    4. Homematic IP Einbindung
      Broler last edited by
      Habe es heute morgen noch einmal probiert mit dem gleichen Ergebnis.
      Fehlermeldung CCU: Eine Kompnente der Homematic reagiert nicht mehr.
      Mindestens eine Komponente der Homematic ist abgestürzt.
      Hier die Logdatei:
      Jan 26 10:40:46 (none) syslog.info -- MARK --
      Jan 26 10:41:26 (none) local0.err ReGaHss: [truncated] Error: Content-Length or Postback Param size incorrect! PostParam=&!# devices.fn 1.4 !# !# Dieses Homematic-Script gibt eine Liste aller Geraete/Kanäle als JSON String aus !# !# 3'2013-7'2013 hobbyquaker https://github.com/hobbyquaker !# string sDevId; string sChnId; Write('{'); boolean dFirst = true; foreach (sDevId, root.Devices().EnumUsedIDs()) { object oDevice = dom.GetObject(sDevId); boolean bDevReady = oDevice.ReadyConfig(); string sDevInterfaceId = oDevice.Interface(); string sDevInterface = dom.GetObject(sDevInterfaceId).Name(); if (bDevReady) { if (dFirst) { dFirst = false; } else { WriteLine(','); } Write('"' # oDevice.Address() # '":{"Name":"'); WriteURL(oDevice.Name()); Write('","Interface":"' # sDevInterface # '"}'); foreach(sChnId, oDevice.Channels()) { ^Iobject oChannel = dom.GetObject(sChnId); WriteLine(',');
      Jan 26 10:45:02 (none) cron.notice crond[977]: USER root pid 11907 cmd /bin/arm7setclock
      Jan 26 10:45:36 (none) local0.err ReGaHss: Error: IseXmlRpc::CallXmlrpcMethod: execute failed; method =setValue Params = {"MEQ1900392:1","STATE",true} result= nil [../Platform/DOM/iseXmlRpc.cpp (2551)]
      Jan 26 10:45:36 (none) local0.err ReGaHss: Error: IseXmlRpc::CallSetValue: CallXmlrpcMethod failed [../Platform/DOM/iseXmlRpc.cpp (1447)]
      Jan 26 10:45:36 (none) local0.err ReGaHss: Error: IseHssDP::WriteValue: CallSetValue failed; address = MEQ1900392:1 [../Platform/DOM/iseDOMdpHSS.cpp (77)]
      Jan 26 10:45:46 (none) local0.err ReGaHss: Error: IseXmlRpc::CallXmlrpcMethod: execute failed; method =setValue Params = {"MEQ1900392:1","STATE",true} result= nil [../Platform/DOM/iseXmlRpc.cpp (2551)]
      Jan 26 10:45:46 (none) local0.err ReGaHss: Error: IseXmlRpc::CallSetValue: CallXmlrpcMethod failed [../Platform/DOM/iseXmlRpc.cpp (1447)]
      Jan 26 10:45:46 (none) local0.err ReGaHss: Error: IseHssDP::WriteValue: CallSetValue failed; address = MEQ1900392:1 [../Platform/DOM/iseDOMdpHSS.cpp (77)]
      Jan 26 10:46:04 (none) local0.err ReGaHss: Error: IseXmlRpc::CallXmlrpcMethod: execute failed; method =setValue Params = {"KEQ1061645:1","STATE",true} result= nil [../Platform/DOM/iseXmlRpc.cpp (2551)]
      Jan 26 10:46:04 (none) local0.err ReGaHss: Error: IseXmlRpc::CallSetValue: CallXmlrpcMethod failed [../Platform/DOM/iseXmlRpc.cpp (1447)]
      Jan 26 10:46:04 (none) local0.err ReGaHss: Error: IseHssDP::WriteValue: CallSetValue failed; address = KEQ1061645:1 [../Platform/DOM/iseDOMdpHSS.cpp (77)]
        terne last edited by
        Hallo Zusammen
        habe mit dem HM-RPC IP ein Problem: wenn ich über IO-Broker die Temp im Thermostat ändere wird diese zwar im Thermostat geändert, aber im LOG steht eine Fehlermeldung:
        hm-rpc.1 2017-09-18 10:08:37.169 warn Cannot setValue "hm-rpc.1.000XXXXXXXXXX6.1.SET_POINT_TEMPERATURE", because not connected.
        Des weiteren kommen auch immer wieder folgende Meldungen:
        hm-rpc.1	2017-09-18 10:12:24.420	info	new HmIP devices/channels after filter: 0
        hm-rpc.1	2017-09-18 10:12:24.407	info	xmlrpc <- newDevices 14
        hm-rpc.1	2017-09-18 10:12:24.295	info	xmlrpc -> 0 devices
        hm-rpc.1	2017-09-18 10:12:24.277	info	xmlrpc <- listDevices ["hm-rpc.1"]
        Instanz ist auf jedenfall grün ( also connected )
        Auch die Nummer mit den Images ist bei mir vorhanden:
        hm-rpc.1 2017-09-18 10:07:18.873 warn No image for "HmIP-BWTH" found.
        Irgendwas übersehe ich
        Gruß Thorsten
        • nieIP
          nieIP last edited by
          Hallo
          die Fehlermeldung mit dem Bild wir wohl kommen, weil kein Bild da ist ?
          Die 4 Zeilen INFO sind kein Fehler.
          Es wird nach HMIP Geräten gesucht, mit dem Bestand verglichen und kein Unterschied (=0) gefunden. Das passiert regelmässig in dem von Dir im Adapter konfigurierten Zeitabstand.
            DavidT last edited by
            leider habe auch ich das Problem, dass in regelmäßigen Abständen mein (vermutlich) hm-rpc.1 mit dem HMIP Geräten neu gestartet wird und dabei werden alle Geräte gelöscht und neu angelegt. D.h. in vis habe ich nie den aktuellen Status meiner Geräte (Funksteckdosen).
            Also habe ich versucht, wie hier öfters beschrieben, das der Haken bei HMIP Geräten im Rega-Adapter gesetzt werden muss, in der Hoffnung damit das Problem zu lösen. Ich kann es zwar aktivieren, habe aber dann in der Auswahlliste für die hm-rpc Instanz keine Einträge. Hat jemand eine Ahnung woran das liegt? Habe eine Rega-Instanz und 2 RPC Instanzen.
            Danke!
            Gruß David
              chka last edited by
              wie sieht den dein hmrpc für die hip aus??
              • nieIP
                Hallo
                in der aktuellen Version des Adapters gibt es einen haken, der das automatische löschen verhindert.
                  MrLee last edited by
                  Moin!
                  Ich habe aktuell die 1.4.14 installiert…und bei mir gibt es den Haken nicht...welche Version ist das in dem Screenshot?
                  bis denne
                  Mr.Lee
                    Die Version 1.4.15 gibt es leider noch nicht im npm… 😞
                    • Dutchman
                      @DavidT:
                      Die Version 1.4.15 gibt es leider noch nicht im npm… 😞 `
                      Wer möchte könnte es aber per git Link installieren
                      Send from mobile device
                      • Dutchman
                        Wurde soeben durch Bluefox gefixt also beim nächsten Update ist der Fehler weg [emoji3]
                        https://github.com/ioBroker/ioBroker.hm … -340045194
                          heitau last edited by
                          ich habe seit gestern einen neuen Dimmaktor von Homematic IP und habe diesen auch eingebunden. Mit dem neuen Adapter konnte ich den Dimmaktor auch im ioBroker platzieren und auch bedienen. Nur Alexa findet dieses Gerät nicht. Was kann ich tun, damit auch dieser Dimmaktor über Alexa erkannt wird? Ich habe schon alle Dienste neu gestartet aber nicht passiert. So sieht es derzeit bei mir im ioBroker aus:
                          Kann mir bei diesem Problem jemand helfen?
                          Heiko
                          134
                          33157
