    4. Nach Systemaktualisierung Modbus Fehler 25
    • Fabio
      Fabio @Dooley_76 last edited by
      @dooley_76 setze die Ausgabe bitte in die Code Tags </> damit man das lesen kann.
        Dooley_76 @Fabio last edited by
        @fa-bio
        Irgendwas scheint da gerade bei der Übertragung nicht gefunzt zu haben, also hier nochmal
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 3 Model B Plus Rev 1.3
        Architecture    : armv7l
        Docker          : false
        Virtualization  : none
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 11 (bullseye)
        Release:        11
        Codename:       bullseye
        PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         11:25:29 up 9 min,  1 user,  load average: 0.26, 0.26, 0.18
        CPU threads: 4
        Raspberry only:
        throttled=0x80000
        Other values than 0x0 hint to temperature/voltage problems
        temp=53.7'C
        volt=1.3875V
        *** Time and Time Zones ***
                       Local time: Tue 2023-08-22 11:25:30 BST
                   Universal time: Tue 2023-08-22 10:25:30 UTC
                         RTC time: n/a
                        Time zone: Europe/London (BST, +0100)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            971M         56M        498M        0.0K        415M        849M
        Swap:            99M          0B         99M
        Total:          1.1G         56M        598M
                  971 M total memory
                   56 M used memory
                  215 M active memory
                  165 M inactive memory
                  498 M free memory
                   56 M buffer memory
                  359 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4       29G  3.0G   25G  11% /
        devtmpfs       devtmpfs  358M     0  358M   0% /dev
        tmpfs          tmpfs     486M     0  486M   0% /dev/shm
        tmpfs          tmpfs     195M  920K  194M   1% /run
        /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
        tmpfs          tmpfs      98M     0   98M   0% /run/user/1000
        [Tue Aug 22 11:16:15 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        data mode. Quota mode: none.
        [Tue Aug 22 11:16:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Tue Aug 22 11:16:21 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        353M    /var/
        94M     /var/lib
        90M     /var/log
        89M     /var/log/journal/97dfd2004a894a86ab647e0fbc98a3a4
        Archived and active journals take up 88.0M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        251M    /opt/iobroker/iobroker-data/
        245M    /opt/iobroker/iobroker-data/files
        88M     /opt/iobroker/iobroker-data/files/echarts.admin
        57M     /opt/iobroker/iobroker-data/files/echarts
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
        17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
        17M     /opt/iobroker/iobroker-data/files/echarts.admin/preview/static/js/main.1b04901d.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        MULTIHOSTSERVICE/enabled: false
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.8.0
        javascript:     7.0.3
        Adapters from github:   0
        Adapter State
          system.adapter.admin.0                  : admin                 : iobroker-pi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                                                 n
          system.adapter.backitup.0               : backitup              : iobroker-pi        -  enabled
          system.adapter.chromecast.0             : chromecast            : iobroker-pi        -  enabled
          system.adapter.discovery.0              : discovery             : iobroker-pi        -  enabled
          system.adapter.echarts.0                : echarts               : iobroker-pi        -  enabled
          system.adapter.influxdb.0               : influxdb              : iobroker-pi        -  enabled, port: 8086
          system.adapter.jarvis.0                 : jarvis                : iobroker-pi        -  enabled
          system.adapter.javascript.0             : javascript            : iobroker-pi        -  enabled
          system.adapter.net-tools.0              : net-tools             : iobroker-pi        - disabled
          system.adapter.ping.0                   : ping                  : iobroker-pi        - disabled
          system.adapter.synology.0               : synology              : iobroker-pi        - disabled, port: 5000
          system.adapter.vis.0                    : vis                   : iobroker-pi        -  enabled
          system.adapter.web.0                    : web                   : iobroker-pi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi                                                 n
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.8.0    , installed 6.8.0
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "echarts"      : 1.5.1    , installed 1.5.1
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "synology"     : 2.1.13   , installed 2.1.13
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Objects and States
        Objects:        314
        States:         240
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode    PID/Program name
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13764    467/sshd: /usr/sbin
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13766    467/sshd: /usr/sbin
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12641    332/avahi-daemon: r
        udp        0      0 0.0.0.0:41423           0.0.0.0:*                           108        12643    332/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11103    663/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        12642    332/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          12686    663/dhcpcd
        udp6       0      0 :::34871                :::*                                108        12644    332/avahi-daemon: r
        2023-08-22 11:17:00.108  - warn: host.iobroker-pi instance system.adapter.jarvis.0 terminated due to SIGTERM
        2023-08-22 11:17:00.106  - info: chromecast.0 (770) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-08-22 11:17:00.109  - info: host.iobroker-pi instance system.adapter.jarvis.0 terminated with code null ()
        2023-08-22 11:17:00.114  - info: javascript.0 (750) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-08-22 11:17:00.115  - info: host.iobroker-pi stopInstance system.adapter.admin.0 send kill signal
        2023-08-22 11:17:00.116  - info: host.iobroker-pi stopInstance system.adapter.javascript.0 send kill signal
        2023-08-22 11:17:00.117  - info: host.iobroker-pi stopInstance system.adapter.chromecast.0 send kill signal
        2023-08-22 11:17:00.117  - info: host.iobroker-pi stopInstance system.adapter.discovery.0 send kill signal
        2023-08-22 11:17:00.118  - info: host.iobroker-pi stopInstance system.adapter.backitup.0 send kill signal
        2023-08-22 11:17:00.118  - info: host.iobroker-pi stopInstance system.adapter.web.0 send kill signal
        2023-08-22 11:17:00.119  - info: host.iobroker-pi stopInstance system.adapter.echarts.0 send kill signal
        2023-08-22 11:17:00.119  - info: host.iobroker-pi stopInstance system.adapter.jarvis.0 send kill signal
        2023-08-22 11:17:00.159  - info: web.0 (837) terminated http server on port 8082
        2023-08-22 11:17:00.171  - info: web.0 (837) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-08-22 11:17:00.496  - info: echarts.0 (925) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-08-22 11:17:00.787  - info: host.iobroker-pi instance system.adapter.influxdb.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-08-22 11:17:00.819  - info: host.iobroker-pi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-08-22 11:17:00.890  - info: host.iobroker-pi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-08-22 11:17:00.892  - info: host.iobroker-pi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-08-22 11:17:00.893  - info: host.iobroker-pi instance system.adapter.chromecast.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-08-22 11:17:00.929  - info: host.iobroker-pi instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-08-22 11:17:00.958  - info: host.iobroker-pi instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-08-22 11:17:01.059  - info: host.iobroker-pi instance system.adapter.echarts.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-08-22 11:17:01.060  - info: host.iobroker-pi All instances are stopped.
        2023-08-22 11:17:01.263  - info: host.iobroker-pi terminated
        Fabio Thomas Braun 2 Replies Last reply Reply Quote 0
        • Fabio
          @dooley_76 okay ich glaube da sollte mal @Thomas-Braun drüber schauen.
            Thomas Braun Most Active @Dooley_76 last edited by
            @dooley_76 sagte in Nach Systemaktualisierung Modbus Fehler 25:
            Frisch aufgesetzt? Ich hätte da dann die 64bit-Version genommen.
            Raspberry only:
            throttled=0x80000
            Original Netzteil in Verwendung? Das scheint mir zuviel Spannung zu sein.
            Vermutlich die falsche Zeitzone, oder hockst du auf der Insel?
            Ansonsten läuft da keine einzige Instanz.
            Was sagt:
            iobroker add modbus --host iobroker-pi --debug
              @fa-bio
              Ok, dann warten wir mal ab ...
              Hier noch ein paar Randinformationen, falls die helfen und sich somit hoffentlich keiner unnötig auf einen "Irrweg" begibt:
              Aktuell:
              • Installation des Images von buanet: https://github.com/buanet/ioBroker.raspberry-os/releases
              Nach der Installation des Images habe ich mich dann mit Thomas Braun seiner Anleitung weiter gemacht, was die Installation node betrifft: https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
              Leider war es mir nicht möglich, IOBroker manuell zu installieren, da er IMMER mit einem Fehler abgebrochen hat.
              Ich weiß die Meldung nicht mehr aus dem Kopf, aber irgendwas mit ... tree ... Im Zweifel kann ich die SD-Karte noch einmal löschen und den Fehler nachstellen, wenn wir so nicht weiter kommen.
              Gehalten habe ich mich dabei an folgende Anleitung: https://www.iobroker.net/#de/documentation/install/nodejs.md
              Vorher habe ich noch das aktuelle Raspberry Image Lite (64bit) per PI Imager aufgespielt.
              Das hat dann auch alles soweit geklappt, alles war auf aktuellem Stand. Nur die Adapter (alle) lassen sich nicht installieren. Alle brechen mit Code 25 ab.
              Hier übrigens noch die Struktur:
              pi @iobroker-pi: ~$ uname - m && type - P nodejs node npm npx corepack && nodejs - v && node - v && npm - v && npx - v && corepack - v && iob - v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              armv7l
                  / usr / bin / nodejs
                  / usr / bin / node
                  / usr / bin / npm
                  / usr / bin / npx
                  / usr / bin / corepack
              v18.17.1
              v18.17.1
              9.6.7
              9.6.7
              0.18.0
              4.0.24
              pi
              tty
                  / home / pi
              Hit: 1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit: 2 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit: 3 https://deb.nodesource.com/node_18.x bullseye InRelease
              Reading package lists...Done
              Building dependency tree...Done
              Reading state information...Done
              All packages are up to date.
                  nodejs:
              Installed: 18.17.1 - deb - 1nodesource1
              Candidate: 18.17.1 - deb - 1nodesource1
                Version table:
               *** 18.17.1 - deb - 1nodesource1 500
              100 /var/lib/dpkg / status
              12.22.12~dfsg - 1~deb11u4 500
              Ich hoffe ich habe keinen "Dummy-Fehler" begangen ... 😉
              Danke Euch schon einmal im voraus für Eure Mühen ...
              Holger
                Dooley_76 @Thomas Braun last edited by
                Original-Netzteil: Nein, damit habe ich immer Unterspannungsfehler bekommen, welche ich jetzt teilweise auch nocht hatte
                Zeitzone: Hatte ich eigentlich eingestellt, aber ich prüfe es nochmal, vielleicht habe ich ja die falsche erwischt.
                Hier noch die Ausgabe Deiner Anfrage:
                pi @iobroker-pi: ~$ iobroker add modbus--host iobroker - pi--debug
                NPM version: 9.6.7
                Installing iobroker.modbus@5.0.11... (System call)
                npm ERR! code ECONNREFUSED
                npm ERR! syscall connect
                npm ERR! errno ECONNREFUSED
                npm ERR! FetchError: request to https://registry.npmjs.org/iobroker.modbus failed, reason: connect ECONNREFUSED 2606:4700::6810:622:443
                npm ERR!     at ClientRequest.< anonymous > (/usr/lib / node_modules / npm / node_modules / minipass - fetch / lib / index.js: 130: 14)
                npm ERR!     at ClientRequest.emit(node: events: 514: 28)
                npm ERR!     at TLSSocket.socketErrorListener(node: _http_client: 501: 9)
                npm ERR!     at TLSSocket.emit(node: events: 526: 35)
                npm ERR!     at emitErrorNT(node: internal / streams / destroy: 151: 8)
                npm ERR!     at emitErrorCloseNT(node: internal / streams / destroy: 116: 3)
                npm ERR!     at process.processTicksAndRejections(node: internal / process / task_queues: 82: 21)
                npm ERR!     at process.processTicksAndRejections(node: internal / process / task_queues: 82: 21) {
                npm ERR!   code: 'ECONNREFUSED',
                        npm ERR!   errno: 'ECONNREFUSED',
                            npm ERR!   syscall: 'connect',
                                npm ERR!   address: '2606:4700::6810:622',
                                    npm ERR!   port: 443,
                                        npm ERR!   type: 'system',
                                            npm ERR!   requiredBy: '.'
                npm ERR!
                npm ERR!
                npm ERR! If you are behind a proxy, please make sure that the
                npm ERR! 'proxy' config is set properly.See: 'npm help config'
                npm ERR! A complete log of this run can be found in: /home/iobroker /.npm / _logs / 2023 - 08 - 22T11_21_24_839Z - debug - 0.log
                host.iobroker - pi Cannot install iobroker.modbus@5.0.11: 1
                Danke,
                Gruß Holger
                  Homoran Global Moderator Administrators @Dooley_76 last edited by Homoran
                  das wird im von @fa-bio verlinkten Beitrag zum Error 25 gefixt
                    Dooley_76 @Homoran last edited by
                    Danke, den hatte ich auch gefunden und probiert: ( https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/2 )
                    leider ohne Erfolg 😞
                    Holger
                      Thomas Braun Most Active @Dooley_76 last edited by Thomas Braun
                      @dooley_76
                      Ich würde die Kiste nochmal ganz neu aufsetzen. Keine iob-Images, keine manuelle Installation von nodejs usw, dafür direkt mit einem user, der weder pi noch iobroker heißt und mit der richtigen Zeitzone:
                      https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                      Da ist auch was beim Netzwerk 'krumm'. Kann sein, dass da schon die falsche Zeitzone reinspielt.
                        Ok, dann mache ich das mal. Hab es jetzt schon so oft gemacht, da kommt es auf einmal mehr auch nicht mehr an ;))
                        Danke und ich melde mich dann wieder zwecks Rückmeldung ...
                        Holger
                          @dooley_76
                          Aber irgendwas machst du falsch, denn
                          führt nicht zu armv7l. Das ist die 32bit-Version.
                            Da habe ich mich vielleicht unglücklich bzw. falsch ausgedrückt:
                            Ich habe es einmal mit dem "original" Image per Imager versucht (Raspberry 64bit Lite)
                            und dann versucht IOBroker zu installieren, was dann ja immer nicht funktioniert hat.
                            Danach erst habe ich das Image genommen, welches jetzt läuft und das ist wohl kein 64bit.
                            Holger
                              Warum nicht?
                              Hier nach geht das:
                                Hallo Thomas,
                                vielleicht habe ich bei der letzten Installation eine andere Anleitung bzw. andere Befehle benutzt, die da standen. Ganz sicher bin ich mir aber mittlerweile nicht mehr. Ich habe den Pi jetzt seit heute morgen bestimmt schon 10-15 mal neu installiert, immer wieder mit anderen Anleitungen/Wegen/Versuchen, bis ich mich in meiner Verzweiflung an Euch gewandt habe.
                                Aber ich bin gerade dabei, es jetzt noch einmal nach Deiner Anleitung zu machen und werde ich auch strikt daran halten 😉
                                Ich geb' Bescheid ...
                                Holger
                                P.S.: Wenn das dann wirklich gleich laufen sollte mach' ich alles aus, nimm' mir ein Bier, setz' mich nach draußen und heul 😄
                                  Dooley_76 @Dooley_76 last edited by
                                  @dooley_76
                                  Jetzt bin ich ja "beruhigt" ;)) Ich hänge wieder da, wo es vorher auch schon nicht weiter ging, wenn ich IOBroker ( per curl -sLf https://iobroker.net/install.sh | bash - ) aufspiele:
                                  Wenn ich nichts mache, geht es nach ~ 5-6 Minuten "weiter" und es kommt dieses hier:
                                  Holger @raspberryiobroker: ~$ curl - sLf https://iobroker.net/install.sh | bash -
                                  library: loaded
                                  Library version = 2022 - 12 - 09
                                      Welcome to the ioBroker installer!
                                      Installer version: 2023-04-16
                                      You might need to enter your password a couple of times.
                                      Installing prerequisites (1/4)
                                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                                  Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                  Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Reading package lists... Done
                                      Node.js not found. Installing...
                                  ## Installing the NodeSource Node.js 18.x repo...
                                  ## Populating apt-get cache...
                                  + apt-get update
                                  ## Confirming "bullseye" is supported...
                                  + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/bullseye/Re            lease'
                                  ## Adding the NodeSource signing key to your keyring...
                                  + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor |             tee /usr/share/keyrings/nodesource.gpg >/dev/null
                                  ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
                                  + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesourc            e.com/node_18.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
                                  + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodes            ource.com/node_18.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
                                  ## Running `apt-get update` for you...
                                  + apt-get update
                                  Get:2 https://deb.nodesource.com/node_18.x bullseye InRelease [4,586 B]
                                  Hit:4 http://deb.debian.org/debian bullseye InRelease
                                  Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                                  Get:6 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages [776 B]
                                  Get:7 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages [787 B]
                                  Fetched 6,149 B in 2s (2,634 B/s)
                                  ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
                                  ## You may also need development tools to build native addons:
                                       sudo apt-get install gcc g++ make
                                  ## To install the Yarn package manager, run:
                                       curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo te            e /usr/share/keyrings/yarnkey.gpg >/dev/null
                                       echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.co            m/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                       sudo apt-get update && sudo apt-get install yarn
                                  Installed nodejs
                                  Node.js Installed successfully!
                                  Changing npm registry to https://registry.npmjs.org
                                  Installed acl
                                  Installed gcc-c++
                                  Installed libavahi-compat-libdnssd-dev
                                  Installed libudev-dev
                                  Installed libpam0g-dev
                                  Installed git
                                  Installed libcairo2-dev
                                  Installed libpango1.0-dev
                                  Installed libjpeg-dev
                                  Installed libgif-dev
                                  Installed librsvg2-dev
                                  Installed cmake
                                      Creating ioBroker user and directory (2/4)
                                  User iobroker created
                                  Created /etc/sudoers.d/iobroker
                                  Directory /opt/iobroker created
                                      Installing ioBroker (3/4)
                                  npm ERR! FetchError: request to https://registry.npmjs.org/iobroker.admin failed            , reason: connect ECONNREFUSED 2606:4700::6810:b22:443
                                  npm ERR!     at ClientRequest.<anonymous> (/usr/lib/node_modules/npm/node_module            s/minipass-fetch/lib/index.js:130:14)
                                  npm ERR!     at ClientRequest.emit (node:events:514:28)
                                  npm ERR!     at TLSSocket.socketErrorListener (node:_http_client:501:9)
                                  npm ERR!     at TLSSocket.emit (node:events:526:35)
                                  npm ERR!     at emitErrorNT (node:internal/streams/destroy:151:8)
                                  npm ERR!     at emitErrorCloseNT (node:internal/streams/destroy:116:3)
                                  npm ERR!     at process.processTicksAndRejections (node:internal/process/task_qu            eues:82:21)
                                  npm ERR!  FetchError: request to https://registry.npmjs.org/iobroker.admin faile            d, reason: connect ECONNREFUSED 2606:4700::6810:b22:443
                                  npm ERR!     at process.processTicksAndRejections (node:internal/process/task_qu            eues:82:21) {
                                  npm ERR!   address: '2606:4700::6810:b22',
                                  npm ERR!   port: 443,
                                  npm ERR! }
                                  npm ERR!
                                  npm ERR! 'proxy' config is set properly.  See: 'npm help config'
                                  npm ERR! A complete log of this run can be found in: /home/Holger/.npm/_logs/202            3-08-22T12_14_59_986Z-debug-0.log
                                      Finalizing installation (4/4)
                                  Enabling autostart...
                                  Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /            lib/systemd/system/iobroker.service.
                                  Autostart enabled!
                                  Fixing directory permissions...
                                      ioBroker was installed successfully
                                      Open http://192.168.0.191:8081 in a browser and start configuring!
                                  You need to re-login before doing anything else on the console!
                                  Und nu' ... ?
                                  Holger
                                  D Homoran 2 Replies Last reply Reply Quote 0
                                    @dooley_76
                                    Hier noch die diag, falls es helfen sollte:
                                    Skript v.2023-04-16
                                    *** BASE SYSTEM ***
                                    Architecture    : aarch64
                                    Docker          : false
                                    Distributor ID: Debian
                                    Description:    Debian GNU/Linux 11 (bullseye)
                                    Release:        11
                                    Codename:       bullseye
                                    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                    NAME="Debian GNU/Linux"
                                    VERSION_ID="11"
                                    ID=debian
                                    HOME_URL="https://www.debian.org/"
                                    SUPPORT_URL="https://www.debian.org/support"
                                    BUG_REPORT_URL="https://bugs.debian.org/"
                                     14:26:08 up 17 min,  1 user,  load average: 0.07, 0.20, 0.28
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    temp=54.8'C
                                    volt=1.3813V
                                                   Local time: Tue 2023-08-22 14:26:08 CEST
                                               Universal time: Tue 2023-08-22 12:26:08 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    Holger
                                    /home/Holger
                                    Holger adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            909M         79M        223M        0.0K        606M        765M
                                    Swap:            99M          0B         99M
                                    Total:          1.0G         79M        323M
                                              909 M total memory
                                               79 M used memory
                                              125 M active memory
                                              445 M inactive memory
                                              223 M free memory
                                               39 M buffer memory
                                              567 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       29G  2.0G   26G   7% /
                                    devtmpfs       devtmpfs  325M     0  325M   0% /dev
                                    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                                    tmpfs          tmpfs     182M  976K  181M   1% /run
                                    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                                    [Tue Aug 22 14:08:52 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=26b2c4cb-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Tue Aug 22 14:08:55 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Tue Aug 22 14:08:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Tue Aug 22 14:08:58 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                                    /var:
                                    476M    /var/
                                    180M    /var/cache
                                    174M    /var/cache/apt
                                    147M    /var/lib
                                    123M    /var/lib/apt/lists
                                    Archived and active journals take up 48.0M in the file system.
                                    du: cannot access '/opt/iobroker/backups/': No such file or directory
                                    du: cannot access '/opt/iobroker/iobroker-data/': No such file or directory
                                    find: '/opt/iobroker/iobroker-data': No such file or directory
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
                                    nodejs:
                                      Version table:
                                            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                         12.22.12~dfsg-1~deb11u3 500
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    find: '/opt/iobroker/node_modules': No such file or directory
                                    ioBroker Status
                                    node:internal/modules/cjs/loader:1080
                                      throw err;
                                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                        at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                                        at Module._load (node:internal/modules/cjs/loader:922:27)
                                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                        at node:internal/main/run_main_module:23:47 {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                    js-controller:
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                    admin:
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                    javascript:
                                    npm ERR! code ELSPROBLEMS
                                    npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
                                    npm ERR! missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
                                    npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
                                    npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
                                    npm ERR! A complete log of this run can be found in: /home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log
                                    Adapter State
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                    Objects and States
                                    Objects:        0
                                    States:         0
                                    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                                    Pending Updates: 0
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12883      474/sshd: /usr/sbin
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          12885      474/sshd: /usr/sbin
                                    udp        0      0 0.0.0.0:60377           0.0.0.0:*                           108        13975      354/avahi-daemon: r
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14343      602/dhcpcd
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13973      354/avahi-daemon: r
                                    udp6       0      0 :::546                  :::*                                0          1654       602/dhcpcd
                                    udp6       0      0 :::5353                 :::*                                108        13974      354/avahi-daemon: r
                                    udp6       0      0 :::43804                :::*                                108        13976      354/avahi-daemon: r
                                    tail: cannot open '/opt/iobroker/log/iobroker.current.log' for reading: No such file or directory
                                      @dooley_76
                                      und hier noch das komplette Log-File:
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:        11
                                      Codename:       bullseye
                                      VERSION_ID="11"
                                      ID=debian
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=54.8'C
                                      volt=1.3813V
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      Holger
                                      /home/Holger
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                                909 M total memory
                                                 79 M used memory
                                                125 M active memory
                                                223 M free memory
                                                 39 M buffer memory
                                                567 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      476M    /var/
                                      180M    /var/cache
                                      174M    /var/cache/apt
                                      147M    /var/lib
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                      js-controller:
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                      admin:
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                      javascript:
                                      Adapter State
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                      Objects and States
                                      Objects:        0
                                      States:         0
                                      Pending Updates: 0
                                      iob diag has finished.
                                      Press any key for a summary
                                      Holger@raspberryiobroker:~ $ cd /home/Holger/.npm/_logs
                                      Holger@raspberryiobroker:~/.npm/_logs $ dir -a
                                      .                                     2023-08-22T12_26_10_875Z-debug-0.log
                                      ..                                    2023-08-22T12_26_12_556Z-debug-0.log
                                      2023-08-22T12_11_53_157Z-debug-0.log  2023-08-22T12_26_14_191Z-debug-0.log
                                      2023-08-22T12_11_54_801Z-debug-0.log  2023-08-22T12_26_15_825Z-debug-0.log
                                      2023-08-22T12_14_59_986Z-debug-0.log  2023-08-22T12_26_18_961Z-debug-0.log
                                      Holger@raspberryiobroker:~/.npm/_logs $ mcedit 2023-08-22T12_26_18_961Z-debug-0.log
                                      -bash: mcedit: command not found
                                      Holger@raspberryiobroker:~/.npm/_logs $ ^C
                                      Holger@raspberryiobroker:~/.npm/_logs $ sudo edit 2023-08-22T12_26_18_961Z-debug-0.log
                                      0 verbose cli /usr/bin/node /usr/bin/npm
                                      1 info using npm@9.6.7
                                      2 info using node@v18.17.1
                                      3 timing npm:load:whichnode Completed in 6ms
                                      4 timing config:load:defaults Completed in 11ms
                                      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 5ms
                                      6 timing config:load:builtin Completed in 6ms
                                      7 timing config:load:cli Completed in 14ms
                                      8 timing config:load:env Completed in 3ms
                                      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 9ms
                                      10 timing config:load:project Completed in 32ms
                                      11 timing config:load:file:/home/Holger/.npmrc Completed in 2ms
                                      12 timing config:load:user Completed in 3ms
                                      13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                                      14 timing config:load:global Completed in 1ms
                                      15 timing config:load:setEnvs Completed in 6ms
                                      16 timing config:load Completed in 80ms
                                      17 timing npm:load:configload Completed in 81ms
                                      18 timing npm:load:mkdirpcache Completed in 2ms
                                      19 timing npm:load:mkdirplogs Completed in 1ms
                                      20 verbose title npm ls
                                      21 verbose argv "ls"
                                      22 timing npm:load:setTitle Completed in 6ms
                                      23 timing config:load:flatten Completed in 16ms
                                      24 timing npm:load:display Completed in 21ms
                                      25 verbose logfile logs-max:10 dir:/home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-
                                      26 verbose logfile /home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log
                                      27 timing npm:load:logFile Completed in 50ms
                                      28 timing npm:load:timers Completed in 1ms
                                      29 timing npm:load:configScope Completed in 0ms
                                      30 timing npm:load Completed in 171ms
                                      31 timing arborist:ctor Completed in 4ms
                                      32 silly logfile done cleaning log files
                                      33 timing command:ls Completed in 1010ms
                                      34 verbose stack Error: missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
                                      34 verbose stack missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
                                      34 verbose stack missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
                                      34 verbose stack missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
                                      34 verbose stack     at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:202:9)
                                      34 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:89:5)
                                      35 verbose cwd /opt/iobroker
                                      36 verbose Linux 6.1.21-v8+
                                      37 verbose node v18.17.1
                                      38 verbose npm  v9.6.7
                                      39 error code ELSPROBLEMS
                                      40 error missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
                                      40 error missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
                                      40 error missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
                                      40 error missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
                                      41 verbose exit 1
                                      42 timing npm Completed in 1352ms
                                      43 verbose code 1
                                      44 error A complete log of this run can be found in: /home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log
                                      "/home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log" 53 lines, 2732 bytes
                                        @dooley_76
                                        Der Server lässt dich nicht, warum auch immer.
                                          Ok, Danke für die Info. Noch eine Idee, was ich hier bei mir probieren könnte oder bin ich
                                          jetzt erst einmal "lahmgelegt"?
                                          Oder doch wieder ein Image nehmen und dann nicht auf die aktuellsten Versionen gehen? Wobei
                                          das ja eigentlich genau der Grund war ...
                                          Auf jeden Fall nochmal Danke für die Mühen 🙂
                                            Das nutzt dir natürlich bei 'Netzwerktrouble' nix.
                                            Hast du irgendwas 'ungewöhnliches' da bei dir laufen?
                                            pihole? Sonst irgendwas in der Richtung?
                                            2297
