    4. Performance Probleme im iobroker Admin auf pi4
      maxpd @crunchip last edited by
      @crunchip
      pi@iobroker:~ $ find "/opt/iobroker/node_modules" -type d -iname ".*-????????" !        -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
      pi@iobroker:~ $ cd /opt/iobroker
      pi@iobroker:/opt/iobroker $ npm prune
      npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.sma-em.git
      npm WARN skipping integrity check for git dependency ssh://git@github.com/BuZZy1337/ioBroker.doorbird.git
      npm WARN skipping integrity check for git dependency ssh://git@github.com/nbuenger/ioBroker.govee.git
      npm WARN skipping integrity check for git dependency ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git
      npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.chromecast.git
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You m                            ay safely remove the package from your dependencies.
      npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the on                            e that's built-in.
      npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
      npm WARN deprecated topo@3.0.3: This module has moved and is now available at @hapi/topo. Please update your dependencies as this version is no longer maintained                             an may contain bugs and security issues.
      npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://g                            ithub.com/request/request/issues/3142
      npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check https://opencollective.com/babel to support the Babe                            l maintainers
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/requ                            est/request/issues/3142
      npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained                             an may contain bugs and security issues.
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recom                            mended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be prob                            lematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated joi@14.3.1: This module has moved and is now available at @hapi/joi. Please update your dependencies as this version is no longer maintained                             an may contain bugs and security issues.
      npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
      removed 861 packages, and changed 1482 packages in 7m
      141 packages are looking for funding
        run `npm fund` for details
      Ich glaube die gelöschten Adapter hat er wieder Installiert 🍡
      pi@iobroker:/opt/iobroker $ cd /opt/iobroker && npm ls
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
      npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
      npm ERR! invalid: iobroker.chromecast@3.0.3 /opt/iobroker/node_modules/iobroker.chromecast
      npm ERR! invalid: iobroker.doorbird@0.1.5 /opt/iobroker/node_modules/iobroker.doorbird
      npm ERR! invalid: iobroker.google-sharedlocations@2.1.5 /opt/iobroker/node_modules/iobroker.google-sharedlocations
      npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
      npm ERR! invalid: iobroker.sma-em@0.6.4 /opt/iobroker/node_modules/iobroker.sma-em
      npm ERR! invalid: iobroker.sma-speedwire@0.7.0 /opt/iobroker/node_modules/iobroker.sma-speedwire
      npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      iobroker.inst@2.0.3 /opt/iobroker
      ├── @types/caseless@0.12.2 extraneous
      ├── @types/request@2.48.8 extraneous
      ├── @types/tough-cookie@4.0.2 extraneous
      ├── coffeescript@1.12.7 extraneous
      ├── colors@1.4.0
      ├── fs-extra@7.0.1
      ├── iobroker.admin@6.3.5
      ├── iobroker.alias-manager@1.2.6
      ├── iobroker.backitup@2.6.19
      ├── iobroker.chromecast@3.0.3 invalid: "github:iobroker-community-adapters/ioBroker.chromecast#426f5814382158fd28b785badf08773ea412dcb5" from the root project
      ├── iobroker.cloud@4.3.0
      ├── iobroker.coronavirus-statistics@0.8.7
      ├── iobroker.daswetter@3.1.8
      ├── iobroker.denon@1.15.0
      ├── iobroker.devices@1.1.2
      ├── iobroker.discovery@3.1.0
      ├── iobroker.doorbird@0.1.5 invalid: "github:BuZZy1337/ioBroker.doorbird#47440ddff9a9074ef1e0beb8ff7b7f2a6e368efb" from the root project
      ├── iobroker.feiertage@1.1.0
      ├── iobroker.flot@1.11.0
      ├── iobroker.go-e@1.0.27
      ├── iobroker.google-sharedlocations@2.1.5 invalid: "github:Garfonso/ioBroker.google-sharedlocations#73f8c9bd627e81518dec7e659d98332bd84d9e69" from the root project
      ├── iobroker.govee@0.0.5 invalid: "github:nbuenger/ioBroker.govee#0d983c49135b87ac2f88f9d832a6d632c4889606" from the root project
      ├── iobroker.history@2.2.4
      ├── iobroker.hm-rega@3.0.46
      ├── iobroker.hm-rpc@1.15.16
      ├── iobroker.ical@1.13.2
      ├── iobroker.info@1.9.26
      ├── iobroker.iot@1.14.2
      ├── iobroker.javascript@6.1.4
      ├── iobroker.js-controller@4.0.24
      ├── iobroker.lgtv@1.1.12
      ├── iobroker.lovelace@3.0.1
      ├── iobroker.mihome-vacuum@3.9.5
      ├── iobroker.modbus@5.0.11
      ├── iobroker.mqtt-client@1.6.3
      ├── iobroker.mqtt@4.0.7
      ├── iobroker.net-tools@0.2.0
      ├── iobroker.pi-hole@1.3.4
      ├── iobroker.ping@1.5.3
      ├── iobroker.rpi2@1.3.2
      ├── iobroker.sayit@1.13.0
      ├── iobroker.shelly@6.3.1
      ├── iobroker.shuttercontrol@1.4.29
      ├── iobroker.simple-api@2.7.2
      ├── iobroker.sma-em@0.6.4 invalid: "github:iobroker-community-adapters/ioBroker.sma-em#4b2a4a1f3736ca56d1dae532e47219647609799f" from the root project
      ├── iobroker.sma-speedwire@0.7.0 invalid: "https://github.com/Apollon77/iobroker.sma-speedwire/tarball/3dce8e5d3fb9112502ba697a0f41ec0ab0aa90f4" from the root project
      ├── iobroker.socketio@4.2.0
      ├── iobroker.sonoff@2.5.1
      ├── iobroker.spotify-premium@1.2.1
      ├── iobroker.sunnyportal@0.1.5
      ├── iobroker.synology@2.1.13
      ├── iobroker.systeminfo@0.3.1
      ├── iobroker.telegram@1.15.2
      ├── iobroker.terminal@1.0.0
      ├── iobroker.text2command@2.3.0
      ├── iobroker.tr-064@4.2.17
      ├── iobroker.tuya@3.13.1
      ├── iobroker.web@4.3.0
      ├── iobroker.whatsapp-cmb@0.2.3
      ├── iobroker.wifilight@1.1.4
      ├── iobroker.wled@0.6.7
      ├── iobroker.yeelight-2@1.2.1
      ├── iobroker.youtube@4.1.0
      ├── iobroker.zigbee@1.8.10
      ├── jsonata@1.8.6 extraneous
      ├── node-inspect@2.0.0 extraneous
      ├── semver@5.7.2
      ├── typescript@4.7.4 extraneous
      ├── virtual-tsc@0.6.2 extraneous
      ├── wake_on_lan@1.0.0 extraneous
      └── yargs@7.1.2
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-25T13_13_20_856Z-debug-0.log
      Qix- created this issue in visionmedia/debug
      closed ReDos Vulnerability Regression Visibility Notice #797
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @maxpd last edited by Thomas Braun
        @maxpd sagte in Performance Probleme im iobroker Admin auf pi4:
        chromecast
        Installier den z. B. nochmal drüber.
        Bzw. installier den aus dem stable-Repository.
        Gleiches gilt für die anderen mit 'invalid' markierten Adapter.
        chromecast
        github:	3.1.0 for 9 days
        latest:	3.0.3 for 12 months
        stable:	3.0.3 for 12 months
        doorbird
        github:	1.2.3
        latest:	1.2.3 for 7 days
        stable:	1.2.3 for 7 days
        sma-em
        github:	1.0.0
        latest:	1.0.0 for 6 days
        stable:	0.7.0 for 5 months
          crunchip Forum Testing Most Active @maxpd last edited by
          sollst ja auch nicht unbedingt löschen, nur zusehen, das diese per iobroker installiert sind und keine git versionen aufweisen
          ursprüngliche Problem war ja, der esphome Adapter, der kein update/installieren zugelassen hat
            Die installation klappt leider weiterhin nicht.
            $ iobroker url iobroker.chromecast --host iobroker --debug
            install iobroker.chromecast
            NPM version: 9.6.7
            Installing iobroker.chromecast... (System call)
            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
            npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
            npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
            npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check https://opencollective.com/babel to support the Babel maintainers
            npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
            npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
            INFO: Directory "/opt/iobroker/node_modules/iobroker.chromecast/admin" was not found! Nothing was uploaded or deleted.
            Process exited with code 0
            Habe auch nicht mitbekommen, an welcher Stelle wir ESP Home wegbekamen. Hatte den genauso gelöscht wie die anderen Adapter, die jetzt wieder da sind.
              Das ist ja auch nicht der Befehl dafür.
              Was machst du da bei den Installationen?
                maxpd @Thomas Braun last edited by
                @thomas-braun sorry, übers interface installieren 😞
                  @maxpd
                  Versuch es z. B. damit in der Kommandozeile:
                  iobroker upgrade chromecast@3.0.3
                    @thomas-braun Habe mich an einen Beitrag weiter vorne erinnert und es für den Adapter nun auch so probiert ja. Für den SMA Adapter hat es übers Interface funktioniert. Für Chromecast nun auch über die Konsole. Aber 8 Min egal über welche Variante kommt mir seeehr lang vor, wobei wir wieder beim ursprünglichen Performance Problem sind ^^
                    pi@iobroker:~ $ iobroker upgrade chromecast@3.0.3 --debug
                    Would you like to reinstall version 3.0.3 of chromecast now? [(y)es, (n)o]: y
                    Update chromecast from @3.0.3 to @3.0.3
                    NPM version: 9.6.7
                    Installing iobroker.chromecast@3.0.3... (System call)
                    npm WARN skipping integrity check for git dependency ssh://git@github.com/nbueng        er/ioBroker.govee.git
                    npm WARN skipping integrity check for git dependency ssh://git@github.com/Garfon        so/ioBroker.google-sharedlocations.git
                    npm WARN skipping integrity check for git dependency ssh://git@github.com/BuZZy1        337/ioBroker.doorbird.git
                    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reason        s. As it's a core Node module, we will not transfer it over to other users. You        may safely remove the package from your dependencies.
                    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now        a built-in Node module. If you've depended on crypto, you should switch to the o        ne that's built-in.
                    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide        s its own type definitions, so you do not need this installed.
                    npm WARN deprecated topo@3.0.3: This module has moved and is now available at @h        api/topo. Please update your dependencies as this version is no longer maintaine        d an may contain bugs and security issues.
                    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has bee        n deprecated because it extends the now deprecated request package, see https://        github.com/request/request/issues/3142
                    npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated        in favor of babel-cli. Check https://opencollective.com/babel to support the Bab        el maintainers
                    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b        ecause it extends the now deprecated request package, see https://github.com/req        uest/request/issues/3142
                    npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @h        api/hoek. Please update your dependencies as this version is no longer maintaine        d an may contain bugs and security issues.
                    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS        ON 3
                    npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, fl        atted is its successor.
                    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav        e a low-severity ReDos regression when used in a Node.js environment. It is reco        mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss        ues/797)
                    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v        ersions may use Math.random() in certain circumstances, which is known to be pro        blematic.  See https://v8.dev/blog/math-random for details.
                    npm WARN deprecated request@2.88.2: request has been deprecated, see https://git        hub.com/request/request/issues/3142
                    npm WARN deprecated joi@14.3.1: This module has moved and is now available at @h        api/joi. Please update your dependencies as this version is no longer maintained        an may contain bugs and security issues.
                    removed 861 packages, and changed 1482 packages in 8m
                    upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                    upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                    upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                    upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                      Dein Setup ist ja vermutlich noch nicht wieder senkrecht.
                        @maxpd
                        Wo stehen wir denn nun?
                        und
                        iob update
                        sagt?
                          Ich bin noch beim Austausch der Adapter, habe aber Probleme mit npm.
                          pi@iobroker:~ $ cd /opt/iobroker && npm ls
                          ├── colors@1.4.0
                          ├── fs-extra@7.0.1
                          ├── iobroker.doorbird@1.2.3
                          ├── iobroker.sma-em@0.7.0
                          ├── semver@5.7.2
                          └── yargs@7.1.2
                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-26T04_51_22_964Z-debug-0.log
                          pi@iobroker:/opt/iobroker $ iobroker upgrade sma-speedwire@0.7.0 --debug
                          Adapter "sma-speedwire" is not in the repository and cannot be updated.
                          Cannot upgrade: Cannot read properties of undefined (reading 'controller')
                          pi@iobroker:/opt/iobroker $ iobroker upgrade google-sharedlocations@2.1.5 --debug
                          Adapter "google-sharedlocations" is not in the repository and cannot be updated.
                          pi@iobroker:/opt/iobroker $ iobroker upgrade google-sharedlocations@1.5.2 --debu        g
                          z.B. der sharedlocations Adapter. Dieser ist bei npm in einer 5 Jahre alten Version. Seit dem hat sich sehr viel bei dem Adapter getan. Aber auch die 5 Jahre alte Version findet er nicht.
                          Den sma-speedwire kann man auch löschen, wird nicht benötigt.
                            @maxpd
                            Dann schmeiß das raus, was nicht benötigt wird.
                            Den Rest in aktueller Version drüber installieren.
                              @thomas-braun bevor ich es wieder falsch mache. wie installiere ich den Google shared locations über npm? dort wird der nicht gefunden.
                              und wie installiere ich die aktuelle Version drüber, wenn auf npm nur die 5 Jahre alte liegt?
                                @maxpd
                                Keine Ahnung. Hab den selber nicht im Einsatz. Wo haste den denn her?
                                Der?
                                https://github.com/t4qjXH8N/ioBroker.google-sharedlocations
                                Dann installier den nochmal frisch aus GitHub
                                  @thomas-braun genau den. aber ich habe es jetzt so verstanden, dass man nichts aus GitHub installieren darf, da offensichtlich 😂 das System kaputt geht.
                                    @maxpd
                                    Man vermeidet es und hat nur so wenig wie möglich aus GitHub geangeltes im System.
                                    Aber wenn es nicht anders geht...
                                      @thomas-braun warum bringen die Entwickler ihre Adapter nicht zu npm? oder halten sie dort aktuell?
                                        @maxpd
                                        Das musst du dort fragen. Der Adapter sieht auch etwas verwaist aus.
                                        Gilt auch für den govee.
                                        Schau mal ob der nicht durch govee-app oder govee-local ersetzt werden kann.
                                          @thomas-braun said in Performance Probleme im iobroker Admin auf pi4:
                                          @maxpd
                                          und
                                          iob update
                                          sagt?
                                          npm ERR! invalid: iobroker.google-sharedlocations@2.1.3 /opt/iobroker/node_modules/iobroker.google-sharedlocations
                                          ├── colors@1.4.0
                                          ├── fs-extra@7.0.1
                                          ├── iobroker.google-sharedlocations@2.1.3 invalid: "github:t4qjXH8N/ioBroker.google-sharedlocations" from the root project
                                          ├── semver@5.7.2
                                          └── yargs@7.1.2
                                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-26T19_59_46_695Z-debug-0.log
                                          pi@iobroker:/opt/iobroker $ iob update
                                          Used repository: stable
                                          Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                                          Adapter    "alias-manager": 1.2.4    , installed 1.2.6
                                          Adapter    "backitup"     : 2.6.23   , installed 2.6.19 [Updatable]
                                          Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                                          Adapter    "cloud"        : 4.4.1    , installed 4.3.0  [Updatable]
                                          Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                          Adapter    "daswetter"    : 3.1.10   , installed 3.1.8  [Updatable]
                                          Adapter    "denon"        : 1.15.3   , installed 1.15.0 [Updatable]
                                          Adapter    "devices"      : 1.1.5    , installed 1.1.2  [Updatable]
                                          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                          Adapter    "doorbird"     : 1.2.3    , installed 1.2.3
                                          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                          Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
                                          Adapter    "go-e"         : 1.0.27   , installed 1.0.27
                                          Adapter    "history"      : 2.2.4    , installed 2.2.4
                                          Adapter    "hm-rega"      : 3.0.47   , installed 3.0.46 [Updatable]
                                          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
                                          Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
                                          Adapter    "info"         : 1.9.26   , installed 1.9.26
                                          Adapter    "iot"          : 1.14.5   , installed 1.14.2 [Updatable]
                                          Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
                                          Controller "js-controller": 4.0.24   , installed 4.0.24
                                          Adapter    "lgtv"         : 1.1.10   , installed 1.1.12
                                          Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                                          Adapter    "mihome-vacuum": 3.11.0   , installed 3.9.5  [Updatable]
                                          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                                          Adapter    "mqtt"         : 4.1.1    , installed 4.0.7  [Updatable]
                                          Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                                          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.4  [Updatable]
                                          Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                                          Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
                                          Adapter    "shelly"       : 6.4.1    , installed 6.3.1  [Updatable]
                                          Adapter    "shuttercontrol": 1.6.1   , installed 1.4.29 [Updatable]
                                          Adapter    "sma-em"       : 0.7.0    , installed 0.7.0
                                          Adapter    "sonoff"       : 2.5.3    , installed 2.5.1  [Updatable]
                                          Adapter    "spotify-premium": 1.2.2  , installed 1.2.1  [Updatable]
                                          Adapter    "synology"     : 2.1.13   , installed 2.1.13
                                          Adapter    "systeminfo"   : 1.0.0    , installed 0.3.1  [Updatable]
                                          Adapter    "telegram"     : 1.16.0   , installed 1.15.2 [Updatable]
                                          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                          Adapter    "text2command" : 3.0.2    , installed 2.3.0  [Updatable]
                                          Adapter    "tr-064"       : 4.2.18   , installed 4.2.17 [Updatable]
                                          Adapter    "tuya"         : 3.14.2   , installed 3.13.1 [Updatable]
                                          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                          Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                                          Adapter    "wled"         : 0.6.7    , installed 0.6.7
                                          Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                                          Adapter    "youtube"      : 4.2.1    , installed 4.1.0  [Updatable]
                                          Adapter    "zigbee"       : 1.8.23   , installed 1.8.10 [Updatable]
                                          Die einzelnen Adapter habe ich noch nicht geupdated, da jeder 8 Minuten benötigt und es wohl woanders noch klemmt.
                                            Nochmal installieren.
                                            iobroker url https://github.com/t4qjXH8N/ioBroker.google-sharedlocations --debug
                                            9240
