    3. Off Topic
    4. InfluxDB
    5. InfluxDB im Query unter _measurement keine Datenpunkte mehr
      A Former User @Geesthachter last edited by
      @geesthachter sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
      ich verstehe es nicht aber es kommt immer nur wieder eine Fehlermeldung
      Moin,
      dann auch mal
      influx -t "dein_token" org list
      Sehr eigenartig, erinnerst Du Dich noch wie Du das Installiert hast?
      VG
      Bernd
      G 2 Replies Last reply Reply Quote 0
        Geesthachter @Guest last edited by
        @dp20eic
        Wenn ich das richtig verstehe ist mein Token nicht korrekt?
        Incorrect Usage. flag provided but not defined: -t
        NAME:
           influx - Influx Client
        USAGE:
           influx [command]
        HINT: If you are looking for the InfluxQL shell from 1.x, run "influx v1 shell"
        COMMANDS:
           version              Print the influx CLI version
           write                Write points to InfluxDB
           bucket               Bucket management commands
           completion           Generates completion scripts
           query                Execute a Flux query
           config               Config management commands
           org, organization    Organization management commands
           delete               Delete points from InfluxDB
           user                 User management commands
           task                 Task management commands
           telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
           dashboards           List Dashboard(s).
           export               Export existing resources as a template
           secret               Secret management commands
           v1                   InfluxDB v1 management commands
           auth, authorization  Authorization management commands
           apply                Apply a template to manage resources
           stacks               List stack(s) and associated templates. Subcommands manage stacks.
           template             Summarize the provided template
           bucket-schema        Bucket schema management commands
           scripts              Scripts management commands
           ping                 Check the InfluxDB /health endpoint
           setup                Setup instance with initial user, org, bucket
           backup               Backup database
           restore              Restores a backup directory to InfluxDB
           remote               Remote connection management commands
           replication          Replication stream management commands
           server-config        Display server config
           help, h              Shows a list of commands or help for one command
        GLOBAL OPTIONS:
           --help, -h  show help
        Error: flag provided but not defined: -t
          @dp20eic
          Installiert hatte ich es so
          https://www.youtube.com/watch?v=oasYKpkIv1U
            Moin,
            nein, nur bei dem abgesetzten Befehl, den man leider nicht sieht, gibt es kein -t
            VG
            Bernd
              @dp20eic
               influx -t wW8syN4VCT9B5uboZnPjxcJqwNvY8rx0DvGpzxPVVU5w9bRs4fW5tmn4a35UdCYnC60zOcTnWoQY-7S3BhG7Fg== org list
              NAME:
              USAGE:
                 influx [command]
              COMMANDS:
              GLOBAL OPTIONS:
                Thomas Braun Most Active @Geesthachter last edited by Thomas Braun
                @geesthachter
                Ich hoffe du hast influxdb nicht so wie in dem Clip installiert sondern ein Repository reingezogen und das dann ordentlich über den Paketmanager gemacht.
                  Moin,
                  ja wie gesagt, der Befehl kennt kein flag -t daher
                  VG
                  Bernd
                  • Marc Berg
                    Marc Berg Most Active @Guest last edited by Marc Berg
                    @dp20eic sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
                    Doch, das geht schon, allerdings in der zuerst angenommenen Reihenfolge "influx org list -t <token>". Da das aber nicht funktioniert, nehme ich an, dass @Geesthachter einen Token innerhalb Organisation "A" erstellt hat und nun versucht, damit Organisation "B" zu löschen. Das geht natürlich nicht.
                    @Geesthachter: welchen Token nutzt du und wo hast du den her?
                    ? G 2 Replies Last reply Reply Quote 0
                      A Former User @Marc Berg last edited by
                      @marc-berg sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
                      Moin,
                      ja, gestern habe ich schon darüber nachgedacht, dass ich ihm vorschlage einen ganz neuen Master/admin Token zu erstellen.
                      Scheue mich aber etwas, da ich nicht schuld sein möchte, wenn es in die Hose geht.
                      https://docs.influxdata.com/influxdb/v2.7/reference/cli/influx/auth/create/#create-an-api-token-with-specified-read-and-write-permissions
                      VG
                      Bernd
                      • Marc Berg
                        Marc Berg Most Active last edited by
                        ja, das wäre sicher das Beste und man könnte die Config gleich mit glattziehen, um nicht immer wieder den Token eingeben zu müssen. Ist denn sicher, dass der Root Token nicht mehr existiert? Das konnte ich hier noch nicht herauslesen.
                        Ja, insbesondere deshalb, da ja ohne Root Token wahrscheinlich auch kein Backup existiert.
                          Geesthachter @Marc Berg last edited by
                          @marc-berg
                          Ich habe mir einmal den ursprünglichen ersten Token gesichert und dann später, frag mich nicht zu welchem Zeitpunkt und warum einen zweiten.
                          Wie gesagt ich weiß nicht wofür der zweite Token war
                          ? Marc Berg 2 Replies Last reply Reply Quote 0
                            Moin,
                            hast Du es denn dann mal mit beiden Tokens versucht?
                            VG
                            Bernd
                              @thomas-braun sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
                              @geesthachter
                              Wenn ich mich recht erinnere dann habe ich es wie hier im Video gezeigt gemacht.
                              Gibt es irgendwo eine bessere Anleitung in deutsch mit Repository und dem Paketmanager?
                              Viel Schwierigkeiten habe ich dann jedenfalls später mit der Sicherung über backitup gehabt, das hat ewig gedauert bis backitup auch die Influx Daten gesichert hat.
                              Wenn es erforderlich sein sollte das ich alles neu machen muss dann wäre ich bereit alles noch mal von vorne neu zu installieren, das bedeutet zwar in Grafana wieder viel Arbeit aber wenn dann alles läuft dann wäre mir lieber das jetzt zu machen als zu einem Zeitpunkt wo ich noch mehr Visualisierungen erstellt habe.
                              Wäre es bei einer Neuinstallation möglich die ganzen Grafana Visualisierungen irgendwie zu sichern und dann nach einem platt machen des Raspberrys wieder einzuspielen?
                                Moin,
                                VG
                                Bernd
                                ja ich habe es mit beiden versucht.
                                • Marc Berg
                                  Marc Berg Most Active @Geesthachter last edited by Marc Berg
                                  Da dieser erste Token nicht mehr funktioniert, wird er nicht mehr existieren. Entweder der Token wurde gelöscht, oder der User, unter dem der Token erstellt wurde.
                                  Was wird hier angezeigt? Insbesondere der älteste Eintrag?
                                  Edit: am besten für ALLE Organizations zeigen.
                                    @geesthachter
                                    Ist zwar jetzt OT, aber
                                    apt policy grafana influxdb*
                                    sagt?
                                      A Former User last edited by
                                      Moin,
                                      warum haben immer alle so viel Angst vor dem Englischen, ich habe mein Englisch verbessert, seit dem ich mit Computern herumspiele ~1990, mit Linux, es gab da noch so gut wie keine deutschsprachigen Bücher und das Internet lag noch im Dornröschenschlaf 🙂
                                      Der Google - Übersetzer oder die Übersetzung im Browser sollten eigentlich reichen, um die Grundgedanken zu verstehen.
                                      Anyway.
                                      Soweit mir bekannt, nutze BackitUp nicht, kann man damit Grafana und auch influxDB sichern und auch wieder zurückspielen, oder Du sicherst Dir deine Dashboards händisch.
                                      Oder
                                      ich glaube, das sollte passen https://grafana.com/docs/grafana/latest/setup-grafana/installation/debian/ aber @Thomas-Braun hat da so eine kleine geniale Sammlung von Repositorys, finde ich aber gerade nicht :
                                      Für influxDB hatte ich mal geschaut, das sollte passen, so wie es im YT Video gezeigt wurde -> https://portal.influxdata.com/downloads/
                                      # influxdata-archive_compat.key GPG fingerprint:
                                      #     9D53 9D90 D332 8DC7 D6C8 D3B9 D8FF 8E1F 7DF8 B07E
                                      wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                      echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                                      echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                      sudo apt-get update && sudo apt-get install influxdb2
                                      VG
                                      Bernd
                                        Homoran Global Moderator Administrators @Guest last edited by
                                        https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind?_=1692443708129
                                          @dp20eic
                                          Du meinst
                                          vermutlich.
                                          Ich hatte in das Video nur mal kurz reingeschaut und mich mal wieder darüber gewundert, warum ein Video gepostet wird, in dem lediglich immer wieder gezeigt wird wie mal Text von a nach b kopiert. Naja, wer es braucht...
                                          Und entweder bei grafana oder influxdb wurde da wohl nicht das Repo angelegt sondern ein deb statisch in das System gelegt. Klar, steht ja auch so blöd in der Anleitung drin. Ist aber dennoch falsch, wenn man ein Repo zur Verfügung hat.
                                            A Former User @Thomas Braun last edited by A Former User
                                            Moin,
                                            Du meinst
                                            vermutlich.
                                            Ja genau, ich sollte mir das endlich mal in die Favoriten aufnehmen 🙂
                                            @homoran sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
                                            Ja, Dnake 🙂
                                            Jup, sehe ich ja auch so, aber bei der influxDB Installation hat er tatsächlich das Repo angelegt
                                            Bei Grafana nicht, wenn ich das nicht im Schnelldurchlauf übersehen haben sollte.
                                            VG
                                            Bernd
                                            16803
