    4. Performance Probleme im iobroker Admin auf pi4
      maxpd @Thomas Braun last edited by
      @thomas-braun Habe mich an einen Beitrag weiter vorne erinnert und es für den Adapter nun auch so probiert ja. Für den SMA Adapter hat es übers Interface funktioniert. Für Chromecast nun auch über die Konsole. Aber 8 Min egal über welche Variante kommt mir seeehr lang vor, wobei wir wieder beim ursprünglichen Performance Problem sind ^^
      pi@iobroker:~ $ iobroker upgrade chromecast@3.0.3 --debug
      Would you like to reinstall version 3.0.3 of chromecast now? [(y)es, (n)o]: y
      Update chromecast from @3.0.3 to @3.0.3
      NPM version: 9.6.7
      Installing iobroker.chromecast@3.0.3... (System call)
      npm WARN skipping integrity check for git dependency ssh://git@github.com/nbueng        er/ioBroker.govee.git
      npm WARN skipping integrity check for git dependency ssh://git@github.com/Garfon        so/ioBroker.google-sharedlocations.git
      npm WARN skipping integrity check for git dependency ssh://git@github.com/BuZZy1        337/ioBroker.doorbird.git
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reason        s. As it's a core Node module, we will not transfer it over to other users. You        may safely remove the package from your dependencies.
      npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now        a built-in Node module. If you've depended on crypto, you should switch to the o        ne that's built-in.
      npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide        s its own type definitions, so you do not need this installed.
      npm WARN deprecated topo@3.0.3: This module has moved and is now available at @h        api/topo. Please update your dependencies as this version is no longer maintaine        d an may contain bugs and security issues.
      npm WARN deprecated request-promise-native@1.0.9: request-promise-native has bee        n deprecated because it extends the now deprecated request package, see https://        github.com/request/request/issues/3142
      npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated        in favor of babel-cli. Check https://opencollective.com/babel to support the Bab        el maintainers
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b        ecause it extends the now deprecated request package, see https://github.com/req        uest/request/issues/3142
      npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @h        api/hoek. Please update your dependencies as this version is no longer maintaine        d an may contain bugs and security issues.
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS        ON 3
      npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, fl        atted is its successor.
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and        does not need to be installed separately. It is now unmaintained.
      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav        e a low-severity ReDos regression when used in a Node.js environment. It is reco        mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss        ues/797)
      npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy.        new code should use the URLSearchParams API instead.
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v        ersions may use Math.random() in certain circumstances, which is known to be pro        blematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://git        hub.com/request/request/issues/3142
      npm WARN deprecated joi@14.3.1: This module has moved and is now available at @h        api/joi. Please update your dependencies as this version is no longer maintained        an may contain bugs and security issues.
      npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in        0.5.0
      removed 861 packages, and changed 1482 packages in 8m
      141 packages are looking for funding
        run `npm fund` for details
      upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
      upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
      upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
      upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
        Thomas Braun Most Active @maxpd last edited by
        @maxpd sagte in Performance Probleme im iobroker Admin auf pi4:
        Dein Setup ist ja vermutlich noch nicht wieder senkrecht.
          Thomas Braun Most Active @maxpd last edited by Thomas Braun
          @maxpd
          Wo stehen wir denn nun?
          cd /opt/iobroker && npm ls
          und
          iob update
          sagt?
            Ich bin noch beim Austausch der Adapter, habe aber Probleme mit npm.
            pi@iobroker:~ $ cd /opt/iobroker && npm ls
            npm ERR! code ELSPROBLEMS
            npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
            npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
            npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
            npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
            npm ERR! invalid: iobroker.google-sharedlocations@2.1.5 /opt/iobroker/node_modules/iobroker.google-sharedlocations
            npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
            npm ERR! invalid: iobroker.sma-speedwire@0.7.0 /opt/iobroker/node_modules/iobroker.sma-speedwire
            npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
            npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
            npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
            npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
            npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
            iobroker.inst@2.0.3 /opt/iobroker
            ├── @types/caseless@0.12.2 extraneous
            ├── @types/request@2.48.8 extraneous
            ├── @types/tough-cookie@4.0.2 extraneous
            ├── coffeescript@1.12.7 extraneous
            ├── colors@1.4.0
            ├── fs-extra@7.0.1
            ├── iobroker.admin@6.3.5
            ├── iobroker.alias-manager@1.2.6
            ├── iobroker.backitup@2.6.19
            ├── iobroker.chromecast@3.0.3
            ├── iobroker.cloud@4.3.0
            ├── iobroker.coronavirus-statistics@0.8.7
            ├── iobroker.daswetter@3.1.8
            ├── iobroker.denon@1.15.0
            ├── iobroker.devices@1.1.2
            ├── iobroker.discovery@3.1.0
            ├── iobroker.doorbird@1.2.3
            ├── iobroker.feiertage@1.1.0
            ├── iobroker.flot@1.11.0
            ├── iobroker.go-e@1.0.27
            ├── iobroker.google-sharedlocations@2.1.5 invalid: "github:Garfonso/ioBroker.google-sharedlocations#73f8c9bd627e81518dec7e659d98332bd84d9e69" from the root project
            ├── iobroker.govee@0.0.5 invalid: "github:nbuenger/ioBroker.govee#0d983c49135b87ac2f88f9d832a6d632c4889606" from the root project
            ├── iobroker.history@2.2.4
            ├── iobroker.hm-rega@3.0.46
            ├── iobroker.hm-rpc@1.15.16
            ├── iobroker.ical@1.13.2
            ├── iobroker.info@1.9.26
            ├── iobroker.iot@1.14.2
            ├── iobroker.javascript@6.1.4
            ├── iobroker.js-controller@4.0.24
            ├── iobroker.lgtv@1.1.12
            ├── iobroker.lovelace@3.0.1
            ├── iobroker.mihome-vacuum@3.9.5
            ├── iobroker.modbus@5.0.11
            ├── iobroker.mqtt-client@1.6.3
            ├── iobroker.mqtt@4.0.7
            ├── iobroker.net-tools@0.2.0
            ├── iobroker.pi-hole@1.3.4
            ├── iobroker.ping@1.5.3
            ├── iobroker.rpi2@1.3.2
            ├── iobroker.sayit@1.13.0
            ├── iobroker.shelly@6.3.1
            ├── iobroker.shuttercontrol@1.4.29
            ├── iobroker.simple-api@2.7.2
            ├── iobroker.sma-em@0.7.0
            ├── iobroker.sma-speedwire@0.7.0 invalid: "https://github.com/Apollon77/iobroker.sma-speedwire/tarball/3dce8e5d3fb9112502ba697a0f41ec0ab0aa90f4" from the root project
            ├── iobroker.socketio@4.2.0
            ├── iobroker.sonoff@2.5.1
            ├── iobroker.spotify-premium@1.2.1
            ├── iobroker.sunnyportal@0.1.5
            ├── iobroker.synology@2.1.13
            ├── iobroker.systeminfo@0.3.1
            ├── iobroker.telegram@1.15.2
            ├── iobroker.terminal@1.0.0
            ├── iobroker.text2command@2.3.0
            ├── iobroker.tr-064@4.2.17
            ├── iobroker.tuya@3.13.1
            ├── iobroker.web@4.3.0
            ├── iobroker.whatsapp-cmb@0.2.3
            ├── iobroker.wifilight@1.1.4
            ├── iobroker.wled@0.6.7
            ├── iobroker.yeelight-2@1.2.1
            ├── iobroker.youtube@4.1.0
            ├── iobroker.zigbee@1.8.10
            ├── jsonata@1.8.6 extraneous
            ├── node-inspect@2.0.0 extraneous
            ├── semver@5.7.2
            ├── typescript@4.7.4 extraneous
            ├── virtual-tsc@0.6.2 extraneous
            ├── wake_on_lan@1.0.0 extraneous
            └── yargs@7.1.2
            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-26T04_51_22_964Z-debug-0.log
            pi@iobroker:/opt/iobroker $ iobroker upgrade sma-speedwire@0.7.0 --debug
            Adapter "sma-speedwire" is not in the repository and cannot be updated.
            Cannot upgrade: Cannot read properties of undefined (reading 'controller')
            pi@iobroker:/opt/iobroker $ iobroker upgrade google-sharedlocations@2.1.5 --debug
            Adapter "google-sharedlocations" is not in the repository and cannot be updated.
            pi@iobroker:/opt/iobroker $ iobroker upgrade google-sharedlocations@1.5.2 --debu        g
            z.B. der sharedlocations Adapter. Dieser ist bei npm in einer 5 Jahre alten Version. Seit dem hat sich sehr viel bei dem Adapter getan. Aber auch die 5 Jahre alte Version findet er nicht.
            Den sma-speedwire kann man auch löschen, wird nicht benötigt.
              @maxpd
              Dann schmeiß das raus, was nicht benötigt wird.
              Den Rest in aktueller Version drüber installieren.
                @thomas-braun bevor ich es wieder falsch mache. wie installiere ich den Google shared locations über npm? dort wird der nicht gefunden.
                und wie installiere ich die aktuelle Version drüber, wenn auf npm nur die 5 Jahre alte liegt?
                  @maxpd
                  Keine Ahnung. Hab den selber nicht im Einsatz. Wo haste den denn her?
                  Der?
                  https://github.com/t4qjXH8N/ioBroker.google-sharedlocations
                  Dann installier den nochmal frisch aus GitHub
                    @thomas-braun genau den. aber ich habe es jetzt so verstanden, dass man nichts aus GitHub installieren darf, da offensichtlich 😂 das System kaputt geht.
                      @maxpd
                      Man vermeidet es und hat nur so wenig wie möglich aus GitHub geangeltes im System.
                      Aber wenn es nicht anders geht...
                        @thomas-braun warum bringen die Entwickler ihre Adapter nicht zu npm? oder halten sie dort aktuell?
                          @maxpd
                          Das musst du dort fragen. Der Adapter sieht auch etwas verwaist aus.
                          Gilt auch für den govee.
                          Schau mal ob der nicht durch govee-app oder govee-local ersetzt werden kann.
                            @thomas-braun said in Performance Probleme im iobroker Admin auf pi4:
                            @maxpd
                            und
                            iob update
                            sagt?
                            npm ERR! invalid: iobroker.google-sharedlocations@2.1.3 /opt/iobroker/node_modules/iobroker.google-sharedlocations
                            ├── colors@1.4.0
                            ├── fs-extra@7.0.1
                            ├── iobroker.google-sharedlocations@2.1.3 invalid: "github:t4qjXH8N/ioBroker.google-sharedlocations" from the root project
                            ├── semver@5.7.2
                            └── yargs@7.1.2
                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-26T19_59_46_695Z-debug-0.log
                            pi@iobroker:/opt/iobroker $ iob update
                            Used repository: stable
                            Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                            Adapter    "alias-manager": 1.2.4    , installed 1.2.6
                            Adapter    "backitup"     : 2.6.23   , installed 2.6.19 [Updatable]
                            Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                            Adapter    "cloud"        : 4.4.1    , installed 4.3.0  [Updatable]
                            Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                            Adapter    "daswetter"    : 3.1.10   , installed 3.1.8  [Updatable]
                            Adapter    "denon"        : 1.15.3   , installed 1.15.0 [Updatable]
                            Adapter    "devices"      : 1.1.5    , installed 1.1.2  [Updatable]
                            Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                            Adapter    "doorbird"     : 1.2.3    , installed 1.2.3
                            Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                            Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
                            Adapter    "go-e"         : 1.0.27   , installed 1.0.27
                            Adapter    "history"      : 2.2.4    , installed 2.2.4
                            Adapter    "hm-rega"      : 3.0.47   , installed 3.0.46 [Updatable]
                            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
                            Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
                            Adapter    "info"         : 1.9.26   , installed 1.9.26
                            Adapter    "iot"          : 1.14.5   , installed 1.14.2 [Updatable]
                            Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
                            Controller "js-controller": 4.0.24   , installed 4.0.24
                            Adapter    "lgtv"         : 1.1.10   , installed 1.1.12
                            Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                            Adapter    "mihome-vacuum": 3.11.0   , installed 3.9.5  [Updatable]
                            Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                            Adapter    "mqtt"         : 4.1.1    , installed 4.0.7  [Updatable]
                            Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                            Adapter    "pi-hole"      : 1.3.6    , installed 1.3.4  [Updatable]
                            Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                            Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
                            Adapter    "shelly"       : 6.4.1    , installed 6.3.1  [Updatable]
                            Adapter    "shuttercontrol": 1.6.1   , installed 1.4.29 [Updatable]
                            Adapter    "sma-em"       : 0.7.0    , installed 0.7.0
                            Adapter    "sonoff"       : 2.5.3    , installed 2.5.1  [Updatable]
                            Adapter    "spotify-premium": 1.2.2  , installed 1.2.1  [Updatable]
                            Adapter    "synology"     : 2.1.13   , installed 2.1.13
                            Adapter    "systeminfo"   : 1.0.0    , installed 0.3.1  [Updatable]
                            Adapter    "telegram"     : 1.16.0   , installed 1.15.2 [Updatable]
                            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                            Adapter    "text2command" : 3.0.2    , installed 2.3.0  [Updatable]
                            Adapter    "tr-064"       : 4.2.18   , installed 4.2.17 [Updatable]
                            Adapter    "tuya"         : 3.14.2   , installed 3.13.1 [Updatable]
                            Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                            Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                            Adapter    "wled"         : 0.6.7    , installed 0.6.7
                            Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                            Adapter    "youtube"      : 4.2.1    , installed 4.1.0  [Updatable]
                            Adapter    "zigbee"       : 1.8.23   , installed 1.8.10 [Updatable]
                            Die einzelnen Adapter habe ich noch nicht geupdated, da jeder 8 Minuten benötigt und es wohl woanders noch klemmt.
                              Nochmal installieren.
                              iobroker url https://github.com/t4qjXH8N/ioBroker.google-sharedlocations --debug
                                @thomas-braun Ich hatte es wieder über das Admin Interface gemacht und hatte den Adapter auch zuvor komplett gelöscht. Jetzt habe ich es über deinen Befehl gemacht. Das Ergebnis ist aber das gleiche.
                                pi@iobroker:/opt/iobroker $ iobroker url https://github.com/t4qjXH8N/ioBroker.google-sharedlocations --debug
                                install t4qjXH8N/ioBroker.google-sharedlocations#d5a738e822ba42066fee93246f5a1f9c6621bca1
                                NPM version: 9.6.7
                                Installing t4qjXH8N/ioBroker.google-sharedlocations#d5a738e822ba42066fee93246f5a1f9c6621bca1... (System call)
                                npm WARN skipping integrity check for git dependency ssh://git@github.com/t4qjXH8N/ioBroker.google-sharedlocations.git
                                npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
                                npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                                npm WARN deprecated topo@3.0.3: This module has moved and is now available at @hapi/topo. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                                npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check https://opencollective.com/babel to support the Babel maintainers
                                npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                                npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
                                npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                npm WARN deprecated joi@14.3.1: This module has moved and is now available at @hapi/joi. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                                removed 863 packages, and changed 1482 packages in 8m
                                upload [3] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/google-cookie.JPG google-cookie.JPG image/jpeg
                                upload [2] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/google-sharedlocations.png google-sharedlocations.png image/png
                                upload [1] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/index_m.html index_m.html text/html
                                upload [0] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/words.js words.js application/javascript
                                pi@iobroker:/opt/iobroker $ ^C
                                pi@iobroker:/opt/iobroker $ cd /opt/iobroker && npm ls
                                ├── colors@1.4.0
                                ├── fs-extra@7.0.1
                                ├── iobroker.backitup@2.6.23
                                ├── iobroker.google-sharedlocations@2.1.3 invalid: "github:t4qjXH8N/ioBroker.google-sharedlocations#d5a738e822ba42066fee93246f5a1f9c6621bca1" from the root project
                                ├── semver@5.7.2
                                └── yargs@7.1.2
                                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-26T20_42_24_072Z-debug-0.log
                                mikeal created this issue in request/request
                                open Request’s Past, Present and Future #3142
                                Qix- created this issue in visionmedia/debug
                                closed ReDos Vulnerability Regression Visibility Notice #797
                                Thomas Braun 3 Replies Last reply Reply Quote 0
                                  @maxpd
                                  Keine Ahnung warum das bei dir nicht sauber läuft.
                                  Der ist hier in 7 Sekunden sauber installiert.
                                  echad@chet:/opt/iobroker $  iobroker url https://github.com/t4qjXH8N/ioBroker.google-sharedlocations --host chet --debug
                                  NPM version: 9.6.7
                                  added 2 packages in 7s
                                  96 packages are looking for funding
                                    @maxpd
                                    Zeig nochmal die Langfassung von
                                    iob diag
                                      @maxpd
                                      Und lösch mal den npm cache.
                                      npm cache clean --force
                                      sudo -H -u iobroker npm cache clean --force
                                        ticaki Developer last edited by ticaki
                                        @thomas-braun sagte in Performance Probleme im iobroker Admin auf pi4:
                                        tim@iobroker:~$ iobroker url https://github.com/t4qjXH8N/ioBroker.google-sharedlocations --debug
                                        NPM version: 9.6.7
                                        added 3 packages in 6s
                                        158 packages are looking for funding
                                        ups wollte nur bestätigen ist aber schon ne stunde her 🙂
                                          crunchip Forum Testing Most Active @Thomas Braun last edited by
                                          war das nicht früher mal aus einer bestimmten Konstellation mit nodejs und npm, das es so lange gedauert hat.
                                            Thomas Braun Most Active @crunchip last edited by
                                            @crunchip
                                            Ja, aber das war ein npm@6, wenn ich mich recht erinnere. Das wird was anderes sein. Ich vermute eine nicht abgeschlossener Kompilierung.
                                            9356
