    4. Grafana reagiert nicht mehr auf Port 3000
    • werner2000x
      werner2000x @Thomas Braun last edited by werner2000x
                           v.2023-04-16
      Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
      Kernel:                 6.1.21-v8+
      Installation:           Native
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               true
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                              /usr/bin/node           v16.20.2
                              /usr/bin/npm            8.19.4
                              /usr/bin/npx            8.19.4
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            7.8G        4.8G        874M        9.0M        2.2G        3.2G
      Swap:            99M         99M        0.0K
      Total:          7.9G        4.8G        875M
      Active iob-Instances:   42
      Active repo(s): stable
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.198.39, run as: admin
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                22821
      States:                 19488
      Size of iob-Database:
      36M     /opt/iobroker/iobroker-data/objects.jsonl
      15M     /opt/iobroker/iobroker-data/objects.json.migrated
      15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      28M     /opt/iobroker/iobroker-data/states.jsonl
      3.4M    /opt/iobroker/iobroker-data/states.json.migrated
      3.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        Thomas Braun Most Active @werner2000x last edited by
        @werner2000x
        Das ist nicht die Langfassung.
        Aber bis auf den mitrumpelnden Desktop in Ordnung. Schalt den aus.
        werner2000x 1 Reply Last reply Reply Quote 0
        • werner2000x
          Raspi Desktop Ein:
          sudo systemctl set-default multi-user.target
          Raspi Desktop Aus:
          sudo systemctl set-default graphical.target
          iob diag
                               v.2023-04-16
          Kernel:                 6.1.21-v8+
          User-ID:                1000
          X-Server:               true
          Boot Target:            multi-user.target
                                  /usr/bin/npm            8.19.4
                                  /usr/bin/npx            8.19.4
          MEMORY:
          Mem:            7.8G        4.8G        421M        9.0M        2.6G        3.2G
          Swap:            99M         99M        0.0K
          Total:          7.9G        4.9G        421M
                                  admin                   6.8.0
          Objects type: jsonl
          States  type: jsonl
          Objects:                22821
          States:                 19488
          33M     /opt/iobroker/iobroker-data/states.jsonl
          passiert ...
            @werner2000x sagte in Grafana reagiert nicht mehr auf Port 3000:
            X-Server: true
            Der läuft noch. Einmal neustarten oder mit isolate das boot target setzen.
            • werner2000x
                                   v.2023-04-16
              Kernel:                 6.1.21-v8+
              User-ID:                1000
              X-Server:               false
                                      /usr/bin/npm            8.19.4
                                      /usr/bin/npx            8.19.4
              MEMORY:
              Mem:            7.8G        2.5G        3.9G        0.0K        1.4G        5.8G
              Swap:            99M          0B         99M
              Total:          7.9G        2.5G        4.0G
                                      admin                   6.8.0
              Objects type: jsonl
              States  type: jsonl
              Objects:                22540
              States:                 19332
              39M     /opt/iobroker/iobroker-data/objects.jsonl
              39M     /opt/iobroker/iobroker-data/states.jsonl
              passiert...
                https://github.com/grafana/grafana/issues/73781
                BMerz created this issue in grafana/grafana
                closed Grafana-Server crashes with SIGILL after update from 10.0.3 to 10.1.0 on RaspberryPi #73781
                werner2000x 1 Reply Last reply Reply Quote -1
                • werner2000x
                  werner2000x @crunchip last edited by
                  @crunchip Danke für den Link. Dann bin ich ja nicht alleine mit dem Fehler...
                    darkblu last edited by
                    @werner2000x ,
                    alleine bist du nicht, mich hat es auch erwischt.
                    Könnte man Grafana nicht einfach deinstallieren und wieder neu installieren, anschliessend per Backitup wieder auf den letzten stand bringen ?
                    Im neuen Grafana sollten ja nur die Dashboards fehlen und die werden dann ja wieder hergestellt ?
                    crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                      crunchip Forum Testing Most Active @darkblu last edited by
                      @darkblu sagte in Grafana reagiert nicht mehr auf Port 3000:
                      so einfach ist das nicht, denn dann installierst du ja wieder die version😜
                      guck ins issue, da ist es beschrieben
                        Thomas Braun Most Active @darkblu last edited by
                        @darkblu
                        Freie Auswahl bezüglich der Version:
                        echad@chet:~ $ apt policy grafana
                        grafana:
                          Installed: (none)
                          Candidate: 10.1.0
                          Version table:
                             10.1.0 500
                                500 https://apt.grafana.com stable/main arm64 Packages
                             10.0.4 500
                             10.0.3 500
                             10.0.2 500
                             10.0.1 500
                             10.0.0 500
                                100 /var/lib/dpkg/status
                             9.5.8 500
                             9.5.7 500
                             9.5.6 500
                             9.5.5 500
                             9.5.3 500
                             9.5.2 500
                             9.5.1 500
                             9.5.0 500
                             9.4.13 500
                             9.4.12 500
                             9.4.10 500
                             9.4.9 500
                             9.4.7 500
                             9.4.3 500
                             9.4.2 500
                             9.4.1 500
                             9.4.0 500
                             9.3.16 500
                             9.3.15 500
                             9.3.14 500
                             9.3.13 500
                             9.3.11 500
                             9.3.8 500
                             9.3.6 500
                             9.3.4 500
                             9.3.2 500
                             9.3.1 500
                             9.3.0 500
                             9.2.20 500
                             9.2.19 500
                             9.2.18 500
                             9.2.17 500
                             9.2.15 500
                             9.2.13 500
                             9.2.10 500
                             9.2.8 500
                             9.2.7 500
                             9.2.6 500
                             9.2.5 500
                             9.2.4 500
                             9.2.3 500
                             9.2.2 500
                             9.2.1 500
                             9.2.0 500
                             9.1.8 500
                             9.1.7 500
                             9.1.6 500
                             9.1.5 500
                             9.1.4 500
                             9.1.3 500
                             9.1.2 500
                             9.1.1 500
                             9.1.0 500
                             9.0.9 500
                             9.0.8 500
                             9.0.7 500
                             9.0.6 500
                             9.0.5 500
                             9.0.4 500
                             9.0.3 500
                             9.0.2 500
                             9.0.1 500
                             9.0.0 500
                             8.5.27 500
                             8.5.26 500
                             8.5.25 500
                             8.5.24 500
                             8.5.22 500
                             8.5.21 500
                             8.5.20 500
                             8.5.16 500
                             8.5.15 500
                             8.5.14 500
                             8.5.13 500
                             8.5.12 500
                             8.5.10 500
                             8.5.9 500
                             8.5.6 500
                             8.5.5 500
                             8.5.4 500
                             8.5.3 500
                             8.5.2 500
                             8.5.1 500
                             8.5.0 500
                             8.4.11 500
                             8.4.10 500
                             8.4.7 500
                             8.4.6 500
                             8.4.5 500
                             8.4.4 500
                             8.4.3 500
                             8.4.2 500
                             8.4.1 500
                             8.4.0 500
                             8.3.11 500
                             8.3.10 500
                             8.3.7 500
                             8.3.6 500
                             8.3.5 500
                             8.3.4 500
                             8.3.3 500
                             8.3.2 500
                             8.3.1 500
                             8.3.0 500
                             8.2.7 500
                             8.2.6 500
                             8.2.5 500
                             8.2.4 500
                             8.2.3 500
                             8.2.2 500
                             8.2.1 500
                             8.2.0 500
                             8.1.8 500
                             8.1.7 500
                             8.1.6 500
                             8.1.5 500
                             8.1.4 500
                             8.1.3 500
                             8.1.2 500
                             8.1.1 500
                             8.1.0 500
                             8.0.7 500
                             8.0.6 500
                             8.0.5 500
                             8.0.4 500
                             8.0.3 500
                             8.0.2 500
                             8.0.1 500
                             8.0.0 500
                             7.5.16 500
                             7.5.15 500
                             7.5.13 500
                             7.5.12 500
                             7.5.11 500
                             7.5.10 500
                             7.5.9 500
                             7.5.8 500
                             7.5.7 500
                             7.5.6 500
                             7.5.5 500
                             7.5.4 500
                             7.5.3 500
                             7.5.2 500
                             7.5.1 500
                             7.5.0 500
                             7.4.5 500
                             7.4.3 500
                             7.4.2 500
                             7.4.1 500
                             7.4.0 500
                             7.3.10 500
                             7.3.7 500
                             7.3.6 500
                             7.3.5 500
                             7.3.4 500
                             7.3.3 500
                             7.3.2 500
                             7.3.1 500
                             7.3.0 500
                             7.2.2 500
                             7.2.1 500
                             7.2.0 500
                             7.1.5 500
                             7.1.4 500
                             7.1.3 500
                             7.1.2 500
                             7.1.1 500
                             7.1.0 500
                             7.0.6 500
                             7.0.5 500
                             7.0.4 500
                             7.0.3 500
                             7.0.2 500
                             7.0.1 500
                             7.0.0 500
                             6.7.6 500
                             6.7.5 500
                             6.7.4 500
                             6.7.3 500
                             6.7.2 500
                             6.7.1 500
                             6.7.0 500
                             6.6.2 500
                             6.6.1 500
                             6.6.0 500
                             6.5.3 500
                             6.5.2 500
                             6.5.1 500
                             6.5.0 500
                             6.4.5 500
                             6.4.4 500
                             6.4.3 500
                             6.4.2 500
                             6.4.1 500
                             6.4.0 500
                             6.3.7 500
                             6.3.6 500
                             6.3.5 500
                             6.3.4 500
                             6.3.3 500
                             6.3.2 500
                             6.3.1 500
                             6.3.0 500
                             6.2.5 500
                             6.2.4 500
                             6.2.3 500
                             6.2.2 500
                             6.2.1 500
                             6.2.0 500
                             6.1.6 500
                             6.1.5 500
                             6.1.4 500
                             6.1.3 500
                             6.1.2 500
                             6.1.1 500
                             6.1.0 500
                             6.0.2 500
                             6.0.1 500
                             6.0.0 500
                             5.4.5 500
                             5.4.4 500
                             5.4.3 500
                             5.4.2 500
                             5.4.1 500
                             5.4.0 500
                             5.3.4 500
                             5.3.3 500
                             5.3.2 500
                             5.3.1 500
                             5.3.0 500
                             5.2.5 500
                             5.2.4 500
                             5.2.3 500
                             5.2.2 500
                             5.2.1 500
                             5.2.0 500
                             0.0.0~test 500
                        sudo apt install grafana=WUNSCHVERSION
                        Vielleicht grafana vorerst auf hold setzen, fertig:
                        sudo apt-mark hold grafana
                        • Meister Mopper
                          Meister Mopper last edited by
                          Im von @crunchip beschriebenen issue steht es doch, einfach tun:
                          For those who have a similar issue and want to downgrade:
                              Backup /etc/grafana and /var/lib/grafana
                              apt-get remove grafana
                              apt-get install grafana=10.0.3
                          Re-Enable/Start Grafana daemon
                              sudo /bin/systemctl daemon-reload
                              sudo /bin/systemctl enable grafana-server
                              sudo /bin/systemctl start grafana-server
                          After that Grafana works like before ;-)
                            darkblu last edited by darkblu
                            @crunchip
                            @Meister-Mopper ,
                            wollte ich eben nachmachen, scheinbar bin ich zu doof: 🤷‍♂️
                            also die ersten beiden funktionieren schon nicht.
                            pi@raspberrypi:~ $ Backup /etc/grafana and /var/lib/grafana
                            -bash: Backup: Kommando nicht gefunden.
                            pi@raspberrypi:~ $ apt-get remove grafana
                            E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                            E: Erlangen der Sperre für die Dpkg-Oberfläche (/var/lib/dpkg/lock-frontend) nicht möglich; sind Sie root?
                            pi@raspberrypi:~ $
                            könnt ihr mir den schubs in die richtige Richtung geben ?
                              @darkblu du sollst dir die Verzeichnisse sichern
                              das heisst du kopierst sie dir irgendwo hin
                              nein, also mit sudo voran
                                @darkblu
                                sudo apt install grafana=10.0.3
                                Wenn es wieder eine funktionierende Version gibt per
                                sudo apt-mark unhold grafana
                                auf den Update-Zug aufspringen.
                                  darkblu @Thomas Braun last edited by
                                  @thomas-braun said in Grafana reagiert nicht mehr auf Port 3000:
                                  @darkblu
                                  also nur die zwei ersten Befehle von dir und irgendwann dann den dritten wenn der Fehler in einer der nächsten Versionen gefixt ist ?
                                    Thomas Braun Most Active @darkblu last edited by Thomas Braun
                                    @darkblu
                                    Den Service musst du natürlich noch neustarten:
                                    sudo systemctl daemon-reload
                                    sudo systemctl enable grafana-server
                                    sudo systemctl start grafana-server
                                      @thomas-braun ,
                                      DANKE, löppt wieder 👏 (auf 10.0.3)
                                        Hallo, hat schon jemand die Grafana 10.1.1. probiert ?
                                        Ich trau mich (noch) nicht 😧
                                        • Meister Mopper
                                          Meister Mopper @darkblu last edited by
                                          Ja, läuft bei mir fehlerfrei.
                                          • werner2000x
                                            werner2000x @Meister Mopper last edited by werner2000x
                                            @meister-mopper Bei mir klappt es mit 10.0.1 noch nicht mit dem Port 3000.
                                            Die Version 10.0.3 habe ich noch nicht bekommen.
                                            Mit sudo apt update erhalte ich folgende Meldung:
                                            Die folgenden Pakete sind zur▒ckgehalten worden:
                                              grafana
                                            1.0k
                                            3000 grafana port
                                            2384
