    5. [gelöst] Lampe nach Zeit ein /ausschalten
    • DJMarc75
      DJMarc75 @Alero last edited by
      @alero und jetzt bitte noch auf den Bleistift bei jedem DP klicken und die Objektdaten hier in Codetags posten.
        Alero @DJMarc75 last edited by Alero
        @djmarc75
        Fenstergriff
          "type": "state",
          "common": {
            "def": "CLOSED",
            "type": "number",
            "read": true,
            "write": false,
            "min": 0,
            "max": 2,
            "states": {
              "0": "CLOSED",
              "1": "TILTED",
              "2": "OPEN"
            "role": "state",
            "name": "RHS_Wohnzimmer:1.STATE"
          "native": {
            "MIN": "CLOSED",
            "OPERATIONS": 5,
            "MAX": "OPEN",
            "FLAGS": 1,
            "ID ": "STATE",
            "TYPE": "ENUM",
            "DEFAULT": "CLOSED",
            "VALUE_LIST": [
              "CLOSED",
              "TILTED",
              "OPEN"
            "CONTROL": "RHS.STATE",
            "ID": "STATE"
          "from": "system.adapter.hm-rega.0",
          "user": "system.user.admin",
          "ts": 1606565663365,
          "_id": "hm-rpc.1.0007DA4989ADED.1.STATE",
          "acl": {
            "object": 1636,
            "state": 1636,
            "owner": "system.user.admin",
        Fensterkontakt
          "type": "state",
          "common": {
            "def": 0,
            "type": "number",
            "read": true,
            "write": false,
            "min": 0,
            "max": 1,
            "states": {
              "0": "CLOSED",
              "1": "OPEN"
            "unit": "\"\"",
            "role": "value.window",
            "name": "TFK_Terrassentuer:1.STATE"
          "native": {
            "MIN": "CLOSED",
            "UNIT": "\"\"",
            "OPERATIONS": 5,
            "MAX": "OPEN",
            "FLAGS": 1,
            "ID": "STATE",
            "TAB_ORDER": 0,
            "TYPE": "ENUM",
            "VALUE_LIST": [
              "CLOSED",
              "OPEN"
            "CONTROL": "DOOR_SENSOR.STATE"
          "ts": 1683371744664,
          "_id": "hm-rpc.1.0000D8A99E5B80.1.STATE",
          "acl": {
            "object": 1636,
            "state": 1636,
        Schalter licht
          "type": "state",
          "common": {
            "def": false,
            "type": "boolean",
            "read": true,
            "write": true,
            "role": "switch",
            "name": "FS_Garage_Gartenlicht_1_bis_4:1.STATE"
          "native": {
            "CONTROL": "SWITCH.STATE",
            "DEFAULT": false,
            "FLAGS": 1,
            "ID": "STATE",
            "MAX": true,
            "MIN": false,
            "OPERATIONS": 7,
            "TAB_ORDER": 0,
            "TYPE": "BOOL",
            "UNIT": ""
          "ts": 1561403105982,
          "_id": "hm-rpc.0.IEQ0023606.1.STATE",
          "acl": {
            "object": 1636,
            "state": 1636,
        Homoran DJMarc75 2 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Alero last edited by
          @alero sagte in Lampe nach Zeit ein /ausschalten:
          Fenstergriff
          ist der channel, nicht der state!
          Fensterkontakt
          ist wie erwartet Werteliste mit 0 und 1, weder bool, noch text
          Schalter licht
          ist bool
          • DJMarc75
            @alero Dann eben so:
            A Newpicsel 2 Replies Last reply Reply Quote 0
              @djmarc75
              hi,
              vielen dank, ich werde es ausprobieren und bescheid geben.
              Vielen vielen Dank an euch alle.
              • Codierknecht
                Codierknecht Developer Most Active @Homoran last edited by
                @homoran sagte in Lampe nach Zeit ein /ausschalten:
                DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
                • DJMarc75
                  DJMarc75 @Codierknecht last edited by
                  @codierknecht er hat es editiert und steht nun korrekt drin 😉
                    Homoran Global Moderator Administrators @Codierknecht last edited by
                    @codierknecht sagte in Lampe nach Zeit ein /ausschalten:
                    enäää
                    nachträglich editiert ohne Kennzeichnung 😡
                    Strafmaß wird später bekannt gegeben 😂
                    crunchip 1 Reply Last reply Reply Quote 1
                      crunchip Forum Testing Most Active @Homoran last edited by
                      @homoran is der Vorteil wenn man nachgucken kann😜
                        Homoran Global Moderator Administrators @DJMarc75 last edited by
                        @djmarc75 sagte in Lampe nach Zeit ein /ausschalten:
                        @Alero
                        und genau deswegen müssen Edits gekennzeichnet werden, weil sonst die folgenden Posts sinnentstellt werden
                          Alero @Homoran last edited by
                          hi,
                          habe jetzt mal das script gestestet.
                          Die Lampe geht an aber leider nicht wieder aus nach 3 min.
                          • DJMarc75
                            @alero
                            Verschiebe das obere "stop ausschalten" unter Deinen gelben KommentarBaustein.
                              @djmarc75
                              danke
                              werde es testen
                                Alero @Alero last edited by
                                Leider funzt es immer noch nicht
                                • DJMarc75
                                  Blockly zeigen bitte
                                    @djmarc75
                                    HI,
                                    hier das script. Das licht geht zwar an aber nicht wieder aus.
                                    • DJMarc75
                                      @alero kann es sein dass der BWM ständig eine Bewegung registriert ?
                                      Bau mal ein Debug ganz oben ein und beobachte das LOG
                                        @djmarc75
                                          @alero was willst du damit zeigen?
                                          • DJMarc75
                                            @alero stell mal von debug auf error oder warn um
                                            3055
