    4. Grafana reagiert nicht mehr auf Port 3000
    • werner2000x
      werner2000x @Thomas Braun last edited by werner2000x
      Raspi Desktop Ein:
      sudo systemctl set-default multi-user.target
      Raspi Desktop Aus:
      sudo systemctl set-default graphical.target
      iob diag
                           v.2023-04-16
      Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
      Kernel:                 6.1.21-v8+
      Installation:           Native
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               true
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                              /usr/bin/node           v16.20.2
                              /usr/bin/npm            8.19.4
                              /usr/bin/npx            8.19.4
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            7.8G        4.8G        421M        9.0M        2.6G        3.2G
      Swap:            99M         99M        0.0K
      Total:          7.9G        4.9G        421M
      Active iob-Instances:   42
      Active repo(s): stable
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.198.39, run as: admin
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                22821
      States:                 19488
      Size of iob-Database:
      36M     /opt/iobroker/iobroker-data/objects.jsonl
      15M     /opt/iobroker/iobroker-data/objects.json.migrated
      15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      33M     /opt/iobroker/iobroker-data/states.jsonl
      3.4M    /opt/iobroker/iobroker-data/states.json.migrated
      3.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      passiert ...
        Thomas Braun Most Active @werner2000x last edited by
        @werner2000x sagte in Grafana reagiert nicht mehr auf Port 3000:
        X-Server: true
        Der läuft noch. Einmal neustarten oder mit isolate das boot target setzen.
        werner2000x 1 Reply Last reply Reply Quote 0
        • werner2000x
                               v.2023-04-16
          Kernel:                 6.1.21-v8+
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            8.19.4
                                  /usr/bin/npx            8.19.4
          MEMORY:
          Mem:            7.8G        2.5G        3.9G        0.0K        1.4G        5.8G
          Swap:            99M          0B         99M
          Total:          7.9G        2.5G        4.0G
                                  admin                   6.8.0
          Objects type: jsonl
          States  type: jsonl
          Objects:                22540
          States:                 19332
          39M     /opt/iobroker/iobroker-data/objects.jsonl
          39M     /opt/iobroker/iobroker-data/states.jsonl
          passiert...
            https://github.com/grafana/grafana/issues/73781
            BMerz created this issue in grafana/grafana
            closed Grafana-Server crashes with SIGILL after update from 10.0.3 to 10.1.0 on RaspberryPi #73781
            werner2000x 1 Reply Last reply Reply Quote -1
            • werner2000x
              werner2000x @crunchip last edited by
              @crunchip Danke für den Link. Dann bin ich ja nicht alleine mit dem Fehler...
                darkblu last edited by
                @werner2000x ,
                alleine bist du nicht, mich hat es auch erwischt.
                Könnte man Grafana nicht einfach deinstallieren und wieder neu installieren, anschliessend per Backitup wieder auf den letzten stand bringen ?
                Im neuen Grafana sollten ja nur die Dashboards fehlen und die werden dann ja wieder hergestellt ?
                crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                  crunchip Forum Testing Most Active @darkblu last edited by
                  @darkblu sagte in Grafana reagiert nicht mehr auf Port 3000:
                  so einfach ist das nicht, denn dann installierst du ja wieder die version😜
                  guck ins issue, da ist es beschrieben
                    Thomas Braun Most Active @darkblu last edited by
                    @darkblu
                    Freie Auswahl bezüglich der Version:
                    echad@chet:~ $ apt policy grafana
                    grafana:
                      Installed: (none)
                      Candidate: 10.1.0
                      Version table:
                         10.1.0 500
                            500 https://apt.grafana.com stable/main arm64 Packages
                         10.0.4 500
                         10.0.3 500
                         10.0.2 500
                         10.0.1 500
                         10.0.0 500
                            100 /var/lib/dpkg/status
                         9.5.8 500
                         9.5.7 500
                         9.5.6 500
                         9.5.5 500
                         9.5.3 500
                         9.5.2 500
                         9.5.1 500
                         9.5.0 500
                         9.4.13 500
                         9.4.12 500
                         9.4.10 500
                         9.4.9 500
                         9.4.7 500
                         9.4.3 500
                         9.4.2 500
                         9.4.1 500
                         9.4.0 500
                         9.3.16 500
                         9.3.15 500
                         9.3.14 500
                         9.3.13 500
                         9.3.11 500
                         9.3.8 500
                         9.3.6 500
                         9.3.4 500
                         9.3.2 500
                         9.3.1 500
                         9.3.0 500
                         9.2.20 500
                         9.2.19 500
                         9.2.18 500
                         9.2.17 500
                         9.2.15 500
                         9.2.13 500
                         9.2.10 500
                         9.2.8 500
                         9.2.7 500
                         9.2.6 500
                         9.2.5 500
                         9.2.4 500
                         9.2.3 500
                         9.2.2 500
                         9.2.1 500
                         9.2.0 500
                         9.1.8 500
                         9.1.7 500
                         9.1.6 500
                         9.1.5 500
                         9.1.4 500
                         9.1.3 500
                         9.1.2 500
                         9.1.1 500
                         9.1.0 500
                         9.0.9 500
                         9.0.8 500
                         9.0.7 500
                         9.0.6 500
                         9.0.5 500
                         9.0.4 500
                         9.0.3 500
                         9.0.2 500
                         9.0.1 500
                         9.0.0 500
                         8.5.27 500
                         8.5.26 500
                         8.5.25 500
                         8.5.24 500
                         8.5.22 500
                         8.5.21 500
                         8.5.20 500
                         8.5.16 500
                         8.5.15 500
                         8.5.14 500
                         8.5.13 500
                         8.5.12 500
                         8.5.10 500
                         8.5.9 500
                         8.5.6 500
                         8.5.5 500
                         8.5.4 500
                         8.5.3 500
                         8.5.2 500
                         8.5.1 500
                         8.5.0 500
                         8.4.11 500
                         8.4.10 500
                         8.4.7 500
                         8.4.6 500
                         8.4.5 500
                         8.4.4 500
                         8.4.3 500
                         8.4.2 500
                         8.4.1 500
                         8.4.0 500
                         8.3.11 500
                         8.3.10 500
                         8.3.7 500
                         8.3.6 500
                         8.3.5 500
                         8.3.4 500
                         8.3.3 500
                         8.3.2 500
                         8.3.1 500
                         8.3.0 500
                         8.2.7 500
                         8.2.6 500
                         8.2.5 500
                         8.2.4 500
                         8.2.3 500
                         8.2.2 500
                         8.2.1 500
                         8.2.0 500
                         8.1.8 500
                         8.1.7 500
                         8.1.6 500
                         8.1.5 500
                         8.1.4 500
                         8.1.3 500
                         8.1.2 500
                         8.1.1 500
                         8.1.0 500
                         8.0.7 500
                         8.0.6 500
                         8.0.5 500
                         8.0.4 500
                         8.0.3 500
                         8.0.2 500
                         8.0.1 500
                         8.0.0 500
                         7.5.16 500
                         7.5.15 500
                         7.5.13 500
                         7.5.12 500
                         7.5.11 500
                         7.5.10 500
                         7.5.9 500
                         7.5.8 500
                         7.5.7 500
                         7.5.6 500
                         7.5.5 500
                         7.5.4 500
                         7.5.3 500
                         7.5.2 500
                         7.5.1 500
                         7.5.0 500
                         7.4.5 500
                         7.4.3 500
                         7.4.2 500
                         7.4.1 500
                         7.4.0 500
                         7.3.10 500
                         7.3.7 500
                         7.3.6 500
                         7.3.5 500
                         7.3.4 500
                         7.3.3 500
                         7.3.2 500
                         7.3.1 500
                         7.3.0 500
                         7.2.2 500
                         7.2.1 500
                         7.2.0 500
                         7.1.5 500
                         7.1.4 500
                         7.1.3 500
                         7.1.2 500
                         7.1.1 500
                         7.1.0 500
                         7.0.6 500
                         7.0.5 500
                         7.0.4 500
                         7.0.3 500
                         7.0.2 500
                         7.0.1 500
                         7.0.0 500
                         6.7.6 500
                         6.7.5 500
                         6.7.4 500
                         6.7.3 500
                         6.7.2 500
                         6.7.1 500
                         6.7.0 500
                         6.6.2 500
                         6.6.1 500
                         6.6.0 500
                         6.5.3 500
                         6.5.2 500
                         6.5.1 500
                         6.5.0 500
                         6.4.5 500
                         6.4.4 500
                         6.4.3 500
                         6.4.2 500
                         6.4.1 500
                         6.4.0 500
                         6.3.7 500
                         6.3.6 500
                         6.3.5 500
                         6.3.4 500
                         6.3.3 500
                         6.3.2 500
                         6.3.1 500
                         6.3.0 500
                         6.2.5 500
                         6.2.4 500
                         6.2.3 500
                         6.2.2 500
                         6.2.1 500
                         6.2.0 500
                         6.1.6 500
                         6.1.5 500
                         6.1.4 500
                         6.1.3 500
                         6.1.2 500
                         6.1.1 500
                         6.1.0 500
                         6.0.2 500
                         6.0.1 500
                         6.0.0 500
                         5.4.5 500
                         5.4.4 500
                         5.4.3 500
                         5.4.2 500
                         5.4.1 500
                         5.4.0 500
                         5.3.4 500
                         5.3.3 500
                         5.3.2 500
                         5.3.1 500
                         5.3.0 500
                         5.2.5 500
                         5.2.4 500
                         5.2.3 500
                         5.2.2 500
                         5.2.1 500
                         5.2.0 500
                         0.0.0~test 500
                    sudo apt install grafana=WUNSCHVERSION
                    Vielleicht grafana vorerst auf hold setzen, fertig:
                    sudo apt-mark hold grafana
                    • Meister Mopper
                      Meister Mopper last edited by
                      Im von @crunchip beschriebenen issue steht es doch, einfach tun:
                      For those who have a similar issue and want to downgrade:
                          Backup /etc/grafana and /var/lib/grafana
                          apt-get remove grafana
                          apt-get install grafana=10.0.3
                      Re-Enable/Start Grafana daemon
                          sudo /bin/systemctl daemon-reload
                          sudo /bin/systemctl enable grafana-server
                          sudo /bin/systemctl start grafana-server
                      After that Grafana works like before ;-)
                        darkblu last edited by darkblu
                        @crunchip
                        @Meister-Mopper ,
                        wollte ich eben nachmachen, scheinbar bin ich zu doof: 🤷‍♂️
                        also die ersten beiden funktionieren schon nicht.
                        pi@raspberrypi:~ $ Backup /etc/grafana and /var/lib/grafana
                        -bash: Backup: Kommando nicht gefunden.
                        pi@raspberrypi:~ $ apt-get remove grafana
                        E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                        E: Erlangen der Sperre für die Dpkg-Oberfläche (/var/lib/dpkg/lock-frontend) nicht möglich; sind Sie root?
                        pi@raspberrypi:~ $
                        könnt ihr mir den schubs in die richtige Richtung geben ?
                          @darkblu du sollst dir die Verzeichnisse sichern
                          das heisst du kopierst sie dir irgendwo hin
                          nein, also mit sudo voran
                            @darkblu
                            sudo apt install grafana=10.0.3
                            Wenn es wieder eine funktionierende Version gibt per
                            sudo apt-mark unhold grafana
                            auf den Update-Zug aufspringen.
                              darkblu @Thomas Braun last edited by
                              @thomas-braun said in Grafana reagiert nicht mehr auf Port 3000:
                              @darkblu
                              also nur die zwei ersten Befehle von dir und irgendwann dann den dritten wenn der Fehler in einer der nächsten Versionen gefixt ist ?
                                Thomas Braun Most Active @darkblu last edited by Thomas Braun
                                @darkblu
                                Den Service musst du natürlich noch neustarten:
                                sudo systemctl daemon-reload
                                sudo systemctl enable grafana-server
                                sudo systemctl start grafana-server
                                  @thomas-braun ,
                                  DANKE, löppt wieder 👏 (auf 10.0.3)
                                    Hallo, hat schon jemand die Grafana 10.1.1. probiert ?
                                    Ich trau mich (noch) nicht 😧
                                    • Meister Mopper
                                      Meister Mopper @darkblu last edited by
                                      Ja, läuft bei mir fehlerfrei.
                                      • werner2000x
                                        werner2000x @Meister Mopper last edited by werner2000x
                                        @meister-mopper Bei mir klappt es mit 10.0.1 noch nicht mit dem Port 3000.
                                        Die Version 10.0.3 habe ich noch nicht bekommen.
                                        Mit sudo apt update erhalte ich folgende Meldung:
                                        Die folgenden Pakete sind zur▒ckgehalten worden:
                                          grafana
                                          @werner2000x
                                          Dann klemmt da etwas bei dir.
                                          sudo apt update
                                          sudo apt full-upgrade
                                          liefert?
                                          • werner2000x
                                            @thomas-braun sagte in Grafana reagiert nicht mehr auf Port 3000:
                                            Danke, klappt jetzt 🙂
                                            3000 grafana port
                                            2384
