info instance system.adapter.rpi2.0 started with pid 1110
            ! socketio.0 2017-10-25 07:44:26.437 info socket.io server listening on port 8084
            ! socketio.0 2017-10-25 07:44:26.240 info starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v6.11.2
            ! socketio.0 2017-10-25 07:44:26.103 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:44:22.561 info instance system.adapter.socketio.0 started with pid 1100
            ! history.0 2017-10-25 07:44:20.426 info starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.history, node: v6.11.2
            ! history.0 2017-10-25 07:44:20.346 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:44:18.561 info instance system.adapter.history.0 started with pid 1090
            ! host.raspi3 2017-10-25 07:44:17.588 info instance system.adapter.vis.0 terminated while should be started once
            ! vis.0 2017-10-25 07:44:16.711 error No license found for vis. Please get one on https://iobroker.net !
            ! vis.0 2017-10-25 07:44:16.700 info starting. Version 0.15.5 in /opt/iobroker/node_modules/iobroker.vis, node: v6.11.2
            ! vis.0 2017-10-25 07:44:16.605 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:44:12.768 info Restart adapter system.adapter.web.0 because enabled
            ! host.raspi3 2017-10-25 07:44:12.767 error instance system.adapter.web.0 terminated with code 7 (Adapter already running)
            ! host.raspi3 2017-10-25 07:44:10.560 info instance system.adapter.web.0 started with pid 1070
            ! host.raspi3 2017-10-25 07:44:10.043 info Restart adapter system.adapter.discovery.0 because enabled
            ! host.raspi3 2017-10-25 07:44:10.042 error instance system.adapter.discovery.0 terminated with code 7 (Adapter already running)
            ! host.raspi3 2017-10-25 07:44:08.497 info Restart adapter system.adapter.admin.0 because enabled
            ! host.raspi3 2017-10-25 07:44:08.495 error instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
            ! host.raspi3 2017-10-25 07:44:06.565 info instance system.adapter.discovery.0 started with pid 1056
            ! host.raspi3 2017-10-25 07:44:02.630 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:44:02.592 info instance system.adapter.admin.0 started with pid 1050
            ! host.raspi3 2017-10-25 07:44:02.547 info starting 7 instances
            ! host.raspi3 2017-10-25 07:44:02.524 info 12 instances found
            ! host.raspi3 2017-10-25 07:44:02.501 info InMemoryDB connected
            ! host.raspi3 2017-10-25 07:44:02.469 info inMem-objects listening on port 9001
            ! host.raspi3 2017-10-25 07:44:02.187 info ip addresses: 192.168.10.59 fe80::bede:f140:bdf2:4c09
            ! host.raspi3 2017-10-25 07:44:02.185 info hostname: raspi3, node: v6.11.2
            ! host.raspi3 2017-10-25 07:44:02.184 info Copyright (c) 2014-2017 bluefox, hobbyquaker
            ! host.raspi3 2017-10-25 07:44:02.169 info iobroker.js-controller version 1.1.3 js-controller starting
            ! Adapter 2017-10-25 07:43:56.878 info rpi2 still running
            ! Adapter 2017-10-25 07:43:56.877 info socketio still running
            ! Adapter 2017-10-25 07:43:56.877 info history still running
            ! Adapter 2017-10-25 07:43:56.876 info web still running
            ! Adapter 2017-10-25 07:43:56.875 info discovery still running
            ! Adapter 2017-10-25 07:43:56.874 info admin still running
            ! host.raspi3 2017-10-25 07:43:56.855 info force terminating
            ! host.raspi3 2017-10-25 07:43:53.973 info received SIGTERM
            ! host.raspi3 2017-10-25 07:43:48.962 info received SIGTERM
            ! iobroker 2017-10-25 07:43:47.863 info exit 0
            ! iobroker 2017-10-25 07:43:47.838 info Starting node restart.js
            ! iobroker 2017-10-25 07:43:46.796 info _restart
            ! SyntaxError: 2017-10-25 07:43:46.793 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2677:31)
            ! SyntaxError: 2017-10-25 07:43:46.793 error at ObjectsInMemServer.extendObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2463:13)
            ! SyntaxError: 2017-10-25 07:43:46.793 error at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1670:18)
            ! SyntaxError: 2017-10-25 07:43:46.793 error at ObjectsInMemServer.getUserGroup (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:374:29)
            ! SyntaxError: 2017-10-25 07:43:46.793 error at ObjectsInMemServer. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1674:17)
            ! SyntaxError: 2017-10-25 07:43:46.793 error at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1737:16)
            ! SyntaxError: 2017-10-25 07:43:46.793 error at ObjectsInMemServer. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2467:33)
            ! SyntaxError: 2017-10-25 07:43:46.793 error at ObjectsInMemServer.extendObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2475:20)
            ! SyntaxError: 2017-10-25 07:43:46.793 error at setDefaultAcl (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:350:30)
            ! SyntaxError: 2017-10-25 07:43:46.793 error at Object.parse (native)
            ! SyntaxError: 2017-10-25 07:43:46.793 error Unexpected token u in JSON at position 0
            ! uncaught 2017-10-25 07:43:46.784 error exception: Unexpected token u in JSON at position 0
            ! rpi2.0 2017-10-25 07:43:08.761 info starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v6.11.2
            ! rpi2.0 2017-10-25 07:43:08.679 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:43:05.838 info instance system.adapter.rpi2.0 started with pid 920
            ! socketio.0 2017-10-25 07:43:05.315 info socket.io server listening on port 8084
            ! socketio.0 2017-10-25 07:43:05.086 info starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v6.11.2
            ! socketio.0 2017-10-25 07:43:04.948 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:43:01.839 info instance system.adapter.socketio.0 started with pid 910
            ! history.0 2017-10-25 07:43:00.647 info starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.history, node: v6.11.2
            ! history.0 2017-10-25 07:43:00.570 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:42:59.681 info instance system.adapter.vis.0 terminated while should be started once
            ! vis.0 2017-10-25 07:42:58.331 error No license found for vis. Please get one on https://iobroker.net !
            ! vis.0 2017-10-25 07:42:58.308 info starting. Version 0.15.5 in /opt/iobroker/node_modules/iobroker.vis, node: v6.11.2
            ! vis.0 2017-10-25 07:42:58.163 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:42:57.841 info instance system.adapter.history.0 started with pid 896
            ! web.0 2017-10-25 07:42:56.521 info http server listening on port 8082
            ! web.0 2017-10-25 07:42:56.510 info socket.io server listening on port 8082
            ! web.0 2017-10-25 07:42:55.339 info starting. Version 2.1.3 in /opt/iobroker/node_modules/iobroker.web, node: v6.11.2
            ! web.0 2017-10-25 07:42:55.134 info States connected to redis: 0.0.0.0:6379
            ! admin.0 2017-10-25 07:42:53.919 info Repository received successfully.
            ! host.raspi3 2017-10-25 07:42:52.109 info Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
            ! admin.0 2017-10-25 07:42:51.951 info system.adapter.admin.0: logging true
            ! admin.0 2017-10-25 07:42:51.948 info system.adapter.admin.0: logging true
            ! discovery.0 2017-10-25 07:42:51.945 info system.adapter.admin.0: logging true
            ! admin.0 2017-10-25 07:42:51.912 info Change log subscriber state: true
            ! admin.0 2017-10-25 07:42:51.667 info Request actual repository...
            ! admin.0 2017-10-25 07:42:51.271 info Use link "http://localhost:8081" to configure.
            ! admin.0 2017-10-25 07:42:51.270 info http server listening on port 8081
            ! admin.0 2017-10-25 07:42:51.064 info received all objects
            ! discovery.0 2017-10-25 07:42:50.070 info starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.11.2
            ! discovery.0 2017-10-25 07:42:49.902 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:42:49.834 info instance system.adapter.web.0 started with pid 876
            ! admin.0 2017-10-25 07:42:49.496 info received all states
            ! admin.0 2017-10-25 07:42:47.930 info requesting all objects
            ! admin.0 2017-10-25 07:42:47.924 info requesting all states
            ! admin.0 2017-10-25 07:42:47.835 info starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.admin, node: v6.11.2
            ! admin.0 2017-10-25 07:42:47.606 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:42:45.824 info instance system.adapter.discovery.0 started with pid 866
            ! host.raspi3 2017-10-25 07:42:41.884 info States connected to redis: 0.0.0.0:6379
            ! host.raspi3 2017-10-25 07:42:41.854 info instance system.adapter.admin.0 started with pid 860
            ! host.raspi3 2017-10-25 07:42:41.810 info starting 7 instances
            ! host.raspi3 2017-10-25 07:42:41.787 info 12 instances found
            ! host.raspi3 2017-10-25 07:42:41.765 info InMemoryDB connected
            ! host.raspi3 2017-10-25 07:42:41.733 info inMem-objects listening on port 9001
            ! host.raspi3 2017-10-25 07:42:41.450 info ip addresses: 192.168.10.59 fe80::bede:f140:bdf2:4c09
            ! host.raspi3 2017-10-25 07:42:41.448 info hostname: raspi3, node: v6.11.2
            ! host.raspi3 2017-10-25 07:42:41.447 info Copyright (c) 2014-2017 bluefox, hobbyquaker
            ! host.raspi3 2017-10-25 07:42:41.432 info iobroker.js-controller version 1.1.3 js-controller starting
            ! host.raspi3 2017-10-25 07:42:34.823 info terminated
            ! host.raspi3 2017-10-25 07:42:34.697 info All instances are stopped.
            ! host.raspi3 2017-10-25 07:42:34.696 info instance system.adapter.web.0 terminated with code 0 (OK)
            ! web.0 2017-10-25 07:42:34.663 info terminating
            ! host.raspi3 2017-10-25 07:42:34.659 info All instances are stopped.
            ! host.raspi3 2017-10-25 07:42:34.658 info instance system.adapter.admin.0 terminated with code 0 (OK)
            ! host.raspi3 2017-10-25 07:42:34.653 info All instances are stopped.
            ! host.raspi3 2017-10-25 07:42:34.652 info instance system.adapter.discovery.0 terminated with code 0 (OK)
            ! host.raspi3 2017-10-25 07:42:34.648 info All instances are stopped.
            ! host.raspi3 2017-10-25 07:42:34.647 info instance system.adapter.rpi2.0 terminated with code 0 (OK)
            ! host.raspi3 2017-10-25 07:42:34.643 info All instances are stopped.
            ! host.raspi3 2017-10-25 07:42:34.641 info instance system.adapter.socketio.0 terminated with code 0 (OK)
            ! host.raspi3 2017-10-25 07:42:34.638 info All instances are stopped.
            ! host.raspi3 2017-10-25 07:42:34.637 info instance system.adapter.history.0 terminated with code 0 (OK)
            ! web.0 2017-10-25 07:42:34.588 info terminated http server on port 8082
            ! iobroker 2017-10-25 07:42:34.593 info _restart
            ! host.raspi3 2017-10-25 07:42:34.590 info stopInstance system.adapter.rpi2.0 killing pid 699
            ! host.raspi3 2017-10-25 07:42:34.589 info stopInstance system.adapter.rpi2.0
            ! host.raspi3 2017-10-25 07:42:34.589 warn stopInstance system.adapter.javascript.0 not running
            ! host.raspi3 2017-10-25 07:42:34.588 info stopInstance system.adapter.javascript.0
            ! host.raspi3 2017-10-25 07:42:34.587 info stopInstance system.adapter.socketio.0 killing pid 678
            ! host.raspi3 2017-10-25 07:42:34.586 info stopInstance system.adapter.socketio.0
            ! host.raspi3 2017-10-25 07:42:34.584 info stopInstance system.adapter.mobile.0
            ! host.raspi3 2017-10-25 07:42:34.583 info stopInstance system.adapter.history.0 killing pid 668
            ! host.raspi3 2017-10-25 07:42:34.582 info stopInstance system.adapter.history.0
            ! host.raspi3 2017-10-25 07:42:34.581 info stopInstance system.adapter.vis.0
            ! host.raspi3 2017-10-25 07:42:34.580 info stopInstance system.adapter.web.0 killing pid 770
            ! host.raspi3 2017-10-25 07:42:34.578 info stopInstance system.adapter.web.0
            ! host.raspi3 2017-10-25 07:42:34.577 warn stopInstance system.adapter.hm-rega.0 not running
            ! host.raspi3 2017-10-25 07:42:34.576 info stopInstance system.adapter.hm-rega.0
            ! host.raspi3 2017-10-25 07:42:34.575 warn stopInstance system.adapter.hm-rpc.0 not running
            ! host.raspi3 2017-10-25 07:42:34.574 info stopInstance system.adapter.hm-rpc.0
            ! host.raspi3 2017-10-25 07:42:34.573 info stopInstance system.adapter.discovery.0 killing pid 755
            ! host.raspi3 2017-10-25 07:42:34.572 info stopInstance system.adapter.discovery.0
            ! host.raspi3 2017-10-25 07:42:34.569 info stopInstance system.adapter.admin.0 killing pid 754
            ! host.raspi3 2017-10-25 07:42:34.567 info stopInstance system.adapter.admin.0
            ! SyntaxError: 2017-10-25 07:42:34.559 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2677:31)
            ! SyntaxError: 2017-10-25 07:42:34.559 error at ObjectsInMemServer.extendObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2463:13)
            ! SyntaxError: 2017-10-25 07:42:34.559 error at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1670:18)
            ! SyntaxError: 2017-10-25 07:42:34.559 error at ObjectsInMemServer.getUserGroup (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:374:29)
            ! SyntaxError: 2017-10-25 07:42:34.559 error at ObjectsInMemServer. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1674:17)
            ! SyntaxError: 2017-10-25 07:42:34.559 error at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1737:16)
            ! SyntaxError: 2017-10-25 07:42:34.559 error at ObjectsInMemServer. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2467:33)
            ! SyntaxError: 2017-10-25 07:42:34.559 error at ObjectsInMemServer.extendObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2475:20)
            ! SyntaxError: 2017-10-25 07:42:34.559 error at setDefaultAcl (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:350:30)
            ! SyntaxError: 2017-10-25 07:42:34.559 error at Object.parse (native)
            ! SyntaxError: 2017-10-25 07:42:34.559 error Unexpected token u in JSON at position 0
            ! socketio.0 2017-10-25 07:42:34.610 info terminating
            ! admin.0 2017-10-25 07:42:34.609 info terminating
            ! history.0 2017-10-25 07:42:34.607 info terminating
            ! rpi2.0 2017-10-25 07:42:34.601 info terminating
            ! socketio.0 2017-10-25 07:42:34.596 info terminating http server on port 8084
            ! discovery.0 2017-10-25 07:42:34.596 info terminating
            ! web.0 2017-10-25 07:42:34.587 info terminating http server on port 8082
            ! admin.0 2017-10-25 07:42:34.577 info terminating http server on port 8081
            ! uncaught 2017-10-25 07:42:34.543 error exception: Unexpected token u in JSON at position 0
            ! admin.0 2017-10-25 07:42:16.395 info Repository received successfully.
            ! admin.0 2017-10-25 07:42:13.876 info system.adapter.admin.0: logging true
            ! socketio.0 2017-10-25 07:42:13.891 info system.adapter.admin.0: logging true
            ! web.0 2017-10-25 07:42:13.917 info system.adapter.admin.0: logging true
            ! discovery.0 2017-10-25 07:42:13.881 info system.adapter.admin.0: logging true
            ! history.0 2017-10-25 07:42:13.880 info system.adapter.admin.0: logging true
            ! rpi2.0 2017-10-25 07:42:13.875 info system.adapter.admin.0: logging true
            ! admin.0 2017-10-25 07:42:13.873 info system.adapter.admin.0: logging true
            ! admin.0 2017-10-25 07:42:13.849 info Change log subscriber state: true
            Das verstehe ich nicht. ISt mir etwas zu hoch!Gut ich kenne mich auch nicht unbedingt mit Linux Systemen aus aber wenn man etwas nach Anleitung macht und es geht nicht, dann ist das schon komisch.
            Hat jemand eine Idee?
            Lieben Gruß
            • eric2905
              eric2905 last edited by
              Hier wären ein paar Screenshots sehr hilfreich - siehst Du eine Möglichkeit, die nochmal zu erstellen?
              Gruß,
              Eric
                ja mach ich. Aber wie kann ich die Bilder dann hier einfügen? Sehe das geht nur über web???
                Werde aber dann wahrscheinlich erst morgen früh dazu kommen! Habe heute Arbeitseinsatz im Garten! 🙂
                Schon mal danke für die Hilfe!
                LG
                  OK Habs unten über Datei anhängen gefunden.
                  Hier mal der aktuelle Stand der Adapter
                  • eric2905
                    Poste mal bitte einens Screenshot der Einstellungen des Admins (Zahnrad-Symbol oben rechts), Reiter "Haupteinstellungen" und Reiter "Verwahrungsorte".
                    Das nur die installierten Adapter angezeigt werden deutet darauf hin, das der Raspi entweder keine Verbindung zum Internet (also zum Repository / Verwahrungsort) hat, oder aber "falsche" dort eingestellt sind oder ein falsches augewählt ist.
                    Gruß,
                    Eric
                    • Dutchman
                      Bitte auch Mal Posten welche js-controller du installiert hast bin mir nicht sicher welches Image du benutzt.
                      Dazu bitte Reiter enum sichtbar machen
                      Send from mobile device
                        Guten Morgen,
                        jetzt hatte ich noch mal versucht ganz in Ruhe das Raspbian Stretch aufzusetzen und genau nach der Anleitung http://www.iobroker.net/docu/?page_id=5106&lang=de ioBroker zu installieren.
                        Folgendes kommt in der Konsole
                        ! Last login: Thu Oct 26 08:24:43 2017 from 192.168.10.53
                        ! root@raspi3:~# node -v
                        ! v6.11.5
                        ! root@raspi3:~# nodejs -v
                        ! v6.11.5
                        ! root@raspi3:~# sudo mkdir /opt/iobroker
                        ! root@raspi3:~# sudo chmod 777 /opt/iobroker
                        ! root@raspi3:~# cd /opt/iobroker
                        ! root@raspi3:/opt/iobroker# sudo npm install iobroker –unsafe-perm
                        ! > iobroker@1.0.2 install /opt/iobroker/node_modules/iobroker
                        ! > node lib/setup.js
                        ! npm install iobroker.discovery --production --prefix /opt/iobroker
                        ! node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAd ... arm.tar.gz
                        ! node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.11.5 (node-v48 ABI) (falling back to source compile with node-gyp)
                        ! ../src/serialport.cpp: In function ‘int getIntFromObject(v8::Localv8::object, std::__cxx11::string)’:
                        ! ../src/serialport.cpp:90:52: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ! return getValueFromObject(options, key)->ToInt32()->Int32Value();
                        ! In file included from /root/.node-gyp/6.11.5/include/node/node.h:42:0,
                        ! from ../../nan/nan.h:49,
                        ! from ../src/./serialport.h:7,
                        ! from ../src/serialport.cpp:1:
                        ! /root/.node-gyp/6.11.5/include/node/v8.h:8214:14: note: declared here
                        ! Local <int32>Value::ToInt32() const {
                        ! ../src/serialport.cpp: In function ‘double getDoubleFromObject(v8::Localv8::object, std::_cxx11::string)’:
                        ! ../src/serialport.cpp:102:53: warning: ‘v8::Local v8::numberv8::Value::ToNumber() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ! return getValueFromObject(options, key)->ToNumber()->NumberValue();
                        ! /root/.node-gyp/6.11.5/include/node/v8.h:8178:15: note: declared here
                        ! Local <number>Value::ToNumber() const {
                        ! ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
                        ! ../src/serialport.cpp:174:31: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ! int fd = argv[1]->ToInt32()->Int32Value();
                        ! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ! ../src/serialport.cpp:193:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ! int fd = info[0]->ToInt32()->Int32Value();
                        ! ../src/serialport.cpp:217:116: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ! baton->baudRate = Nan::Get(options, Nan::Newv8::string("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                        ! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Write(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ! ../src/serialport.cpp:252:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ! ../src/serialport.cpp:369:32: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ! baton->fd = info[0]->ToInt32()->Int32Value();
                        ! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ! ../src/serialport.cpp:480:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ! ../src/serialport.cpp:528:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ! ../src/serialport.cpp:585:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ! ../src/serialport_unix.cpp: In function ‘OpenBatonPlatformOptions* ParsePlatformOptions(const v8::Localv8::object&)’:
                        ! ../src/serialport_unix.cpp:44:109: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ! result->vmin = Nan::Get(options, Nan::Newv8::string("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                        ! from ../src/serialport_unix.cpp:1:
                        ! ../src/serialport_unix.cpp:45:111: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ! result->vtime = Nan::Get(options, Nan::Newv8::string("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                        ! ../src/serialport_poller.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE SerialportPoller::New(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ! ../src/serialport_poller.cpp:86:31: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ! obj->fd
                        ! from ../src/serialport_poller.cpp:5:
                        ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
                        ! npm WARN iobroker No description
                        ! npm WARN iobroker No repository field.
                        ! npm WARN iobroker No README data
                        ! npm WARN iobroker No license field.
                        ! npm install iobroker.admin –production --prefix /opt/iobroker
                        ! npm install iobroker.js-controller --production --prefix /opt/iobroker
                        ! npm WARN deprecated tar.gz@1.0.7: <emoji seq="26a0">⚠️</emoji> WARNING <emoji seq="26a0">⚠️</emoji> tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar</int32></v8::int32></int32></v8::string></v8::int32></int32></v8::string></v8::int32></v8::object></int32></v8::int32></int32></v8::int32></int32></v8::int32></int32></v8::int32></int32></v8::int32></int32></v8::string></v8::int32></int32></v8::int32></int32></v8::int32></number></v8::number></v8::object></int32></v8::int32></v8::object>
                        An der Stelle habe ich dann abgebrochen. Werde das jetzt noch mal mit der Vorinstallierten ioBroker Version versuchen und dann die gewünschten Screenshots posten.
                        • AlCalzone
                          Ich sehe nur warnings, keine tatsächlichen Fehler. NPM hat da ein gewisses Mitteilungsbedürfnis. Lass es mal durchlaufen oder gibt es einen bestimmten Grund, dass du abgebrochen hast?
                            Guten Morgen,
                            Danke. Habe nun mal die Installation trotz der ganzen Warnmeldungen durchlaufen lassen. ioBroker läuft nun!
                            Endlich!
                            Die INstanzen können nun auch ohne PRobleme installiert werden.
                            Jetzt kommt der nächste Schritt. Die ganzen Adapter einzurichten und vor allem wie man dann darauf zugreifen kann.
                            Aber da werde ich erst mal im Forum ein bißchen schnüffeln bevor ich wieder dumme Fragen stelle!
                            Herzlichen Dank für die tolle Unterstützung!
                            Lieben Gruß
                            4886
