    4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
      Malz1902 @Malz1902 last edited by
      @malz1902 said in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
      Cannot find module 'cron-parser'
      host.iobroker
      	2023-08-01 08:53:36.334	warn	adapter "device-watcher" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
      Node.js
      v16.20.1
      soll ich auf 18 gehen?
      hmm okay mit nodejs geht es auch nicht
        A Former User @Malz1902 last edited by
        @malz1902 sollte auch egal sein angegeben ist das es bei 16, 18 und 20 gehen soll. Nur 14 wurde entfernt. Besteht der Fehler weiterhin wenn du auf Version 2.9.2 gehst?
          Malz1902 @Guest last edited by
          @ciddi89 bin runter bis Version 2.8.2. immer der gleiche Fehler:
          host.iobroker
          	2023-08-01 09:24:22.173	error	instance system.adapter.device-watcher.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: Node.js v18.17.0
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: }
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.device-watcher/main.js' ]
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.device-watcher/main.js:11:20)
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.device-watcher/main.js
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: Require stack:
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: Error: Cannot find module 'cron-parser'
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: ^
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: throw err;
          host.iobroker
          	2023-08-01 09:24:22.173	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
            Habe in der Javascript Instanz jetzt cron-parser als npm Modul angegeben, dann geht es
              @malz1902 hmm okay... Evtl wurde das Modul von einem anderen Adapter gelöscht oder so? Ist nur komisch, normalerweise sollte er das neu laden wenn der Adapter neu installiert wird.
              • FredF
                FredF Most Active Forum Testing last edited by
                @ciddi89 Ich habe nichts gefunden darüber... vielleicht auch falsch gesucht...
                Der ble Adapter hat den Datenpunkt ble.0.info.driverState, überwacht dein Adapter den auch?
                Bei Updates geht der gerne vom Status poweredOn auf unauthorized und empfängt dann keine Daten mehr.
                 "_id": "ble.0.info.driverState",
                 "type": "state",
                 "common": {
                   "role": "indicator.state",
                   "name": "bluetooth driver state",
                   "desc": "The current state of the bluetooth driver",
                   "type": "string",
                   "read": true,
                   "write": false,
                   "def": "poweredOff"
                 "native": {},
                 "from": "system.adapter.ble.0",
                 "ts": 1691677391808,
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                   "owner": "system.user.admin",
                 "user": "system.user.admin"
                  A Former User @FredF last edited by
                  @fredf ne den überwacht der Adapter nicht. Sollte dann aber nicht besser der Ble Adapter auf ‚Nicht verbunden mit Gerät oder Dienst‘ gehen? Nutze selber Ble nicht mehr in Verbindung mit iobroker daher weiß ich nicht mehr ob der das dann so macht. Ich glaube nicht, wäre aber meiner Meinung sinnvoller.
                  • FredF
                    FredF Most Active Forum Testing @Guest last edited by
                    @ciddi89 ok muss ich mal beobachten. Mache dann ein issue beim ble Adapter auf
                      jerzimeik last edited by
                      ich habe den Adapter über Github installiert und bekomme nach dem Starten des Adapters folgende Fehlermeldung:
                      Im Javascript-Adapter habe ich den Eintrag gesetzt:
                      Wo könnte noch der Fehler liegen?
                      da_Woody Merlin123 crunchip 3 Replies Last reply Reply Quote 0
                      • da_Woody
                        da_Woody @jerzimeik last edited by
                        @jerzimeik keine Screenshots von logs.
                        Die gehören kopiert und in codetags eingefügt.
                        • Merlin123
                          Merlin123 @jerzimeik last edited by
                          @jerzimeik Die neu 2er Version läuft nur mit js-controller > 5.0. Welchen js-controller hast Du im Einsatz?
                            crunchip Forum Testing Most Active @jerzimeik last edited by
                            @jerzimeik sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                            ist normalerweise gar nicht nötig
                            nodejs 18.11 ist mittlerweile auch nicht mehr der neuste Stand, da du aus deinem anderen Thread auch Probleme hast, shelly im iot hinzu zu fügen, zeig mal die Ausgabe von iob diag
                              jerzimeik last edited by jerzimeik
                              iob upgrade self
                              bringt komischerweise auch nichts Neues.
                              Die Ausgabe von iob diag :
                                                   v.2023-04-16
                              Operatingsystem:        Ubuntu 21.04
                              Kernel:                 5.11.22-4-pve
                              Installation:           lxc
                              Timezone:               Europe/Berlin (CEST, +0200)
                              User-ID:                0
                              X-Server:               false
                              Boot Target:            graphical.target
                              Pending OS-Updates:     0
                              Pending iob updates:    0
                              Nodejs-Installation:    /usr/bin/nodejs         v18.11.0
                                                      /usr/bin/node           v18.11.0
                                                      /usr/bin/npm            8.19.2
                                                      /usr/bin/npx            8.19.2
                              Recommended versions are nodejs 18.x.y and npm 9.x.y
                              MEMORY:
                              Mem:           7.7G        156M        6.4G          0B        1.2G        7.6G
                              Swap:          7.2G        2.0M        7.2G
                              Total:          14G        159M         13G
                              Active iob-Instances:   2
                              Active repo(s): stable
                              ioBroker Core:          js-controller           4.0.24
                                                      admin                   6.8.0
                              ioBroker Status:        iobroker is not running on this host.
                              Objects type: jsonl
                              States  type: jsonl
                                system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
                                system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
                                system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              Objects:                57729
                              States:                 43526
                              Size of iob-Database:
                              65M     /opt/iobroker/iobroker-data/objects.jsonl
                              35M     /opt/iobroker/iobroker-data/objects.json.migrated
                              35M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              90M     /opt/iobroker/iobroker-data/states.jsonl
                              5.7M    /opt/iobroker/iobroker-data/states.json.migrated
                              5.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                              • DJMarc75
                                DJMarc75 @jerzimeik last edited by
                                Ubuntu 21.04
                                Hat seit Januar 2022 das EOL erreicht.
                                v18.11.0
                                18.17.1 ist aktuell.
                                Da würde ich als erstes mal ansetzen.
                                  Nach
                                  sudo apt purge --autoremove nodejs* npm node-*
                                  und
                                  curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash
                                  sudo apt install nodejs
                                  sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                  bleibt aber die Version
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  /usr/bin/npx
                                  v18.11.0
                                  v18.11.0
                                  8.19.2
                                  8.19.2
                                  Vorher habe ich natürlich apt update und apt upgrade gemacht.
                                  JLeg DJMarc75 2 Replies Last reply Reply Quote 0
                                  • JLeg
                                    JLeg @jerzimeik last edited by
                                    @jerzimeik ...die Antwort hierauf wird in der Ausgabe deiner o.g. Kommandos stehen...
                                    Btw, die "offiziell" der nodejs-V18 zugeordnete npm-Version ist "9.x" - d.h. deine 8.x ist schonmal ziemlich daneben. Siehe auch https://nodejs.org/en/download/releases
                                    • DJMarc75
                                      @jerzimeik mach das nach folgender Anleitung
                                      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                                      aber bitte nicht in diesem Beitrag weiter kommunizieren - hier gehts um den Adapter 😉
                                      • Merlin123
                                        Merlin123 last edited by Merlin123
                                        Hmmm... Irgendwie mag der Adapter seit 2.x nicht mehr.
                                        Vielleicht steh ich aber auch grad auf dem Schlauch...
                                        Ich habe meine Spülmaschine neu eingetragen. DPs für Verbrauch und Schalten stimmen, in den DPs des Adapters sehe ich die richtige Live comsumption. Das Starten bekommt er auch richtig mit, aber das Beenden nicht.
                                        Die spülmaschine zieht 0W und ist aus, der Adapter zeigt auch 0W an, sagt aber weiterhin "in action".
                                        Was mach ich denn da falsch? Beim alten Adapter lief das.
                                        Edit: nach so 15 Minuten hat der Adapter gemerkt, dass sie fertig ist
                                        • da_Woody
                                          da_Woody @Merlin123 last edited by
                                          @merlin123 sorry, wir quatschen noch im alten fred.
                                          https://forum.iobroker.net/topic/40573/test-adapter-device-reminder-v-1-x/554
                                          der sollte eigentlich geschlossen werden...
                                          • Merlin123
                                            Merlin123 @da_Woody last edited by
                                            @da_woody ok. Poste ich dort nochmal 🙂
                                            1461
                                            497462
