    2. English
    3. ioBroker general
    4. Neato Botvac adapter - further development
      bourton88 @PeterVoronov last edited by
      @petervoronov
      Ohh thats cool. Thanks!!
      I stopped the Adapter just for an hour and it works 🙂
      I have another assumption because unfortunately i changed two things. I stopped the adapter AND i recognized that the clock-time from the running ioBroker instance was not set to the correct time. So i changed that as well.
      Maybe there is an Sync-Problem with the Neato-Server when the time doesn´t fit?
        PeterVoronov @bourton88 last edited by
        Пользователь @bourton88 написал в Neato Botvac adapter - further development:
        @petervoronov
        It the code for connection I not saw the time-sync recs or functions...
        But by my understanding, it is some limitation on the cloud for the connections in the same time from one account...
          @petervoronov
          After a long time a had the same issue as before (see post from 23. Mai 2021, 10:11)
          This time i checked your recommendation first but it doesn´t help. Then i checked the clock-time at my Server again and it doesn´t fit with the current time. So i changed the Server time back to the current time and it works well.
          There must be a dependency to the time-sync.
            Thomas Braun Most Active @bourton88 last edited by
            @bourton88
            Correct timezones in your system?
            date && date -u
              bourton88 @Thomas Braun last edited by
              My Server is a QNAP-NAS. So i just correct the time in the settings.
                danielmayer @bourton88 last edited by danielmayer
                @PeterVoronov
                Hey Peter,
                login is again (?) not working. I found this thread and installed dev-1.0.4-1, but log says "botvac.1 2023-07-15 11:51:19.359 warn login failed"
                As such, no objects have been discovered/installed.
                I recognize that there are several neato-plugins for several utilities (Smarthome), which seemed to have the same problem and needed some update work. So I suppose Neato changed their login procedure slightly.
                Could you provide another update please? I have absolutely no competence in JS or PHP or any programming language...
                Many thanks,
                Daniel
                  PeterVoronov @danielmayer last edited by
                  Hi @danielmayer .
                  Unfortunately my botvac broke a few years ago ... Currently I can't check the plugin.
                  At least - it can't find any robots, as it not logged in the Neato system.
                  That's why currently I have no possibility to help ....
                  But I have no any issues with login of plugin...
                  Only "no robots" message ...
                    csp @PeterVoronov last edited by
                    @petervoronov
                    Hi Peter,
                    the plugin was working fine for quite some time, but after I updated to the latest Node.js 18... it stopped working.
                    Reinstalling doesn't work either, I'm getting following error:
                    Any idea how to get it working again? It seems the adapter is no longer compatible...
                    Thanks,
                    Thomas
                    *host.iobroker
                    2023-08-31 08:54:49.650	info	Rebuild for adapter system.adapter.botvac.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                    host.iobroker
                    2023-08-31 08:54:49.650	error	instance system.adapter.botvac.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.iobroker
                    2023-08-31 08:54:49.650	error	Caught by controller[0]: Node.js v18.17.1
                    host.iobroker
                    2023-08-31 08:54:49.650	error	Caught by controller[0]: }
                    host.iobroker
                    2023-08-31 08:54:49.650	error	Caught by controller[0]: ]
                    host.iobroker
                    2023-08-31 08:54:49.650	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/main.js'
                    host.iobroker
                    2023-08-31 08:54:49.650	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js',
                    host.iobroker
                    2023-08-31 08:54:49.650	error	Caught by controller[0]: requireStack: [
                    host.iobroker
                    2023-08-31 08:54:49.649	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                    host.iobroker
                    2023-08-31 08:54:49.649	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
                    host.iobroker
                    2023-08-31 08:54:49.649	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
                    host.iobroker
                    2023-08-31 08:54:49.649	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
                    host.iobroker
                    2023-08-31 08:54:49.649	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                    host.iobroker
                    2023-08-31 08:54:49.649	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                    host.iobroker
                    2023-08-31 08:54:49.649	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js:46:25)
                    host.iobroker
                    2023-08-31 08:54:49.649	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
                    host.iobroker
                    host.iobroker
                    2023-08-31 08:54:49.648	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                    host.iobroker
                    2023-08-31 08:54:49.648	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                    host.iobroker
                    2023-08-31 08:54:49.648	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/main.js
                    host.iobroker
                    2023-08-31 08:54:49.648	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/lib/utils.js
                    host.iobroker
                    2023-08-31 08:54:49.648	error	Caught by controller[0]: Require stack:
                    host.iobroker
                    2023-08-31 08:54:49.648	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                    host.iobroker
                    2023-08-31 08:54:49.648	error	Caught by controller[0]: ^
                    host.iobroker
                    2023-08-31 08:54:49.648	error	Caught by controller[0]: throw err;
                    host.iobroker
                    2023-08-31 08:54:49.647	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
                    host.iobroker
                    2023-08-31 08:54:49.444	info	instance system.adapter.botvac.0 started with pid 22369
                    host.iobroker
                    2023-08-31 08:54:49.370	info	iobroker npm-rebuild: exit 0
                    host.iobroker
                    2023-08-31 08:54:48.355	info	iobroker npm-rebuild: rebuilt dependencies successfullyRebuilding native modules done*
                      PeterVoronov @csp last edited by
                      @csp
                      I have the same version of node - 18.17.1.
                      As I have no more botvac devices, I can only check the starting adapter and login to the api.
                      For me it's working. But when I made migration to node 18th, I wiped the node_modules directory fully.
                      I will not recommend to follow my way, as it required some additional understanding and manual work.
                      You can try at least to follow the recommendations from error log - execute "npm install --production" in adapter directory manually.
                        @petervoronov I tried that already. It is a bit difficult, as I'm running it on Synology server in docker.
                        It did run through though, but not worked at the end.
                        Any idea on how to wipe the adapter fully? (Not all of course, just this one)
                        Happy to follow instructions.
                        Thomas
                          csp @csp last edited by
                          @csp I just did it again, no success.
                          So I deinstalled the adapter and manually deleted the module folder.
                          Reboot ioBroker.
                          Reinstall bot vac adapter -> OK
                          Putting credentials in and restart... -> same issue. ioBroker tries 3 times to rebuild and fails...
                          host.iobroker
                          2023-09-01 09:37:08.038	info	iobroker npm-rebuild: Rebuilding native modules ...
                          host.iobroker
                          2023-09-01 09:37:06.088	info	iobroker rebuild
                          host.iobroker
                          2023-09-01 09:37:06.088	warn	adapter "botvac" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                          host.iobroker
                          2023-09-01 09:37:06.087	info	system.adapter.botvac.0 will be rebuilt
                          host.iobroker
                          2023-09-01 09:37:06.087	info	Adapter system.adapter.botvac.0 needs rebuild and will be restarted afterwards.
                          host.iobroker
                          2023-09-01 09:37:06.086	error	instance system.adapter.botvac.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          host.iobroker
                          2023-09-01 09:37:06.086	error	Caught by controller[0]: Node.js v18.17.1
                          host.iobroker
                          2023-09-01 09:37:06.086	error	Caught by controller[0]: }
                          host.iobroker
                          2023-09-01 09:37:06.086	error	Caught by controller[0]: ]
                          host.iobroker
                          2023-09-01 09:37:06.086	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/main.js'
                          host.iobroker
                          2023-09-01 09:37:06.086	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js',
                          host.iobroker
                          2023-09-01 09:37:06.086	error	Caught by controller[0]: requireStack: [
                          host.iobroker
                          2023-09-01 09:37:06.085	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                          host.iobroker
                          2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
                          host.iobroker
                          2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
                          host.iobroker
                          2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
                          host.iobroker
                          2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                          host.iobroker
                          2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                          host.iobroker
                          2023-09-01 09:37:06.085	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js:46:25)
                          host.iobroker
                          2023-09-01 09:37:06.079	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
                          host.iobroker
                          2023-09-01 09:37:06.079	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
                          host.iobroker
                          2023-09-01 09:37:06.079	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                          host.iobroker
                          2023-09-01 09:37:06.079	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                          host.iobroker
                          2023-09-01 09:37:06.079	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/main.js
                          host.iobroker
                          2023-09-01 09:37:06.079	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/lib/utils.js
                          host.iobroker
                          2023-09-01 09:37:06.079	error	Caught by controller[0]: Require stack:
                          host.iobroker
                          2023-09-01 09:37:06.079	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                          host.iobroker
                          2023-09-01 09:37:06.079	error	Caught by controller[0]: ^
                          host.iobroker
                          2023-09-01 09:37:06.078	error	Caught by controller[0]: throw err;
                          host.iobroker
                          2023-09-01 09:37:06.078	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
                          host.iobroker
                          2023-09-01 09:37:02.812	info	instance system.adapter.botvac.0 started with pid 912
                          host.iobroker
                          2023-09-01 09:36:57.818	info	iobroker exit 0
                          host.iobroker
                          2023-09-01 09:36:56.009	info	iobroker host.iobroker object system.adapter.botvac.0 created
                          host.iobroker
                          2023-09-01 09:36:54.323	info	iobroker host.iobroker object system.adapter.botvac.0.logLevel created
                          host.iobroker
                          2023-09-01 09:36:53.946	info	iobroker host.iobroker object system.adapter.botvac.0.sigKill created
                          host.iobroker
                          2023-09-01 09:36:53.779	info	iobroker host.iobroker object system.adapter.botvac.0.eventLoopLag created
                          host.iobroker
                          2023-09-01 09:36:53.594	info	iobroker host.iobroker object system.adapter.botvac.0.outputCount created
                          host.iobroker
                          2023-09-01 09:36:53.420	info	iobroker host.iobroker object system.adapter.botvac.0.inputCount created
                          host.iobroker
                          2023-09-01 09:36:53.287	info	iobroker host.iobroker object system.adapter.botvac.0.uptime created
                          host.iobroker
                          2023-09-01 09:36:53.061	info	iobroker host.iobroker object system.adapter.botvac.0.memRss created
                          host.iobroker
                          2023-09-01 09:36:52.850	info	iobroker host.iobroker object system.adapter.botvac.0.memHeapTotal created
                          host.iobroker
                          2023-09-01 09:36:52.603	info	iobroker host.iobroker object system.adapter.botvac.0.memHeapUsed created
                          host.iobroker
                          2023-09-01 09:36:51.671	info	iobroker host.iobroker object system.adapter.botvac.0.cputime created
                          host.iobroker
                          2023-09-01 09:36:48.434	info	iobroker host.iobroker object system.adapter.botvac.0.cpu created
                          host.iobroker
                          2023-09-01 09:36:48.027	info	iobroker host.iobroker object system.adapter.botvac.0.compactMode created
                          host.iobroker
                          2023-09-01 09:36:47.669	info	iobroker host.iobroker object system.adapter.botvac.0.connected created
                          host.iobroker
                          2023-09-01 09:36:47.477	info	iobroker host.iobroker object system.adapter.botvac.0.alive created
                          host.iobroker
                          2023-09-01 09:36:47.342	info	iobroker host.iobroker create instance botvac
                          host.iobroker
                          2023-09-01 09:36:46.191	info	iobroker host.iobroker object system.adapter.botvac created/updated
                            Thomas Braun Most Active @csp last edited by
                            @csp
                            I just did a crosscheck on my setup.
                            The adapter installs without issues here.
                            Check your setup, especially the nodejs install.
                            iob diag
                            may be helpfull.
                              csp @Thomas Braun last edited by
                              @thomas-braun Installation works fine on my end as well. But as soon as I want to log in, it doesn't work.
                              What do I need to do exactly? Can you help?
                                @csp
                                No, I don't own that device, I just checked the adapter installation.
                                  @thomas-braun but maybe how I can check nodejs with iob diag?
                                    @csp sagte in Neato Botvac adapter - further development:
                                    iob diag
                                    Just run it in your terminal and copy the output in the forum.
                                    iob diag
                                      @thomas-braun I think I'm doing something wrong...
                                      root@iobroker:/opt/iobroker# iob diag
                                      iobroker [command]
                                      Commands:
                                        iobroker setup                                               Setup ioBroker
                                        iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
                                        iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
                                        iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
                                        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                                        iobroker info                                                Shows the host info
                                        iobroker logs [<adapter>]                                    Monitor log
                                        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                                        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                                        iobroker rebuild [<module>]                                  Rebuild all native modules or path
                                        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                                        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                                        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                                        iobroker update [<repositoryUrl>]                            Update repository and list adapters
                                        iobroker upgrade                                             Upgrade management
                                        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                                        iobroker object                                              Object management  [aliases: o]
                                        iobroker state                                               State management  [aliases: s]
                                        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                                        iobroker list <type> [<filter>]                              List all entries, like objects
                                        iobroker chmod <mode> <file>                                 Change file rights
                                        iobroker chown <user> <group> <file>                         Change file ownership
                                        iobroker touch <file>                                        Touch file
                                        iobroker rm <file>                                           Remove file
                                        iobroker file                                                File management
                                        iobroker user                                                User commands
                                        iobroker group                                               group management
                                        iobroker host <hostname>                                     Set host to given hostname
                                        iobroker set <adapter>.<instance>                            Change settings of adapter config
                                        iobroker license <license.file or license.text>              Update license by given file
                                        iobroker cert                                                Certificate management
                                        iobroker clean <yes>                                         Clears all objects and states
                                        iobroker backup                                              Create backup
                                        iobroker restore <backup name or path>                       Restore a specified backup
                                        iobroker validate <backup name or path>                      Validate a specified backup
                                        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                                        iobroker repo [<name>]                                       Show repo information
                                        iobroker uuid                                                Show uuid of the installation  [aliases: id]
                                        iobroker unsetup                                             Reset license, installation secret and language
                                        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                                        iobroker multihost                                           Multihost management
                                        iobroker compact                                             compact group management
                                        iobroker plugin                                              Plugin management
                                        iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
                                        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                                      Options:
                                        --help  Show help  [boolean]
                                        @csp
                                        iob stop
                                        iob fix
                                        iob start
                                        iob diag
                                        C 2 Replies Last reply Reply Quote 0
                                          v.2023-04-16
                                          Operatingsystem: Debian GNU/Linux 11 (bullseye)
                                          Kernel: 4.4.180+
                                          Installation: Docker
                                          Timezone: Etc/UTC
                                          User-ID: 0
                                          X-Server: false
                                          Pending OS-Updates: 121
                                          Pending iob updates: 0
                                          Nodejs-Installation: /usr/bin/nodejs v12.22.7
                                          /usr/local/bin/node v18.17.1
                                          /usr/local/bin/npm 9.6.7
                                          /usr/local/bin/npx 9.6.7
                                          Recommended versions are nodejs 18.x.y and npm 9.x.y
                                          *** nodejs is NOT correctly installed ***
                                          MEMORY:
                                          total used free shared buff/cache available
                                          Mem: 9.8G 3.7G 407M 558M 5.6G 5.2G
                                          Swap: 7.9G 419M 7.5G
                                          Total: 17G 4.2G 7.9G
                                          Active iob-Instances: 34
                                          Active repo(s): default, beta
                                          ioBroker Core: js-controller 5.0.12
                                          admin 6.9.1
                                          ioBroker Status: iobroker is running on this host.
                                          Objects type: jsonl
                                          States type: jsonl
                                          • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          Objects: 20245
                                          States: 3
                                          Size of iob-Database:
                                          25M /opt/iobroker/iobroker-data/objects.jsonl
                                          13M /opt/iobroker/iobroker-data/objects.json.migrated
                                          13M /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                          61M /opt/iobroker/iobroker-data/states.jsonl
                                          1.9M /opt/iobroker/iobroker-data/states.json.migrated
                                          1.9M /opt/iobroker/iobroker-data/states.json.bak.migrated
                                            @thomas-braun here you go:
                                            v.2023-04-16
                                            Kernel: 4.4.180+
                                            Timezone: Etc/UTC
                                            User-ID: 0
                                            X-Server: false
                                            MEMORY:
                                            admin 6.9.1
                                            Objects type: jsonl
                                            States type: jsonl
                                            Objects: 20245
                                            States: 3
                                            68
                                            9549
