    4. Nach Systemaktualisierung Modbus Fehler 25
      Dooley_76 @Dooley_76 last edited by
      @dooley_76
      und hier noch das komplette Log-File:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 3 Model B Plus Rev 1.3
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       14:26:08 up 17 min,  1 user,  load average: 0.07, 0.20, 0.28
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=54.8'C
      volt=1.3813V
      *** Time and Time Zones ***
                     Local time: Tue 2023-08-22 14:26:08 CEST
                 Universal time: Tue 2023-08-22 12:26:08 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      Holger
      /home/Holger
      Holger adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            909M         79M        223M        0.0K        606M        765M
      Swap:            99M          0B         99M
      Total:          1.0G         79M        323M
                909 M total memory
                 79 M used memory
                125 M active memory
                445 M inactive memory
                223 M free memory
                 39 M buffer memory
                567 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       29G  2.0G   26G   7% /
      devtmpfs       devtmpfs  325M     0  325M   0% /dev
      tmpfs          tmpfs     455M     0  455M   0% /dev/shm
      tmpfs          tmpfs     182M  976K  181M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
      [Tue Aug 22 14:08:52 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=26b2c4cb-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue Aug 22 14:08:55 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Aug 22 14:08:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Tue Aug 22 14:08:58 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      476M    /var/
      180M    /var/cache
      174M    /var/cache/apt
      147M    /var/lib
      123M    /var/lib/apt/lists
      Archived and active journals take up 48.0M in the file system.
      /opt/iobroker/backups:
      du: cannot access '/opt/iobroker/backups/': No such file or directory
      /opt/iobroker/iobroker-data:
      du: cannot access '/opt/iobroker/iobroker-data/': No such file or directory
      find: '/opt/iobroker/iobroker-data': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      find: '/opt/iobroker/node_modules': No such file or directory
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      node:internal/modules/cjs/loader:1080
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
          at Module._load (node:internal/modules/cjs/loader:922:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
          at node:internal/main/run_main_module:23:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.17.1
        throw err;
        requireStack: []
      Node.js v18.17.1
      Core adapters versions
        throw err;
        requireStack: []
      Node.js v18.17.1
      js-controller:
        throw err;
        requireStack: []
      Node.js v18.17.1
      admin:
        throw err;
        requireStack: []
      Node.js v18.17.1
      javascript:
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
      npm ERR! A complete log of this run can be found in: /home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log
      Adapters from github:   0
      Adapter State
        throw err;
        requireStack: []
      Node.js v18.17.1
        throw err;
        requireStack: []
      Node.js v18.17.1
      ioBroker-Repositories
        throw err;
        requireStack: []
      Node.js v18.17.1
      Installed ioBroker-Instances
        throw err;
        requireStack: []
      Node.js v18.17.1
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12883      474/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12885      474/sshd: /usr/sbin
      udp        0      0 0.0.0.0:60377           0.0.0.0:*                           108        13975      354/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14343      602/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13973      354/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          1654       602/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        13974      354/avahi-daemon: r
      udp6       0      0 :::43804                :::*                                108        13976      354/avahi-daemon: r
      tail: cannot open '/opt/iobroker/log/iobroker.current.log' for reading: No such file or directory
      iob diag has finished.
      Press any key for a summary
      Holger@raspberryiobroker:~ $ cd /home/Holger/.npm/_logs
      Holger@raspberryiobroker:~/.npm/_logs $ dir -a
      .                                     2023-08-22T12_26_10_875Z-debug-0.log
      ..                                    2023-08-22T12_26_12_556Z-debug-0.log
      2023-08-22T12_11_53_157Z-debug-0.log  2023-08-22T12_26_14_191Z-debug-0.log
      2023-08-22T12_11_54_801Z-debug-0.log  2023-08-22T12_26_15_825Z-debug-0.log
      2023-08-22T12_14_59_986Z-debug-0.log  2023-08-22T12_26_18_961Z-debug-0.log
      Holger@raspberryiobroker:~/.npm/_logs $ mcedit 2023-08-22T12_26_18_961Z-debug-0.log
      -bash: mcedit: command not found
      Holger@raspberryiobroker:~/.npm/_logs $ ^C
      Holger@raspberryiobroker:~/.npm/_logs $ sudo edit 2023-08-22T12_26_18_961Z-debug-0.log
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@9.6.7
      2 info using node@v18.17.1
      3 timing npm:load:whichnode Completed in 6ms
      4 timing config:load:defaults Completed in 11ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 5ms
      6 timing config:load:builtin Completed in 6ms
      7 timing config:load:cli Completed in 14ms
      8 timing config:load:env Completed in 3ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 9ms
      10 timing config:load:project Completed in 32ms
      11 timing config:load:file:/home/Holger/.npmrc Completed in 2ms
      12 timing config:load:user Completed in 3ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:setEnvs Completed in 6ms
      16 timing config:load Completed in 80ms
      17 timing npm:load:configload Completed in 81ms
      18 timing npm:load:mkdirpcache Completed in 2ms
      19 timing npm:load:mkdirplogs Completed in 1ms
      20 verbose title npm ls
      21 verbose argv "ls"
      22 timing npm:load:setTitle Completed in 6ms
      23 timing config:load:flatten Completed in 16ms
      24 timing npm:load:display Completed in 21ms
      25 verbose logfile logs-max:10 dir:/home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-
      26 verbose logfile /home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log
      27 timing npm:load:logFile Completed in 50ms
      28 timing npm:load:timers Completed in 1ms
      29 timing npm:load:configScope Completed in 0ms
      30 timing npm:load Completed in 171ms
      31 timing arborist:ctor Completed in 4ms
      32 silly logfile done cleaning log files
      33 timing command:ls Completed in 1010ms
      34 verbose stack Error: missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
      34 verbose stack missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
      34 verbose stack missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
      34 verbose stack missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
      34 verbose stack     at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:202:9)
      34 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:89:5)
      35 verbose cwd /opt/iobroker
      36 verbose Linux 6.1.21-v8+
      37 verbose node v18.17.1
      38 verbose npm  v9.6.7
      39 error code ELSPROBLEMS
      40 error missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
      40 error missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
      40 error missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
      40 error missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
      41 verbose exit 1
      42 timing npm Completed in 1352ms
      43 verbose code 1
      44 error A complete log of this run can be found in: /home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log
      "/home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log" 53 lines, 2732 bytes
        Thomas Braun Most Active @Dooley_76 last edited by
        @dooley_76
        Der Server lässt dich nicht, warum auch immer.
        ECONNREFUSED 2606:4700::6810:b22:443
          Dooley_76 @Thomas Braun last edited by
          Ok, Danke für die Info. Noch eine Idee, was ich hier bei mir probieren könnte oder bin ich
          jetzt erst einmal "lahmgelegt"?
          Oder doch wieder ein Image nehmen und dann nicht auf die aktuellsten Versionen gehen? Wobei
          das ja eigentlich genau der Grund war ...
          Auf jeden Fall nochmal Danke für die Mühen 🙂
            @dooley_76 sagte in Nach Systemaktualisierung Modbus Fehler 25:
            Das nutzt dir natürlich bei 'Netzwerktrouble' nix.
            Hast du irgendwas 'ungewöhnliches' da bei dir laufen?
            pihole? Sonst irgendwas in der Richtung?
              Nur einen anderen Pi, auf der "Solaranzeige" läuft ( https://solaranzeige.de/phpBB3/solaranzeige.php )
              Aber der ist nur für die InfluxDB und Darstellung in Grafana zuständig. Die Darstellungen hatte ich dann
              bei IOBroker eingebunden.
              Und der läuft aber auch schon ewig und war auch schon bei der ersten Installation von IOB am Laufen ...
              Mit anderen Worten: Gegenüber der ersten Installation habe ich nichts verändert. Es sei denn, der Shelly
              kann hier noch etwas mit zu tun haben, denn der ist seit der letzten Installation neu dazu gekommen.
                @dooley_76
                Ich glaub' ich werde heute Abend mal alles andere an Netzwerk abhängen inkl. WLAN deaktivieren, so das nur noch mein Computer und der Pi noch "online" sind und mal sehen, was dann passiert. ..
                  Homoran Global Moderator Administrators @Dooley_76 last edited by Homoran
                  Wenn ich nichts mache, geht es nach ~ 5-6 Minuten "weiter"
                  der pi3 ist zwar langsam, aber so lange sollte die "Pause" nicht sein. Da wird im Hintergrund gearbeitet.
                  request to https://registry.npmjs.org/iobroker.admin failed , reason: connect ECONNREFUSED 2606:4700::6810:b22:443
                  hast du irgendwelche Blocker im Netz?
                  ist das eine ipv6 Adresse von dir?
                  Edit:
                  da tauchen gerade die anderen Posts auf! sorry
                    @homoran sagte in Nach Systemaktualisierung Modbus Fehler 25:
                    Nö, die gehört zu Cloudflare.
                      @thomas-braun kann es am ipv6 selbst liegen? wenn kein ipv4 läuft?
                        Eigentlich nicht. Bei mir läuft auch Kabelinternet mit ipv6 (nach draußen).
                          Kurzes Update:
                          Alles noch einmal installiert und dieses mal über das Gast-WLAN, also keine weiteren Geräte, keine Beschränkungen, Portweiterleitungen o.ä.
                          Aber leider immer noch derselbe Fehler ... 😞
                          Keine Ahnung ... ich werde es jetzt wohl noch einmal mit dem Image aufsetzen, auch wenn es dann nicht auf dem aktuellsten Stand ist, aber es funktioniert wenigstens.
                          Für weitere Ratschläge oder Ideen bin ich natürlich trotzdem jederzeit gern zu haben 🙂
                          In diesem Sinne aber noch einmal Danke für Eure bisherige (und vor allem schnelle :)) Hilfe ...
                          Holger
                          Fabio 1 Reply Last reply Reply Quote 0
                          • Fabio
                            Fabio @Dooley_76 last edited by
                            @dooley_76 fahre den zweiten PI mit Solaranzeige mal runter dann nimmst du ihn vom Netzwerk Lan Kabel ziehen etc.
                            Dann machst du die Installation noch mal neu und schaust dann was passiert.
                            Was für einen Router hast du und hast du darin irgendwelche Ports geblockt oder eine Firewall. Du kannst auch mal den Router neu starten. Viel Glück, ich hau mich auf Ohr.👍
                              So, ein kurzes Update für alle:
                              nachdem ich mit der "normalen" Installation einfach nicht ans Ziel gekommen bin, habe ich einen anderen Weg eingeschlagen:
                              Image IOBroker installiert ( https://github.com/buanet/ioBroker.raspberry-os/releases )
                              Nach der Installation hatte ich folgende Versionen:
                              NPM 8.19.4 (9.6.7)
                              Node.js v16.20.2
                              Dann erst einmal getestet, ob ich hiermit wieder Modbus etc. installieren kann > i.O.
                              Also SD-Karte wieder platt gemacht, Image neu - ohne Modbus etc. - installiert, damit ich wieder
                              die gleiche Ausgangslage habe.
                              Danach mich an das manuelle Upgrade nach Thomas seiner wirklich guten Anleitung gemacht:
                              ( https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian )
                              Gebe zu, das war ein bisschen Arbeit, aber am Ende hatte ich alles auf aktuellem Stand:
                              NPM 9.6.7
                              Node.js v18.17.1
                              Und siehe da: Ich konnte alle Adapter installieren 🙂
                              Ich habe keine Ahnung, warum er die "normale" Installation nicht gemacht hat. Irgendwas scheint
                              ja aber anders zu sein. Wenn es ein genereller Netzwerkfehler ist/wäre, hätte ich doch auch hier nichts
                              installieren können müssen, oder? Zumindest habe ich bei beiden Wegen die gleichen Voraussetzungen
                              geschaffen, damit ich vergleichen kann. Also irgendwas scheint durch das Image anders zu laufen ...
                              Aber hey ... what ever: ich habe jetzt ein stabil laufendes System, welches aktuell ist und mit dem ich erst
                              einmal wieder an meiner Automation arbeiten kann.
                              Nebenbei habe ich mir aber noch eine 2te SD-Karte fertig gemacht, mit der ich zwischendrin mal
                              verschiedene Szenarien durchspielen werde. Irgendwie muss der "Fehler" ja einzugrenzen zu sein.
                              Am Ende möchte ich aber auf jeden Fall noch einmal Danke 🙂 für Eure Zeit und Hilfe sagen.
                              Greez
                              Holger
                              1448
