    3. Entwicklung
    4. Adapter mihome-vacuum anpassungen
      Kusi @dirkhe last edited by
      @dirkhe sagte in Adapter mihome-vacuum anpassungen:
      @kusi zeige mal das debug log, aber ich vermute, dass der Fehler ist, dass du String eingestellt hast, es soll aber ein json übergeben werden, kenne mich mit blocky aber nicht aus, ist mir zu kompliziert....
      Vielleicht kann hier @paul53 helfen?
        mihome-vacuum.0
        2023-08-26 16:26:36.959	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        mihome-vacuum.0
        2023-08-26 16:26:36.959	debug	Plugin sentry destroyed
        mihome-vacuum.0
        2023-08-26 16:26:36.958	info	terminating
        mihome-vacuum.0
        2023-08-26 16:26:36.958	error	Socket Close
        mihome-vacuum.0
        2023-08-26 16:26:36.953	error	Cannot read properties of undefined (reading 'repeat')
        mihome-vacuum.0
        2023-08-26 16:26:36.953	error	TypeError: Cannot read properties of undefined (reading 'repeat') at VacuumManager.onMessage (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/vacuum.js:1416:22) at processTicksAndRejections (node:internal/process/task_queues:95:5) at MihomeVacuum.onMessage (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:414:14)
        mihome-vacuum.0
        2023-08-26 16:26:36.951	error	unhandled promise rejection: Cannot read properties of undefined (reading 'repeat')
        mihome-vacuum.0
        2023-08-26 16:26:36.951	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        mihome-vacuum.0
        2023-08-26 16:26:36.951	debug	MIIO RECIVE: {"id":33,"error":{"code":-10005,"message":"data for segment is not a number"},"exe_time":10}
        mihome-vacuum.0
        2023-08-26 16:26:36.950	debug	MIIO MESSAGE TESTING: {"id":33,"error":{"code":-10005,"message":"data for segment is not a number"},"exe_time":10}
        mihome-vacuum.0
        2023-08-26 16:26:36.933	debug	Message= {"id":33,"method":"app_segment_clean","params":[null,null,null]}
        mihome-vacuum.0
        2023-08-26 16:26:36.933	info	trigger cleaning segment {rooms:[21],fanSpeed:100,repeat:2}
        mihome-vacuum.0
        2023-08-26 16:26:36.933	debug	start Cleaning: 18 MObj: {"command":"cleanSegments","message":"{rooms:[21],fanSpeed:100,repeat:2}","from":"system.adapter.javascript.0","_id":76612610,"segments":[null,null,null],"channels":null}
        mihome-vacuum.0
        2023-08-26 16:26:36.933	debug	We are in onMessage:{"command":"cleanSegments","message":"{rooms:[21],fanSpeed:100,repeat:2}","from":"system.adapter.javascript.0","_id":76612610,"segments":[null,null,null],"channels":null}
        mihome-vacuum.0
        2023-08-26 16:26:36.933	debug	search channels for {rooms:[21],fanSpeed:100,repeat:2} ->
        mihome-vacuum.0
        2023-08-26 16:26:36.924	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        mihome-vacuum.0
        2023-08-26 16:26:36.923	debug	We are in onMessage:{"command":"cleanSegments","message":"{rooms:[21],fanSpeed:100,repeat:2}","from":"system.adapter.javascript.0","_id":76612610}
          dirkhe Developer @Kusi last edited by
          @kusi du übergibst einen string, anstatt ein json
            Kusi @dirkhe last edited by Kusi
            @dirkhe Habe es gefunden... Datenpunkt steht jetzt auf "json".
            Hier das neue Log:
            mihome-vacuum.0
            2023-08-26 22:06:53.875	debug	Plugin sentry destroyed
            mihome-vacuum.0
            2023-08-26 22:06:53.875	info	terminating
            mihome-vacuum.0
            2023-08-26 22:06:53.874	error	Socket Close
            mihome-vacuum.0
            2023-08-26 22:06:53.869	error	Cannot read properties of undefined (reading 'repeat')
            mihome-vacuum.0
            2023-08-26 22:06:53.869	error	TypeError: Cannot read properties of undefined (reading 'repeat') at VacuumManager.onMessage (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/vacuum.js:1416:22) at processTicksAndRejections (node:internal/process/task_queues:95:5) at MihomeVacuum.onMessage (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:414:14)
            mihome-vacuum.0
            2023-08-26 22:06:53.868	error	unhandled promise rejection: Cannot read properties of undefined (reading 'repeat')
            mihome-vacuum.0
            2023-08-26 22:06:53.867	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            mihome-vacuum.0
            2023-08-26 22:06:53.867	debug	MIIO RECIVE: {"id":33,"error":{"code":-10005,"message":"data for segment is not a number"},"exe_time":10}
            mihome-vacuum.0
            2023-08-26 22:06:53.867	debug	MIIO MESSAGE TESTING: {"id":33,"error":{"code":-10005,"message":"data for segment is not a number"},"exe_time":10}
            mihome-vacuum.0
            2023-08-26 22:06:53.848	debug	Message= {"id":33,"method":"app_segment_clean","params":[null,null,null]}
            mihome-vacuum.0
            2023-08-26 22:06:53.848	info	trigger cleaning segment {rooms:[21],fanSpeed:100, repeat:2}
            mihome-vacuum.0
            2023-08-26 22:06:53.847	debug	start Cleaning: 18 MObj: {"command":"cleanSegments","message":"{rooms:[21],fanSpeed:100, repeat:2}","from":"system.adapter.javascript.0","_id":76612619,"segments":[null,null,null],"channels":null}
            mihome-vacuum.0
            2023-08-26 22:06:53.847	debug	We are in onMessage:{"command":"cleanSegments","message":"{rooms:[21],fanSpeed:100, repeat:2}","from":"system.adapter.javascript.0","_id":76612619,"segments":[null,null,null],"channels":null}
            mihome-vacuum.0
            2023-08-26 22:06:53.847	debug	search channels for {rooms:[21],fanSpeed:100, repeat:2} ->
            mihome-vacuum.0
            2023-08-26 22:06:53.842	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            mihome-vacuum.0
            2023-08-26 22:06:53.841	debug	We are in onMessage:{"command":"cleanSegments","message":"{rooms:[21],fanSpeed:100, repeat:2}","from":"system.adapter.javascript.0","_id":76612619}
              @kusi ist immer noch ein string
              Müsste So aussehen
              We are in onMessage:{"command":"cleanSegments","message":{rooms:[21],fanSpeed:100, repeat:2},"from":"system
                Freakahhh last edited by
                habe gestern auf meinen Xiaomi Gen 1 Roboter Valetudo gespielt. Hat alles super geklappt. Kann ihn auch im Valetudo WebInterface Steuern und die Karte ist auch schon erstellt.
                Jetzt klappt allerdings die Einbindung in ioBroker nicht mehr. Ich habe den Token aus der Valetudo Log genommen und die Ports auf 54321 belassen und natürlich die richtige IP angegeben. Leider bleibt der Adapter gelb 😞
                Mit der originalen Firmware und Xiaomi App hat die Einbindung in den Adapter immer ohne Probleme geklappt. Hat jemand eine Idee was ich falsch mache? Ist das auch der richtige Token aus der Valetudo Log Datei?
                Ich bin um jede Hilfe Dankbar!
                  A Former User @Freakahhh last edited by
                  @freakahhh
                  hi, da hast du jetzt ein Problem. ... irgendwann vor etlichen Monaten wurde die Valetudo Unterstuetzung vom Adapter rausgenommen.. da Valetudo dauernd was geaendert hat und keiner der Developer sich damit auch noch befassen konnte..
                    Freakahhh @Guest last edited by Freakahhh
                    @ilovegym ja gut zu wissen - danke dir! 👍 Schade, dass ich dazu nichts im Netz gefunden habe...
                    Dann geh ich wieder zurück auf die originale FW... Ich dachte eig. ich könnte dem alten Robi per Valetudo und dem Adapter noch die Zonenreinigung beibringen 🙂 Evtl. gibts ja noch einen anderen weg.
                      A Former User last edited by
                      @freakahhh
                      das ist hier in dem Thread irgendwo drin... aber schon lange her... Es sei denn, du machst ne alte Valetudo drauf..
                      Geht die Zone nicht mit dem Adapter?
                        Thomas Braun Most Active @Freakahhh last edited by Thomas Braun
                        @freakahhh
                        Rät nicht auch valetudo selber davon ab es auf der ersten Generation des Saugers einzusetzen?
                          @ilovegym sagte in Adapter mihome-vacuum anpassungen:
                          @freakahhh
                          Evtl. hab hatte ich's bisher einfach falsch gemacht. Meine Steps waren mit der originalen FW immer wie folgt.
                          1. In der Xiaomi App den Server auf Deutschland
                          2. In der App 1x komplett saugen lassen und so eine komplette Karte erstellen lassen
                          3. Robi mit dem ioBroker Adapter verbunden
                          4. In der App dann eine Zone erstellt und die Reinigung angestossen
                          5. Im Adapter unter zoneClean werden dann Koordinaten angezeigt. Die hab ich mir kopiert. Z.B.: [23400,33250,26300,31300,1]
                          6. Reinigung pausiert und Robi wieder ins Dock fahren lassen - die Karte bleibt dabei in der App vorhanden.
                          7. In ioBroker eine Szene erstellt und die Koordinaten in den Datenpunkt zoneClean schreiben lassen. Und auf Test gedrückt.
                          Grundsätzlich funktioniert das so nur fährt der Robi so 2min unkoordiniert in der Gegend rum und dann wieder ins Dock zurück mit der Meldung, dass nicht alle Bereiche gereinigt werden konnten...
                            Freakahhh @Thomas Braun last edited by
                            @thomas-braun sagte in Adapter mihome-vacuum anpassungen:
                            @freakahhh
                            Laut der Valetudo Website ist er bei den Unterstützten dabei https://valetudo.cloud/pages/general/supported-robots.html#xiaomi . Hat sich auch easy OTA flashen lassen und funktioniert im Valetudo Webinterface auch 1A. Nur an der Einbindung in den Adapter bin ich gescheitert...
                              Kusi @Kusi last edited by
                              @kusi sagte in Adapter mihome-vacuum anpassungen:
                              @nu_81 sagte in Adapter mihome-vacuum anpassungen:
                              Ich schreibe nun den String in einen Datenpunkt und ordne dem SendTo Block (Blockly) den Werte dieses Objekts zu.
                              Das klappt dann auch mit einem Raum.
                              Ich kriege es mit SendTo nicht mal hin einen Raum zu reinigen.
                              Beim Ausführen des Befehls stürzt der Adapter ab.
                              Nun läuft bei mir alles wunschgemäss.
                              Mit dem SendTo-Block konnte ich es dennoch nicht zum laufen bringen, aber mit einem kleinen Skript läuft es einwandfrei.
                              Ich habe eine Javascript-Funktion mit folgenden 4 Variablen erstellt:
                              "z_Raum", "z_Saugleistung", "z_Wischintensitaet" und "z_Reinigungszyklen"
                              sendTo("mihome-vacuum.0", "cleanSegments",
                                  rooms:z_Raum,
                                  waterBoxMode:z_Wischintensitaet,
                                  fanSpeed:z_Saugleistung,
                                  repeat:z_Reinigungszyklen
                              async function (result) {
                                  console.log(result);
                              console.debug("mihome-vacuum.0: " + "");
                              Die Werte für Saugleistung, Wischintensität und Reinigungszyklen nehme ich aus 3 manuell erstellen Datenpunkten, welche ich via vis ändern kann.
                              Für die Räume habe ich jeweils einen Datenpunkt erstellt, welchen ich auf "true" setze, wenn ich diesen reinigen will (Mehrfachauswahl möglich). Jedem Raum-Datenpunkt habe ich als Name (nicht ID!) die ID-Nummer des Raumes im Mihome-Adapters eingetragen.
                              Zudem habe ich einen Datenpunkt mit dem Namen "Start" erstellt.
                              --> Die JS-Funktion mit Ergebnis "mapIndex suchen" mit der Variable "mapIndex" hat folgendes Skript:
                              return getObject(mapIndex).common.name;
                              Nun mein Vorgehen, wenn ich einen/mehrere Raum/Räume reinigen will:
                              Ich stelle die Reinigungseinstellungen ein (Saugleistung, Wischintensität und Reinigungszyklen), dann wählen ich die Räume an, welche ich reinigen will. Danach klicke ich auf "Start".
                              Blockly holt sich dann die MapIndex des jeweiligen Raumes, und sendet diese mit den Reinigungseinstellungen an den Roborock.
                              Anbei das komplette Blockly zum Import:
                              Roborock S7 Blockly.txt
                                Krys @Kusi last edited by
                                Ich hab das über den Szenen-Adapter über eine Szene gelöst.
                                  MP_Trixi @dirkhe last edited by MP_Trixi
                                  @dirkhe
                                  komisch ist, dass die Werte ja so schon gepasst hatten. Die können sich ja dann nur zB durch ein FW Update geändert haben, oder nicht? Hier mal Auszüge aus dem Log:
                                  • gestartet wird es per Blockly (setzt die Werte in Datenpunkten) um 7:55 (zwei Zonen, jeweils Saugen Max (104) und Wischen aus (200)). Der Roboter startet, aber hat keine Saugleistung (erstes Log).
                                  • um 8:55 ist die erste Zone fertig. Roboter fährt zur Station. 2te Zone wird gestartet, aber er will wischen und geht zur Mobreinigung. Um 9:00 bin ich in der App erst auf Indv. und dann zurück auf Saugen gegangen, damit er das Wischen aufhört und die Saugleistung anpasst (Log 2)
                                  • um 9:29 war er dann fertig (Log 3)
                                  Log1:
                                  2023-08-28 07:54:48.251  - debug: mihome-vacuum.0 (423131) Helo message Timeout
                                  2023-08-28 07:54:58.349  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff000043aaffffffffffffffffffffffffffffffff
                                  2023-08-28 07:54:58.350  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693184776 sec
                                  2023-08-28 07:54:59.012  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                  2023-08-28 07:54:59.012  - debug: mihome-vacuum.0 (423131) Message= {"id":6282,"method":"get_status"}
                                  2023-08-28 07:54:59.059  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6282,"result":[{"msg_ver":2,"msg_seq":605,"state":8,"battery":100,"clean_time":121,"clean_area":2860000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":4,"unsave_map_flag":0}],"exe_time":10}
                                  2023-08-28 07:54:59.059  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6282,"result":[{"msg_ver":2,"msg_seq":605,"state":8,"battery":100,"clean_time":121,"clean_area":2860000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":4,"unsave_map_flag":0}],"exe_time":10}
                                  2023-08-28 07:54:59.059  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":605,"state":8,"battery":100,"clean_time":121,"clean_area":2860000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":4,"unsave_map_flag":0,"error_text":"No error"}
                                  2023-08-28 07:54:59.060  - debug: mihome-vacuum.0 (423131) Message= {"id":6283,"method":"get_network_info"}
                                  2023-08-28 07:54:59.138  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6283,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-94},"exe_time":51}
                                  2023-08-28 07:54:59.139  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6283,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-94},"exe_time":51}
                                  2023-08-28 07:54:59.191  - debug: mihome-vacuum.0 (423131) Message= {"id":6284,"method":"get_sound_volume"}
                                  2023-08-28 07:54:59.221  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6284,"result":[90],"exe_time":10}
                                  2023-08-28 07:54:59.222  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6284,"result":[90],"exe_time":10}
                                  2023-08-28 07:54:59.222  - debug: mihome-vacuum.0 (423131) Message= {"id":6285,"method":"get_carpet_mode"}
                                  2023-08-28 07:54:59.260  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6285,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":10}
                                  2023-08-28 07:54:59.260  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6285,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":10}
                                  2023-08-28 07:55:00.145  - debug: mihome-vacuum.0 (423131) command: roomFanPower parent: manual_18300_32000_29000_24900
                                  2023-08-28 07:55:00.149  - debug: mihome-vacuum.0 (423131) command: roomWaterBoxMode parent: manual_18300_32000_29000_24900
                                  2023-08-28 07:55:00.154  - debug: mihome-vacuum.0 (423131) command: roomFanPower parent: manual_21300_24900_25000_15000
                                  2023-08-28 07:55:00.158  - debug: mihome-vacuum.0 (423131) command: roomWaterBoxMode parent: manual_21300_24900_25000_15000
                                  2023-08-28 07:55:02.172  - debug: mihome-vacuum.0 (423131) command: roomClean parent: manual_18300_32000_29000_24900
                                  2023-08-28 07:55:02.182  - debug: mihome-vacuum.0 (423131) We are in onMessage:{"command":"cleanZone","message":{"zones":["[18300,32000,29000,24900,1]"],"channels":["mihome-vacuum.0.rooms.manual_18300_32000_29000_24900"]},"from":"system.adapter.mihome-vacuum.0","_id":99543803}
                                  2023-08-28 07:55:02.183  - debug: mihome-vacuum.0 (423131) start Cleaning: 17 MObj: {"command":"cleanZone","message":"[18300,32000,29000,24900,1]","from":"system.adapter.mihome-vacuum.0","_id":99543803,"zones":["[18300,32000,29000,24900,1]"],"channels":["mihome-vacuum.0.rooms.manual_18300_32000_29000_24900"]}
                                  2023-08-28 07:55:02.186  - debug: mihome-vacuum.0 (423131) Set water box mode from Room to 200
                                  2023-08-28 07:55:02.188  - info: mihome-vacuum.0 (423131) trigger cleaning zone [18300,32000,29000,24900,1]
                                  2023-08-28 07:55:02.188  - debug: mihome-vacuum.0 (423131) Message= {"id":6286,"method":"app_zoned_clean","params":[[18300,32000,29000,24900,1]]}
                                  2023-08-28 07:55:02.261  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6286,"result":["ok"],"exe_time":11}
                                  2023-08-28 07:55:02.262  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6286,"result":["ok"],"exe_time":11}
                                  2023-08-28 07:55:02.291  - debug: mihome-vacuum.0 (423131) command: water_box_mode parent: control
                                  2023-08-28 07:55:02.292  - debug: mihome-vacuum.0 (423131) Message= {"id":6287,"method":"set_water_box_custom_mode","params":[200]}
                                  2023-08-28 07:55:02.296  - debug: mihome-vacuum.0 (423131) command: mop_mode parent: control
                                  2023-08-28 07:55:02.297  - debug: mihome-vacuum.0 (423131) Message= {"id":6288,"method":"set_mop_mode","params":[301]}
                                  2023-08-28 07:55:02.329  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6287,"result":["ok"],"exe_time":11}
                                  2023-08-28 07:55:02.330  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6287,"result":["ok"],"exe_time":11}
                                  2023-08-28 07:55:02.330  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6287,"result":["ok"],"exe_time":11}
                                  2023-08-28 07:55:02.337  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6288,"result":["ok"],"exe_time":11}
                                  2023-08-28 07:55:02.338  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6288,"result":["ok"],"exe_time":11}
                                  2023-08-28 07:55:04.084  - debug: mihome-vacuum.0 (423131) command: roomClean parent: manual_21300_24900_25000_15000
                                  2023-08-28 07:55:04.088  - debug: mihome-vacuum.0 (423131) We are in onMessage:{"command":"cleanZone","message":{"zones":["[21300,24900,25000,15000,1]"],"channels":["mihome-vacuum.0.rooms.manual_21300_24900_25000_15000"]},"from":"system.adapter.mihome-vacuum.0","_id":99543804}
                                  2023-08-28 07:55:04.088  - debug: mihome-vacuum.0 (423131) start Cleaning: 17 MObj: {"command":"cleanZone","message":"[21300,24900,25000,15000,1]","from":"system.adapter.mihome-vacuum.0","_id":99543804,"zones":["[21300,24900,25000,15000,1]"],"channels":["mihome-vacuum.0.rooms.manual_21300_24900_25000_15000"]}
                                  2023-08-28 07:55:04.088  - info: mihome-vacuum.0 (423131) should trigger cleaning zone [21300,24900,25000,15000,1], but is currently active(17). Add to queue
                                  2023-08-28 07:55:08.818  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff000043b4ffffffffffffffffffffffffffffffff
                                  2023-08-28 07:55:08.818  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693184776 sec
                                  2023-08-28 07:55:19.364  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                  2023-08-28 07:55:19.365  - debug: mihome-vacuum.0 (423131) Message= {"id":6289,"method":"get_status"}
                                  2023-08-28 07:55:20.819  - debug: mihome-vacuum.0 (423131) Helo message Timeout
                                  2023-08-28 07:55:21.367  - debug: mihome-vacuum.0 (423131) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                  2023-08-28 07:55:21.368  - debug: mihome-vacuum.0 (423131) your device is not connected, but this could be temporary
                                  2023-08-28 07:55:32.821  - debug: mihome-vacuum.0 (423131) Helo message Timeout
                                  2023-08-28 07:55:41.369  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                  2023-08-28 07:55:41.369  - debug: mihome-vacuum.0 (423131) your device is not connected, but this could be temporary
                                  2023-08-28 07:55:41.370  - debug: mihome-vacuum.0 (423131) your device is not connected, but this could be temporary
                                  2023-08-28 07:55:44.822  - debug: mihome-vacuum.0 (423131) Helo message Timeout
                                  2023-08-28 07:55:56.823  - debug: mihome-vacuum.0 (423131) Helo message Timeout
                                  2023-08-28 07:56:01.370  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                  2023-08-28 07:56:01.370  - debug: mihome-vacuum.0 (423131) your device is not connected, but this could be temporary
                                  2023-08-28 07:56:01.371  - debug: mihome-vacuum.0 (423131) your device is not connected, but this could be temporary
                                  2023-08-28 07:56:08.823  - debug: mihome-vacuum.0 (423131) Helo message Timeout
                                  2023-08-28 07:56:20.825  - debug: mihome-vacuum.0 (423131) Helo message Timeout
                                  2023-08-28 07:56:21.371  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                  2023-08-28 07:56:21.372  - debug: mihome-vacuum.0 (423131) your device is not connected, but this could be temporary
                                  2023-08-28 07:56:32.826  - debug: mihome-vacuum.0 (423131) Helo message Timeout
                                  2023-08-28 07:56:41.373  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                  2023-08-28 07:56:41.373  - debug: mihome-vacuum.0 (423131) your device is not connected, but this could be temporary
                                  2023-08-28 07:56:41.374  - debug: mihome-vacuum.0 (423131) your device is not connected, but this could be temporary
                                  2023-08-28 07:56:44.826  - debug: mihome-vacuum.0 (423131) Helo message Timeout
                                  2023-08-28 07:56:54.833  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000012ffffffffffffffffffffffffffffffff
                                  2023-08-28 07:56:54.834  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                  2023-08-28 07:57:01.374  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                  2023-08-28 07:57:01.375  - debug: mihome-vacuum.0 (423131) Message= {"id":6290,"method":"get_status"}
                                  2023-08-28 07:57:01.427  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6290,"result":[{"msg_ver":2,"msg_seq":612,"state":17,"battery":100,"clean_time":116,"clean_area":4425000,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":200,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                  2023-08-28 07:57:01.427  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6290,"result":[{"msg_ver":2,"msg_seq":612,"state":17,"battery":100,"clean_time":116,"clean_area":4425000,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":200,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                  2023-08-28 07:57:01.428  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":612,"state":17,"battery":100,"clean_time":116,"clean_area":4425000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":200,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                  2023-08-28 07:57:01.428  - debug: mihome-vacuum.0 (423131) Message= {"id":6291,"method":"get_map_v1"}
                                  2023-08-28 07:57:01.429  - debug: mihome-vacuum.0 (423131) Message= {"id":6292,"method":"get_network_info"}
                                  2023-08-28 07:57:01.451  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6291,"result":["retry"],"exe_time":11}
                                  2023-08-28 07:57:01.452  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6291,"result":["retry"],"exe_time":11}
                                  2023-08-28 07:57:01.452  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6291,"result":["retry"],"exe_time":11}
                                  2023-08-28 07:57:01.511  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6292,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"d8:07:b6:86:bc:b6","rssi":-45},"exe_time":62}
                                  2023-08-28 07:57:01.512  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6292,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"d8:07:b6:86:bc:b6","rssi":-45},"exe_time":62}
                                  2023-08-28 07:57:01.708  - debug: mihome-vacuum.0 (423131) Message= {"id":6293,"method":"get_sound_volume"}
                                  2023-08-28 07:57:01.724  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6293,"result":[90],"exe_time":11}
                                  2023-08-28 07:57:01.724  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6293,"result":[90],"exe_time":11}
                                  2023-08-28 07:57:01.725  - debug: mihome-vacuum.0 (423131) Message= {"id":6294,"method":"get_map_v1"}
                                  2023-08-28 07:57:01.746  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6294,"result":["retry"],"exe_time":11}
                                  2023-08-28 07:57:01.746  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6294,"result":["retry"],"exe_time":11}
                                  2023-08-28 07:57:01.753  - debug: mihome-vacuum.0 (423131) Message= {"id":6295,"method":"get_map_v1"}
                                  2023-08-28 07:57:01.777  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6295,"result":["retry"],"exe_time":10}
                                  2023-08-28 07:57:01.778  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6295,"result":["retry"],"exe_time":10}
                                  2023-08-28 07:57:02.047  - debug: mihome-vacuum.0 (423131) Message= {"id":6296,"method":"get_map_v1"}
                                  2023-08-28 07:57:02.078  - debug: mihome-vacuum.0 (423131) Message= {"id":6297,"method":"get_map_v1"}
                                  2023-08-28 07:57:02.086  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6296,"result":["retry"],"exe_time":32}
                                  2023-08-28 07:57:02.087  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6296,"result":["retry"],"exe_time":32}
                                  2023-08-28 07:57:02.087  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6296,"result":["retry"],"exe_time":32}
                                  2023-08-28 07:57:02.097  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6297,"result":["retry"],"exe_time":11}
                                  2023-08-28 07:57:02.097  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6297,"result":["retry"],"exe_time":11}
                                  2023-08-28 07:57:02.388  - debug: mihome-vacuum.0 (423131) Message= {"id":6298,"method":"get_map_v1"}
                                  2023-08-28 07:57:02.398  - debug: mihome-vacuum.0 (423131) Message= {"id":6299,"method":"get_map_v1"}
                                  2023-08-28 07:57:02.466  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6298,"result":["roboroommap%2F506345727%2F1"],"exe_time":72}
                                  2023-08-28 07:57:02.466  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6298,"result":["roboroommap%2F506345727%2F1"],"exe_time":72}
                                  2023-08-28 07:57:02.466  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                  2023-08-28 07:57:02.467  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                  2023-08-28 07:57:02.467  - debug: mihome-vacuum.0 (423131) update_Map need new mapurl
                                  2023-08-28 07:57:02.482  - debug: mihome-vacuum.0 (423131) Message= {"id":6300,"method":"get_carpet_mode"}
                                  2023-08-28 07:57:02.482  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6299,"result":["roboroommap%2F506345727%2F1"],"exe_time":12}
                                  2023-08-28 07:57:02.483  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":6299,"result":["roboroommap%2F506345727%2F1"],"exe_time":12}
                                  2023-08-28 07:57:02.483  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":6299,"result":["roboroommap%2F506345727%2F1"],"exe_time":12}
                                  2023-08-28 07:57:02.483  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                  2023-08-28 07:57:02.483  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                  2023-08-28 07:57:02.483  - debug: mihome-vacuum.0 (423131) update_Map need new mapurl
                                    MP_Trixi @MP_Trixi last edited by
                                    @dirkhe
                                    Log2.1:
                                    2023-08-28 08:55:01.856  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:01.857  - debug: mihome-vacuum.0 (423131) Message= {"id":8132,"method":"get_map_v1"}
                                    2023-08-28 08:55:01.986  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8132,"result":["roboroommap%2F506345727%2F15"],"exe_time":11}
                                    2023-08-28 08:55:01.987  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8132,"result":["roboroommap%2F506345727%2F15"],"exe_time":11}
                                    2023-08-28 08:55:01.987  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:01.987  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:01.987  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:05.721  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:05.722  - debug: mihome-vacuum.0 (423131) Message= {"id":8133,"method":"get_map_v1"}
                                    2023-08-28 08:55:05.774  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8133,"result":["roboroommap%2F506345727%2F16"],"exe_time":10}
                                    2023-08-28 08:55:05.774  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8133,"result":["roboroommap%2F506345727%2F16"],"exe_time":10}
                                    2023-08-28 08:55:05.775  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:05.775  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:05.775  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:06.985  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000db7ffffffffffffffffffffffffffffffff
                                    2023-08-28 08:55:06.985  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202195 sec
                                    2023-08-28 08:55:08.726  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:08.726  - debug: mihome-vacuum.0 (423131) Message= {"id":8134,"method":"get_map_v1"}
                                    2023-08-28 08:55:08.849  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8134,"result":["roboroommap%2F506345727%2F17"],"exe_time":11}
                                    2023-08-28 08:55:08.850  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8134,"result":["roboroommap%2F506345727%2F17"],"exe_time":11}
                                    2023-08-28 08:55:08.850  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:08.850  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:08.850  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:12.071  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:12.072  - debug: mihome-vacuum.0 (423131) Message= {"id":8135,"method":"get_map_v1"}
                                    2023-08-28 08:55:12.122  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8135,"result":["roboroommap%2F506345727%2F0"],"exe_time":10}
                                    2023-08-28 08:55:12.123  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8135,"result":["roboroommap%2F506345727%2F0"],"exe_time":10}
                                    2023-08-28 08:55:12.123  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:12.123  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:12.124  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:13.588  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                    2023-08-28 08:55:13.588  - debug: mihome-vacuum.0 (423131) Message= {"id":8136,"method":"get_status"}
                                    2023-08-28 08:55:13.613  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8136,"result":[{"msg_ver":2,"msg_seq":969,"state":17,"battery":54,"clean_time":3569,"clean_area":48782500,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":200,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                    2023-08-28 08:55:13.624  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8136,"result":[{"msg_ver":2,"msg_seq":969,"state":17,"battery":54,"clean_time":3569,"clean_area":48782500,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":200,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                    2023-08-28 08:55:13.625  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":969,"state":17,"battery":54,"clean_time":3569,"clean_area":48782500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":200,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                    2023-08-28 08:55:13.626  - debug: mihome-vacuum.0 (423131) Message= {"id":8137,"method":"get_network_info"}
                                    2023-08-28 08:55:13.672  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8137,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-50},"exe_time":40}
                                    2023-08-28 08:55:13.673  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8137,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-50},"exe_time":40}
                                    2023-08-28 08:55:13.868  - debug: mihome-vacuum.0 (423131) Message= {"id":8138,"method":"get_sound_volume"}
                                    2023-08-28 08:55:13.884  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8138,"result":[90],"exe_time":10}
                                    2023-08-28 08:55:13.885  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8138,"result":[90],"exe_time":10}
                                    2023-08-28 08:55:13.885  - debug: mihome-vacuum.0 (423131) Message= {"id":8139,"method":"get_carpet_mode"}
                                    2023-08-28 08:55:13.913  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8139,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                    2023-08-28 08:55:13.913  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8139,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                    2023-08-28 08:55:15.111  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:15.111  - debug: mihome-vacuum.0 (423131) Message= {"id":8140,"method":"get_map_v1"}
                                    2023-08-28 08:55:15.149  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8140,"result":["roboroommap%2F506345727%2F1"],"exe_time":10}
                                    2023-08-28 08:55:15.149  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8140,"result":["roboroommap%2F506345727%2F1"],"exe_time":10}
                                    2023-08-28 08:55:15.150  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:15.150  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:15.150  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:17.015  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000dc1ffffffffffffffffffffffffffffffff
                                    2023-08-28 08:55:17.016  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                    2023-08-28 08:55:18.291  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:18.291  - debug: mihome-vacuum.0 (423131) Message= {"id":8141,"method":"get_map_v1"}
                                    2023-08-28 08:55:18.363  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8141,"result":["roboroommap%2F506345727%2F2"],"exe_time":10}
                                    2023-08-28 08:55:18.363  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8141,"result":["roboroommap%2F506345727%2F2"],"exe_time":10}
                                    2023-08-28 08:55:18.364  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:18.364  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:18.364  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:21.250  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:21.251  - debug: mihome-vacuum.0 (423131) Message= {"id":8142,"method":"get_map_v1"}
                                    2023-08-28 08:55:21.332  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8142,"result":["roboroommap%2F506345727%2F3"],"exe_time":11}
                                    2023-08-28 08:55:21.333  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8142,"result":["roboroommap%2F506345727%2F3"],"exe_time":11}
                                    2023-08-28 08:55:21.334  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:21.334  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:21.334  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:24.518  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:24.519  - debug: mihome-vacuum.0 (423131) Message= {"id":8143,"method":"get_map_v1"}
                                    2023-08-28 08:55:24.606  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8143,"result":["roboroommap%2F506345727%2F4"],"exe_time":11}
                                    2023-08-28 08:55:24.606  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8143,"result":["roboroommap%2F506345727%2F4"],"exe_time":11}
                                    2023-08-28 08:55:24.606  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:24.606  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:24.606  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:27.047  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000dcbffffffffffffffffffffffffffffffff
                                    2023-08-28 08:55:27.047  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                    2023-08-28 08:55:27.415  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:27.415  - debug: mihome-vacuum.0 (423131) Message= {"id":8144,"method":"get_map_v1"}
                                    2023-08-28 08:55:27.573  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8144,"result":["roboroommap%2F506345727%2F5"],"exe_time":10}
                                    2023-08-28 08:55:27.574  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8144,"result":["roboroommap%2F506345727%2F5"],"exe_time":10}
                                    2023-08-28 08:55:27.575  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:27.575  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:27.575  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:30.798  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:30.798  - debug: mihome-vacuum.0 (423131) Message= {"id":8145,"method":"get_map_v1"}
                                    2023-08-28 08:55:30.851  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8145,"result":["roboroommap%2F506345727%2F6"],"exe_time":11}
                                    2023-08-28 08:55:30.851  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8145,"result":["roboroommap%2F506345727%2F6"],"exe_time":11}
                                    2023-08-28 08:55:30.851  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:30.852  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:30.852  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:33.730  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:33.731  - debug: mihome-vacuum.0 (423131) Message= {"id":8146,"method":"get_map_v1"}
                                    2023-08-28 08:55:33.812  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8146,"result":["roboroommap%2F506345727%2F7"],"exe_time":10}
                                    2023-08-28 08:55:33.813  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8146,"result":["roboroommap%2F506345727%2F7"],"exe_time":10}
                                    2023-08-28 08:55:33.813  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:33.813  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:33.813  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:34.636  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                    2023-08-28 08:55:34.637  - debug: mihome-vacuum.0 (423131) Message= {"id":8147,"method":"get_status"}
                                    2023-08-28 08:55:34.663  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8147,"result":[{"msg_ver":2,"msg_seq":970,"state":17,"battery":54,"clean_time":3599,"clean_area":48782500,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":200,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                    2023-08-28 08:55:34.664  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8147,"result":[{"msg_ver":2,"msg_seq":970,"state":17,"battery":54,"clean_time":3599,"clean_area":48782500,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":200,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                    2023-08-28 08:55:34.664  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":970,"state":17,"battery":54,"clean_time":3599,"clean_area":48782500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":200,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                    2023-08-28 08:55:34.665  - debug: mihome-vacuum.0 (423131) Message= {"id":8148,"method":"get_network_info"}
                                    2023-08-28 08:55:34.717  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8148,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-58},"exe_time":41}
                                    2023-08-28 08:55:34.718  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8148,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-58},"exe_time":41}
                                    2023-08-28 08:55:35.129  - debug: mihome-vacuum.0 (423131) Message= {"id":8149,"method":"get_sound_volume"}
                                    2023-08-28 08:55:35.246  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8149,"result":[90],"exe_time":11}
                                    2023-08-28 08:55:35.246  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8149,"result":[90],"exe_time":11}
                                    2023-08-28 08:55:35.246  - debug: mihome-vacuum.0 (423131) Message= {"id":8150,"method":"get_carpet_mode"}
                                    2023-08-28 08:55:35.264  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8150,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":10}
                                    2023-08-28 08:55:35.265  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8150,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":10}
                                    2023-08-28 08:55:37.065  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:37.065  - debug: mihome-vacuum.0 (423131) Message= {"id":8151,"method":"get_map_v1"}
                                    2023-08-28 08:55:37.076  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000dd5ffffffffffffffffffffffffffffffff
                                    2023-08-28 08:55:37.076  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                    2023-08-28 08:55:37.103  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8151,"result":["roboroommap%2F506345727%2F8"],"exe_time":12}
                                    2023-08-28 08:55:37.104  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8151,"result":["roboroommap%2F506345727%2F8"],"exe_time":12}
                                    2023-08-28 08:55:37.104  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:37.104  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:37.104  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:39.974  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:39.974  - debug: mihome-vacuum.0 (423131) Message= {"id":8152,"method":"get_map_v1"}
                                    2023-08-28 08:55:40.054  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8152,"result":["roboroommap%2F506345727%2F9"],"exe_time":11}
                                    2023-08-28 08:55:40.055  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8152,"result":["roboroommap%2F506345727%2F9"],"exe_time":11}
                                    2023-08-28 08:55:40.055  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:40.055  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:40.055  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:43.198  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:43.199  - debug: mihome-vacuum.0 (423131) Message= {"id":8153,"method":"get_map_v1"}
                                    2023-08-28 08:55:43.334  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8153,"result":["roboroommap%2F506345727%2F10"],"exe_time":11}
                                    2023-08-28 08:55:43.334  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8153,"result":["roboroommap%2F506345727%2F10"],"exe_time":11}
                                    2023-08-28 08:55:43.335  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:43.335  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:43.335  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:46.280  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:46.280  - debug: mihome-vacuum.0 (423131) Message= {"id":8154,"method":"get_map_v1"}
                                    2023-08-28 08:55:46.400  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8154,"result":["roboroommap%2F506345727%2F11"],"exe_time":11}
                                    2023-08-28 08:55:46.401  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8154,"result":["roboroommap%2F506345727%2F11"],"exe_time":11}
                                    2023-08-28 08:55:46.402  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:46.402  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:46.402  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:47.210  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000ddfffffffffffffffffffffffffffffffff
                                    2023-08-28 08:55:47.210  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                    2023-08-28 08:55:49.609  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:49.609  - debug: mihome-vacuum.0 (423131) Message= {"id":8155,"method":"get_map_v1"}
                                    2023-08-28 08:55:49.685  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8155,"result":["roboroommap%2F506345727%2F12"],"exe_time":10}
                                    2023-08-28 08:55:49.685  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8155,"result":["roboroommap%2F506345727%2F12"],"exe_time":10}
                                    2023-08-28 08:55:49.685  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:49.685  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:49.685  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:52.537  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:52.537  - debug: mihome-vacuum.0 (423131) Message= {"id":8156,"method":"get_map_v1"}
                                    2023-08-28 08:55:52.646  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8156,"result":["roboroommap%2F506345727%2F13"],"exe_time":11}
                                    2023-08-28 08:55:52.646  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8156,"result":["roboroommap%2F506345727%2F13"],"exe_time":11}
                                    2023-08-28 08:55:52.646  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:52.646  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:52.647  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:55.362  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                    2023-08-28 08:55:55.362  - debug: mihome-vacuum.0 (423131) Message= {"id":8157,"method":"get_status"}
                                    2023-08-28 08:55:55.414  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8157,"result":[{"msg_ver":2,"msg_seq":972,"state":6,"battery":54,"clean_time":3607,"clean_area":48782500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":1,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":0,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":6,"unsave_map_flag":0}],"exe_time":11}
                                    2023-08-28 08:55:55.414  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8157,"result":[{"msg_ver":2,"msg_seq":972,"state":6,"battery":54,"clean_time":3607,"clean_area":48782500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":1,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":0,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":6,"unsave_map_flag":0}],"exe_time":11}
                                    2023-08-28 08:55:55.414  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":972,"state":6,"battery":54,"clean_time":3607,"clean_area":48782500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":1,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":0,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":6,"unsave_map_flag":0,"error_text":"No error"}
                                    2023-08-28 08:55:55.415  - debug: mihome-vacuum.0 (423131) use clean trigger from Queue
                                    2023-08-28 08:55:55.415  - debug: mihome-vacuum.0 (423131) We are in onMessage:{"command":"cleanZone","message":"[21300,24900,25000,15000,1]","from":"system.adapter.mihome-vacuum.0","_id":99543804,"zones":["[21300,24900,25000,15000,1]"],"channels":["mihome-vacuum.0.rooms.manual_21300_24900_25000_15000"],"info":"zone  manual_21300_24900_25000_15000"}
                                    2023-08-28 08:55:55.415  - debug: mihome-vacuum.0 (423131) start Cleaning: 17 MObj: {"command":"cleanZone","message":"[21300,24900,25000,15000,1]","from":"system.adapter.mihome-vacuum.0","_id":99543804,"zones":["[21300,24900,25000,15000,1]"],"channels":["mihome-vacuum.0.rooms.manual_21300_24900_25000_15000"],"info":"zone  manual_21300_24900_25000_15000"}
                                    2023-08-28 08:55:55.416  - debug: mihome-vacuum.0 (423131) Message= {"id":8158,"method":"get_map_v1"}
                                    2023-08-28 08:55:55.416  - debug: mihome-vacuum.0 (423131) Message= {"id":8159,"method":"get_network_info"}
                                    2023-08-28 08:55:55.425  - debug: mihome-vacuum.0 (423131) Set water box mode from Room to 200
                                    2023-08-28 08:55:55.426  - info: mihome-vacuum.0 (423131) trigger cleaning zone [21300,24900,25000,15000,1]
                                    2023-08-28 08:55:55.427  - debug: mihome-vacuum.0 (423131) Message= {"id":8160,"method":"app_zoned_clean","params":[[21300,24900,25000,15000,1]]}
                                    2023-08-28 08:55:55.434  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8158,"result":["roboroommap%2F506345727%2F14"],"exe_time":11}
                                    2023-08-28 08:55:55.435  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8158,"result":["roboroommap%2F506345727%2F14"],"exe_time":11}
                                    2023-08-28 08:55:55.436  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8158,"result":["roboroommap%2F506345727%2F14"],"exe_time":11}
                                    2023-08-28 08:55:55.437  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8158,"result":["roboroommap%2F506345727%2F14"],"exe_time":11}
                                    2023-08-28 08:55:55.437  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:55.437  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:55.438  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:55.486  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8159,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-66},"exe_time":51}
                                    2023-08-28 08:55:55.487  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8159,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-66},"exe_time":51}
                                    2023-08-28 08:55:55.487  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8159,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-66},"exe_time":51}
                                    2023-08-28 08:55:55.517  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8160,"result":["ok"],"exe_time":71}
                                    2023-08-28 08:55:55.518  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8160,"result":["ok"],"exe_time":71}
                                    2023-08-28 08:55:55.548  - debug: mihome-vacuum.0 (423131) command: mop_mode parent: control
                                    2023-08-28 08:55:55.549  - debug: mihome-vacuum.0 (423131) Message= {"id":8161,"method":"set_mop_mode","params":[301]}
                                    2023-08-28 08:55:55.568  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8161,"result":["ok"],"exe_time":10}
                                    2023-08-28 08:55:55.569  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8161,"result":["ok"],"exe_time":10}
                                    2023-08-28 08:55:56.263  - debug: mihome-vacuum.0 (423131) Message= {"id":8162,"method":"get_sound_volume"}
                                    2023-08-28 08:55:56.290  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8162,"result":[90],"exe_time":10}
                                    2023-08-28 08:55:56.290  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8162,"result":[90],"exe_time":10}
                                    2023-08-28 08:55:56.291  - debug: mihome-vacuum.0 (423131) Message= {"id":8163,"method":"get_carpet_mode"}
                                    2023-08-28 08:55:56.327  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8163,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":21}
                                    2023-08-28 08:55:56.328  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8163,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":21}
                                    2023-08-28 08:55:57.232  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000de9ffffffffffffffffffffffffffffffff
                                    2023-08-28 08:55:57.233  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                    2023-08-28 08:55:58.391  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:55:58.392  - debug: mihome-vacuum.0 (423131) Message= {"id":8164,"method":"get_map_v1"}
                                    2023-08-28 08:55:58.476  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8164,"result":["retry"],"exe_time":10}
                                    2023-08-28 08:55:58.477  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8164,"result":["retry"],"exe_time":10}
                                    2023-08-28 08:55:58.778  - debug: mihome-vacuum.0 (423131) Message= {"id":8165,"method":"get_map_v1"}
                                    2023-08-28 08:55:58.806  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8165,"result":["roboroommap%2F506345727%2F16"],"exe_time":11}
                                    2023-08-28 08:55:58.807  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8165,"result":["roboroommap%2F506345727%2F16"],"exe_time":11}
                                    2023-08-28 08:55:58.807  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:55:58.807  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:55:58.808  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:55:59.196  - debug: mihome-vacuum.0 (423131) zone changed[[21300,26300,25000,36200]]
                                    2023-08-28 08:56:01.754  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:56:01.755  - debug: mihome-vacuum.0 (423131) Message= {"id":8166,"method":"get_map_v1"}
                                    2023-08-28 08:56:01.851  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8166,"result":["roboroommap%2F506345727%2F17"],"exe_time":11}
                                    2023-08-28 08:56:01.852  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8166,"result":["roboroommap%2F506345727%2F17"],"exe_time":11}
                                    2023-08-28 08:56:01.852  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:56:01.852  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:56:01.852  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:56:04.935  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:56:04.936  - debug: mihome-vacuum.0 (423131) Message= {"id":8167,"method":"get_map_v1"}
                                    2023-08-28 08:56:05.027  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8167,"result":["roboroommap%2F506345727%2F0"],"exe_time":10}
                                    2023-08-28 08:56:05.028  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8167,"result":["roboroommap%2F506345727%2F0"],"exe_time":10}
                                    2023-08-28 08:56:05.028  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:56:05.028  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:56:05.028  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:56:07.260  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000df3ffffffffffffffffffffffffffffffff
                                    2023-08-28 08:56:07.260  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                    2023-08-28 08:56:08.087  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:56:08.087  - debug: mihome-vacuum.0 (423131) Message= {"id":8168,"method":"get_map_v1"}
                                    2023-08-28 08:56:08.110  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8168,"result":["roboroommap%2F506345727%2F1"],"exe_time":10}
                                    2023-08-28 08:56:08.111  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8168,"result":["roboroommap%2F506345727%2F1"],"exe_time":10}
                                    2023-08-28 08:56:08.111  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:56:08.111  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:56:08.111  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:56:10.847  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:56:10.848  - debug: mihome-vacuum.0 (423131) Message= {"id":8169,"method":"get_map_v1"}
                                    2023-08-28 08:56:10.966  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8169,"result":["roboroommap%2F506345727%2F2"],"exe_time":11}
                                    2023-08-28 08:56:10.967  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8169,"result":["roboroommap%2F506345727%2F2"],"exe_time":11}
                                    2023-08-28 08:56:10.967  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:56:10.967  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:56:10.967  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:56:13.898  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:56:13.899  - debug: mihome-vacuum.0 (423131) Message= {"id":8170,"method":"get_map_v1"}
                                    2023-08-28 08:56:14.033  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8170,"result":["roboroommap%2F506345727%2F3"],"exe_time":10}
                                    2023-08-28 08:56:14.033  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8170,"result":["roboroommap%2F506345727%2F3"],"exe_time":10}
                                    2023-08-28 08:56:14.033  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:56:14.033  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:56:14.033  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:56:16.464  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                    2023-08-28 08:56:16.464  - debug: mihome-vacuum.0 (423131) Message= {"id":8171,"method":"get_status"}
                                    2023-08-28 08:56:16.590  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8171,"result":[{"msg_ver":2,"msg_seq":977,"state":26,"battery":54,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":1,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                    2023-08-28 08:56:16.591  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8171,"result":[{"msg_ver":2,"msg_seq":977,"state":26,"battery":54,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":1,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                    2023-08-28 08:56:16.591  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":977,"state":26,"battery":54,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":1,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                    2023-08-28 08:56:16.591  - debug: mihome-vacuum.0 (423131) Message= {"id":8172,"method":"get_network_info"}
                                    2023-08-28 08:56:16.651  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8172,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-58},"exe_time":51}
                                    2023-08-28 08:56:16.652  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8172,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-58},"exe_time":51}
                                    2023-08-28 08:56:16.744  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                    2023-08-28 08:56:16.744  - debug: mihome-vacuum.0 (423131) Message= {"id":8173,"method":"get_map_v1"}
                                    2023-08-28 08:56:16.746  - debug: mihome-vacuum.0 (423131) Message= {"id":8174,"method":"get_sound_volume"}
                                    2023-08-28 08:56:16.769  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8173,"result":["roboroommap%2F506345727%2F4"],"exe_time":11}
                                    2023-08-28 08:56:16.770  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8173,"result":["roboroommap%2F506345727%2F4"],"exe_time":11}
                                    2023-08-28 08:56:16.770  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8173,"result":["roboroommap%2F506345727%2F4"],"exe_time":11}
                                    2023-08-28 08:56:16.771  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                    2023-08-28 08:56:16.771  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                    2023-08-28 08:56:16.772  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                    2023-08-28 08:56:16.793  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8174,"result":[90],"exe_time":11}
                                    2023-08-28 08:56:16.793  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8174,"result":[90],"exe_time":11}
                                    2023-08-28 08:56:16.794  - debug: mihome-vacuum.0 (423131) Message= {"id":8175,"method":"get_carpet_mode"}
                                    2023-08-28 08:56:16.817  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8175,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":10}
                                    2023-08-28 08:56:16.818  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8175,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":10}
                                    2023-08-28 08:56:17.528  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000dfdffffffffffffffffffffffffffffffff
                                    2023-08-28 08:56:17.528  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                    2023-08-28 08:56:27.626  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e07ffffffffffffffffffffffffffffffff
                                    2023-08-28 08:56:27.626  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                    2023-08-28 08:56:37.541  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                    2023-08-28 08:56:37.541  - debug: mihome-vacuum.0 (423131) Message= {"id":8176,"method":"get_status"}
                                    2023-08-28 08:56:37.669  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e11ffffffffffffffffffffffffffffffff
                                    2023-08-28 08:56:37.669  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                    2023-08-28 08:56:37.669  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8176,"result":[{"msg_ver":2,"msg_seq":985,"state":23,"battery":54,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                    2023-08-28 08:56:37.670  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8176,"result":[{"msg_ver":2,"msg_seq":985,"state":23,"battery":54,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                    2023-08-28 08:56:37.670  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":985,"state":23,"battery":54,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                    2023-08-28 08:56:37.670  - debug: mihome-vacuum.0 (423131) Message= {"id":8177,"method":"get_network_info"}
                                    2023-08-28 08:56:37.730  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8177,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-55},"exe_time":52}
                                    2023-08-28 08:56:37.730  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8177,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-55},"exe_time":52}
                                    2023-08-28 08:56:37.848  - debug: mihome-vacuum.0 (423131) Message= {"id":8178,"method":"get_sound_volume"}
                                    2023-08-28 08:56:37.872  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8178,"result":[90],"exe_time":11}
                                    2023-08-28 08:56:37.873  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8178,"result":[90],"exe_time":11}
                                    2023-08-28 08:56:37.873  - debug: mihome-vacuum.0 (423131) Message= {"id":8179,"method":"get_carpet_mode"}
                                    2023-08-28 08:56:37.893  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8179,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                    2023-08-28 08:56:37.895  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8179,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                    2023-08-28 08:56:47.789  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e1bffffffffffffffffffffffffffffffff
                                    2023-08-28 08:56:47.790  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                    2023-08-28 08:56:57.814  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e25ffffffffffffffffffffffffffffffff
                                    2023-08-28 08:56:57.815  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                    2023-08-28 08:56:57.976  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                    2023-08-28 08:56:57.976  - debug: mihome-vacuum.0 (423131) Message= {"id":8180,"method":"get_status"}
                                    2023-08-28 08:56:58.000  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8180,"result":[{"msg_ver":2,"msg_seq":986,"state":23,"battery":54,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":10}
                                    2023-08-28 08:56:58.001  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8180,"result":[{"msg_ver":2,"msg_seq":986,"state":23,"battery":54,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":10}
                                    2023-08-28 08:56:58.001  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":986,"state":23,"battery":54,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                    2023-08-28 08:56:58.002  - debug: mihome-vacuum.0 (423131) Message= {"id":8181,"method":"get_network_info"}
                                    2023-08-28 08:56:58.062  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8181,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-56},"exe_time":51}
                                    2023-08-28 08:56:58.063  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8181,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-56},"exe_time":51}
                                    2023-08-28 08:56:58.175  - debug: mihome-vacuum.0 (423131) Message= {"id":8182,"method":"get_sound_volume"}
                                    2023-08-28 08:56:58.193  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8182,"result":[90],"exe_time":11}
                                    2023-08-28 08:56:58.194  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8182,"result":[90],"exe_time":11}
                                    2023-08-28 08:56:58.194  - debug: mihome-vacuum.0 (423131) Message= {"id":8183,"method":"get_carpet_mode"}
                                    2023-08-28 08:56:58.215  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8183,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                    2023-08-28 08:56:58.215  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8183,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                    2023-08-28 08:57:07.842  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e2fffffffffffffffffffffffffffffffff
                                      @dirkhe
                                      Log 2.2:
                                      2023-08-28 08:57:07.842  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:57:17.845  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e39ffffffffffffffffffffffffffffffff
                                      2023-08-28 08:57:17.846  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:57:18.308  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                      2023-08-28 08:57:18.308  - debug: mihome-vacuum.0 (423131) Message= {"id":8184,"method":"get_status"}
                                      2023-08-28 08:57:18.328  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8184,"result":[{"msg_ver":2,"msg_seq":988,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 08:57:18.328  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8184,"result":[{"msg_ver":2,"msg_seq":988,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 08:57:18.329  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":988,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                      2023-08-28 08:57:18.329  - debug: mihome-vacuum.0 (423131) Message= {"id":8185,"method":"get_network_info"}
                                      2023-08-28 08:57:18.388  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8185,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-56},"exe_time":51}
                                      2023-08-28 08:57:18.388  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8185,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-56},"exe_time":51}
                                      2023-08-28 08:57:18.672  - debug: mihome-vacuum.0 (423131) Message= {"id":8186,"method":"get_sound_volume"}
                                      2023-08-28 08:57:18.703  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8186,"result":[90],"exe_time":10}
                                      2023-08-28 08:57:18.703  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8186,"result":[90],"exe_time":10}
                                      2023-08-28 08:57:18.703  - debug: mihome-vacuum.0 (423131) Message= {"id":8187,"method":"get_carpet_mode"}
                                      2023-08-28 08:57:18.723  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8187,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":10}
                                      2023-08-28 08:57:18.723  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8187,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":10}
                                      2023-08-28 08:57:28.102  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e44ffffffffffffffffffffffffffffffff
                                      2023-08-28 08:57:28.103  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:57:38.131  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e4effffffffffffffffffffffffffffffff
                                      2023-08-28 08:57:38.132  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:57:38.841  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                      2023-08-28 08:57:38.841  - debug: mihome-vacuum.0 (423131) Message= {"id":8188,"method":"get_status"}
                                      2023-08-28 08:57:38.965  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8188,"result":[{"msg_ver":2,"msg_seq":989,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 08:57:38.965  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8188,"result":[{"msg_ver":2,"msg_seq":989,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 08:57:38.965  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":989,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                      2023-08-28 08:57:38.966  - debug: mihome-vacuum.0 (423131) Message= {"id":8189,"method":"get_network_info"}
                                      2023-08-28 08:57:39.025  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8189,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-55},"exe_time":51}
                                      2023-08-28 08:57:39.025  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8189,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-55},"exe_time":51}
                                      2023-08-28 08:57:39.440  - debug: mihome-vacuum.0 (423131) Message= {"id":8190,"method":"get_sound_volume"}
                                      2023-08-28 08:57:39.460  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8190,"result":[90],"exe_time":11}
                                      2023-08-28 08:57:39.460  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8190,"result":[90],"exe_time":11}
                                      2023-08-28 08:57:39.460  - debug: mihome-vacuum.0 (423131) Message= {"id":8191,"method":"get_carpet_mode"}
                                      2023-08-28 08:57:39.481  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8191,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 08:57:39.481  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8191,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 08:57:48.161  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e58ffffffffffffffffffffffffffffffff
                                      2023-08-28 08:57:48.161  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:57:58.189  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e62ffffffffffffffffffffffffffffffff
                                      2023-08-28 08:57:58.189  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:57:59.580  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                      2023-08-28 08:57:59.581  - debug: mihome-vacuum.0 (423131) Message= {"id":8192,"method":"get_status"}
                                      2023-08-28 08:57:59.639  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8192,"result":[{"msg_ver":2,"msg_seq":990,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 08:57:59.640  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8192,"result":[{"msg_ver":2,"msg_seq":990,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 08:57:59.641  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":990,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                      2023-08-28 08:57:59.642  - debug: mihome-vacuum.0 (423131) Message= {"id":8193,"method":"get_network_info"}
                                      2023-08-28 08:57:59.706  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8193,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-56},"exe_time":51}
                                      2023-08-28 08:57:59.707  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8193,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-56},"exe_time":51}
                                      2023-08-28 08:58:00.276  - debug: mihome-vacuum.0 (423131) Message= {"id":8194,"method":"get_sound_volume"}
                                      2023-08-28 08:58:00.356  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8194,"result":[90],"exe_time":10}
                                      2023-08-28 08:58:00.357  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8194,"result":[90],"exe_time":10}
                                      2023-08-28 08:58:00.358  - debug: mihome-vacuum.0 (423131) Message= {"id":8195,"method":"get_carpet_mode"}
                                      2023-08-28 08:58:00.374  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8195,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 08:58:00.375  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8195,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 08:58:08.219  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e6cffffffffffffffffffffffffffffffff
                                      2023-08-28 08:58:08.219  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:58:18.246  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e76ffffffffffffffffffffffffffffffff
                                      2023-08-28 08:58:18.246  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:58:20.589  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                      2023-08-28 08:58:20.589  - debug: mihome-vacuum.0 (423131) Message= {"id":8196,"method":"get_status"}
                                      2023-08-28 08:58:20.616  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8196,"result":[{"msg_ver":2,"msg_seq":993,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 08:58:20.617  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8196,"result":[{"msg_ver":2,"msg_seq":993,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 08:58:20.618  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":993,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":11,"wash_ready":1,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                      2023-08-28 08:58:20.618  - debug: mihome-vacuum.0 (423131) Message= {"id":8197,"method":"get_network_info"}
                                      2023-08-28 08:58:20.709  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8197,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-55},"exe_time":81}
                                      2023-08-28 08:58:20.710  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8197,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-55},"exe_time":81}
                                      2023-08-28 08:58:20.771  - debug: mihome-vacuum.0 (423131) Message= {"id":8198,"method":"get_sound_volume"}
                                      2023-08-28 08:58:20.793  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8198,"result":[90],"exe_time":11}
                                      2023-08-28 08:58:20.794  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8198,"result":[90],"exe_time":11}
                                      2023-08-28 08:58:20.795  - debug: mihome-vacuum.0 (423131) Message= {"id":8199,"method":"get_carpet_mode"}
                                      2023-08-28 08:58:20.812  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8199,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 08:58:20.813  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8199,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 08:58:28.281  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e80ffffffffffffffffffffffffffffffff
                                      2023-08-28 08:58:28.281  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:58:38.303  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e8affffffffffffffffffffffffffffffff
                                      2023-08-28 08:58:38.303  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:58:40.909  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                      2023-08-28 08:58:40.909  - debug: mihome-vacuum.0 (423131) Message= {"id":8200,"method":"get_status"}
                                      2023-08-28 08:58:40.984  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8200,"result":[{"msg_ver":2,"msg_seq":997,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":13,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 08:58:40.985  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8200,"result":[{"msg_ver":2,"msg_seq":997,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":13,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 08:58:40.985  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":997,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":13,"wash_ready":1,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                      2023-08-28 08:58:40.986  - debug: mihome-vacuum.0 (423131) Message= {"id":8201,"method":"get_network_info"}
                                      2023-08-28 08:58:41.048  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8201,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-55},"exe_time":51}
                                      2023-08-28 08:58:41.049  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8201,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-55},"exe_time":51}
                                      2023-08-28 08:58:41.177  - debug: mihome-vacuum.0 (423131) Message= {"id":8202,"method":"get_sound_volume"}
                                      2023-08-28 08:58:41.198  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8202,"result":[90],"exe_time":11}
                                      2023-08-28 08:58:41.199  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8202,"result":[90],"exe_time":11}
                                      2023-08-28 08:58:41.199  - debug: mihome-vacuum.0 (423131) Message= {"id":8203,"method":"get_carpet_mode"}
                                      2023-08-28 08:58:41.220  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8203,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 08:58:41.220  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8203,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 08:58:48.334  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e94ffffffffffffffffffffffffffffffff
                                      2023-08-28 08:58:48.335  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:58:58.361  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000e9effffffffffffffffffffffffffffffff
                                      2023-08-28 08:58:58.362  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:59:01.621  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                      2023-08-28 08:59:01.621  - debug: mihome-vacuum.0 (423131) Message= {"id":8204,"method":"get_status"}
                                      2023-08-28 08:59:01.651  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8204,"result":[{"msg_ver":2,"msg_seq":998,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":13,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":10}
                                      2023-08-28 08:59:01.652  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8204,"result":[{"msg_ver":2,"msg_seq":998,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":13,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":10}
                                      2023-08-28 08:59:01.652  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":998,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":13,"wash_ready":1,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                      2023-08-28 08:59:01.653  - debug: mihome-vacuum.0 (423131) Message= {"id":8205,"method":"get_network_info"}
                                      2023-08-28 08:59:01.713  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8205,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-56},"exe_time":52}
                                      2023-08-28 08:59:01.714  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8205,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-56},"exe_time":52}
                                      2023-08-28 08:59:02.156  - debug: mihome-vacuum.0 (423131) Message= {"id":8206,"method":"get_sound_volume"}
                                      2023-08-28 08:59:02.269  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8206,"result":[90],"exe_time":11}
                                      2023-08-28 08:59:02.270  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8206,"result":[90],"exe_time":11}
                                      2023-08-28 08:59:02.270  - debug: mihome-vacuum.0 (423131) Message= {"id":8207,"method":"get_carpet_mode"}
                                      2023-08-28 08:59:02.290  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8207,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 08:59:02.291  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8207,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 08:59:08.392  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000ea8ffffffffffffffffffffffffffffffff
                                      2023-08-28 08:59:08.392  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:59:18.420  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000eb2ffffffffffffffffffffffffffffffff
                                      2023-08-28 08:59:18.420  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:59:22.649  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                      2023-08-28 08:59:22.649  - debug: mihome-vacuum.0 (423131) Message= {"id":8208,"method":"get_status"}
                                      2023-08-28 08:59:22.733  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8208,"result":[{"msg_ver":2,"msg_seq":999,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":13,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 08:59:22.734  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8208,"result":[{"msg_ver":2,"msg_seq":999,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":13,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 08:59:22.734  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":999,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":13,"wash_ready":1,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                      2023-08-28 08:59:22.735  - debug: mihome-vacuum.0 (423131) Message= {"id":8209,"method":"get_network_info"}
                                      2023-08-28 08:59:22.794  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8209,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-56},"exe_time":51}
                                      2023-08-28 08:59:22.795  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8209,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-56},"exe_time":51}
                                      2023-08-28 08:59:22.972  - debug: mihome-vacuum.0 (423131) Message= {"id":8210,"method":"get_sound_volume"}
                                      2023-08-28 08:59:22.987  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8210,"result":[90],"exe_time":10}
                                      2023-08-28 08:59:22.988  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8210,"result":[90],"exe_time":10}
                                      2023-08-28 08:59:22.989  - debug: mihome-vacuum.0 (423131) Message= {"id":8211,"method":"get_carpet_mode"}
                                      2023-08-28 08:59:23.008  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8211,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":10}
                                      2023-08-28 08:59:23.009  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8211,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":10}
                                      2023-08-28 08:59:28.423  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000ebcffffffffffffffffffffffffffffffff
                                      2023-08-28 08:59:28.423  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:59:38.476  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000ec6ffffffffffffffffffffffffffffffff
                                      2023-08-28 08:59:38.476  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:59:43.316  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                      2023-08-28 08:59:43.317  - debug: mihome-vacuum.0 (423131) Message= {"id":8212,"method":"get_status"}
                                      2023-08-28 08:59:43.402  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8212,"result":[{"msg_ver":2,"msg_seq":1000,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":13,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":10}
                                      2023-08-28 08:59:43.403  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8212,"result":[{"msg_ver":2,"msg_seq":1000,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":13,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":10}
                                      2023-08-28 08:59:43.403  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":1000,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":13,"wash_ready":1,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                      2023-08-28 08:59:43.403  - debug: mihome-vacuum.0 (423131) Message= {"id":8213,"method":"get_network_info"}
                                      2023-08-28 08:59:43.471  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8213,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-56},"exe_time":51}
                                      2023-08-28 08:59:43.472  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8213,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-56},"exe_time":51}
                                      2023-08-28 08:59:43.651  - debug: mihome-vacuum.0 (423131) Message= {"id":8214,"method":"get_sound_volume"}
                                      2023-08-28 08:59:43.676  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8214,"result":[90],"exe_time":11}
                                      2023-08-28 08:59:43.677  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8214,"result":[90],"exe_time":11}
                                      2023-08-28 08:59:43.677  - debug: mihome-vacuum.0 (423131) Message= {"id":8215,"method":"get_carpet_mode"}
                                      2023-08-28 08:59:43.697  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8215,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 08:59:43.697  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8215,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 08:59:48.513  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000ed0ffffffffffffffffffffffffffffffff
                                      2023-08-28 08:59:48.513  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 08:59:58.532  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000edaffffffffffffffffffffffffffffffff
                                      2023-08-28 08:59:58.533  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 09:00:04.060  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                      2023-08-28 09:00:04.061  - debug: mihome-vacuum.0 (423131) Message= {"id":8216,"method":"get_status"}
                                      2023-08-28 09:00:04.079  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8216,"result":[{"msg_ver":2,"msg_seq":1002,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":12,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 09:00:04.080  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8216,"result":[{"msg_ver":2,"msg_seq":1002,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":12,"wash_ready":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 09:00:04.080  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":1002,"state":23,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":12,"wash_ready":1,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                      2023-08-28 09:00:04.081  - debug: mihome-vacuum.0 (423131) Message= {"id":8217,"method":"get_network_info"}
                                      2023-08-28 09:00:04.143  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8217,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-55},"exe_time":51}
                                      2023-08-28 09:00:04.144  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8217,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-55},"exe_time":51}
                                      2023-08-28 09:00:04.272  - debug: mihome-vacuum.0 (423131) Message= {"id":8218,"method":"get_sound_volume"}
                                      2023-08-28 09:00:04.293  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8218,"result":[90],"exe_time":11}
                                      2023-08-28 09:00:04.294  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8218,"result":[90],"exe_time":11}
                                      2023-08-28 09:00:04.294  - debug: mihome-vacuum.0 (423131) Message= {"id":8219,"method":"get_carpet_mode"}
                                      2023-08-28 09:00:04.315  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8219,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 09:00:04.318  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8219,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 09:00:08.535  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000ee4ffffffffffffffffffffffffffffffff
                                      2023-08-28 09:00:08.536  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 09:00:18.539  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000eeeffffffffffffffffffffffffffffffff
                                      2023-08-28 09:00:18.539  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 09:00:24.420  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                      2023-08-28 09:00:24.420  - debug: mihome-vacuum.0 (423131) Message= {"id":8220,"method":"get_status"}
                                      2023-08-28 09:00:24.439  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8220,"result":[{"msg_ver":2,"msg_seq":1016,"state":17,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 09:00:24.440  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8220,"result":[{"msg_ver":2,"msg_seq":1016,"state":17,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 09:00:24.441  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":1016,"state":17,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":301,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                      2023-08-28 09:00:24.441  - debug: mihome-vacuum.0 (423131) Message= {"id":8221,"method":"get_map_v1"}
                                      2023-08-28 09:00:24.442  - debug: mihome-vacuum.0 (423131) Message= {"id":8222,"method":"get_network_info"}
                                      2023-08-28 09:00:24.463  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8221,"result":["roboroommap%2F506345727%2F5"],"exe_time":11}
                                      2023-08-28 09:00:24.464  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8221,"result":["roboroommap%2F506345727%2F5"],"exe_time":11}
                                      2023-08-28 09:00:24.465  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8221,"result":["roboroommap%2F506345727%2F5"],"exe_time":11}
                                      2023-08-28 09:00:24.465  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                      2023-08-28 09:00:24.465  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                      2023-08-28 09:00:24.465  - debug: mihome-vacuum.0 (423131) update_Map need new mapurl
                                      2023-08-28 09:00:24.517  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8222,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-55},"exe_time":51}
                                      2023-08-28 09:00:24.518  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8222,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-55},"exe_time":51}
                                      2023-08-28 09:00:24.597  - debug: mihome-vacuum.0 (423131) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/roboroommap/506345727/5?Expires=1693207824000&GalaxyAccessKeyId=5271733786445&Signature=BX/l7F7r14/5Aai8RAhPLegTbm8=
                                      2023-08-28 09:00:24.598  - debug: mihome-vacuum.0 (423131) update_Map got new expires:1693207824
                                      2023-08-28 09:00:24.598  - debug: mihome-vacuum.0 (423131) update_Map got new time:1693206024
                                      2023-08-28 09:00:24.610  - debug: mihome-vacuum.0 (423131) Message= {"id":8223,"method":"get_sound_volume"}
                                      2023-08-28 09:00:24.625  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8223,"result":[90],"exe_time":11}
                                      2023-08-28 09:00:24.626  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8223,"result":[90],"exe_time":11}
                                      2023-08-28 09:00:24.626  - debug: mihome-vacuum.0 (423131) Message= {"id":8224,"method":"get_carpet_mode"}
                                      2023-08-28 09:00:24.646  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8224,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 09:00:24.647  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8224,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 09:00:27.694  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                      2023-08-28 09:00:27.694  - debug: mihome-vacuum.0 (423131) Message= {"id":8225,"method":"get_map_v1"}
                                      2023-08-28 09:00:27.712  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8225,"result":["roboroommap%2F506345727%2F7"],"exe_time":11}
                                      2023-08-28 09:00:27.712  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8225,"result":["roboroommap%2F506345727%2F7"],"exe_time":11}
                                      2023-08-28 09:00:27.713  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                      2023-08-28 09:00:27.713  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                      2023-08-28 09:00:27.713  - debug: mihome-vacuum.0 (423131) update_Map need new mapurl
                                      2023-08-28 09:00:27.826  - debug: mihome-vacuum.0 (423131) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/roboroommap/506345727/7?Expires=1693207827000&GalaxyAccessKeyId=5271733786445&Signature=i0tuC0Fr+hHEmUiuvVpFhu8EH6o=
                                      2023-08-28 09:00:27.827  - debug: mihome-vacuum.0 (423131) update_Map got new expires:1693207827
                                      2023-08-28 09:00:27.827  - debug: mihome-vacuum.0 (423131) update_Map got new time:1693206027
                                      2023-08-28 09:00:28.542  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000ef8ffffffffffffffffffffffffffffffff
                                      2023-08-28 09:00:28.543  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 09:00:30.584  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                      2023-08-28 09:00:30.584  - debug: mihome-vacuum.0 (423131) Message= {"id":8226,"method":"get_map_v1"}
                                      2023-08-28 09:00:30.599  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8226,"result":["roboroommap%2F506345727%2F8"],"exe_time":10}
                                      2023-08-28 09:00:30.600  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8226,"result":["roboroommap%2F506345727%2F8"],"exe_time":10}
                                      2023-08-28 09:00:30.600  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                      2023-08-28 09:00:30.600  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                      2023-08-28 09:00:30.600  - debug: mihome-vacuum.0 (423131) update_Map need new mapurl
                                      2023-08-28 09:00:30.717  - debug: mihome-vacuum.0 (423131) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/roboroommap/506345727/8?Expires=1693207830000&GalaxyAccessKeyId=5271733786445&Signature=ZGY5Cnq76RNbHIY8hdQdlb0zR4I=
                                      2023-08-28 09:00:30.717  - debug: mihome-vacuum.0 (423131) update_Map got new expires:1693207830
                                      2023-08-28 09:00:30.717  - debug: mihome-vacuum.0 (423131) update_Map got new time:1693206030
                                      2023-08-28 09:00:33.442  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                      2023-08-28 09:00:33.443  - debug: mihome-vacuum.0 (423131) Message= {"id":8227,"method":"get_map_v1"}
                                      2023-08-28 09:00:33.545  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8227,"result":["roboroommap%2F506345727%2F10"],"exe_time":11}
                                      2023-08-28 09:00:33.546  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8227,"result":["roboroommap%2F506345727%2F10"],"exe_time":11}
                                      2023-08-28 09:00:33.546  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                      2023-08-28 09:00:33.546  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                      2023-08-28 09:00:33.546  - debug: mihome-vacuum.0 (423131) update_Map need new mapurl
                                      2023-08-28 09:00:33.630  - debug: mihome-vacuum.0 (423131) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/roboroommap/506345727/10?Expires=1693207833000&GalaxyAccessKeyId=5271733786445&Signature=dhUFsYdzCf9Zt0xxtRwhJjqd0SA=
                                      2023-08-28 09:00:33.631  - debug: mihome-vacuum.0 (423131) update_Map got new expires:1693207833
                                      2023-08-28 09:00:33.631  - debug: mihome-vacuum.0 (423131) update_Map got new time:1693206033
                                      2023-08-28 09:00:36.650  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                      2023-08-28 09:00:36.650  - debug: mihome-vacuum.0 (423131) Message= {"id":8228,"method":"get_map_v1"}
                                      2023-08-28 09:00:36.673  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8228,"result":["roboroommap%2F506345727%2F12"],"exe_time":11}
                                      2023-08-28 09:00:36.674  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8228,"result":["roboroommap%2F506345727%2F12"],"exe_time":11}
                                      2023-08-28 09:00:36.674  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                      2023-08-28 09:00:36.674  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                      2023-08-28 09:00:36.674  - debug: mihome-vacuum.0 (423131) update_Map need new mapurl
                                      2023-08-28 09:00:36.805  - debug: mihome-vacuum.0 (423131) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/roboroommap/506345727/12?Expires=1693207836000&GalaxyAccessKeyId=5271733786445&Signature=3EFggdygm+i7RDYgnkFon0gHpQY=
                                      2023-08-28 09:00:36.806  - debug: mihome-vacuum.0 (423131) update_Map got new expires:1693207836
                                      2023-08-28 09:00:36.806  - debug: mihome-vacuum.0 (423131) update_Map got new time:1693206036
                                      2023-08-28 09:00:38.546  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000f02ffffffffffffffffffffffffffffffff
                                      2023-08-28 09:00:38.546  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 09:00:39.565  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                      2023-08-28 09:00:39.566  - debug: mihome-vacuum.0 (423131) Message= {"id":8229,"method":"get_map_v1"}
                                      2023-08-28 09:00:39.690  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8229,"result":["roboroommap%2F506345727%2F14"],"exe_time":11}
                                      2023-08-28 09:00:39.691  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8229,"result":["roboroommap%2F506345727%2F14"],"exe_time":11}
                                      2023-08-28 09:00:39.691  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                      2023-08-28 09:00:39.691  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                      2023-08-28 09:00:39.691  - debug: mihome-vacuum.0 (423131) update_Map need new mapurl
                                      2023-08-28 09:00:39.777  - debug: mihome-vacuum.0 (423131) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/roboroommap/506345727/14?Expires=1693207839000&GalaxyAccessKeyId=5271733786445&Signature=OdBkavCXy0SiynqlPKd4IX1zBwk=
                                      2023-08-28 09:00:39.777  - debug: mihome-vacuum.0 (423131) update_Map got new expires:1693207839
                                      2023-08-28 09:00:39.778  - debug: mihome-vacuum.0 (423131) update_Map got new time:1693206039
                                      2023-08-28 09:00:42.774  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                      2023-08-28 09:00:42.775  - debug: mihome-vacuum.0 (423131) Message= {"id":8230,"method":"get_map_v1"}
                                      2023-08-28 09:00:42.793  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8230,"result":["roboroommap%2F506345727%2F16"],"exe_time":11}
                                      2023-08-28 09:00:42.794  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8230,"result":["roboroommap%2F506345727%2F16"],"exe_time":11}
                                      2023-08-28 09:00:42.794  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                      2023-08-28 09:00:42.794  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                      2023-08-28 09:00:42.794  - debug: mihome-vacuum.0 (423131) update_Map need new mapurl
                                      2023-08-28 09:00:42.924  - debug: mihome-vacuum.0 (423131) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/roboroommap/506345727/16?Expires=1693207842000&GalaxyAccessKeyId=5271733786445&Signature=DU1SAYmiSk/b3zv5hl4s9rg2yIc=
                                      2023-08-28 09:00:42.924  - debug: mihome-vacuum.0 (423131) update_Map got new expires:1693207842
                                      2023-08-28 09:00:42.924  - debug: mihome-vacuum.0 (423131) update_Map got new time:1693206042
                                      2023-08-28 09:00:44.728  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                      2023-08-28 09:00:44.729  - debug: mihome-vacuum.0 (423131) Message= {"id":8231,"method":"get_status"}
                                      2023-08-28 09:00:44.752  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8231,"result":[{"msg_ver":2,"msg_seq":1027,"state":17,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":200,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 09:00:44.753  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8231,"result":[{"msg_ver":2,"msg_seq":1027,"state":17,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":2,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":200,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                      2023-08-28 09:00:44.753  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":1027,"state":17,"battery":53,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":200,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                      2023-08-28 09:00:44.753  - debug: mihome-vacuum.0 (423131) Message= {"id":8232,"method":"get_network_info"}
                                      2023-08-28 09:00:44.804  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8232,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-51},"exe_time":41}
                                      2023-08-28 09:00:44.804  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8232,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-51},"exe_time":41}
                                      2023-08-28 09:00:44.883  - debug: mihome-vacuum.0 (423131) Message= {"id":8233,"method":"get_sound_volume"}
                                      2023-08-28 09:00:44.905  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8233,"result":[90],"exe_time":11}
                                      2023-08-28 09:00:44.906  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8233,"result":[90],"exe_time":11}
                                      2023-08-28 09:00:44.906  - debug: mihome-vacuum.0 (423131) Message= {"id":8234,"method":"get_carpet_mode"}
                                      2023-08-28 09:00:44.929  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8234,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 09:00:44.930  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8234,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                      2023-08-28 09:00:45.646  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                      2023-08-28 09:00:45.646  - debug: mihome-vacuum.0 (423131) Message= {"id":8235,"method":"get_map_v1"}
                                      2023-08-28 09:00:45.726  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8235,"result":["roboroommap%2F506345727%2F17"],"exe_time":11}
                                      2023-08-28 09:00:45.726  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8235,"result":["roboroommap%2F506345727%2F17"],"exe_time":11}
                                      2023-08-28 09:00:45.726  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                      2023-08-28 09:00:45.727  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                      2023-08-28 09:00:45.727  - debug: mihome-vacuum.0 (423131) update_Map need new mapurl
                                      2023-08-28 09:00:45.836  - debug: mihome-vacuum.0 (423131) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/roboroommap/506345727/17?Expires=1693207845000&GalaxyAccessKeyId=5271733786445&Signature=aCRwWpEdEPMb+FqFZPzu4NGcow4=
                                      2023-08-28 09:00:45.836  - debug: mihome-vacuum.0 (423131) update_Map got new expires:1693207845
                                      2023-08-28 09:00:45.836  - debug: mihome-vacuum.0 (423131) update_Map got new time:1693206045
                                      2023-08-28 09:00:48.551  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000f0cffffffffffffffffffffffffffffffff
                                      2023-08-28 09:00:48.551  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                      2023-08-28 09:00:48.866  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                      2023-08-28 09:00:48.866  - debug: mihome-vacuum.0 (423131) Message= {"id":8236,"method":"get_map_v1"}
                                      2023-08-28 09:00:48.884  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8236,"result":["roboroommap%2F506345727%2F1"],"exe_time":11}
                                      2023-08-28 09:00:48.885  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8236,"result":["roboroommap%2F506345727%2F1"],"exe_time":11}
                                      2023-08-28 09:00:48.885  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                      2023-08-28 09:00:48.885  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                      2023-08-28 09:00:48.885  - debug: mihome-vacuum.0 (423131) update_Map need new mapurl
                                      2023-08-28 09:00:48.973  - debug: mihome-vacuum.0 (423131) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/roboroommap/506345727/1?Expires=1693207848000&GalaxyAccessKeyId=5271733786445&Signature=v8UbpK0VE9Lw441oyzGfUwxDz0k=
                                      2023-08-28 09:00:48.974  - debug: mihome-vacuum.0 (423131) update_Map got new expires:1693207848
                                      2023-08-28 09:00:48.974  - debug: mihome-vacuum.0 (423131) update_Map got new time:1693206048
                                      2023-08-28 09:00:51.709  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                      2023-08-28 09:00:51.709  - debug: mihome-vacuum.0 (423131) Message= {"id":8237,"method":"get_map_v1"}
                                      2023-08-28 09:00:51.762  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8237,"result":["roboroommap%2F506345727%2F3"],"exe_time":11}
                                      2023-08-28 09:00:51.762  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8237,"result":["roboroommap%2F506345727%2F3"],"exe_time":11}
                                      2023-08-28 09:00:51.763  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                      2023-08-28 09:00:51.763  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                      2023-08-28 09:00:51.763  - debug: mihome-vacuum.0 (423131) update_Map need new mapurl
                                      2023-08-28 09:00:51.874  - debug: mihome-vacuum.0 (423131) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/roboroommap/506345727/3?Expires=1693207851000&GalaxyAccessKeyId=5271733786445&Signature=UM05fxTZ2stIk05alzTrGSnuWag=
                                      2023-08-28 09:00:51.875  - debug: mihome-vacuum.0 (423131) update_Map got new expires:1693207851
                                      2023-08-28 09:00:51.875  - debug: mihome-vacuum.0 (423131) update_Map got new time:1693206051
                                      2023-08-28 09:00:54.847  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                      2023-08-28 09:00:54.847  - debug: mihome-vacuum.0 (423131) Message= {"id":8238,"method":"get_map_v1"}
                                      2023-08-28 09:00:54.865  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8238,"result":["roboroommap%2F506345727%2F5"],"exe_time":11}
                                      2023-08-28 09:00:54.865  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8238,"result":["roboroommap%2F506345727%2F5"],"exe_time":11}
                                      2023-08-28 09:00:54.865  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                      2023-08-28 09:00:54.865  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                      2023-08-28 09:00:54.865  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                      2023-08-28 09:00:57.575  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                      2023-08-28 09:00:57.576  - debug: mihome-vacuum.0 (423131) Message= {"id":8239,"method":"get_map_v1"}
                                      2023-08-28 09:00:57.696  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":8239,"result":["roboroommap%2F506345727%2F6"],"exe_time":11}
                                      2023-08-28 09:00:57.697  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":8239,"result":["roboroommap%2F506345727%2F6"],"exe_time":11}
                                      2023-08-28 09:00:57.697  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                      2023-08-28 09:00:57.697  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                      2023-08-28 09:00:57.697  - debug: mihome-vacuum.0 (423131) update_Map need new mapurl
                                      2023-08-28 09:00:57.813  - debug: mihome-vacuum.0 (423131) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/roboroommap/506345727/6?Expires=1693207857000&GalaxyAccessKeyId=5271733786445&Signature=8bh8cwBvyVF9ML9vd9Mg+Oyqz1Y=
                                      2023-08-28 09:00:57.814  - debug: mihome-vacuum.0 (423131) update_Map got new expires:1693207857
                                      2023-08-28 09:00:57.814  - debug: mihome-vacuum.0 (423131) update_Map got new time:1693206057
                                      2023-08-28 09:00:58.555  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00000f16ffffffffffffffffffffffffffffffff
                                      2023-08-28 09:00:58.555  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                        MP_Trixi @MP_Trixi last edited by
                                        @dirkhe
                                        Log 3:
                                        2023-08-28 09:28:45.507  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff00001599ffffffffffffffffffffffffffffffff
                                        2023-08-28 09:28:45.507  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                        2023-08-28 09:28:46.874  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                        2023-08-28 09:28:46.875  - debug: mihome-vacuum.0 (423131) Message= {"id":9061,"method":"get_map_v1"}
                                        2023-08-28 09:28:46.954  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9061,"result":["roboroommap%2F506345727%2F17"],"exe_time":11}
                                        2023-08-28 09:28:46.955  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9061,"result":["roboroommap%2F506345727%2F17"],"exe_time":11}
                                        2023-08-28 09:28:46.955  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                        2023-08-28 09:28:46.955  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                        2023-08-28 09:28:46.955  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                        2023-08-28 09:28:49.963  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                        2023-08-28 09:28:49.964  - debug: mihome-vacuum.0 (423131) Message= {"id":9062,"method":"get_map_v1"}
                                        2023-08-28 09:28:50.025  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9062,"result":["roboroommap%2F506345727%2F0"],"exe_time":11}
                                        2023-08-28 09:28:50.026  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9062,"result":["roboroommap%2F506345727%2F0"],"exe_time":11}
                                        2023-08-28 09:28:50.027  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                        2023-08-28 09:28:50.027  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                        2023-08-28 09:28:50.027  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                        2023-08-28 09:28:53.152  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                        2023-08-28 09:28:53.152  - debug: mihome-vacuum.0 (423131) Message= {"id":9063,"method":"get_map_v1"}
                                        2023-08-28 09:28:53.216  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9063,"result":["roboroommap%2F506345727%2F1"],"exe_time":22}
                                        2023-08-28 09:28:53.216  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9063,"result":["roboroommap%2F506345727%2F1"],"exe_time":22}
                                        2023-08-28 09:28:53.217  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                        2023-08-28 09:28:53.217  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                        2023-08-28 09:28:53.217  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                        2023-08-28 09:28:55.512  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff000015a3ffffffffffffffffffffffffffffffff
                                        2023-08-28 09:28:55.512  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                        2023-08-28 09:28:55.994  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                        2023-08-28 09:28:55.994  - debug: mihome-vacuum.0 (423131) Message= {"id":9064,"method":"get_map_v1"}
                                        2023-08-28 09:28:56.069  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9064,"result":["roboroommap%2F506345727%2F2"],"exe_time":10}
                                        2023-08-28 09:28:56.070  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9064,"result":["roboroommap%2F506345727%2F2"],"exe_time":10}
                                        2023-08-28 09:28:56.070  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                        2023-08-28 09:28:56.070  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                        2023-08-28 09:28:56.070  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                        2023-08-28 09:28:59.385  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                        2023-08-28 09:28:59.386  - debug: mihome-vacuum.0 (423131) Message= {"id":9065,"method":"get_map_v1"}
                                        2023-08-28 09:28:59.411  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9065,"result":["roboroommap%2F506345727%2F3"],"exe_time":11}
                                        2023-08-28 09:28:59.411  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9065,"result":["roboroommap%2F506345727%2F3"],"exe_time":11}
                                        2023-08-28 09:28:59.411  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                        2023-08-28 09:28:59.411  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                        2023-08-28 09:28:59.412  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                        2023-08-28 09:29:02.178  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                        2023-08-28 09:29:02.179  - debug: mihome-vacuum.0 (423131) Message= {"id":9066,"method":"get_map_v1"}
                                        2023-08-28 09:29:02.198  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9066,"result":["roboroommap%2F506345727%2F4"],"exe_time":11}
                                        2023-08-28 09:29:02.198  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9066,"result":["roboroommap%2F506345727%2F4"],"exe_time":11}
                                        2023-08-28 09:29:02.198  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                        2023-08-28 09:29:02.199  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                        2023-08-28 09:29:02.199  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                        2023-08-28 09:29:03.556  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                        2023-08-28 09:29:03.556  - debug: mihome-vacuum.0 (423131) Message= {"id":9067,"method":"get_status"}
                                        2023-08-28 09:29:03.574  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9067,"result":[{"msg_ver":2,"msg_seq":1137,"state":22,"battery":32,"clean_time":1680,"clean_area":18872500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":10}
                                        2023-08-28 09:29:03.574  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9067,"result":[{"msg_ver":2,"msg_seq":1137,"state":22,"battery":32,"clean_time":1680,"clean_area":18872500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":10}
                                        2023-08-28 09:29:03.575  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":1137,"state":22,"battery":32,"clean_time":1680,"clean_area":18872500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                        2023-08-28 09:29:03.575  - debug: mihome-vacuum.0 (423131) Message= {"id":9068,"method":"get_network_info"}
                                        2023-08-28 09:29:03.623  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9068,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-63},"exe_time":41}
                                        2023-08-28 09:29:03.624  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9068,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-63},"exe_time":41}
                                        2023-08-28 09:29:03.812  - debug: mihome-vacuum.0 (423131) Message= {"id":9069,"method":"get_sound_volume"}
                                        2023-08-28 09:29:03.826  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9069,"result":[90],"exe_time":11}
                                        2023-08-28 09:29:03.827  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9069,"result":[90],"exe_time":11}
                                        2023-08-28 09:29:03.827  - debug: mihome-vacuum.0 (423131) Message= {"id":9070,"method":"get_carpet_mode"}
                                        2023-08-28 09:29:03.847  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9070,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                        2023-08-28 09:29:03.847  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9070,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                        2023-08-28 09:29:05.347  - debug: mihome-vacuum.0 (423131) Get Mappointer while cleaning
                                        2023-08-28 09:29:05.348  - debug: mihome-vacuum.0 (423131) Message= {"id":9071,"method":"get_map_v1"}
                                        2023-08-28 09:29:05.488  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9071,"result":["roboroommap%2F506345727%2F5"],"exe_time":11}
                                        2023-08-28 09:29:05.488  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9071,"result":["roboroommap%2F506345727%2F5"],"exe_time":11}
                                        2023-08-28 09:29:05.489  - debug: mihome-vacuum.0 (423131) Mappointer_updated
                                        2023-08-28 09:29:05.489  - debug: mihome-vacuum.0 (423131) update_Map Mimap enabled
                                        2023-08-28 09:29:05.489  - debug: mihome-vacuum.0 (423131) update_Map use old mapurl
                                        2023-08-28 09:29:05.515  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff000015adffffffffffffffffffffffffffffffff
                                        2023-08-28 09:29:05.516  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                        2023-08-28 09:29:15.593  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff000015b7ffffffffffffffffffffffffffffffff
                                        2023-08-28 09:29:15.594  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                        2023-08-28 09:29:23.956  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                        2023-08-28 09:29:23.957  - debug: mihome-vacuum.0 (423131) Message= {"id":9072,"method":"get_status"}
                                        2023-08-28 09:29:23.999  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9072,"result":[{"msg_ver":2,"msg_seq":1138,"state":22,"battery":32,"clean_time":1680,"clean_area":18872500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                        2023-08-28 09:29:23.999  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9072,"result":[{"msg_ver":2,"msg_seq":1138,"state":22,"battery":32,"clean_time":1680,"clean_area":18872500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                        2023-08-28 09:29:24.000  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":1138,"state":22,"battery":32,"clean_time":1680,"clean_area":18872500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                        2023-08-28 09:29:24.000  - debug: mihome-vacuum.0 (423131) Message= {"id":9073,"method":"get_network_info"}
                                        2023-08-28 09:29:24.073  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9073,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-61},"exe_time":63}
                                        2023-08-28 09:29:24.074  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9073,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-61},"exe_time":63}
                                        2023-08-28 09:29:24.175  - debug: mihome-vacuum.0 (423131) Message= {"id":9074,"method":"get_sound_volume"}
                                        2023-08-28 09:29:24.195  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9074,"result":[90],"exe_time":11}
                                        2023-08-28 09:29:24.195  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9074,"result":[90],"exe_time":11}
                                        2023-08-28 09:29:24.195  - debug: mihome-vacuum.0 (423131) Message= {"id":9075,"method":"get_carpet_mode"}
                                        2023-08-28 09:29:24.216  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9075,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                        2023-08-28 09:29:24.216  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9075,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":11}
                                        2023-08-28 09:29:25.622  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff000015c1ffffffffffffffffffffffffffffffff
                                        2023-08-28 09:29:25.622  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                        2023-08-28 09:29:35.651  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff000015cbffffffffffffffffffffffffffffffff
                                        2023-08-28 09:29:35.651  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                        2023-08-28 09:29:44.313  - debug: mihome-vacuum.0 (423131) get params for stock Vacuum
                                        2023-08-28 09:29:44.313  - debug: mihome-vacuum.0 (423131) Message= {"id":9076,"method":"get_status"}
                                        2023-08-28 09:29:44.366  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9076,"result":[{"msg_ver":2,"msg_seq":1145,"state":8,"battery":32,"clean_time":1680,"clean_area":18872500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                        2023-08-28 09:29:44.367  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9076,"result":[{"msg_ver":2,"msg_seq":1145,"state":8,"battery":32,"clean_time":1680,"clean_area":18872500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}],"exe_time":11}
                                        2023-08-28 09:29:44.367  - debug: mihome-vacuum.0 (423131) setGetStatus {"msg_ver":2,"msg_seq":1145,"state":8,"battery":32,"clean_time":1680,"clean_area":18872500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                        2023-08-28 09:29:44.368  - debug: mihome-vacuum.0 (423131) Message= {"id":9077,"method":"get_consumable"}
                                        2023-08-28 09:29:44.368  - debug: mihome-vacuum.0 (423131) Message= {"id":9078,"method":"get_network_info"}
                                        2023-08-28 09:29:44.386  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9077,"result":[{"main_brush_work_time":595173,"side_brush_work_time":595173,"filter_work_time":31575,"filter_element_work_time":0,"sensor_dirty_time":132646,"strainer_work_times":56,"dust_collection_work_times":178,"cleaning_brush_work_times":209}],"exe_time":11}
                                        2023-08-28 09:29:44.387  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9077,"result":[{"main_brush_work_time":595173,"side_brush_work_time":595173,"filter_work_time":31575,"filter_element_work_time":0,"sensor_dirty_time":132646,"strainer_work_times":56,"dust_collection_work_times":178,"cleaning_brush_work_times":209}],"exe_time":11}
                                        2023-08-28 09:29:44.388  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9077,"result":[{"main_brush_work_time":595173,"side_brush_work_time":595173,"filter_work_time":31575,"filter_element_work_time":0,"sensor_dirty_time":132646,"strainer_work_times":56,"dust_collection_work_times":178,"cleaning_brush_work_times":209}],"exe_time":11}
                                        2023-08-28 09:29:44.388  - debug: mihome-vacuum.0 (423131) Message= {"id":9079,"method":"get_clean_summary"}
                                        2023-08-28 09:29:44.438  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9078,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-61},"exe_time":52}
                                        2023-08-28 09:29:44.439  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9078,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-61},"exe_time":52}
                                        2023-08-28 09:29:44.440  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9078,"result":{"ssid":"WLANssid","ip":"192.168.1.147","mac":"00:00:00:00:00:00","bssid":"00:00:00:00:00:00","rssi":-61},"exe_time":52}
                                        2023-08-28 09:29:44.472  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9079,"result":{"clean_time":595173,"clean_area":8196832500,"clean_count":363,"dust_collection_count":178,"records":[1693205756,1693202104,1692950915,1692950767,1692950582,1692945945,1692942904,1692773574,1692770103,1692604208,1692601508,1692597302,1690528276,1690523703,1690355990,1690350903,1690180984,1690178104,1689922090,1689918903]},"exe_time":72}
                                        2023-08-28 09:29:44.473  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9079,"result":{"clean_time":595173,"clean_area":8196832500,"clean_count":363,"dust_collection_count":178,"records":[1693205756,1693202104,1692950915,1692950767,1692950582,1692945945,1692942904,1692773574,1692770103,1692604208,1692601508,1692597302,1690528276,1690523703,1690355990,1690350903,1690180984,1690178104,1689922090,1689918903]},"exe_time":72}
                                        2023-08-28 09:29:44.474  - debug: mihome-vacuum.0 (423131) Message= {"id":9080,"method":"get_clean_record","params":[1693205756]}
                                        2023-08-28 09:29:44.491  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9080,"result":[{"begin":1693205756,"end":1693207694,"duration":1680,"area":18872500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":1}],"exe_time":10}
                                        2023-08-28 09:29:44.492  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9080,"result":[{"begin":1693205756,"end":1693207694,"duration":1680,"area":18872500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":1}],"exe_time":10}
                                        2023-08-28 09:29:44.492  - debug: mihome-vacuum.0 (423131) Message= {"id":9081,"method":"get_clean_record","params":[1693202104]}
                                        2023-08-28 09:29:44.513  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9081,"result":[{"begin":1693202104,"end":1693205737,"duration":3607,"area":48782500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.514  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9081,"result":[{"begin":1693202104,"end":1693205737,"duration":3607,"area":48782500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.515  - debug: mihome-vacuum.0 (423131) Message= {"id":9082,"method":"get_clean_record","params":[1692950915]}
                                        2023-08-28 09:29:44.533  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9082,"result":[{"begin":1692950915,"end":1692951224,"duration":121,"area":2860000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":1}],"exe_time":10}
                                        2023-08-28 09:29:44.533  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9082,"result":[{"begin":1692950915,"end":1692951224,"duration":121,"area":2860000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":1}],"exe_time":10}
                                        2023-08-28 09:29:44.533  - debug: mihome-vacuum.0 (423131) Message= {"id":9083,"method":"get_clean_record","params":[1692950767]}
                                        2023-08-28 09:29:44.554  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9083,"result":[{"begin":1692950767,"end":1692950822,"duration":55,"area":967500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.556  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9083,"result":[{"begin":1692950767,"end":1692950822,"duration":55,"area":967500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.556  - debug: mihome-vacuum.0 (423131) Message= {"id":9084,"method":"get_clean_record","params":[1692950582]}
                                        2023-08-28 09:29:44.575  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9084,"result":[{"begin":1692950582,"end":1692950705,"duration":123,"area":4185000,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.575  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9084,"result":[{"begin":1692950582,"end":1692950705,"duration":123,"area":4185000,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.576  - debug: mihome-vacuum.0 (423131) Message= {"id":9085,"method":"get_clean_record","params":[1692945945]}
                                        2023-08-28 09:29:44.578  - debug: mihome-vacuum.0 (423131) Message= {"id":9086,"method":"get_sound_volume"}
                                        2023-08-28 09:29:44.597  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9085,"result":[{"begin":1692945945,"end":1692947622,"duration":1677,"area":18767500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":0}],"exe_time":11}
                                        2023-08-28 09:29:44.598  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9085,"result":[{"begin":1692945945,"end":1692947622,"duration":1677,"area":18767500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":0}],"exe_time":11}
                                        2023-08-28 09:29:44.598  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9085,"result":[{"begin":1692945945,"end":1692947622,"duration":1677,"area":18767500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":0}],"exe_time":11}
                                        2023-08-28 09:29:44.598  - debug: mihome-vacuum.0 (423131) Message= {"id":9087,"method":"get_clean_record","params":[1692942904]}
                                        2023-08-28 09:29:44.607  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9086,"result":[90],"exe_time":10}
                                        2023-08-28 09:29:44.608  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9086,"result":[90],"exe_time":10}
                                        2023-08-28 09:29:44.609  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9086,"result":[90],"exe_time":10}
                                        2023-08-28 09:29:44.611  - debug: mihome-vacuum.0 (423131) Message= {"id":9088,"method":"get_carpet_mode"}
                                        2023-08-28 09:29:44.619  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9087,"result":[{"begin":1692942904,"end":1692945923,"duration":3019,"area":46677500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.620  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9087,"result":[{"begin":1692942904,"end":1692945923,"duration":3019,"area":46677500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.621  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9087,"result":[{"begin":1692942904,"end":1692945923,"duration":3019,"area":46677500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.622  - debug: mihome-vacuum.0 (423131) Message= {"id":9089,"method":"get_clean_record","params":[1692773574]}
                                        2023-08-28 09:29:44.630  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9088,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":10}
                                        2023-08-28 09:29:44.630  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9088,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":10}
                                        2023-08-28 09:29:44.631  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9088,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":10}
                                        2023-08-28 09:29:44.642  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9089,"result":[{"begin":1692773574,"end":1692775835,"duration":2261,"area":19047500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":1}],"exe_time":11}
                                        2023-08-28 09:29:44.644  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9089,"result":[{"begin":1692773574,"end":1692775835,"duration":2261,"area":19047500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":1}],"exe_time":11}
                                        2023-08-28 09:29:44.644  - debug: mihome-vacuum.0 (423131) Message= {"id":9090,"method":"get_clean_record","params":[1692770103]}
                                        2023-08-28 09:29:44.660  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9090,"result":[{"begin":1692770103,"end":1692773571,"duration":3335,"area":49477500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":1}],"exe_time":11}
                                        2023-08-28 09:29:44.661  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9090,"result":[{"begin":1692770103,"end":1692773571,"duration":3335,"area":49477500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":1}],"exe_time":11}
                                        2023-08-28 09:29:44.662  - debug: mihome-vacuum.0 (423131) Message= {"id":9091,"method":"get_clean_record","params":[1692604208]}
                                        2023-08-28 09:29:44.681  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9091,"result":[{"begin":1692604208,"end":1692616145,"duration":3334,"area":47622500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.682  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9091,"result":[{"begin":1692604208,"end":1692616145,"duration":3334,"area":47622500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.683  - debug: mihome-vacuum.0 (423131) Message= {"id":9092,"method":"get_clean_record","params":[1692601508]}
                                        2023-08-28 09:29:44.704  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9092,"result":[{"begin":1692601508,"end":1692603386,"duration":1878,"area":18755000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":1}],"exe_time":10}
                                        2023-08-28 09:29:44.705  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9092,"result":[{"begin":1692601508,"end":1692603386,"duration":1878,"area":18755000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":1}],"exe_time":10}
                                        2023-08-28 09:29:44.706  - debug: mihome-vacuum.0 (423131) Message= {"id":9093,"method":"get_clean_record","params":[1692597302]}
                                        2023-08-28 09:29:44.732  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9093,"result":[{"begin":1692597302,"end":1692601497,"duration":4195,"area":48797500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.732  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9093,"result":[{"begin":1692597302,"end":1692601497,"duration":4195,"area":48797500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.733  - debug: mihome-vacuum.0 (423131) Message= {"id":9094,"method":"get_clean_record","params":[1690528276]}
                                        2023-08-28 09:29:44.755  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9094,"result":[{"begin":1690528276,"end":1690554691,"duration":1740,"area":19067500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":2}],"exe_time":11}
                                        2023-08-28 09:29:44.756  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9094,"result":[{"begin":1690528276,"end":1690554691,"duration":1740,"area":19067500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":2}],"exe_time":11}
                                        2023-08-28 09:29:44.756  - debug: mihome-vacuum.0 (423131) Message= {"id":9095,"method":"get_clean_record","params":[1690523703]}
                                        2023-08-28 09:29:44.779  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9095,"result":[{"begin":1690523703,"end":1690528253,"duration":4550,"area":49055000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":0}],"exe_time":11}
                                        2023-08-28 09:29:44.780  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9095,"result":[{"begin":1690523703,"end":1690528253,"duration":4550,"area":49055000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":0}],"exe_time":11}
                                        2023-08-28 09:29:44.781  - debug: mihome-vacuum.0 (423131) Message= {"id":9096,"method":"get_clean_record","params":[1690355990]}
                                        2023-08-28 09:29:44.797  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9096,"result":[{"begin":1690355990,"end":1690358245,"duration":2255,"area":18617500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":1}],"exe_time":11}
                                        2023-08-28 09:29:44.799  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9096,"result":[{"begin":1690355990,"end":1690358245,"duration":2255,"area":18617500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":1}],"exe_time":11}
                                        2023-08-28 09:29:44.800  - debug: mihome-vacuum.0 (423131) Message= {"id":9097,"method":"get_clean_record","params":[1690350903]}
                                        2023-08-28 09:29:44.818  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9097,"result":[{"begin":1690350903,"end":1690355727,"duration":4135,"area":48472500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":4}],"exe_time":11}
                                        2023-08-28 09:29:44.819  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9097,"result":[{"begin":1690350903,"end":1690355727,"duration":4135,"area":48472500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":4}],"exe_time":11}
                                        2023-08-28 09:29:44.820  - debug: mihome-vacuum.0 (423131) Message= {"id":9098,"method":"get_clean_record","params":[1690180984]}
                                        2023-08-28 09:29:44.840  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9098,"result":[{"begin":1690180984,"end":1690183336,"duration":2057,"area":19040000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":2}],"exe_time":10}
                                        2023-08-28 09:29:44.840  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9098,"result":[{"begin":1690180984,"end":1690183336,"duration":2057,"area":19040000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"wash_count":2}],"exe_time":10}
                                        2023-08-28 09:29:44.841  - debug: mihome-vacuum.0 (423131) Message= {"id":9099,"method":"get_clean_record","params":[1690178104]}
                                        2023-08-28 09:29:44.861  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9099,"result":[{"begin":1690178104,"end":1690180973,"duration":2869,"area":48310000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.862  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9099,"result":[{"begin":1690178104,"end":1690180973,"duration":2869,"area":48310000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.862  - debug: mihome-vacuum.0 (423131) Message= {"id":9100,"method":"get_clean_record","params":[1689922090]}
                                        2023-08-28 09:29:44.882  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9100,"result":[{"begin":1689922090,"end":1689966177,"duration":287,"area":5245000,"error":5,"complete":0,"start_type":2,"clean_type":2,"finish_reason":34,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.883  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9100,"result":[{"begin":1689922090,"end":1689966177,"duration":287,"area":5245000,"error":5,"complete":0,"start_type":2,"clean_type":2,"finish_reason":34,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.883  - debug: mihome-vacuum.0 (423131) Message= {"id":9101,"method":"get_clean_record","params":[1689918903]}
                                        2023-08-28 09:29:44.904  - debug: mihome-vacuum.0 (423131) MIIO MESSAGE TESTING: {"id":9101,"result":[{"begin":1689918903,"end":1689922079,"duration":3176,"area":48787500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.905  - debug: mihome-vacuum.0 (423131) MIIO RECIVE: {"id":9101,"result":[{"begin":1689918903,"end":1689922079,"duration":3176,"area":48787500,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":0,"wash_count":0}],"exe_time":10}
                                        2023-08-28 09:29:44.905  - debug: mihome-vacuum.0 (423131) finish logs all [{"Datum":"28.8","Start":"08:55","Saugzeit":"28 min","Fläche":"18.87 m²","Error":0,"Ende":true},{"Datum":"28.8","Start":"07:55","Saugzeit":"60 min","Fläche":"48.78 m²","Error":0,"Ende":true},{"Datum":"25.8","Start":"10:08","Saugzeit":"2 min","Fläche":"2.86 m²","Error":0,"Ende":false},{"Datum":"25.8","Start":"10:06","Saugzeit":"1 min","Fläche":"0.97 m²","Error":0,"Ende":false},{"Datum":"25.8","Start":"10:03","Saugzeit":"2 min","Fläche":"4.19 m²","Error":0,"Ende":false},{"Datum":"25.8","Start":"08:45","Saugzeit":"28 min","Fläche":"18.77 m²","Error":0,"Ende":true},{"Datum":"25.8","Start":"07:55","Saugzeit":"50 min","Fläche":"46.68 m²","Error":0,"Ende":true},{"Datum":"23.8","Start":"08:52","Saugzeit":"38 min","Fläche":"19.05 m²","Error":0,"Ende":true},{"Datum":"23.8","Start":"07:55","Saugzeit":"56 min","Fläche":"49.48 m²","Error":0,"Ende":true},{"Datum":"21.8","Start":"09:50","Saugzeit":"56 min","Fläche":"47.62 m²","Error":0,"Ende":true},{"Datum":"21.8","Start":"09:05","Saugzeit":"31 min","Fläche":"18.76 m²","Error":0,"Ende":true},{"Datum":"21.8","Start":"07:55","Saugzeit":"70 min","Fläche":"48.8 m²","Error":0,"Ende":true},{"Datum":"28.7","Start":"09:11","Saugzeit":"29 min","Fläche":"19.07 m²","Error":0,"Ende":true},{"Datum":"28.7","Start":"07:55","Saugzeit":"76 min","Fläche":"49.06 m²","Error":0,"Ende":true},{"Datum":"26.7","Start":"09:19","Saugzeit":"38 min","Fläche":"18.62 m²","Error":0,"Ende":true},{"Datum":"26.7","Start":"07:55","Saugzeit":"69 min","Fläche":"48.47 m²","Error":0,"Ende":true},{"Datum":"24.7","Start":"08:43","Saugzeit":"34 min","Fläche":"19.04 m²","Error":0,"Ende":true},{"Datum":"24.7","Start":"07:55","Saugzeit":"48 min","Fläche":"48.31 m²","Error":0,"Ende":true},{"Datum":"21.7","Start":"08:48","Saugzeit":"5 min","Fläche":"5.25 m²","Error":5,"Ende":false},{"Datum":"21.7","Start":"07:55","Saugzeit":"53 min","Fläche":"48.79 m²","Error":0,"Ende":true}]
                                        2023-08-28 09:29:45.680  - debug: mihome-vacuum.0 (423131) Receive <<< Helo <<< 21310020000000001e2e38ff000015d5ffffffffffffffffffffffffffffffff
                                        2023-08-28 09:29:45.681  - debug: mihome-vacuum.0 (423131) Time difference between Mihome Vacuum and ioBroker: -1693202196 sec
                                          dirkhe Developer @MP_Trixi last edited by
                                          @mp_trixi du kannst das triggern, bis der Arzt kommt, du musst ein json übergeben und keinen string. Vlt. Hat sivh auch was im adapter oder blocky verändert, keine ahnung. Wenn du einen string übergibst, wird davon ausgegangen, dass es eine kommaseparierte liste von segmenten ist und kein json objekt, was in einen string geschrieben wird.
                                            MP_Trixi @dirkhe last edited by MP_Trixi
                                            @dirkhe
                                            Hi - ich hoffe ich verstehe es nicht falsch. Ich übergebe keinen String. Ich schreibe die Datenpunkte der einzelnen Zonen. Also jeweils z.B. in Suction Power 104 und Waterbox Mode 200. Dann starte ich die Zonenreinigung, in dem ich den entsprechenden Button triggere:
                                            wenn ich das "händisch" mache habe ich das gleiche Ergebnis
                                            adapter entwicklung raumreinigung roborock test vacuum zeitplan
                                            67
                                            511
                                            104679
