Troubleshooting NodeJS update
@matthiaspetersen sagte in Troubleshooting NodeJS update:
Der Fehler ist aber leider der Gleiche.
welcher?
@crunchip Hier ist die erste Meldung aus dem Log (taucht insgesamt ja 3x auf, weil 3x ein rebuild versucht wird:
2023-08-27 15:02:30.658 - ^[[32minfo^[[39m: host.iobroker instance system.adapter.ping.0 started with pid 10838 2023-08-27 15:02:31.138 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1080 2023-08-27 15:02:31.139 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: throw err; 2023-08-27 15:02:31.140 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: ^ 2023-08-27 15:02:31.140 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: Error: Cannot find module '@iobroker/types' 2023-08-27 15:02:31.141 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: Require stack: 2023-08-27 15:02:31.141 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/> 2023-08-27 15:02:31.142 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js 2023-08-27 15:02:31.142 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) 2023-08-27 15:02:31.143 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27) 2023-08-27 15:02:31.143 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) 2023-08-27 15:02:31.144 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18) 2023-08-27 15:02:31.144 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iob> 2023-08-27 15:02:31.144 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14) 2023-08-27 15:02:31.145 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) 2023-08-27 15:02:31.145 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) 2023-08-27 15:02:31.146 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12) 2023-08-27 15:02:31.147 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) { 2023-08-27 15:02:31.147 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND', 2023-08-27 15:02:31.148 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: requireStack: [ 2023-08-27 15:02:31.148 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/bui> 2023-08-27 15:02:31.149 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.admin/main.js' 2023-08-27 15:02:31.149 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: ] 2023-08-27 15:02:31.150 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: } 2023-08-27 15:02:31.150 - ^[[31merror^[[39m: host.iobroker Caught by controller[0]: Node.js v18.17.1 2023-08-27 15:02:31.151 - ^[[31merror^[[39m: host.iobroker instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2023-08-27 15:02:31.151 - ^[[32minfo^[[39m: host.iobroker Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards. 2023-08-27 15:02:31.152 - ^[[32minfo^[[39m: host.iobroker system.adapter.admin.0 will be rebuilt 2023-08-27 15:02:31.153 - ^[[33mwarn^[[39m: host.iobroker adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt 2023-08-27 15:02:31.154 - ^[[32minfo^[[39m: host.iobroker iobroker rebuild -
Deinstallier den admin und reinstallier den frisch.
@thomas-braun Wenn ich den Admin-Adapter per
iob del adminlösche, dann bekomme ich ihn nicht weg, weil da diverse andere Adapter (backitup, history, ical etc.) abhängig sind. Meinst Du ein iob del admin?
@matthiaspetersen probier es mit
iobroker rebuild admin --install -
@crunchip @Thomas-Braun Vielen lieben Dank für Eure Unterstützung und Eure schnellen Antworten. Das
iobroker rebuild admin --installhat geholfen.
Hallo zusammen.
Ich hab heute mein Debian Stretch auf Debian Buster (10) upgedatet und natürlich direkt auch nodejs auch direkt auf Version 18.
Das habe ich bei meinem Master-System im Dockercontainer gemacht, sowie auf einem Raspbian Slave System.
Auf dem Raspbian scheint alles gut verlaufen zu sein.
Auf dem Master läuft auch ioBroker, jedoch kann ich keine Module updaten.
Im Admin kommt beim ersten Updateversuch folgende Meldung:
iobroker upgrade heatingcontrol@2.11.1 --debug Update heatingcontrol from @2.10.6 to @2.11.1 host.iobroker Adapter "system.adapter.heatingcontrol.0" is stopped. NPM version: 9.6.7 Installing iobroker.heatingcontrol@2.11.1... (System call) npm WARN skipping integrity check for git dependency ssh://git@github.com/noopkat/browser-serialport.git npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info. npm WARN deprecated jscs-preset-wikimedia@1.0.1: No longer maintained. We recomment migrating to ESLint with eslint-config-wikimedia. npm WARN deprecated topo@3.0.3: This module has moved and is now available at @hapi/topo. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues. npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142 npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142 npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained. npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3 npm WARN deprecated jscs@3.0.7: JSCS has merged with ESLint! See - https://medium.com/@markelog/jscs-end-of-the-line-bc9bf0b3fdb2 npm WARN deprecated joi@14.3.1: This module has moved and is now available at @hapi/joi. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues. npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues. npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies. npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor. npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check https://opencollective.com/babel to support the Babel maintainers npm WARN deprecated appdirectory@0.1.0: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info. npm WARN deprecated uuid@2.0.3: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797) npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js. npm WARN cleanup Failed to remove some directories [ npm WARN cleanup syscall: 'rmdir', npm WARN cleanup path: '/opt/iobroker/node_modules/cpu-features'npm WARN cleanup }npm WARN cleanup ],npm WARN cleanup [npm WARN cleanup '/opt/iobroker/node_modules/cpu-features',npm WARN cleanup [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/cpu-features'] {npm WARN cleanup errno: -39,npm WARN cleanup code: 'ENOTEMPTY',npm WARN cleanup syscall: 'rmdir',npm WARN cleanup path: '/opt/iobroker/node_modules/cpu-features'npm WARN cleanup }npm WARN cleanup ]npm WARN cleanup ] npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@serialport/bindings npm ERR! command failednpm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuildnpm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betretennpm ERR! CXX(target) Release/obj.target/bindings/src/serialport.onpm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassennpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@9.3.1npm ERR! gyp info using node@18.17.1 | linux | x64npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/@serialport/bindings/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.17.1/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.17.1',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.17.1/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/@serialport/bindings',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! gyp info spawn makenpm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);npm ERR! ^~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);npm ERR! ^~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);npm ERR! ^~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);npm ERR! ^~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);npm ERR! ^~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);npm ERR! ^~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:npm ERR! ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’npm ERR! results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));npm ERR! ^npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-array-buffer.h:13,npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8.h:24,npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/node.h:73,npm ERR! from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,npm ERR! ^~~npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate expects 3 arguments, 2 providednpm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,npm ERR! ^~~npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate expects 3 arguments, 2 providednpm ERR! ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’npm ERR! results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));npm ERR! ^npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-array-buffer.h:13,npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8.h:24,npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/node.h:73,npm ERR! from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,npm ERR! ^~~npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate expects 3 arguments, 2 providednpm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,npm ERR! ^~~npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate expects 3 arguments, 2 providednpm ERR! ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’npm ERR! results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));npm ERR! ^npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-array-buffer.h:13,npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8.h:24,npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/node.h:73,npm ERR! from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,npm ERR! ^~~npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate expects 3 arguments, 2 providednpm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,npm ERR! ^~~npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate expects 3 arguments, 2 providednpm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);npm ERR! ^~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’: npm ERR! ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’ npm ERR! results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));npm ERR! ^npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-array-buffer.h:13,npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8.h:24,npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/node.h:73,npm ERR! from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1: npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,npm ERR! ^~~npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate expects 3 arguments, 2 providednpm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,npm ERR! ^~~npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate expects 3 arguments, 2 providednpm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); npm ERR! ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]npm ERR! SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {npm ERR! ^npm ERR! In file included from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/node.h:1014:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]npm ERR! (node::addon_register_func) (regfunc), \npm ERR! ^npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’npm ERR! NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)npm ERR! ^~~~~~~~~~~~~npm ERR! ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’npm ERR! NODE_MODULE(serialport, init);npm ERR! ^~~~~~~~~~~npm ERR! make: *** [bindings.target.mk:116: Release/obj.target/bindings/src/serialport.o] Fehler 1npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2npm ERR! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 5.15.108-1-pvenpm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsnpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v9.3.1npm ERR! gyp ERR! not ok npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-31T13_02_01_266Z-debug-0.log Update "system.adapter.heatingcontrol.0" upload [4] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/heatingcontrol.png heatingcontrol.png image/png upload [3] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/img/info-big.png img/info-big.png image/png upload [2] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/index_m.html index_m.html text/html upload [1] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/style.css style.css text/css upload [0] heatingcontrol.admin /opt/iobroker/node_modules/iobroker.heatingcontrol/admin/words.js words.js application/javascript host.iobroker Adapter "system.adapter.heatingcontrol.0" is started Process exited with code 0Bei Updateversuchen weiterer Module ist die Ausgabe dann kürzer:
$ iobroker upgrade ping@1.6.2 --debug Update ping from @1.5.3 to @1.6.2 NPM version: 9.6.7 Installing iobroker.ping@1.6.2... (System call) npm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/cpu-featuresnpm ERR! dest /opt/iobroker/node_modules/.cpu-features-JirOBYx7npm ERR! errno -39 npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-31T13_16_17_169Z-debug-0.log host.iobroker Cannot install iobroker.ping@1.6.2: 217 ERROR: Process exited with code 25Installiert ist mein System wie folgt:
======================= SUMMARY ======================= v.2023-04-16 Operatingsystem: Debian GNU/Linux 10 (buster) Kernel: 5.15.108-1-pve Installation: lxc Failed to query server: Connection timed out Timezone: User-ID: 1000 X-Server: false Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 12 Nodejs-Installation: /usr/bin/nodejs v18.17.1 /usr/bin/node v18.17.1 /usr/bin/npm 9.6.7 /usr/bin/npx 9.6.7 Recommended versions are nodejs 18.x.y and npm 9.x.y Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 4.1G 2.5G 775M 8.0M 778M 1.6G Swap: 4.1G 0.0K 4.1G Total: 8.2G 2.5G 4.9G Active iob-Instances: 43 Active repo(s): stable ioBroker Core: js-controller 4.0.24 admin 6.3.5 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.admin.1 : admin : iobroker2 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 14436 States: 12673 Size of iob-Database: 14M /opt/iobroker/iobroker-data/objects.jsonl 14M /opt/iobroker/iobroker-data/objects.json.migrated 14M /opt/iobroker/iobroker-data/objects.json.bak.migrated 14M /opt/iobroker/iobroker-data/states.jsonl 2.4M /opt/iobroker/iobroker-data/states.json.migrated 2.4M /opt/iobroker/iobroker-data/states.json.bak.migrated ********************************************************************* Some problems detected, please run iob fix and try to have them fixed ********************************************************************* =================== END OF SUMMARY ====================iob fix habe ich natürlich schon oft ausprobiert.
@tobi81 sagte in Troubleshooting NodeJS update:
ist oben angepinnt bei NEWS
von Tod auf Sterbebett quasi
Warum nicht auf Bullseye ? Welche dubiose Anleitung hast Du verwendet ?
Und wie @crunchip schrieb, die Lösung ist angepinnt
@djmarc75 sagte in Troubleshooting NodeJS update:
weil per update nicht überspringen kann
Ja, leider habe ich ein bisschen verschlafen das System aktuell zu halten und hole das natürlich nach.
Von Stretch --> Buster --> BullseyeDas letzte Upgrade wollte ich erst machen wenn ioBroker wieder läuft.
Die angepinnte News mit meinem Problem habe ich natürlich nicht gesehen, aber trotzdem habe ich ja den Fixer mehrer Male gestartet und das hat leider nichts gebraucht.
Ich habe gerade versucht die aktuellste Version so herunterzuladen
curl -fsL https://iobroker.net/fix.sh | bash -Aber das Ergebnis bei einem Adapterupgradeversuch ist immer noch:
tobias@iobroker:/opt/iobroker$ iob upgrade --debug This upgrade of "yahka" will introduce the following changes: ========================================================================== -> 1.0.3: Corrected empty device list with rebuild -> 1.0.1: we ensured controller 5 compatibility Formatting ========================================================================== BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES! Would you like to upgrade yahka from @0.17.0 to @1.0.3 now? [(y)es, (n)o]: n No upgrade of "yahka" desired. This upgrade of "ping" will introduce the following changes: ========================================================================== -> 1.6.2: Handling of state updates causing crashes with js-controller 5 has been corrected. (Issue #106) Trailing spaces are now removed from ip address and name. Trailing spaces blocked correct operation. (Issue #98) Added json config Added different intervals for online and offline devices implemented export/import of devices -> 1.6.0: Handling of state updates causing crashes with js-controller 5 has been corrected. (Issue #106) Trailing spaces are now removed from ip address and name. Trailing spaces blocked correct operation. (Issue #98) Added json config ========================================================================== Would you like to upgrade ping from @1.5.3 to @1.6.2 now? [(y)es, (n)o]: y Update ping from @1.5.3 to @1.6.2 NPM version: 9.6.7 Installing iobroker.ping@1.6.2... (System call) npm WARN skipping integrity check for git dependency ssh://git@github.com/noopkat/browser-serialport.git npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies. npm WARN deprecated topo@3.0.3: This module has moved and is now available at @hapi/topo. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues. npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142 npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check https://opencollective.com/babel to support the Babel maintainers npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142 npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues. npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3 npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor. npm WARN deprecated appdirectory@0.1.0: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info. npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained. npm WARN deprecated jscs-preset-wikimedia@1.0.1: No longer maintained. We recomment migrating to ESLint with eslint-config-wikimedia. npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797) npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info. npm WARN deprecated uuid@2.0.3: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 npm WARN deprecated joi@14.3.1: This module has moved and is now available at @hapi/joi. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues. npm WARN deprecated jscs@3.0.7: JSCS has merged with ESLint! See - https://medium.com/@markelog/jscs-end-of-the-line-bc9bf0b3fdb2 npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js. npm WARN cleanup Failed to remove some directories [ npm WARN cleanup [ npm WARN cleanup '/opt/iobroker/node_modules/cpu-features', npm WARN cleanup [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/cpu-features'] { npm WARN cleanup errno: -39, npm WARN cleanup code: 'ENOTEMPTY', npm WARN cleanup syscall: 'rmdir', npm WARN cleanup path: '/opt/iobroker/node_modules/cpu-features' npm WARN cleanup } npm WARN cleanup ], npm WARN cleanup [ npm WARN cleanup '/opt/iobroker/node_modules/cpu-features', npm WARN cleanup [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/cpu-features'] { npm WARN cleanup errno: -39, npm WARN cleanup code: 'ENOTEMPTY', npm WARN cleanup syscall: 'rmdir', npm WARN cleanup path: '/opt/iobroker/node_modules/cpu-features' npm WARN cleanup } npm WARN cleanup ] npm WARN cleanup ] npm ERR! code 1 npm ERR! path /opt/iobroker/node_modules/@serialport/bindings npm ERR! command failed npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten npm ERR! CXX(target) Release/obj.target/bindings/src/serialport.o npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen npm ERR! gyp info it worked if it ends with ok npm ERR! gyp info using node-gyp@9.3.1 npm ERR! gyp info using node@18.17.1 | linux | x64 npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3" npm ERR! gyp info spawn /usr/bin/python3 npm ERR! gyp info spawn args [ npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py', npm ERR! gyp info spawn args 'binding.gyp', npm ERR! gyp info spawn args '-f', npm ERR! gyp info spawn args 'make', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/opt/iobroker/node_modules/@serialport/bindings/build/config.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.17.1/include/node/common.gypi', npm ERR! gyp info spawn args '-Dlibrary=shared_library', npm ERR! gyp info spawn args '-Dvisibility=default', npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.17.1', npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp', npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.17.1/<(target_arch)/node.lib', npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/@serialport/bindings', npm ERR! gyp info spawn args '-Dnode_engine=v8', npm ERR! gyp info spawn args '--depth=.', npm ERR! gyp info spawn args '--no-parallel', npm ERR! gyp info spawn args '--generator-output', npm ERR! gyp info spawn args 'build', npm ERR! gyp info spawn args '-Goutput_dir=.' npm ERR! gyp info spawn args ] npm ERR! gyp info spawn make npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ] npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’: npm ERR! ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); npm ERR! ^~~~~~~~~~~~~ npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’: npm ERR! ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); npm ERR! ^~~~~~~~~~~~~~~ npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’: npm ERR! ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); npm ERR! ^~~~~~~~~~~~~~ npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’: npm ERR! ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); npm ERR! ^~~~~~~~~~~~~~ npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’: npm ERR! ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); npm ERR! ^~~~~~~~~~~~ npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’: npm ERR! ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); npm ERR! ^~~~~~~~~~~~ npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’: npm ERR! ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’ npm ERR! results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts)); npm ERR! ^ npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-array-buffer.h:13, npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8.h:24, npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/node.h:73, npm ERR! from ../../../nan/nan.h:60, npm ERR! from ../src/./serialport.h:6, npm ERR! from ../src/serialport.cpp:1: npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’ npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, npm ERR! ^~~ npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate expects 3 arguments, 2 provided npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’ npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index, npm ERR! ^~~ npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate expects 3 arguments, 2 provided npm ERR! ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’ npm ERR! results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr)); npm ERR! ^ npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-array-buffer.h:13, npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8.h:24, npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/node.h:73, npm ERR! from ../../../nan/nan.h:60, npm ERR! from ../src/./serialport.h:6, npm ERR! from ../src/serialport.cpp:1: npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’ npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, npm ERR! ^~~ npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate expects 3 arguments, 2 provided npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’ npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index, npm ERR! ^~~ npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate expects 3 arguments, 2 provided npm ERR! ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’ npm ERR! results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd)); npm ERR! ^ npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-array-buffer.h:13, npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8.h:24, npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/node.h:73, npm ERR! from ../../../nan/nan.h:60, npm ERR! from ../src/./serialport.h:6, npm ERR! from ../src/serialport.cpp:1: npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’ npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, npm ERR! ^~~ npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate expects 3 arguments, 2 provided npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’ npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index, npm ERR! ^~~ npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate expects 3 arguments, 2 provided npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’: npm ERR! ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm ERR! uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); npm ERR! ^~~~~~~~~~~~~~~~~~~~ npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’: npm ERR! ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’ npm ERR! results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate)); npm ERR! ^ npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-array-buffer.h:13, npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8.h:24, npm ERR! from /home/iobroker/.cache/node-gyp/18.17.1/include/node/node.h:73, npm ERR! from ../../../nan/nan.h:60, npm ERR! from ../src/./serialport.h:6, npm ERR! from ../src/serialport.cpp:1: npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’ npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, npm ERR! ^~~ npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:244:37: note: candidate expects 3 arguments, 2 provided npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’ npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index, npm ERR! ^~~ npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-object.h:247:37: note: candidate expects 3 arguments, 2 provided npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’: npm ERR! ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); npm ERR! ^~~~~~~~~~~~~~ npm ERR! ../src/serialport.cpp: At global scope: npm ERR! ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] npm ERR! SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) { npm ERR! ^ npm ERR! ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] npm ERR! SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { npm ERR! ^ npm ERR! In file included from ../../../nan/nan.h:60, npm ERR! from ../src/./serialport.h:6, npm ERR! from ../src/serialport.cpp:1: npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/node.h:1014:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] npm ERR! (node::addon_register_func) (regfunc), \ npm ERR! ^ npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’ npm ERR! NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) npm ERR! ^~~~~~~~~~~~~ npm ERR! ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’ npm ERR! NODE_MODULE(serialport, init); npm ERR! ^~~~~~~~~~~ npm ERR! make: *** [bindings.target.mk:116: Release/obj.target/bindings/src/serialport.o] Fehler 1 npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2 npm ERR! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23) npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28) npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12) npm ERR! gyp ERR! System Linux 5.15.108-1-pve npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings npm ERR! gyp ERR! node -v v18.17.1 npm ERR! gyp ERR! node-gyp -v v9.3.1 npm ERR! gyp ERR! not ok npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-31T13_46_32_906Z-debug-0.log upload [4] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/img/info-big.png img/info-big.png image/png upload [3] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index.html index.html text/html upload [2] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index_m.html index_m.html text/html upload [1] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png ping.png image/png upload [0] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/words.js words.js application/javascriptYahka habe ich erst einmal übersprungen, da ich denke dass der Ping Adapter die wenigsten Probleme machen sollte.
@tobi81 Wenn Du ein aktuelles Backup hast dann tu Dir einen Gefallen und installiere Debian neu - gleich mit Bullseye in der 64 Bit LITE-Version und spül das Backup dann zurück.
@djmarc75 Wenn es keine anderen Dinge mehr gibt die ich machen kann, dann muss ich den Container zurückspielen und eine Neuinstallation die Tage machen.
Aber vielleicht hat noch jemand eine Idee.
Ich hab jetzt eine Neuinstallation auf Debian Bookworm gemacht und bin gerade dabei ioBroker wieder komplett an's Laufen zu bekommen.
Hat sich also erledigt. -
mein ioBroker läuft auf einem Mac mini M2 mit macOS Ventura.
Ich nutze aktuell node v16.17.0 npm 8.15.0 js-controller 4.0.24Ich finde keine aktuelle Anleitung für's korrekte Updaten von node.js für meine Konfiguration - kann mir jemand helfen?
Reicht es die neue node Version als .pkg Installerdatei für macOS runterzuladen auf https://nodejs.org/de und auszuführen?
Muss ich die alte deinstallieren, muss ich nach der Installation noch irgendwelche Verknüpfungen im Terminal herstellen?
Möchte mich nicht durchprobieren mit dem Ergebnis, dass im schlimmsten Fall nichts mehr läuft und ich mich mit Backups zurückspielen rumschlage und wieder auf der alten Version bin.
Bin über Hilfe zu den verschiedenen Schritten beim Update dankbar.
Hallo Leute,
das große Zittern beginnt wieder, nachdem mir mein ioB empfiehlt, Controller, Admin etc. upzudaten, was aber nicht geht, ehe man nodejs geupdatet hat.
Ich habe auf meinem Raspi4 noch Buster mit nodejs 14.21.3.Ich glaube, dass ich auf Bullseye updaten konnte. Zumindest bin ich die Anleitung von @Thomas-Braun durchgegangen. Es kam bis zum Ende keine Fehlermeldung.
Nun wollte ich nodejs 14 löschen und die aktuelle Version 18 installieren. Der Puls steigt. Bereits beim Versuch, zu löschen, kommen Fehlermeldungen:
pi@raspberrypi:~ $ sudo apt purge --autoremove nodejs* npm node-* Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Hinweis: »nodejs-legacy« wird für das Suchmuster »nodejs*« gewählt. Hinweis: »nodejs« wird für das Suchmuster »nodejs*« gewählt. Hinweis: »nodejs-dev« wird für das Suchmuster »nodejs*« gewählt. Hinweis: »nodejs-doc« wird für das Suchmuster »nodejs*« gewählt. Hinweis: »nodejs« wird an Stelle von »nodejs-legacy« gewählt. Hinweis: »nodejs« wird an Stelle von »nodejs-dev« gewählt. E: Paket node-v14.9.0-linux-armv6l kann nicht gefunden werden. E: Mittels des Musters »node-v14.9.0-linux-armv6l« konnte kein Paket gefunden werden. E: Paket node-v14.9.0-linux-armv6l.tar.xz kann nicht gefunden werden. E: Mittels des Musters »node-v14.9.0-linux-armv6l.tar.xz« konnte kein Paket gefunden werden.Weiter komme ich nicht.
Ist das der richtige Weg?
sudo rm `sudo find / -name nodesource.gpg` sudo rm `sudo find / -name nodesource.key` sudo rm /etc/apt/sources.list.d/nodesource.listNODE_MAJOR=18 sudo apt update sudo apt install -y ca-certificates curl gnupg sudo mkdir -p /etc/apt/keyrings curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_${NODE_MAJOR}.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list sudo apt update sudo apt install nodejsKönnen die Profis weiterhelfen?
Vielen Dank!!
Stoni -
@stoni sagte in Troubleshooting NodeJS update:
Pi4
Und warum liegt dann da eine Datei node-v14.9.0-linux-armv6lin deinem Home herum? Hat da a) nix zu suchen und ist b) auch falsch.
Lösch die.
