    4. Grafana reagiert nicht mehr auf Port 3000
    • werner2000x
      werner2000x @Ro75 last edited by werner2000x
      sudo systemctl status grafana-server
      * grafana-server.service - Grafana instance
           Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
           Active: active (running) since Fri 2023-08-25 17:55:17 CEST; 7s ago
             Docs: http://docs.grafana.org
         Main PID: 5812 (grafana)
            Tasks: 8 (limit: 4915)
              CPU: 7.235s
           CGroup: /system.slice/grafana-server.service
                   `-5812 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:defau>
      Aug 25 17:55:19 raspberrypi grafana[5812]: logger=migrator t=2023-08-25T17:55:19.010307297+02:00 level=info msg="Starting DB migrations"
      Aug 25 17:55:19 raspberrypi grafana[5812]: logger=migrator t=2023-08-25T17:55:19.078297824+02:00 level=info msg="migrations completed" performed=0 skipped=493 duration=4.953881ms
      Aug 25 17:55:19 raspberrypi grafana[5812]: logger=secrets t=2023-08-25T17:55:19.083680032+02:00 level=info msg="Envelope encryption state" enabled=true currentprovider=secretKey.v1
      Aug 25 17:55:19 raspberrypi grafana[5812]: logger=plugin.loader t=2023-08-25T17:55:19.302744623+02:00 level=warn msg="Plugin missing module.js" pluginID=input warning="Missing module.js, If you loade>
      Aug 25 17:55:19 raspberrypi grafana[5812]: logger=plugin.loader t=2023-08-25T17:55:19.302928768+02:00 level=info msg="Plugin registered" pluginID=input
      Aug 25 17:55:20 raspberrypi grafana[5812]: logger=plugin.loader t=2023-08-25T17:55:20.585287158+02:00 level=info msg="Plugin registered" pluginID=cloudspout-button-panel
      Aug 25 17:55:20 raspberrypi grafana[5812]: logger=plugin.loader t=2023-08-25T17:55:20.585597079+02:00 level=info msg="Plugin registered" pluginID=grafana-clock-panel
      Aug 25 17:55:20 raspberrypi grafana[5812]: logger=query_data t=2023-08-25T17:55:20.598718456+02:00 level=info msg="Query Service initialization"
      Aug 25 17:55:20 raspberrypi grafana[5812]: logger=live.push_http t=2023-08-25T17:55:20.611838647+02:00 level=info msg="Live Push Gateway initialization"
      Aug 25 17:55:20 raspberrypi grafana[5812]: logger=ngalert t=2023-08-25T17:55:20.743301201+02:00 level=warn msg="Unexpected number of rows updating alert configuration history" rows=0 org=1 hash=not-y>
      lines 1-20/20 (END)
      Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
      • Ro75
        Ro75 @werner2000x last edited by
        @werner2000x
        schon mal
        sudo systemctl restart grafana-server
        versucht?
        werner2000x 1 Reply Last reply Reply Quote 0
        • werner2000x
          @ro75 Ja, aber half nicht.
          Hatte heute ein Update von Grafana auf 10.1.0
            Thomas Braun Most Active @werner2000x last edited by
            @werner2000x
            Und wenn das wieder laufen sollte bringst du das System in Gänze auf einen aktuellen Stand. Das sieht mir nach Update-Stau aus.
            • Ro75
              @werner2000x
              Welches Linux läuft eigentlich bei dir?
                @werner2000x
                iob diag
                in der Langfassung sagt?
                • werner2000x
                  werner2000x @Thomas Braun last edited by werner2000x
                                       v.2023-04-16
                  Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                  Kernel:                 6.1.21-v8+
                  Installation:           Native
                  Timezone:               Europe/Berlin (CEST, +0200)
                  User-ID:                1000
                  X-Server:               true
                  Boot Target:            graphical.target
                  Pending OS-Updates:     0
                  Pending iob updates:    0
                  Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                                          /usr/bin/node           v16.20.2
                                          /usr/bin/npm            8.19.4
                                          /usr/bin/npx            8.19.4
                  Recommended versions are nodejs 18.x.y and npm 9.x.y
                  MEMORY:
                  Mem:            7.8G        4.8G        874M        9.0M        2.2G        3.2G
                  Swap:            99M         99M        0.0K
                  Total:          7.9G        4.8G        875M
                  Active iob-Instances:   42
                  Active repo(s): stable
                  ioBroker Core:          js-controller           4.0.24
                                          admin                   6.8.0
                  Objects type: jsonl
                  States  type: jsonl
                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.198.39, run as: admin
                  + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  Objects:                22821
                  States:                 19488
                  Size of iob-Database:
                  36M     /opt/iobroker/iobroker-data/objects.jsonl
                  15M     /opt/iobroker/iobroker-data/objects.json.migrated
                  15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                  28M     /opt/iobroker/iobroker-data/states.jsonl
                  3.4M    /opt/iobroker/iobroker-data/states.json.migrated
                  3.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                    @werner2000x
                    Das ist nicht die Langfassung.
                    Aber bis auf den mitrumpelnden Desktop in Ordnung. Schalt den aus.
                    • werner2000x
                      Raspi Desktop Ein:
                      sudo systemctl set-default multi-user.target
                      Raspi Desktop Aus:
                      sudo systemctl set-default graphical.target
                      iob diag
                                           v.2023-04-16
                      Kernel:                 6.1.21-v8+
                      User-ID:                1000
                      X-Server:               true
                      Boot Target:            multi-user.target
                                              /usr/bin/npm            8.19.4
                                              /usr/bin/npx            8.19.4
                      MEMORY:
                      Mem:            7.8G        4.8G        421M        9.0M        2.6G        3.2G
                      Swap:            99M         99M        0.0K
                      Total:          7.9G        4.9G        421M
                                              admin                   6.8.0
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                22821
                      States:                 19488
                      33M     /opt/iobroker/iobroker-data/states.jsonl
                      passiert ...
                        @werner2000x sagte in Grafana reagiert nicht mehr auf Port 3000:
                        X-Server: true
                        Der läuft noch. Einmal neustarten oder mit isolate das boot target setzen.
                        • werner2000x
                                               v.2023-04-16
                          Kernel:                 6.1.21-v8+
                          User-ID:                1000
                          X-Server:               false
                                                  /usr/bin/npm            8.19.4
                                                  /usr/bin/npx            8.19.4
                          MEMORY:
                          Mem:            7.8G        2.5G        3.9G        0.0K        1.4G        5.8G
                          Swap:            99M          0B         99M
                          Total:          7.9G        2.5G        4.0G
                                                  admin                   6.8.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                22540
                          States:                 19332
                          39M     /opt/iobroker/iobroker-data/objects.jsonl
                          39M     /opt/iobroker/iobroker-data/states.jsonl
                          passiert...
                            https://github.com/grafana/grafana/issues/73781
                            BMerz created this issue in grafana/grafana
                            closed Grafana-Server crashes with SIGILL after update from 10.0.3 to 10.1.0 on RaspberryPi #73781
                            werner2000x 1 Reply Last reply Reply Quote -1
                            • werner2000x
                              werner2000x @crunchip last edited by
                              @crunchip Danke für den Link. Dann bin ich ja nicht alleine mit dem Fehler...
                                darkblu last edited by
                                @werner2000x ,
                                alleine bist du nicht, mich hat es auch erwischt.
                                Könnte man Grafana nicht einfach deinstallieren und wieder neu installieren, anschliessend per Backitup wieder auf den letzten stand bringen ?
                                Im neuen Grafana sollten ja nur die Dashboards fehlen und die werden dann ja wieder hergestellt ?
                                crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                                  crunchip Forum Testing Most Active @darkblu last edited by
                                  @darkblu sagte in Grafana reagiert nicht mehr auf Port 3000:
                                  so einfach ist das nicht, denn dann installierst du ja wieder die version😜
                                  guck ins issue, da ist es beschrieben
                                    Thomas Braun Most Active @darkblu last edited by
                                    @darkblu
                                    Freie Auswahl bezüglich der Version:
                                    echad@chet:~ $ apt policy grafana
                                    grafana:
                                      Installed: (none)
                                      Candidate: 10.1.0
                                      Version table:
                                         10.1.0 500
                                            500 https://apt.grafana.com stable/main arm64 Packages
                                         10.0.4 500
                                         10.0.3 500
                                         10.0.2 500
                                         10.0.1 500
                                         10.0.0 500
                                            100 /var/lib/dpkg/status
                                         9.5.8 500
                                         9.5.7 500
                                         9.5.6 500
                                         9.5.5 500
                                         9.5.3 500
                                         9.5.2 500
                                         9.5.1 500
                                         9.5.0 500
                                         9.4.13 500
                                         9.4.12 500
                                         9.4.10 500
                                         9.4.9 500
                                         9.4.7 500
                                         9.4.3 500
                                         9.4.2 500
                                         9.4.1 500
                                         9.4.0 500
                                         9.3.16 500
                                         9.3.15 500
                                         9.3.14 500
                                         9.3.13 500
                                         9.3.11 500
                                         9.3.8 500
                                         9.3.6 500
                                         9.3.4 500
                                         9.3.2 500
                                         9.3.1 500
                                         9.3.0 500
                                         9.2.20 500
                                         9.2.19 500
                                         9.2.18 500
                                         9.2.17 500
                                         9.2.15 500
                                         9.2.13 500
                                         9.2.10 500
                                         9.2.8 500
                                         9.2.7 500
                                         9.2.6 500
                                         9.2.5 500
                                         9.2.4 500
                                         9.2.3 500
                                         9.2.2 500
                                         9.2.1 500
                                         9.2.0 500
                                         9.1.8 500
                                         9.1.7 500
                                         9.1.6 500
                                         9.1.5 500
                                         9.1.4 500
                                         9.1.3 500
                                         9.1.2 500
                                         9.1.1 500
                                         9.1.0 500
                                         9.0.9 500
                                         9.0.8 500
                                         9.0.7 500
                                         9.0.6 500
                                         9.0.5 500
                                         9.0.4 500
                                         9.0.3 500
                                         9.0.2 500
                                         9.0.1 500
                                         9.0.0 500
                                         8.5.27 500
                                         8.5.26 500
                                         8.5.25 500
                                         8.5.24 500
                                         8.5.22 500
                                         8.5.21 500
                                         8.5.20 500
                                         8.5.16 500
                                         8.5.15 500
                                         8.5.14 500
                                         8.5.13 500
                                         8.5.12 500
                                         8.5.10 500
                                         8.5.9 500
                                         8.5.6 500
                                         8.5.5 500
                                         8.5.4 500
                                         8.5.3 500
                                         8.5.2 500
                                         8.5.1 500
                                         8.5.0 500
                                         8.4.11 500
                                         8.4.10 500
                                         8.4.7 500
                                         8.4.6 500
                                         8.4.5 500
                                         8.4.4 500
                                         8.4.3 500
                                         8.4.2 500
                                         8.4.1 500
                                         8.4.0 500
                                         8.3.11 500
                                         8.3.10 500
                                         8.3.7 500
                                         8.3.6 500
                                         8.3.5 500
                                         8.3.4 500
                                         8.3.3 500
                                         8.3.2 500
                                         8.3.1 500
                                         8.3.0 500
                                         8.2.7 500
                                         8.2.6 500
                                         8.2.5 500
                                         8.2.4 500
                                         8.2.3 500
                                         8.2.2 500
                                         8.2.1 500
                                         8.2.0 500
                                         8.1.8 500
                                         8.1.7 500
                                         8.1.6 500
                                         8.1.5 500
                                         8.1.4 500
                                         8.1.3 500
                                         8.1.2 500
                                         8.1.1 500
                                         8.1.0 500
                                         8.0.7 500
                                         8.0.6 500
                                         8.0.5 500
                                         8.0.4 500
                                         8.0.3 500
                                         8.0.2 500
                                         8.0.1 500
                                         8.0.0 500
                                         7.5.16 500
                                         7.5.15 500
                                         7.5.13 500
                                         7.5.12 500
                                         7.5.11 500
                                         7.5.10 500
                                         7.5.9 500
                                         7.5.8 500
                                         7.5.7 500
                                         7.5.6 500
                                         7.5.5 500
                                         7.5.4 500
                                         7.5.3 500
                                         7.5.2 500
                                         7.5.1 500
                                         7.5.0 500
                                         7.4.5 500
                                         7.4.3 500
                                         7.4.2 500
                                         7.4.1 500
                                         7.4.0 500
                                         7.3.10 500
                                         7.3.7 500
                                         7.3.6 500
                                         7.3.5 500
                                         7.3.4 500
                                         7.3.3 500
                                         7.3.2 500
                                         7.3.1 500
                                         7.3.0 500
                                         7.2.2 500
                                         7.2.1 500
                                         7.2.0 500
                                         7.1.5 500
                                         7.1.4 500
                                         7.1.3 500
                                         7.1.2 500
                                         7.1.1 500
                                         7.1.0 500
                                         7.0.6 500
                                         7.0.5 500
                                         7.0.4 500
                                         7.0.3 500
                                         7.0.2 500
                                         7.0.1 500
                                         7.0.0 500
                                         6.7.6 500
                                         6.7.5 500
                                         6.7.4 500
                                         6.7.3 500
                                         6.7.2 500
                                         6.7.1 500
                                         6.7.0 500
                                         6.6.2 500
                                         6.6.1 500
                                         6.6.0 500
                                         6.5.3 500
                                         6.5.2 500
                                         6.5.1 500
                                         6.5.0 500
                                         6.4.5 500
                                         6.4.4 500
                                         6.4.3 500
                                         6.4.2 500
                                         6.4.1 500
                                         6.4.0 500
                                         6.3.7 500
                                         6.3.6 500
                                         6.3.5 500
                                         6.3.4 500
                                         6.3.3 500
                                         6.3.2 500
                                         6.3.1 500
                                         6.3.0 500
                                         6.2.5 500
                                         6.2.4 500
                                         6.2.3 500
                                         6.2.2 500
                                         6.2.1 500
                                         6.2.0 500
                                         6.1.6 500
                                         6.1.5 500
                                         6.1.4 500
                                         6.1.3 500
                                         6.1.2 500
                                         6.1.1 500
                                         6.1.0 500
                                         6.0.2 500
                                         6.0.1 500
                                         6.0.0 500
                                         5.4.5 500
                                         5.4.4 500
                                         5.4.3 500
                                         5.4.2 500
                                         5.4.1 500
                                         5.4.0 500
                                         5.3.4 500
                                         5.3.3 500
                                         5.3.2 500
                                         5.3.1 500
                                         5.3.0 500
                                         5.2.5 500
                                         5.2.4 500
                                         5.2.3 500
                                         5.2.2 500
                                         5.2.1 500
                                         5.2.0 500
                                         0.0.0~test 500
                                    sudo apt install grafana=WUNSCHVERSION
                                    Vielleicht grafana vorerst auf hold setzen, fertig:
                                    sudo apt-mark hold grafana
                                    • Meister Mopper
                                      Meister Mopper last edited by
                                      Im von @crunchip beschriebenen issue steht es doch, einfach tun:
                                      For those who have a similar issue and want to downgrade:
                                          Backup /etc/grafana and /var/lib/grafana
                                          apt-get remove grafana
                                          apt-get install grafana=10.0.3
                                      Re-Enable/Start Grafana daemon
                                          sudo /bin/systemctl daemon-reload
                                          sudo /bin/systemctl enable grafana-server
                                          sudo /bin/systemctl start grafana-server
                                      After that Grafana works like before ;-)
                                        darkblu last edited by darkblu
                                        @crunchip
                                        @Meister-Mopper ,
                                        wollte ich eben nachmachen, scheinbar bin ich zu doof: 🤷‍♂️
                                        also die ersten beiden funktionieren schon nicht.
                                        pi@raspberrypi:~ $ Backup /etc/grafana and /var/lib/grafana
                                        -bash: Backup: Kommando nicht gefunden.
                                        pi@raspberrypi:~ $ apt-get remove grafana
                                        E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                                        E: Erlangen der Sperre für die Dpkg-Oberfläche (/var/lib/dpkg/lock-frontend) nicht möglich; sind Sie root?
                                        pi@raspberrypi:~ $
                                        könnt ihr mir den schubs in die richtige Richtung geben ?
                                          @darkblu du sollst dir die Verzeichnisse sichern
                                          das heisst du kopierst sie dir irgendwo hin
                                          nein, also mit sudo voran
                                            @darkblu
                                            sudo apt install grafana=10.0.3
                                            Wenn es wieder eine funktionierende Version gibt per
                                            sudo apt-mark unhold grafana
                                            auf den Update-Zug aufspringen.
                                            1.0k
                                            3000 grafana port
                                            2384
