    4. Support Adapter Energiefluss-erweitert v0.7.7
    • SKB
      SKB Developer Most Active @Wal last edited by
      @wal Korrekt. Changelog steht ja oben 😉
      • Wal
        Wal Developer @SKB last edited by
        @skb ,
        habe den Adapter deinstalliert und die Alpha 16 installiert.
        Der Adapter startet ohne Probleme, danach ein Backup eingespielt und er stürtzt ab.
            "basic": {
                "enable_grid": true,
                "enable_animation": false,
                "enable_area_catch": true,
                "enable_config_icon": true,
                "enable_last_id": false,
                "enable_icon_proxy": false,
                "height": 540,
                "width": 600,
                "styles": "",
                "font": {
                    "family": "\"Arial\", sans-serif",
                    "size": "20",
                    "color": "",
                    "fill": "",
                    "align": "middle"
                "rect": {
                    "height": 100,
                    "width": 100,
                    "corners": 10
                "circle": {
                    "radius": 50
                "elm": {
                    "stroke_width": 5,
                    "color": "",
                    "fill": "",
                    "pos_x": 50,
                    "pos_y": 50
                "icon": {
                    "height": 24,
                    "width": 24,
                    "color": ""
            "calculation": {
                "battery": {
                    "dod": 0,
                    "capacity": 0,
                    "percent": -1,
                    "charge": -1,
                    "charge_prop": false,
                    "charge_kw": false,
                    "discharge": -1,
                    "discharge_prop": false,
                    "discharge_kw": false
                "consumption": {
                    "production": [
                        -1
                    "production_kw": false,
                    "gridFeed": -1,
                    "gridFeed_kw": false,
                    "gridFeed_prop": false,
                    "gridConsume": -1,
                    "gridConsume_kw": false,
                    "gridConsume_prop": false,
                    "batteryCharge": -1,
                    "batteryCharge_kw": false,
                    "batteryCharge_prop": false,
                    "batteryDischarge": -1,
                    "batteryDischarge_kw": false,
                    "batteryDischarge_prop": false
            "animation": {
                "stroke": "#ffce4a",
                "stroke_dasharray": "10 17 10 17 10  72",
                "stroke_width": "6",
                "animation_duration": "2000",
                "stroke_linecap": "round",
                "animation_timing_function": "linear"
            "animation_configuration": {
                "dots": "3",
                "distance": "17",
                "length": "10"
            "line": {
                "stroke_width": "8",
                "stroke": "#000000"
            "elements": {
                "2": {
                    "position": 0,
                    "type": "text",
                    "subType": "datasource",
                    "id": 2,
                    "pos_x": 49,
                    "pos_y": 41,
                    "color": "none",
                    "fill": "rgb(195, 255, 81)",
                    "font_family": "Arial, sans-serif",
                    "font_size": 18,
                    "align": "middle",
                    "text": "ID 2",
                    "unit": "kW",
                    "source": 2,
                    "source_option": -1,
                    "source_display": "value",
                    "shadow": "",
                    "threshold": 0,
                    "calculate_kw": true,
                    "convert": false,
                    "decimal_places": 2,
                    "action": "none",
                    "subtract": [
                        -1
                    "frame": "_overlay"
                "5": {
                    "position": 0,
                    "type": "rect",
                    "id": 5,
                    "rx": 10,
                    "height": 100,
                    "width": 100,
                    "pos_x": 1,
                    "pos_y": 1,
                    "fill": "none",
                    "color": "rgb(195, 255, 81)",
                    "stroke": 2,
                    "shadow": "rgba(0,0,0,0.7)",
                    "frame": "_overlay",
                    "fill_value": null,
                    "fill_type": "percent",
                    "fill_direction": 90,
                    "fill_max": null,
                    "border_value": null,
                    "border_type": -1,
                    "border_direction": "cw",
                    "border_style": "round",
                    "border_max": null,
                    "border_reverse_value": null,
                    "border_reverse": false,
                    "border_start": 180,
                    "source": 2,
                    "threshold": 0
                "6": {
                    "position": 0,
                    "type": "icon",
                    "id": "6",
                    "icon": "mdi:solar-panel",
                    "width": 24,
                    "height": 24,
                    "pos_x": "39",
                    "pos_y": "5",
                    "shadow": "",
                    "source": -1,
                    "threshold": 0,
                    "action": "none"
                "7": {
                    "position": 1,
                    "type": "rect",
                    "id": 7,
                    "rx": 10,
                    "height": 100,
                    "width": 100,
                    "pos_x": 221,
                    "pos_y": 221,
                    "fill": "none",
                    "color": "rgb(0, 209, 255)",
                    "stroke": 2,
                    "fill_value": null,
                    "fill_max": null,
                    "border_type": -1,
                    "border_max": null,
                    "source": 1,
                    "threshold": 0
                "9": {
                    "position": 1,
                    "type": "text",
                    "id": 9,
                    "pos_x": 271,
                    "pos_y": 263,
                    "color": "none",
                    "fill": "rgb(0, 209, 255)",
                    "font_size": 18,
                    "align": "middle",
                    "text": "ID 9",
                    "unit": "kW",
                    "source": 1,
                    "shadow": "",
                    "threshold": 0,
                    "convert": false,
                    "action": "none",
                    "subtract": [
                        -1
                    "frame": "_overlay"
                "10": {
                    "position": 2,
                    "type": "text",
                    "id": 10,
                    "pos_x": 51,
                    "pos_y": 74,
                    "color": "none",
                    "font_size": 14,
                    "align": "middle",
                    "text": "Produktion",
                    "shadow": "",
                    "frame": "_overlay"
                "11": {
                    "position": 3,
                    "type": "text",
                    "id": 11,
                    "pos_x": 271,
                    "pos_y": 297,
                    "color": "none",
                    "font_size": 14,
                    "align": "middle",
                    "text": "Gesamt",
                    "shadow": "",
                    "frame": "_overlay"
                "12": {
                    "position": 1,
                    "type": "icon",
                    "id": "12",
                    "icon": "mdi:house-city",
                    "width": 24,
                    "height": 24,
                    "pos_x": "259",
                    "pos_y": "227",
                    "shadow": "",
                    "source": -1,
                    "threshold": 0,
                    "action": "none"
                "14": {
                    "position": 2,
                    "type": "rect",
                    "id": 14,
                    "rx": 10,
                    "height": 100,
                    "width": 100,
                    "pos_x": 1,
                    "pos_y": 301,
                    "fill": "none",
                    "color": "rgb(255, 0, 0)",
                    "stroke": 2,
                    "fill_value": null,
                    "fill_max": null,
                    "border_type": -1,
                    "border_max": null,
                    "source": 0,
                    "threshold": 0
                "19": {
                    "position": 4,
                    "type": "text",
                    "id": 19,
                    "pos_x": 50,
                    "pos_y": 343,
                    "color": "none",
                    "fill": "rgb(255, 0, 0)",
                    "font_size": 18,
                    "align": "middle",
                    "text": "ID 19",
                    "unit": "kW",
                    "source": 0,
                    "shadow": "",
                    "threshold": 0,
                    "convert": true,
                    "action": "none",
                    "subtract": [
                        -1
                    "frame": "_overlay"
                "20": {
                    "position": 2,
                    "type": "icon",
                    "id": "20",
                    "icon": "mdi:electricity-from-grid",
                    "width": 24,
                    "height": 24,
                    "pos_x": "38",
                    "pos_y": "307",
                    "shadow": "",
                    "source": -1,
                    "threshold": 0,
                    "action": "none"
                "21": {
                    "position": 5,
                    "type": "text",
                    "id": 21,
                    "pos_x": 50,
                    "pos_y": 377,
                    "color": "none",
                    "font_size": 14,
                    "align": "middle",
                    "text": "Netz",
                    "shadow": "",
                    "frame": "_overlay"
                "22": {
                    "position": 3,
                    "type": "rect",
                    "id": 22,
                    "rx": 10,
                    "height": 100,
                    "width": 100,
                    "pos_x": 121,
                    "pos_y": 1,
                    "fill": "none",
                    "color": "rgb(255, 206, 74)",
                    "stroke": 2,
                    "fill_value": null,
                    "fill_max": null,
                    "border_type": -1,
                    "border_max": null,
                    "source": -1,
                    "threshold": 0
                "24": {
                    "position": 6,
                    "type": "text",
                    "id": 24,
                    "pos_x": 171,
                    "pos_y": 77,
                    "color": "none",
                    "fill": "rgb(255, 206, 74)",
                    "font_size": 14,
                    "align": "middle",
                    "text": "Proxmox",
                    "shadow": "",
                    "frame": "_overlay"
                "26": {
                    "position": 7,
                    "type": "text",
                    "id": 26,
                    "pos_x": 171,
                    "pos_y": 43,
                    "color": "none",
                    "font_size": 18,
                    "align": "middle",
                    "text": "ID 26",
                    "unit": "W",
                    "source": 3,
                    "shadow": "",
                    "threshold": 0,
                    "calculate_kw": false,
                    "convert": false,
                    "decimal_places": 0,
                    "action": "none",
                    "subtract": [
                        -1
                    "frame": "_overlay"
                "27": {
                    "position": 4,
                    "type": "rect",
                    "id": 27,
                    "rx": 10,
                    "height": 100,
                    "width": 100,
                    "pos_x": 241,
                    "pos_y": 1,
                    "fill": "none",
                    "stroke": 2,
                    "fill_value": null,
                    "fill_max": null,
                    "border_type": -1,
                    "border_max": null,
                    "source": -1,
                    "threshold": 0
                "28": {
                    "position": 8,
                    "type": "text",
                    "id": 28,
                    "pos_x": 291,
                    "pos_y": 77,
                    "color": "none",
                    "font_size": 14,
                    "align": "middle",
                    "text": "Tiefkühltruhe",
                    "shadow": "",
                    "frame": "_overlay"
                "29": {
                    "position": 9,
                    "type": "text",
                    "id": 29,
                    "pos_x": 291,
                    "pos_y": 43,
                    "color": "none",
                    "font_size": 18,
                    "align": "middle",
                    "text": "ID 29",
                    "unit": "W",
                    "source": 4,
                    "shadow": "",
                    "threshold": 0,
                    "convert": false,
                    "action": "none",
                    "subtract": [
                        -1
                    "frame": "_overlay"
                "31": {
                    "position": 5,
                    "type": "rect",
                    "id": 31,
                    "rx": 10,
                    "height": 100,
                    "width": 100,
                    "pos_x": 363,
                    "pos_y": 1,
                    "fill": "none",
                    "stroke": 2,
                    "fill_value": null,
                    "fill_max": null,
                    "border_type": -1,
                    "border_max": null,
                    "source": -1,
                    "threshold": 0
                "32": {
                    "position": 10,
                    "type": "text",
                    "id": 32,
                    "pos_x": 413,
                    "pos_y": 77,
                    "color": "none",
                    "font_size": 14,
                    "align": "middle",
                    "text": "Fernseher",
                    "shadow": "",
                    "frame": "_overlay"
                "33": {
                    "position": 11,
                    "type": "text",
                    "id": 33,
                    "pos_x": 413,
                    "pos_y": 43,
                    "color": "none",
                    "font_size": 18,
                    "align": "middle",
                    "text": "ID 33",
                    "unit": "W",
                    "source": 5,
                    "shadow": "",
                    "threshold": 0,
                    "convert": false,
                    "action": "none",
                    "subtract": [
                        -1
                    "frame": "_overlay"
                "35": {
                    "position": 3,
                    "type": "icon",
                    "id": "35",
                    "width": 24,
                    "height": 24,
                    "pos_x": "158",
                    "pos_y": "6",
                    "shadow": "",
                    "source": -1,
                    "threshold": 0,
                    "action": "none"
                "36": {
                    "position": 4,
                    "type": "icon",
                    "id": "36",
                    "width": 24,
                    "height": 24,
                    "pos_x": "278",
                    "pos_y": "7",
                    "shadow": "",
                    "source": -1,
                    "threshold": 0,
                    "action": "none"
                "37": {
                    "position": 5,
                    "type": "icon",
                    "id": "37",
                    "width": 24,
                    "height": 24,
                    "pos_x": "401",
                    "pos_y": "6",
                    "shadow": "",
                    "source": -1,
                    "threshold": 0,
                    "action": "none"
            "defs": {
                "path_5_7": {
                    "type": "def",
                    "id": "path_5_7",
                    "d": "M31 102  V 131.8   V 236 A 15 15 0 0 0 46 251  H 220",
                    "startSlot": "bottom_left",
                    "endSlot": "left_top"
                "path_7_22": {
                    "type": "def",
                    "id": "path_7_22",
                    "d": "M251 220  V 196.4 A 15 15 0 0 0 236 181.4  H 166 A 15 15 0 0 1 151 166.4   V 102",
                    "startSlot": "top_left",
                    "endSlot": "bottom_left"
                "path_7_27": {
                    "type": "def",
                    "id": "path_7_27",
                    "d": "M271 220  V 102",
                    "startSlot": "top",
                "path_7_31": {
                    "type": "def",
                    "id": "path_7_31",
                    "d": "M291 220  V 196.4 A 15 15 0 0 1 306 181.4  H 378 A 15 15 0 0 0 393 166.4  V 102",
                    "startSlot": "top_right",
                "path_14_7": {
                    "type": "def",
                    "id": "path_14_7",
                    "d": "M71 300  V 294.2   V 285 A 14 14 0 0 1 85 271  H 220",
                    "endSlot": "left"
            "lines": {
                "line_path_5_7": {
                    "type": "line",
                    "id": "line_path_5_7",
                    "href": "#path_5_7",
                    "color": "rgb(0, 0, 0)",
                    "shadow": ""
                "line_path_7_22": {
                    "type": "line",
                    "id": "line_path_7_22",
                    "href": "#path_7_22",
                    "shadow": ""
                "line_path_7_27": {
                    "type": "line",
                    "id": "line_path_7_27",
                    "href": "#path_7_27",
                    "shadow": ""
                "line_path_7_31": {
                    "type": "line",
                    "id": "line_path_7_31",
                    "href": "#path_7_31",
                    "shadow": ""
                "line_path_14_7": {
                    "type": "line",
                    "id": "line_path_14_7",
                    "href": "#path_14_7",
                    "shadow": ""
            "animations": {
                "anim_path_5_7": {
                    "type": "animation",
                    "id": "anim_path_5_7",
                    "source": 2,
                    "threshold": 0,
                    "animation_properties": "positive",
                    "animation_option": false,
                    "dots": 0,
                    "duration": 0,
                    "power": 0,
                    "animation_type": -1
                "anim_path_7_22": {
                    "id": "anim_path_7_22",
                    "source": 3,
                    "threshold": 0,
                    "dots": 0,
                    "duration": 0,
                    "power": 0,
                "anim_path_7_27": {
                    "id": "anim_path_7_27",
                    "source": 4,
                    "threshold": 0,
                    "dots": 0,
                    "duration": 0,
                    "power": 0,
                "anim_path_7_31": {
                    "id": "anim_path_7_31",
                    "source": 5,
                    "threshold": 0,
                    "dots": 0,
                    "duration": 0,
                    "power": 0,
                "anim_path_14_7": {
                    "id": "anim_path_14_7",
                    "color": "rgb(255, 15, 67)",
                    "source": 0,
                    "threshold": 0,
                    "dots": 0,
                    "duration": 0,
                    "power": 0,
            "datasources": {
                "0": {
                    "source": "sonoff.0.Haus.Stromzähler.MT175_P",
                    "alias": "Netzverbrauch"
                "1": {
                    "source": "0_userdata.0.Stromverbrauch_aktuell",
                    "alias": "Gesamtverbrauch"
                "2": {
                    "source": "sonoff.0.Haus.Balkonkraftwerk.ENERGY_Power",
                    "alias": "Balkonkraftwerk"
                "3": {
                    "source": "sonoff.0.Test.Steckdose3.ENERGY_Power",
                    "alias": "Proxmox"
                "4": {
                    "source": "sonoff.0.Test.Steckdose.ENERGY_Power",
                    "alias": "Tiefkühltruhe"
                "5": {
                    "source": "sonoff.0.Test.Steckdose2.ENERGY_Power",
                    "alias": "Fernseher"
        • SKB
          @wal Welche Fehlermeldung kommt beim Absturz?
          • Wal
            @skb ,
            siehe Log den ich gepostet habe.
            Armilar SKB 2 Replies Last reply Reply Quote 0
            • Armilar
              Armilar Most Active Forum Testing @Wal last edited by
              @wal
              @SKB
              energiefluss-erweitert.0
              2023-09-01 10:49:56.407	info	Requesting the following states: energiefluss-erweitert.0.configuration,mqtt.0.PV.Terrassendach.total.P_AC,sonoff.0.DZG_DWSB20_2H.DZG_Leistung_Aktuell,0_userdata.0.PV_Akku_Emulation.Akkustand,0_userdata.0.PV_Akku_Emulation.Leistung,shelly.0.shellypro3em#shellypro3em#1.EM0.TotalActivePower,0_userdata.0.Energiebilanz.Leistung.Verbrauch,sonoff.0.Kuehlschrank_Kueche.ENERGY_Power,sonoff.0.Waschmaschine.ENERGY_Power,sonoff.0.Geschirrspuelmaschine.ENERGY_Power,tuya.0.581550838caab5731891.5,sonoff.0.Mikrowelle.ENERGY_Power,sonoff.0.Kuehlschrank_HW.ENERGY_Power,sonoff.0.HW_LED_Unterbau.ENERGY_Power,0_userdata.0.Energiebilanz.Leistung.Verbrauch_HW,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Kueche,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Buero,sonoff.0.Airbowl_Buero.ENERGY_Power,sonoff.0.Buero_Schreibtisch.ENERGY_Power,sonoff.0.Buero_Server.ENERGY_Power,sonoff.0.Pool.ENERGY_Power,sonoff.0.Kaffemaschine.ENERGY_Power,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Rest,sonoff.0.Fritteuse.ENERGY_Power,pvforecast.0.summary.power.now,0_userdata.0.Stromzaehler.Aktuell.Bezug,0_userdata.0.Stromzaehler.Aktuell.EinspeisungWh,0_userdata.0.Stromzaehler.Aktuell.Bedarf,mqtt.0.PV.Terrassendach.total.YieldDay,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Esszimmer,shelly.0.SHDM-1#F3C218#1.lights.Power,sonoff.0.Esszimmer_Schreibtisch.ENERGY_Power,mqtt.0.PV.Terrassendach.Terrassendach.ch0.P_AC,mqtt.0.PV.Terrassendach.Terassendach2.ch0.P_AC,followthesun.0.current.altitude,followthesun.0.current.azimuth,0_userdata.0.Waermepumpe.Tag.Verbrauch_Total,0_userdata.0.Astro.01 - sunrise,0_userdata.0.Astro.07 - sunset,0_userdata.0.Zeit.Aktuell,mqtt.0.PV.Terrassendach.Terrassendach.ch0.active_PowerLimit,mqtt.0.PV.Terrassendach.Terassendach2.ch0.active_PowerLimit,sonoff.0.Pool.ENERGY_Today,sonoff.0.Kuehlschrank_Kueche.ENERGY_Today,sonoff.0.Kaffemaschine.ENERGY_Today,sonoff.0.Buero_Server.ENERGY_Today,sonoff.0.Buero_Schreibtisch.ENERGY_Today,sonoff.0.Esszimmer_Schreibtisch.ENERGY_Today,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Flur,sonoff.0.Treppenbeleuchtung_EG.Virtual_Energy_Power,shelly.0.SHSW-L#3C6105E43DD2#1.Relay0.Virtual_Energy_Power,sonoff.0.Licht_Flur_Vorne_EG.Virtual_Energy_Power,shelly.0.SHSW-L#84CCA8AE12A1#1.Relay0.Virtual_Energy_Power,0_userdata.0.Energiebilanz.Leistung.Verbrauch_Naehzimmer,0_userdata.0.Energiebilanz.Leistung.Verbrauch_GaesteWC,sonoff.0.Geschirrspuelmaschine.ENERGY_Today,sonoff.0.Waschmaschine.ENERGY_Today,sonoff.0.Kuehlschrank_HW.ENERGY_Today,sonoff.0.HW_LED_Unterbau.ENERGY_Today
              2023-09-01 10:49:56.406	info	Configuration loaded!
              2023-09-01 10:49:56.271	info	Adapter started. Loading config!
              2023-09-01 10:49:56.231	info	starting. Version 0.0.2-alpha.16 (non-npm: SKB-CGN/ioBroker.energiefluss-erweitert#b7d0fd6df1e7181a917b26c4e162aa1fe8c54078) in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
              2023-09-01 10:49:24.528	info	terminating
              2023-09-01 10:49:24.026	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              2023-09-01 10:49:24.025	info	terminating
              2023-09-01 10:49:24.025	info	Cleared interval for relative values!
              2023-09-01 10:49:24.023	error	Cannot read properties of undefined (reading 'log')
              2023-09-01 10:49:24.023	error	TypeError: Cannot read properties of undefined (reading 'log') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1148:19)
              2023-09-01 10:49:24.022	error	unhandled promise rejection: Cannot read properties of undefined (reading 'log')
              2023-09-01 10:49:24.022	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-09-01 10:49:23.961	warn	The adapter could not find the state 'shelly.0.SHSW-L#84CCA8AE12A1#1.Relay0.Virtual_Energy_Power'! Please review your configuration of the adapter!
              2023-09-01 10:49:23.959	warn	The adapter could not find the state 'shelly.0.SHSW-L#3C6105E43DD2#1.Relay0.Virtual_Energy_Power'! Please review your configuration of the adapter!
              2023-09-01 10:49:23.893	info	Adapter started. Loading config!
              2023-09-01 10:49:23.857	info	starting. Version 0.0.2-alpha.16 (non-npm: SKB-CGN/ioBroker.energiefluss-erweitert#b7d0fd6df1e7181a917b26c4e162aa1fe8c54078) in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
              habe den ioBroker auch mal neu gestartet. Folgendes steht im log - Habe auch den Eindruck, dass sich nicht alle Datasources sauber aktualisieren...
              • SKB
                SKB Developer Most Active @Armilar last edited by SKB
                @armilar sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
                @wal
                @SKB
                Ist ja auch so, da die States nicht gefunden werden.
                EDIT: Habe den Fehler mit dem "Log" beseitigt. Bitte nochmal drüber installieren und schauen, was passiert.
                • SKB
                  @wal Kannst Du nochmal drüber installieren und schauen, ob der Fehler noch auftritt?
                  Wal 2 Replies Last reply Reply Quote 0
                  • Wal
                    @skb ,
                    ja ist weg. 👍
                    • SKB
                      @wal Danke für den Hinweis und die Rückmeldung 🙂
                      • Wal
                        @skb ,
                        die Animation ist nicht mehr flüssig, die stockt alle 3sec. ist aber i. M. nicht wichtig. 😉
                        • SKB
                          @wal Dann wird dies vorher schon gewesen sein - an den Animationen habe ich seit einigen Versionen nichts geändert.
                          Wal 3 Replies Last reply Reply Quote 0
                          • Wal
                            @skb ,
                            leider nein, das stocken ist erst seit alpha 16.
                            Ich mache nochmal den recheck.
                            • Wal
                              @skb sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
                              Bin zurück gegangen und kein stocken, mach dir aber erst mal kein Stress.
                              • SKB
                                @wal Kannst du mal ein Beispiel aufnehmen?
                                • Wal
                                  @skb ,
                                  da legst dich nieder, wieder zurück auf die Neuste und auch kein stocken. 😉
                                  • SKB
                                    @wal vielleicht der Upload unvollständig. Aber gut, wenn es geht 😉
                                    • Armilar
                                      Armilar Most Active Forum Testing @SKB last edited by Armilar
                                      @skb
                                      Merkwürdig... Habe 2 Datenpunkte auf 0_userdate.0... vom Typ state/number. Damit errechne ich den Gesamtverbrauch und den Restverbrauch per JS. Wenn ich die GUI speicher und verlasse, dann stimmen die beiden Werte, jedoch werden sie in der GUI danach nicht mehr aktualisiert.
                                      Bei allen anderen ID's aktualisieren sich die Werte.
                                      Ist in der vorherigen Version nicht so...
                                      EDIT: im ioBroker ändern sich die Werte sekündlich...
                                      • SKB
                                        @armilar Danke für den Hinweis. Gemäß den Bestimmungen von ioBroker sollen Adapter bei fremden Datenpunkten nur reagieren, wenn "ACK" true gesetzt wird.
                                        Du kannst in deinen Javascripts, die die Punkte bearbeiten, einfach ein "ACK" true mitgeben:
                                        setState(Datenpunkt, Wert, true); // true am Ende
                                        Armilar F 2 Replies Last reply Reply Quote 1
                                        • Armilar
                                          @skb
                                          okay... das wars... aktualisieren sich wieder
                                          • SKB
                                            @armilar na perfekt 🙂
                                            81.1k
                                            vis
                                            191
                                            4363
                                            5669283
