    4. ioBroker-Objekte der piVCCU3 nicht immer richtig
      Thomas Braun Most Active @HerrFrodo last edited by
      @herrfrodo
      Nein, wenn dein System nicht komplett verfummelt ist kannst du dich am initialen Posting entlang hangeln.
      H 2 Replies Last reply Reply Quote 1
        HerrFrodo @Thomas Braun last edited by
        @thomas-braun na toll.....soviel zu verwurschtelt.....
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Get:3 https://repos.influxdata.com/debian jessie InRelease [7,038 B]
        Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
        Get:5 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
        Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
        Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
        Err:3 https://repos.influxdata.com/debian jessie InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        Err:5 https://packages.grafana.com/oss/deb stable InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        Fetched 7,038 B in 2s (4,180 B/s)
        Reading package lists... Done
        Building dependency tree
        All packages are up to date.
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian jessie InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        W: Failed to fetch https://repos.influxdata.com/debian/dists/jessie/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Some index files failed to download. They have been ignored, or old ones used instead.
          @thomas-braun Grafana und Influx nutze ich nicht - kann weg
          Wie soll ich das ohne wurschteln machen?
            Thomas Braun Most Active @HerrFrodo last edited by Thomas Braun
            @herrfrodo
            Jessie ist komplett falsch, da gehört Buster in die list-Datei. Das ist wohl 'schon immer falsch' gewesen bei dir. Und dann müssen die Keys für grafana sowie influxdb frisch reingeladen werden. Gibt aber auch dazu Threads von mir.
            Edith:
            sudo rm /etc/apt/sources.list.d/graf*
            sudo rm /etc/apt/sources.list.d/influ*
            sudo apt update
            H 3 Replies Last reply Reply Quote 1
              @thomas-braun Viel besser!
              pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/graf*
              pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/influ*
              pi@raspberrypi:~ $ sudo apt update
              Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:2 http://archive.raspberrypi.org/debian buster InRelease
              Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
              Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
              Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                @thomas-braun Damit ist aber Grafana und Influx noch da, gelle.
                Das gockel ich dann in Deinen Threads
                  pi@raspberrypi:~ $ iob fix
                  library: loaded
                  Library version=2022-12-09
                      Welcome to the ioBroker installation fixer!
                      Script version: 2023-04-02
                      You might need to enter your password a couple of times.
                      Installing prerequisites (1/5)
                  Installed gcc-c++
                      Checking ioBroker user and directory permissions (2/5)
                  Created /etc/sudoers.d/iobroker
                  Fixing directory permissions...
                      Check and cleanup npm temporary directories (3/5)
                  Done.
                      Database maintenance (4/5)
                  Checking for uncompressed JSONL databases... This might take a while!
                  Compressing /opt/iobroker/iobroker-data/states.jsonl
                  Compressing /opt/iobroker/iobroker-data/objects.jsonl
                  Compressed 2 JSONL files. Done
                      Checking autostart (5/5)
                  Enabling autostart...
                  Autostart enabled!
                      Your installation was fixed successfully
                      Run iobroker start to start ioBroker again!
                  pi@raspberrypi:~ $ iob start
                    @herrfrodo sagte in ioBroker-Objekte der piVCCU3 nicht immer richtig:
                    Ich dachte du nutzt es nicht?
                    sudo apt remove grafana influxdb*
                      @thomas-braun Ich nutze es nicht.
                      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                      Building dependency tree... Done
                      Jetzt müsste es passen - dank Deiner Hilfe!
                      Vielen Dank!
                        @thomas-braun Hallo!
                        Ich habe ja nun dank Deiner Hilfe mein Raspi-System auf den neuesten Stand bringen können.
                        Bis jetzt kann ich keine Fehler/Probleme feststellen - auch die HM-Adapter laufen gut - habe allerdings "Sentry" immer noch deaktiviert - teste ich mal.
                        Einzig und allein die NFS-Freigabe bzw. das Mounten des Syno-Laufwerkes für den raspiBackup hat nicht funktioniert.
                        Autofs war installiert und die auto.nfs war auch noch wie zuvor.
                        Es schien aber die auto.master nicht zu stimmen.
                        Ich habe dann mit Hilfe von https://darkwolfcave.de/raspberry-pi-nas-freigaben-automatisch-einbinden/
                        die Verbindung geschafft.
                        Keine Ahnung, ob das nun die idealste Lösung ist seinen Raspi täglich zu sichern.
                        Die erzeugte Sicherung auf der Syno wird dann zeitversetzt auf 2 externe Platten geschrieben.
                        Eine dritte Sicherung noch an einem anderen Ort.
                        Wie handhabst Du das?
                          Ich schiebe jede Nacht ein Backitup-Backup auf mein FritzNAS sowie auf GoogleDrive.
                            @thomas-braun said in ioBroker-Objekte der piVCCU3 nicht immer richtig:
                            Du meinst Backitup in ioBroker?
                            Und das System, die SD? Wird das nicht gesichert?
                              Nö, warum?
                              Wenn mir das System in Gänze um die Ohren fliegen sollte installiere ich das ohnehin komplett neu und zieh nur das Backup vom iobroker rein.
                                Nö, warum?
                                Kaputte SD....Überspannung......
                                  HerrFrodo @Thomas Braun last edited by HerrFrodo
                                  Aber das dauert doch bis alles installiert ist.
                                  Bei mir hat ein Backitup-Backup mal nicht funktioniert - muss gestehen, dass ich das vorher auch noch nie getestet habe und möglicherweise mein System verwurschtelt sein könnte.
                                  Ich habe damals ein Image von smartkram genommen, bei dem piVCCU mit dabei war.
                                    Stunde vielleicht. Aber dafür schlepp ich auch keinen alten Kram rein.
                                      Stimmt wohl. Kommt bestimmt auch nicht so oft vor.
                                      Hast Du auch Homematic?
                                      Ist die Nutzung von ioBroker und Hm auf einem System sinnvoll oder besser trennen?
                                      Eventuell irgendwas auf der Syno laufen lassen?
                                        @herrfrodo
                                        Hab ich alles nicht im Einsatz.
                                          HerrFrodo last edited by HerrFrodo
                                          bezüglich Homematic-Adapter habe ich mich wohl etwas zu früh gefreut....
                                          Einige Werte werden wieder nicht in den Objekten aktualisiert aber auf der piVCCU und unter pocketControl richtig angezeigt.
                                          Ich würde nun gerne hier ein Protokoll einfügen.
                                          Wie ist es am sinnvollsten?
                                          Alle 3 hm-rpc Instanzen als Debug zusammen oder einzeln?
                                          Hm-rega mit dabei oder extra?
                                          Besten Dank!
                                            Homoran Global Moderator Administrators @HerrFrodo last edited by
                                            was heisst das genau?
                                            schalte mal Sentry in den Instanzen ab
                                            3274
