    4. SMA Wechselrichter
    SMA Wechselrichter
      Marcolotti last edited by
      hier ist z.B. der Code für das Widget. Im Edit auf Widget Importieren und dann das:
      [{"tpl":"tplCGradialGauge","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","factor":"1","valueOffset":"0","hCount":"4","minorTicks":"4","animation":"true","needle":"true","needleShadow":"true","needleType":"arrow","borders":true,"borderOuterWidth":"2","borderMiddleWidth":"2","borderInnerWidth":"2","borderShadowWidth":"2","valueBox":true,"ticksAngle":"270","startAngle":"45","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"oid":"javascript.0.PV_Anlage.Werte.PVLeistung","minValue":0,"maxValue":"9000","units":"Watt","title":"PV-Leistung","valueBoxStroke":"0","highlightsFrom1":"0","highlightsTo1":"1500","highlightsColor1":"#fb1313","highlightsFrom2":"1500","highlightsTo2":"2500","highlightsColor2":"#fee710","highlightsFrom3":"2500","highlightsTo3":"8000","highlightsColor3":"#30f816","highlightsFrom4":"8000","highlightsTo4":"9000","highlightsColor4":"#e907d7","majorTicks":"10","strokeTicks":true,"animationRule":"quad","animateOnInit":true,"animationTarget":"needle","colorPlate":"#707070","colorPlateEnd":"#3e3838","colorMajorTicks":"#FFFFFF","colorNumbers":"#FFFFFF","colorTitle":"#FFFFFF","needleStart":"","needleEnd":"","colorNeedleCircleInner":"","colorNeedleCircleOuter":"","needleCircleOuter":true,"needleCircleSize":"","animationDuration":"750","animatedValue":false,"valueText":"","fontTitle":"","valueDec":"1","colorUnits":"#FFFFFF","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"922px","top":"252px","width":"275px","height":"270px"},"widgetSet":"canvas-gauges"}]
      Gruß Marco
        KaFaBe last edited by
        Danke für die schnelle Antwort.
        Import schein nicht zu funktionieren. Kann danach den Eigenschaftsreiter "Allgemein" nicht anklicken.
          Sorry, du musst vorher oder auch jetzt die "canvas-gauges style widgets" installieren. 😄
            @Marcolotti:
            Sorry, du musst vorher oder auch jetzt die "canvas-gauges style widgets" installieren. 😄 `
            Genial, es funktioniert. DANKE
              Was hast du eingestellt, damit die Werte bei WR im Standby nicht ins Negative rauschen?
              Wie hast du zwei Werte zusammen addiert?
                du müsstest den Javascript-Adapter installieren und dort ein Script erstellen.
                Das sieht dann z.B. so aus:
                on({id: 'modbus.0.inputRegisters.30775_PVLeistung', change: "ne"}, function (obj) {
                  var value = obj.state.val;
                  setState("javascript.0.PV_Anlage.Werte.PVLeistung"/*PVLeistung*/, (getState("modbus.0.inputRegisters.30775_PVLeistung").val + getState("modbus.1.inputRegisters.30775_PV-Leistung").val), true);
                Wenn du das Objekt (PVLeistung unter javascript.0.PV_Anlage.Werte" anlegst, kannst du in den Objekteigenschaften festlegen, was der Min und Max Wert ist.
                Am besten wäre für den Anfang Blockly.
                Gruß Marco
                  Sorry, dass ich nochmal frage.
                  Den Adapter habe ich angelegt.
                  Aber wo trage ich den Code ein?
                  Bei Dir steht in dem Feld "Custom" auch etwas von SQL. Muss ich auch eine SQL Datenbank installieren?
                  • Goersch
                    Goersch last edited by
                    hab nun auch beide ModBus (Tripower + Sunny Island) am laufen … nach ein paar Problemchen; deshalb ein paar Hinweise für andere:
                    1. Die Tripower werden nicht mehr unbedingt mit Bluetooth ausgeliefert. Auch wenn ein Bluetooth Zeichen an einer LED, muss nicht unbedingt Bluetooth verbaut sein. Wenn auf dem Geräte Label "Network only" steht, ist kein Bluetooth vorhanden.
                    2. Installateur Passwort Sunny Explorer: Weder mein Installateuer noch der SMA-Service haben mich direkt darauf hingewiesen; erst nach mehreren Diskussionen: Zu benutzen ist das Anlagenpasswort - nicht die "1111"
                    3. Sollte es dennoch gelingen ein Gerät mit der "1111" zu parametrieren, dann hat es noch nicht das Anlagenkennwort erhalten. Dann mittels Sunny Explorer das Installateur Kennwort auf das Anlagenkennwort setzen. ACHTUNG! Auch das Benutzerkennwort dann eingeben/ändern (auch "0000" OK), ansonsten wird das neu gesetzte Kennwort beim Installateur nicht übernommen - warum das so ist: keine Ahnung.
                    4. Info: Für den Life-View innerhalb des Sunny Portals werden die Daten von den Umrichtern und dem Sunny Home Manager via VoIP-Verbindung übertragen. Also im Router entsprechende Ports öffnen.
                    5. Das Anlagenpasswort darf maximal 12 Zeichen lang sein. Bei der Anmeldung und Vergabe des Anlagenpassworts schneidet das SMA Portal zu viel eingegebene Zeichen einfach ab - man steht dann erst mal blöd da und wundert sich, warum das Passwort nicht funktioniert oder im Sunny Explorer abgelehnt wird.
                    • wendy2702
                      wendy2702 last edited by
                      Teil 4 stimmt nicht.
                      Der Sunny Home Manager sendet/ empfängt nur Daten über Standart Protokolle.
                      Eine Port Öffnung und/oder Weiterleitung ist nicht notwendig.
                      Und mit VOIP = Voice over Ip läuft das ganz bestimmt nicht.
                      Glaube da hast du was falsch verstanden oder irgendwer hat blödsinn erzählt.
                      Allerdings lasse ich mich auch gerne eines besseren belehren.
                      Allerdings funktioniert mein live view schon seit 2014 ohne irgendwelche Port Öffnung oder Weiterleitung an O2 DSL mit Fritzbox 7490
                      • Goersch
                        Wenn man im Sunny Portal live daten anschaut, läuft das über ein VoIP Protokoll. Andere Daten gehen direkt über Port 80 raus.
                        Die Ports sind üblicher Weise auf - bei mir halt nicht, weshalb ich diese öffnen musste.
                        • wendy2702
                          Welche live Daten genau meinst du?
                          Welche/welchen Port musstest du denn öffnen?
                            Ist mir auch schleierhaft. Habe das bei Kunden schon x-mal eingerichtet und musste nichts öffnen. :shock:
                            • Goersch
                              jupp, deshalb hab ich ja auch geschrieben, dass diese Ports üblicher Weise offen sind - üblicher Weise muss man nix öffnen 🙂 bei mir halt schon, da bei mir alles verriegelt ist, was nicht gebraucht wird.
                              Aus meinem Chat mit dem SMA-Service
                              "Man kann im Portal einsehen das die Historischen Daten in der Energiebilanz und Geräteübersicht von Sunny Island übermittelt werden. Es werden rein die Live Daten im Aktuellen Status und Prognose nicht übermittelt.
                              Dies liegt daran das diese beiden Daten über zwei Wege in das Portal gesendet werden. Die Historischen Daten werden über den Standard Webserver Port 80 gesendet und die Live Werte kommen über eine Voice over IP Verbindung.
                              Für die Anzeige von Livedaten loggt sich Sunny Portal über eine dafür entwickelte Kommunikationsschnittstelle in die Anlage ein. Für die Kommunikation wird das bei Voice over IP (VoIP) verwendete SIP/STUN-Verfahren eingesetzt. Dieses Verfahren wird eingesetzt, da wir davon ausgehen können, dass die meisten Netzwerk-Router mit diesem Verfahren zurechtkommen und somit die Kommunikation zwischen Sunny Portal und Home Manager aufgebaut werden kann. Eine spezielle Routerkonfiguration, zum Beispiel das Anlegen von NAT- und Portregeln, ist nicht erforderlich.
                              Es kann nicht ausgeschlossen werden, dass die IT-Infrastruktur das verwendete Verfahren blockiert. Das kann am eingesetzten Router oder am Switch liegen. Im Router dürfen ausgehende UDP-Ports ab Port 1024 nicht geblockt werden. Die UDP-Ports 9523 und 3478 müssen ein- und ausgehend freigegeben sein."
                                @Goersch:
                                Für die Anzeige von Livedaten loggt sich Sunny Portal über eine dafür entwickelte Kommunikationsschnittstelle in die Anlage ein. Für die Kommunikation wird das bei Voice over IP (VoIP) verwendete SIP/STUN-Verfahren eingesetzt. `
                                Man lernt nie aus. :shock:
                                • Goersch
                                  ich war auch überrascht - macht aber Sinn
                                  • wendy2702
                                    Hm,
                                    Also entweder SMA erzählt was falsches oder AVM zeigt was falsches an.
                                    Laut meiner Fritzbox sind die oben erwähnten und angeblich notwendigen Ports nicht offen.
                                    3 der Einträge in der Liste habe ich selber zu verantworten wegen VPN und TR069 was ich selber freigeschaltet habe.
                                    Bleibt seitens AVM, also der Standard Konfiguration nur noch Port 5060 und der Range 50000-50031. Wie soll das mit der Angabe von SMA zusammen passen?
                                    Ich werde bei Gelegenheit mal einen Port Mitschnitt machen und schauen wer mit wem „redet“. Das Interessiert mich jetzt.
                                    ~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201710 ... ad6cac.jpg">https://uploads.tapatalk-cdn.com/20171027/ba85a87229dd1006664480de10ad6cac.jpg</link_text>" />
                                    Gesendet von iPad mit Tapatalk Pro~~
                                    • Goersch
                                      @wendy2702: Ja, mach das ruhig. Da ich diese Ports in meiner Firewall öffnen musste, nachdem ich mit dem "SMA"-Netzwerk von der FritzBox hinter meine Firewall umgezogen bin, wüsste ich nicht, warum ich die Aussage des SMA Service in Frage stellen sollte.
                                      @Marco: Magst Du nicht mal in deinem ersten Post in diesem Thread eine kleine Zusammenfassung der wichtigsten Puntke hinterlegen? Es ist immer mühsam sich durch 100+ Posts in diversen Foren zu lesen, bis man das wichtigste zusammen hat.
                                      Neben den Infos aus meinem Post 26.10.2017, 19:22 und den ModBus-Einstellungen der iobroker-Instanz, sollten da auch die wichtigsten ModBus-Adressen hinterlegt sein (wobei "wichtig" sind für mich nur Verbrauchswerte). Also in etwa so:
                                      Tripower
                                      30775 Power = Einspeise-Leistung Panels
                                      Sunny Island
                                      30775 Power = Lade-/Einspeise-Leistung Batterie
                                      30845 Percentage = Ladezustand Batterie
                                      30861 LoadPower = Einspeisung Netz + Batterie (Wert aus 30775)
                                      Beim 30861 bin ich noch nicht 100% sicher, ob das passt. Gestern war der erste Tag wo meine Berechnungen aus den 3 Werten bei Stichproben mit den Anzeigen im Sunny Portal übereinsimmten.
                                      • wendy2702
                                        habe mal meinen Homemanager belauscht.
                                        Laut Internet Schnittstellen Mitschnitt konnte ich nur folgende Ports und Protokolle finden:
                                        Das die das SIP Protokoll benutzen ist also richtig. Nur mit den Ports die von denen genannt wurden und welche wirklich benutzt werden passt irgendwie nicht zusammen.
                                        Aber wenn es ja funktioniert ist ja alles OK und eigentlich geht es hier im Forum ja auch um iobroker und nicht um SMA.
                                        Gruß und schönes Wochenende
                                          In dem Moment, wo du eine FritzBox an einem TKotz oder anderem All-IP Anschluss hast, ist der SIP-Port immer offen.
                                          Rainer
                                          • wendy2702
                                            Hi Rainer,
                                            ist auch nicht das Problem. Geht sich eigentlich nur darum das SMA Ports zur Freischaltung genannt hat die ich und auch Marco nicht freigeschaltet habe und user Goersch das machen musste damit die Kommunikation SMA Homemanager mit SMA Web Portal funktioniert.
                                            Mirko
                                            586
                                            162351
