    4. [Aufruf] IKEA-Trådfri v0.4.4 testen
      Bittaschön:
      tradfri.0	2017-10-28 15:44:15.041	info	updating possible scenes for group 169143: ["204053","207387","220862","222993","224698","225238"]
      tradfri.0	2017-10-28 15:44:14.961	info	updating possible scenes for group 169143: ["204053","207387","220862","222993","224698"]
      tradfri.0	2017-10-28 15:44:14.905	info	updating possible scenes for group 169143: ["204053","207387","220862","222993"]
      tradfri.0	2017-10-28 15:44:14.850	info	updating possible scenes for group 169143: ["204053","207387","220862"]
      tradfri.0	2017-10-28 15:44:14.803	info	updating possible scenes for group 169143: ["204053","207387"]
      tradfri.0	2017-10-28 15:44:14.744	info	updating possible scenes for group 169143: ["204053"]
      tradfri.0	2017-10-28 15:44:14.699	info	updating possible scenes for group 153251: ["198929","209806","215571"]
      tradfri.0	2017-10-28 15:44:14.638	info	updating possible scenes for group 153251: ["198929","209806"]
      tradfri.0	2017-10-28 15:44:14.578	info	updating possible scenes for group 153251: ["198929"]
      tradfri.0	2017-10-28 15:44:14.520	info	updating possible scenes for group 169143: []
      tradfri.0	2017-10-28 15:44:14.507	info	got all scenes in group 169143: [207387,204053,220862,225238,224698,222993]
      tradfri.0	2017-10-28 15:44:14.420	info	got all scenes in group 153251: [215571,198929,209806]
      tradfri.0	2017-10-28 15:44:14.118	info	got all groups: [153251,169143]
      tradfri.0	2017-10-28 15:44:14.088	info	got all devices: [65539,65537,65538,65536,65540]
      tradfri.0	2017-10-28 15:44:13.953	info	startfile = /opt/iobroker/node_modules/iobroker.tradfri/main.js
      tradfri.0	2017-10-28 15:44:13.908	info	starting. Version 0.5.0-beta4 in /opt/iobroker/node_modules/iobroker.tradfri, node: v6.11.5
      tradfri.0	2017-10-28 15:44:13.858	info	States connected to redis: 127.0.0.1:6379
      host.linaro-alip	2017-10-28 15:44:12.512	info	instance system.adapter.tradfri.0 started with pid 21333
      host.linaro-alip	2017-10-28 15:44:12.484	info	"system.adapter.tradfri.0" enabled
      Rückwärts natürlich
      Rainer
      • AlCalzone
        Das sieh gut aus.
        Und der Dropdown ist trotzdem nicht da? Bei mir funktioniert der Dropdown und wird automatisch aktualisiert, wenn ich in der App was ändere.
          War in der Beta3 bei mir auch so.
          Ich leere mal den Browsercache und sehe dann, dann ändere ich nochmal in der App und melde mich wieder.
          Bis gleich
          Rainer
          • AlCalzone
            Objekt-Liste neu laden (mit dem ioBroker-Knopf) reicht manchmal auch aus.
              Ok It seems to be no bug but a feature :shock:
              Browsercache, kein Erfolg
              Mit der Fernbedineung die Farben durchklicken, heller/dunkler; an /aus, kein Erfolg
              in der App die Farben wechseln, kein Erfolg
              in der App eine Stimmung auswählen -> actual scene steht wieder da - mit pulldown.
              beim weiter durchklickern der Farben steht da weiterhin das pulldown mit einer falschen Stimmung.
              Dabei ist mir aufgefallen dass mit dem weiterschalten via fernbedienung gar nicht alle Farben angewählt werden.
              Ich hatte gehofft, dass wenn es dann die richtige Farbe und Helligkeit ist auch die richtige Stimmung wieder im pulldown angezeigt wird.
              wird sie nicht, selbst wenn ich im Farbmenü grün und die Helligkeit auf 67% setze, was der Stimmung "gut" entspricht, blleibt die Anzeige auf "geht"
              EDIT: reload hatte auch nicht geholfen.
              Rainer
              • AlCalzone
                Ah ok, das macht Sinn. Das ist das altbekannte Problem, dass das Gateway keine Infos über Gruppen sendet. Die aktuelle Szene wird nur gesendet, wenn tatsächlich eine ausgewählt wurde.
                Für alles außer Szenen kommt die Aktualisierung der Gruppen-States im nächsten Update.
                Szenen sind komplizierter, da muss jede Lampe mit den in der Szene für diese Lampe definierten Werten für Helligkeit, Farbe und an/aus verglichen werden
                  Ich bin dann bis Mittwoch außer Haus.
                  Du kannst dir also ruhig Zeit lassen 😄 :lol: 😄
                  Rainer
                    MIr ist gerade noch etwas aufgefallen.
                    Ich habe die neuen Funktionen in den Gruppen getestet.
                    Klappt alles wie es soll! Super.
                    bei der Weißtongruppe kann man bei rgb einstellen was man will -> es hat keinen Einfluss, bei der RGB Gruppe entsprechend bei Farbton das selbe.
                    Das schöne hier ist, dass der eingestellte rgb Wert stehen bleibt, auch wenn es kein IKEA default wert ist.
                    Dann habe ich noch mit der Transition time gespielt auch das klappt, eininteressantes Verhalten ist mir dabei aufgefallen.
                    In der RGB gruppe hatte ich die TT auf 20 sec gesetzt und dann von ff00ff auf 00ff00 gewechselt.
                    Damit ich besser sehen konnte was passierte wollte ich mal eben schnell die Brightness der Weißtongruppe reduzieren.
                    Da griff aber, da dieser Timer noch nicht abgelaufen war, dann anscheinend ebenfalls die 20sec. Transition Time (oder der Rest davon).
                    Rainer
                    • AlCalzone
                      Alles klar, danke schon mal fürs Testen!
                        Da nich für!
                        Danke fürs Programmieren!
                        Rainer
                        • AlCalzone
                          @Homoran:
                          Das schöne hier ist, dass der eingestellte rgb Wert stehen bleibt, auch wenn es kein IKEA default wert ist. `
                          So war das gedacht. Mit 0.5.0 werden die States auch immer wieder aufgeräumt, d.h. wenn in einer Gruppe keine RGB Lampen sind, werden beim Start die Werte für color/hue/saturation gelöscht (States bleiben aber).
                          Zum RGB: Stimmen die dargestellten Farben ungefähr mit dem überein, was die Hex-Farbe darstellt?
                          @Homoran:
                          Da griff aber, da dieser Timer noch nicht abgelaufen war, dann anscheinend ebenfalls die 20sec. Transition Time (oder der Rest davon). `
                          Interessant, muss ich mal mit spielen.
                          • AlCalzone
                            Version 0.5.0 ist veröffentlicht!
                            Hier geht's weiter: http://forum.iobroker.net/viewtopic.php?f=36&t=8733
                              @AlCalzone:
                              um RGB: Stimmen die dargestellten Farben ungefähr mit dem überein, was die Hex-Farbe darstellt? `
                              wenn man nicht zu doof ist und den Hash immer mit in das Feld kopiert -> Ja!
                              Außerdem bleibt hier auch die geänderte Transitiontime solange gültig bis man sie ändert. Sie springt nicht zurück auf 0.5
                              Rainer
                              • AlCalzone
                                @Homoran:
                                wenn man nicht zu doof ist und den Hash immer mit in das Feld kopiert -> Ja! `
                                Warte… funktioniert es mit Hash oder ohne?
                                31.7k
                                79.8k
                                166
                                22449
