Zigbee zum verzweifeln * gelöst *
Hallo ich habe langsamm die Nase voll
ich brauch eure Hilfe ich nutzte seid 2 Jahren eine Conbee2 Stick oder falsch inzwischen warren ews schon 3 Stück die ich bestellt habe
Ständig sind Geäte Nicht ereichbar oder ich habe in meinen Logs fehler meldung
wer von euch welche geräte (Sticks ohne probleme laufen )
edit hiermal sie fehlermeldung
zigbee.0 2023-08-28 03:17:02.361 warn DeviceAvailability:Failed to ping 0x00178801089debfe LOM001 zigbee.0 2023-08-28 03:10:46.330 warn DeviceAvailability:Stopping to ping 0xbc33acfffec7fd3f TS011F after 8 ping attempts zigbee.0 2023-08-28 02:56:40.258 warn DeviceAvailability:Failed to ping 0x00178801089debfe LOM001 zigbee.0 2023-08-28 02:20:04.025 warn DeviceAvailability:Stopping to ping 0x00178801089debfe LOM001 after 7 ping attempts zigbee.0 2023-08-28 02:07:38.952 error Send command to 0xbc33acfffec7fd3f failed with no error code (no response received (253) zigbee.0 2023-08-28 02:02:24.909 error Send command to 0xbc33acfffec7fd3f failed with no error code (no response received (238) zigbee.0 2023-08-28 01:51:21.821 error Send command to 0xbc33acfffec7fd3f failed with no error code (no response received (230) zigbee.0 2023-08-28 00:48:59.429 error Send command to 0xbc33acfffec7fd3f failed with no error code (no response received (193) zigbee.0 2023-08-28 00:47:56.429 error Send command to 0xbc33acfffec7fd3f failed with no error code (no response received (189) zigbee.0 2023-08-28 00:47:56.423 error Send command to 0xbc33acfffec7fd3f failed with no error code (no response received (191) zigbee.0 2023-08-28 00:45:50.408 error Send command to 0xbc33acfffec7fd3f failed with no error code (no response received (185) zigbee.0 2023-08-28 00:43:45.363 error Send command to 0xbc33acfffec7fd3f failed with no error code (no response received (176) zigbee.0 2023-08-28 00:41:38.351 error Send command to 0xbc33acfffec7fd3f failed with no error code (no response received (170) zigbee.0 2023-08-28 00:31:38.305 error Send command to 0xbc33acfffec7fd3f failed with no error code (no response received (166) zigbee.0 2023-08-28 00:31:38.299 error Send command to 0xbc33acfffec7fd3f failed with no error code (no response received (168)
Einen von dieser Liste:
https://www.zigbee2mqtt.io/guide/adapters/
Hier im Forum gibt es im Marktplatz aber auch immer wieder Angebote, ich glaube @dimaiv hat da was im zu offerieren.
€dit: Vermutlich reicht es aber dein Netz enger zu weben.
@horst-böttcher
Die error Meldungen beziehen sich auf eine Philips Bulb und eine Tuya Steckdose soweit ich sehen konnte.
Scheint ein Reichweitenproblem zu sein. Aber das ist auf Grund der Datenlage nur eine Vermutung.Ich habe 3 Ikea Zigbee Repeater in meinem Haus und seitdem ist die Coverage mehr kein Problem.
Zwar sollten Zigbeegeräte ja selbst als repeater agieren, aber Kosten, kleinste Bauweise und nicht funkoptimiertes Design können den Usern zu schaffen machen.Einen Versuch ist es Wert. Falls der Conbee2 Stick direkt am Rechner hängt, reicht es eventuell ha ja schon den Stich an eine USB Verlängerungskabel zu hängen und ihn etwas besser zu positionieren.
@horst-böttcher seit ich vom Conbee auf Texas Board gewechselt bin , habe ich keine Probleme mehr
Ok ich muss mir das mal heute abend ansehen
@horst-böttcher du solltest den ConBee II (und auch jeden anderen ZigBee USB-Stick) mit einer Verlängerung betreiben.
30cm könnten schon reichen damit er weit genug von anderen USB-Ports, insbesondere USB3.0 Ports entfernt ist, die sollen das wohl ziemlich stören können.
Wobei - wenn man schon eine Verlängerung dazwischen steckt kann man den Stick auch gleich schöner positionieren. Ich habe an meinen ConBee II an einer 2m Verlängerung und es läuft ohne Probleme.Ein ZigBee Gateway über LAN-Netzwerk kann ich allerdings auch nur empfehlen, ich habe auch den hier im Markplatz von dimaiv gekauft.
Den betreibe ich parallel. Neue Geräte lerne ich gleich an dem an, die älteren ziehen immer dann um wenn es gerade passt. -
Der Problem wurde von einer 3stecldose von lidl ausgelöst was über tuya zigbee angeschossen war jetzt ist sie weg und das problem auch danke euch
Guten Abend,
Kannst du bitte kurz erklären wie du das Lan Gateway eingebunden hast und warum? Für eine bessere Abdeckung?
Gruss Duffy
@duffy sagte in Zigbee zum verzweifeln * gelöst *:
Moin,
ich bin zwar nicht @BananaJoe, aber ich glaube Dir ja schon in einem anderen Thread gesagt zu haben, dass Du durch Verwendung eines Zigbee-WLAN/LAN Stick, den Vorteil hast, dass Du frei entscheiden kannst, bei WLAN, bei LAN muss man eine Dose/Kabel haben, wo Du das Teil in der Wohnung platzierst.
Beispiel, Dein RasPI steht im Keller, dort hast DU WLAN, dann kannst Du den Stick trotzdem ins Treppenhaus hängen, damit er optimal mit dem Keller, EG und OG funken kann.Durch LAN/WLAN wird aber die Empfangsleistung nicht besser, einzig durch den besseren Standort.
Anbinden tust Du das so
Wurde aber auch alles im Video von @haus-automatisierung erklärt, auch wenn es da nicht um den Stick hier aus dem Forum geht, ist die Konfiguration, des
Zigbee - Adapters
gleich.
Hier geht es zum Forums Stick -> https://forum.iobroker.net/topic/48312/verkaufe-zigbee-lan-usb-wlan-gateway-cc2652pVG
BerndP.S.: zum
warum
kann ich natürlich nichts sagen -
@dp20eic
Hallo Bernd,
Ja ich weis wir hatten es schon mal davon. Mir ging es um das „wie“ einbinden aber das ist ja nun beantwortet.
Wenn die Lan Anbindung auch weiter keine Verbesserung bringt kann ich mir das ja erst mal schenken.Wenn hier aber geschrieben wird das der Conbee 2 weiter parallel läuft verstehe ich das so das ich doch auch ein EG und OG Netzwerk aufbauen könnte. Eins über Lan ins OG und das andere vom Pi aus über USB im EG.
Auf jeden Fall werden Zigbee und ich keine Freunde mehr
Moin,
sorry, was?
JaNein, Du kannst natürlich mehrerezigbee - Adapter
Instanzen anlegen und jedem einen eigenenZigBee - Stick
zuweisen, bei Verwendung über USB hast Du aber nichts gewonnen, bei WLAN ginge das, aber dann überschneiden sich die Netze und dann wissen vielleicht einige batteriebetriebene Geräte nicht, bei welchen Koordinator sie sich anmelden sollen/dürfen, hüpfen von einem zum anderen, was sich dann wieder in Fehlverhalten/Funktionsstörung niederschlägt.
EinZigbee Netzwerk
lebt von Routern, also von den Geräten, die ständig am Strom hängen, je mehr Du davon in der Wohnung verteilst, umso besser wird das Netzwerk, so nach ein paar Tagen, haben dann alle Geräte sich soweit als möglich die beste Route gesucht.
Für ein LAN/WLAN Zigbee-Stick bekommst Du 3-4 Zwischenstecker oder Leuchtmittel, nur vorher erkundigen, welche gut oder weniger gut sind.@duffy sagte in Zigbee zum verzweifeln * gelöst *:
Nicht das LAN/WLAN macht da den Unterschied, sondern die bessere Platzierung in der Wohnung, zentraler, sodass alle Geräte ungefähr alle den gleichen Abstand zum Koordinator haben.
VG
Bernd -
@dp20eic
Hallo Bernd,
meine alte Hütte hat Aussenmaße von 8,6 x 10 m.
Da sind im OG (Holzwände) 5 Geräte an Dauerstrom und im EG 7 incl. Coordinator. Carport 1 und Keller auch einer.
Trotzdem steigen andauernd die Sonoff Thermometer (im Haus) aus. Gerade im EG liegt eins 2 m vom Coordinator weg und sendet schon wieder 11 Stunden keine Signale mehr, trotz Temperaturänderung. Dabei lässt es sich das Thermometer aber nicht nehmen true zu sein und eine Signalsärke von 123 zu zeigen. Es nervt einfach nur.Werde die Sonoff evtl. austauschen und da wo es nicht geht weil man ein Display braucht/will einfach einen Aquara Sensor dahinter pappen. Die Aquara funktionieren.
Grundsätzlich, das man überhaupt auf Zigbee gesetzt hat wundert mich da es auf Wlan doch wohl recht empfindlich reagiert und Wlan doch sehr verbreitet ist.
Ist doch eigentlich zum scheitern verurteilt. Wie geht das in riesen Wohnblocks wenn es bei mir im Einzelhaus schon nicht gut geht.Nun ist jetzt halt so.
VG
Sooooo viele Frequenzen, die man ohne weiteres nutzen darf, gibt es nun auch nicht. Da knubbelt sich natürlich alles was zivil funkt.
Ist doch eigentlich zum scheitern verurteilt.Moin,
das sind aussagen, weil Du gefrustet bist, verstehe ich, aber
ZigBEe
ist erfunden worden, um auch Geräte mit Batterie zu betreiben, und nicht nur Geräte mit ständigem Stromanschluss, den WLAN brauch viel mehr Strom, selbst wenn man Geräte in einen absoluten Tiefschlaf bringen könnte, spätesten beim aufwachen und WLAN wieder anschalten und neu verbinden, braucht mehr alsZigBee
.Zu der Verteilung in Deinem Haus, bei mir sind es 16 Leuchtmittel auf zwei Etagen, 13 Aquara Tür/Fenster Sensoren, 5 Aquara Klimasensoren, 8 Aquara Taster, 2 Ikea Rollos, 2 Ikea Repeater/Verstärker, drei Ikea Bewegungsmelder, demnächst kommen noch 4 Klimasensoren für Gefrierschrank/Kühlschrank und die letzten Räume bekommen auch noch welch verpasst.
Zur Qualität der Sonoffs kann ich nicht viel sagen, habe keine, das schlechteste, was ich habe, ist Osram Leuchtmittel, die fliegen aber raus, sobald mal kaputt.
Solltest Du noch Garantie haben, zurückschicken, hat ja vielleicht 'ne Macke.VG
Bernd -
@dp20eic
In deiner Aufzählung sind aber auch viele Batterie Geräte die ja nicht repeaten.
Von deinen 16 Birnen bin ich nicht so weit weg bei mir sinds halt Steckdosen Birnen Repeater und Relays.
Bin gerade dabei den Frust etwas zu lindern. Habe gerade wieder 2 Aqara Thermometer geordert. Dann fliegen die nächsten 2 Sonoff raus.
Die machen die meisten Probleme.
Du hast natürlich recht Wlan bräuchte zu viel Strom aber muss es ausgerechnet dieser Funkstandard sein
aber dazu hat ja auch thomas braun was gesagt.
Euch einen schönen Abend und immer ein stabiles Zigbee Signal
Viele Grüße
Moin,
ja, die verbinden sich aber auch mit dem Leuchtmittel im Raum und nicht mit dem Koordinator, ich habe damals erst alle strombetriebenen Geräte gepairt, dann mit den Batteriegeräten in das Zimmer, in dem sie anschließend verbaut werden sollten, und dann dort gepairt.
Aber ich habe auch mein Netzwerk einfach in Ruhe gelassen, das hat sich jetzt eingespielt, vielleicht lieg es aber einfach auch am Zigbee Board von Texas Instrument, dass das bei mir nicht herumzickt.VG
Bernd -
@dp20eic
Ja, so war auch mein letztes Vorgehen.
Hast du mal deine Signale der Repeater aufgezeichnet um es zu visualisieren? -
Moin,
nop, einige zeigen mir nur 10 oder weniger an, funktionieren trotzdem
Z. B.: der Taster um die Rollos zu bedienen, zeigt nicht verbunden, funzt trotzdem
Mal eine Liste aus demDevice-Reminder
EinzigOG_Schlafzimmer_Ambiente_neu
ist nicht am Strom, da ich da noch bastel, aber wie gesagt es funktioniert alles.VG
Bernd -
Diese 'Netzwerkkarten' sind im Grunde Kokolores. Die zeigen alles mögliche, aber nicht akurat dein Netz. Ich glaube man war bei iobroker.zigbee auch schon kurz davor die Karte rauszuwerfen.
@thomas-braun sagte in Zigbee zum verzweifeln * gelöst *:
die Karte Zeigt die Momentaufnahme von Geräten.. die Router werden per Ping abgeholt, deshalb dauert es länger bit die Karte sich aufgebaut hat.. die Batteriebetriebenen Geräte haben immer alte Werte von letzten Senden .. man kan die nicht aktiv abholen..
deshalb ist die KArte wie die ist.. schnickschnak.. ja ich wollte
dichdie liquidieren..das geschreie war aber zu gross
