    5. [gelöst] Lampe nach Zeit ein /ausschalten
    • Codierknecht
      Codierknecht Developer Most Active @Alero last edited by
      @alero
      Mit "Objektdaten" ist sowas gemeint:
        "common": {
          "name": "SwitchState",
          "desc": "Manuell erzeugt",
          "role": "state",
          "type": "boolean",
          "read": true,
          "write": true,
          "def": false
        "type": "state",
        "native": {},
        "_id": "0_userdata.0.Test.test_bool",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
        "user": "system.user.admin",
        "ts": 1679403446220
      • DJMarc75
        DJMarc75 @Alero last edited by
        @alero und jetzt bitte noch auf den Bleistift bei jedem DP klicken und die Objektdaten hier in Codetags posten.
          Alero @DJMarc75 last edited by Alero
          @djmarc75
          Fenstergriff
            "type": "state",
            "common": {
              "def": "CLOSED",
              "type": "number",
              "read": true,
              "write": false,
              "min": 0,
              "max": 2,
              "states": {
                "0": "CLOSED",
                "1": "TILTED",
                "2": "OPEN"
              "role": "state",
              "name": "RHS_Wohnzimmer:1.STATE"
            "native": {
              "MIN": "CLOSED",
              "OPERATIONS": 5,
              "MAX": "OPEN",
              "FLAGS": 1,
              "ID ": "STATE",
              "TYPE": "ENUM",
              "DEFAULT": "CLOSED",
              "VALUE_LIST": [
                "CLOSED",
                "TILTED",
                "OPEN"
              "CONTROL": "RHS.STATE",
              "ID": "STATE"
            "from": "system.adapter.hm-rega.0",
            "ts": 1606565663365,
            "_id": "hm-rpc.1.0007DA4989ADED.1.STATE",
            "acl": {
              "object": 1636,
              "state": 1636,
          Fensterkontakt
            "type": "state",
            "common": {
              "def": 0,
              "type": "number",
              "read": true,
              "write": false,
              "min": 0,
              "max": 1,
              "states": {
                "0": "CLOSED",
                "1": "OPEN"
              "unit": "\"\"",
              "role": "value.window",
              "name": "TFK_Terrassentuer:1.STATE"
            "native": {
              "MIN": "CLOSED",
              "UNIT": "\"\"",
              "OPERATIONS": 5,
              "MAX": "OPEN",
              "FLAGS": 1,
              "ID": "STATE",
              "TAB_ORDER": 0,
              "TYPE": "ENUM",
              "VALUE_LIST": [
                "CLOSED",
                "OPEN"
              "CONTROL": "DOOR_SENSOR.STATE"
            "ts": 1683371744664,
            "_id": "hm-rpc.1.0000D8A99E5B80.1.STATE",
            "acl": {
              "object": 1636,
              "state": 1636,
          Schalter licht
            "type": "state",
            "common": {
              "def": false,
              "type": "boolean",
              "read": true,
              "write": true,
              "role": "switch",
              "name": "FS_Garage_Gartenlicht_1_bis_4:1.STATE"
            "native": {
              "CONTROL": "SWITCH.STATE",
              "DEFAULT": false,
              "FLAGS": 1,
              "ID": "STATE",
              "MAX": true,
              "MIN": false,
              "OPERATIONS": 7,
              "TAB_ORDER": 0,
              "TYPE": "BOOL",
              "UNIT": ""
            "ts": 1561403105982,
            "_id": "hm-rpc.0.IEQ0023606.1.STATE",
            "acl": {
              "object": 1636,
              "state": 1636,
          Homoran DJMarc75 2 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @Alero last edited by
            @alero sagte in Lampe nach Zeit ein /ausschalten:
            Fenstergriff
            ist der channel, nicht der state!
            Fensterkontakt
            ist wie erwartet Werteliste mit 0 und 1, weder bool, noch text
            Schalter licht
            ist bool
            • DJMarc75
              @alero Dann eben so:
              A Newpicsel 2 Replies Last reply Reply Quote 0
                @djmarc75
                hi,
                vielen dank, ich werde es ausprobieren und bescheid geben.
                Vielen vielen Dank an euch alle.
                • Codierknecht
                  Codierknecht Developer Most Active @Homoran last edited by
                  @homoran sagte in Lampe nach Zeit ein /ausschalten:
                  DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
                  • DJMarc75
                    DJMarc75 @Codierknecht last edited by
                    @codierknecht er hat es editiert und steht nun korrekt drin 😉
                      Homoran Global Moderator Administrators @Codierknecht last edited by
                      @codierknecht sagte in Lampe nach Zeit ein /ausschalten:
                      enäää
                      nachträglich editiert ohne Kennzeichnung 😡
                      Strafmaß wird später bekannt gegeben 😂
                      crunchip 1 Reply Last reply Reply Quote 1
                        crunchip Forum Testing Most Active @Homoran last edited by
                        @homoran is der Vorteil wenn man nachgucken kann😜
                          Homoran Global Moderator Administrators @DJMarc75 last edited by
                          @djmarc75 sagte in Lampe nach Zeit ein /ausschalten:
                          @Alero
                          und genau deswegen müssen Edits gekennzeichnet werden, weil sonst die folgenden Posts sinnentstellt werden
                            Alero @Homoran last edited by
                            hi,
                            habe jetzt mal das script gestestet.
                            Die Lampe geht an aber leider nicht wieder aus nach 3 min.
                            • DJMarc75
                              @alero
                              Verschiebe das obere "stop ausschalten" unter Deinen gelben KommentarBaustein.
                                @djmarc75
                                danke
                                werde es testen
                                  Alero @Alero last edited by
                                  Leider funzt es immer noch nicht
                                  • DJMarc75
                                    Blockly zeigen bitte
                                      @djmarc75
                                      HI,
                                      hier das script. Das licht geht zwar an aber nicht wieder aus.
                                      • DJMarc75
                                        @alero kann es sein dass der BWM ständig eine Bewegung registriert ?
                                        Bau mal ein Debug ganz oben ein und beobachte das LOG
                                          @djmarc75
                                            @alero was willst du damit zeigen?
                                            3055
