    3. Off Topic
    4. InfluxDB
    5. InfluxDB im Query unter _measurement keine Datenpunkte mehr
      Geesthachter @Thomas Braun last edited by
      @thomas-braun sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
      @geesthachter
      Das ist nur die Menükarte/Softwarequelle.
      Du musst das noch bestellen/installieren.
      sudo apt update
      sudo apt install grafana
      sudo apt update
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
      Get:7 https://apt.grafana.com stable InRelease [5,984 B]
      Get:8 https://apt.grafana.com stable/main arm64 Packages [98.6 kB]
      Get:9 https://apt.grafana.com stable/main armhf Packages [91.2 kB]
      Fetched 196 kB in 2s (86.2 kB/s)
      Reading package lists... Done
      Building dependency tree... Done
      25 packages can be upgraded. Run 'apt list --upgradable' to see them.
      pi@raspberrypi:~ $ sudo apt install grafana
      The following NEW packages will be installed:
        grafana
      0 upgraded, 1 newly installed, 0 to remove and 25 not upgraded.
      Need to get 80.4 MB of archives.
      After this operation, 302 MB of additional disk space will be used.
      Get:1 https://apt.grafana.com stable/main arm64 grafana arm64 10.0.3 [80.4 MB]
      Fetched 80.4 MB in 20s (3,938 kB/s)
      Selecting previously unselected package grafana.
      (Reading database ... 50834 files and directories currently installed.)
      Preparing to unpack .../grafana_10.0.3_arm64.deb ...
      Unpacking grafana (10.0.3) ...
      Setting up grafana (10.0.3) ...
      Adding system user `grafana' (UID 110) ...
      Adding new user `grafana' (UID 110) with group `grafana' ...
      Not creating home directory `/usr/share/grafana'.
      ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
       sudo /bin/systemctl daemon-reload
       sudo /bin/systemctl enable grafana-server
      ### You can start grafana-server by executing
       sudo /bin/systemctl start grafana-server
      pi@raspberrypi:~ $ apt policy grafana
      grafana:
        Installed: 10.0.3
        Candidate: 10.0.3
        Version table:
       *** 10.0.3 500
              500 https://apt.grafana.com stable/main arm64 Packages
              100 /var/lib/dpkg/status
           10.0.2 500
           10.0.1 500
           10.0.0 500
           9.5.8 500
           9.5.7 500
           9.5.6 500
           9.5.5 500
           9.5.3 500
           9.5.2 500
           9.5.1 500
           9.5.0 500
           9.4.13 500
           9.4.12 500
           9.4.10 500
           9.4.9 500
           9.4.7 500
           9.4.3 500
           9.4.2 500
           9.4.1 500
           9.4.0 500
           9.3.16 500
           9.3.15 500
           9.3.14 500
           9.3.13 500
           9.3.11 500
           9.3.8 500
           9.3.6 500
           9.3.4 500
           9.3.2 500
           9.3.1 500
           9.3.0 500
           9.2.20 500
           9.2.19 500
           9.2.18 500
           9.2.17 500
           9.2.15 500
           9.2.13 500
           9.2.10 500
           9.2.8 500
           9.2.7 500
           9.2.6 500
           9.2.5 500
           9.2.4 500
           9.2.3 500
           9.2.2 500
           9.2.1 500
           9.2.0 500
           9.1.8 500
           9.1.7 500
           9.1.6 500
           9.1.5 500
           9.1.4 500
           9.1.3 500
           9.1.2 500
           9.1.1 500
           9.1.0 500
           9.0.9 500
           9.0.8 500
           9.0.7 500
           9.0.6 500
           9.0.5 500
           9.0.4 500
           9.0.3 500
           9.0.2 500
           9.0.1 500
           9.0.0 500
           8.5.27 500
           8.5.26 500
           8.5.25 500
           8.5.24 500
           8.5.22 500
           8.5.21 500
           8.5.20 500
           8.5.16 500
           8.5.15 500
           8.5.14 500
           8.5.13 500
           8.5.12 500
           8.5.10 500
           8.5.9 500
           8.5.6 500
           8.5.5 500
           8.5.4 500
           8.5.3 500
           8.5.2 500
           8.5.1 500
           8.5.0 500
           8.4.11 500
           8.4.10 500
           8.4.7 500
           8.4.6 500
           8.4.5 500
           8.4.4 500
           8.4.3 500
           8.4.2 500
           8.4.1 500
           8.4.0 500
           8.3.11 500
           8.3.10 500
           8.3.7 500
           8.3.6 500
           8.3.5 500
           8.3.4 500
           8.3.3 500
           8.3.2 500
           8.3.1 500
           8.3.0 500
           8.2.7 500
           8.2.6 500
           8.2.5 500
           8.2.4 500
           8.2.3 500
           8.2.2 500
           8.2.1 500
           8.2.0 500
           8.1.8 500
           8.1.7 500
           8.1.6 500
           8.1.5 500
           8.1.4 500
           8.1.3 500
           8.1.2 500
           8.1.1 500
           8.1.0 500
           8.0.7 500
           8.0.6 500
           8.0.5 500
           8.0.4 500
           8.0.3 500
           8.0.2 500
           8.0.1 500
           8.0.0 500
           7.5.16 500
           7.5.15 500
           7.5.13 500
           7.5.12 500
           7.5.11 500
           7.5.10 500
           7.5.9 500
           7.5.8 500
           7.5.7 500
           7.5.6 500
           7.5.5 500
           7.5.4 500
           7.5.3 500
           7.5.2 500
           7.5.1 500
           7.5.0 500
           7.4.5 500
           7.4.3 500
           7.4.2 500
           7.4.1 500
           7.4.0 500
           7.3.10 500
           7.3.7 500
           7.3.6 500
           7.3.5 500
           7.3.4 500
           7.3.3 500
           7.3.2 500
           7.3.1 500
           7.3.0 500
           7.2.2 500
           7.2.1 500
           7.2.0 500
           7.1.5 500
           7.1.4 500
           7.1.3 500
           7.1.2 500
           7.1.1 500
           7.1.0 500
           7.0.6 500
           7.0.5 500
           7.0.4 500
           7.0.3 500
           7.0.2 500
           7.0.1 500
           7.0.0 500
           6.7.6 500
           6.7.5 500
           6.7.4 500
           6.7.3 500
           6.7.2 500
           6.7.1 500
           6.7.0 500
           6.6.2 500
           6.6.1 500
           6.6.0 500
           6.5.3 500
           6.5.2 500
           6.5.1 500
           6.5.0 500
           6.4.5 500
           6.4.4 500
           6.4.3 500
           6.4.2 500
           6.4.1 500
           6.4.0 500
           6.3.7 500
           6.3.6 500
           6.3.5 500
           6.3.4 500
           6.3.3 500
           6.3.2 500
           6.3.1 500
           6.3.0 500
           6.2.5 500
           6.2.4 500
           6.2.3 500
           6.2.2 500
           6.2.1 500
           6.2.0 500
           6.1.6 500
           6.1.5 500
           6.1.4 500
           6.1.3 500
           6.1.2 500
           6.1.1 500
           6.1.0 500
           6.0.2 500
           6.0.1 500
           6.0.0 500
           5.4.5 500
           5.4.4 500
           5.4.3 500
           5.4.2 500
           5.4.1 500
           5.4.0 500
           5.3.4 500
           5.3.3 500
           5.3.2 500
           5.3.1 500
           5.3.0 500
           5.2.5 500
           5.2.4 500
           5.2.3 500
           5.2.2 500
           5.2.1 500
           5.2.0 500
           0.0.0~test 500
      pi@raspberrypi:~ $ sudo reboot
        Geesthachter @Geesthachter last edited by
        oder muss ich doch erst einmal die Punkte 1 + 2 + 4 von hier installieren ?
        https://grafana.com/docs/grafana/latest/setup-grafana/installation/debian/
          Thomas Braun Most Active @Geesthachter last edited by
          @geesthachter
          Nein, außer des Pakets 'grafana' muss nichts mehr installiert werden.
          Installier die
          noch. Künftig dann regelmäßig eigenständig machen.
            @geesthachter
            Hast du die Services geladen?
              @geesthachter
              nein hatte ich nicht.
              aber jetzt.
              Jetzt startet Grafana 👍
                @geesthachter
                Gut.
                Updates auch eingespielt?
                  @geesthachter
                  Gut.
                  sudo apt update?
                    Jetzt gehe ich das erste mal nach der Installation in InfluxDb rein und finde dort jetzt zwei Buckets mit dem Namen "Iobroker" vor.
                    Auch beim Querry sind beide vorhanden
                    in einem sind keine Datenpunkte vorhanden
                    und in dem anderen sind zwar Datenpunkte vorhanden aber nicht die von meinen Sensoren
                    ? 2 Replies Last reply Reply Quote 0
                      @geesthachter sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
                      @geesthachter
                      Gut.
                      sudo apt update?
                      Immer (mindestens) ein Zweisatz:
                      sudo apt update
                      sudo apt full-upgrade
                      Je nachdem ist danach ein sauberer Neustart erforderlich.
                        @geesthachter
                        Gut.
                        sudo apt update?
                        sudo apt update
                        habe ich jetzt gemacht
                          ich habe es hinbekommen, meine Datnpunkte von den Sensoren werden jetzt angezeigt
                            Leider lassen sich meine Dashbords die ich mir gestern gesichert habe jetzt nicht wieder herstellen .
                              kann ich das löschen?
                                A Former User @Geesthachter last edited by
                                Moin,
                                bitte lesen,
                                Da steht einmal iobroker und dann Iobroker unter Unix gilt, dass man exakt sein muss, denn es wird auch die Groß-, Kleinschreibung beachtet wird.
                                Du hast einmal ein neues Bucket vom ioBroker InfluxDb Adapter anlegen lassen und dann auch das Backup eingespielt, ich Denke Dein Iobroker kommt aus dem Backup, oder Du hast Dich schon wieder bei der Einrichtung von influxDB vertippt.
                                VG
                                Bernd
                                  Moin,
                                  Lesen ist nicht Dein Ding ;), da steht doch ganz deutlich, dass Du erst eine Datenquelle auswählen musst
                                  Da Deine influxDB konfigurieren und beim Import der Dashboards dann diese Datenquelle angeben.
                                  VG
                                  Bernd
                                    Moin,
                                    wirklich jetzt, womit hat dieser Thread angefangen?
                                    https://forum.iobroker.net/topic/67637/influxdb-im-query-unter-_measurement-keine-datenpunkte-mehr
                                    Da hast Du doch mit begonnen, ich denke, wir drehen uns hier im Kreis 🙂
                                    VG
                                    Bernd
                                    P.S.: ich habe hier jetzt x-Mal Sachen geschrieben, die Du nicht oder nicht korrekt gelesen hast, ich bin dann jetzt mal raus aus dem Thread
                                      Geesthachter @Guest last edited by
                                      @dp20eic @crunchip @Homoran @Marc-Berg @Thomas-Braun
                                      Das war ein langer Tag, ich habe weil wieder etwas nicht stimmte noch einmal der Raspberry platt gemacht und alles neu installiert.
                                      Jetzt läuft alles. Sowohl Influxdb als auch Grafana.
                                      Ich habe weil die Sicherung meiner Grafan Daten nicht funktioniert hat auch bereits alle Grafana Dashbords wieder neu erstellt.
                                      Ich danke Euch allen die ihr mir mit viel Geduld und guten Tipps geholfen habt.
                                      Danke Danke Danke
                                      Gruß Björn
                                        crunchip Forum Testing Most Active @Geesthachter last edited by
                                        Dann hast du ja jetzt einiges an Informationen kennen gelernt und auch umgesetzt.
                                        Je öfter, desto mehr Routine bekommt man.
                                        Speicher dir am besten den Thread zum nachlesen
                                          Geesthachter @crunchip last edited by Geesthachter
                                          @crunchip
                                          Das stimmt, man lernt immer dazu.
                                          Wie ich vor zwei Jahren mit Iobroker angefangen habe hatte ich gar keine Ahnung von irgendwelchen Skripten und Programmierungen, da war es schon eine eine echte Herausforderung über Blockly ein Skript zu schreiben mit dem ich nur eine Lampe an und ausschalten konnte.
                                          Das Blockly Skript hatte ich ja dank der Hilfe von Beiträgen und Videos noch hin bekommen aber nirgends wurde man darauf hingewiesen das man solch ein Skript dann auch noch starten muss 🙄
                                          Oft fehlt halt nur ein ganz bisschen.
                                          Inzwischen habe ich nun das ganze Haus mit Smarthome ausgestattet und das nicht nur mit Lampen sondern auch Rollläden, Alarmanlage, Klimaanlage, Kameras und vieles mehr. Anfangs mit Vis inzwischen mit iQobtrol, was mir wesentlich besser gefällt, Ich habe mittlerweile weit über 100 Aktoren verbaut und das meiste lässt sich auch über Sprachsteuerung bedienen.
                                          Aber es kommen immer wieder neue Herausforderungen von denen ich dann wieder gar keine Ahnung habe und wo ich mich dann per Google, Youtube und Hilfe aus dem Forum rein wurschtel, so wie jetzt influxdb und Grafana. Bei solch neuen Sachen bin ich dann immer sehr froh wenn ich, so wie jetzt solch tolle Hilfe bekomme.
                                          Wenn man erst einmal mit der Materie vertraut ist, ist es dann alles einfach und selbstverständlich aber bis dahin ist es oft ein sehr steiniger schwerer Weg.
                                          Vielen Dank nochmals an alle die mir geholfen haben
                                          Gruß Björn
                                            Geesthachter last edited by Geesthachter
                                            @crunchip @dp20eic
                                            Ich habe noch eine Frage,
                                            bei meine Rollläden hätte ich es gerne das nur tatsächliche Änderungen angezeigt werden. Momentan sieht das leider so aus. Wie kann ich das machen?
                                            1.0k
                                            16823
