    4. Node-Red
    5. 2 Kontaktzustände gleichzeitig abfragen
    • mickym
      mickym Most Active last edited by mickym
      Ich würde keine Verknüpfungen machen - insbesondere dann noch mit diesen Logik-Nodes.
      Hier mal eine einfache Version mit Standardmitteln
             "id": "c2e6ec09e43e9963",
             "type": "inject",
             "z": "8e615e82aa5ca254",
             "name": "",
             "props": [
                     "p": "payload"
                     "p": "topic",
                     "vt": "str"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "reedhaustür",
             "payload": "true",
             "payloadType": "bool",
             "x": 160,
             "y": 220,
             "wires": [
                     "a125e6b73596db9d"
             "id": "56c606c4911edf67",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
                     "p": "topic",
                     "vt": "str"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "reedhaustürriegel",
             "payload": "true",
             "x": 140,
             "y": 320,
             "wires": [
                     "a125e6b73596db9d"
             "id": "1125ed5c6b7a3a36",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
                     "p": "topic",
                     "vt": "str"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "payload": "false",
             "x": 160,
             "y": 260,
             "wires": [
                     "a125e6b73596db9d"
             "id": "3cf934311a4c9004",
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
                     "p": "topic",
                     "vt": "str"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "payload": "false",
             "x": 140,
             "y": 360,
             "wires": [
                     "a125e6b73596db9d"
             "id": "a125e6b73596db9d",
             "type": "join",
             "name": "",
             "mode": "custom",
             "build": "object",
             "property": "payload",
             "propertyType": "msg",
             "key": "topic",
             "joiner": "\\n",
             "joinerType": "str",
             "accumulate": true,
             "timeout": "",
             "count": "2",
             "reduceRight": false,
             "reduceExp": "",
             "reduceInit": "",
             "reduceInitType": "",
             "reduceFixup": "",
             "x": 390,
             "y": 280,
             "wires": [
                     "1bfd67d784b4d1aa",
                     "6882d7837f45f43d"
             "id": "1bfd67d784b4d1aa",
             "type": "debug",
             "name": "Haustür Statusobjekt",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "payload",
             "targetType": "msg",
             "statusVal": "",
             "statusType": "auto",
             "x": 680,
             "y": 100,
             "wires": []
             "id": "492b5abd04e6b495",
             "type": "change",
             "name": "Riegeloffen/Türzu",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "1",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 930,
             "y": 280,
             "wires": [
                     "f57d1411b6bc2201"
             "id": "8498e01c37c203fa",
             "type": "change",
             "name": "Riegelzu/Türzu",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "0",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 920,
             "y": 180,
             "wires": [
                     "28c26f06120965e3"
             "id": "d9be4a146d42a968",
             "type": "change",
             "name": "Riegeloffen/Türoffen",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "2",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 920,
             "y": 380,
             "wires": [
                     "95064fd43a97c05e"
             "id": "ff63d576864351f5",
             "type": "comment",
             "name": "Tür geschlossen und versperrt = grün",
             "info": "",
             "x": 930,
             "y": 140,
             "wires": []
             "id": "e862a84c4eaae633",
             "type": "comment",
             "name": "Tür offen und nicht versperrt = rot",
             "info": "",
             "x": 910,
             "y": 340,
             "wires": []
             "id": "e7be8078a052091b",
             "type": "comment",
             "name": "Tür geschlossen und nicht versperrt = blau",
             "info": "",
             "x": 940,
             "y": 240,
             "wires": []
             "id": "28c26f06120965e3",
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": true,
             "statusVal": "payload",
             "x": 1160,
             "y": 180,
             "wires": []
             "id": "f57d1411b6bc2201",
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": true,
             "x": 1170,
             "y": 280,
             "wires": []
             "id": "95064fd43a97c05e",
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": true,
             "x": 1180,
             "y": 380,
             "wires": []
             "id": "6882d7837f45f43d",
             "type": "switch",
             "name": "",
             "rules": [
                     "t": "jsonata_exp",
                     "v": "payload = {\"reedhaustür\":true,\"reedhaustürriegel\":true}",
                     "vt": "jsonata"
                     "t": "jsonata_exp",
                     "v": "payload = {\"reedhaustür\":true,\"reedhaustürriegel\":false}",
                     "vt": "jsonata"
                     "t": "jsonata_exp",
                     "v": "payload = {\"reedhaustür\":false,\"reedhaustürriegel\":false}",
                     "vt": "jsonata"
             "checkall": "true",
             "repair": false,
             "outputs": 3,
             "x": 570,
             "y": 280,
             "wires": [
                     "8498e01c37c203fa"
                     "492b5abd04e6b495"
                     "d9be4a146d42a968"
      Falls Dir simple Vergleiche nicht taugen, wie in dem Flow:
      kannst Du auch ohne Logiknodes - sowas mit boolescher Logik implementieren.
      H ? 2 Replies Last reply Reply Quote 1
      • bahnuhr
        bahnuhr Forum Testing Most Active @hpgo last edited by bahnuhr
        @hpgo
        per Script
        var IDsensor1 = "DP von Sensor 1";
        var IDsensor2 = "DP von Sensor 2";
        var Ergebnis = "neuer DP für das Ergebnis";     // dieser manuell anlegen mit string
        var idTest = [IDsensor1, IDsensor2];
        on({id: idTest}, function(){
            var sensor1 = getState(IDsensor1).val;
            var sensor2 = getState(IDsensor2).val;
            if (sensor1 == false && sensor2 == false) {
                    setState(Ergebnis, "versperrt");
            } else if (sensor1 == false && sensor2) {
                    setState(Ergebnis, "unversperrt");
            } else if (sensor1 && sensor2) {
                    setState(Ergebnis, "offen");
          hpgo @mickym last edited by
          Vielen lieben Dank, habe den ersten Vorschlag von @mickym übernommen.
          Danke dafür!
            A Former User @mickym last edited by
            @mickym sagte in 2 Kontaktzustände gleichzeitig abfragen:
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                           "p": "topic",
                           "vt": "str"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "payload": "true",
                   "x": 160,
                   "y": 220,
                   "wires": [
                           "a125e6b73596db9d"
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                           "p": "topic",
                           "vt": "str"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "payload": "true",
                   "x": 140,
                   "y": 320,
                   "wires": [
                           "a125e6b73596db9d"
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                           "p": "topic",
                           "vt": "str"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "payload": "false",
                   "x": 160,
                   "y": 260,
                   "wires": [
                           "a125e6b73596db9d"
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                           "p": "topic",
                           "vt": "str"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "payload": "false",
                   "x": 140,
                   "y": 360,
                   "wires": [
                           "a125e6b73596db9d"
                   "type": "join",
                   "name": "",
                   "mode": "custom",
                   "build": "object",
                   "key": "topic",
                   "joiner": "\\n",
                   "accumulate": true,
                   "timeout": "",
                   "count": "2",
                   "reduceExp": "",
                   "reduceInit": "",
                   "reduceFixup": "",
                   "x": 390,
                   "y": 280,
                   "wires": [
                           "1bfd67d784b4d1aa",
                           "6882d7837f45f43d"
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 680,
                   "y": 100,
                   "wires": []
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "1",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 930,
                   "y": 280,
                   "wires": [
                           "f57d1411b6bc2201"
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "0",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 920,
                   "y": 180,
                   "wires": [
                           "28c26f06120965e3"
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "2",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 920,
                   "y": 380,
                   "wires": [
                           "95064fd43a97c05e"
                   "type": "comment",
                   "info": "",
                   "x": 930,
                   "y": 140,
                   "wires": []
                   "type": "comment",
                   "info": "",
                   "x": 910,
                   "y": 340,
                   "wires": []
                   "type": "comment",
                   "info": "",
                   "x": 940,
                   "y": 240,
                   "wires": []
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": true,
                   "x": 1160,
                   "y": 180,
                   "wires": []
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": true,
                   "x": 1170,
                   "y": 280,
                   "wires": []
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": true,
                   "x": 1180,
                   "y": 380,
                   "wires": []
                   "type": "switch",
                   "name": "",
                   "rules": [
                           "t": "jsonata_exp",
                           "vt": "jsonata"
                           "t": "jsonata_exp",
                           "vt": "jsonata"
                           "t": "jsonata_exp",
                           "vt": "jsonata"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 3,
                   "x": 570,
                   "y": 280,
                   "wires": [
                           "8498e01c37c203fa"
                           "492b5abd04e6b495"
                           "d9be4a146d42a968"
            ich habe das versucht nachzubauen, wenn ich in dem Join als Beispiel noch 2 weitere Kontakte( zb Fenster) hinzufüge, funktioniert es nicht mehr. In der switch node kann ich die verschieden Fenster und Türen scheinbar nicht separat auswerten.
            • mickym
              mickym Most Active @Guest last edited by mickym
              @typ1er doch das sollte gehen. Poste mal dein Objekt, das man es in eine inject-Node importieren gehen kann und deine Switch-node wenn man übrigens nur überprüfen möchte, ob irgendein Kontakt offen ist, reduziert man das Objekt wieder zu einem Zustand.
              Wenn Du generell - so mache ich das auch alle Zustände als booleans hast und die alle in einem Objekt sammelst, kannst Du die ebenfalls einfach auswerten.
              Diese 4 Nodes werten alle Booleans eines Objektes mit AND oder OR - als Change oder Switch Nodes aus.
              Hier zum Import:
                     "id": "60816370026e2141",
                     "type": "switch",
                     "z": "f270af8063daa8ba",
                     "name": "AND?",
                     "property": "$reduce(payload.*,function($i, $j){$i and $j})",
                     "propertyType": "jsonata",
                     "rules": [
                             "t": "true"
                             "t": "false"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 370,
                     "y": 380,
                     "wires": [
                     "info": "# All properties of an object must be true.\n\nAll properties of an object must be true.\n\n`{\n    \"Office\": true,\n    \"Bedroom\": true,\n    \"Living Room Balcony\": true,\n    \"Living Room Right Window\": true,\n    \"Living Room Left Window\": true\n}`\n\nis true,\n\n`{\n    \"Office\": true,\n    \"Bedroom\": false,\n    \"Living Room Balcony\": true,\n    \"Living Room Right Window\": true,\n    \"Living Room Left Window\": true\n}`\n\nis false.\n\n# Alle Eigenschaften eines Objektes müssen wahr sein\n\nAlle Eigenschaften eines Objektes müssen wahr sein.\n\n`{\n    \"Büro Balkon\": true,\n    \"Schlafzimmer Balkon\": true,\n    \"Wohnzimmer Balkon\": true,\n    \"Wohnzimmer rechtes Fenster\": true,\n    \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt true,\n\n`{\n    \"Büro Balkon\": true,\n    \"Schlafzimmer Balkon\": true,\n    \"Wohnzimmer Balkon\": true,\n    \"Wohnzimmer rechtes Fenster\": false,\n    \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt false."
                     "id": "71026038ebb3ee0d",
                     "type": "change",
                     "name": "AND ?",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "$reduce(payload.*,function($i, $j){$i and $j})",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 370,
                     "y": 420,
                     "wires": [
                     "info": "# All Property of an object must be true.\n\nAll properties of an object must be true.\n\n`{\n    \"Office\": true,\n    \"Bedroom\": true,\n    \"Living Room Balcony\": true,\n    \"Living Room Right Window\": true,\n    \"Living Room Left Window\": true\n}`\n\nis true,\n\n`{\n    \"Office\": true,\n    \"Bedroom\": false,\n    \"Living Room Balcony\": true,\n    \"Living Room Right Window\": true,\n    \"Living Room Left Window\": true\n}`\n\nis false.\n\n# Alle Eigenschaften eines Objektes müssen wahr sein\n\nAlle Eigenschaften eines Objektes müssen wahr sein.\n\n`{\n    \"Büro Balkon\": true,\n    \"Schlafzimmer Balkon\": true,\n    \"Wohnzimmer Balkon\": true,\n    \"Wohnzimmer rechtes Fenster\": true,\n    \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt true,\n\n`{\n    \"Büro Balkon\": true,\n    \"Schlafzimmer Balkon\": true,\n    \"Wohnzimmer Balkon\": true,\n    \"Wohnzimmer rechtes Fenster\": false,\n    \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt false."
                     "id": "82b0cad57098c8eb",
                     "type": "switch",
                     "name": "OR?",
                     "property": "$reduce(payload.*,function($i, $j){$i or $j})",
                     "rules": [
                             "t": "true"
                             "t": "false"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 530,
                     "y": 380,
                     "wires": [
                     "info": "# Only one or more properties of an object need to be true.\n\n Only one or more properties of an object need to be true.\n\n`{\n    \"Office\": false,\n    \"Bedroom\": false,\n    \"Living Room Balcony\": false,\n    \"Liviueng Room Right Window\": false,\n    \"Living Room Left Window\": false\n}`\n\nis false,\n\n`{\n    \"Office\": false,\n    \"Bedroom\": true,\n    \"Living Room Balcony\": false,\n    \"Living Room Right Window\": false,\n    \"Living Room Left Window\": false\n}`\n\nis true.\n\n# Mindestens eine Eigenschaft des Objektes muss wahr sein.\n\nMindestens eine Eigenschaft des Objektes muss wahr sein.\n\n`{\n    \"Büro Balkon\": false,\n    \"Schlafzimmer Balkon\": false,\n    \"Wohnzimmer Balkon\": false,\n    \"Wohnzimmer rechtes Fenster\": false,\n    \"Wohnzimmer linkes Fenster\": false\n}`\n\nergibt false,\n\n`{\n    \"Büro Balkon\": false,\n    \"Schlafzimmer Balkon\": true,\n    \"Wohnzimmer Balkon\": false,\n    \"Wohnzimmer rechtes Fenster\": false,\n    \"Wohnzimmer linkes Fenster\": false\n}`\n\nergibt true (wahr)."
                     "id": "663edf9a2bddfec1",
                     "type": "change",
                     "name": "OR ?",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "$reduce(payload.*,function($i, $j){$i or $j})",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 530,
                     "y": 420,
                     "wires": [
                     "id": "fc873ce0cd52bf75",
                     "type": "change",
                     "name": "NOT",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "$not(payload)\t",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 690,
                     "y": 400,
                     "wires": [
                A Former User last edited by
                die 2 Kontakte für ein Fenster klappen so recht gut, wenn ich jetzt in der join node die 2 Fenster und als Beispiel die Rollladenposition zusammenfüge, geht die Split Node nicht mehr, wo ist da der Fehler?
                       "id": "0e6696ffc08cbc06",
                       "type": "comment",
                       "z": "063e8e832d4bac35",
                       "name": "Sensor Oben (links)",
                       "info": "",
                       "x": 270,
                       "y": 120,
                       "wires": []
                       "id": "d7ad700377413412",
                       "type": "comment",
                       "name": "Sensor Unten (links)",
                       "info": "",
                       "x": 260,
                       "y": 220,
                       "wires": []
                       "id": "3110eb1427fd4ca7",
                       "type": "comment",
                       "name": "Sensor Oben (rechts)",
                       "info": "",
                       "x": 260,
                       "y": 320,
                       "wires": []
                       "id": "07fac73d96cc64f9",
                       "type": "comment",
                       "name": "Sensor Unten (rechts)",
                       "info": "",
                       "x": 260,
                       "y": 420,
                       "wires": []
                       "id": "cf53ff6c9887d576",
                       "type": "ioBroker in",
                       "name": "",
                       "topic": "zigbee.0.00158d0001fd5296.opened",
                       "payloadType": "value",
                       "onlyack": "update",
                       "func": "rbe",
                       "gap": "",
                       "fireOnStart": "true",
                       "outFormat": "ioBroker",
                       "x": 210,
                       "y": 80,
                       "wires": [
                               "9ecf0357e409e4fe"
                       "id": "9b76565cec5ff675",
                       "name": "",
                       "topic": "zigbee.0.00158d0001de8e2d.opened",
                       "func": "rbe",
                       "gap": "",
                       "x": 210,
                       "y": 180,
                       "wires": [
                               "50312d05e00b12df"
                       "id": "b5650d3eea88a349",
                       "name": "",
                       "topic": "zigbee.0.00158d00022bd6b1.opened",
                       "func": "rbe",
                       "gap": "",
                       "x": 210,
                       "y": 280,
                       "wires": [
                               "1d30367204c6967c"
                       "id": "b4f859a0b3efd30f",
                       "name": "",
                       "topic": "zigbee.0.00158d00022bd653.opened",
                       "func": "rbe",
                       "gap": "",
                       "x": 210,
                       "y": 380,
                       "wires": [
                               "b880b89a4cbd44cb"
                       "id": "1d30367204c6967c",
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "Fenster2oben",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 490,
                       "y": 280,
                       "wires": [
                               "88f8f0d3407a16ea"
                       "id": "b880b89a4cbd44cb",
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "Fenster2unten",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 490,
                       "y": 380,
                       "wires": [
                               "88f8f0d3407a16ea"
                       "id": "50312d05e00b12df",
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "Fenster1unten",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 490,
                       "y": 180,
                       "wires": [
                               "ef1772d95f6d4f02"
                       "id": "9ecf0357e409e4fe",
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "Fenster1oben",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 490,
                       "y": 80,
                       "wires": [
                               "ef1772d95f6d4f02"
                       "id": "88f8f0d3407a16ea",
                       "type": "join",
                       "name": "",
                       "mode": "custom",
                       "build": "object",
                       "key": "topic",
                       "joiner": "\\n",
                       "accumulate": true,
                       "timeout": "",
                       "count": "2",
                       "reduceExp": "",
                       "reduceInit": "",
                       "reduceFixup": "",
                       "x": 830,
                       "y": 320,
                       "wires": [
                               "6b72403eebc7a162",
                               "9c42920aa2d032db"
                       "id": "6b72403eebc7a162",
                       "type": "debug",
                       "name": "msg",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": true,
                       "complete": "true",
                       "targetType": "full",
                       "x": 930,
                       "y": 220,
                       "wires": []
                       "id": "c808fbfd9d8b50a9",
                       "name": "",
                       "topic": "zwave2.0.Node_004.Multilevel_Switch.currentValue",
                       "onlyack": "",
                       "func": "rbe",
                       "gap": "",
                       "x": 220,
                       "y": 540,
                       "wires": [
                               "1d423f5fc521a92c"
                       "id": "1d423f5fc521a92c",
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "currentValue",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 550,
                       "y": 540,
                       "wires": [
                       "id": "9c42920aa2d032db",
                       "type": "switch",
                       "name": "",
                       "rules": [
                               "t": "jsonata_exp",
                               "v": "payload = {\"Fenster2oben\": true,\"Fenster2unten\": false} ",
                               "vt": "jsonata"
                               "t": "jsonata_exp",
                               "v": "payload = {\"Fenster2oben\": false,\"Fenster2unten\": false} ",
                               "vt": "jsonata"
                               "t": "jsonata_exp",
                               "v": "payload = {\"Fenster2oben\": true,\"Fenster2unten\": true} ",
                               "vt": "jsonata"
                               "t": "jsonata_exp",
                               "v": "payload = {\"Fenster2oben\": false,\"Fenster2unten\": true} ",
                               "vt": "jsonata"
                       "checkall": "false",
                       "repair": false,
                       "outputs": 4,
                       "x": 990,
                       "y": 320,
                       "wires": [
                               "9b040f37641b3023"
                               "298920d373a42660"
                               "487ea6c4bad33074"
                               "40bf1833ce4dafce"
                       "id": "9b040f37641b3023",
                       "type": "change",
                       "name": "setze payload = zu",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "zu",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1230,
                       "y": 260,
                       "wires": [
                               "db55548158e7cf46"
                       "id": "298920d373a42660",
                       "type": "change",
                       "name": "setze payload = entriegelt",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "entriegelt",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1260,
                       "y": 300,
                       "wires": [
                               "db55548158e7cf46"
                       "id": "db55548158e7cf46",
                       "type": "debug",
                       "name": "",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": true,
                       "complete": "true",
                       "x": 1510,
                       "y": 300,
                       "wires": []
                       "id": "487ea6c4bad33074",
                       "type": "change",
                       "name": "setze payload = offen",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "offen",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1240,
                       "y": 340,
                       "wires": [
                               "db55548158e7cf46"
                       "id": "40bf1833ce4dafce",
                       "type": "change",
                       "name": "setze payload = gekippt",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "gekippt",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1250,
                       "y": 380,
                       "wires": [
                               "db55548158e7cf46"
                       "id": "ef1772d95f6d4f02",
                       "type": "join",
                       "name": "",
                       "mode": "custom",
                       "build": "object",
                       "key": "topic",
                       "joiner": "\\n",
                       "accumulate": true,
                       "timeout": "",
                       "count": "2",
                       "reduceExp": "",
                       "reduceInit": "",
                       "reduceFixup": "",
                       "x": 810,
                       "y": 100,
                       "wires": [
                               "bb8bd7b93c4ebcf9",
                               "e67e935145f681e3"
                       "id": "bb8bd7b93c4ebcf9",
                       "type": "debug",
                       "name": "msg",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": true,
                       "complete": "true",
                       "x": 890,
                       "y": 20,
                       "wires": []
                       "id": "d0708354332fe1bb",
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "zu",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1230,
                       "y": 40,
                       "wires": [
                               "34a60587b129cd25"
                       "id": "3506db50c7bf2b99",
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "entriegelt",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1260,
                       "y": 80,
                       "wires": [
                               "34a60587b129cd25"
                       "id": "34a60587b129cd25",
                       "type": "debug",
                       "name": "",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": true,
                       "complete": "true",
                       "x": 1510,
                       "y": 80,
                       "wires": []
                       "id": "9e045a37a0fcb511",
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "offen",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1240,
                       "y": 120,
                       "wires": [
                               "34a60587b129cd25"
                       "id": "6d6e9be994b3b2c7",
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "gekippt",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1250,
                       "y": 160,
                       "wires": [
                               "34a60587b129cd25"
                       "id": "e67e935145f681e3",
                       "type": "switch",
                       "name": "",
                       "rules": [
                               "t": "jsonata_exp",
                               "v": "payload = {\"Fenster1oben\": true,\"Fenster1unten\": false} ",
                               "vt": "jsonata"
                               "t": "jsonata_exp",
                               "v": "payload = {\"Fenster1oben\": false,\"Fenster1unten\": false} ",
                               "vt": "jsonata"
                               "t": "jsonata_exp",
                               "v": "payload = {\"Fenster1oben\": true,\"Fenster1unten\": true} ",
                               "vt": "jsonata"
                               "t": "jsonata_exp",
                               "v": "payload = {\"Fenster1oben\": false,\"Fenster1unten\": true} ",
                               "vt": "jsonata"
                       "repair": false,
                       "outputs": 4,
                       "x": 990,
                       "y": 100,
                       "wires": [
                               "d0708354332fe1bb"
                               "3506db50c7bf2b99"
                               "9e045a37a0fcb511"
                               "6d6e9be994b3b2c7"
                • mickym
                  @typ1er Die Frage ist halt ob das so Sinn macht - freilich geht es, aber das macht keinen Sinn. Die Fälle werden ja immer mehr mit der Fakultät- Sprich 2 Fensterparameter *2 + Rolladen macht doch keinen Sinn. Die Split Node so wie sie hier im Einsatz ist muss überprüft doch das GESAMTE Objekt. Sprich wenn du alles in ein Objekt überführst dann sieht das Objekt doch so aus:
                  {"Fenster1oben": true,"Fenster1unten": false,"Fenster2oben": true,"Fenster2unten": false,"currentValue" : 39}
                  das kannst Du doch nicht mit
                  payload = {"Fenster1oben": true,"Fenster1unten": false,"Fenster2oben": true,"Fenster2unten": false,"currentValue" : 39}
                  abfragen.
                  Da müsstest Du 100 * 8 = 800 Ausgänge basteln.
                  Was willst Du denn erreichen, dann können wir ggf. gemeinsam einen Flow entwickeln. Du kannst das kaskadieren, aber die Frage ist weiterhin was willst Du als Ergebnis?
                  Wobei auch Deine jetzigen Zuordnungen keinen Sinn ergeben:
                  payload = {"Fenster2oben": true,"Fenster2unten": false} (wenn openend true ist) - dann wäre oben offen und unten zu => gekippt
                  payload = {"Fenster2oben": false,"Fenster2unten": false} - beides zu => zu
                  payload = {"Fenster2oben": true,"Fenster2unten": true} -=> offen
                  payload = {"Fenster2oben": false,"Fenster2unten": true} => sollte es eigentlich nicht geben
                  Um einen sauberen Status zu erhalten - würde ich folgendes machen - allerdings weiß ich nicht ob der Rollladen für beide Fenster gilt.
                    ich wollte die Rolladensteuerung später in einen Subflow unterbringen, das ist bis auf 1 Fenster bei allen gleich. Also alle Parameter zusammenführen und im Subflow wieder trennen mit der switch Node.
                    Auswerten wollte ich den Fensterstatus, Wetter, Ausrichtung, Helligkeit und Temperatur. Um nachts das Fenster beim öffnen der Fenster in bestimmte Positionen anzufahren als auch Tagsüber das Fenster zu beschatten. Ich habe das vor ein paar Jahren mal zusammengeklickt irgendwie, in hunderten Nodes, und ist leider unübersichtlich.
                    • mickym
                      @typ1er Ist der Rollladen für ein Fenster oder für beide?
                        ein Fenster mit 2 Flügeln und 1 Rollladen
                        • mickym
                          So ich hab dir mal einen Flow gebastelt - was du mit den Rollläden machen willst weiss ich noch nicht, der Dir alle gekippten oder offenen Fenster ausschmeisst.
                                 "id": "812ed04f69c00b48",
                                 "type": "comment",
                                 "z": "7e6af0015415146d",
                                 "info": "",
                                 "x": 2190,
                                 "y": 3340,
                                 "wires": []
                                 "id": "589c4f9f3aef4e5b",
                                 "type": "comment",
                                 "info": "",
                                 "x": 2190,
                                 "y": 3480,
                                 "wires": []
                                 "id": "6878f876350c292c",
                                 "type": "comment",
                                 "info": "",
                                 "x": 2180,
                                 "y": 3600,
                                 "wires": []
                                 "id": "bbb2fea4e9fcb01e",
                                 "type": "comment",
                                 "info": "",
                                 "x": 2180,
                                 "y": 3740,
                                 "wires": []
                                 "id": "e86911a52463f3f2",
                                 "d": true,
                                 "name": "",
                                 "func": "rbe",
                                 "gap": "",
                                 "x": 2120,
                                 "y": 3260,
                                 "wires": [
                                 "id": "3c0167f3c360a51b",
                                 "d": true,
                                 "name": "",
                                 "func": "rbe",
                                 "gap": "",
                                 "x": 2130,
                                 "y": 3400,
                                 "wires": [
                                 "id": "afcd568569421914",
                                 "d": true,
                                 "name": "",
                                 "func": "rbe",
                                 "gap": "",
                                 "x": 2130,
                                 "y": 3520,
                                 "wires": [
                                 "id": "6cee51daabfd7617",
                                 "d": true,
                                 "name": "",
                                 "func": "rbe",
                                 "gap": "",
                                 "x": 2140,
                                 "y": 3660,
                                 "wires": [
                                 "id": "3228c09e88db173d",
                                 "d": true,
                                 "name": "",
                                 "onlyack": "",
                                 "func": "rbe",
                                 "gap": "",
                                 "x": 2090,
                                 "y": 3820,
                                 "wires": [
                                         "e243b1dffd4fdf21"
                                 "id": "e243b1dffd4fdf21",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 2420,
                                 "y": 3860,
                                 "wires": [
                                         "b5c59b5789c87a88",
                                         "a33ee981fb7d70b9"
                                 "id": "235355255db1e681",
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "Oben (links)",
                                 "payload": "true",
                                 "x": 2200,
                                 "y": 3300,
                                 "wires": [
                                         "d95337dbf023fddd"
                                 "id": "7fa747e333cd28ab",
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "Unten (links)",
                                 "payload": "false",
                                 "x": 2210,
                                 "y": 3440,
                                 "wires": [
                                         "c7e9225660fb24d9"
                                 "id": "22a4d618a51e1933",
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "Oben (rechts)",
                                 "payload": "true",
                                 "x": 2190,
                                 "y": 3560,
                                 "wires": [
                                         "96725fc47558807c"
                                 "id": "04298c2e449b8995",
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "Unten (rechts)",
                                 "payload": "true",
                                 "x": 2190,
                                 "y": 3700,
                                 "wires": [
                                         "cb9727a6b7952e51"
                                 "id": "4c432269faf13246",
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "rolladen_level",
                                 "payload": "99",
                                 "payloadType": "num",
                                 "x": 2200,
                                 "y": 3860,
                                 "wires": [
                                         "e243b1dffd4fdf21"
                                 "id": "c7e9225660fb24d9",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "unten",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 2420,
                                 "y": 3440,
                                 "wires": [
                                         "a33ee981fb7d70b9"
                                 "id": "d95337dbf023fddd",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "oben",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 2410,
                                 "y": 3300,
                                 "wires": [
                                         "a33ee981fb7d70b9"
                                 "id": "a33ee981fb7d70b9",
                                 "type": "join",
                                 "name": "",
                                 "mode": "custom",
                                 "build": "object",
                                 "key": "topic",
                                 "joiner": "\\n",
                                 "accumulate": true,
                                 "timeout": "",
                                 "count": "2",
                                 "reduceExp": "",
                                 "reduceInit": "",
                                 "reduceFixup": "",
                                 "x": 2610,
                                 "y": 3360,
                                 "wires": [
                                         "4dccfb9fc35d9e35"
                                 "id": "cb9727a6b7952e51",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "unten",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 2440,
                                 "y": 3700,
                                 "wires": [
                                         "b5c59b5789c87a88"
                                 "id": "96725fc47558807c",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "oben",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 2430,
                                 "y": 3560,
                                 "wires": [
                                         "b5c59b5789c87a88"
                                 "id": "b5c59b5789c87a88",
                                 "type": "join",
                                 "name": "",
                                 "mode": "custom",
                                 "build": "object",
                                 "key": "topic",
                                 "joiner": "\\n",
                                 "accumulate": true,
                                 "timeout": "",
                                 "count": "2",
                                 "reduceExp": "",
                                 "reduceInit": "",
                                 "reduceFixup": "",
                                 "x": 2630,
                                 "y": 3620,
                                 "wires": [
                                         "d89ad04521bff933"
                                 "id": "4dccfb9fc35d9e35",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "Fenster1",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 2800,
                                 "y": 3360,
                                 "wires": [
                                         "383f43197a118cdc",
                                         "d3743b846ce90f67"
                                 "id": "d89ad04521bff933",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "Fenster2",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 2800,
                                 "y": 3620,
                                 "wires": [
                                         "383f43197a118cdc"
                                 "id": "dd0d28a9a37903b7",
                                 "type": "debug",
                                 "name": "AllInOne",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 3320,
                                 "y": 3540,
                                 "wires": []
                                 "id": "d3743b846ce90f67",
                                 "type": "debug",
                                 "name": "msg",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": true,
                                 "x": 3030,
                                 "y": 3300,
                                 "wires": []
                                 "id": "6ab6c4f9ba3e354b",
                                 "type": "join",
                                 "name": "",
                                 "mode": "custom",
                                 "build": "object",
                                 "key": "topic",
                                 "joiner": "\\n",
                                 "accumulate": true,
                                 "timeout": "",
                                 "count": "1",
                                 "reduceExp": "",
                                 "reduceInit": "",
                                 "reduceFixup": "",
                                 "x": 3110,
                                 "y": 3620,
                                 "wires": [
                                         "dd0d28a9a37903b7",
                                         "50162239ecd6eab5"
                                 "id": "50162239ecd6eab5",
                                 "type": "change",
                                 "name": "Flat Array",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "$each(payload, function($v, $k) {{\"name\":$k,\"unten\":$v.unten,\"oben\":$v.oben,\"currentValue\":$v.currentValue}} )",
                                         "tot": "jsonata"
                                         "t": "delete",
                                         "p": "topic",
                                         "pt": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 3280,
                                 "y": 3620,
                                 "wires": [
                                         "6367bb8956302678",
                                         "d58bdd810c41b8ab"
                                 "id": "6367bb8956302678",
                                 "type": "debug",
                                 "name": "Array",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 3430,
                                 "y": 3680,
                                 "wires": []
                                 "id": "d58bdd810c41b8ab",
                                 "type": "change",
                                 "name": "Analyze",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "$.payload~>|$|{\"gekippt\" : oben and $not(unten), \"offen\" : oben or unten},[\"oben\",\"unten\"]|",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 3440,
                                 "y": 3620,
                                 "wires": [
                                         "7b4943647e3a242f",
                                         "c2a206e96f77d7ca",
                                         "d293b242aa3d3d75"
                                 "id": "7b4943647e3a242f",
                                 "type": "debug",
                                 "name": "Status",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 3570,
                                 "y": 3540,
                                 "wires": []
                                 "id": "c2a206e96f77d7ca",
                                 "type": "change",
                                 "name": "gekippt ?",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "payload[gekippt].name",
                                         "tot": "jsonata"
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "gekippt",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 3660,
                                 "y": 3580,
                                 "wires": [
                                         "9e65d9dd8276a7af"
                                 "id": "d293b242aa3d3d75",
                                 "type": "change",
                                 "name": "offen ?",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "payload[offen].name",
                                         "tot": "jsonata"
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "offen",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 3650,
                                 "y": 3620,
                                 "wires": [
                                         "9e65d9dd8276a7af"
                                 "id": "6b6e9a603a4269af",
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "payload": "false",
                                 "x": 2190,
                                 "y": 3980,
                                 "wires": [
                                         "fbc77afb88bf03c0"
                                 "id": "efe5b3d1b4fe6b35",
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "payload": "false",
                                 "x": 2190,
                                 "y": 4120,
                                 "wires": [
                                         "21a25a373ce4e2e8"
                                 "id": "fbc77afb88bf03c0",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "oben",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 2390,
                                 "y": 3980,
                                 "wires": [
                                         "17a150bf9f890d79"
                                 "id": "21a25a373ce4e2e8",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "unten",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 2400,
                                 "y": 4120,
                                 "wires": [
                                         "17a150bf9f890d79"
                                 "id": "17a150bf9f890d79",
                                 "type": "join",
                                 "name": "",
                                 "mode": "custom",
                                 "build": "object",
                                 "key": "topic",
                                 "joiner": "\\n",
                                 "accumulate": true,
                                 "timeout": "",
                                 "count": "2",
                                 "reduceExp": "",
                                 "reduceInit": "",
                                 "reduceFixup": "",
                                 "x": 2590,
                                 "y": 4040,
                                 "wires": [
                                         "0a49f77d7d7c4254"
                                 "id": "0a49f77d7d7c4254",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "Fenster3",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 2760,
                                 "y": 4040,
                                 "wires": [
                                         "383f43197a118cdc"
                                 "id": "69e27948be4a3958",
                                 "type": "debug",
                                 "name": "Ergebnis",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 3960,
                                 "y": 3600,
                                 "wires": []
                                 "id": "9e65d9dd8276a7af",
                                 "type": "switch",
                                 "name": "",
                                 "rules": [
                                         "t": "nnull"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 1,
                                 "x": 3810,
                                 "y": 3600,
                                 "wires": [
                                         "69e27948be4a3958"
                                 "id": "383f43197a118cdc",
                                 "type": "junction",
                                 "x": 3000,
                                 "y": 3620,
                                 "wires": [
                                         "6ab6c4f9ba3e354b"
                          Die Change Nodes kannst natürlich zusammenfassen - dient mehr der Illustration.
                          Alternativ kannst natürlich auch alles im Flow Kontext sammeln und auswerten.
                          712
