    4. Grafana reagiert nicht mehr auf Port 3000
    • Ro75
      Ro75 @werner2000x last edited by Ro75
      @werner2000x
      was sagt denn
      sudo systemctl status grafana-server
      Ro75.
      werner2000x 1 Reply Last reply Reply Quote 0
      • werner2000x
        werner2000x @Ro75 last edited by werner2000x
        * grafana-server.service - Grafana instance
             Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
             Active: active (running) since Fri 2023-08-25 17:55:17 CEST; 7s ago
               Docs: http://docs.grafana.org
           Main PID: 5812 (grafana)
              Tasks: 8 (limit: 4915)
                CPU: 7.235s
             CGroup: /system.slice/grafana-server.service
                     `-5812 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:defau>
        Aug 25 17:55:19 raspberrypi grafana[5812]: logger=migrator t=2023-08-25T17:55:19.010307297+02:00 level=info msg="Starting DB migrations"
        Aug 25 17:55:19 raspberrypi grafana[5812]: logger=migrator t=2023-08-25T17:55:19.078297824+02:00 level=info msg="migrations completed" performed=0 skipped=493 duration=4.953881ms
        Aug 25 17:55:19 raspberrypi grafana[5812]: logger=secrets t=2023-08-25T17:55:19.083680032+02:00 level=info msg="Envelope encryption state" enabled=true currentprovider=secretKey.v1
        Aug 25 17:55:19 raspberrypi grafana[5812]: logger=plugin.loader t=2023-08-25T17:55:19.302744623+02:00 level=warn msg="Plugin missing module.js" pluginID=input warning="Missing module.js, If you loade>
        Aug 25 17:55:19 raspberrypi grafana[5812]: logger=plugin.loader t=2023-08-25T17:55:19.302928768+02:00 level=info msg="Plugin registered" pluginID=input
        Aug 25 17:55:20 raspberrypi grafana[5812]: logger=plugin.loader t=2023-08-25T17:55:20.585287158+02:00 level=info msg="Plugin registered" pluginID=cloudspout-button-panel
        Aug 25 17:55:20 raspberrypi grafana[5812]: logger=plugin.loader t=2023-08-25T17:55:20.585597079+02:00 level=info msg="Plugin registered" pluginID=grafana-clock-panel
        Aug 25 17:55:20 raspberrypi grafana[5812]: logger=query_data t=2023-08-25T17:55:20.598718456+02:00 level=info msg="Query Service initialization"
        Aug 25 17:55:20 raspberrypi grafana[5812]: logger=live.push_http t=2023-08-25T17:55:20.611838647+02:00 level=info msg="Live Push Gateway initialization"
        Aug 25 17:55:20 raspberrypi grafana[5812]: logger=ngalert t=2023-08-25T17:55:20.743301201+02:00 level=warn msg="Unexpected number of rows updating alert configuration history" rows=0 org=1 hash=not-y>
        lines 1-20/20 (END)
        Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
        • Ro75
          @werner2000x
          schon mal
          sudo systemctl restart grafana-server
          versucht?
          • werner2000x
            @ro75 Ja, aber half nicht.
            Hatte heute ein Update von Grafana auf 10.1.0
              Thomas Braun Most Active @werner2000x last edited by
              @werner2000x
              Und wenn das wieder laufen sollte bringst du das System in Gänze auf einen aktuellen Stand. Das sieht mir nach Update-Stau aus.
              • Ro75
                @werner2000x
                Welches Linux läuft eigentlich bei dir?
                  @werner2000x
                  iob diag
                  in der Langfassung sagt?
                  • werner2000x
                    werner2000x @Thomas Braun last edited by werner2000x
                                         v.2023-04-16
                    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                    Kernel:                 6.1.21-v8+
                    Installation:           Native
                    Timezone:               Europe/Berlin (CEST, +0200)
                    User-ID:                1000
                    X-Server:               true
                    Boot Target:            graphical.target
                    Pending OS-Updates:     0
                    Pending iob updates:    0
                    Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                                            /usr/bin/node           v16.20.2
                                            /usr/bin/npm            8.19.4
                                            /usr/bin/npx            8.19.4
                    Recommended versions are nodejs 18.x.y and npm 9.x.y
                    MEMORY:
                    Mem:            7.8G        4.8G        874M        9.0M        2.2G        3.2G
                    Swap:            99M         99M        0.0K
                    Total:          7.9G        4.8G        875M
                    Active iob-Instances:   42
                    Active repo(s): stable
                    ioBroker Core:          js-controller           4.0.24
                                            admin                   6.8.0
                    Objects type: jsonl
                    States  type: jsonl
                    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.198.39, run as: admin
                    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    Objects:                22821
                    States:                 19488
                    Size of iob-Database:
                    36M     /opt/iobroker/iobroker-data/objects.jsonl
                    15M     /opt/iobroker/iobroker-data/objects.json.migrated
                    15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                    28M     /opt/iobroker/iobroker-data/states.jsonl
                    3.4M    /opt/iobroker/iobroker-data/states.json.migrated
                    3.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                      @werner2000x
                      Das ist nicht die Langfassung.
                      Aber bis auf den mitrumpelnden Desktop in Ordnung. Schalt den aus.
                      • werner2000x
                        Raspi Desktop Ein:
                        sudo systemctl set-default multi-user.target
                        Raspi Desktop Aus:
                        sudo systemctl set-default graphical.target
                        iob diag
                                             v.2023-04-16
                        Kernel:                 6.1.21-v8+
                        User-ID:                1000
                        X-Server:               true
                        Boot Target:            multi-user.target
                                                /usr/bin/npm            8.19.4
                                                /usr/bin/npx            8.19.4
                        MEMORY:
                        Mem:            7.8G        4.8G        421M        9.0M        2.6G        3.2G
                        Swap:            99M         99M        0.0K
                        Total:          7.9G        4.9G        421M
                                                admin                   6.8.0
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                22821
                        States:                 19488
                        33M     /opt/iobroker/iobroker-data/states.jsonl
                        passiert ...
                          @werner2000x sagte in Grafana reagiert nicht mehr auf Port 3000:
                          X-Server: true
                          Der läuft noch. Einmal neustarten oder mit isolate das boot target setzen.
                          • werner2000x
                                                 v.2023-04-16
                            Kernel:                 6.1.21-v8+
                            User-ID:                1000
                            X-Server:               false
                                                    /usr/bin/npm            8.19.4
                                                    /usr/bin/npx            8.19.4
                            MEMORY:
                            Mem:            7.8G        2.5G        3.9G        0.0K        1.4G        5.8G
                            Swap:            99M          0B         99M
                            Total:          7.9G        2.5G        4.0G
                                                    admin                   6.8.0
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                22540
                            States:                 19332
                            39M     /opt/iobroker/iobroker-data/objects.jsonl
                            39M     /opt/iobroker/iobroker-data/states.jsonl
                            passiert...
                              https://github.com/grafana/grafana/issues/73781
                              BMerz created this issue in grafana/grafana
                              closed Grafana-Server crashes with SIGILL after update from 10.0.3 to 10.1.0 on RaspberryPi #73781
                              werner2000x 1 Reply Last reply Reply Quote -1
                              • werner2000x
                                werner2000x @crunchip last edited by
                                @crunchip Danke für den Link. Dann bin ich ja nicht alleine mit dem Fehler...
                                  darkblu last edited by
                                  @werner2000x ,
                                  alleine bist du nicht, mich hat es auch erwischt.
                                  Könnte man Grafana nicht einfach deinstallieren und wieder neu installieren, anschliessend per Backitup wieder auf den letzten stand bringen ?
                                  Im neuen Grafana sollten ja nur die Dashboards fehlen und die werden dann ja wieder hergestellt ?
                                  crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                                    crunchip Forum Testing Most Active @darkblu last edited by
                                    @darkblu sagte in Grafana reagiert nicht mehr auf Port 3000:
                                    so einfach ist das nicht, denn dann installierst du ja wieder die version😜
                                    guck ins issue, da ist es beschrieben
                                      Thomas Braun Most Active @darkblu last edited by
                                      @darkblu
                                      Freie Auswahl bezüglich der Version:
                                      echad@chet:~ $ apt policy grafana
                                      grafana:
                                        Installed: (none)
                                        Candidate: 10.1.0
                                        Version table:
                                           10.1.0 500
                                              500 https://apt.grafana.com stable/main arm64 Packages
                                           10.0.4 500
                                           10.0.3 500
                                           10.0.2 500
                                           10.0.1 500
                                           10.0.0 500
                                              100 /var/lib/dpkg/status
                                           9.5.8 500
                                           9.5.7 500
                                           9.5.6 500
                                           9.5.5 500
                                           9.5.3 500
                                           9.5.2 500
                                           9.5.1 500
                                           9.5.0 500
                                           9.4.13 500
                                           9.4.12 500
                                           9.4.10 500
                                           9.4.9 500
                                           9.4.7 500
                                           9.4.3 500
                                           9.4.2 500
                                           9.4.1 500
                                           9.4.0 500
                                           9.3.16 500
                                           9.3.15 500
                                           9.3.14 500
                                           9.3.13 500
                                           9.3.11 500
                                           9.3.8 500
                                           9.3.6 500
                                           9.3.4 500
                                           9.3.2 500
                                           9.3.1 500
                                           9.3.0 500
                                           9.2.20 500
                                           9.2.19 500
                                           9.2.18 500
                                           9.2.17 500
                                           9.2.15 500
                                           9.2.13 500
                                           9.2.10 500
                                           9.2.8 500
                                           9.2.7 500
                                           9.2.6 500
                                           9.2.5 500
                                           9.2.4 500
                                           9.2.3 500
                                           9.2.2 500
                                           9.2.1 500
                                           9.2.0 500
                                           9.1.8 500
                                           9.1.7 500
                                           9.1.6 500
                                           9.1.5 500
                                           9.1.4 500
                                           9.1.3 500
                                           9.1.2 500
                                           9.1.1 500
                                           9.1.0 500
                                           9.0.9 500
                                           9.0.8 500
                                           9.0.7 500
                                           9.0.6 500
                                           9.0.5 500
                                           9.0.4 500
                                           9.0.3 500
                                           9.0.2 500
                                           9.0.1 500
                                           9.0.0 500
                                           8.5.27 500
                                           8.5.26 500
                                           8.5.25 500
                                           8.5.24 500
                                           8.5.22 500
                                           8.5.21 500
                                           8.5.20 500
                                           8.5.16 500
                                           8.5.15 500
                                           8.5.14 500
                                           8.5.13 500
                                           8.5.12 500
                                           8.5.10 500
                                           8.5.9 500
                                           8.5.6 500
                                           8.5.5 500
                                           8.5.4 500
                                           8.5.3 500
                                           8.5.2 500
                                           8.5.1 500
                                           8.5.0 500
                                           8.4.11 500
                                           8.4.10 500
                                           8.4.7 500
                                           8.4.6 500
                                           8.4.5 500
                                           8.4.4 500
                                           8.4.3 500
                                           8.4.2 500
                                           8.4.1 500
                                           8.4.0 500
                                           8.3.11 500
                                           8.3.10 500
                                           8.3.7 500
                                           8.3.6 500
                                           8.3.5 500
                                           8.3.4 500
                                           8.3.3 500
                                           8.3.2 500
                                           8.3.1 500
                                           8.3.0 500
                                           8.2.7 500
                                           8.2.6 500
                                           8.2.5 500
                                           8.2.4 500
                                           8.2.3 500
                                           8.2.2 500
                                           8.2.1 500
                                           8.2.0 500
                                           8.1.8 500
                                           8.1.7 500
                                           8.1.6 500
                                           8.1.5 500
                                           8.1.4 500
                                           8.1.3 500
                                           8.1.2 500
                                           8.1.1 500
                                           8.1.0 500
                                           8.0.7 500
                                           8.0.6 500
                                           8.0.5 500
                                           8.0.4 500
                                           8.0.3 500
                                           8.0.2 500
                                           8.0.1 500
                                           8.0.0 500
                                           7.5.16 500
                                           7.5.15 500
                                           7.5.13 500
                                           7.5.12 500
                                           7.5.11 500
                                           7.5.10 500
                                           7.5.9 500
                                           7.5.8 500
                                           7.5.7 500
                                           7.5.6 500
                                           7.5.5 500
                                           7.5.4 500
                                           7.5.3 500
                                           7.5.2 500
                                           7.5.1 500
                                           7.5.0 500
                                           7.4.5 500
                                           7.4.3 500
                                           7.4.2 500
                                           7.4.1 500
                                           7.4.0 500
                                           7.3.10 500
                                           7.3.7 500
                                           7.3.6 500
                                           7.3.5 500
                                           7.3.4 500
                                           7.3.3 500
                                           7.3.2 500
                                           7.3.1 500
                                           7.3.0 500
                                           7.2.2 500
                                           7.2.1 500
                                           7.2.0 500
                                           7.1.5 500
                                           7.1.4 500
                                           7.1.3 500
                                           7.1.2 500
                                           7.1.1 500
                                           7.1.0 500
                                           7.0.6 500
                                           7.0.5 500
                                           7.0.4 500
                                           7.0.3 500
                                           7.0.2 500
                                           7.0.1 500
                                           7.0.0 500
                                           6.7.6 500
                                           6.7.5 500
                                           6.7.4 500
                                           6.7.3 500
                                           6.7.2 500
                                           6.7.1 500
                                           6.7.0 500
                                           6.6.2 500
                                           6.6.1 500
                                           6.6.0 500
                                           6.5.3 500
                                           6.5.2 500
                                           6.5.1 500
                                           6.5.0 500
                                           6.4.5 500
                                           6.4.4 500
                                           6.4.3 500
                                           6.4.2 500
                                           6.4.1 500
                                           6.4.0 500
                                           6.3.7 500
                                           6.3.6 500
                                           6.3.5 500
                                           6.3.4 500
                                           6.3.3 500
                                           6.3.2 500
                                           6.3.1 500
                                           6.3.0 500
                                           6.2.5 500
                                           6.2.4 500
                                           6.2.3 500
                                           6.2.2 500
                                           6.2.1 500
                                           6.2.0 500
                                           6.1.6 500
                                           6.1.5 500
                                           6.1.4 500
                                           6.1.3 500
                                           6.1.2 500
                                           6.1.1 500
                                           6.1.0 500
                                           6.0.2 500
                                           6.0.1 500
                                           6.0.0 500
                                           5.4.5 500
                                           5.4.4 500
                                           5.4.3 500
                                           5.4.2 500
                                           5.4.1 500
                                           5.4.0 500
                                           5.3.4 500
                                           5.3.3 500
                                           5.3.2 500
                                           5.3.1 500
                                           5.3.0 500
                                           5.2.5 500
                                           5.2.4 500
                                           5.2.3 500
                                           5.2.2 500
                                           5.2.1 500
                                           5.2.0 500
                                           0.0.0~test 500
                                      sudo apt install grafana=WUNSCHVERSION
                                      Vielleicht grafana vorerst auf hold setzen, fertig:
                                      sudo apt-mark hold grafana
                                      • Meister Mopper
                                        Meister Mopper last edited by
                                        Im von @crunchip beschriebenen issue steht es doch, einfach tun:
                                        For those who have a similar issue and want to downgrade:
                                            Backup /etc/grafana and /var/lib/grafana
                                            apt-get remove grafana
                                            apt-get install grafana=10.0.3
                                        Re-Enable/Start Grafana daemon
                                            sudo /bin/systemctl daemon-reload
                                            sudo /bin/systemctl enable grafana-server
                                            sudo /bin/systemctl start grafana-server
                                        After that Grafana works like before ;-)
                                          darkblu last edited by darkblu
                                          @crunchip
                                          @Meister-Mopper ,
                                          wollte ich eben nachmachen, scheinbar bin ich zu doof: 🤷‍♂️
                                          also die ersten beiden funktionieren schon nicht.
                                          pi@raspberrypi:~ $ Backup /etc/grafana and /var/lib/grafana
                                          -bash: Backup: Kommando nicht gefunden.
                                          pi@raspberrypi:~ $ apt-get remove grafana
                                          E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                                          E: Erlangen der Sperre für die Dpkg-Oberfläche (/var/lib/dpkg/lock-frontend) nicht möglich; sind Sie root?
                                          pi@raspberrypi:~ $
                                          könnt ihr mir den schubs in die richtige Richtung geben ?
                                            @darkblu du sollst dir die Verzeichnisse sichern
                                            das heisst du kopierst sie dir irgendwo hin
                                            nein, also mit sudo voran
                                            1.0k
                                            3000 grafana port
                                            2384
