    4. [How-to] Node.js für ioBroker richtig updaten
      m0uh @Thomas Braun last edited by
      @thomas-braun said in [How-to] Node.js für ioBroker richtig updaten:
      sudo apt install --reinstall nodejs
      pi@iobroker:~ $
      apt policy nodejs
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      pi@iobroker:~ $ sudo apt install --reinstall nodejs
      Reading package lists... Done
      Building dependency tree... Done
      0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
      Need to get 0 B/28.1 MB of archives.
      After this operation, 0 B of additional disk space will be used.
      (Reading database ... 102217 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.17.1-deb-1nodesource1_arm64.deb ...
      Unpacking nodejs (18.17.1-deb-1nodesource1) over (18.17.1-deb-1nodesource1) ...
      Setting up nodejs (18.17.1-deb-1nodesource1) ...
      Processing triggers for man-db (2.9.4-2) ...
      pi@iobroker:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      /usr/bin/nodejs
      v18.17.1
      /usr/bin/node
      v18.17.1
      /usr/bin/npm
      /usr/lib/node_modules/npm/lib/cli.js:35
          throw err
      TypeError: Class extends value undefined is not a constructor or null
          at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/fs-minipass/lib/index.js:136:4)
          at Module._compile (node:internal/modules/cjs/loader:1256:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
          at Module.load (node:internal/modules/cjs/loader:1119:32)
          at Module._load (node:internal/modules/cjs/loader:960:12)
          at Module.require (node:internal/modules/cjs/loader:1143:19)
          at require (node:internal/modules/cjs/helpers:121:18)
          at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/cacache/lib/content/read.js:4:13)
      Node.js v18.17.1
      pi@iobroker:~ $
      leider keine Abhilfe. Hab ich schon mehrfach probiert.
        michihorn @Thomas Braun last edited by
        @thomas-braun sagte in [How-to] Node.js für ioBroker richtig updaten:
        @michihorn
        Das funktioniert aber nur, wenn die Grundeinstellung sauber ist. Und ein Upgrade auf eine höhere Version funktioniert damit auch nicht.
        Doch das Upgrade funktioniert!
          crunchip Forum Testing Most Active @michihorn last edited by
          @michihorn NEIN, innerhalb, sprich minor version ja, ein upgrade auf eine nächst höhere major version aber nicht
            Thomas Braun Most Active @m0uh last edited by
            @m0uh
            Mal jemals npm von Hand angepackt und upgedatet?
              Homoran Global Moderator Administrators @michihorn last edited by
              @michihorn sagte in [How-to] Node.js für ioBroker richtig updaten:
              nach einer Anleitung aus der "Chip"
              von wann ist diese Anleitung denn?
              den Befehl "sudo apt-get update"
              benutzt man eigentlich schon länger nicht mehr.
              apt-get wurde durch ein einfaches apt ersetzt (grob gesagt)
                @thomas-braun Nein, hab alle Updates immer nach der Anleitung hier im Forum gemacht.
                  @m0uh
                  Lösch mal den npm cache.
                  sudo -H -u iobroker npm cache clean --force
                    @thomas-braun Selber Fehler
                    pi@iobroker:~ $ sudo -H -u iobroker npm cache clean --force
                        throw err
                    Node.js v18.17.1
                      @m0uh sagte in [How-to] Node.js für ioBroker richtig updaten:
                      Mach einen eigenen Thread auf und gib da mal die Ausgabe von
                      iob diag
                      rein. Dürfte zwar sehr zerfetzt aussehen, aber sei's drum.
                      M M 2 Replies Last reply Reply Quote 0
                        @thomas-braun Erledigt. Siehe:
                        https://forum.iobroker.net/topic/67912/nodejs-update-von-16-x-auf-18-x-nicht-möglich-npm-fehler
                          MCU @Thomas Braun last edited by MCU
                          @thomas-braun Installation-Setup wird als veraltet angemerkt. Gibt es da was Neues?
                          Hab es in Deiner Signatur nachvollzogen. ok.
                          prox@jarvisV313:~$ curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash -
                                                     SCRIPT DEPRECATION WARNING
                            This script, located at https://deb.nodesource.com/setup_X, used to
                            install Node.js is deprecated now and will eventually be made inactive.
                            Please visit the NodeSource distributions Github and follow the
                            instructions to migrate your repo.
                            https://github.com/nodesource/distributions
                            The NodeSource Node.js Linux distributions GitHub repository contains
                            information about which versions of Node.js and which Linux distributions
                            are supported and how to install it.
                          TO AVOID THIS WAIT MIGRATE THE SCRIPT
                          Continuing in 60 seconds (press Ctrl-C to abort) ...
                            Thomas Braun Most Active @MCU last edited by
                            @mcu sagte in [How-to] Node.js für ioBroker richtig updaten:
                            Ja, da hab ich es schon drin. Und im 'Beta-iob-diag' ist es auch drin.
                            Ich wollte mir die Tage dann vielleicht auch den iob installer mal anschauen und einen PR schreiben.
                              @thomas-braun Wie kann man denn z.B. nodejs 20 sperren?
                              Achtung, wenn das Repo mit einer höheren Version nicht deaktiviert wird kommt beim nächsten apt update / apt upgrade natürlich die höhere Version mit.
                                Thomas Braun Most Active @MCU last edited by Thomas Braun
                                @mcu
                                Einfach keine Zeile für nodejs@20 anlegen.
                                Die Versionszweige kommen immer noch aus separaten Einträgen.
                                ODER man pinnt ein nodejs@18 fest. Ging per 'apt pinning'
                                • PLCHome 0
                                  PLCHome 0 Developer last edited by Homoran
                                  Also das Installieren hat sich geändert.
                                  Man soll das Script nicht mehr benutzen:
                                  Alt:
                                  curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
                                  sudo apt-get install -y nodejs
                                  Neu
                                  sudo apt install -y ca-certificates curl gnupg
                                  curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
                                  NODE_MAJOR=18
                                  echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
                                  sudo apt-get update && sudo apt-get install nodejs -y
                                  MOD-EDIT: Code korrigiert!
                                  quelle: https://deb.nodesource.com/
                                  mit NODE_MAJOR=18 kann man die Version bestimmen.
                                  Das hier ist aber nur mit Bookworm getestet. NPM wird nur mit Version 20 mitinstalliert. Unter Buster ist bei mir eine 12 statt der 18 installiert worden.
                                  Thomas Braun oberfragger F 3 Replies Last reply Reply Quote 0
                                    Thomas Braun Most Active @PLCHome 0 last edited by
                                    @plchome-0 sagte in [How-to] Node.js für ioBroker richtig updaten:
                                    Man muss nun das "Key verfahren "benutzen:
                                    Nee, das ist nicht die Änderung, das wurde 'schon immer' verwendet.
                                    Die Änderung ist im wesentlichen, das nicht mehr für jedes Distributions-Release ein deb gebaut wird sondern ein generisches, das auf alles passt, was die grundlegendsten Bedingungen erfüllt.
                                    Gilt analog für yum / rpm-basierte Paketmanagementsysteme.
                                    • oberfragger
                                      oberfragger @PLCHome 0 last edited by oberfragger
                                      Neu
                                      NODE_MAJOR=18
                                      sudo apt-get install nodejs npm -y
                                      Das hat bei mir nicht funktioniert.
                                      The following packages have unmet dependencies:
                                       libnode72 : Conflicts: nodejs-legacy
                                       nodejs : Conflicts: npm
                                      E: Unable to correct problems, you have held broken packages.
                                      root@iobroker:/opt/iobroker#
                                      Muss ich irgendwas deinstallieren?
                                      Habe zwischenzeitlich diesen Link gefunden.
                                      https://github.com/Chia-Network/chia-blockchain/discussions/9673
                                      Nach iobroekr start habe ich aber plötzlich die aktuelle 18.17.1 Seltsam.
                                        Thomas Braun Most Active @oberfragger last edited by Thomas Braun
                                        @oberfragger sagte in [How-to] Node.js für ioBroker richtig updaten:
                                        Ja.
                                        sudo apt remove libnode72 npm nodejs-legacy
                                        Und hampel da nicht als root herum.
                                          fastfoot @PLCHome 0 last edited by
                                          da steht aber NICHTS von npm installieren so wie du es da stehen hast. Die Installation von nodejs beinhaltet bereits npm. Bitte ändere das ab damit sich dieser Unsinn nicht verbreitet
                                          PLCHome 0 1 Reply Last reply Reply Quote 0
                                          • PLCHome 0
                                            PLCHome 0 Developer @fastfoot last edited by
                                            @fastfoot ich setze jedes Mal einen Docker neu auf. NPM fehlte jedes Mal wenn ich nur NODEJS im apt hatte.
                                            Thomas Braun F 2 Replies Last reply Reply Quote 0
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            735646
