    3. Off Topic
    4. Grafana
    5. Fehler Grafana Update (sudo apt Update)
      Thomas Braun Most Active @teletapi last edited by Thomas Braun
      @teletapi
      Schalt den X-Server/Desktop aus.
      Zum Problem:
      https://forum.iobroker.net/topic/67822/grafana-repo-braucht-neuen-schlüssel
      Spiel die Updates ein:
      Pending Updates: 27
      Und stell den simple-api auf ein 'normales' loglevel zurück, silly knallt dir das Log voll.
      teletapi 1 Reply Last reply Reply Quote 0
      • teletapi
        teletapi @Thomas Braun last edited by
        Wow das ging ja schnell, und ja hat geklappt,das mit der simple-api wie das geht muss ich erstmal schauen....
        Aber vielen lieben dank
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Architecture    : aarch64
        Docker          : false
        Virtualization  : none
        Distributor ID: Debian
        Description:    Debian GNU/Linux 11 (bullseye)
        Release:        11
        Codename:       bullseye
        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
        NAME="Debian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        Systemuptime and Load:
         11:32:04 up 42 min,  3 users,  load average: 0.56, 0.76, 0.76
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=43.3'C
        volt=0.9460V
        *** Time and Time Zones ***
                       Local time: Thu 2023-08-31 11:32:05 CEST
                   Universal time: Thu 2023-08-31 09:32:05 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.8G        2.7G        2.0G         35M        3.2G        5.0G
        Swap:            99M          0B         99M
        Total:          7.9G        2.7G        2.1G
                 7811 M total memory
                 2668 M used memory
                 4865 M active memory
                  695 M inactive memory
                 1986 M free memory
                  156 M buffer memory
                 2999 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4       59G  9.3G   47G  17% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
        /dev/sda1      vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
        [Thu Aug 31 10:50:01 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Thu Aug 31 10:50:03 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Thu Aug 31 10:50:03 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Thu Aug 31 10:50:04 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.9G    /var/
        1.3G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
        1.3G    /var/log
        445M    /var/lib
        Archived and active journals take up 1.2G in the file system.
        /opt/iobroker/backups:
        887M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        352M    /opt/iobroker/iobroker-data/
        182M    /opt/iobroker/iobroker-data/files
        71M     /opt/iobroker/iobroker-data/backup-objects
        62M     /opt/iobroker/iobroker-data/node-red/node_modules
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        29M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
        8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        MULTIHOSTSERVICE/enabled: false
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.9.1
        javascript:     7.1.4
        Adapters from github:   2
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
        + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hue-extended.0           : hue-extended          : iobroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
        + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
        + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
        + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
        + system.adapter.panasonic-viera.0        : panasonic-viera       : iobroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
          system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
          system.adapter.smartmeter.1             : smartmeter            : iobroker                                 - disabled
        + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 6.9.1    , installed 6.9.1
        Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
        Adapter    "backitup"     : 2.7.0    , installed 2.7.0
        Adapter    "discovery"    : 3.2.0    , installed 3.2.0
        Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
        Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "info"         : 1.9.26   , installed 1.9.26
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.2
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "nuki"         : 1.6.0    , installed 1.6.0
        Adapter    "opendtu"      : 0.1.7    , installed 0.1.7
        Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
        Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
        Adapter    "socketio"     : 6.5.2    , installed 6.5.2
        Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
        Adapter    "web"          : 6.1.0    , installed 6.1.0
        Adapter    "ws"           : 2.5.3    , installed 2.5.3
        Objects and States
        Objects:        10136
        States:         9469
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://repos.influxdata.com/debian stable InRelease
        Hit:6 https://apt.grafana.com stable InRelease
        Get:7 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
        Fetched 4586 B in 2s (2325 B/s)
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       21603      2246/io.hm-rpc.3
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15861      540/cupsd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16838      786/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19468      786/iobroker.js-con
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12747      577/sshd: /usr/sbin
        tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       20712      2152/io.hm-rpc.0
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       26650      2681/io.jarvis.0
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18970      2088/node-red
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        13752      562/mosquitto
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       21751      2321/io.sonoff.0
        tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       18368      2196/io.hm-rpc.2
        tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       19002      2174/io.hm-rpc.1
        tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       26994      3076/io.simple-api.
        tcp6       0      0 :::3000                 :::*                    LISTEN      117        17875      785/grafana
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15860      540/cupsd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17929      2005/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23024      2450/io.web.0
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       27053      3220/io.socketio.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        15906      556/influxd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12749      577/sshd: /usr/sbin
        tcp6       0      0 :::1883                 :::*                    LISTEN      116        13753      562/mosquitto
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15089      635/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13603      402/avahi-daemon: r
        udp        0      0 0.0.0.0:35549           0.0.0.0:*                           108        13605      402/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15261      476/dhcpcd
        udp6       0      0 :::546                  :::*                                0          14006      476/dhcpcd
        udp6       0      0 :::33601                :::*                                108        13606      402/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        13604      402/avahi-daemon: r
        2023-08-31 11:30:03.572  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.ical.0.data.html:{"_id":"ical.0.data.html","type":"state","common":{"name":{"en":"Calendar data as HTML","de":"Kalenderdaten als HTML","ru":"Данные календаря как HTML","pt":"Dados do calendário como HTML","nl":"Calendar data als HTML","fr":"Données du calendrier en HTML","it":"Dati del calendario come HTML","es":"Datos del calendario como HTML","pl":"Kalendarz danych jako HTML","zh-cn":"HTML的基准数据"},"desc":"HTML table with events","type":"string","role":"html","read":true,"write":false},"native":{},"from":"system.adapter.ical.0","ts":1693474203567,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2023-08-31 11:30:03.607  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.ical.0.data.text:{"_id":"ical.0.data.text","type":"state","common":{"name":{"en":"Calendar data as Text","de":"Kalenderdaten als Text","ru":"Календарь данных как текст","pt":"Dados do calendário como texto","nl":"Calendar data als Text","fr":"Données du calendrier comme texte","it":"Dati del calendario come testo","es":"Datos del calendario como texto","pl":"Kalendarzowe dane jako tekst","zh-cn":"作为案文的简历数据"},"desc":"Text table with events","type":"string","role":"text","read":true,"write":false},"native":{},"from":"system.adapter.ical.0","ts":1693474203580,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2023-08-31 11:30:03.627  - info: ical.0 (10954) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
        2023-08-31 11:30:04.282  - info: ical.0 (10954) processing URL: Wichtige Termine Elke und HaWe https://calendar.google.com/calendar/ical/2qb10bajtpd1ppp5bgdvoijc4c%40group.calendar.google.com/private-8f460a093288c84c16085fa95391b0a0/basic.ics
        2023-08-31 11:30:04.377  - info: ical.0 (10954) processing URL: Feiertage https://calendar.google.com/calendar/ical/mgovdcdlp83u1b9klhkct1l8kk%40group.calendar.google.com/private-98ebcd540847cbbf5a1694450687b9a3/basic.ics
        2023-08-31 11:30:04.442  - info: ical.0 (10954) processing URL: Geburtstage https://calendar.google.com/calendar/ical/hwscheli%40gmx.de/private-defea42d88700d2ad12ad1695849c123/basic.ics
        2023-08-31 11:30:04.580  - info: ical.0 (10954) processing URL: Müllabfuhr https://calendar.google.com/calendar/ical/3295bfe416800402292641670f17e653306ae542998553872a7deac07e916817%40group.calendar.google.com/private-02d0e7d362e3d4991cf8a46fdd2baa8a/basic.ics
        2023-08-31 11:30:09.766  - info: ical.0 (10954) Terminated (NO_ERROR): Without reason
        2023-08-31 11:30:10.310  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2023-08-31 11:32:12.736  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.iobroker.plugins.sentry","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:12.746  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.iobroker.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:16.580  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.iobroker.plugins.sentry","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:16.589  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.iobroker.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:35.238  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.iobroker.plugins.sentry","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:35.261  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.iobroker.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:39.231  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.iobroker.plugins.sentry","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:39.244  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.iobroker.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:43.106  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.iobroker.plugins.sentry","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:43.119  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.iobroker.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:47.525  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.iobroker.plugins.sentry","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:47.538  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.iobroker.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:53.113  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.iobroker.plugins.sentry","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:53.124  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.iobroker.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:59.369  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.iobroker.plugins.sentry","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-08-31 11:32:59.399  - silly: simple-api.0 (3076) Objects user redis pmessage */cfg.o.system.host.iobroker.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.iobroker.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        iob diag has finished.
        lg
        Hawe
        Meister Mopper Thomas Braun 2 Replies Last reply Reply Quote 0
        • Meister Mopper
          Meister Mopper @teletapi last edited by
          @teletapi sagte in Fehler Grafana Update (sudo apt Update):
          Das wird in der Instanz gemacht. Stell 2. auf z. B. Fehler (error)
            @teletapi
            Der X-Server läuft noch:
            X-Server:       true
            Desktop:
            Terminal:       tty
            Und da läuft auch ein Druckerserver 'cupsd' mit. Druckst du mit der Kiste? Vermutlich eher nicht.
            • teletapi
              teletapi @Thomas Braun last edited by teletapi
              @thomas-braun Das hab ich total überlesen was bitte ist ein X-Server und wie kann ich den ausschalten...?
              • teletapi
                teletapi @Meister Mopper last edited by
                @meister-mopper
                Danke das war noch vom letzten Fehler da hatte ich auf "silly" gestellt und vergessen wieder auf "info" zu gehn
                  Da läuft (u.a.) die graphische Benutzeroberfläche drauf.
                  Kann man aussstellen, in dem man in
                  sudo raspi-config
                  Den boot-Vorgang auf 'CLI without login' oder so ähnlich stellt.
                  Kann das aber gerade nicht nachschauen.
                  • teletapi
                    @thomas-braun said in Fehler Grafana Update (sudo apt Update):
                    CLI without login
                    leider finde ich unter sudo Raspi-config nichts was mich dahingehend den X-server ausschalten lässt
                    Ich hatte irgendwann mal gesehen das ich wohl den raspi mit grafischer Oberfläche installiert hatte obwohl ich das garnicht wollte. Hat aber bisher nicht gestört.
                    Von daher hatte ich das bisher nicht weiter beachtet
                      Homoran Global Moderator Administrators @teletapi last edited by
                      zeigen!
                      muss beim boot menü stehen
                      • teletapi
                        teletapi @Homoran last edited by teletapi
                          @teletapi https://forum.iobroker.net/post/1024706
                          • teletapi
                            @homora
                            Boah seid Ihr gut.
                            Skript v.2023-04-16
                            *** BASE SYSTEM ***
                            Docker          : false
                            Release:        11
                            Codename:       bullseye
                            VERSION_ID="11"
                            ID=debian
                             12:44:01 up 4 min,  1 user,  load average: 2.51, 2.26, 1.03
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            temp=49.1'C
                            volt=0.9360V
                                           Local time: Thu 2023-08-31 12:44:02 CEST
                                       Universal time: Thu 2023-08-31 10:44:02 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            Boot Target:    multi-user.target
                            *** MEMORY ***
                            Mem:            7.8G        2.2G        4.1G        1.0M        1.4G        5.4G
                            Swap:            99M          0B         99M
                            Total:          7.9G        2.2G        4.2G
                                     7811 M total memory
                                     2248 M used memory
                                     3010 M active memory
                                      484 M inactive memory
                                     4125 M free memory
                                       99 M buffer memory
                                     1337 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                            tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
                            [Thu Aug 31 12:39:32 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                            [Thu Aug 31 12:39:34 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Thu Aug 31 12:39:34 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                            [Thu Aug 31 12:39:35 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                            /var:
                            1.9G    /var/
                            1.3G    /var/log
                            447M    /var/lib
                            340M    /opt/iobroker/iobroker-data/
                            16M     /opt/iobroker/iobroker-data/objects.jsonl
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.9.1
                            javascript:     7.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        10140
                            States:         9480
                            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:2 http://deb.debian.org/debian bullseye InRelease
                            Hit:3 https://repos.influxdata.com/debian stable InRelease
                            Hit:4 https://apt.grafana.com stable InRelease
                            Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
                            Fetched 4586 B in 2s (2313 B/s)
                            Pending Updates: 0
                            tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       15145      1280/io.hm-rpc.0
                            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       15119      1210/node-red
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        14669      568/mosquitto
                            tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18264      1490/io.sonoff.0
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15685      577/sshd: /usr/sbin
                            tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       22259      1949/io.jarvis.0
                            tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       23118      2087/io.simple-api.
                            tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       17510      1318/io.hm-rpc.2
                            tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       15158      1297/io.hm-rpc.1
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16530      655/iobroker.js-con
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16537      655/iobroker.js-con
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14691      536/cupsd
                            tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       17633      1370/io.hm-rpc.3
                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14690      536/cupsd
                            tcp6       0      0 :::1883                 :::*                    LISTEN      116        14670      568/mosquitto
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          15687      577/sshd: /usr/sbin
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11941      977/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20296      1740/io.web.0
                            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       25046      2149/io.socketio.0
                            tcp6       0      0 :::8086                 :::*                    LISTEN      999        15705      550/influxd
                            tcp6       0      0 :::3000                 :::*                    LISTEN      117        14951      654/grafana
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14547      402/avahi-daemon: r
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14735      482/dhcpcd
                            udp        0      0 0.0.0.0:49440           0.0.0.0:*                           108        14549      402/avahi-daemon: r
                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14710      617/cups-browsed
                            udp6       0      0 :::5353                 :::*                                108        14548      402/avahi-daemon: r
                            udp6       0      0 :::39629                :::*                                108        14550      402/avahi-daemon: r
                            udp6       0      0 :::546                  :::*                                0          11745      482/dhcpcd
                            2023-08-31 12:42:10.347  - info: socketio.0 (2149) socket.io server listening on port 8084
                            2023-08-31 12:42:12.375  - info: sourceanalytix.0 (2291) starting. Version 0.4.14 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v18.17.1, js-controller: 5.0.12
                            2023-08-31 12:42:12.528  - info: sourceanalytix.0 (2291) Welcome to SourceAnalytix, making things ready ...
                            2023-08-31 12:42:12.895  - info: opendtu.0 (2325) starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.opendtu, node: v18.17.1, js-controller: 5.0.12
                            2023-08-31 12:42:12.908  - info: sourceanalytix.0 (2291) Found 4 SourceAnalytix enabled states
                            2023-08-31 12:42:12.909  - info: sourceanalytix.0 (2291) Initialising (1 of 4) "mqtt.0.Wechselrichter.total.YieldDay"
                            2023-08-31 12:42:14.857  - info: energiefluss.1 (2347) starting. Version 3.6.0 (non-npm: SKB-CGN/ioBroker.energiefluss) in /opt/iobroker/node_modules/iobroker.energiefluss, node: v18.17.1, js-controller: 5.0.12
                            2023-08-31 12:42:14.950  - info: energiefluss.1 (2347) Starting Energiefluss Adapter
                            2023-08-31 12:42:15.389  - info: energiefluss.1 (2347) Adapter started and listening to 5 States
                            2023-08-31 12:42:24.080  - info: sourceanalytix.0 (2291) Initialization of mqtt.0.Wechselrichter.total.YieldDay successfully
                            2023-08-31 12:42:24.082  - info: sourceanalytix.0 (2291) Initialising (2 of 4) "mqtt.0.Wechselrichter.total.YieldTotal"
                            2023-08-31 12:42:24.713  - info: cloud.0 (1779) Trying to connect as system.user.admin to cloud
                            2023-08-31 12:42:24.839  - info: cloud.0 (1779) Connection changed: connect
                            2023-08-31 12:42:30.785  - info: sourceanalytix.0 (2291) Initialization of mqtt.0.Wechselrichter.total.YieldTotal successfully
                            2023-08-31 12:42:30.786  - info: sourceanalytix.0 (2291) Initialising (3 of 4) "sonoff.0.Tasmota Energie LG E320.E320_Total_in"
                            2023-08-31 12:42:36.403  - info: sourceanalytix.0 (2291) Initialization of sonoff.0.Tasmota Energie LG E320.E320_Total_in successfully
                            2023-08-31 12:42:36.404  - info: sourceanalytix.0 (2291) Initialising (4 of 4) "sonoff.0.Tasmota Energie LG E320.E320_Total_out"
                            2023-08-31 12:42:41.703  - info: sourceanalytix.0 (2291) Initialization of sonoff.0.Tasmota Energie LG E320.E320_Total_out successfully
                            2023-08-31 12:42:41.745  - info: sourceanalytix.0 (2291) Successfully activated SourceAnalytix for 4 of 4 states, will do my Job until you stop me!
                            2023-08-31 12:42:45.680  - info: alexa2.0 (1356) No smart home devices to query
                            2023-08-31 12:42:50.642  - info: alexa2.0 (1356) Subscribing to states...
                            2023-08-31 12:42:50.652  - info: alexa2.0 (1356) Deleting the following states: ["Smart-Home-Devices.0b7e87f5-3204-4300-963e-f9d1c28910d4","Smart-Home-Devices.175077c8-5338-4770-a9e0-99967be386af","Smart-Home-Devices.8f896317-3a98-4dfa-976a-d79fa3009886","Smart-Home-Devices.bac632dd-ca10-43b4-91df-0e4db4dbddd3","Smart-Home-Devices.cd614394-ef0d-47d6-ab5d-09c680e762fc","Smart-Home-Devices.844e1fcb-f324-4e87-8c89-c7086bde3b84","Smart-Home-Devices.d09a9c49-a787-4db1-bdd2-b4211bb0d02f","Smart-Home-Devices.0b7e87f5-3204-4300-963e-f9d1c28910d4.#delete","Smart-Home-Devices.0b7e87f5-3204-4300-963e-f9d1c28910d4.#enabled","Smart-Home-Devices.0b7e87f5-3204-4300-963e-f9d1c28910d4.#includeInAllQuery","Smart-Home-Devices.0b7e87f5-3204-4300-963e-f9d1c28910d4.#query","Smart-Home-Devices.0b7e87f5-3204-4300-963e-f9d1c28910d4.powerState","Smart-Home-Devices.175077c8-5338-4770-a9e0-99967be386af.#delete","Smart-Home-Devices.175077c8-5338-4770-a9e0-99967be386af.#enabled","Smart-Home-Devices.175077c8-5338-4770-a9e0-99967be386af.#includeInAllQuery","Smart-Home-Devices.175077c8-5338-4770-a9e0-99967be386af.#query","Smart-Home-Devices.175077c8-5338-4770-a9e0-99967be386af.brightness","Smart-Home-Devices.175077c8-5338-4770-a9e0-99967be386af.colorTemperatureInKelvin","Smart-Home-Devices.175077c8-5338-4770-a9e0-99967be386af.colorTemperatureName","Smart-Home-Devices.175077c8-5338-4770-a9e0-99967be386af.powerState","Smart-Home-Devices.8f896317-3a98-4dfa-976a-d79fa3009886.#delete","Smart-Home-Devices.8f896317-3a98-4dfa-976a-d79fa3009886.#enabled","Smart-Home-Devices.8f896317-3a98-4dfa-976a-d79fa3009886.#includeInAllQuery","Smart-Home-Devices.8f896317-3a98-4dfa-976a-d79fa3009886.#query","Smart-Home-Devices.8f896317-3a98-4dfa-976a-d79fa3009886.powerState","Smart-Home-Devices.bac632dd-ca10-43b4-91df-0e4db4dbddd3.#delete","Smart-Home-Devices.bac632dd-ca10-43b4-91df-0e4db4dbddd3.#enabled","Smart-Home-Devices.bac632dd-ca10-43b4-91df-0e4db4dbddd3.#includeInAllQuery","Smart-Home-Devices.bac632dd-ca10-43b4-91df-0e4db4dbddd3.#query","Smart-Home-Devices.bac632dd-ca10-43b4-91df-0e4db4dbddd3.brightness","Smart-Home-Devices.bac632dd-ca10-43b4-91df-0e4db4dbddd3.colorTemperatureInKelvin","Smart-Home-Devices.bac632dd-ca10-43b4-91df-0e4db4dbddd3.colorTemperatureName","Smart-Home-Devices.bac632dd-ca10-43b4-91df-0e4db4dbddd3.powerState","Smart-Home-Devices.cd614394-ef0d-47d6-ab5d-09c680e762fc.#delete","Smart-Home-Devices.cd614394-ef0d-47d6-ab5d-09c680e762fc.#enabled","Smart-Home-Devices.cd614394-ef0d-47d6-ab5d-09c680e762fc.#includeInAllQuery","Smart-Home-Devices.cd614394-ef0d-47d6-ab5d-09c680e762fc.#query","Smart-Home-Devices.cd614394-ef0d-47d6-ab5d-09c680e762fc.powerState","Smart-Home-Devices.844e1fcb-f324-4e87-8c89-c7086bde3b84.#enabled","Smart-Home-Devices.844e1fcb-f324-4e87-8c89-c7086bde3b84.#delete","Smart-Home-Devices.844e1fcb-f324-4e87-8c89-c7086bde3b84.powerState","Smart-Home-Devices.844e1fcb-f324-4e87-8c89-c7086bde3b84.colorTemperatureName","Smart-Home-Devices.844e1fcb-f324-4e87-8c89-c7086bde3b84.colorTemperatureInKelvin","Smart-Home-Devices.844e1fcb-f324-4e87-8c89-c7086bde3b84.brightness","Smart-Home-Devices.844e1fcb-f324-4e87-8c89-c7086bde3b84.#query","Smart-Home-Devices.844e1fcb-f324-4e87-8c89-c7086bde3b84.#includeInAllQuery","Smart-Home-Devices.d09a9c49-a787-4db1-bdd2-b4211bb0d02f.#enabled","Smart-Home-Devices.d09a9c49-a787-4db1-bdd2-b4211bb0d02f.#delete","Smart-Home-Devices.d09a9c49-a787-4db1-bdd2-b4211bb0d02f.powerState","Smart-Home-Devices.d09a9c49-a787-4db1-bdd2-b4211bb0d02f.connectivity","Smart-Home-Devices.d09a9c49-a787-4db1-bdd2-b4211bb0d02f.connectivity-reason","Smart-Home-Devices.d09a9c49-a787-4db1-bdd2-b4211bb0d02f.#query","Smart-Home-Devices.d09a9c49-a787-4db1-bdd2-b4211bb0d02f.#includeInAllQuery"]
                            2023-08-31 12:42:52.635  - info: alexa2.0 (1356) Alexa-Push-Connection (macDms = true) established. Disable Polling
                            2023-08-31 12:43:00.975  - info: alexa2.0 (1356) Initialization Done ...
                            2023-08-31 12:43:49.926  - info: web.0 (1740) <== Disconnect system.user.admin from ::ffff:192.168.178.63
                              @teletapi
                              Und direkt 500MB RAM und ein paar CPU-cycles mehr zur Verfügung die sonst für den graphischen Quatsch drauf gegangen sind.
                              (Für kritische Mitleser: Ja, ich weiß, das ist etwas vereinfacht plakativ...)
                              • teletapi
                                Ja so gut bin ich dann doch nicht war immer sehr frroh das das System läuft aber es geht nix über Leute wie euch die es besser wissen und uns unterstützen wo Sie können.
                                Ganz herzlichen dank dafür
                                Hawe
                                660
