    4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
      A Former User @Malz1902 last edited by
      @malz1902 sollte auch egal sein angegeben ist das es bei 16, 18 und 20 gehen soll. Nur 14 wurde entfernt. Besteht der Fehler weiterhin wenn du auf Version 2.9.2 gehst?
        Malz1902 @Guest last edited by
        @ciddi89 bin runter bis Version 2.8.2. immer der gleiche Fehler:
        host.iobroker
        	2023-08-01 09:24:22.173	error	instance system.adapter.device-watcher.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: Node.js v18.17.0
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: }
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.device-watcher/main.js' ]
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.device-watcher/main.js:11:20)
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.device-watcher/main.js
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: Require stack:
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: Error: Cannot find module 'cron-parser'
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: ^
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: throw err;
        host.iobroker
        	2023-08-01 09:24:22.173	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
          Malz1902 @Malz1902 last edited by
          Habe in der Javascript Instanz jetzt cron-parser als npm Modul angegeben, dann geht es
            @malz1902 hmm okay... Evtl wurde das Modul von einem anderen Adapter gelöscht oder so? Ist nur komisch, normalerweise sollte er das neu laden wenn der Adapter neu installiert wird.
            • FredF
              FredF Most Active Forum Testing last edited by
              @ciddi89 Ich habe nichts gefunden darüber... vielleicht auch falsch gesucht...
              Der ble Adapter hat den Datenpunkt ble.0.info.driverState, überwacht dein Adapter den auch?
              Bei Updates geht der gerne vom Status poweredOn auf unauthorized und empfängt dann keine Daten mehr.
               "_id": "ble.0.info.driverState",
               "type": "state",
               "common": {
                 "role": "indicator.state",
                 "name": "bluetooth driver state",
                 "desc": "The current state of the bluetooth driver",
                 "type": "string",
                 "read": true,
                 "write": false,
                 "def": "poweredOff"
               "native": {},
               "from": "system.adapter.ble.0",
               "ts": 1691677391808,
               "acl": {
                 "object": 1636,
                 "state": 1636,
                 "owner": "system.user.admin",
               "user": "system.user.admin"
                A Former User @FredF last edited by
                @fredf ne den überwacht der Adapter nicht. Sollte dann aber nicht besser der Ble Adapter auf ‚Nicht verbunden mit Gerät oder Dienst‘ gehen? Nutze selber Ble nicht mehr in Verbindung mit iobroker daher weiß ich nicht mehr ob der das dann so macht. Ich glaube nicht, wäre aber meiner Meinung sinnvoller.
                • FredF
                  FredF Most Active Forum Testing @Guest last edited by
                  @ciddi89 ok muss ich mal beobachten. Mache dann ein issue beim ble Adapter auf
                    jerzimeik last edited by
                    ich habe den Adapter über Github installiert und bekomme nach dem Starten des Adapters folgende Fehlermeldung:
                    Im Javascript-Adapter habe ich den Eintrag gesetzt:
                    Wo könnte noch der Fehler liegen?
                    da_Woody Merlin123 crunchip 3 Replies Last reply Reply Quote 0
                    • da_Woody
                      da_Woody @jerzimeik last edited by
                      @jerzimeik keine Screenshots von logs.
                      Die gehören kopiert und in codetags eingefügt.
                      • Merlin123
                        Merlin123 @jerzimeik last edited by
                        @jerzimeik Die neu 2er Version läuft nur mit js-controller > 5.0. Welchen js-controller hast Du im Einsatz?
                          crunchip Forum Testing Most Active @jerzimeik last edited by
                          @jerzimeik sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                          ist normalerweise gar nicht nötig
                          nodejs 18.11 ist mittlerweile auch nicht mehr der neuste Stand, da du aus deinem anderen Thread auch Probleme hast, shelly im iot hinzu zu fügen, zeig mal die Ausgabe von iob diag
                            jerzimeik last edited by jerzimeik
                            iob upgrade self
                            bringt komischerweise auch nichts Neues.
                            Die Ausgabe von iob diag :
                                                 v.2023-04-16
                            Operatingsystem:        Ubuntu 21.04
                            Kernel:                 5.11.22-4-pve
                            Installation:           lxc
                            Timezone:               Europe/Berlin (CEST, +0200)
                            User-ID:                0
                            X-Server:               false
                            Boot Target:            graphical.target
                            Pending OS-Updates:     0
                            Pending iob updates:    0
                            Nodejs-Installation:    /usr/bin/nodejs         v18.11.0
                                                    /usr/bin/node           v18.11.0
                                                    /usr/bin/npm            8.19.2
                                                    /usr/bin/npx            8.19.2
                            Recommended versions are nodejs 18.x.y and npm 9.x.y
                            MEMORY:
                            Mem:           7.7G        156M        6.4G          0B        1.2G        7.6G
                            Swap:          7.2G        2.0M        7.2G
                            Total:          14G        159M         13G
                            Active iob-Instances:   2
                            Active repo(s): stable
                            ioBroker Core:          js-controller           4.0.24
                                                    admin                   6.8.0
                            ioBroker Status:        iobroker is not running on this host.
                            Objects type: jsonl
                            States  type: jsonl
                              system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
                              system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
                              system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            Objects:                57729
                            States:                 43526
                            Size of iob-Database:
                            65M     /opt/iobroker/iobroker-data/objects.jsonl
                            35M     /opt/iobroker/iobroker-data/objects.json.migrated
                            35M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                            90M     /opt/iobroker/iobroker-data/states.jsonl
                            5.7M    /opt/iobroker/iobroker-data/states.json.migrated
                            5.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                            • DJMarc75
                              DJMarc75 @jerzimeik last edited by
                              Ubuntu 21.04
                              Hat seit Januar 2022 das EOL erreicht.
                              v18.11.0
                              18.17.1 ist aktuell.
                              Da würde ich als erstes mal ansetzen.
                                Nach
                                sudo apt purge --autoremove nodejs* npm node-*
                                und
                                curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash
                                sudo apt install nodejs
                                sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                bleibt aber die Version
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                /usr/bin/npx
                                v18.11.0
                                v18.11.0
                                8.19.2
                                8.19.2
                                Vorher habe ich natürlich apt update und apt upgrade gemacht.
                                JLeg DJMarc75 2 Replies Last reply Reply Quote 0
                                • JLeg
                                  JLeg @jerzimeik last edited by
                                  @jerzimeik ...die Antwort hierauf wird in der Ausgabe deiner o.g. Kommandos stehen...
                                  Btw, die "offiziell" der nodejs-V18 zugeordnete npm-Version ist "9.x" - d.h. deine 8.x ist schonmal ziemlich daneben. Siehe auch https://nodejs.org/en/download/releases
                                  • DJMarc75
                                    @jerzimeik mach das nach folgender Anleitung
                                    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                                    aber bitte nicht in diesem Beitrag weiter kommunizieren - hier gehts um den Adapter 😉
                                    • Merlin123
                                      Merlin123 last edited by Merlin123
                                      Hmmm... Irgendwie mag der Adapter seit 2.x nicht mehr.
                                      Vielleicht steh ich aber auch grad auf dem Schlauch...
                                      Ich habe meine Spülmaschine neu eingetragen. DPs für Verbrauch und Schalten stimmen, in den DPs des Adapters sehe ich die richtige Live comsumption. Das Starten bekommt er auch richtig mit, aber das Beenden nicht.
                                      Die spülmaschine zieht 0W und ist aus, der Adapter zeigt auch 0W an, sagt aber weiterhin "in action".
                                      Was mach ich denn da falsch? Beim alten Adapter lief das.
                                      Edit: nach so 15 Minuten hat der Adapter gemerkt, dass sie fertig ist
                                      • da_Woody
                                        da_Woody @Merlin123 last edited by
                                        @merlin123 sorry, wir quatschen noch im alten fred.
                                        https://forum.iobroker.net/topic/40573/test-adapter-device-reminder-v-1-x/554
                                        der sollte eigentlich geschlossen werden...
                                        • Merlin123
                                          Merlin123 @da_Woody last edited by
                                          @da_woody ok. Poste ich dort nochmal 🙂
                                          • da_Woody
                                            @merlin123 oops, hab ich 2 adapter durcheinander gebracht!
                                            1461
                                            497895
